commit 38e088546522e1e86d2b8f401a1354ad3a9b3303 upstream.
The NUMA balancing logic uses an arch-specific PROT_NONE page table flag
defined by pte_protnone() or pmd_protnone() to mark PTEs or huge page
PMDs respectively as requiring balancing upon a subsequent page fault.
User-defined PROT_NONE memory regions which also have this flag set will
not normally invoke the NUMA balancing code as do_page_fault() will send
a segfault to the process before handle_mm_fault() is even called.
However if access_remote_vm() is invoked to access a PROT_NONE region of
memory, handle_mm_fault() is called via faultin_page() and
__get_user_pages() without any access checks being performed, meaning
the NUMA balancing logic is incorrectly invoked on a non-NUMA memory
region.
A simple means of triggering this problem is to access PROT_NONE mmap'd
memory using /proc/self/mem which reliably results in the NUMA handling
functions being invoked when CONFIG_NUMA_BALANCING is set.
This issue was reported in bugzilla (issue 99101) which includes some
simple repro code.
There are BUG_ON() checks in do_numa_page() and do_huge_pmd_numa_page()
added at commit c0e7cad to avoid accidentally provoking strange
behaviour by attempting to apply NUMA balancing to pages that are in
fact PROT_NONE. The BUG_ON()'s are consistently triggered by the repro.
This patch moves the PROT_NONE check into mm/memory.c rather than
invoking BUG_ON() as faulting in these pages via faultin_page() is a
valid reason for reaching the NUMA check with the PROT_NONE page table
flag set and is therefore not always a bug.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=99101
Reported-by: Trevor Saunders <tbsaunde@tbsaunde.org>
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Marcelo Henrique Cerri <marcelo.cerri@canonical.com>
[cascardo: context adjustments were necessary]
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
commit 17839856fd588f4ab6b789f482ed3ffd7c403e1f upstream.
Doing a "get_user_pages()" on a copy-on-write page for reading can be
ambiguous: the page can be COW'ed at any time afterwards, and the
direction of a COW event isn't defined.
Yes, whoever writes to it will generally do the COW, but if the thread
that did the get_user_pages() unmapped the page before the write (and
that could happen due to memory pressure in addition to any outright
action), the writer could also just take over the old page instead.
End result: the get_user_pages() call might result in a page pointer
that is no longer associated with the original VM, and is associated
with - and controlled by - another VM having taken it over instead.
So when doing a get_user_pages() on a COW mapping, the only really safe
thing to do would be to break the COW when getting the page, even when
only getting it for reading.
At the same time, some users simply don't even care.
For example, the perf code wants to look up the page not because it
cares about the page, but because the code simply wants to look up the
physical address of the access for informational purposes, and doesn't
really care about races when a page might be unmapped and remapped
elsewhere.
This adds logic to force a COW event by setting FOLL_WRITE on any
copy-on-write mapping when FOLL_GET (or FOLL_PIN) is used to get a page
pointer as a result.
The current semantics end up being:
- __get_user_pages_fast(): no change. If you don't ask for a write,
you won't break COW. You'd better know what you're doing.
- get_user_pages_fast(): the fast-case "look it up in the page tables
without anything getting mmap_sem" now refuses to follow a read-only
page, since it might need COW breaking. Which happens in the slow
path - the fast path doesn't know if the memory might be COW or not.
- get_user_pages() (including the slow-path fallback for gup_fast()):
for a COW mapping, turn on FOLL_WRITE for FOLL_GET/FOLL_PIN, with
very similar semantics to FOLL_FORCE.
If it turns out that we want finer granularity (ie "only break COW when
it might actually matter" - things like the zero page are special and
don't need to be broken) we might need to push these semantics deeper
into the lookup fault path. So if people care enough, it's possible
that we might end up adding a new internal FOLL_BREAK_COW flag to go
with the internal FOLL_COW flag we already have for tracking "I had a
COW".
Alternatively, if it turns out that different callers might want to
explicitly control the forced COW break behavior, we might even want to
make such a flag visible to the users of get_user_pages() instead of
using the above default semantics.
But for now, this is mostly commentary on the issue (this commit message
being a lot bigger than the patch, and that patch in turn is almost all
comments), with that minimal "enable COW breaking early" logic using the
existing FOLL_WRITE behavior.
[ It might be worth noting that we've always had this ambiguity, and it
could arguably be seen as a user-space issue.
You only get private COW mappings that could break either way in
situations where user space is doing cooperative things (ie fork()
before an execve() etc), but it _is_ surprising and very subtle, and
fork() is supposed to give you independent address spaces.
So let's treat this as a kernel issue and make the semantics of
get_user_pages() easier to understand. Note that obviously a true
shared mapping will still get a page that can change under us, so this
does _not_ mean that get_user_pages() somehow returns any "stable"
page ]
[surenb: backport notes
Since gup_pgd_range does not exist, made appropriate changes on
the the gup_huge_pgd, gup_huge_pd and gup_pud_range calls instead.
Replaced (gup_flags | FOLL_WRITE) with write=1 in gup_huge_pgd,
gup_huge_pd and gup_pud_range.
Removed FOLL_PIN usage in should_force_cow_break since it's missing in
the earlier kernels.]
Reported-by: Jann Horn <jannh@google.com>
Tested-by: Christoph Hellwig <hch@lst.de>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Kirill Shutemov <kirill@shutemov.name>
Acked-by: Jan Kara <jack@suse.cz>
Cc: Matthew Wilcox <willy@infradead.org>
[surenb: backport to 4.4 kernel]
Signed-off-by: Suren Baghdasaryan <surenb@google.com>
commit 7ad69832f37e3cea8557db6df7c793905f1135e8 upstream.
When we free a page whose order is very close to MAX_ORDER and greater
than pageblock_order, it wastes some CPU cycles to increase max_order to
MAX_ORDER one by one and check the pageblock migratetype of that page
repeatedly especially when MAX_ORDER is much larger than pageblock_order.
We also should not be checking migratetype of buddy when "order ==
MAX_ORDER - 1" as the buddy pfn may be invalid, so adjust the condition.
With the new check, we don't need the max_order check anymore, so we
replace it.
Also adjust max_order initialization so that it's lower by one than
previously, which makes the code hopefully more clear.
Link: https://lkml.kernel.org/r/20201204155109.55451-1-songmuchun@bytedance.com
Fixes: d9dddbf55667 ("mm/page_alloc: prevent merging between isolated and other pageblocks")
Signed-off-by: Muchun Song <songmuchun@bytedance.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Oscar Salvador <osalvador@suse.de>
Reviewed-by: David Hildenbrand <david@redhat.com>
commit 13ab183d138f607d885e995d625e58d47678bf97 upstream.
Commit bde5f6bc68db ("kmemleak: add scheduling point to
kmemleak_scan()") tries to rate-limit the frequency of cond_resched()
calls, but does it in a way which might incur an expensive division
operation in the inner loop. Simplify this.
Fixes: bde5f6bc68db5 ("kmemleak: add scheduling point to kmemleak_scan()")
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Michal Hocko <mhocko@kernel.org>
commit 552546366a30d88bd1d6f5efe848b2ab50fd57e5 upstream.
A new clang diagnostic (-Wsizeof-array-div) warns about the calculation
to determine the number of u32's in an array of unsigned longs.
Suppress warning by adding parentheses.
While looking at the above issue, noticed that the 'address' parameter
to hugetlb_fault_mutex_hash is no longer used. So, remove it from the
definition and all callers.
No functional change.
Link: http://lkml.kernel.org/r/20190919011847.18400-1-mike.kravetz@oracle.com
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Ilie Halip <ilie.halip@gmail.com>
Cc: David Bolvansky <david.bolvansky@gmail.com>
Commit 93b3a674485f6a4b8ffff85d1682d5e8b7c51560 upstream
Commit 93b3a674485f ("mm,vmstat: reduce zone->lock holding time by
/proc/pagetypeinfo") upstream caps the number of iterations over each
free_list at 100,000, and also drops the zone->lock in between each
migrate type. Capping the iteration count alters the file contents in
some cases, which means this approach may not be suitable for stable
backports.
However, dropping zone->lock in between migrate types (and, as a result,
page orders) will not change the /proc/pagetypeinfo file contents. It
can significantly reduce the length of time spent with IRQs disabled,
which can prevent missed interrupts or soft lockups which we have
observed on systems with particularly large memory.
Thus, this commit is a modified version of the upstream one which only
drops the lock in between migrate types.
Fixes: 467c996c1e19 ("Print out statistics in relation to fragmentation avoidance to /proc/pagetypeinfo")
Signed-off-by: Stephen Brennan <stephen.s.brennan@oracle.com>
Reviewed-by: Aruna Ramakrishna <aruna.ramakrishna@oracle.com>
Reviewed-by: Khalid Aziz <khalid.aziz@oracle.com>
[ Upstream commit c89a384e2551c692a9fe60d093fd7080f50afc51 ]
When removing rmap_item from stable tree, STABLE_FLAG of rmap_item is
cleared with head reserved. So the following scenario might happen: For
ksm page with rmap_item1:
cmp_and_merge_page
stable_node->head = &migrate_nodes;
remove_rmap_item_from_tree, but head still equal to stable_node;
try_to_merge_with_ksm_page failed;
return;
For the same ksm page with rmap_item2, stable node migration succeed this
time. The stable_node->head does not equal to migrate_nodes now. For ksm
page with rmap_item1 again:
cmp_and_merge_page
stable_node->head != &migrate_nodes && rmap_item->head == stable_node
return;
We would miss the rmap_item for stable_node and might result in failed
rmap_walk_ksm(). Fix this by set rmap_item->head to NULL when rmap_item
is removed from stable tree.
