path: root/mm
2010-01-25vmalloc: remove BUG_ON due to racy counting of VM_LAZY_FREEYongseok Koh
commit 88f5004430babb836cfce886d5d54c82166f8ba4 upstream. In free_unmap_area_noflush(), va->flags is marked as VM_LAZY_FREE first, and then vmap_lazy_nr is increased atomically. But, in __purge_vmap_area_lazy(), while traversing of vmap_are_list, nr is counted by checking VM_LAZY_FREE is set to va->flags. After counting the variable nr, kernel reads vmap_lazy_nr atomically and checks a BUG_ON condition whether nr is greater than vmap_lazy_nr to prevent vmap_lazy_nr from being negative. The problem is that, if interrupted right after marking VM_LAZY_FREE, increment of vmap_lazy_nr can be delayed. Consequently, BUG_ON condition can be met because nr is counted more than vmap_lazy_nr. It is highly probable when vmalloc/vfree are called frequently. This scenario have been verified by adding delay between marking VM_LAZY_FREE and increasing vmap_lazy_nr in free_unmap_area_noflush(). Even the vmap_lazy_nr is for checking high watermark, it never be the strict watermark. Although the BUG_ON condition is to prevent vmap_lazy_nr from being negative, vmap_lazy_nr is signed variable. So, it could go down to negative value temporarily. Consequently, removing the BUG_ON condition is proper. A possible BUG_ON message is like the below. kernel BUG at mm/vmalloc.c:517! invalid opcode: 0000 [#1] SMP EIP: 0060:[<c04824a4>] EFLAGS: 00010297 CPU: 3 EIP is at __purge_vmap_area_lazy+0x144/0x150 EAX: ee8a8818 EBX: c08e77d4 ECX: e7c7ae40 EDX: c08e77ec ESI: 000081fe EDI: e7c7ae60 EBP: e7c7ae64 ESP: e7c7ae3c DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Call Trace: [<c0482ad9>] free_unmap_vmap_area_noflush+0x69/0x70 [<c0482b02>] remove_vm_area+0x22/0x70 [<c0482c15>] __vunmap+0x45/0xe0 [<c04831ec>] vmalloc+0x2c/0x30 Code: 8d 59 e0 eb 04 66 90 89 cb 89 d0 e8 87 fe ff ff 8b 43 20 89 da 8d 48 e0 8d 43 20 3b 04 24 75 e7 fe 05 a8 a5 a3 c0 e9 78 ff ff ff <0f> 0b eb fe 90 8d b4 26 00 00 00 00 56 89 c6 b8 ac a5 a3 c0 31 EIP: [<c04824a4>] __purge_vmap_area_lazy+0x144/0x150 SS:ESP 0068:e7c7ae3c [ See also http://marc.info/?l=linux-kernel&m=126335856228090&w=2 ] Signed-off-by: Yongseok Koh <yongseok.koh@samsung.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22vfs: Fix vmtruncate() regressionOGAWA Hirofumi
commit cedabed49b39b4319bccc059a63344b6232b619c upstream. If __block_prepare_write() was failed in block_write_begin(), the allocated blocks can be outside of ->i_size. But new truncate_pagecache() in vmtuncate() does nothing if new < old. It means the above usage is not working anymore. So, this patch fixes it by removing "new < old" check. It would need more cleanup/change. But, now -rc and truncate working is in progress, so, this tried to fix it minimum change. Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22page allocator: update NR_FREE_PAGES only when necessaryKOSAKI Motohiro
commit 6ccf80eb15ccaca4d3f1ab5162b9ded5eecd9971 upstream. commit f2260e6b (page allocator: update NR_FREE_PAGES only as necessary) made one minor regression. if __rmqueue() was failed, NR_FREE_PAGES stat go wrong. this patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reported-by: Huang Shijie <shijie8@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22memcg: ensure list is empty at rmdirDaisuke Nishimura
commit fce66477578d081f19aef5ea218664ff7758c33a upstream. Current mem_cgroup_force_empty() only ensures mem->res.usage == 0 on success. But this doesn't guarantee memcg's LRU is really empty, because there are some cases in which !PageCgrupUsed pages exist on memcg's LRU. For example: - Pages can be uncharged by its owner process while they are on LRU. - race between mem_cgroup_add_lru_list() and __mem_cgroup_uncharge_common(). So there can be a case in which the usage is zero but some of the LRUs are not empty. OTOH, mem_cgroup_del_lru_list(), which can be called asynchronously with rmdir, accesses the mem_cgroup, so this access can cause a problem if it races with rmdir because the mem_cgroup might have been freed by rmdir. Actually, I saw a bug which seems to be caused by this race. [1530745.949906] BUG: unable to handle kernel NULL pointer dereference at 0000000000000230 [1530745.950651] IP: [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80 [1530745.950651] PGD 3863de067 PUD 3862c7067 PMD 0 [1530745.950651] Oops: 0002 [#1] SMP [1530745.950651] last sysfs file: /sys/devices/system/cpu/cpu7/cache/index1/shared_cpu_map [1530745.950651] CPU 3 [1530745.950651] Modules linked in: configs ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp nfsd nfs_acl auth_rpcgss exportfs autofs4 hidp rfcomm l2cap crc16 bluetooth lockd sunrpc ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr