commit 03787301420376ae41fbaf4267f4a6253d152ac5 upstream.
Commit b1cb0982bdd6 ("change the management method of free objects of
the slab") introduced a bug on slab leak detector
('/proc/slab_allocators'). This detector works like as following
decription.
1. traverse all objects on all the slabs.
2. determine whether it is active or not.
3. if active, print who allocate this object.
but that commit changed the way how to manage free objects, so the logic
determining whether it is active or not is also changed. In before, we
regard object in cpu caches as inactive one, but, with this commit, we
mistakenly regard object in cpu caches as active one.
This intoduces kernel oops if DEBUG_PAGEALLOC is enabled. If
DEBUG_PAGEALLOC is enabled, kernel_map_pages() is used to detect who
corrupt free memory in the slab. It unmaps page table mapping if object
is free and map it if object is active. When slab leak detector check
object in cpu caches, it mistakenly think this object active so try to
access object memory to retrieve caller of allocation. At this point,
page table mapping to this object doesn't exist, so oops occurs.
Following is oops message reported from Dave.
It blew up when something tried to read /proc/slab_allocators
(Just cat it, and you should see the oops below)
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
[snip...]
CPU: 1 PID: 9386 Comm: trinity-c33 Not tainted 3.14.0-rc5+ #131
task: ffff8801aa46e890 ti: ffff880076924000 task.ti: ffff880076924000
RIP: 0010:[<ffffffffaa1a8f4a>] [<ffffffffaa1a8f4a>] handle_slab+0x8a/0x180
RSP: 0018:ffff880076925de0 EFLAGS: 00010002
RAX: 0000000000001000 RBX: 0000000000000000 RCX: 000000005ce85ce7
RDX: ffffea00079be100 RSI: 0000000000001000 RDI: ffff880107458000
RBP: ffff880076925e18 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 000000000000000f R12: ffff8801e6f84000
R13: ffffea00079be100 R14: ffff880107458000 R15: ffff88022bb8d2c0
FS: 00007fb769e45740(0000) GS:ffff88024d040000(0000) knlGS:0000000000000000
CR2: ffff8801e6f84ff8 CR3: 00000000a22db000 CR4: 00000000001407e0
DR0: 0000000002695000 DR1: 0000000002695000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000070602
Call Trace:
leaks_show+0xce/0x240
seq_read+0x28e/0x490
proc_reg_read+0x3d/0x80
vfs_read+0x9b/0x160
SyS_read+0x58/0xb0
tracesys+0xd4/0xd9
Code: f5 00 00 00 0f 1f 44 00 00 48 63 c8 44 3b 0c 8a 0f 84 e3 00 00 00 83 c0 01 44 39 c0 72 eb 41 f6 47 1a 01 0f 84 e9 00 00 00 89 f0 <4d> 8b 4c 04 f8 4d 85 c9 0f 84 88 00 00 00 49 8b 7e 08 4d 8d 46
RIP handle_slab+0x8a/0x180
To fix the problem, I introduce an object status buffer on each slab.
With this, we can track object status precisely, so slab leak detector
would not access active object and no kernel oops would occur. Memory
overhead caused by this fix is only imposed to CONFIG_DEBUG_SLAB_LEAK
which is mainly used for debugging, so memory overhead isn't big
problem.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Reviewed-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
commit 13ace4d0d9db40e10ecd66dfda14e297571be813 upstream.
I was well aware of FALLOC_FL_ZERO_RANGE and FALLOC_FL_COLLAPSE_RANGE
support being added to fallocate(); but didn't realize until now that I
had been too stupid to future-proof shmem_fallocate() against new
additions. -EOPNOTSUPP instead of going on to ordinary fallocation.
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
The age table walker doesn't check non-present hugetlb entry in common
path, so hugetlb_entry() callbacks must check it. The reason for this
behavior is that some callers want to handle it in its own way.
[ I think that reason is bogus, btw - it should just do what the regular
code does, which is to call the "pte_hole()" function for such hugetlb
entries - Linus]
However, some callers don't check it now, which causes unpredictable
result, for example when we have a race between migrating hugepage and
reading /proc/pid/numa_maps. This patch fixes it by adding !pte_present
checks on buggy callbacks.
This bug exists for years and got visible by introducing hugepage
migration.
ChangeLog v2:
- fix if condition (check !pte_present() instead of pte_present())
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: <stable@vger.kernel.org> [3.12+]
[ Backported to 3.15. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> ]
While working address sanitizer for kernel I've discovered
use-after-free bug in __put_anon_vma.
For the last anon_vma, anon_vma->root freed before child anon_vma.
Later in anon_vma_free(anon_vma) we are referencing to already freed
anon_vma->root to check rwsem.
This fixes it by freeing the child anon_vma before freeing
anon_vma->root.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: <stable@vger.kernel.org> # v3.0+
When a memory error happens on an in-use page or (free and in-use)
hugepage, the victim page is isolated with its refcount set to one.
When you try to unpoison it later, unpoison_memory() calls put_page()
for it twice in order to bring the page back to free page pool (buddy or
free hugepage list). However, if another memory error occurs on the
page which we are unpoisoning, memory_failure() returns without
releasing the refcount which was incremented in the same call at first,
which results in memory leak and unconsistent num_poisoned_pages
statistics. This patch fixes it.