Link: https://lkml.kernel.org/r/20210330140228.45635-5-linmiaohe@huawei.com
Fixes: 4146d2d673e8 ("ksm: make !merge_across_nodes migration safe")
Signed-off-by: Miaohe Lin <linmiaohe@huawei.com>
commit e720e7d0e983bf05de80b231bccc39f1487f0f16 upstream.
There are code paths that rely on zero_pfn to be fully initialized
before core_initcall. For example, wq_sysfs_init() is a core_initcall
function that eventually results in a call to kernel_execve, which
causes a page fault with a subsequent mmput. If zero_pfn is not
initialized by then it may not get cleaned up properly and result in an
error:
BUG: Bad rss-counter state mm:(ptrval) type:MM_ANONPAGES val:1
Here is an analysis of the race as seen on a MIPS device. On this
particular MT7621 device (Ubiquiti ER-X), zero_pfn is PFN 0 until
initialized, at which point it becomes PFN 5120:
1. wq_sysfs_init calls into kobject_uevent_env at core_initcall:
kobject_uevent_env+0x7e4/0x7ec
kset_register+0x68/0x88
bus_register+0xdc/0x34c
subsys_virtual_register+0x34/0x78
wq_sysfs_init+0x1c/0x4c
do_one_initcall+0x50/0x1a8
kernel_init_freeable+0x230/0x2c8
kernel_init+0x10/0x100
ret_from_kernel_thread+0x14/0x1c
2. kobject_uevent_env() calls call_usermodehelper_exec() which executes
kernel_execve asynchronously.
3. Memory allocations in kernel_execve cause a page fault, bumping the
MM reference counter:
add_mm_counter_fast+0xb4/0xc0
handle_mm_fault+0x6e4/0xea0
__get_user_pages.part.78+0x190/0x37c
__get_user_pages_remote+0x128/0x360
get_arg_page+0x34/0xa0
copy_string_kernel+0x194/0x2a4
kernel_execve+0x11c/0x298
call_usermodehelper_exec_async+0x114/0x194
4. In case zero_pfn has not been initialized yet, zap_pte_range does
not decrement the MM_ANONPAGES RSS counter and the BUG message is
triggered shortly afterwards when __mmdrop checks the ref counters:
__mmdrop+0x98/0x1d0
free_bprm+0x44/0x118
kernel_execve+0x160/0x1d8
To avoid races such as described above, initialize init_zero_pfn at
early_initcall level. Depending on the architecture, ZERO_PAGE is
either constant or gets initialized even earlier, at paging_init, so
there is no issue with initializing zero_pfn earlier.
Link: https://lkml.kernel.org/r/CALCv0x2YqOXEAy2Q=hafjhHCtTHVodChv1qpM=niAXOpqEbt7w@mail.gmail.com
Signed-off-by: Ilya Lipnitskiy <ilya.lipnitskiy@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: stable@vger.kernel.org
Tested-by: 周琰杰 (Zhou Yanjie) <zhouyanjie@wanyeetech.com>
commit 9b1ea29bc0d7b94d420f96a0f4121403efc3dd85 upstream.
This reverts commit 8ff60eb052eeba95cfb3efe16b08c9199f8121cf.
The kernel test robot reports a huge performance regression due to the
commit, and the reason seems fairly straightforward: when there is
contention on the page list (which is what causes acquire_slab() to
fail), we do _not_ want to just loop and try again, because that will
transfer the contention to the 'n->list_lock' spinlock we hold, and
just make things even worse.
This is admittedly likely a problem only on big machines - the kernel
test robot report comes from a 96-thread dual socket Intel Xeon Gold
6252 setup, but the regression there really is quite noticeable:
-47.9% regression of stress-ng.rawpkt.ops_per_sec
and the commit that was marked as being fixed (7ced37197196: "slub:
Acquire_slab() avoid loop") actually did the loop exit early very
intentionally (the hint being that "avoid loop" part of that commit
message), exactly to avoid this issue.
The correct thing to do may be to pick some kind of reasonable middle
ground: instead of breaking out of the loop on the very first sign of
contention, or trying over and over and over again, the right thing may
be to re-try _once_, and then give up on the second failure (or pick
your favorite value for "once"..).
Reported-by: kernel test robot <oliver.sang@intel.com>
Link: https://lore.kernel.org/lkml/20210301080404.GF12822@xsang-OptiPlex-9020/
Cc: Jann Horn <jannh@google.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Christoph Lameter <cl@linux.com>
commit caf6912f3f4af7232340d500a4a2008f81b93f14 upstream.
We're not factoring in the start of the file for where to write and
read the swapfile, which leads to very unfortunate side effects of
writing where we should not be...
[This issue only affects swapfiles on filesystems on top of blockdevs
that implement rw_page ops (brd, zram, btt, pmem), and not on top of any
other block devices, in contrast to the upstream commit fix.]
Fixes: dd6bd0d9c7db ("swap: use bdev_read_page() / bdev_write_page()")
Cc: stable@vger.kernel.org # 4.4
Signed-off-by: Anthony Iliopoulos <ailiop@suse.com>
commit 2395928158059b8f9858365fce7713ce7fef62e4 upstream.
There exists multiple path may do zram compaction concurrently.
1. auto-compaction triggered during memory reclaim
2. userspace utils write zram<id>/compaction node
So, multiple threads may call zs_shrinker_scan/zs_compact concurrently.
But pages_compacted is a per zsmalloc pool variable and modification
of the variable is not serialized(through under class->lock).
There are two issues here:
1. the pages_compacted may not equal to total number of pages
freed(due to concurrently add).
2. zs_shrinker_scan may not return the correct number of pages
freed(issued by current shrinker).
The fix is simple:
1. account the number of pages freed in zs_compact locally.
2. use actomic variable pages_compacted to accumulate total number.
Link: https://lkml.kernel.org/r/20210202122235.26885-1-wu-yan@tcl.com
Fixes: 860c707dca155a56 ("zsmalloc: account the number of compacted pages")
Signed-off-by: Rokudo Yan <wu-yan@tcl.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: <stable@vger.kernel.org>
commit a1ba9da8f0f9a37d900ff7eff66482cf7de8015e upstream.
The current code would unnecessarily expand the address range. Consider
one example, (start, end) = (1G-2M, 3G+2M), and (vm_start, vm_end) =
(1G-4M, 3G+4M), the expected adjustment should be keep (1G-2M, 3G+2M)
without expand. But the current result will be (1G-4M, 3G+4M). Actually,
the range (1G-4M, 1G) and (3G, 3G+4M) would never been involved in pmd
sharing.
After this patch, we will check that the vma span at least one PUD aligned
size and the start,end range overlap the aligned range of vma.
With above example, the aligned vma range is (1G, 3G), so if (start, end)
range is within (1G-4M, 1G), or within (3G, 3G+4M), then no adjustment to
both start and end. Otherwise, we will have chance to adjust start
downwards or end upwards without exceeding (vm_start, vm_end).
Mike:
: The 'adjusted range' is used for calls to mmu notifiers and cache(tlb)
: flushing. Since the current code unnecessarily expands the range in some
: cases, more entries than necessary would be flushed. This would/could
: result in performance degradation. However, this is highly dependent on
: the user runtime. Is there a combination of vma layout and calls to
: actually hit this issue? If the issue is hit, will those entries
: unnecessarily flushed be used again and need to be unnecessarily reloaded?
Link: https://lkml.kernel.org/r/20210104081631.2921415-1-lixinhai.lxh@gmail.com
Fixes: 75802ca66354 ("mm/hugetlb: fix calculation of adjust_range_if_pmd_sharing_possible")
Signed-off-by: Li Xinhai <lixinhai.lxh@gmail.com>
Suggested-by: Mike Kravetz <mike.kravetz@oracle.com>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Peter Xu <peterx@redhat.com>
commit dbfee5aee7e54f83d96ceb8e3e80717fac62ad63 upstream.
page structs are not guaranteed to be contiguous for gigantic pages. The
routine update_and_free_page can encounter a gigantic page, yet it assumes
page structs are contiguous when setting page flags in subpages.
If update_and_free_page encounters non-contiguous page structs, we can see
“BUG: Bad page state in process …” errors.
Non-contiguous page structs are generally not an issue. However, they can
exist with a specific kernel configuration and hotplug operations. For
example: Configure the kernel with CONFIG_SPARSEMEM and
!CONFIG_SPARSEMEM_VMEMMAP. Then, hotplug add memory for the area where
the gigantic page will be allocated. Zi Yan outlined steps to reproduce
here [1].
[1] https://lore.kernel.org/linux-mm/16F7C58B-4D79-41C5-9B64-A1A1628F4AF2@nvidia.com/
Link: https://lkml.kernel.org/r/20210217184926.33567-1-mike.kravetz@oracle.com
Fixes: 944d9fec8d7a ("hugetlb: add support for gigantic page allocation at runtime")
Signed-off-by: Zi Yan <ziy@nvidia.com>
Cc: Zi Yan <ziy@nvidia.com>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: "Kirill A . Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Oscar Salvador <osalvador@suse.de>
Cc: Joao Martins <joao.m.martins@oracle.com>
commit 7ffddd499ba6122b1a07828f023d1d67629aa017 upstream
There is a race condition between __free_huge_page()
and dissolve_free_huge_page().