iscsi_tcp bnx2i cnic uio ipv6 cxgb3i cxgb3 mdio libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_multipath scsi_dh video output sbs sbshc battery ac lp kvm_intel kvm sg ide_cd_mod cdrom serio_raw tpm_tis tpm tpm_bios acpi_memhotplug button parport_pc parport rtc_cmos rtc_core rtc_lib e1000 i2c_i801 i2c_core pcspkr dm_region_hash dm_log dm_mod ata_piix libata shpchp megaraid_mbox sd_mod scsi_mod megaraid_mm ext3 jbd uhci_hcd ohci_hcd ehci_hcd [last unloaded: freq_table] [1530745.950651] Pid: 19653, comm: shmem_test_02 Tainted: G M 2.6.32-mm1-00701-g2b04386 #3 Express5800/140Rd-4 [N8100-1065] [1530745.950651] RIP: 0010:[<ffffffff810fbc11>] [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80 [1530745.950651] RSP: 0018:ffff8803863ddcb8 EFLAGS: 00010002 [1530745.950651] RAX: 00000000000001e0 RBX: ffff8803abc02238 RCX: 00000000000001e0 [1530745.950651] RDX: 0000000000000000 RSI: ffff88038611a000 RDI: ffff8803abc02238 [1530745.950651] RBP: ffff8803863ddcc8 R08: 0000000000000002 R09: ffff8803a04c8643 [1530745.950651] R10: 0000000000000000 R11: ffffffff810c7333 R12: 0000000000000000 [1530745.950651] R13: ffff880000017f00 R14: 0000000000000092 R15: ffff8800179d0310 [1530745.950651] FS: 0000000000000000(0000) GS:ffff880017800000(0000) knlGS:0000000000000000 [1530745.950651] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [1530745.950651] CR2: 0000000000000230 CR3: 0000000379d87000 CR4: 00000000000006e0 [1530745.950651] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [1530745.950651] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [1530745.950651] Process shmem_test_02 (pid: 19653, threadinfo ffff8803863dc000, task ffff88038612a8a0) [1530745.950651] Stack: [1530745.950651] ffffea00040c2fe8 0000000000000000 ffff8803863ddd98 ffffffff810c739a [1530745.950651] <0> 00000000863ddd18 000000000000000c 0000000000000000 0000000000000000 [1530745.950651] <0> 0000000000000002 0000000000000000 ffff8803863ddd68 0000000000000046 [1530745.950651] Call Trace: [1530745.950651] [<ffffffff810c739a>] release_pages+0x142/0x1e7 [1530745.950651] [<ffffffff810c778f>] ? pagevec_move_tail+0x6e/0x112 [1530745.950651] [<ffffffff810c781e>] pagevec_move_tail+0xfd/0x112 [1530745.950651] [<ffffffff810c78a9>] lru_add_drain+0x76/0x94 [1530745.950651] [<ffffffff810dba0c>] exit_mmap+0x6e/0x145 [1530745.950651] [<ffffffff8103f52d>] mmput+0x5e/0xcf [1530745.950651] [<ffffffff81043ea8>] exit_mm+0x11c/0x129 [1530745.950651] [<ffffffff8108fb29>] ? audit_free+0x196/0x1c9 [1530745.950651] [<ffffffff81045353>] do_exit+0x1f5/0x6b7 [1530745.950651] [<ffffffff8106133f>] ? up_read+0x2b/0x2f [1530745.950651] [<ffffffff8137d187>] ? lockdep_sys_exit_thunk+0x35/0x67 [1530745.950651] [<ffffffff81045898>] do_group_exit+0x83/0xb0 [1530745.950651] [<ffffffff810458dc>] sys_exit_group+0x17/0x1b [1530745.950651] [<ffffffff81002c1b>] system_call_fastpath+0x16/0x1b [1530745.950651] Code: 54 53 0f 1f 44 00 00 83 3d cc 29 7c 00 00 41 89 f4 75 63 eb 4e 48 83 7b 08 00 75 04 0f 0b eb fe 48 89 df e8 18 f3 ff ff 44 89 e2 <48> ff 4c d0 50 48 8b 05 2b 2d 7c 00 48 39 43 08 74 39 48 8b 4b [1530745.950651] RIP [<ffffffff810fbc11>] mem_cgroup_del_lru_list+0x30/0x80 [1530745.950651] RSP <ffff8803863ddcb8> [1530745.950651] CR2: 0000000000000230 [1530745.950651] ---[ end trace c3419c1bb8acc34f ]--- [1530745.950651] Fixing recursive fault but reboot is needed! The problem here is pages on LRU may contain pointer to stale memcg. To make res->usage to be 0, all pages on memcg must be uncharged or moved to another(parent) memcg. Moved page_cgroup have already removed from original LRU, but uncharged page_cgroup contains pointer to memcg withou PCG_USED bit. (This asynchronous LRU work is for improving performance.) If PCG_USED bit is not set, page_cgroup will never be added to memcg's LRU. So, about pages not on LRU, they never access stale pointer. Then, what we have to take care of is page_cgroup _on_ LRU list. This patch fixes this problem by making mem_cgroup_force_empty() visit all LRUs before exiting its loop and guarantee there are no pages on its LRU. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18untangle the do_mremap() messAl Viro