Cc: <stable@vger.kernel.org> [2.6.32+]
Commit 284f39afeaa4 ("mm: memcg: push !mm handling out to page cache
charge function") explicitly checks for page cache charges without any
mm context (from kernel thread context[1]).
This seemed to be the only possible case where memory could be charged
without mm context so commit 03583f1a631c ("memcg: remove unnecessary
!mm check from try_get_mem_cgroup_from_mm()") removed the mm check from
get_mem_cgroup_from_mm(). This however caused another NULL ptr
dereference during early boot when loopback kernel thread splices to
tmpfs as reported by Stephan Kulow:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000360
IP: get_mem_cgroup_from_mm.isra.42+0x2b/0x60
Oops: 0000 [#1] SMP
Modules linked in: btrfs dm_multipath dm_mod scsi_dh multipath raid10 raid456 async_raid6_recov async_memcpy async_pq raid6_pq async_xor xor async_tx raid1 raid0 md_mod parport_pc parport nls_utf8 isofs usb_storage iscsi_ibft iscsi_boot_sysfs arc4 ecb fan thermal nfs lockd fscache nls_iso8859_1 nls_cp437 sg st hid_generic usbhid af_packet sunrpc sr_mod cdrom ata_generic uhci_hcd virtio_net virtio_blk ehci_hcd usbcore ata_piix floppy processor button usb_common virtio_pci virtio_ring virtio edd squashfs loop ppa]
CPU: 0 PID: 97 Comm: loop1 Not tainted 3.15.0-rc5-5-default #1
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
__mem_cgroup_try_charge_swapin+0x40/0xe0
mem_cgroup_charge_file+0x8b/0xd0
shmem_getpage_gfp+0x66b/0x7b0
shmem_file_splice_read+0x18f/0x430
splice_direct_to_actor+0xa2/0x1c0
do_lo_receive+0x5a/0x60 [loop]
loop_thread+0x298/0x720 [loop]
kthread+0xc6/0xe0
ret_from_fork+0x7c/0xb0
Also Branimir Maksimovic reported the following oops which is tiggered
for the swapcache charge path from the accounting code for kernel threads:
CPU: 1 PID: 160 Comm: kworker/u8:5 Tainted: P OE 3.15.0-rc5-core2-custom #159
Hardware name: System manufacturer System Product Name/MAXIMUSV GENE, BIOS 1903 08/19/2013
task: ffff880404e349b0 ti: ffff88040486a000 task.ti: ffff88040486a000
RIP: get_mem_cgroup_from_mm.isra.42+0x2b/0x60
Call Trace:
__mem_cgroup_try_charge_swapin+0x45/0xf0
mem_cgroup_charge_file+0x9c/0xe0
shmem_getpage_gfp+0x62c/0x770
shmem_write_begin+0x38/0x40
generic_perform_write+0xc5/0x1c0
__generic_file_aio_write+0x1d1/0x3f0
generic_file_aio_write+0x4f/0xc0
do_sync_write+0x5a/0x90
do_acct_process+0x4b1/0x550
acct_process+0x6d/0xa0
do_exit+0x827/0xa70
kthread+0xc3/0xf0
This patch fixes the issue by reintroducing mm check into
get_mem_cgroup_from_mm. We could do the same trick in
__mem_cgroup_try_charge_swapin as we do for the regular page cache path
but it is not worth troubles. The check is not that expensive and it is
better to have get_mem_cgroup_from_mm more robust.
[1] - http://marc.info/?l=linux-mm&m=139463617808941&w=2
Fixes: 03583f1a631c ("memcg: remove unnecessary !mm check from try_get_mem_cgroup_from_mm()")
Reported-and-tested-by: Stephan Kulow <coolo@suse.com>
Reported-by: Branimir Maksimovic <branimir.maksimovic@gmail.com>
MADV_WILLNEED currently does not read swapped out shmem pages back in.
Commit 0cd6144aadd2 ("mm + fs: prepare for non-page entries in page
cache radix trees") made find_get_page() filter exceptional radix tree
entries but failed to convert all find_get_page() callers that WANT
exceptional entries over to find_get_entry(). One of them is shmem swap
readahead in madvise, which now skips over any swap-out records.
Convert it to find_get_entry().
Fixes: 0cd6144aadd2 ("mm + fs: prepare for non-page entries in page cache radix trees")
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Hugh Dickins <hughd@google.com>
In some testing I ran today (some fio jobs that spread over two nodes),
we end up spending 40% of the time in filemap_check_errors(). That
smells fishy. Looking further, this is basically what happens:
blkdev_aio_read()
generic_file_aio_read()
filemap_write_and_wait_range()
if (!mapping->nr_pages)
and filemap_check_errors() always attempts two test_and_clear_bit() on
the mapping flags, thus dirtying it for every single invocation. The
patch below tests each of these bits before clearing them, avoiding this
issue. In my test case (4-socket box), performance went from 1.7M IOPS
to 4.0M IOPS.
