commit 9b7f43afd417a6feb80841d30ced4051c362eb5d upstream.
My 9ce70c0240d0 "memcg: fix deadlock by inverting lrucare nesting" put a
nasty little bug into v3.3's version of mem_cgroup_replace_page_cache(),
sometimes used for FUSE. Replacing __mem_cgroup_commit_charge_lrucare()
by __mem_cgroup_commit_charge(), I used the "pc" pointer set up earlier:
but it's for oldpage, and needs now to be for newpage. Once oldpage was
freed, its PageCgroupUsed bit (cleared above but set again here) caused
"Bad page state" messages - and perhaps worse, being missed from newpage.
(I didn't find this by using FUSE, but in reusing the function for tmpfs.)
commit 66aebce747eaf9bc456bf1f1b217d8db843031d0 upstream.
The race is as follows:
Suppose a multi-threaded task forks a new process (on cpu A), thus
bumping up the ref count on all the pages. While the fork is occurring
(and thus we have marked all the PTEs as read-only), another thread in
the original process (on cpu B) tries to write to a huge page, taking an
access violation from the write-protect and calling hugetlb_cow(). Now,
suppose the fork() fails. It will undo the COW and decrement the ref
count on the pages, so the ref count on the huge page drops back to 1.
Meanwhile hugetlb_cow() also decrements the ref count by one on the
original page, since the original address space doesn't need it any
more, having copied a new page to replace the original page. This
leaves the ref count at zero, and when we call unlock_page(), we panic.
fork on CPU A fault on CPU B
down_write(&parent->mmap_sem);
down_write_nested(&child->mmap_sem);
while duplicating vmas
if error
break;
up_write(&child->mmap_sem);
up_write(&parent->mmap_sem); ...
down_read(&parent->mmap_sem);
lock_page(page);
handle COW
page_mapcount(old_page) == 2
alloc and prepare new_page
handle error
page_remove_rmap(page);
put_page(page);
fold new_page into pte
put_page(page);
oops ==> unlock_page(page);
up_read(&parent->mmap_sem);
The solution is to take an extra reference to the page while we are
holding the lock on it.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Cc: Hillf Danton <dhillf@gmail.com>
commit 66c4c35c6bc5a1a452b024cf0364635b28fd94e4 upstream.
sysfs_slab_add() calls various sysfs functions that actually may
end up in userspace doing all sorts of things.
Release the slub_lock after adding the kmem_cache structure to the list.
At that point the address of the kmem_cache is not known so we are
guaranteed exlusive access to the following modifications to the
kmem_cache structure.
If the sysfs_slab_add fails then reacquire the slub_lock to
remove the kmem_cache structure from the list.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
highmem
commit cc715d99e529d470dde2f33a6614f255adea71f3 upstream.
Stuart Foster reported on bugzilla that copying large amounts of data
from NTFS caused an OOM kill on 32-bit X86 with 16G of memory. Andrew
Morton correctly identified that the problem was NTFS was using 512
blocks meaning each page had 8 buffer_heads in low memory pinning it.
In the past, direct reclaim used to scan highmem even if the allocating
process did not specify __GFP_HIGHMEM but not any more. kswapd no longer
will reclaim from zones that are above the high watermark. The intention
in both cases was to minimise unnecessary reclaim. The downside is on
machines with large amounts of highmem that lowmem can be fully consumed
by buffer_heads with nothing trying to free them.
The following patch is based on a suggestion by Andrew Morton to extend
the buffer_heads_over_limit case to force kswapd and direct reclaim to
scan the highmem zone regardless of the allocation request or watermarks.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=42578
[hughd@google.com: move buffer_heads_over_limit check up]
[akpm@linux-foundation.org: buffer_heads_over_limit is unlikely]
Reported-by: Stuart Foster <smf.linux@ntlworld.com>
Tested-by: Stuart Foster <smf.linux@ntlworld.com>
Cc: Christoph Lameter <cl@linux.com>
commit f5bf18fa22f8c41a13eb8762c7373eb3a93a7333 upstream.
While testing AMS (Active Memory Sharing) / CMO (Cooperative Memory
Overcommit) on powerpc, we tripped the following:
kernel BUG at mm/bootmem.c:483!
cpu 0x0: Vector: 700 (Program Check) at [c000000000c03940]
pc: c000000000a62bd8: .alloc_bootmem_core+0x90/0x39c
lr: c000000000a64bcc: .sparse_early_usemaps_alloc_node+0x84/0x29c
sp: c000000000c03bc0
msr: 8000000000021032
current = 0xc000000000b0cce0
paca = 0xc000000001d80000
pid = 0, comm = swapper
enter ? for help
[c000000000c03c80] c000000000a64bcc
[c000000000c03d50] c000000000a64f10 .sparse_init+0x12c/0x28c
[c000000000c03e20] c000000000a474f4 .setup_arch+0x20c/0x294
[c000000000c03ee0] c000000000a4079c .start_kernel+0xb4/0x460
[c000000000c03f90] c000000000009670 .start_here_common+0x1c/0x2c
This is
BUG_ON(limit && goal + size > limit);
and after some debugging, it seems that
goal = 0x7ffff000000
limit = 0x80000000000
and sparse_early_usemaps_alloc_node ->
sparse_early_usemaps_alloc_pgdat_section calls
return alloc_bootmem_section(usemap_size() * count, section_nr);
This is on a system with 8TB available via the AMS pool, and as a quirk
of AMS in firmware, all of that memory shows up in node 0. So, we end
up with an allocation that will fail the goal/limit constraints.
