commit b3084f4db3aeb991c507ca774337c7e7893ed04f upstream.
This patch fix the below crash
NIP [c00000000004cee4] .__hash_page_thp+0x2a4/0x440
LR [c0000000000439ac] .hash_page+0x18c/0x5e0
Call Trace:
[c000000736103c40] [00001ffffb000000] 0x1ffffb000000(unreliable)
[437908.479693] [c000000736103d50] [c0000000000439ac] .hash_page+0x18c/0x5e0
[437908.479699] [c000000736103e30] [c00000000000924c] .do_hash_page+0x4c/0x58
On ppc64 we use the pgtable for storing the hpte slot information and
store address to the pgtable at a constant offset (PTRS_PER_PMD) from
pmd. On mremap, when we switch the pmd, we need to withdraw and deposit
the pgtable again, so that we find the pgtable at PTRS_PER_PMD offset
from new pmd.
We also want to move the withdraw and deposit before the set_pmd so
that, when page fault find the pmd as trans huge we can be sure that
pgtable can be located at the offset.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 778c14affaf94a9e4953179d3e13a544ccce7707 upstream.
A 3% of system memory bonus is sometimes too excessive in comparison to
other processes.
With commit a63d83f427fb ("oom: badness heuristic rewrite"), the OOM
killer tries to avoid killing privileged tasks by subtracting 3% of
overall memory (system or cgroup) from their per-task consumption. But
as a result, all root tasks that consume less than 3% of overall memory
are considered equal, and so it only takes 33+ privileged tasks pushing
the system out of memory for the OOM killer to do something stupid and
kill dhclient or other root-owned processes. For example, on a 32G
machine it can't tell the difference between the 1M agetty and the 10G
fork bomb member.
The changelog describes this 3% boost as the equivalent to the global
overcommit limit being 3% higher for privileged tasks, but this is not
the same as discounting 3% of overall memory from _every privileged task
individually_ during OOM selection.
Replace the 3% of system memory bonus with a 3% of current memory usage
bonus.
By giving root tasks a bonus that is proportional to their actual size,
they remain comparable even when relatively small. In the example
above, the OOM killer will discount the 1M agetty's 256 badness points
down to 179, and the 10G fork bomb's 262144 points down to 183500 points
and make the right choice, instead of discounting both to 0 and killing
agetty because it's first in the task list.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Johannes Weiner <hannes@cmpxchg.org>
commit c297663c0b3930491a3cb2aba4b6e5a7159c3503 upstream.
The command line parsing takes place before jump labels are initialised
which generates a warning if numa_balancing= is specified and
CONFIG_JUMP_LABEL is set.
On older kernels before commit c4b2c0c5f647 ("static_key: WARN on usage
before jump_label_init was called") the kernel would have crashed. This
patch enables automatic numa balancing later in the initialisation
process if numa_balancing= is specified.
commit 54a43d54988a3731d644fdeb7a1d6f46b4ac64c7 upstream.
Add a working sysctl to enable/disable automatic numa memory balancing
at runtime.
This allows us to track down performance problems with this feature and
is generally a good idea.
This was possible earlier through debugfs, but only with special
debugging options set. Also fix the boot message.
[akpm@linux-foundation.org: s/sched_numa_balancing/sysctl_numa_balancing/]
commit 8afb1474db4701d1ab80cd8251137a3260e6913e upstream.
/sys/kernel/slab/:t-0000048 # cat cpu_slabs
231 N0=16 N1=215
/sys/kernel/slab/:t-0000048 # cat slabs
145 N0=36 N1=109
See, the number of slabs is smaller than that of cpu slabs.
The bug was introduced by commit 49e2258586b423684f03c278149ab46d8f8b6700
("slub: per cpu cache for partial pages").
We should use page->pages instead of page->pobjects when calculating
the number of cpu partial slabs. This also fixes the mapping of slabs
and nodes.
As there's no variable storing the number of total/active objects in
cpu partial slabs, and we don't have user interfaces requiring those
statistics, I just add WARN_ON for those cases.
Acked-by: Christoph Lameter <cl@linux.com>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Signed-off-by: Li Zefan <lizefan@huawei.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit 34228d473efe764d4db7c0536375f0c993e6e06a upstream.