Signed-off-by: Jens Axboe <axboe@fb.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
hugepage
For handling a free hugepage in memory failure, the race will happen if
another thread hwpoisoned this hugepage concurrently. So we need to
check PageHWPoison instead of !PageHWPoison.
If hwpoison_filter(p) returns true or a race happens, then we need to
unlock_page(hpage).
Signed-off-by: Chen Yucong <slaoub@gmail.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: <stable@vger.kernel.org> [2.6.36+]
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag
Pull Metag architecture and related fixes from James Hogan:
"Mostly fixes for metag and parisc relating to upgrowing stacks.
- Fix missing compiler barriers in metag memory barriers.
- Fix BUG_ON on metag when RLIMIT_STACK hard limit is increased
beyond safe value.
- Make maximum stack size configurable. This reduces the default
user stack size back to 80MB (especially on parisc after their
removal of _STK_LIM_MAX override). This only affects metag and
parisc.
- Remove metag _STK_LIM_MAX override to match other arches and follow
parisc, now that it is safe to do so (due to the BUG_ON fix
mentioned above).
- Finally now that both metag and parisc _STK_LIM_MAX overrides have
been removed, it makes sense to remove _STK_LIM_MAX altogether"
* tag 'metag-for-v3.15-2' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag:
asm-generic: remove _STK_LIM_MAX
metag: Remove _STK_LIM_MAX override
parisc,metag: Do not hardcode maximum userspace stack size
metag: Reduce maximum stack size to 256MB
metag: fix memory barriers
This patch affects only architectures where the stack grows upwards
(currently parisc and metag only). On those do not hardcode the maximum
initial stack size to 1GB for 32-bit processes, but make it configurable
via a config option.
The main problem with the hardcoded stack size is, that we have two
memory regions which grow upwards: stack and heap. To keep most of the
memory available for heap in a flexmap memory layout, it makes no sense
to hard allocate up to 1GB of the memory for stack which can't be used
as heap then.
This patch makes the stack size for 32-bit processes configurable and
uses 80MB as default value which has been in use during the last few
years on parisc and which hasn't showed any problems yet.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: linux-parisc@vger.kernel.org
Cc: linux-metag@vger.kernel.org
Cc: John David Anglin <dave.anglin@bell.net>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull a percpu fix from Tejun Heo:
"Fix for a percpu allocator bug where it could try to kfree() a memory
region allocated using vmalloc(). The bug has been there for years
now and is unlikely to have ever triggered given the size of struct
pcpu_chunk. It's still theoretically possible and the fix is simple
and safe enough, so the patch is marked with -stable"
* 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: make pcpu_alloc_chunk() use pcpu_mem_free() instead of kfree()
It's critical for split_huge_page() (and migration) to catch and freeze
all PMDs on rmap walk. It gets tricky if there's concurrent fork() or
mremap() since usually we copy/move page table entries on dup_mm() or
move_page_tables() without rmap lock taken. To get it work we rely on
rmap walk order to not miss any entry. We expect to see destination VMA
after source one to work correctly.
But after switching rmap implementation to interval tree it's not always
possible to preserve expected walk order.
It works fine for dup_mm() since new VMA has the same vma_start_pgoff()
/ vma_last_pgoff() and explicitly insert dst VMA after src one with
vma_interval_tree_insert_after().
But on move_vma() destination VMA can be merged into adjacent one and as
result shifted left in interval tree. Fortunately, we can detect the
situation and prevent race with rmap walk by moving page table entries
under rmap lock. See commit 38a76013ad80.
Problem is that we miss the lock when we move transhuge PMD. Most
likely this bug caused the crash[1].
[1] http://thread.gmane.org/gmane.linux.kernel.mm/96473
Fixes: 108d6642ad81 ("mm anon rmap: remove anon_vma_moveto_tail")
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Michel Lespinasse <walken@google.com>
Cc: Dave Jones <davej@redhat.com>
Cc: <stable@vger.kernel.org> [3.7+]
Commit 8910ae896c8c ("kmemleak: change some global variables to int"),
in addition to the atomic -> int conversion, moved the disabling of
kmemleak_early_log to the beginning of the kmemleak_init() function,
before the full kmemleak tracing is actually enabled. In this small
window, kmem_cache_create() is called by kmemleak which triggers
additional memory allocation that are not traced. This patch restores
the original logic with kmemleak_early_log disabling when kmemleak is
fully functional.