This backports the following upstream commits all as one patch: 54f5de709984bae0d31d823ff03de755f9dcac54 ecc1a8993751de4e82eb18640d631dae1f626bd6 1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f f106af4e90eadd76cfc0b5325f659619e08fb762 097eed103862f9c6a97f2e415e21d1134017b135 935874141df839c706cd6cdc438e85eb69d1525e 0ec62d290912bb4b989be7563851bc364ec73b56 c4caa778157dbbf04116f0ac2111e389b5cd7a29 2ea1d13f64efdf49319e86c87d9ba38c30902782 570dcf2c15463842e384eb597a87c1e39bead99b 564b3bffc619dcbdd160de597b0547a7017ea010 0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301 f8b7256096a20436f6d0926747e3ac3d64c81d24 8c7b49b3ecd48923eb64ff57e07a1cdb74782970 9206de95b1ea68357996ec02be5db0638a0de2c1 2c6a10161d0b5fc047b5bd81b03693b9af99fab5 05d72faa6d13c9d857478a5d35c85db9adada685 bb52d6694002b9d632bb355f64daa045c6293a4e e77414e0aad6a1b063ba5e5750c582c75327ea6a aa65607373a4daf2010e8c3867b6317619f3c1a3 Backport done by Greg Kroah-Hartman. Only minor tweaks were needed. Cc: David S. Miller <davem@davemloft.net> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06ksm: fix mlockfreed to munlockedHugh Dickins
2.6.33-rc1 commit 73848b4684e84a84cfd1555af78d41158f31e16b, adjusted to include 31e855ea7173bdb0520f9684580423a9560f66e0's movement of the unlock_page(oldpage), but omit other intervening cleanups. When KSM merges an mlocked page, it has been forgetting to munlock it: that's been left to free_page_mlock(), which reports it in /proc/vmstat as unevictable_pgs_mlockfreed instead of unevictable_pgs_munlocked, which indicates that such pages _might_ be left unevictable for long after they should be evictable. Call munlock_vma_page() to fix that. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06vmscan: do not evict inactive pages when skipping an active list scanRik van Riel
commit b39415b2731d7dec5e612d2d12595da82399eedf upstream. In AIM7 runs, recent kernels start swapping out anonymous pages well before they should. This is due to shrink_list falling through to shrink_inactive_list if !inactive_anon_is_low(zone, sc), when all we really wanted to do is pre-age some anonymous pages to give them extra time to be referenced while on the inactive list. The obvious fix is to make sure that shrink_list does not fall through to scanning/reclaiming inactive pages when we called it to scan one of the active lists. This change should be safe because the loop in shrink_zone ensures that we will still shrink the anon and file inactive lists whenever we should. [kosaki.motohiro@jp.fujitsu.com: inactive_file_is_low() should be inactive_anon_is_low()] Reported-by: Larry Woodman <lwoodman@redhat.com> Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Tomasz Chmielewski <mangoo@wpkg.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rik Theys <rik.theys@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06memcg: avoid oom-killing innocent task in case of use_hierarchyDaisuke Nishimura
commit d31f56dbf8bafaacb0c617f9a6f137498d5c7aed upstream. task_in_mem_cgroup(), which is called by select_bad_process() to check whether a task can be a candidate for being oom-killed from memcg's limit, checks "curr->use_hierarchy"("curr" is the mem_cgroup the task belongs to). But this check return true(it's false positive) when: <some path>/aa use_hierarchy == 0 <- hitting limit <some path>/aa/00 use_hierarchy == 1 <- the task belongs to This leads to killing an innocent task in aa/00. This patch is a fix for this bug. And this patch also fixes the arg for mem_cgroup_print_oom_info(). We should print information of mem_cgroup which the task being killed, not current, belongs to. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06NOMMU: Optimise away the {dac_,}mmap_min_addr testsDavid Howells
commit 6e1415467614e854fee660ff6648bd10fa976e95 upstream. In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be skipped by the compiler. We do this as the minimum mmap address doesn't make any sense in NOMMU mode. mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18mm: sigbus instead of abusing oomHugh Dickins
commit d99be1a8ecf377c2c9b3372d36411ad6547bbd4c upstream. When do_nonlinear_fault() realizes that the page table must have been corrupted for it to have been called, it does print_bad_pte() and returns ... VM_FAULT_OOM, which is hard to understand. It made some sense when I did it for 2.6.15, when do_page_fault() just killed the current process; but nowadays it lets the OOM killer decide who to kill - so page table corruption in one process would be liable to kill another. Change it to return VM_FAULT_SIGBUS instead: that doesn't guarantee that the process will be killed, but is good enough for such a rare abnormality, accompanied as it is by the "BUG: Bad page map" message. And recent HWPOISON work has copied that code into do_swap_page(), when it finds an impossible swap entry: fix that to VM_FAULT_SIGBUS too. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18vmalloc: conditionalize build of pcpu_get_vm_areas()Tejun Heo