The VM_SOFTDIRTY bit affects vma merge routine: if two VMAs has all bits
in vm_flags matched except dirty bit the kernel can't longer merge them
and this forces the kernel to generate new VMAs instead.
It finally may lead to the situation when userspace application reaches
vm.max_map_count limit and get crashed in worse case
| (gimp:11768): GLib-ERROR **: gmem.c:110: failed to allocate 4096 bytes
| (file-tiff-load:12038): LibGimpBase-WARNING **: file-tiff-load: gimp_wire_read(): error
| xinit: connection to X server lost
| waiting for X server to shut down
| /usr/lib64/gimp/2.0/plug-ins/file-tiff-load terminated: Hangup
| /usr/lib64/gimp/2.0/plug-ins/script-fu terminated: Hangup
https://bugzilla.kernel.org/show_bug.cgi?id=67651
https://bugzilla.gnome.org/show_bug.cgi?id=719619#c0
Initial problem came from missed VM_SOFTDIRTY in do_brk() routine but
even if we would set up VM_SOFTDIRTY here, there is still a way to
prevent VMAs from merging: one can call
| echo 4 > /proc/$PID/clear_refs
and clear all VM_SOFTDIRTY over all VMAs presented in memory map, then
new do_brk() will try to extend old VMA and finds that dirty bit doesn't
match thus new VMA will be generated.
As discussed with Pavel, the right approach should be to ignore
VM_SOFTDIRTY bit when we're trying to merge VMAs and if merge successed
we mark extended VMA with dirty bit where needed.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Reported-by: Bastian Hougaard <gnome@rvzt.net>
Reported-by: Mel Gorman <mgorman@suse.de>
Cc: Pavel Emelyanov <xemul@parallels.com>
commit 0eef615665ede1e0d603ea9ecca88c1da6f02234 upstream.
Commit 19f39402864e ("memcg: simplify mem_cgroup_iter") has reorganized
mem_cgroup_iter code in order to simplify it. A part of that change was
dropping an optimization which didn't call css_tryget on the root of the
walked tree. The patch however didn't change the css_put part in
mem_cgroup_iter which excludes root.
This wasn't an issue at the time because __mem_cgroup_iter_next bailed
out for root early without taking a reference as cgroup iterators
(css_next_descendant_pre) didn't visit root themselves.
Nevertheless cgroup iterators have been reworked to visit root by commit
bd8815a6d802 ("cgroup: make css_for_each_descendant() and friends
include the origin css in the iteration") when the root bypass have been
dropped in __mem_cgroup_iter_next. This means that css_put is not
called for root and so css along with mem_cgroup and other cgroup
internal object tied by css lifetime are never freed.
Fix the issue by reintroducing root check in __mem_cgroup_iter_next and
do not take css reference for it.
This reference counting magic protects us also from another issue, an
endless loop reported by Hugh Dickins when reclaim races with root
removal and css_tryget called by iterator internally would fail. There
would be no other nodes to visit so __mem_cgroup_iter_next would return
NULL and mem_cgroup_iter would interpret it as "start looping from root
again" and so mem_cgroup_iter would loop forever internally.
Reported-by: Hugh Dickins <hughd@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
commit ecc736fc3c71c411a9d201d8588c9e7e049e5d8c upstream.
Hugh has reported an endless loop when the hardlimit reclaim sees the
same group all the time. This might happen when the reclaim races with
the memcg removal.
shrink_zone
[rmdir root]
mem_cgroup_iter(root, NULL, reclaim)
// prev = NULL
rcu_read_lock()
mem_cgroup_iter_load
last_visited = iter->last_visited // gets root || NULL
css_tryget(last_visited) // failed
last_visited = NULL [1]
memcg = root = __mem_cgroup_iter_next(root, NULL)
mem_cgroup_iter_update
iter->last_visited = root;
reclaim->generation = iter->generation
mem_cgroup_iter(root, root, reclaim)
// prev = root
rcu_read_lock
[1]
The issue seemed to be introduced by commit 5f5781619718 ("memcg: relax
memcg iter caching") which has replaced unconditional css_get/css_put by
css_tryget/css_put for the cached iterator.
This patch fixes the issue by skipping css_tryget on the root of the
tree walk in mem_cgroup_iter_load and symmetrically doesn't release it
in mem_cgroup_iter_update.
commit a1c3bfb2f67ef766de03f1f56bdfff9c8595ab14 upstream.