Fixes: 8910ae896c8c (kmemleak: change some global variables to int)
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Li Zefan <lizefan@huawei.com>
Merge misc fixes from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
agp: info leak in agpioc_info_wrap()
fs/affs/super.c: bugfix / double free
fanotify: fix -EOVERFLOW with large files on 64-bit
slub: use sysfs'es release mechanism for kmem_cache
revert "mm: vmscan: do not swap anon pages just because free+file is low"
autofs: fix lockref lookup
mm: filemap: update find_get_pages_tag() to deal with shadow entries
mm/compaction: make isolate_freepages start at pageblock boundary
MAINTAINERS: zswap/zbud: change maintainer email address
mm/page-writeback.c: fix divide by zero in pos_ratio_polynom
hugetlb: ensure hugepage access is denied if hugepages are not supported
slub: fix memcg_propagate_slab_attrs
drivers/rtc/rtc-pcf8523.c: fix month definition
debugobjects warning during netfilter exit:
WARNING: CPU: 6 PID: 4178 at lib/debugobjects.c:260 debug_print_object+0x8d/0xb0()
ODEBUG: free active (active state 0) object type: timer_list hint: delayed_work_timer_fn+0x0/0x20
Modules linked in:
CPU: 6 PID: 4178 Comm: kworker/u16:2 Tainted: G W 3.11.0-next-20130906-sasha #3984
Workqueue: netns cleanup_net
Call Trace:
dump_stack+0x52/0x87
warn_slowpath_common+0x8c/0xc0
warn_slowpath_fmt+0x46/0x50
__debug_check_no_obj_freed+0xa5/0x220
debug_check_no_obj_freed+0x15/0x20
kmem_cache_free+0x197/0x340
kmem_cache_destroy+0x86/0xe0
nf_conntrack_cleanup_net_list+0x131/0x170
nf_conntrack_pernet_exit+0x5d/0x70
ops_exit_list+0x5e/0x70
cleanup_net+0xfb/0x1c0
process_one_work+0x338/0x550
worker_thread+0x215/0x350
kthread+0xe7/0xf0
Also during dcookie cleanup:
WARNING: CPU: 12 PID: 9725 at lib/debugobjects.c:260 debug_print_object+0x8c/0xb0()
Modules linked in:
CPU: 12 PID: 9725 Comm: trinity-c141 Not tainted 3.15.0-rc2-next-20140423-sasha-00018-gc4ff6c4 #408
Call Trace:
dump_stack (lib/dump_stack.c:52)
warn_slowpath_common (kernel/panic.c:430)
warn_slowpath_fmt (kernel/panic.c:445)
debug_print_object (lib/debugobjects.c:262)
__debug_check_no_obj_freed (lib/debugobjects.c:697)
debug_check_no_obj_freed (lib/debugobjects.c:726)
kmem_cache_free (mm/slub.c:2689 mm/slub.c:2717)
kmem_cache_destroy (mm/slab_common.c:363)
dcookie_unregister (fs/dcookies.c:302 fs/dcookies.c:343)
event_buffer_release (arch/x86/oprofile/../../../drivers/oprofile/event_buffer.c:153)
__fput (fs/file_table.c:217)
____fput (fs/file_table.c:253)
task_work_run (kernel/task_work.c:125 (discriminator 1))
do_notify_resume (include/linux/tracehook.h:196 arch/x86/kernel/signal.c:751)
int_signal (arch/x86/kernel/entry_64.S:807)
Sysfs has a release mechanism. Use that to release the kmem_cache
structure if CONFIG_SYSFS is enabled.
Only slub is changed - slab currently only supports /proc/slabinfo and
not /sys/kernel/slab/*. We talked about adding that and someone was
working on it.
[akpm@linux-foundation.org: fix CONFIG_SYSFS=n build]
[akpm@linux-foundation.org: fix CONFIG_SYSFS=n build even more]
Signed-off-by: Christoph Lameter <cl@linux.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Acked-by: Greg KH <greg@kroah.com>
Cc: Bart Van Assche <bvanassche@acm.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
This reverts commit 0bf1457f0cfc ("mm: vmscan: do not swap anon pages
just because free+file is low") because it introduced a regression in
mostly-anonymous workloads, where reclaim would become ineffective and
trap every allocating task in direct reclaim.
The problem is that there is a runaway feedback loop in the scan balance
between file and anon, where the balance tips heavily towards a tiny
thrashing file LRU and anonymous pages are no longer being looked at.
The commit in question removed the safe guard that would detect such
situations and respond with forced anonymous reclaim.
This commit was part of a series to fix premature swapping in loads with
relatively little cache, and while it made a small difference, the cure
is obviously worse than the disease. Revert it.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Rafael Aquini <aquini@redhat.com>
Cc: <stable@kernel.org> [3.12+]
Dave Jones reports the following crash when find_get_pages_tag() runs
into an exceptional entry:
kernel BUG at mm/filemap.c:1347!
RIP: find_get_pages_tag+0x1cb/0x220
Call Trace:
find_get_pages_tag+0x36/0x220
pagevec_lookup_tag+0x21/0x30
filemap_fdatawait_range+0xbe/0x1e0
filemap_fdatawait+0x27/0x30
sync_inodes_sb+0x204/0x2a0
sync_inodes_one_sb+0x19/0x20
iterate_supers+0xb2/0x110
sys_sync+0x44/0xb0
ia32_do_call+0x13/0x13
1343 /*
1344 * This function is never used on a shmem/tmpfs
1345 * mapping, so a swap entry won't be found here.
1346 */
1347 BUG();
After commit 0cd6144aadd2 ("mm + fs: prepare for non-page entries in
page cache radix trees") this comment and BUG() are out of date because
exceptional entries can now appear in all mappings - as shadows of
recently evicted pages.
However, as Hugh Dickins notes,
"it is truly surprising for a PAGECACHE_TAG_WRITEBACK (and probably
any other PAGECACHE_TAG_*) to appear on an exceptional entry.