CPU0: CPU1:
// page_count(page) == 1
put_page(page)
__free_huge_page(page)
dissolve_free_huge_page(page)
spin_lock(&hugetlb_lock)
// PageHuge(page) && !page_count(page)
update_and_free_page(page)
// page is freed to the buddy
spin_unlock(&hugetlb_lock)
clear_page_huge_active(page)
enqueue_huge_page(page)
// It is wrong, the page is already freed
The race window is between put_page() and dissolve_free_huge_page().
We should make sure that the page is already on the free list when it is
dissolved.
As a result __free_huge_page would corrupt page(s) already in the buddy
allocator.
Link: https://lkml.kernel.org/r/20210115124942.46403-4-songmuchun@bytedance.com
Fixes: c8721bbbdd36 ("mm: memory-hotplug: enable memory hotplug to handle hugepage")
Cc: David Hildenbrand <david@redhat.com>
Cc: Yang Shi <shy828301@gmail.com>
[sudip: adjust context]
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit cc2205a67dec5a700227a693fc113441e73e4641 ]
In hugetlb_sysfs_add_hstate(), we would do kobject_put() on hstate_kobjs
when failed to create sysfs group but forget to set hstate_kobjs to NULL.
Then in hugetlb_register_node() error path, we may free it again via
hugetlb_unregister_node().
Link: https://lkml.kernel.org/r/20210107123249.36964-1-linmiaohe@huawei.com
Fixes: a3437870160c ("hugetlb: new sysfs interface")
Reviewed-by: Muchun Song <smuchun@gmail.com>
[ Upstream commit 90a3e375d324b2255b83e3dd29e99e2b05d82aaf ]
Since commit 42e4089c7890 ("x86/speculation/l1tf: Disallow non privileged
high MMIO PROT_NONE mappings"), when the first pfn modify is not allowed,
we would break the loop with pte unchanged. Then the wrong pte - 1 would
be passed to pte_unmap_unlock.
Andi said:
"While the fix is correct, I'm not sure if it actually is a real bug.
Is there any architecture that would do something else than unlocking
the underlying page? If it's just the underlying page then it should
be always the same page, so no bug"
Link: https://lkml.kernel.org/r/20210109080118.20885-1-linmiaohe@huawei.com
Fixes: 42e4089c789 ("x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappings")
Signed-off-by: Hongxiang Lou <louhongxiang@huawei.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
[ Upstream commit 2dcb3964544177c51853a210b6ad400de78ef17d ]
With kaslr the kernel image is placed at a random place, so starting the
bottom-up allocation with the kernel_end can result in an allocation
failure and a warning like this one:
hugetlb_cma: reserve 2048 MiB, up to 2048 MiB per node
memblock: bottom-up allocation failed, memory hotremove may be affected
WARNING: CPU: 0 PID: 0 at mm/memblock.c:332 memblock_find_in_range_node+0x178/0x25a
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 5.10.0+ #1169
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.14.0-1.fc33 04/01/2014
RIP: 0010:memblock_find_in_range_node+0x178/0x25a
Code: e9 6d ff ff ff 48 85 c0 0f 85 da 00 00 00 80 3d 9b 35 df 00 00 75 15 48 c7 c7 c0 75 59 88 c6 05 8b 35 df 00 01 e8 25 8a fa ff <0f> 0b 48 c7 44 24 20 ff ff ff ff 44 89 e6 44 89 ea 48 c7 c1 70 5c
RSP: 0000:ffffffff88803d18 EFLAGS: 00010086 ORIG_RAX: 0000000000000000
RAX: 0000000000000000 RBX: 0000000240000000 RCX: 00000000ffffdfff
RDX: 00000000ffffdfff RSI: 00000000ffffffea RDI: 0000000000000046
RBP: 0000000100000000 R08: ffffffff88922788 R09: 0000000000009ffb
R10: 00000000ffffe000 R11: 3fffffffffffffff R12: 0000000000000000
R13: 0000000000000000 R14: 0000000080000000 R15: 00000001fb42c000
FS: 0000000000000000(0000) GS:ffffffff88f71000(0000) knlGS:0000000000000000
CR2: ffffa080fb401000 CR3: 00000001fa80a000 CR4: 00000000000406b0
Call Trace:
memblock_alloc_range_nid+0x8d/0x11e
cma_declare_contiguous_nid+0x2c4/0x38c
hugetlb_cma_reserve+0xdc/0x128
flush_tlb_one_kernel+0xc/0x20
native_set_fixmap+0x82/0xd0
flat_get_apic_id+0x5/0x10
register_lapic_address+0x8e/0x97
setup_arch+0x8a5/0xc3f
start_kernel+0x66/0x547
load_ucode_bsp+0x4c/0xcd
secondary_startup_64_no_verify+0xb0/0xbb
random: get_random_bytes called from __warn+0xab/0x110 with crng_init=0
---[ end trace f151227d0b39be70 ]---
At the same time, the kernel image is protected with memblock_reserve(),
so we can just start searching at PAGE_SIZE. In this case the bottom-up
allocation has the same chances to success as a top-down allocation, so
there is no reason to fallback in the case of a failure. All together it
simplifies the logic.
Link: https://lkml.kernel.org/r/20201217201214.3414100-2-guro@fb.com
Fixes: 8fabc623238e ("powerpc: Ensure that swiotlb buffer is allocated from low memory")
Signed-off-by: Roman Gushchin <guro@fb.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: Rik van Riel <riel@surriel.com>
Cc: Wonhyuk Yang <vvghjk1234@gmail.com>
Cc: Thiago Jung Bauermann <bauerman@linux.ibm.com>
[ Upstream commit 68f23b89067fdf187763e75a56087550624fdbee ]
Without memcg, there is a one-to-one mapping between the bdi and
bdi_writeback structures. In this world, things are fairly
straightforward; the first thing bdi_unregister() does is to shutdown
the bdi_writeback structure (or wb), and part of that writeback ensures
that no other work queued against the wb, and that the wb is fully
drained.
With memcg, however, there is a one-to-many relationship between the bdi
and bdi_writeback structures; that is, there are multiple wb objects
which can all point to a single bdi. There is a refcount which prevents
the bdi object from being released (and hence, unregistered). So in
theory, the bdi_unregister() *should* only get called once its refcount
goes to zero (bdi_put will drop the refcount, and when it is zero,
release_bdi gets called, which calls bdi_unregister).
Unfortunately, del_gendisk() in block/gen_hd.c never got the memo about
the Brave New memcg World, and calls bdi_unregister directly. It does
this without informing the file system, or the memcg code, or anything
else. This causes the root wb associated with the bdi to be
unregistered, but none of the memcg-specific wb's are shutdown. So when
one of these wb's are woken up to do delayed work, they try to
dereference their wb->bdi->dev to fetch the device name, but
unfortunately bdi->dev is now NULL, thanks to the bdi_unregister()
called by del_gendisk(). As a result, *boom*.
Fortunately, it looks like the rest of the writeback path is perfectly
happy with bdi->dev and bdi->owner being NULL, so the simplest fix is to
create a bdi_dev_name() function which can handle bdi->dev being NULL.
This also allows us to bulletproof the writeback tracepoints to prevent
them from dereferencing a NULL pointer and crashing the kernel if one is
tracing with memcg's enabled, and an iSCSI device dies or a USB storage
stick is pulled.
The most common way of triggering this will be hotremoval of a device
while writeback with memcg enabled is going on. It was triggering
several times a day in a heavily loaded production environment.
Google Bug Id: 145475544
Link: https://lore.kernel.org/r/20191227194829.150110-1-tytso@mit.edu
Link: http://lkml.kernel.org/r/20191228005211.163952-1-tytso@mit.edu
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: Chris Mason <clm@fb.com>
Cc: Tejun Heo <tj@kernel.org>
commit ecbf4724e6061b4b01be20f6d797d64d462b2bc8 upstream.
The page_huge_active() can be called from scan_movable_pages() which do
not hold a reference count to the HugeTLB page. So when we call
page_huge_active() from scan_movable_pages(), the HugeTLB page can be
freed parallel. Then we will trigger a BUG_ON which is in the
page_huge_active() when CONFIG_DEBUG_VM is enabled. Just remove the
VM_BUG_ON_PAGE.
Link: https://lkml.kernel.org/r/20210115124942.46403-6-songmuchun@bytedance.com
Fixes: 7e1f049efb86 ("mm: hugetlb: cleanup using paeg_huge_active()")
commit 0eb2df2b5629794020f75e94655e1994af63f0d4 upstream.
There is a race between isolate_huge_page() and __free_huge_page().
CPU0: CPU1:
if (PageHuge(page))
put_page(page)
set_compound_page_dtor(page,
NULL_COMPOUND_DTOR)
isolate_huge_page(page)
// trigger BUG_ON
VM_BUG_ON_PAGE(!PageHead(page), page)
// trigger BUG_ON
VM_BUG_ON_PAGE(!PageHuge(page), page)
When we isolate a HugeTLB page on CPU0. Meanwhile, we free it to the
buddy allocator on CPU1. Then, we can trigger a BUG_ON on CPU0, because
it is already freed to the buddy allocator.