The VM is currently heavily tuned to avoid swapping. Whether that is
good or bad is a separate discussion, but as long as the VM won't swap
to make room for dirty cache, we can not consider anonymous pages when
calculating the amount of dirtyable memory, the baseline to which
dirty_background_ratio and dirty_ratio are applied.
A simple workload that occupies a significant size (40+%, depending on
memory layout, storage speeds etc.) of memory with anon/tmpfs pages and
uses the remainder for a streaming writer demonstrates this problem. In
that case, the actual cache pages are a small fraction of what is
considered dirtyable overall, which results in an relatively large
portion of the cache pages to be dirtied. As kswapd starts rotating
these, random tasks enter direct reclaim and stall on IO.
Only consider free pages and file pages dirtyable.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Tejun Heo <tj@kernel.org>
Tested-by: Tejun Heo <tj@kernel.org>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit a804552b9a15c931cfc2a92a2e0aed1add8b580a upstream.
Tejun reported stuttering and latency spikes on a system where random
tasks would enter direct reclaim and get stuck on dirty pages. Around
50% of memory was occupied by tmpfs backed by an SSD, and another disk
(rotating) was reading and writing at max speed to shrink a partition.
: The problem was pretty ridiculous. It's a 8gig machine w/ one ssd and 10k
: rpm harddrive and I could reliably reproduce constant stuttering every
: several seconds for as long as buffered IO was going on on the hard drive
: either with tmpfs occupying somewhere above 4gig or a test program which
: allocates about the same amount of anon memory. Although swap usage was
: zero, turning off swap also made the problem go away too.
: The trigger conditions seem quite plausible - high anon memory usage w/
: heavy buffered IO and swap configured - and it's highly likely that this
: is happening in the wild too. (this can happen with copying large files
: to usb sticks too, right?)
This patch (of 2):
The dirty_balance_reserve is an approximation of the fraction of free
pages that the page allocator does not make available for page cache
allocations. As a result, it has to be taken into account when
calculating the amount of "dirtyable memory", the baseline to which
However, currently the reserve is subtracted from the sum of free and
reclaimable pages, which is non-sensical and leads to erroneous results
when the system is dominated by unreclaimable pages and the
dirty_balance_reserve is bigger than free+reclaimable. In that case, at
least the already allocated cache should be considered dirtyable.
Fix the calculation by subtracting the reserve from the amount of free
pages, then adding the reclaimable pages on top.
[akpm@linux-foundation.org: fix CONFIG_HIGHMEM build]
commit d8ad30559715ce97afb7d1a93a12fd90e8fff312 upstream.
It is surprising that the mem_cgroup iterator can return memcgs which
have not yet been fully initialized. By accident (or trial and error?)
this appears not to present an actual problem; but it may be better to
prevent such surprises, by skipping memcgs not yet online.
Cc: Tejun Heo <tj@kernel.org>
Acked-by: Michal Hocko <mhocko@suse.cz>
commit 54b9dd14d09f24927285359a227aa363ce46089e upstream.
After thp split in hwpoison_user_mappings(), we hold page lock on the
raw error page only between try_to_unmap, hence we are in danger of race
condition.
I found in the RHEL7 MCE-relay testing that we have "bad page" error
when a memory error happens on a thp tail page used by qemu-kvm:
Triggering MCE exception on CPU 10
mce: [Hardware Error]: Machine check events logged
MCE exception done on CPU 10
MCE 0x38c535: Killing qemu-kvm:8418 due to hardware memory corruption
MCE 0x38c535: dirty LRU page recovery: Recovered
qemu-kvm[8418]: segfault at 20 ip 00007ffb0f0f229a sp 00007fffd6bc5240 error 4 in qemu-kvm[7ffb0ef14000+420000]
BUG: Bad page state in process qemu-kvm pfn:38c400
page:ffffea000e310000 count:0 mapcount:0 mapping: (null) index:0x7ffae3c00
page flags: 0x2fffff0008001d(locked|referenced|uptodate|dirty|swapbacked)
Modules linked in: hwpoison_inject mce_inject vhost_net macvtap macvlan ...