I expect it comes down to an occasional race in RCU lookup of the
radix_tree: lacking absolute synchronization, we might sometimes
catch an exceptional entry, with the tag which really belongs with
the unexceptional entry which was there an instant before."
And indeed, not only is the tree walk lockless, the tags are also read
in chunks, one radix tree node at a time. There is plenty of time for
page reclaim to swoop in and replace a page that was already looked up
as tagged with a shadow entry.
Remove the BUG() and update the comment. While reviewing all other
lookup sites for whether they properly deal with shadow entries of
evicted pages, update all the comments and fix memcg file charge moving
to not miss shmem/tmpfs swapcache pages.
The compaction freepage scanner implementation in isolate_freepages()
starts by taking the current cc->free_pfn value as the first pfn. In a
for loop, it scans from this first pfn to the end of the pageblock, and
then subtracts pageblock_nr_pages from the first pfn to obtain the first
pfn for the next for loop iteration.
This means that when cc->free_pfn starts at offset X rather than being
aligned on pageblock boundary, the scanner will start at offset X in all
scanned pageblock, ignoring potentially many free pages. Currently this
can happen when
a) zone's end pfn is not pageblock aligned, or
b) through zone->compact_cached_free_pfn with CONFIG_HOLES_IN_ZONE
enabled and a hole spanning the beginning of a pageblock
This patch fixes the problem by aligning the initial pfn in
isolate_freepages() to pageblock boundary. This also permits replacing
the end-of-pageblock alignment within the for loop with a simple
pageblock_nr_pages increment.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Reported-by: Heesub Shin <heesub.shin@samsung.com>
Acked-by: Minchan Kim <minchan@kernel.org>
Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Dongjun Shin <d.j.shin@samsung.com>
Cc: Sunghwan Yun <sunghwan.yun@samsung.com>
It is possible for "limit - setpoint + 1" to equal zero, after getting
truncated to a 32 bit variable, and resulting in a divide by zero error.
Using the fully 64 bit divide functions avoids this problem. It also
will cause pos_ratio_polynom() to return the correct value when
(setpoint - limit) exceeds 2^32.
Also uninline pos_ratio_polynom, at Andrew's request.
Signed-off-by: Rik van Riel <riel@redhat.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
Currently, I am seeing the following when I `mount -t hugetlbfs /none
/dev/hugetlbfs`, and then simply do a `ls /dev/hugetlbfs`. I think it's
related to the fact that hugetlbfs is properly not correctly setting
itself up in this state?:
Unable to handle kernel paging request for data at address 0x00000031
Faulting instruction address: 0xc000000000245710
Oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=2048 NUMA pSeries
In KVM guests on Power, in a guest not backed by hugepages, we see the
following:
AnonHugePages: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 64 kB
HPAGE_SHIFT == 0 in this configuration, which indicates that hugepages
are not supported at boot-time, but this is only checked in
hugetlb_init(). Extract the check to a helper function, and use it in a
few relevant places.
This does make hugetlbfs not supported (not registered at all) in this
environment. I believe this is fine, as there are no valid hugepages
and that won't change at runtime.
[akpm@linux-foundation.org: use pr_info(), per Mel]
[akpm@linux-foundation.org: fix build when HPAGE_SHIFT is undefined]
Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
After creating a cache for a memcg we should initialize its sysfs attrs
with the values from its parent. That's what memcg_propagate_slab_attrs
is for. Currently it's broken - we clearly muddled root-vs-memcg caches
there. Let's fix it up.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Pull vfs fixes from Al Viro:
"dcache fixes + kvfree() (uninlined, exported by mm/util.c) + posix_acl
bugfix from hch"
The dcache fixes are for a subtle LRU list corruption bug reported by
Miklos Szeredi, where people inside IBM saw list corruptions with the
LTP/host01 test.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
nick kvfree() from apparmor
posix_acl: handle NULL ACL in posix_acl_equiv_mode
dcache: don't need rcu in shrink_dentry_list()
more graceful recovery in umount_collect()
don't remove from shrink list in select_collect()
dentry_kill(): don't try to remove from shrink list
expand the call of dentry_lru_del() in dentry_kill()
new helper: dentry_free()
fold try_prune_one_dentry()
fold d_kill() and d_free()
fix races between __d_instantiate() and checks of dentry flags
too many places open-code it
If freelist_idx_t is a byte, SLAB_OBJ_MAX_NUM should be 255 not 256, and
likewise if freelist_idx_t is a short, then it should be 65535 not
65536.
This was leading to all kinds of random crashes on sparc64 where
PAGE_SIZE is 8192. One problem shown was that if spinlock debugging was
enabled, we'd get deadlocks in copy_pte_range() or do_wp_page() with the
same cpu already holding a lock it shouldn't hold, or the lock belonging
to a completely unrelated process.
Fixes: a41adfaa23df ("slab: introduce byte sized index for the freelist of a slab")
Commit a41adfaa23df ("slab: introduce byte sized index for the freelist
of a slab") changes the size of freelist index and also changes
prototype of accessor function to freelist index. And there was a
mistake.