No matching upstream commit as it was resolved differently there. pcpu_get_vm_areas() is used only when dynamic percpu allocator is used by the architecture. In 2.6.32, ia64 doesn't use dynamic percpu allocator and has a macro which makes pcpu_get_vm_areas() buggy via local/global variable aliasing and triggers compile warning. The problem is fixed in upstream and ia64 uses dynamic percpu allocators, so the only left issue is inclusion of unnecessary code and compile warning on ia64 on 2.6.32. Don't build pcpu_get_vm_areas() if legacy percpu allocator is in use. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jan Beulich <JBeulich@novell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18memcg: fix memory.memsw.usage_in_bytes for root cgroupKirill A. Shutemov
commit cd9b45b78a61e8df250e69385c74e729e5b66abf upstream. A memory cgroup has a memory.memsw.usage_in_bytes file. It shows the sum of the usage of pages and swapents in the cgroup. Presently the root cgroup's memsw.usage_in_bytes shows the wrong value - the number of swapents are not added. So take MEM_CGROUP_STAT_SWAPOUT into account. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18mm: hugetlb: fix hugepage memory leak in walk_page_range()Naoya Horiguchi
commit d33b9f45bd24a6391bc05e2b5a13c1b5787ca9c2 upstream. Most callers of pmd_none_or_clear_bad() check whether the target page is in a hugepage or not, but walk_page_range() do not check it. So if we read /proc/pid/pagemap for the hugepage on x86 machine, the hugepage memory is leaked as shown below. This patch fixes it. Details ======= My test program (leak_pagemap) works as follows: - creat() and mmap() a file on hugetlbfs (file size is 200MB == 100 hugepages,) - read()/write() something on it, - call page-types with option -p (walk around the page tables), - munmap() and unlink() the file on hugetlbfs Without my patches ------------------ $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ./leak_pagemap [snip output] $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 900 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ls /hugetlbfs/ $ 100 hugepages are accounted as used while there is no file on hugetlbfs. With my patches --------------- $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ./leak_pagemap [snip output] $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ls /hugetlbfs $ No memory leaks. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-18mm: hugetlb: fix hugepage memory leak in mincore()Naoya Horiguchi
commit 4f16fc107d9c9b8a72aa19b189a9216e90a7aaef upstream. Most callers of pmd_none_or_clear_bad() check whether the target page is in a hugepage or not, but mincore() and walk_page_range() do not check it. So if we use mincore() on a hugepage on x86 machine, the hugepage memory is leaked as shown below. This patch fixes it by extending mincore() system call to support hugepages. Details ======= My test program (leak_mincore) works as follows: - creat() and mmap() a file on hugetlbfs (file size is 200MB == 100 hugepages,) - read()/write() something on it, - call mincore() for first ten pages and printf() the values of *vec - munmap() and unlink() the file on hugetlbfs Without my patch ---------------- $ cat /proc/meminfo| grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ./leak_mincore vec[0] 0 vec[1] 0 vec[2] 0 vec[3] 0 vec[4] 0 vec[5] 0 vec[6] 0 vec[7] 0 vec[8] 0 vec[9] 0 $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 999 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ls /hugetlbfs/ $ Return values in *vec from mincore() are set to 0, while the hugepage should be in memory, and 1 hugepage is still accounted as used while there is no file on hugetlbfs. With my patch ------------- $ cat /proc/meminfo| grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ./leak_mincore vec[0] 1 vec[1] 1 vec[2] 1 vec[3] 1 vec[4] 1 vec[5] 1 vec[6] 1 vec[7] 1 vec[8] 1 vec[9] 1 $ cat /proc/meminfo |grep "HugePage" HugePages_Total: 1000 HugePages_Free: 1000 HugePages_Rsvd: 0 HugePages_Surp: 0 $ ls /hugetlbfs/ $ Return value in *vec set to 1 and no memory leaks. [akpm@linux-foundation.org: cleanup] [akpm@linux-foundation.org: build fix] Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-30Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cciss: make device attrs static Thaw refrigerated bdi flusher threads before invoking kthread_stop on them
2009-11-17mm: allow memory hotplug and hibernation in the same kernelAndi Kleen
Allow memory hotplug and hibernation in the same kernel Memory hotplug and hibernation were exclusive in Kconfig. This is obviously a problem for distribution kernels who want to support both in the same image. After some discussions with Rafael and others the only problem is with parallel memory hotadd or removal while a hibernation operation is in process. It was also working for s390 before. This patch removes the Kconfig level exclusion, and simply makes the memory add / remove functions grab the pm_mutex to exclude against hibernation. Fixes a regression - old kernels didn't exclude memory hotadd and hibernation. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-17mm/memory_hotplug: fix section mismatchHidetoshi Seto