CPU: 0 PID: 8418 Comm: qemu-kvm Tainted: G M -------------- 3.10.0-54.0.1.el7.mce_test_fixed.x86_64 #1
Hardware name: NEC NEC Express5800/R120b-1 [N8100-1719F]/MS-91E7-001, BIOS 4.6.3C19 02/10/2011
Call Trace:
dump_stack+0x19/0x1b
bad_page.part.59+0xcf/0xe8
free_pages_prepare+0x148/0x160
free_hot_cold_page+0x31/0x140
free_hot_cold_page_list+0x46/0xa0
release_pages+0x1c1/0x200
free_pages_and_swap_cache+0xad/0xd0
tlb_flush_mmu.part.46+0x4c/0x90
tlb_finish_mmu+0x55/0x60
exit_mmap+0xcb/0x170
mmput+0x67/0xf0
vhost_dev_cleanup+0x231/0x260 [vhost_net]
vhost_net_release+0x3f/0x90 [vhost_net]
__fput+0xe9/0x270
____fput+0xe/0x10
task_work_run+0xc4/0xe0
do_exit+0x2bb/0xa40
do_group_exit+0x3f/0xa0
get_signal_to_deliver+0x1d0/0x6e0
do_signal+0x48/0x5e0
do_notify_resume+0x71/0xc0
retint_signal+0x48/0x8c
The reason of this bug is that a page fault happens before unlocking the
head page at the end of memory_failure(). This strange page fault is
trying to access to address 0x20 and I'm not sure why qemu-kvm does
this, but anyway as a result the SIGSEGV makes qemu-kvm exit and on the
way we catch the bad page bug/warning because we try to free a locked
page (which was the former head page.)
To fix this, this patch suggests to shift page lock from head page to
tail page just after thp split. SIGSEGV still happens, but it affects
only error affected VMs, not a whole system.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
commit 8790c71a18e5d2d93532ae250bcf5eddbba729cd upstream.
As a result of commit 5606e3877ad8 ("mm: numa: Migrate on reference
policy"), /proc/<pid>/numa_maps prints the mempolicy for any <pid> as
"prefer:N" for the local node, N, of the process reading the file.
This should only be printed when the mempolicy of <pid> is
MPOL_PREFERRED for node N.
If the process is actually only using the default mempolicy for local
node allocation, make sure "default" is printed as expected.
Reported-by: Robert Lippert <rlippert@google.com>
Commit 8456a648cf44 ("slab: use struct page for slab management") causes
a crash in the LVM2 testsuite on PA-RISC (the crashing test is
fsadm.sh). The testsuite doesn't crash on 3.12, crashes on 3.13-rc1 and
later.
Bad Address (null pointer deref?): Code=15 regs=000000413edd89a0 (Addr=000006202224647d)
CPU: 3 PID: 24008 Comm: loop0 Not tainted 3.13.0-rc6 #5
task: 00000001bf3c0048 ti: 000000413edd8000 task.ti: 000000413edd8000
YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI
PSW: 00001000000001101111100100001110 Not tainted
r00-03 000000ff0806f90e 00000000405c8de0 000000004013e6c0 000000413edd83f0
r04-07 00000000405a95e0 0000000000000200 00000001414735f0 00000001bf349e40
r08-11 0000000010fe3d10 0000000000000001 00000040829c7778 000000413efd9000
r12-15 0000000000000000 000000004060d800 0000000010fe3000 0000000010fe3000
r16-19 000000413edd82a0 00000041078ddbc0 0000000000000010 0000000000000001
r20-23 0008f3d0d83a8000 0000000000000000 00000040829c7778 0000000000000080
r24-27 00000001bf349e40 00000001bf349e40 202d66202224640d 00000000405a95e0
r28-31 202d662022246465 000000413edd88f0 000000413edd89a0 0000000000000001
sr00-03 000000000532c000 0000000000000000 0000000000000000 000000000532c000
sr04-07 0000000000000000 0000000000000000 0000000000000000 0000000000000000
IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000401fe42c 00000000401fe430
IIR: 539c0030 ISR: 00000000202d6000 IOR: 000006202224647d
CPU: 3 CR30: 000000413edd8000 CR31: 0000000000000000
ORIG_R28: 00000000405a95e0
IAOQ[0]: vma_interval_tree_iter_first+0x14/0x48
IAOQ[1]: vma_interval_tree_iter_first+0x18/0x48
RP(r2): flush_dcache_page+0x128/0x388
Backtrace:
lo_splice_actor+0x90/0x148 [loop]
splice_from_pipe_feed+0xc0/0x1d0
__splice_from_pipe+0xac/0xc0
lo_direct_splice_actor+0x1c/0x70 [loop]
splice_direct_to_actor+0xec/0x228
lo_receive+0xe4/0x298 [loop]
loop_thread+0x478/0x640 [loop]
kthread+0x134/0x168
end_fault_vector+0x20/0x28
xfs_setsize_buftarg+0x0/0x90 [xfs]
Kernel panic - not syncing: Bad Address (null pointer deref?)