The mistake is that although it changes the size of freelist index
correctly, it changes the size of the index of freelist index
incorrectly. With patch, freelist index can be 1 byte or 2 bytes, that
means that num of object on on a slab can be more than 255. So we need
more than 1 byte for the index to find the index of free object on
freelist. But, above patch makes this index type 1 byte, so slab which
have more than 255 objects cannot work properly and in consequence of
it, the system cannot boot.
This issue was reported by Steven King on m68knommu which would use
2 bytes freelist index:
https://lkml.org/lkml/2014/4/16/433
To fix is easy. To change the type of the index of freelist index on
accessor functions is enough to fix this bug. Although 2 bytes is
enough, I use 4 bytes since it have no bad effect and make things more
easier. This fix was suggested and tested by Steven in his original
report.
Reported-and-acked-by: Steven King <sfking@fdwdc.com>
Acked-by: Christoph Lameter <cl@linux.com>
Tested-by: James Hogan <james.hogan@imgtec.com>
Tested-by: David Miller <davem@davemloft.net>
BUG_ON() is a big hammer, and should be used _only_ if there is some
major corruption that you cannot possibly recover from, making it
imperative that the current process (and possibly the whole machine) be
terminated with extreme prejudice.
The trivial sanity check in the vmacache code is *not* such a fatal
error. Recovering from it is absolutely trivial, and using BUG_ON()
just makes it harder to debug for no actual advantage.
To make matters worse, the placement of the BUG_ON() (only if the range
check matched) actually makes it harder to hit the sanity check to begin
with, so _if_ there is a bug (and we just got a report from Srivatsa
Bhat that this can indeed trigger), it is harder to debug not just
because the machine is possibly dead, but because we don't have better
coverage.
BUG_ON() must *die*. Maybe we should add a checkpatch warning for it,
because it is simply just about the worst thing you can ever do if you
hit some "this cannot happen" situation.
Reported-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
The mmu-gather operation 'tlb_flush_mmu()' has done two things: the
actual tlb flush operation, and the batched freeing of the pages that
the TLB entries pointed at.
This splits the operation into separate phases, so that the forced
batched flushing done by zap_pte_range() can now do the actual TLB flush
while still holding the page table lock, but delay the batched freeing
of all the pages to after the lock has been dropped.
This in turn allows us to avoid a race condition between
set_page_dirty() (as called by zap_pte_range() when it finds a dirty
shared memory pte) and page_mkclean(): because we now flush all the
dirty page data from the TLB's while holding the pte lock,
page_mkclean() will be held up walking the (recently cleaned) page
tables until after the TLB entries have been flushed from all CPU's.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Dave Hansen <dave.hansen@intel.com>
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
fixup_user_fault() is used by the futex code when the direct user access
fails, and the futex code wants it to either map in the page in a usable
form or return an error. It relied on handle_mm_fault() to map the
page, and correctly checked the error return from that, but while that
does map the page, it doesn't actually guarantee that the page will be
mapped with sufficient permissions to be then accessed.
So do the appropriate tests of the vma access rights by hand.
[ Side note: arguably handle_mm_fault() could just do that itself, but
we have traditionally done it in the caller, because some callers -
notably get_user_pages() - have been able to access pages even when
they are mapped with PROT_NONE. Maybe we should re-visit that design
decision, but in the meantime this is the minimal patch. ]
Found by Dave Jones running his trinity tool.
Cc: stable@vger.kernel.org
Sasha Levin has reported two THP BUGs[1][2]. I believe both of them
have the same root cause. Let's look to them one by one.
The first bug[1] is "kernel BUG at mm/huge_memory.c:1829!". It's
BUG_ON(mapcount != page_mapcount(page)) in __split_huge_page(). From my
testing I see that page_mapcount() is higher than mapcount here.
I think it happens due to race between zap_huge_pmd() and
page_check_address_pmd(). page_check_address_pmd() misses PMD which is
under zap:
CPU0 CPU1
zap_huge_pmd()
pmdp_get_and_clear()
__split_huge_page()
anon_vma_interval_tree_foreach()
__split_huge_page_splitting()
mm_find_pmd()
* We check if PMD present without taking ptl: no
* serialization against zap_huge_pmd(). We miss this PMD,
* it's not accounted to 'mapcount' in __split_huge_page().
pmd_present(pmd) == 0
BUG_ON(mapcount != page_mapcount(page)) // CRASH!!!
page_remove_rmap(page)
atomic_add_negative(-1, &page->_mapcount)
The second bug[2] is "kernel BUG at mm/huge_memory.c:1371!".
It's VM_BUG_ON_PAGE(!PageHead(page), page) in zap_huge_pmd().
This happens in similar way:
CPU0 CPU1
zap_huge_pmd()
__split_huge_page()
mm_find_pmd()
pmd_present(pmd) == 0 /* The same comment as above */
* No crash this time since we already decremented page->_mapcount in
* zap_huge_pmd().
* We split the compound page here into small pages without
__split_huge_page_refcount()
VM_BUG_ON_PAGE(!PageHead(page), page); // CRASH!!!
So my understanding the problem is pmd_present() check in mm_find_pmd()
without taking page table lock.