In theory, we could "fall-back" to alloc_bootmem_node() in
sparse_early_usemaps_alloc_node(), but since we actually have HOTREMOVE
defined, we'll BUG_ON() instead. A simple solution appears to be to
unconditionally remove the limit condition in alloc_bootmem_section,
meaning allocations are allowed to cross section boundaries (necessary
for systems of this size).
Johannes Weiner pointed out that if alloc_bootmem_section() no longer
guarantees section-locality, we need check_usemap_section_nr() to print
possible cross-dependencies between node descriptors and the usemaps
allocated through it. That makes the two loops in
sparse_early_usemaps_alloc_node() identical, so re-factor the code a
bit.
[akpm@linux-foundation.org: code simplification]
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Anton Blanchard <anton@au1.ibm.com>
Cc: Ben Herrenschmidt <benh@kernel.crashing.org>
Cc: Robert Jennings <rcj@linux.vnet.ibm.com>
commit 1a5a9906d4e8d1976b701f889d8f35d54b928f25 upstream.
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
[akpm@linux-foundation.org: checkpatch fixes]
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: Mark Salter <msalter@redhat.com>
After fixing the GPF in mem_cgroup_lru_del_list(), three times one
machine running a similar load (moving and removing memcgs while
swapping) has oopsed in mem_cgroup_zone_nr_lru_pages(), when retrieving
memcg zone numbers for get_scan_count() for shrink_mem_cgroup_zone():
this is where a struct mem_cgroup is first accessed after being chosen
by mem_cgroup_iter().
Just what protects a struct mem_cgroup from being freed, in between
mem_cgroup_iter()'s css_get_next() and its css_tryget()? css_tryget()
fails once css->refcnt is zero with CSS_REMOVED set in flags, yes: but
what if that memory is freed and reused for something else, which sets
"refcnt" non-zero? Hmm, and scope for an indefinite freeze if refcnt is
left at zero but flags are cleared.
It's tempting to move the css_tryget() into css_get_next(), to make it
really "get" the css, but I don't think that actually solves anything:
the same difficulty in moving from css_id found to stable css remains.
But we already have rcu_read_lock() around the two, so it's easily fixed
if __mem_cgroup_free() just uses kfree_rcu() to free mem_cgroup.
However, a big struct mem_cgroup is allocated with vzalloc() instead of
kzalloc(), and we're not allowed to vfree() at interrupt time: there
doesn't appear to be a general vfree_rcu() to help with this, so roll
our own using schedule_work(). The compiler decently removes
vfree_work() and vfree_rcu() when the config doesn't need them.
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Ying Han <yinghan@google.com>
Respectfully revert commit e6ca7b89dc76 "memcg: fix mapcount check
in move charge code for anonymous page" for the 3.3 release, so that
it behaves exactly like releases 2.6.35 through 3.2 in this respect.
Horiguchi-san's commit is correct in itself, 1 makes much more sense
than 2 in that check; but it does not go far enough - swapcount
should be considered too - if we really want such a check at all.
We appear to have reached agreement now, and expect that 3.4 will
remove the mapcount check, but had better not make 3.3 different.
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Several users of "find_vma_prev()" were not in fact interested in the
previous vma if there was no primary vma to be found either. And in
those cases, we're much better off just using the regular "find_vma()",
and then "prev" can be looked up by just checking vma->vm_prev.
The find_vma_prev() semantics are fairly subtle (see Mikulas' recent
commit 83cd904d271b: "mm: fix find_vma_prev"), and the whole "return
prev by reference" means that it generates worse code too.
Thus this "let's avoid using this inconvenient and clearly too subtle
interface when we don't really have to" patch.
Cc: Mikulas Patocka <mpatocka@redhat.com>
Commit 6bd4837de96e ("mm: simplify find_vma_prev()") broke memory
management on PA-RISC.
After application of the patch, programs that allocate big arrays on the
stack crash with segfault, for example, this will crash if compiled
without optimization:
int main()
char array[200000];
array[199999] = 0;
return 0;
The reason is that PA-RISC has up-growing stack and the stack is usually
the last memory area. In the above example, a page fault happens above
the stack.
Previously, if we passed too high address to find_vma_prev, it returned
NULL and stored the last VMA in *pprev. After "simplify find_vma_prev"
change, it stores NULL in *pprev. Consequently, the stack area is not
found and it is not expanded, as it used to be before the change.
This patch restores the old behavior and makes it return the last VMA in
*pprev if the requested address is higher than address of any other VMA.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Currently error is -ENOMEM when rejecting VM_GROWSDOWN|VM_GROWSUP
from shared anonymous: hoist the file case's -EINVAL up for both.
Why is memcg's swap accounting so broken? Insane counts, wrong
ownership, unfreeable structures, which later get freed and then
accessed after free.
Turns out to be a tiny a little 3.3-rc1 regression in 9fb4b7cc0724
"page_cgroup: add helper function to get swap_cgroup": the helper
function (actually named lookup_swap_cgroup()) returns an address using
void* arithmetic, but the structure in question is a short.