Commit 8456a648cf44 changes the page structure so that the slab
subsystem reuses the page->mapping field.
The crash happens in the following way:
* XFS allocates some memory from slab and issues a bio to read data
into it.
* the bio is sent to the loopback device.
* lo_receive creates an actor and calls splice_direct_to_actor.
* lo_splice_actor copies data to the target page.
* lo_splice_actor calls flush_dcache_page because the page may be
mapped by userspace. In that case we need to flush the kernel cache.
* flush_dcache_page asks for the list of userspace mappings, however
that page->mapping field is reused by the slab subsystem for a
different purpose. This causes the crash.
Note that other architectures without coherent caches (sparc, arm, mips)
also call page_mapping from flush_dcache_page, so they may crash in the
same way.
This patch fixes this bug by testing if the page is a slab page in
page_mapping and returning NULL if it is.
The patch also fixes VM_BUG_ON(PageSlab(page)) that could happen in
earlier kernels in the same scenario on architectures without cache
coherence when CONFIG_DEBUG_VM is enabled - so it should be backported
to stable kernels.
In the old kernels, the function page_mapping is placed in
include/linux/mm.h, so you should modify the patch accordingly when
backporting it.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: John David Anglin <dave.anglin@bell.net>]
Cc: Christoph Lameter <cl@linux.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Reviewed-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Helge Deller <deller@gmx.de>
Cc: <stable@vger.kernel.org>
We see General Protection Fault on RSI in copy_page_rep: that RSI is
what you get from a NULL struct page pointer.
RIP: 0010:[<ffffffff81154955>] [<ffffffff81154955>] copy_page_rep+0x5/0x10
RSP: 0000:ffff880136e15c00 EFLAGS: 00010286
RAX: ffff880000000000 RBX: ffff880136e14000 RCX: 0000000000000200
RDX: 6db6db6db6db6db7 RSI: db73880000000000 RDI: ffff880dd0c00000
RBP: ffff880136e15c18 R08: 0000000000000200 R09: 000000000005987c
R10: 000000000005987c R11: 0000000000000200 R12: 0000000000000001
R13: ffffea00305aa000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f195752f700(0000) GS:ffff880c7fc20000(0000) knlGS:0000000000000000
CR2: 0000000093010000 CR3: 00000001458e1000 CR4: 00000000000027e0
Call Trace:
copy_user_huge_page+0x93/0xab
do_huge_pmd_wp_page+0x710/0x815
handle_mm_fault+0x15d8/0x1d70
__do_page_fault+0x14d/0x840
do_page_fault+0x2f/0x90
page_fault+0x22/0x30
do_huge_pmd_wp_page() tests is_huge_zero_pmd(orig_pmd) four times: but
since shrink_huge_zero_page() can free the huge_zero_page, and we have
no hold of our own on it here (except where the fourth test holds
page_table_lock and has checked pmd_same), it's possible for it to
answer yes the first time, but no to the second or third test. Change
all those last three to tests for NULL page.
(Note: this is not the same issue as trinity's DEBUG_PAGEALLOC BUG
in copy_page_rep with RSI: ffff88009c422000, reported by Sasha Levin
in https://lkml.org/lkml/2013/3/29/103. I believe that one is due
to the source page being split, and a tail page freed, while copy
is in progress; and not a problem without DEBUG_PAGEALLOC, since
the pmd_same check will prevent a miscopy from being made visible.)