Link: https://lkml.kernel.org/r/20210115124942.46403-5-songmuchun@bytedance.com
commit 585fc0d2871c9318c949fbf45b1f081edd489e96 upstream.
If a new hugetlb page is allocated during fallocate it will not be
marked as active (set_page_huge_active) which will result in a later
isolate_huge_page failure when the page migration code would like to
move that page. Such a failure would be unexpected and wrong.
Only export set_page_huge_active, just leave clear_page_huge_active as
static. Because there are no external users.
Link: https://lkml.kernel.org/r/20210115124942.46403-3-songmuchun@bytedance.com
Fixes: 70c3547e36f5 (hugetlbfs: add hugetlbfs_fallocate())
commit 757fed1d0898b893d7daa84183947c70f27632f3 upstream.
This reverts commit dde3c6b72a16c2db826f54b2d49bdea26c3534a2.
syzbot report a double-free bug. The following case can cause this bug.
- mm/slab_common.c: create_cache(): if the __kmem_cache_create() fails,
it does:
out_free_cache:
kmem_cache_free(kmem_cache, s);
- but __kmem_cache_create() - at least for slub() - will have done
sysfs_slab_add(s)
-> sysfs_create_group() .. fails ..
-> kobject_del(&s->kobj); .. which frees s ...
We can't remove the kmem_cache_free() in create_cache(), because other
error cases of __kmem_cache_create() do not free this.
So, revert the commit dde3c6b72a16 ("mm/slub: fix a memory leak in
sysfs_slab_add()") to fix this.
Reported-by: syzbot+d0bd96b4696c1ef67991@syzkaller.appspotmail.com
Fixes: dde3c6b72a16 ("mm/slub: fix a memory leak in sysfs_slab_add()")
Signed-off-by: Wang Hai <wanghai38@huawei.com>
commit 8ff60eb052eeba95cfb3efe16b08c9199f8121cf upstream.
acquire_slab() fails if there is contention on the freelist of the page
(probably because some other CPU is concurrently freeing an object from
the page). In that case, it might make sense to look for a different page
(since there might be more remote frees to the page from other CPUs, and
we don't want contention on struct page).
However, the current code accidentally stops looking at the partial list
completely in that case. Especially on kernels without CONFIG_NUMA set,
this means that get_partial() fails and new_slab_objects() falls back to
new_slab(), allocating new pages. This could lead to an unnecessary
increase in memory fragmentation.
Link: https://lkml.kernel.org/r/20201228130853.1871516-1-jannh@google.com
Fixes: 7ced37197196 ("slub: Acquire_slab() avoid loop")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
commit 0eb98f1588c2cc7a79816d84ab18a55d254f481c upstream.
The huge page size is encoded for VM_FAULT_HWPOISON errors only. So if
we return VM_FAULT_HWPOISON, huge page size would just be ignored.
Link: https://lkml.kernel.org/r/20210107123449.38481-1-linmiaohe@huawei.com
Fixes: aa50d3a7aa81 ("Encode huge page size for VM_FAULT_HWPOISON errors")
commit bfe8cc1db02ab243c62780f17fc57f65bde0afe1 upstream.
Alexander reported a syzkaller / KASAN finding on s390, see below for
complete output.
In do_huge_pmd_anonymous_page(), the pre-allocated pagetable will be
freed in some cases. In the case of userfaultfd_missing(), this will
happen after calling handle_userfault(), which might have released the
mmap_lock. Therefore, the following pte_free(vma->vm_mm, pgtable) will
access an unstable vma->vm_mm, which could have been freed or re-used
already.
For all architectures other than s390 this will go w/o any negative
impact, because pte_free() simply frees the page and ignores the
passed-in mm. The implementation for SPARC32 would also access
mm->page_table_lock for pte_free(), but there is no THP support in
SPARC32, so the buggy code path will not be used there.
For s390, the mm->context.pgtable_list is being used to maintain the 2K
pagetable fragments, and operating on an already freed or even re-used
mm could result in various more or less subtle bugs due to list /
pagetable corruption.
Fix this by calling pte_free() before handle_userfault(), similar to how
it is already done in __do_huge_pmd_anonymous_page() for the WRITE /
non-huge_zero_page case.
Commit 6b251fc96cf2c ("userfaultfd: call handle_userfault() for
userfaultfd_missing() faults") actually introduced both, the
do_huge_pmd_anonymous_page() and also __do_huge_pmd_anonymous_page()
changes wrt to calling handle_userfault(), but only in the latter case
it put the pte_free() before calling handle_userfault().
BUG: KASAN: use-after-free in do_huge_pmd_anonymous_page+0xcda/0xd90 mm/huge_memory.c:744
Read of size 8 at addr 00000000962d6988 by task syz-executor.0/9334
CPU: 1 PID: 9334 Comm: syz-executor.0 Not tainted 5.10.0-rc1-syzkaller-07083-g4c9720875573 #0
Hardware name: IBM 3906 M04 701 (KVM/Linux)
Call Trace:
create_huge_pmd mm/memory.c:4256 [inline]
__handle_mm_fault+0xe6e/0x1068 mm/memory.c:4480
handle_mm_fault+0x288/0x748 mm/memory.c:4607
do_exception+0x394/0xae0 arch/s390/mm/fault.c:479
do_dat_exception+0x34/0x80 arch/s390/mm/fault.c:567
pgm_check_handler+0x1da/0x22c arch/s390/kernel/entry.S:706
copy_from_user_mvcos arch/s390/lib/uaccess.c:111 [inline]
raw_copy_from_user+0x3a/0x88 arch/s390/lib/uaccess.c:174
_copy_from_user+0x48/0xa8 lib/usercopy.c:16
copy_from_user include/linux/uaccess.h:192 [inline]
__do_sys_sigaltstack kernel/signal.c:4064 [inline]
__s390x_sys_sigaltstack+0xc8/0x240 kernel/signal.c:4060
system_call+0xe0/0x28c arch/s390/kernel/entry.S:415
Allocated by task 9334:
slab_alloc_node mm/slub.c:2891 [inline]
slab_alloc mm/slub.c:2899 [inline]
kmem_cache_alloc+0x118/0x348 mm/slub.c:2904
vm_area_dup+0x9c/0x2b8 kernel/fork.c:356
__split_vma+0xba/0x560 mm/mmap.c:2742
split_vma+0xca/0x108 mm/mmap.c:2800
mlock_fixup+0x4ae/0x600 mm/mlock.c:550
apply_vma_lock_flags+0x2c6/0x398 mm/mlock.c:619
do_mlock+0x1aa/0x718 mm/mlock.c:711
__do_sys_mlock2 mm/mlock.c:738 [inline]
__s390x_sys_mlock2+0x86/0xa8 mm/mlock.c:728
Freed by task 9333:
slab_free mm/slub.c:3142 [inline]
kmem_cache_free+0x7c/0x4b8 mm/slub.c:3158
__vma_adjust+0x7b2/0x2508 mm/mmap.c:960
vma_merge+0x87e/0xce0 mm/mmap.c:1209
userfaultfd_release+0x412/0x6b8 fs/userfaultfd.c:868
__fput+0x22c/0x7a8 fs/file_table.c:281
task_work_run+0x200/0x320 kernel/task_work.c:151
tracehook_notify_resume include/linux/tracehook.h:188 [inline]
do_notify_resume+0x100/0x148 arch/s390/kernel/signal.c:538
system_call+0xe6/0x28c arch/s390/kernel/entry.S:416
The buggy address belongs to the object at 00000000962d6948 which belongs to the cache vm_area_struct of size 200
The buggy address is located 64 bytes inside of 200-byte region [00000000962d6948, 00000000962d6a10)
The buggy address belongs to the page: page:00000000313a09fe refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x962d6 flags: 0x3ffff00000000200(slab)
raw: 3ffff00000000200 000040000257e080 0000000c0000000c 000000008020ba00
raw: 0000000000000000 000f001e00000000 ffffffff00000001 0000000096959501
page dumped because: kasan: bad access detected
page->mem_cgroup:0000000096959501
Memory state around the buggy address:
00000000962d6880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000000962d6900: 00 fc fc fc fc fc fc fc fc fa fb fb fb fb fb fb
>00000000962d6980: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
00000000962d6a00: fb fb fc fc fc fc fc fc fc fc 00 00 00 00 00 00
00000000962d6a80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Changes for v4.4 stable:
- Make it apply w/o
* Commit 4cf58924951ef ("mm: treewide: remove unused address argument
from pte_alloc functions")
* Commit 2b7403035459c ("mm: Change return type int to vm_fault_t for
fault handlers")
* Commit 82b0f8c39a386 ("mm: join struct fault_env and vm_fault")
* Commit bae473a423f65 ("mm: introduce fault_env")
* Commit 6fcb52a56ff60 ("thp: reduce usage of huge zero page's atomic counter")
Fixes: 6b251fc96cf2c ("userfaultfd: call handle_userfault() for userfaultfd_missing() faults")
Reported-by: Alexander Egorenkov <egorenar@linux.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@linux.ibm.com>
Cc: Heiko Carstens <hca@linux.ibm.com>
Cc: <stable@vger.kernel.org> [4.3+]
Link: https://lkml.kernel.org/r/20201110190329.11920-1-gerald.schaefer@linux.ibm.com
[ Upstream commit 3f08842098e842c51e3b97d0dcdebf810b32558e ]
When flags in queue_pages_pte_range don't have MPOL_MF_MOVE or
MPOL_MF_MOVE_ALL bits, code breaks and passing origin pte - 1 to
pte_unmap_unlock seems like not a good idea.
queue_pages_pte_range can run in MPOL_MF_MOVE_ALL mode which doesn't
migrate misplaced pages but returns with EIO when encountering such a
page. Since commit a7f40cfe3b7a ("mm: mempolicy: make mbind() return
-EIO when MPOL_MF_STRICT is specified") and early break on the first pte
in the range results in pte_unmap_unlock on an underflow pte. This can
lead to lockups later on when somebody tries to lock the pte resp.
page_table_lock again..