Reviewed-by: Bob Liu <lliubbo@gmail.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Merge the emailed seties of 19 patches from Andrew Morton
* akpm:
rapidio/tsi721: fix queue wrapping bug in inbound doorbell handler
memcg: fix mapcount check in move charge code for anonymous page
mm: thp: fix BUG on mm->nr_ptes
alpha: fix 32/64-bit bug in futex support
memcg: fix GPF when cgroup removal races with last exit
debugobjects: Fix selftest for static warnings
floppy/scsi: fix setting of BIO flags
drivers/rtc/rtc-r9701.c: fix crash in r9701_remove()
c2port: class_create() returns an ERR_PTR
pps: class_create() returns an ERR_PTR, not NULL
hung_task: fix the broken rcu_lock_break() logic
vfork: kill PF_STARTING
coredump_wait: don't call complete_vfork_done()
vfork: make it killable
vfork: introduce complete_vfork_done()
aio: wake up waiters when freeing unused kiocbs
kprobes: return proper error code from register_kprobe()
kmsg_dump: don't run on non-error paths by default
Currently the charge on shared anonyous pages is supposed not to moved in
task migration. To implement this, we need to check that mapcount > 1,
instread of > 2. So this patch fixes it.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Dave Jones reports a few Fedora users hitting the BUG_ON(mm->nr_ptes...)
in exit_mmap() recently.
Quoting Hugh's discovery and explanation of the SMP race condition:
"mm->nr_ptes had unusual locking: down_read mmap_sem plus
page_table_lock when incrementing, down_write mmap_sem (or mm_users
0) when decrementing; whereas THP is careful to increment and
decrement it under page_table_lock.
Now most of those paths in THP also hold mmap_sem for read or write
(with appropriate checks on mm_users), but two do not: when
split_huge_page() is called by hwpoison_user_mappings(), and when
called by add_to_swap().
It's conceivable that the latter case is responsible for the
exit_mmap() BUG_ON mm->nr_ptes that has been reported on Fedora."
The simplest way to fix it without having to alter the locking is to make
split_huge_page() a noop in nr_ptes terms, so by counting the preallocated
pagetables that exists for every mapped hugepage. It was an arbitrary
choice not to count them and either way is not wrong or right, because
they are not used but they're still allocated.
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: <stable@vger.kernel.org> [3.0.x, 3.1.x, 3.2.x]
When moving tasks from old memcg (with move_charge_at_immigrate on new
memcg), followed by removal of old memcg, hit General Protection Fault in
mem_cgroup_lru_del_list() (called from release_pages called from
free_pages_and_swap_cache from tlb_flush_mmu from tlb_finish_mmu from
exit_mmap from mmput from exit_mm from do_exit).
Somewhat reproducible, takes a few hours: the old struct mem_cgroup has
been freed and poisoned by SLAB_DEBUG, but mem_cgroup_lru_del_list() is
still trying to update its stats, and take page off lru before freeing.
A task, or a charge, or a page on lru: each secures a memcg against
removal. In this case, the last task has been moved out of the old memcg,
and it is exiting: anonymous pages are uncharged one by one from the
memcg, as they are zapped from its pagetables, so the charge gets down to
0; but the pages themselves are queued in an mmu_gather for freeing.
Most of those pages will be on lru (and force_empty is careful to
lru_add_drain_all, to add pages from pagevec to lru first), but not
necessarily all: perhaps some have been isolated for page reclaim, perhaps
some isolated for other reasons. So, force_empty may find no task, no
charge and no page on lru, and let the removal proceed.
There would still be no problem if these pages were immediately freed; but
typically (and the put_page_testzero protocol demands it) they have to be
added back to lru before they are found freeable, then removed from lru
and freed. We don't see the issue when adding, because the
mem_cgroup_iter() loops keep their own reference to the memcg being
scanned; but when it comes to mem_cgroup_lru_del_list().
I believe this was not an issue in v3.2: there, PageCgroupAcctLRU and
PageCgroupUsed flags were used (like a trick with mirrors) to deflect view
of pc->mem_cgroup to the stable root_mem_cgroup when neither set.
38c5d72f3ebe ("memcg: simplify LRU handling by new rule") mercifully
removed those convolutions, but left this General Protection Fault.
But it's surprisingly easy to restore the old behaviour: just check
PageCgroupUsed in mem_cgroup_lru_add_list() (which decides on which lruvec
to add), and reset pc to root_mem_cgroup if page is uncharged. A risky
change? just going back to how it worked before; testing, and an audit of
uses of pc->mem_cgroup, show no problem.
And there's a nice bonus: with mem_cgroup_lru_add_list() itself making
sure that an uncharged page goes to root lru, mem_cgroup_reset_owner() no
longer has any purpose, and we can safely revert 4e5f01c2b9b9 ("memcg:
clear pc->mem_cgroup if necessary").
Calling update_page_reclaim_stat() after add_page_to_lru_list() in swap.c
is not strictly necessary: the lru_lock there, with RCU before memcg
structures are freed, makes mem_cgroup_get_reclaim_stat_from_page safe
without that; but it seems cleaner to rely on one dependency less.
We have forgotten the rules of lock nesting: the irq-safe ones must be
taken inside the non-irq-safe ones, otherwise we are open to deadlock:
CPU0 CPU1
lock(&(&pc->lock)->rlock);
local_irq_disable();
lock(&(&zone->lru_lock)->rlock);
<Interrupt>
To check a different locking issue, I happened to add a spin_lock to
memcg's bit_spin_lock in lock_page_cgroup(), and lockdep very quickly
complained about __mem_cgroup_commit_charge_lrucare() (on CPU1 above).
So delete __mem_cgroup_commit_charge_lrucare(), passing a bool lrucare to
__mem_cgroup_commit_charge() instead, taking zone->lru_lock under
lock_page_cgroup() in the lrucare case.
The original was using spin_lock_irqsave, but we'd be in more trouble if
it were ever called at interrupt time: unconditional _irq is enough. And
ClearPageLRU before del from lru, SetPageLRU before add to lru: no strong
reason, but that is the ordering used consistently elsewhere.
Fixes 36b62ad539498d00c2d280a151a ("memcg: simplify corner case handling
of LRU").