The bug was introduced by me commit with commit 117b0791ac42. Sorry for
that. :(
Let's open code mm_find_pmd() in page_check_address_pmd() and do the
check under page table lock.
Note that __page_check_address() does the same for PTE entires
if sync != 0.
I've stress tested split and zap code paths for 36+ hours by now and
don't see crashes with the patch applied. Before it took <20 min to
trigger the first bug and few hours for second one (if we ignore
first).
[1] https://lkml.kernel.org/g/<53440991.9090001@oracle.com>
[2] https://lkml.kernel.org/g/<5310C56C.60709@oracle.com>
Cc: Bob Liu <lliubbo@gmail.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: <stable@vger.kernel.org> [3.13+]
Fix new kernel-doc warning in mm/filemap.c:
Warning(mm/filemap.c:2600): Excess function parameter 'ppos' description in '__generic_file_aio_write'
soft lockup in freeing gigantic hugepage fixed in commit 55f67141a892 "mm:
hugetlb: fix softlockup when a large number of hugepages are freed." can
happen in return_unused_surplus_pages(), so let's fix it.
Signed-off-by: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
Seems to be called with preemption enabled. Therefore it must use
mod_zone_page_state instead.
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Tested-by: Grygorii Strashko <grygorii.strashko@ti.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
pcpu_chunk_struct_size = sizeof(struct pcpu_chunk) +
BITS_TO_LONGS(pcpu_unit_pages) * sizeof(unsigned long)
It hardly could be ever bigger than PAGE_SIZE even for large-scale machine,
but for consistency with its couterpart pcpu_mem_zalloc(),
use pcpu_mem_free() instead.
Commit b4916cb17c26 ("percpu: make pcpu_free_chunk() use
pcpu_mem_free() instead of kfree()") addressed this problem, but
missed this one.
tj: commit message updated
Signed-off-by: Jianyu Zhan <nasa4836@gmail.com>
Fixes: 099a19d91ca4 ("percpu: allow limited allocation before slab is online)
Some versions of gcc even warn about it:
mm/shmem.c: In function ‘shmem_file_aio_read’:
mm/shmem.c:1414: warning: ‘error’ may be used uninitialized in this function
If the loop is aborted during the first iteration by one of the two
first break statements, error will be uninitialized.
Introduced by commit 6e58e79db8a1 ("introduce copy_page_to_iter, kill
loop over iovec in generic_file_aio_read()").
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull slab changes from Pekka Enberg:
"The biggest change is byte-sized freelist indices which reduces slab
freelist memory usage:
https://lkml.org/lkml/2013/12/2/64"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux:
mm: slab/slub: use page->list consistently instead of page->lru
mm/slab.c: cleanup outdated comments and unify variables naming
slab: fix wrongly used macro
slub: fix high order page allocation problem with __GFP_NOFAIL
slab: Make allocations with GFP_ZERO slightly more efficient
slab: make more slab management structure off the slab
slab: restrict the number of objects in a slab
slab: introduce helper functions to get/set free object
slab: factor out calculate nr objects in cache_estimate
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
that commit has fixed only the parts of that mess in fs/splice.c itself;
there had been more in several other ->splice_read() instances...
'struct page' has two list_head fields: 'lru' and 'list'. Conveniently,
they are unioned together. This means that code can use them
interchangably, which gets horribly confusing like with this nugget from
slab.c:
> list_del(&page->lru);
> if (page->active == cachep->num)
> list_add(&page->list, &n->slabs_full);
This patch makes the slab and slub code use page->lru universally instead
of mixing ->list and ->lru.
So, the new rule is: page->lru is what the you use if you want to keep
your page on a list. Don't like the fact that it's not called ->list?
Too bad.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: David Rientjes <rientjes@google.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Page reclaim force-scans / swaps anonymous pages when file cache drops
below the high watermark of a zone in order to prevent what little cache
remains from thrashing.
However, on bigger machines the high watermark value can be quite large
and when the workload is dominated by a static anonymous/shmem set, the
file set might just be a small window of used-once cache. In such
situations, the VM starts swapping heavily when instead it should be
recycling the no longer used cache.
This is a longer-standing problem, but it's more likely to trigger after
commit 81c0a2bb515f ("mm: page_alloc: fair zone allocator policy")
because file pages can no longer accumulate in a single zone and are
dispersed into smaller fractions among the available zones.
To resolve this, do not force scan anon when file pages are low but
instead rely on the scan/rotation ratios to make the right prediction.