Fixes: a7f40cfe3b7a ("mm: mempolicy: make mbind() return -EIO when MPOL_MF_STRICT is specified")
Signed-off-by: Shijie Luo <luoshijie1@huawei.com>
Cc: Miaohe Lin <linmiaohe@huawei.com>
Cc: Feilong Lin <linfeilong@huawei.com>
Cc: Shijie Luo <luoshijie1@huawei.com>
Link: https://lkml.kernel.org/r/20201019074853.50856-1-luoshijie1@huawei.com
commit 64f8ebaf115bcddc4aaa902f981c57ba6506bc42 upstream.
Memory access coded in an assembly won't be seen by KASAN as a compiler
can instrument only C code. Add kasan_check_[read,write]() API which is
going to be used to check a certain memory range.
Link: http://lkml.kernel.org/r/1462538722-1574-3-git-send-email-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Acked-by: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
[bwh: Backported to 4.4: drop change in MAINTAINERS]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 936bb4bbbb832f81055328b84e5afe1fc7246a8d upstream.
When bogus memory access happens in mem[set,cpy,move]() it's usually
caller's fault. So don't blame mem[set,cpy,move]() in bug report, blame
the caller instead.
Before:
BUG: KASAN: out-of-bounds access in memset+0x23/0x40 at <address>
After:
BUG: KASAN: out-of-bounds access in <memset_caller> at <address>
Link: http://lkml.kernel.org/r/1462538722-1574-2-git-send-email-aryabinin@virtuozzo.com
[ Upstream commit 09ef5283fd96ac424ef0e569626f359bf9ab86c9 ]
On passing requirement to vm_unmapped_area, arch_get_unmapped_area and
arch_get_unmapped_area_topdown did not set align_offset. Internally on
both unmapped_area and unmapped_area_topdown, if info->align_mask is 0,
then info->align_offset was meaningless.
But commit df529cabb7a2 ("mm: mmap: add trace point of
vm_unmapped_area") always prints info->align_offset even though it is
uninitialized.
Fix this uninitialized value issue by setting it to 0 explicitly.
Before:
vm_unmapped_area: addr=0x755b155000 err=0 total_vm=0x15aaf0 flags=0x1 len=0x109000 lo=0x8000 hi=0x75eed48000 mask=0x0 ofs=0x4022
After:
vm_unmapped_area: addr=0x74a4ca1000 err=0 total_vm=0x168ab1 flags=0x1 len=0x9000 lo=0x8000 hi=0x753d94b000 mask=0x0 ofs=0x0
Signed-off-by: Jaewon Kim <jaewon31.kim@samsung.com>
Cc: Matthew Wilcox (Oracle) <willy@infradead.org>
Cc: Michel Lespinasse <walken@google.com>
Cc: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/20200409094035.19457-1-jaewon31.kim@samsung.com
[ Upstream commit faffdfa04fa11ccf048cebdde73db41ede0679e0 ]
Mount failure issue happens under the scenario: Application forked dozens
of threads to mount the same number of cramfs images separately in docker,
but several mounts failed with high probability. Mount failed due to the
checking result of the page(read from the superblock of loop dev) is not
uptodate after wait_on_page_locked(page) returned in function cramfs_read:
wait_on_page_locked(page);
if (!PageUptodate(page)) {
The reason of the checking result of the page not uptodate: systemd-udevd
read the loopX dev before mount, because the status of loopX is Lo_unbound
at this time, so loop_make_request directly trigger the calling of io_end
handler end_buffer_async_read, which called SetPageError(page). So It
caused the page can't be set to uptodate in function
end_buffer_async_read:
if(page_uptodate && !PageError(page)) {
SetPageUptodate(page);
Then mount operation is performed, it used the same page which is just
accessed by systemd-udevd above, Because this page is not uptodate, it
will launch a actual read via submit_bh, then wait on this page by calling
wait_on_page_locked(page). When the I/O of the page done, io_end handler
end_buffer_async_read is called, because no one cleared the page
error(during the whole read path of mount), which is caused by
systemd-udevd reading, so this page is still in "PageError" status, which
can't be set to uptodate in function end_buffer_async_read, then caused
mount failure.
But sometimes mount succeed even through systemd-udeved read loopX dev
just before, The reason is systemd-udevd launched other loopX read just
between step 3.1 and 3.2, the steps as below:
1, loopX dev default status is Lo_unbound;
2, systemd-udved read loopX dev (page is set to PageError);
3, mount operation
1) set loopX status to Lo_bound;
==>systemd-udevd read loopX dev<==
2) read loopX dev(page has no error)
3) mount succeed
As the loopX dev status is set to Lo_bound after step 3.1, so the other
loopX dev read by systemd-udevd will go through the whole I/O stack, part
of the call trace as below:
SYS_read
vfs_read
do_sync_read
blkdev_aio_read
generic_file_aio_read
do_generic_file_read:
ClearPageError(page);
mapping->a_ops->readpage(filp, page);
here, mapping->a_ops->readpage() is blkdev_readpage. In latest kernel,
some function name changed, the call trace as below:
blkdev_read_iter
generic_file_read_iter
generic_file_buffered_read:
* A previous I/O error may have been due to temporary
* failures, eg. mutipath errors.
* Pg_error will be set again if readpage fails.
/* Start the actual read. The read will unlock the page*/
error=mapping->a_ops->readpage(flip, page);
We can see ClearPageError(page) is called before the actual read,
then the read in step 3.2 succeed.
This patch is to add the calling of ClearPageError just before the actual
read of read path of cramfs mount. Without the patch, the call trace as
below when performing cramfs mount:
do_mount
cramfs_read
cramfs_blkdev_read
read_cache_page
do_read_cache_page:
filler(data, page);
or
mapping->a_ops->readpage(data, page);
With the patch, the call trace as below when performing mount:
do_mount
cramfs_read
cramfs_blkdev_read
read_cache_page:
do_read_cache_page:
ClearPageError(page); <== new add
filler(data, page);
or
With the patch, mount operation trigger the calling of
ClearPageError(page) before the actual read, the page has no error if no
additional page error happen when I/O done.
Signed-off-by: Xianting Tian <xianting_tian@126.com>
Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org>
Cc: Jan Kara <jack@suse.cz>
Cc: <yubin@h3c.com>
Link: http://lkml.kernel.org/r/1583318844-22971-1-git-send-email-xianting_tian@126.com
[ Upstream commit c02a98753e0a36ba65a05818626fa6adeb4e7c97 ]
If walk_pte_range() is called with a 'end' argument that is beyond the
last page of memory (e.g. ~0UL) then the comparison between 'addr' and
'end' will always fail and the loop will be infinite. Instead change the
comparison to >= while accounting for overflow.
Link: http://lkml.kernel.org/r/20191218162402.45610-15-steven.price@arm.com
Signed-off-by: Steven Price <steven.price@arm.com>
Cc: Albert Ou <aou@eecs.berkeley.edu>
Cc: Alexandre Ghiti <alex@ghiti.fr>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: James Hogan <jhogan@kernel.org>
Cc: James Morse <james.morse@arm.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: "Liang, Kan" <kan.liang@linux.intel.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Vasily Gorbik <gor@linux.ibm.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Will Deacon <will@kernel.org>
Cc: Zong Li <zong.li@sifive.com>
commit 17743798d81238ab13050e8e2833699b54e15467 upstream.
There is a race between the assignment of `table->data` and write value
to the pointer of `table->data` in the __do_proc_doulongvec_minmax() on
the other thread.
CPU0: CPU1:
proc_sys_write
hugetlb_sysctl_handler proc_sys_call_handler
hugetlb_sysctl_handler_common hugetlb_sysctl_handler
table->data = &tmp; hugetlb_sysctl_handler_common
table->data = &tmp;
do_proc_doulongvec_minmax sysctl_head_finish
__do_proc_doulongvec_minmax unuse_table
i = table->data;
*i = val; // corrupt CPU1's stack
Fix this by duplicating the `table`, and only update the duplicate of
it. And introduce a helper of proc_hugetlb_doulongvec_minmax() to
simplify the code.
The following oops was seen:
BUG: kernel NULL pointer dereference, address: 0000000000000000
#PF: supervisor instruction fetch in kernel mode
#PF: error_code(0x0010) - not-present page
Code: Bad RIP value.