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull per-cpu patches from Tejun Heo:
"This pull request contains four patches. One replaces manual clearing
with bitmap_clear(), two fix generic definition of __this_cpu ops so
that they don't choose unnecessarily strict arch version. One makes
_this_cpu definition use raw_local_irq_*() so that it doesn't end up
wrecking irq on/off state tracking when used from inside lockdep.
Of the four patches, the raw_local_irq_*() update is the most
important, so please feel free to cherry pick only that one patch and
ignore the rest if you want to - commit e920d5971d 'percpu: use
raw_local_irq_* in _this_cpu op'."
* 'for-3.3-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: fix __this_cpu_{sub,inc,dec}_return() definition
percpu: use raw_local_irq_* in _this_cpu op
percpu: fix generic definition of __this_cpu_add_and_return()
percpu: use bitmap_clear
All other callers already hold either ->mmap_sem (exclusive) or
->page_table_lock. And we need it because some page table flushing
instanced do work explicitly with ge tables.
See e.g. arch/powerpc/mm/tlb_hash32.c, flush_tlb_range() and
flush_range() in there. The same goes for uml, with a lot more
extensive playing with page tables.
Almost all callers are actually fine - flush_tlb_range() may have no
need to bother playing with page tables, but it can do so safely; again,
this caller is the sole exception - everything else either has exclusive
->mmap_sem on the mm in question, or mm->page_table_lock is held.
memblock allocator aligns @size to @align to reduce the amount
of fragmentation. Commit:
7bd0b0f0da ("memblock: Reimplement memblock allocation using reverse free area iterator")
Broke it by incorrectly relocating @size aligning to
memblock_find_in_range_node(). As the aligned size is not
propagated back to memblock_alloc_base_nid(), the actually
reserved size isn't aligned.
While this increases memory use for memblock reserved array,
this shouldn't cause any critical failure; however, it seems
that the size aligning was hiding a use-beyond-allocation bug in
sparc64 and losing the aligning causes boot failure.
The underlying problem is currently being debugged but this is a
proper fix in itself, it's already pretty late in -rc cycle for
boot failures and reverting the change for debugging isn't
difficult. Restore the size aligning moving it to
memblock_alloc_base_nid().
Reported-by: Meelis Roos <mroos@linux.ee>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rob Herring <rob.herring@calxeda.com>
Link: http://lkml.kernel.org/r/20120228205621.GC3252@dhcp-172-17-108-109.mtv.corp.google.com
LKML-Reference: <alpine.SOC.1.00.1202130942030.1488@math.ut.ee>
Don't clear vm_mm in a deleted VMA as it's unnecessary and might
conceivably break the filesystem or driver VMA close routine.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
cc: stable@vger.kernel.org
Lock i_mmap_mutex for access to the VMA prio list to prevent concurrent
access. Currently, certain parts of the mmap handling are protected by
the region mutex, but not all.
There is an issue when memcg unregisters events that were attached to
the same eventfd:
- On the first call mem_cgroup_usage_unregister_event() removes all
events attached to a given eventfd, and if there were no events left,
thresholds->primary would become NULL;
- Since there were several events registered, cgroups core will call
mem_cgroup_usage_unregister_event() again, but now kernel will oops,
as the function doesn't expect that threshold->primary may be NULL.
That's a good question whether mem_cgroup_usage_unregister_event()
should actually remove all events in one go, but nowadays it can't
do any better as cftype->unregister_event callback doesn't pass
any private event-associated cookie. So, let's fix the issue by
simply checking for threshold->primary.
FWIW, w/o the patch the following oops may be observed:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000004
IP: [<ffffffff810be32c>] mem_cgroup_usage_unregister_event+0x9c/0x1f0
Pid: 574, comm: kworker/0:2 Not tainted 3.3.0-rc4+ #9 Bochs Bochs
RIP: 0010:[<ffffffff810be32c>] [<ffffffff810be32c>] mem_cgroup_usage_unregister_event+0x9c/0x1f0
RSP: 0018:ffff88001d0b9d60 EFLAGS: 00010246
Process kworker/0:2 (pid: 574, threadinfo ffff88001d0b8000, task ffff88001de91cc0)
Call Trace:
[<ffffffff8107092b>] cgroup_event_remove+0x2b/0x60
[<ffffffff8103db94>] process_one_work+0x174/0x450
[<ffffffff8103e413>] worker_thread+0x123/0x2d0
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
When the number of dentry cache hash table entries gets too high
(2147483648 entries), as happens by default on a 16TB system, use of a
signed integer in the dcache_init() initialization loop prevents the
dentry_hashtable from getting initialized, causing a panic in
__d_lookup(). Fix this in dcache_init() and similar areas.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
fix 1 mysterious divide error
fix 3 NULL dereference bugs in writeback tracing, on SD card removal w/o umount
* tag 'writeback-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: fix dereferencing NULL bdi->dev on trace_writeback_queue
lib: proportion: lower PROP_MAX_SHIFT to 32 on 64-bit kernel
writeback: fix NULL bdi->dev in trace writeback_single_inode
backing-dev: fix wakeup timer races with bdi_unregister()
Fix CONFIG_TRANSPARENT_HUGEPAGE=y CONFIG_SMP=n CONFIG_DEBUG_VM=y
CONFIG_DEBUG_SPINLOCK=n kernel: spin_is_locked() is then always false,
and so triggers some BUGs in Transparent HugePage codepaths.
asm-generic/bug.h mentions this problem, and provides a WARN_ON_SMP(x);
but being too lazy to add VM_BUG_ON_SMP, BUG_ON_SMP, WARN_ON_SMP_ONCE,
VM_WARN_ON_SMP_ONCE, just test NR_CPUS != 1 in the existing VM_BUG_ONs.