Cc: Suleiman Souhlal <suleiman@google.com>
Merge second patch-bomb from Andrew Morton:
- the rest of MM
- zram updates
- zswap updates
- exit
- procfs
- exec
- wait
- crash dump
- lib/idr
- rapidio
- adfs, affs, bfs, ufs
- cris
- Kconfig things
- initramfs
- small amount of IPC material
- percpu enhancements
- early ioremap support
- various other misc things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (156 commits)
MAINTAINERS: update Intel C600 SAS driver maintainers
fs/ufs: remove unused ufs_super_block_third pointer
fs/ufs: remove unused ufs_super_block_second pointer
fs/ufs: remove unused ufs_super_block_first pointer
fs/ufs/super.c: add __init to init_inodecache()
doc/kernel-parameters.txt: add early_ioremap_debug
arm64: add early_ioremap support
arm64: initialize pgprot info earlier in boot
x86: use generic early_ioremap
mm: create generic early_ioremap() support
x86/mm: sparse warning fix for early_memremap
lglock: map to spinlock when !CONFIG_SMP
percpu: add preemption checks to __this_cpu ops
vmstat: use raw_cpu_ops to avoid false positives on preemption checks
slub: use raw_cpu_inc for incrementing statistics
net: replace __this_cpu_inc in route.c with raw_cpu_inc
modules: use raw_cpu_write for initialization of per cpu refcount.
mm: use raw_cpu ops for determining current NUMA node
percpu: add raw_cpu_ops
slub: fix leak of 'name' in sysfs_slab_add
This patch creates a generic implementation of early_ioremap() support
based on the existing x86 implementation. early_ioremp() is useful for
early boot code which needs to temporarily map I/O or memory regions
before normal mapping functions such as ioremap() are available.
Some architectures have optional MMU. In the no-MMU case, the remap
functions simply return the passed in physical address and the unmap
functions do nothing.
Signed-off-by: Mark Salter <msalter@redhat.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Dave Young <dyoung@redhat.com>
Statistics are not critical to the operation of the allocation but
should also not cause too much overhead.
When __this_cpu_inc is altered to check if preemption is disabled this
triggers. Use raw_cpu_inc to avoid the checks. Using this_cpu_ops may
cause interrupt disable/enable sequences on various arches which may
significantly impact allocator performance.
[akpm@linux-foundation.org: add comment]
Cc: Fengguang Wu <fengguang.wu@intel.com>
The failure paths of sysfs_slab_add don't release the allocation of
'name' made by create_unique_id() a few lines above the context of the
diff below. Create a common exit path to make it more obvious what
needs freeing.
[vdavydov@parallels.com: free the name only if !unmergeable]
Signed-off-by: Dave Jones <davej@fedoraproject.org>
Currently, we try to arrange sysfs entries for memcg caches in the same
manner as for global caches. Apart from turning /sys/kernel/slab into a
mess when there are a lot of kmem-active memcgs created, it actually
does not work properly - we won't create more than one link to a memcg
cache in case its parent is merged with another cache. For instance, if
A is a root cache merged with another root cache B, we will have the
following sysfs setup:
X
A -> X
B -> X
where X is some unique id (see create_unique_id()). Now if memcgs M and
N start to allocate from cache A (or B, which is the same), we will get:
X
X:M
X:N
A -> X
B -> X
A:M -> X:M
A:N -> X:N
Since B is an alias for A, we won't get entries B:M and B:N, which is
confusing.
It is more logical to have entries for memcg caches under the
corresponding root cache's sysfs directory. This would allow us to keep
sysfs layout clean, and avoid such inconsistencies like one described
above.
This patch does the trick. It creates a "cgroup" kset in each root
cache kobject to keep its children caches there.
Cc: Glauber Costa <glommer@gmail.com>
Otherwise, kzalloc() called from a memcg won't clear the whole object.
Currently we destroy children caches at the very beginning of
kmem_cache_destroy(). This is wrong, because the root cache will not
necessarily be destroyed in the end - if it has aliases (refcount > 0),
kmem_cache_destroy() will simply decrement its refcount and return. In
this case, at best we will get a bunch of warnings in dmesg, like this
one:
kmem_cache_destroy kmalloc-32:0: Slab cache still has objects
CPU: 1 PID: 7139 Comm: modprobe Tainted: G B W 3.13.0+ #117
Call Trace:
dump_stack+0x49/0x5b
kmem_cache_destroy+0xdf/0xf0
kmem_cache_destroy_memcg_children+0x97/0xc0
kmem_cache_destroy+0xf/0xf0
xfs_mru_cache_uninit+0x21/0x30 [xfs]
exit_xfs_fs+0x2e/0xc44 [xfs]
SyS_delete_module+0x198/0x1f0
system_call_fastpath+0x16/0x1b
At worst - if kmem_cache_destroy() will race with an allocation from a
memcg cache - the kernel will panic.
This patch fixes this by moving children caches destruction after the
check if the cache has aliases. Plus, it forbids destroying a root
cache if it still has children caches, because each children cache keeps
a reference to its parent.
Currently, memcg_unregister_cache(), which deletes the cache being
destroyed from the memcg_slab_caches list, is called after
__kmem_cache_shutdown() (see kmem_cache_destroy()), which starts to
destroy the cache.
As a result, one can access a partially destroyed cache while traversing
a memcg_slab_caches list, which can have deadly consequences (for
instance, cache_show() called for each cache on a memcg_slab_caches list
from mem_cgroup_slabinfo_read() will dereference pointers to already
freed data).
To fix this, let's move memcg_unregister_cache() before the cache
destruction process beginning, issuing memcg_register_cache() on failure.
Memcg-awareness turned kmem_cache_create() into a dirty interweaving of
memcg-only and except-for-memcg calls. To clean this up, let's move the
code responsible for memcg cache creation to a separate function.