Call Trace:
? set_max_huge_pages+0x3da/0x4f0
? alloc_pool_huge_page+0x150/0x150
? proc_doulongvec_minmax+0x46/0x60
? hugetlb_sysctl_handler_common+0x1c7/0x200
? nr_hugepages_store+0x20/0x20
? copy_fd_bitmaps+0x170/0x170
? hugetlb_sysctl_handler+0x1e/0x20
? proc_sys_call_handler+0x2f1/0x300
? unregister_sysctl_table+0xb0/0xb0
? __fd_install+0x78/0x100
? proc_sys_write+0x14/0x20
? __vfs_write+0x4d/0x90
? vfs_write+0xef/0x240
? ksys_write+0xc0/0x160
? __ia32_sys_read+0x50/0x50
? __close_fd+0x129/0x150
? __x64_sys_write+0x43/0x50
? do_syscall_64+0x6c/0x200
? entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: e5ff215941d5 ("hugetlb: multiple hstates for multiple page sizes")
Link: http://lkml.kernel.org/r/20200828031146.43035-1-songmuchun@bytedance.com
[ Upstream commit 1d1585ca0f48fe7ed95c3571f3e4a82b2b5045dc ]
Commit 3d7081822f7f ("uaccess: Add non-pagefault user-space read functions")
missed to add probe write function, therefore factor out a probe_write_common()
helper with most logic of probe_kernel_write() except setting KERNEL_DS, and
add a new probe_user_write() helper so it can be used from BPF side.
Again, on some archs, the user address space and kernel address space can
co-exist and be overlapping, so in such case, setting KERNEL_DS would mean
that the given address is treated as being in kernel address space.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Andrii Nakryiko <andriin@fb.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Link: https://lore.kernel.org/bpf/9df2542e68141bfa3addde631441ee45503856a8.1572649915.git.daniel@iogearbox.net
[ Upstream commit 3d7081822f7f9eab867d9bcc8fd635208ec438e0 ]
Add probe_user_read(), strncpy_from_unsafe_user() and
strnlen_unsafe_user() which allows caller to access user-space
in IRQ context.
Current probe_kernel_read() and strncpy_from_unsafe() are
not available for user-space memory, because it sets
KERNEL_DS while accessing data. On some arch, user address
space and kernel address space can be co-exist, but others
can not. In that case, setting KERNEL_DS means given
address is treated as a kernel address space.
Also strnlen_user() is only available from user context since
it can sleep if pagefault is enabled.
To access user-space memory without pagefault, we need
these new functions which sets USER_DS while accessing
the data.
Link: http://lkml.kernel.org/r/155789869802.26965.4940338412595759063.stgit@devnote2
Acked-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit e5b31ac2ca2cd0cf6bf2fcbb708ed01466c89aaa upstream.
The original count is never reused so it can be removed.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
[dwagner: update context]
Signed-off-by: Daniel Wagner <dwagner@suse.de>
commit 75802ca66354a39ab8e35822747cd08b3384a99a upstream.
This is found by code observation only.
Firstly, the worst case scenario should assume the whole range was covered
by pmd sharing. The old algorithm might not work as expected for ranges
like (1g-2m, 1g+2m), where the adjusted range should be (0, 1g+2m) but the
expected range should be (0, 2g).
Since at it, remove the loop since it should not be required. With that,
the new code should be faster too when the invalidating range is huge.
Mike said:
: With range (1g-2m, 1g+2m) within a vma (0, 2g) the existing code will only
: adjust to (0, 1g+2m) which is incorrect.
: We should cc stable. The original reason for adjusting the range was to
: prevent data corruption (getting wrong page). Since the range is not
: always adjusted correctly, the potential for corruption still exists.
: However, I am fairly confident that adjust_range_if_pmd_sharing_possible
: is only gong to be called in two cases:
: 1) for a single page
: 2) for range == entire vma
: In those cases, the current code should produce the correct results.
: To be safe, let's just cc stable.
Fixes: 017b1660df89 ("mm: migration: fix migration of huge PMD shared pages")
Signed-off-by: Peter Xu <peterx@redhat.com>
Link: http://lkml.kernel.org/r/20200730201636.74778-1-peterx@redhat.com
commit 88e8ac11d2ea3acc003cf01bb5a38c8aa76c3cfd upstream.
The following race is observed with the repeated online, offline and a
delay between two successive online of memory blocks of movable zone.
P1 P2
Online the first memory block in
the movable zone. The pcp struct
values are initialized to default
values,i.e., pcp->high = 0 &
pcp->batch = 1.
Allocate the pages from the
movable zone.
Try to Online the second memory
block in the movable zone thus it
entered the online_pages() but yet
to call zone_pcp_update().
This process is entered into
the exit path thus it tries
to release the order-0 pages
to pcp lists through
free_unref_page_commit().
As pcp->high = 0, pcp->count = 1
proceed to call the function
free_pcppages_bulk().
Update the pcp values thus the
new pcp values are like, say,
pcp->high = 378, pcp->batch = 63.
Read the pcp's batch value using
READ_ONCE() and pass the same to
free_pcppages_bulk(), pcp values
passed here are, batch = 63,
count = 1.
Since num of pages in the pcp
lists are less than ->batch,
then it will stuck in
while(list_empty(list)) loop
with interrupts disabled thus
a core hung.
Avoid this by ensuring free_pcppages_bulk() is called with proper count of
pcp list pages.
The mentioned race is some what easily reproducible without [1] because
pcp's are not updated for the first memory block online and thus there is
a enough race window for P2 between alloc+free and pcp struct values
update through onlining of second memory block.
With [1], the race still exists but it is very narrow as we update the pcp
struct values for the first memory block online itself.
This is not limited to the movable zone, it could also happen in cases
with the normal zone (e.g., hotplug to a node that only has DMA memory, or
no other memory yet).
[1]: https://patchwork.kernel.org/patch/11696389/
Fixes: 5f8dcc21211a ("page-allocator: split per-cpu list into one-list-per-migrate-type")
Signed-off-by: Charan Teja Reddy <charante@codeaurora.org>
Acked-by: David Hildenbrand <david@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Vinayak Menon <vinmenon@codeaurora.org>
Cc: <stable@vger.kernel.org> [2.6+]
Link: http://lkml.kernel.org/r/1597150703-19003-1-git-send-email-charante@codeaurora.org
commit e08d3fdfe2dafa0331843f70ce1ff6c1c4900bf4 upstream.
The lowmem_reserve arrays provide a means of applying pressure against
allocations from lower zones that were targeted at higher zones. Its
values are a function of the number of pages managed by higher zones and
are assigned by a call to the setup_per_zone_lowmem_reserve() function.
The function is initially called at boot time by the function
init_per_zone_wmark_min() and may be called later by accesses of the
/proc/sys/vm/lowmem_reserve_ratio sysctl file.
The function init_per_zone_wmark_min() was moved up from a module_init to
a core_initcall to resolve a sequencing issue with khugepaged.
Unfortunately this created a sequencing issue with CMA page accounting.
The CMA pages are added to the managed page count of a zone when
cma_init_reserved_areas() is called at boot also as a core_initcall. This
makes it uncertain whether the CMA pages will be added to the managed page
counts of their zones before or after the call to
init_per_zone_wmark_min() as it becomes dependent on link order. With the
current link order the pages are added to the managed count after the
lowmem_reserve arrays are initialized at boot.
This means the lowmem_reserve values at boot may be lower than the values
used later if /proc/sys/vm/lowmem_reserve_ratio is accessed even if the
ratio values are unchanged.
In many cases the difference is not significant, but for example
an ARM platform with 1GB of memory and the following memory layout
cma: Reserved 256 MiB at 0x0000000030000000
Zone ranges:
DMA [mem 0x0000000000000000-0x000000002fffffff]
Normal empty
HighMem [mem 0x0000000030000000-0x000000003fffffff]
would result in 0 lowmem_reserve for the DMA zone. This would allow
userspace to deplete the DMA zone easily.
Funnily enough
$ cat /proc/sys/vm/lowmem_reserve_ratio
would fix up the situation because as a side effect it forces
setup_per_zone_lowmem_reserve.
This commit breaks the link order dependency by invoking
init_per_zone_wmark_min() as a postcore_initcall so that the CMA pages
have the chance to be properly accounted in their zone(s) and allowing
the lowmem_reserve arrays to receive consistent values.
Fixes: bc22af74f271 ("mm: update min_free_kbytes from khugepaged after core initialization")
Signed-off-by: Doug Berger <opendmb@gmail.com>
Cc: Jason Baron <jbaron@akamai.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Link: http://lkml.kernel.org/r/1597423766-27849-1-git-send-email-opendmb@gmail.com
[ Upstream commit f3f99d63a8156c7a4a6b20aac22b53c5579c7dc1 ]
syzbot crashes on the VM_BUG_ON_MM(khugepaged_test_exit(mm), mm) in
__khugepaged_enter(): yes, when one thread is about to dump core, has set
core_state, and is waiting for others, another might do something calling
__khugepaged_enter(), which now crashes because I lumped the core_state
test (known as "mmget_still_valid") into khugepaged_test_exit(). I still
think it's best to lump them together, so just in this exceptional case,
check mm->mm_users directly instead of khugepaged_test_exit().