When isolating pages for migration, migration starts at the start of a
zone while the free scanner starts at the end of the zone. Migration
avoids entering a new zone by never going beyond the free scanned.
Unfortunately, in very rare cases nodes can overlap. When this happens,
migration isolates pages without the LRU lock held, corrupting lists
which will trigger errors in reclaim or during page free such as in the
following oops
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff810f795c>] free_pcppages_bulk+0xcc/0x450
PGD 1dda554067 PUD 1e1cb58067 PMD 0
Oops: 0000 [#1] SMP
CPU 37
Pid: 17088, comm: memcg_process_s Tainted: G X
RIP: free_pcppages_bulk+0xcc/0x450
Process memcg_process_s (pid: 17088, threadinfo ffff881c2926e000, task ffff881c2926c0c0)
Call Trace:
free_hot_cold_page+0x17e/0x1f0
__pagevec_free+0x90/0xb0
release_pages+0x22a/0x260
pagevec_lru_move_fn+0xf3/0x110
putback_lru_page+0x66/0xe0
unmap_and_move+0x156/0x180
migrate_pages+0x9e/0x1b0
compact_zone+0x1f3/0x2f0
compact_zone_order+0xa2/0xe0
try_to_compact_pages+0xdf/0x110
__alloc_pages_direct_compact+0xee/0x1c0
__alloc_pages_slowpath+0x370/0x830
__alloc_pages_nodemask+0x1b1/0x1c0
alloc_pages_vma+0x9b/0x160
do_huge_pmd_anonymous_page+0x160/0x270
do_page_fault+0x207/0x4c0
page_fault+0x25/0x30
The "X" in the taint flag means that external modules were loaded but but
is unrelated to the bug triggering. The real problem was because the PFN
layout looks like this
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
DMA32 0x00001000 -> 0x00100000
Normal 0x00100000 -> 0x01e80000
Movable zone start PFN for each node
early_node_map[14] active PFN ranges
0: 0x00000010 -> 0x0000009b
0: 0x00000100 -> 0x0007a1ec
0: 0x0007a354 -> 0x0007a379
0: 0x0007f7ff -> 0x0007f800
0: 0x00100000 -> 0x00680000
1: 0x00680000 -> 0x00e80000
0: 0x00e80000 -> 0x01080000
1: 0x01080000 -> 0x01280000
0: 0x01280000 -> 0x01480000
1: 0x01480000 -> 0x01680000
0: 0x01680000 -> 0x01880000
1: 0x01880000 -> 0x01a80000
0: 0x01a80000 -> 0x01c80000
1: 0x01c80000 -> 0x01e80000
The fix is straight-forward. isolate_migratepages() has to make a
similar check to isolate_freepage to ensure that it never isolates pages
from a zone it does not hold the LRU lock for.
This was discovered in a 3.0-based kernel but it affects 3.1.x, 3.2.x
and current mainline.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
* akpm:
mm: compaction: check pfn_valid when entering a new MAX_ORDER_NR_PAGES block during isolation for migration
readahead: fix pipeline break caused by block plug
kprobes: fix a memory leak in function pre_handler_kretprobe()
drivers/tty/vt/vt_ioctl.c: fix KDFONTOP 32bit compatibility layer
lkdtm: avoid calling lkdtm_do_action() with spinlock held
mm/filemap_xip.c: fix race condition in xip_file_fault()
mm/memcontrol.c: fix warning with CONFIG_NUMA=n
avr32: select generic atomic64_t support
mm: postpone migrated page mapping reset
xtensa: fix memscan()
MAINTAINERS: update lguest F: patterns
MAINTAINERS: remove staging sections
MAINTAINERS: remove iMX5 section
MAINTAINERS: update partitions block F: patterns
When isolating for migration, migration starts at the start of a zone
which is not necessarily pageblock aligned. Further, it stops isolating
when COMPACT_CLUSTER_MAX pages are isolated so migrate_pfn is generally
not aligned. This allows isolate_migratepages() to call pfn_to_page() on
an invalid PFN which can result in a crash. This was originally reported
against a 3.0-based kernel with the following trace in a crash dump.
PID: 9902 TASK: d47aecd0 CPU: 0 COMMAND: "memcg_process_s"
#0 [d72d3ad0] crash_kexec at c028cfdb
#1 [d72d3b24] oops_end at c05c5322
#2 [d72d3b38] __bad_area_nosemaphore at c0227e60
#3 [d72d3bec] bad_area at c0227fb6
#4 [d72d3c00] do_page_fault at c05c72ec
#5 [d72d3c80] error_code (via page_fault) at c05c47a4
EAX: 00000000 EBX: 000c0000 ECX: 00000001 EDX: 00000807 EBP: 000c0000
DS: 007b ESI: 00000001 ES: 007b EDI: f3000a80 GS: 6f50
CS: 0060 EIP: c030b15a ERR: ffffffff EFLAGS: 00010002
#6 [d72d3cb4] isolate_migratepages at c030b15a
#7 [d72d3d14] zone_watermark_ok at c02d26cb
#8 [d72d3d2c] compact_zone at c030b8de
#9 [d72d3d68] compact_zone_order at c030bba1
#10 [d72d3db4] try_to_compact_pages at c030bc84
#11 [d72d3ddc] __alloc_pages_direct_compact at c02d61e7
#12 [d72d3e08] __alloc_pages_slowpath at c02d66c7
#13 [d72d3e78] __alloc_pages_nodemask at c02d6a97
#14 [d72d3eb8] alloc_pages_vma at c030a845
#15 [d72d3ed4] do_huge_pmd_anonymous_page at c03178eb
#16 [d72d3f00] handle_mm_fault at c02f36c6
#17 [d72d3f30] do_page_fault at c05c70ed
#18 [d72d3fb0] error_code (via page_fault) at c05c47a4
EAX: b71ff000 EBX: 00000001 ECX: 00001600 EDX: 00000431
DS: 007b ESI: 08048950 ES: 007b EDI: bfaa3788
SS: 007b ESP: bfaa36e0 EBP: bfaa3828 GS: 6f50
CS: 0073 EIP: 080487c8 ERR: ffffffff EFLAGS: 00010202
It was also reported by Herbert van den Bergh against 3.1-based kernel
with the following snippet from the console log.