With CONFIG_MEMORY_HOTPLUG I got following warning: WARNING: vmlinux.o(.text+0x1276b0): Section mismatch in reference from the function hotadd_new_pgdat() to the function .meminit.text:free_area_init_node() The function hotadd_new_pgdat() references the function __meminit free_area_init_node(). This is often because hotadd_new_pgdat lacks a __meminit annotation or the annotation of free_area_init_node is wrong. Use __ref to fix this. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: restructure pcpu_extend_area_map() to fix bugs and improve readability
2009-11-13percpu: restructure pcpu_extend_area_map() to fix bugs and improve readabilityTejun Heo
pcpu_extend_area_map() had the following two bugs. * It should return 1 if pcpu_lock was dropped and reacquired but it returned 0. This could lead to oops if free_percpu() races with area map extension. * pcpu_mem_free() was called under pcpu_lock. pcpu_mem_free() might end up calling vfree() which isn't IRQ safe. This could lead to deadlock through lock order inversion via IRQ. In addition, Linus pointed out that the temporary lock dropping and subtle three-way return value of pcpu_extend_area_map() was very ugly and suggested to split the function into two - pcpu_need_to_extend() and pcpu_extend_area_map(). This patch restructures pcpu_extend_area_map() as suggested and fixes the two bugs. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu>
2009-11-12memcg: fix wrong pointer initialization at page migration when memcg is ↵KAMEZAWA Hiroyuki
disabled. Lee Schermerhorn reported that he saw bad pointer dereference in mem_cgroup_end_migration() when he disabled memcg by boot option. memcg's page migration logic works as mem_cgroup_prepare_migration(page, &ptr); do page migration mem_cgroup_end_migration(page, ptr); Now, ptr is not initialized in prepare_migration when memcg is disabled by boot option. This causes panic in end_migration. This patch fixes it. Reported-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12page allocator: Do not allow interrupts to use ALLOC_HARDERMel Gorman
Commit 341ce06f69abfafa31b9468410a13dbd60e2b237 ("page allocator: calculate the alloc_flags for allocation only once") altered watermark logic slightly by allowing rt_tasks that are handling an interrupt to set ALLOC_HARDER. This patch brings the watermark logic more in line with 2.6.30. This change results in a reduction of the number high-order GFP_ATOMIC allocation failures reported. See http://www.gossamer-threads.com/lists/linux/kernel/1144153 [rientjes@google.com: Spotted the problem] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12page allocator: always wake kswapd when restarting an allocation attempt ↵Mel Gorman
after direct reclaim failed If a direct reclaim makes no forward progress, it considers whether it should go OOM or not. Whether OOM is triggered or not, it may retry the allocation afterwards. In times past, this would always wake kswapd as well but currently, kswapd is not woken up after direct reclaim fails. For order-0 allocations, this makes little difference but if there is a heavy mix of higher-order allocations that direct reclaim is failing for, it might mean that kswapd is not rewoken for higher orders as much as it did previously. This patch wakes up kswapd when an allocation is being retried after a direct reclaim failure. It would be expected that kswapd is already awake, but this has the effect of telling kswapd to reclaim at the higher order as well. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12Thaw refrigerated bdi flusher threads before invoking kthread_stop on themRomit Dasgupta
Unfreezes the bdi flusher task when the said task needs to exit. Steps to reproduce this. 1) Mount a file system from MMC/SD card. 2) Unmount the file system. This creates a flusher task. 3) Attempt suspend to RAM. System is unresponsive. This is because the bdi flusher thread is already in the refrigerator and will remain so until it is thawed. The MMC driver suspend routine call stack will ultimately issue a 'kthread_stop' on the bdi flusher thread and will block until the flusher thread is exited. Since the bdi flusher thread is in the refrigerator it never cleans up until thawed. Signed-off-by: Romit Dasgupta <romit@ti.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-11Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: highmem: Fix debug_kmap_atomic() to also handle KM_IRQ_PTE, KM_NMI, and KM_NMI_PTE highmem: Fix race in debug_kmap_atomic() which could cause warn_count to underflow rcu: Fix long-grace-period race between forcing and initialization uids: Prevent tear down race