Fixes: bbe98f9cadff ("khugepaged: khugepaged_test_exit() check mmget_still_valid()")
Reported-by: syzbot <syzkaller@googlegroups.com>
Acked-by: Yang Shi <shy828301@gmail.com>
Cc: Song Liu <songliubraving@fb.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: <stable@vger.kernel.org> [4.8+]
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.2008141503370.18085@eggly.anvils
[ Upstream commit bbe98f9cadff58cdd6a4acaeba0efa8565dabe65 ]
Move collapse_huge_page()'s mmget_still_valid() check into
khugepaged_test_exit() itself. collapse_huge_page() is used for anon THP
only, and earned its mmget_still_valid() check because it inserts a huge
pmd entry in place of the page table's pmd entry; whereas
collapse_file()'s retract_page_tables() or collapse_pte_mapped_thp()
merely clears the page table's pmd entry. But core dumping without mmap
lock must have been as open to mistaking a racily cleared pmd entry for a
page table at physical page 0, as exit_mmap() was. And we certainly have
no interest in mapping as a THP once dumping core.
Fixes: 59ea6d06cfa9 ("coredump: fix race condition between collapse_huge_page() and core dumping")
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.2008021217020.27773@eggly.anvils
[ Upstream commit 59ea6d06cfa9247b586a695c21f94afa7183af74 ]
When fixing the race conditions between the coredump and the mmap_sem
holders outside the context of the process, we focused on
mmget_not_zero()/get_task_mm() callers in 04f5866e41fb70 ("coredump: fix
race condition between mmget_not_zero()/get_task_mm() and core
dumping"), but those aren't the only cases where the mmap_sem can be
taken outside of the context of the process as Michal Hocko noticed
while backporting that commit to older -stable kernels.
If mmgrab() is called in the context of the process, but then the
mm_count reference is transferred outside the context of the process,
that can also be a problem if the mmap_sem has to be taken for writing
through that mm_count reference.
khugepaged registration calls mmgrab() in the context of the process,
but the mmap_sem for writing is taken later in the context of the
khugepaged kernel thread.
collapse_huge_page() after taking the mmap_sem for writing doesn't
modify any vma, so it's not obvious that it could cause a problem to the
coredump, but it happens to modify the pmd in a way that breaks an
invariant that pmd_trans_huge_lock() relies upon. collapse_huge_page()
needs the mmap_sem for writing just to block concurrent page faults that
call pmd_trans_huge_lock().
Specifically the invariant that "!pmd_trans_huge()" cannot become a
"pmd_trans_huge()" doesn't hold while collapse_huge_page() runs.
The coredump will call __get_user_pages() without mmap_sem for reading,
which eventually can invoke a lockless page fault which will need a
functional pmd_trans_huge_lock().
So collapse_huge_page() needs to use mmget_still_valid() to check it's
not running concurrently with the coredump... as long as the coredump
can invoke page faults without holding the mmap_sem for reading.
This has "Fixes: khugepaged" to facilitate backporting, but in my view
it's more a bug in the coredump code that will eventually have to be
rewritten to stop invoking page faults without the mmap_sem for reading.
So the long term plan is still to drop all mmget_still_valid().
Link: http://lkml.kernel.org/r/20190607161558.32104-1-aarcange@redhat.com
Fixes: ba76149f47d8 ("thp: khugepaged")
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Michal Hocko <mhocko@suse.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 0a3b3c253a1eb2c7fe7f34086d46660c909abeb3 ]
A large process running on a heavily loaded system can encounter the
following RCU CPU stall warning:
rcu: INFO: rcu_sched self-detected stall on CPU
rcu: 3-....: (20998 ticks this GP) idle=4ea/1/0x4000000000000002 softirq=556558/556558 fqs=5190
(t=21013 jiffies g=1005461 q=132576)
NMI backtrace for cpu 3
CPU: 3 PID: 501900 Comm: aio-free-ring-w Kdump: loaded Not tainted 5.2.9-108_fbk12_rc3_3858_gb83b75af7909 #1
Hardware name: Wiwynn HoneyBadger/PantherPlus, BIOS HBM6.71 02/03/2016
Call Trace:
<IRQ>
dump_stack+0x46/0x60
nmi_cpu_backtrace.cold.3+0x13/0x50
? lapic_can_unplug_cpu.cold.27+0x34/0x34
nmi_trigger_cpumask_backtrace+0xba/0xca
rcu_dump_cpu_stacks+0x99/0xc7
rcu_sched_clock_irq.cold.87+0x1aa/0x397
? tick_sched_do_timer+0x60/0x60
update_process_times+0x28/0x60
tick_sched_timer+0x37/0x70
__hrtimer_run_queues+0xfe/0x270
hrtimer_interrupt+0xf4/0x210
smp_apic_timer_interrupt+0x5e/0x120
apic_timer_interrupt+0xf/0x20
</IRQ>
RIP: 0010:kmem_cache_free+0x223/0x300
Code: 88 00 00 00 0f 85 ca 00 00 00 41 8b 55 18 31 f6 f7 da 41 f6 45 0a 02 40 0f 94 c6 83 c6 05 9c 41 5e fa e8 a0 a7 01 00 41 56 9d <49> 8b 47 08 a8 03 0f 85 87 00 00 00 65 48 ff 08 e9 3d fe ff ff 65
RSP: 0018:ffffc9000e8e3da8 EFLAGS: 00000206 ORIG_RAX: ffffffffffffff13
RAX: 0000000000020000 RBX: ffff88861b9de960 RCX: 0000000000000030
RDX: fffffffffffe41e8 RSI: 000060777fe3a100 RDI: 000000000001be18
RBP: ffffea00186e7780 R08: ffffffffffffffff R09: ffffffffffffffff
R10: ffff88861b9dea28 R11: ffff88887ffde000 R12: ffffffff81230a1f
R13: ffff888854684dc0 R14: 0000000000000206 R15: ffff8888547dbc00
? remove_vma+0x4f/0x60
exit_mmap+0xd6/0x160
mmput+0x4a/0x110
do_exit+0x278/0xae0
? syscall_trace_enter+0x1d3/0x2b0
? handle_mm_fault+0xaa/0x1c0
do_group_exit+0x3a/0xa0
__x64_sys_exit_group+0x14/0x20
do_syscall_64+0x42/0x100
And on a PREEMPT=n kernel, the "while (vma)" loop in exit_mmap() can run
for a very long time given a large process. This commit therefore adds
a cond_resched() to this loop, providing RCU any needed quiescent states.
Cc: <linux-mm@kvack.org>
Reviewed-by: Shakeel Butt <shakeelb@google.com>
Reviewed-by: Joel Fernandes (Google) <joel@joelfernandes.org>
Signed-off-by: Paul E. McKenney <paulmck@kernel.org>
commit 8d22a9351035ef2ff12ef163a1091b8b8cf1e49c upstream.
It was hard to keep a test running, moving tasks between memcgs with
move_charge_at_immigrate, while swapping: mem_cgroup_id_get_many()'s
refcount is discovered to be 0 (supposedly impossible), so it is then
forced to REFCOUNT_SATURATED, and after thousands of warnings in quick
succession, the test is at last put out of misery by being OOM killed.
This is because of the way moved_swap accounting was saved up until the
task move gets completed in __mem_cgroup_clear_mc(), deferred from when
mem_cgroup_move_swap_account() actually exchanged old and new ids.
Concurrent activity can free up swap quicker than the task is scanned,
bringing id refcount down 0 (which should only be possible when
offlining).
Just skip that optimization: do that part of the accounting immediately.
Fixes: 615d66c37c75 ("mm: memcontrol: fix memcg id ref counter on swap charge move")
Reviewed-by: Alex Shi <alex.shi@linux.alibaba.com>
Cc: Alex Shi <alex.shi@linux.alibaba.com>
Cc: Shakeel Butt <shakeelb@google.com>
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.2007071431050.4726@eggly.anvils
[ Upstream commit a68ee0573991e90af2f1785db309206408bad3e5 ]
There is no need to copy SLUB_STATS items from root memcg cache to new
memcg cache copies. Doing so could result in stack overruns because the
store function only accepts 0 to clear the stat and returns an error for
everything else while the show method would print out the whole stat.
Then, the mismatch of the lengths returns from show and store methods
happens in memcg_propagate_slab_attrs():
else if (root_cache->max_attr_size < ARRAY_SIZE(mbuf))
buf = mbuf;
max_attr_size is only 2 from slab_attr_store(), then, it uses mbuf[64]
in show_stat() later where a bounch of sprintf() would overrun the stack
variable. Fix it by always allocating a page of buffer to be used in
show_stat() if SLUB_STATS=y which should only be used for debug purpose.