BUG: unable to handle kernel paging request at 01c00008
IP: [<c0522399>] isolate_migratepages+0x119/0x390
*pdpt = 000000002f7ce001 *pde = 0000000000000000
It is expected that it also affects 3.2.x and current mainline.
The problem is that pfn_valid is only called on the first PFN being
checked and that PFN is not necessarily aligned. Lets say we have a case
like this
H = MAX_ORDER_NR_PAGES boundary
| = pageblock boundary
m = cc->migrate_pfn
f = cc->free_pfn
o = memory hole
H------|------H------|----m-Hoooooo|ooooooH-f----|------H
The migrate_pfn is just below a memory hole and the free scanner is beyond
the hole. When isolate_migratepages started, it scans from migrate_pfn to
migrate_pfn+pageblock_nr_pages which is now in a memory hole. It checks
pfn_valid() on the first PFN but then scans into the hole where there are
not necessarily valid struct pages.
This patch ensures that isolate_migratepages calls pfn_valid when
necessary.
Reported-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
Tested-by: Herbert van den Bergh <herbert.van.den.bergh@oracle.com>
Herbert Poetzl reported a performance regression since 2.6.39. The test
is a simple dd read, but with big block size. The reason is:
T1: ra (A, A+128k), (A+128k, A+256k)
T2: lock_page for page A, submit the 256k
T3: hit page A+128K, ra (A+256k, A+384). the range isn't submitted
because of plug and there isn't any lock_page till we hit page A+256k
because all pages from A to A+256k is in memory
T4: hit page A+256k, ra (A+384, A+ 512). Because of plug, the range isn't
submitted again.
T5: lock_page A+256k, so (A+256k, A+512k) will be submitted. The task is
waitting for (A+256k, A+512k) finish.
There is no request to disk in T3 and T4, so readahead pipeline breaks.
We really don't need block plug for generic_file_aio_read() for buffered
I/O. The readahead already has plug and has fine grained control when I/O
should be submitted. Deleting plug for buffered I/O fixes the regression.
One side effect is plug makes the request size 256k, the size is 128k
without it. This is because default ra size is 128k and not a reason we
need plug here.
Vivek said:
: We submit some readahead IO to device request queue but because of nested
: plug, queue never gets unplugged. When read logic reaches a page which is
: not in page cache, it waits for page to be read from the disk
: (lock_page_killable()) and that time we flush the plug list.
: So effectively read ahead logic is kind of broken in parts because of
: nested plugging. Removing top level plug (generic_file_aio_read()) for
: buffered reads, will allow unplugging queue earlier for readahead.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Reported-by: Herbert Poetzl <herbert@13thfloor.at>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Fix a race condition that shows in conjunction with xip_file_fault() when
two threads of the same user process fault on the same memory page.
In this case, the race winner will install the page table entry and the
unlucky loser will cause an oops: xip_file_fault calls vm_insert_pfn (via
vm_insert_mixed) which drops out at this check:
retval = -EBUSY;
if (!pte_none(*pte))
goto out_unlock;
The resulting -EBUSY return value will trigger a BUG_ON() in
xip_file_fault.
This fix simply considers the fault as fixed in this case, because the
race winner has successfully installed the pte.
[akpm@linux-foundation.org: use conventional (and consistent) comment layout]
Reported-by: David Sadler <dsadler@us.ibm.com>
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Reported-by: Louis Alex Eisner <leisner@cs.ucsd.edu>
mm/memcontrol.c: In function 'memcg_check_events':
mm/memcontrol.c:779: warning: unused variable 'do_numainfo'
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Hiroyuki KAMEZAWA <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: "Kirill A. Shutemov" <kirill@shutemov.name>
Postpone resetting page->mapping until the final remove_migration_ptes().
Otherwise the expression PageAnon(migration_entry_to_page(entry)) does not
work.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux
Trivial kmemleak bug-fixes:
- Early logging doesn't stop when kmemleak is off by default.
- Zero-size scanning areas should be ignored (currently it prints a
warning).
* tag 'kmemleak-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux:
kmemleak: Disable early logging when kmemleak is off by default
kmemleak: Only scan non-zero-size areas
This fixes the race in process_vm_core found by Oleg (see
http://article.gmane.org/gmane.linux.kernel/1235667/
for details).
This has been updated since I last sent it as the creation of the new
mm_access() function did almost exactly the same thing as parts of the
previous version of this patch did.
In order to use mm_access() even when /proc isn't enabled, we move it to
kernel/fork.c where other related process mm access functions already
are.
Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com>
While 7a401a972df8e18 ("backing-dev: ensure wakeup_timer is deleted")
addressed the problem of the bdi being freed with a queued wakeup
timer, there are other races that could happen if the wakeup timer
expires after/during bdi_unregister(), before bdi_destroy() is called.
wakeup_timer_fn() could attempt to wakeup a task which has already has
been freed, or could access a NULL bdi->dev via the wake_forker_thread
tracepoint.
Cc: <stable@kernel.org>
Reported-by: Chanho Min <chanho.min@lge.com>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
Signed-off-by: Rabin Vincent <rabin@rab.in>
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
rcu: Add missing __cpuinit annotation in rcutorture code
sched: Add "const" to is_idle_task() parameter
rcu: Make rcutorture bool parameters really bool (core code)
memblock: Fix alloc failure due to dumb underflow protection in memblock_find_in_range_node()
Davem says:
1) Fix JIT code generation on x86-64 for divide by zero, from Eric Dumazet.
2) tg3 header length computation correction from Eric Dumazet.
3) More build and reference counting fixes for socket memory cgroup
code from Glauber Costa.
4) module.h snuck back into a core header after all the hard work we
did to remove that, from Paul Gortmaker and Jesper Dangaard Brouer.
5) Fix PHY naming regression and add some new PCI IDs in stmmac, from
Alessandro Rubini.
6) Netlink message generation fix in new team driver, should only advertise
the entries that changed during events, from Jiri Pirko.
7) SRIOV VF registration and unregistration fixes, and also add a
missing PCI ID, from Roopa Prabhu.
8) Fix infinite loop in tx queue flush code of brcmsmac, from Stanislaw Gruszka.
9) ftgmac100/ftmac100 build fix, missing interrupt.h include.
10) Memory leak fix in net/hyperv do_set_mutlicast() handling, from Wei Yongjun.
11) Off by one fix in netem packet scheduler, from Vijay Subramanian.
12) TCP loss detection fix from Yuchung Cheng.
13) TCP reset packet MD5 calculation uses wrong address, fix from Shawn Lu.
14) skge carrier assertion and DMA mapping fixes from Stephen Hemminger.
15) Congestion recovery undo performed at the wrong spot in BIC and CUBIC
congestion control modules, fix from Neal Cardwell.
16) Ethtool ETHTOOL_GSSET_INFO is unnecessarily restrictive, from Michał Mirosław.
17) Fix triggerable race in ipv6 sysctl handling, from Francesco Ruggeri.
18) Statistics bug fixes in mlx4 from Eugenia Emantayev.
19) rds locking bug fix during info dumps, from your's truly.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (67 commits)
rds: Make rds_sock_lock BH rather than IRQ safe.
netprio_cgroup.h: dont include module.h from other includes
net: flow_dissector.c missing include linux/export.h
team: send only changed options/ports via netlink
net/hyperv: fix possible memory leak in do_set_multicast()
drivers/net: dsa/mv88e6xxx.c files need linux/module.h
stmmac: added PCI identifiers
llc: Fix race condition in llc_ui_recvmsg
stmmac: fix phy naming inconsistency
dsa: Add reporting of silicon revision for Marvell 88E6123/88E6161/88E6165 switches.
tg3: fix ipv6 header length computation
skge: add byte queue limit support
mv643xx_eth: Add Rx Discard and Rx Overrun statistics
bnx2x: fix compilation error with SOE in fw_dump
bnx2x: handle CHIP_REVISION during init_one
bnx2x: allow user to change ring size in ISCSI SD mode
bnx2x: fix Big-Endianess in ethtool -t
bnx2x: fixed ethtool statistics for MF modes
bnx2x: credit-leakage fixup on vlan_mac_del_all
macvlan: fix a possible use after free
Memory migration fills a pte with a migration entry and it doesn't
update the rss counters. Then it replaces the migration entry with the
new page (or the old one if migration failed). But between these two
passes this pte can be unmaped, or a task can fork a child and it will
get a copy of this migration entry. Nobody accounts for this in the rss
counters.
This patch properly adjust rss counters for migration entries in
zap_pte_range() and copy_one_pte(). Thus we avoid extra atomic
operations on the migration fast-path.
Commit cc39c6a9bbde ("mm: account skipped entries to avoid looping in
find_get_pages") correctly fixed an infinite loop; but left a problem
that find_get_pages() on shmem would return 0 (appearing to callers to
mean end of tree) when it meets a run of nr_pages swap entries.
The only uses of find_get_pages() on shmem are via pagevec_lookup(),
called from invalidate_mapping_pages(), and from shmctl SHM_UNLOCK's
scan_mapping_unevictable_pages(). The first is already commented, and
not worth worrying about; but the second can leave pages on the
Unevictable list after an unusual sequence of swapping and locking.
Fix that by using shmem_find_get_pages_and_swap() (then ignoring the
swap) instead of pagevec_lookup().
But I don't want to contaminate vmscan.c with shmem internals, nor
shmem.c with LRU locking. So move scan_mapping_unevictable_pages() into
shmem.c, renaming it shmem_unlock_mapping(); and rename
check_move_unevictable_page() to check_move_unevictable_pages(), looping
down an array of pages, oftentimes under the same lock.
Leave out the "rotate unevictable list" block: that's a leftover from
when this was used for /proc/sys/vm/scan_unevictable_pages, whose flawed
handling involved looking at pages at tail of LRU.
Was there significance to the sequence first ClearPageUnevictable, then
test page_evictable, then SetPageUnevictable here? I think not, we're
under LRU lock, and have no barriers between those.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: <stable@vger.kernel.org> [back to 3.1 but will need respins]
scan_mapping_unevictable_pages() is used to make SysV SHM_LOCKed pages
evictable again once the shared memory is unlocked. It does this with
pagevec_lookup()s across the whole object (which might occupy most of
memory), and takes 300ms to unlock 7GB here. A cond_resched() every
PAGEVEC_SIZE pages would be good.