2009-11-10highmem: Fix debug_kmap_atomic() to also handle KM_IRQ_PTE, KM_NMI, and ↵Soeren Sandmann
KM_NMI_PTE Previously calling debug_kmap_atomic() with these types would cause spurious warnings. (triggered by SysProf using perf events) Signed-off-by: Soeren Sandmann Pedersen <sandmann@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: a.p.zijlstra@chello.nl Cc: <stable@kernel.org> # .31.x LKML-Reference: <ye8vdhz8krw.fsf@camel23.daimi.au.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10highmem: Fix race in debug_kmap_atomic() which could cause warn_count to ↵Soeren Sandmann
underflow debug_kmap_atomic() tries to prevent ever printing more than 10 warnings, but it does so by testing whether an unsigned integer is equal to 0. However, if the warning is caused by a nested IRQ, then this counter may underflow and the stream of warnings will never end. Fix that by using a signed integer instead. Signed-off-by: Soeren Sandmann Pedersen <sandmann@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: a.p.zijlstra@chello.nl Cc: <stable@kernel.org> # .31.x LKML-Reference: <ye8zl7b8ktj.fsf@camel23.daimi.au.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-09ksm: cond_resched in unstable treeHugh Dickins
KSM needs a cond_resched() for CONFIG_PREEMPT_NONE, in its unbounded search of the unstable tree. The stable tree cases already have one, and originally there was one down inside get_user_pages(); but I missed it when I converted to follow_page() instead. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Izik Eidus <ieidus@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-03Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: cfq-iosched: limit coop preemption cfq-iosched: fix bad return value cfq_should_preempt() backing-dev: bdi sb prune should be in the unregister path, not destroy Fix bio_alloc() and bio_kmalloc() documentation bio_put(): add bio_clone() to the list of functions in the comment
2009-11-03backing-dev: bdi sb prune should be in the unregister path, not destroyJens Axboe
Commit 592b09a42fc3ae6737a0f3ecf4fee42ecd0296f8 was different from the tested path, in that it moved the bdi super_block prune from unregister to destroy context. This doesn't fully fix the sync hang bug on unexpected device removal, as need to prune the bdi cache pointer before killing flusher thread. Tested-by: Artur Skawina <art.08.09@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-02mm: remove incorrect swap_count() from try_to_unuse()Bo Liu
In try_to_unuse(), swcount is a local copy of *swap_map, including the SWAP_HAS_CACHE bit; but a wrong comparison against swap_count(*swap_map), which masks off the SWAP_HAS_CACHE bit, succeeded where it should fail. That had the effect of resetting the mm from which to start searching for the next swap page, to an irrelevant mm instead of to an mm in which this swap page had been found: which may increase search time by ~20%. But we're used to swapoff being slow, so never noticed the slowdown. Remove that one spurious use of swap_count(): Bo Liu thought it merely redundant, Hugh rewrote the description since it was measurably wrong. Signed-off-by: Bo Liu <bo-liu@hotmail.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-31NOMMU: Don't pass NULL pointers to fput() in do_mmap_pgoff()David Howells
Don't pass NULL pointers to fput() in the error handling paths of the NOMMU do_mmap_pgoff() as it can't handle it. The following can be used as a test program: int main() { static long long a[1024 * 1024 * 20] = { 0 }; return a;} Without the patch, the code oopses in atomic_long_dec_and_test() as called by fput() after the kernel complains that it can't allocate that big a chunk of memory. With the patch, the kernel just complains about the allocation size and then the program segfaults during execve() as execve() can't complete the allocation of all the new ELF program segments. Reported-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: sched: move rq_weight data array out of .percpu percpu: allow pcpu_alloc() to be called with IRQs off
2009-10-29Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: backing-dev: ensure that a removed bdi no longer has super_block referencing it block: use after free bug in __blkdev_get block: silently error unsupported empty barriers too