Fixes: 97ae17497e99 ("thp: implement refcounting for huge zero page")
Cc: stable@vger.kernel.org # v3.10 v3.11 v3.12
split thp
Memory failures on thp tail pages cause kernel panic like below:
MCE exception done on CPU 7
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff811b7cd1>] dequeue_hwpoisoned_huge_page+0x131/0x1e0
PGD bae42067 PUD ba47d067 PMD 0
Oops: 0000 [#1] SMP
CPU: 7 PID: 128 Comm: kworker/7:2 Tainted: G M O 3.13.0-rc4-131217-1558-00003-g83b7df08e462 #25
Call Trace:
me_huge_page+0x3e/0x50
memory_failure+0x4bb/0xc20
mce_process_work+0x3e/0x70
process_one_work+0x171/0x420
worker_thread+0x11b/0x3a0
? manage_workers.isra.25+0x2b0/0x2b0
kthread+0xe4/0x100
? kthread_create_on_node+0x190/0x190
ret_from_fork+0x7c/0xb0
RIP dequeue_hwpoisoned_huge_page+0x131/0x1e0
CR2: 0000000000000058
The reasoning of this problem is shown below:
- when we have a memory error on a thp tail page, the memory error
handler grabs a refcount of the head page to keep the thp under us.
- Before unmapping the error page from processes, we split the thp,
where page refcounts of both of head/tail pages don't change.
- Then we call try_to_unmap() over the error page (which was a tail
page before). We didn't pin the error page to handle the memory error,
this error page is freed and removed from LRU list.
- We never have the error page on LRU list, so the first page state
check returns "unknown page," then we move to the second check
with the saved page flag.
- The saved page flag have PG_tail set, so the second page state check
returns "hugepage."
- We call me_huge_page() for freed error page, then we hit the above panic.
The root cause is that we didn't move refcount from the head page to the
tail page after split thp. So this patch suggests to do this.
This panic was introduced by commit 524fca1e73 ("HWPOISON: fix
misjudgement of page_action() for errors on mlocked pages"). Note that we
did have the same refcount problem before this commit, but it was just
ignored because we had only first page state check which returned "unknown
page." The commit changed the refcount problem from "doesn't work" to
"kernel panic."
Cc: <stable@vger.kernel.org> [3.9+]
Sasha Levin reported the following warning being triggered
WARNING: CPU: 28 PID: 35287 at mm/huge_memory.c:887 copy_huge_pmd+0x145/ 0x3a0()
Call Trace:
copy_huge_pmd+0x145/0x3a0
copy_page_range+0x3f2/0x560
dup_mmap+0x2c9/0x3d0
dup_mm+0xad/0x150
copy_process+0xa68/0x12e0
do_fork+0x96/0x270
SyS_clone+0x16/0x20
stub_clone+0x69/0x90
This warning was introduced by "mm: numa: Avoid unnecessary disruption
of NUMA hinting during migration" for paranoia reasons but the warning
is bogus. I was thinking of parallel races between NUMA hinting faults
and forks but this warning would also be triggered by a parallel reclaim
splitting a THP during a fork. Remote the bogus warning.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Alex Thorlton <athorlton@sgi.com>
The mem_cgroup structure contains nr_node_ids pointers to
mem_cgroup_per_node objects, not the objects themselves.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Glauber Costa <glommer@openvz.org>
Cc: Balbir Singh <bsingharora@gmail.com>
remap_file_pages calls mmap_region, which may merge the VMA with other
existing VMAs, and free "vma". This can lead to a use-after-free bug.
Avoid the bug by remembering vm_flags before calling mmap_region, and
not trying to dereference vma later.
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: PaX Team <pageexec@freemail.hu>
Cc: Michel Lespinasse <walken@google.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Commit 7225522bb429 ("mm: munlock: batch non-THP page isolation and
munlock+putback using pagevec" introduced __munlock_pagevec() to speed
up munlock by holding lru_lock over multiple isolated pages. Pages that
fail to be isolated are put_page()d immediately, also within the lock.
This can lead to deadlock when __munlock_pagevec() becomes the holder of
the last page pin and put_page() leads to __page_cache_release() which
also locks lru_lock. The deadlock has been observed by Sasha Levin
using trinity.
This patch avoids the deadlock by deferring put_page() operations until
lru_lock is released. Another pagevec (which is also used by later
phases of the function is reused to gather the pages for put_page()
operation.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Since commit ff6a6da60b89 ("mm: accelerate munlock() treatment of THP
pages") munlock skips tail pages of a munlocked THP page. However, when
the head page already has PageMlocked unset, it will not skip the tail
pages.
munlock+putback using pagevec") has added a PageTransHuge() check which
contains VM_BUG_ON(PageTail(page)). Sasha Levin found this triggered
using trinity, on the first tail page of a THP page without PageMlocked
flag.