However, KOSAKI-san points out that this is called under shmem.c's
info->lock, and it's also under shm.c's shm_lock(), both spinlocks.
There is no strong reason for that: we need to take these pages off the
unevictable list soonish, but those locks are not required for it.
So move the call to scan_mapping_unevictable_pages() from shmem.c's
unlock handling up to shm.c's unlock handling. Remove the recently
added barrier, not needed now we have spin_unlock() before the scan.
Use get_file(), with subsequent fput(), to make sure we have a reference
to mapping throughout scan_mapping_unevictable_pages(): that's something
that was previously guaranteed by the shm_lock().
Remove shmctl's lru_add_drain_all(): we don't fault in pages at SHM_LOCK
time, and we lazily discover them to be Unevictable later, so it serves
no purpose for SHM_LOCK; and serves no purpose for SHM_UNLOCK, since
pages still on pagevec are not marked Unevictable.
The original code avoided redundant rescans by checking VM_LOCKED flag
at its level: now avoid them by checking shp's SHM_LOCKED.
The original code called scan_mapping_unevictable_pages() on a locked
area at shm_destroy() time: perhaps we once had accounting cross-checks
which required that, but not now, so skip the overhead and just let
inode eviction deal with them.
Put check_move_unevictable_page() and scan_mapping_unevictable_pages()
under CONFIG_SHMEM (with stub for the TINY case when ramfs is used),
more as comment than to save space; comment them used for SHM_UNLOCK.
Page mapcount should be updated only if we are sure that the page ends
up in the page table otherwise we would leak if we couldn't COW due to
reservations or if idx is out of bounds.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
end_migration() passes the old page instead of the new page to commit
the charge. This page descriptor is not used for committing itself,
though, since we also pass the (correct) page_cgroup descriptor. But
it's used to find the soft limit tree through the page's zone, so the
soft limit tree of the old page's zone is updated instead of that of the
new page's, which might get slightly out of date until the next charge
reaches the ratelimit point.
This glitch has been present since 5564e88 ("memcg: condense
page_cgroup-to-page lookup points").
This fixes a bug that I introduced in 2.6.38. It's benign enough (to my
knowledge) that we probably don't want this for stable.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
page_zone() requires an online node otherwise we are accessing NULL
NODE_DATA. This is not an issue at the moment because node_zones are
located at the structure beginning but this might change in the future
so better be careful about that.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Fix the following NULL ptr dereference caused by
cat /sys/devices/system/memory/memory0/removable
Pid: 13979, comm: sed Not tainted 3.0.13-0.5-default #1 IBM BladeCenter LS21 -[7971PAM]-/Server Blade
RIP: __count_immobile_pages+0x4/0x100
Process sed (pid: 13979, threadinfo ffff880221c36000, task ffff88022e788480)
Call Trace:
is_pageblock_removable_nolock+0x34/0x40
is_mem_section_removable+0x74/0xf0
show_mem_removable+0x41/0x70
sysfs_read_file+0xfe/0x1c0
vfs_read+0xc7/0x130
sys_read+0x53/0xa0
system_call_fastpath+0x16/0x1b
We are crashing because we are trying to dereference NULL zone which
came from pfn=0 (struct page ffffea0000000000). According to the boot
log this page is marked reserved:
e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
and early_node_map confirms that:
early_node_map[3] active PFN ranges
1: 0x00000010 -> 0x0000009c
1: 0x00000100 -> 0x000bffa3
1: 0x00100000 -> 0x00240000
The problem is that memory_present works in PAGE_SECTION_MASK aligned
blocks so the reserved range sneaks into the the section as well. This
also means that free_area_init_node will not take care of those reserved
pages and they stay uninitialized.
When we try to read the removable status we walk through all available
sections and hope that the zone is valid for all pages in the section.
But this is not true in this case as the zone and nid are not initialized.
We have only one node in this particular case and it is marked as node=1
(rather than 0) and that made the problem visible because page_to_nid will
return 0 and there are no zones on the node.
Let's check that the zone is valid and that the given pfn falls into its
boundaries and mark the section not removable. This might cause some
false positives, probably, but we do not have any sane way to find out
whether the page is reserved by the platform or it is just not used for
whatever other reasons.
There is still a build bug with the sock memcg code, that triggers
with !CONFIG_NET, that survived my series of randconfig builds.
Signed-off-by: Glauber Costa <glommer@parallels.com>
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
CC: Hiroyouki Kamezawa <kamezawa.hiroyu@jp.fujitsu.com>
Use bitmap_clear rather than clearing individual bits in a memory region.
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Commit b6693005 (kmemleak: When the early log buffer is exceeded, report
the actual number) deferred the disabling of the early logging to
kmemleak_init(). However, when CONFIG_DEBUG_KMEMLEAK_DEFAULT_OFF=y, the
early logging was no longer disabled causing __init kmemleak functions
to be called even after the kernel freed the init memory. This patch
disables the early logging during kmemleak_init() if kmemleak is left
disabled.
Reported-by: Dirk Gouders <gouders@et.bocholt.fh-gelsenkirchen.de>
Tested-by: Dirk Gouders <gouders@et.bocholt.fh-gelsenkirchen.de>
Tested-by: Josh Boyer <jwboyer@gmail.com>
Kmemleak should only track valid scan areas with a non-zero size.
Otherwise, such area may reside just at the end of an object and
kmemleak would report "Adding scan area to unknown object".
Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com>