2009-10-29Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ppc64: Use preempt_schedule_irq instead of preempt_schedule powerpc: Minor cleanup to lib/Kconfig.debug powerpc: Minor cleanup to sound/ppc/Kconfig powerpc: Minor cleanup to init/Kconfig powerpc: Limit memory hotplug support to PPC64 Book-3S machines powerpc: Limit hugetlbfs support to PPC64 Book-3S machines powerpc: Fix compile errors found by new ppc64e_defconfig powerpc: Add a Book-3E 64-bit defconfig powerpc/booke: Fix xmon single step on PowerPC Book-E powerpc: Align vDSO base address powerpc: Fix segment mapping in vdso32 powerpc/iseries: Remove compiler version dependent hack powerpc/perf_events: Fix priority of MSR HV vs PR bits powerpc/5200: Update defconfigs drivers/serial/mpc52xx_uart.c: Use UPIO_MEM rather than SERIAL_IO_MEM powerpc/boot/dts: drop obsolete 'fsl5200-clocking' of: Remove nested function mpc5200: support for the MAN mpc5200 based board mucmc52 mpc5200: support for the MAN mpc5200 based board uc101
2009-10-29Merge branch 'hwpoison-2.6.32' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: HWPOISON: fix invalid page count in printk output HWPOISON: Allow schedule_on_each_cpu() from keventd HWPOISON: fix/proc/meminfo alignment HWPOISON: fix oops on ksm pages HWPOISON: Fix page count leak in hwpoison late kill in do_swap_page HWPOISON: return early on non-LRU pages HWPOISON: Add brief hwpoison description to Documentation HWPOISON: Clean up PR_MCE_KILL interface
2009-10-29mm: don't call pte_unmap() against an improper pteDaisuke Nishimura
There are some places where we do like: pte = pte_map(); do { (do break in some conditions) } while (pte++, ...); pte_unmap(pte - 1); But if the loop breaks at the first loop, pte_unmap() unmaps invalid pte. This patch is a fix for this problem. Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Reviewd-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29mm: fix sparsemem configurationRussell King
Currently, sparsemem is only available if EXPERIMENTAL is enabled. However, it hasn't ever been marked experimental. It's been about four years since sparsemem was merged, and we have platforms which depend on it; allow architectures to decide whether sparsemem should be the default memory model. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29vmscan: order evictable rescue in LRU putbackJohannes Weiner
Isolators putting a page back to the LRU do not hold the page lock, and if the page is mlocked, another thread might munlock it concurrently. Expecting this, the putback code re-checks the evictability of a page when it just moved it to the unevictable list in order to correct its decision. The problem, however, is that ordering is not garuanteed between setting PG_lru when moving the page to the list and checking PG_mlocked afterwards: #0: #1 spin_lock() if (TestClearPageMlocked()) if (PageLRU()) move to evictable list SetPageLRU() spin_unlock() if (!PageMlocked()) move to evictable list The PageMlocked() check may get reordered before SetPageLRU() in #0, resulting in #0 not moving the still mlocked page, and in #1 failing to isolate and move the page as well. The page is now stranded on the unevictable list. The race condition is very unlikely. The consequence currently is one page falling off the reclaim grid and eventually getting freed with PG_unevictable set, which triggers a warning in the page allocator. TestClearPageMlocked() in #1 already provides full memory barrier semantics. This patch adds an explicit full barrier to force ordering between SetPageLRU() and PageMlocked() so that either one of the competitors rescues the page. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29do_mbind(): fix memory leakKOSAKI Motohiro
If migrate_prep is failed, new variable is leaked. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29mbind(): fix leak of never putback pagesKOSAKI Motohiro
If mbind() receives an invalid address, do_mbind leaks a page. The following test program detects this leak. This patch fixes it. migrate_efault.c ======================================= #include <numaif.h> #include <numa.h> #include <sys/mman.h> #include <stdio.h> #include <unistd.h> #include <stdlib.h> #include <string.h> static unsigned long pagesize; static void* make_hole_mapping(void) { void* addr; addr = mmap(NULL, pagesize*3, PROT_READ|PROT_WRITE, MAP_ANON|MAP_PRIVATE, 0, 0); if (addr == MAP_FAILED) return NULL; /* make page populate */ memset(addr, 0, pagesize*3); /* make memory hole */ munmap(addr+pagesize, pagesize); return addr; } int main(int argc, char** argv) { void* addr; int ch; int node; struct bitmask *nmask = numa_allocate_nodemask(); int err; int node_set = 0; while ((ch = getopt(argc, argv, "n:")) != -1){ switch (ch){ case 'n': node = strtol(optarg, NULL, 0); numa_bitmask_setbit(nmask, node); node_set = 1; break; default: ; } } argc -= optind; argv += optind; if (!node_set) numa_bitmask_setbit(nmask, 0); pagesize = getpagesize(); addr = make_hole_mapping(); err = mbind(addr, pagesize*3, MPOL_BIND, nmask->maskp, nmask->size, MPOL_MF_MOVE_ALL); if (err) perror("mbind "); return 0; } ======================================= Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29vmscan: limit VM_EXEC protection to file pagesWu Fengguang