# echo 1 > /sys/kernel/slab/fs_cache/shrink
BUG: KASAN: stack-out-of-bounds in number+0x421/0x6e0
Write of size 1 at addr ffffc900256cfde0 by task kworker/76:0/53251
Hardware name: HPE ProLiant DL385 Gen10/ProLiant DL385 Gen10, BIOS A40 07/10/2019
Workqueue: memcg_kmem_cache memcg_kmem_cache_create_func
Call Trace:
number+0x421/0x6e0
vsnprintf+0x451/0x8e0
sprintf+0x9e/0xd0
show_stat+0x124/0x1d0
alloc_slowpath_show+0x13/0x20
__kmem_cache_create+0x47a/0x6b0
addr ffffc900256cfde0 is located in stack of task kworker/76:0/53251 at offset 0 in frame:
process_one_work+0x0/0xb90
this frame has 1 object:
[32, 72) 'lockdep_map'
ffffc900256cfc80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffffc900256cfd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffffc900256cfd80: 00 00 00 00 00 00 00 00 00 00 00 00 f1 f1 f1 f1
ffffc900256cfe00: 00 00 00 00 00 f2 f2 f2 00 00 00 00 00 00 00 00
ffffc900256cfe80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: __kmem_cache_create+0x6ac/0x6b0
Call Trace:
Fixes: 107dab5c92d5 ("slub: slub-specific propagation changes")
Signed-off-by: Qian Cai <cai@lca.pw>
Cc: Glauber Costa <glauber@scylladb.com>
Link: http://lkml.kernel.org/r/20200429222356.4322-1-cai@lca.pw
[ Upstream commit 243bce09c91b0145aeaedd5afba799d81841c030 ]
Chris Murphy reports that a slightly overcommitted load, testing swap
and zram along with i915, splats and keeps on splatting, when it had
better fail less noisily:
gnome-shell: page allocation failure: order:0,
mode:0x400d0(__GFP_IO|__GFP_FS|__GFP_COMP|__GFP_RECLAIMABLE),
nodemask=(null),cpuset=/,mems_allowed=0
CPU: 2 PID: 1155 Comm: gnome-shell Not tainted 5.7.0-1.fc33.x86_64 #1
Call Trace:
dump_stack+0x64/0x88
warn_alloc.cold+0x75/0xd9
__alloc_pages_slowpath.constprop.0+0xcfa/0xd30
__alloc_pages_nodemask+0x2df/0x320
alloc_slab_page+0x195/0x310
allocate_slab+0x3c5/0x440
___slab_alloc+0x40c/0x5f0
__slab_alloc+0x1c/0x30
kmem_cache_alloc+0x20e/0x220
xas_nomem+0x28/0x70
add_to_swap_cache+0x321/0x400
__read_swap_cache_async+0x105/0x240
swap_cluster_readahead+0x22c/0x2e0
shmem_swapin+0x8e/0xc0
shmem_swapin_page+0x196/0x740
shmem_getpage_gfp+0x3a2/0xa60
shmem_read_mapping_page_gfp+0x32/0x60
shmem_get_pages+0x155/0x5e0 [i915]
__i915_gem_object_get_pages+0x68/0xa0 [i915]
i915_vma_pin+0x3fe/0x6c0 [i915]
eb_add_vma+0x10b/0x2c0 [i915]
i915_gem_do_execbuffer+0x704/0x3430 [i915]
i915_gem_execbuffer2_ioctl+0x1ea/0x3e0 [i915]
drm_ioctl_kernel+0x86/0xd0 [drm]
drm_ioctl+0x206/0x390 [drm]
ksys_ioctl+0x82/0xc0
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x5b/0xf0
Reported on 5.7, but it goes back really to 3.1: when
shmem_read_mapping_page_gfp() was implemented for use by i915, and
allowed for __GFP_NORETRY and __GFP_NOWARN flags in most places, but
missed swapin's "& GFP_KERNEL" mask for page tree node allocation in
__read_swap_cache_async() - that was to mask off HIGHUSER_MOVABLE bits
from what page cache uses, but GFP_RECLAIM_MASK is now what's needed.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=208085
Link: http://lkml.kernel.org/r/alpine.LSU.2.11.2006151330070.11064@eggly.anvils
Fixes: 68da9f055755 ("tmpfs: pass gfp to shmem_getpage_gfp")
Reviewed-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Chris Murphy <lists@colorremedies.com>
Analyzed-by: Vlastimil Babka <vbabka@suse.cz>
Analyzed-by: Matthew Wilcox <willy@infradead.org>
Tested-by: Chris Murphy <lists@colorremedies.com>
Cc: <stable@vger.kernel.org> [3.1+]
commit 8982ae527fbef170ef298650c15d55a9ccd33973 upstream.
The kzfree() function is normally used to clear some sensitive
information, like encryption keys, in the buffer before freeing it back to
the pool. Memset() is currently used for buffer clearing. However
unlikely, there is still a non-zero probability that the compiler may
choose to optimize away the memory clearing especially if LTO is being
used in the future.
To make sure that this optimization will never happen,
memzero_explicit(), which is introduced in v3.18, is now used in
kzfree() to future-proof it.
Link: http://lkml.kernel.org/r/20200616154311.12314-2-longman@redhat.com
Fixes: 3ef0e5ba4673 ("slab: introduce kzfree()")
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Cc: "Serge E. Hallyn" <serge@hallyn.com>
Cc: Joe Perches <joe@perches.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: "Jason A . Donenfeld" <Jason@zx2c4.com>
commit dde3c6b72a16c2db826f54b2d49bdea26c3534a2 upstream.
syzkaller reports for memory leak when kobject_init_and_add() returns an
error in the function sysfs_slab_add() [1]
When this happened, the function kobject_put() is not called for the
corresponding kobject, which potentially leads to memory leak.
This patch fixes the issue by calling kobject_put() even if
kobject_init_and_add() fails.
[1]
BUG: memory leak
unreferenced object 0xffff8880a6d4be88 (size 8):
comm "syz-executor.3", pid 946, jiffies 4295772514 (age 18.396s)
hex dump (first 8 bytes):
70 69 64 5f 33 00 ff ff pid_3...
backtrace:
kstrdup+0x35/0x70 mm/util.c:60
kstrdup_const+0x3d/0x50 mm/util.c:82
kvasprintf_const+0x112/0x170 lib/kasprintf.c:48
kobject_set_name_vargs+0x55/0x130 lib/kobject.c:289
kobject_add_varg lib/kobject.c:384 [inline]
kobject_init_and_add+0xd8/0x170 lib/kobject.c:473
sysfs_slab_add+0x1d8/0x290 mm/slub.c:5811
__kmem_cache_create+0x50a/0x570 mm/slub.c:4384
create_cache+0x113/0x1e0 mm/slab_common.c:407
kmem_cache_create_usercopy+0x1a1/0x260 mm/slab_common.c:505
kmem_cache_create+0xd/0x10 mm/slab_common.c:564
create_pid_cachep kernel/pid_namespace.c:54 [inline]
create_pid_namespace kernel/pid_namespace.c:96 [inline]
copy_pid_ns+0x77c/0x8f0 kernel/pid_namespace.c:148
create_new_namespaces+0x26b/0xa30 kernel/nsproxy.c:95
unshare_nsproxy_namespaces+0xa7/0x1e0 kernel/nsproxy.c:229
ksys_unshare+0x3d2/0x770 kernel/fork.c:2969
__do_sys_unshare kernel/fork.c:3037 [inline]
__se_sys_unshare kernel/fork.c:3035 [inline]
__x64_sys_unshare+0x2d/0x40 kernel/fork.c:3035
do_syscall_64+0xa1/0x530 arch/x86/entry/common.c:295
Fixes: 80da026a8e5d ("mm/slub: fix slab double-free in case of duplicate sysfs filename")
Link: http://lkml.kernel.org/r/20200602115033.1054-1-wanghai38@huawei.com
commit 6ade20327dbb808882888ed8ccded71e93067cf9 upstream.
find_vmap_area() can return a NULL pointer and we're going to
dereference it without checking it first. Use the existing
find_vm_area() function which does exactly what we want and checks for
the NULL pointer.
Link: http://lkml.kernel.org/r/20181228171009.22269-1-liviu@dudau.co.uk
Fixes: f3c01d2f3ade ("mm: vmalloc: avoid racy handling of debugobjects in vunmap")
Signed-off-by: Liviu Dudau <liviu@dudau.co.uk>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Chintan Pandya <cpandya@codeaurora.org>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
[ Upstream commit d6d8c8a48291b929b2e039f220f0b62958cccfea ]
When mainline introduced commit a96dfddbcc04 ("base/memory, hotplug: fix
a kernel oops in show_valid_zones()"), it obtained the valid start and
end pfn from the given pfn range. The valid start pfn can fix the
actual issue, but it introduced another issue. The valid end pfn will
may exceed the given end_pfn.
Although the incorrect overflow will not result in actual problem at
present, but I think it need to be fixed.
[toshi.kani@hpe.com: remove assumption that end_pfn is aligned by MAX_ORDER_NR_PAGES]
Fixes: a96dfddbcc04 ("base/memory, hotplug: fix a kernel oops in show_valid_zones()")
Link: http://lkml.kernel.org/r/1486467299-22648-1-git-send-email-zhongjiang@huawei.com
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
commit aa9f7d5172fac9bf1f09e678c35e287a40a7b7dd upstream.
Using an empty (malformed) nodelist that is not caught during mount option
parsing leads to a stack-out-of-bounds access.
The option string that was used was: "mpol=prefer:,". However,
MPOL_PREFERRED requires a single node number, which is not being provided
here.
Add a check that 'nodes' is not empty after parsing for MPOL_PREFERRED's
nodeid.
Fixes: 095f1fc4ebf3 ("mempolicy: rework shmem mpol parsing and display")
Reported-by: Entropy Moe <3ntr0py1337@gmail.com>
Reported-by: syzbot+b055b1a6b2b958707a21@syzkaller.appspotmail.com
Tested-by: syzbot+b055b1a6b2b958707a21@syzkaller.appspotmail.com
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Link: http://lkml.kernel.org/r/89526377-7eb6-b662-e1d8-4430928abde9@infradead.org