This patch fixes the issue by skipping tail pages also in the case when
PageMlocked flag is unset. There is still a possibility of race with
THP page split between clearing PageMlocked and determining how many
pages to skip. The race might result in former tail pages not being
skipped, which is however no longer a bug, as during the skip the
PageTail flags are cleared.
However this race also affects correctness of NR_MLOCK accounting, which
is to be fixed in a separate patch.
Cc: Bob Liu <bob.liu@oracle.com>
The arbitrary restriction on page counts offered by the core
migrate_page_move_mapping() code results in rather suspicious looking
fiddling with page reference counts in the aio_migratepage() operation.
To fix this, make migrate_page_move_mapping() take an extra_count parameter
that allows aio to tell the code about its own reference count on the page
being migrated.
While cleaning up aio_migratepage(), make it validate that the old page
being passed in is actually what aio_migratepage() expects to prevent
misbehaviour in the case of races.
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
Commit 597d795a2a78 ('mm: do not allocate page->ptl dynamically, if
spinlock_t fits to long') restructures some allocators that are compiled
even if USE_SPLIT_PTLOCKS arn't used. It results in compilation
failure:
mm/memory.c:4282:6: error: 'struct page' has no member named 'ptl'
mm/memory.c:4288:12: error: 'struct page' has no member named 'ptl'
Add in the missing ifdef.
Fixes: 597d795a2a78 ('mm: do not allocate page->ptl dynamically, if spinlock_t fits to long')
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
In struct page we have enough space to fit long-size page->ptl there,
but we use dynamically-allocated page->ptl if size(spinlock_t) is larger
than sizeof(int).
It hurts 64-bit architectures with CONFIG_GENERIC_LOCKBREAK, where
sizeof(spinlock_t) == 8, but it easily fits into struct page.
Commit 81c0a2bb515f ("mm: page_alloc: fair zone allocator policy") meant
to bring aging fairness among zones in system, but it was overzealous
and badly regressed basic workloads on NUMA systems.
Due to the way kswapd and page allocator interacts, we still want to
make sure that all zones in any given node are used equally for all
allocations to maximize memory utilization and prevent thrashing on the
highest zone in the node.
While the same principle applies to NUMA nodes - memory utilization is
obviously improved by spreading allocations throughout all nodes -
remote references can be costly and so many workloads prefer locality
over memory utilization. The original change assumed that
zone_reclaim_mode would be a good enough predictor for that, but it
turned out to be as indicative as a coin flip.
Revert the NUMA aspect of the fairness until we can find a proper way to
make it configurable and agree on a sane default.
Cc: <stable@kernel.org> # 3.12
policy"
This reverts commit 73f038b863df. The NUMA behaviour of this patch is
less than ideal. An alternative approch is to interleave allocations
only within local zones which is implemented in the next patch.
In __page_check_address(), if address's pud is not present,
huge_pte_offset() will return NULL, we should check the return value.
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: qiuxishi <qiuxishi@huawei.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
BUG_ON(!vma) assumption is introduced by commit 0bf598d863e3 ("mbind:
add BUG_ON(!vma) in new_vma_page()"), however, even if
address = __vma_address(page, vma);
and
vma->start < address < vma->end
page_address_in_vma() may still return -EFAULT because of many other
conditions in it. As a result the while loop in new_vma_page() may end
with vma=NULL.
This patch revert the commit and also fix the potential dereference NULL
pointer reported by Dan.