It is possible to have !Anon but SwapBacked pages, and some apps could create huge number of such pages with MAP_SHARED|MAP_ANONYMOUS. These pages go into the ANON lru list, and hence shall not be protected: we only care mapped executable files. Failing to do so may trigger OOM. Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29revert "mm: oom analysis: add buffer cache information to show_free_areas()"Andrew Morton
Revert commit 71de1ccbe1fb40203edd3beb473f8580d917d2ca Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> AuthorDate: Mon Sep 21 17:01:31 2009 -0700 Commit: Linus Torvalds <torvalds@linux-foundation.org> CommitDate: Tue Sep 22 07:17:27 2009 -0700 mm: oom analysis: add buffer cache information to show_free_areas() show_free_areas() is called during page allocation failures, and page allocation failures can occur in any calling context. But nr_blockdev_pages() takes VFS locks which should not be taken from hard IRQ context (at least). The result is lockdep warnings (and deadlockability) during page allocation failures. Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29congestion_wait(): don't use WRITEKOSAKI Motohiro
commit 8aa7e847d (Fix congestion_wait() sync/async vs read/write confusion) replace WRITE with BLK_RW_ASYNC. Unfortunately, concurrent mm development made the unchanged place accidentally. This patch fixes it too. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29hwpoison: fix oops on ksm pagesHugh Dickins
Memory failure on a KSM page currently oopses on its NULL anon_vma in page_lock_anon_vma(): that may not be much worse than the consequence of ignoring it, but it is better to be consistent with how ZERO_PAGE and hugetlb pages and other awkward cases are treated. Just skip it. We could fix it for 2.6.32 at the KSM end, by putting a dummy anon_vma pointer in there; but that would get harder next time, when KSM will put a pointer to something else there (and I'm not currently planning to do any work to open that up to memory_failure). So I would prefer this simple PageKsm test, until the other exceptions are handled. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29backing-dev: ensure that a removed bdi no longer has super_block referencing itJens Axboe
When the bdi is being removed, we have to ensure that no super_blocks currently have that cached in sb->s_bdi. Normally this is ensured by the sb having a longer life span than the bdi, but if the device is suddenly yanked, we have to kill this reference. sb->s_bdi is pointed to freed memory at that point. This fixes a problem with sync(1) hanging when a USB stick is pulled without cleanly umounting it first. Reported-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-29percpu: allow pcpu_alloc() to be called with IRQs offJiri Kosina
pcpu_alloc() and pcpu_extend_area_map() perform a series of spin_lock_irq()/spin_unlock_irq() calls, which make them unsafe with respect to being called from contexts which have IRQs off. This patch converts the code to perform save/restore of flags instead, making pcpu_alloc() (or __alloc_percpu() respectively) to be called from early kernel startup stage, where IRQs are off. This is needed for proper initialization of per-cpu rq_weight data from sched_init(). tj: added comment explaining why irqsave/restore is used in alloc path. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-10-27powerpc: Limit memory hotplug support to PPC64 Book-3S machinesKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-19HWPOISON: fix invalid page count in printk outputWu Fengguang
The madvise injector already holds a reference when passing in a page to the memory-failure code. The code corrects for this additional reference for its checks, but the final printk output didn't. Fix that. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-10-19HWPOISON: fix oops on ksm pagesHugh Dickins
Memory failure on a KSM page currently oopses on its NULL anon_vma in page_lock_anon_vma(): that may not be much worse than the consequence of ignoring it, but it is better to be consistent with how ZERO_PAGE and hugetlb pages and other awkward cases are treated. Just skip it. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-10-19HWPOISON: Fix page count leak in hwpoison late kill in do_swap_pageAndi Kleen
When returning due to a poisoned page drop the page count. It wasn't a fatal problem because noone cares about the page count on a poisoned page (except when it wraps), but it's cleaner to fix it. Pointed out by Linus. Signed-off-by: Andi Kleen <ak@linux.intel.com>