http://marc.info/?l=linux-mm&m=137689530323257&w=2
kernel BUG at mm/mempolicy.c:1204!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU: 3 PID: 7056 Comm: trinity-child3 Not tainted 3.13.0-rc3+ #2
task: ffff8801ca5295d0 ti: ffff88005ab20000 task.ti: ffff88005ab20000
RIP: new_vma_page+0x70/0x90
RSP: 0000:ffff88005ab21db0 EFLAGS: 00010246
RAX: fffffffffffffff2 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000008040075 RSI: ffff8801c3d74600 RDI: ffffea00079a8b80
RBP: ffff88005ab21dc8 R08: 0000000000000004 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: fffffffffffffff2
R13: ffffea00079a8b80 R14: 0000000000400000 R15: 0000000000400000
FS: 00007ff49c6f4740(0000) GS:ffff880244e00000(0000) knlGS:0000000000000000
CR2: 00007ff49c68f994 CR3: 000000005a205000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Stack:
ffffea00079a8b80 ffffea00079a8bc0 ffffea00079a8ba0 ffff88005ab21e50
ffffffff811adc7a 0000000000000000 ffff8801ca5295d0 0000000464e224f8
0000000000000000 0000000000000002 0000000000000000 ffff88020ce75c00
Call Trace:
migrate_pages+0x12a/0x850
SYSC_mbind+0x513/0x6a0
SyS_mbind+0xe/0x10
ia32_do_call+0x13/0x13
Code: 85 c0 75 2f 4c 89 e1 48 89 da 31 f6 bf da 00 02 00 65 44 8b 04 25 08 f7 1c 00 e8 ec fd ff ff 5b 41 5c 41 5d 5d c3 0f 1f 44 00 00 <0f> 0b 66 0f 1f 44 00 00 4c 89 e6 48 89 df ba 01 00 00 00 e8 48
RIP [<ffffffff8119f200>] new_vma_page+0x70/0x90
RSP <ffff88005ab21db0>
Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Reported-by: Dave Jones <davej@redhat.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Bob Liu <bob.liu@oracle.com>
After a successful hugetlb page migration by soft offline, the source
page will either be freed into hugepage_freelists or buddy(over-commit
page). If page is in buddy, page_hstate(page) will be NULL. It will
hit a NULL pointer dereference in dequeue_hwpoisoned_huge_page().
IP: [<ffffffff81163761>] dequeue_hwpoisoned_huge_page+0x131/0x1d0
PGD c23762067 PUD c24be2067 PMD 0
Oops: 0000 [#1] SMP
So check PageHuge(page) after call migrate_pages() successfully.
Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
update_pageblock_skip() only fits to compaction which tries to isolate
by pageblock unit. If isolate_migratepages_range() is called by CMA, it
try to isolate regardless of pageblock unit and it don't reference
get_pageblock_skip() by ignore_skip_hint. We should also respect it on
update_pageblock_skip() to prevent from setting the wrong information.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: <stable@vger.kernel.org> [3.7+]
queue_pages_range() isolates hugetlbfs pages and putback_lru_pages()
can't handle these. We should change it to putback_movable_pages().
Naoya said that it is worth going into stable, because it can break
in-use hugepage list.
Acked-by: Rafael Aquini <aquini@redhat.com>
Cc: <stable@vger.kernel.org> [3.12.x]
Eliminate the following (rand)config warning by adding missing PROC_FS
dependency:
warning: (HWPOISON_INJECT && MEM_SOFT_DIRTY) selects PROC_PAGE_MONITOR which has unmet direct dependencies (PROC_FS && MMU)
Signed-off-by: Sima Baymani <sima.baymani@gmail.com>
Suggested-by: David Rientjes <rientjes@google.com>
Acked-by: David Rientjes <rientjes@google.com>
Dave Hansen noted a regression in a microbenchmark that loops around
open() and close() on an 8-node NUMA machine and bisected it down to
commit 81c0a2bb515f ("mm: page_alloc: fair zone allocator policy").
That change forces the slab allocations of the file descriptor to spread
out to all 8 nodes, causing remote references in the page allocator and
slab.
The round-robin policy is only there to provide fairness among memory
allocations that are reclaimed involuntarily based on pressure in each
zone. It does not make sense to apply it to unreclaimable kernel
allocations that are freed manually, in this case instantly after the
allocation, and incur the remote reference costs twice for no reason.
Only round-robin allocations that are usually freed through page reclaim
or slab shrinking.
Bisected by Dave Hansen.
THP migration can fail for a variety of reasons. Avoid flushing the TLB
to deal with THP migration races until the copy is ready to start.
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
do_huge_pmd_numa_page() handles the case where there is parallel THP
migration. However, by the time it is checked the NUMA hinting
information has already been disrupted. This patch adds an earlier
check with some helpers.
On a protection change it is no longer clear if the page should be still
accessible. This patch clears the NUMA hinting fault bits on a
protection change.
If a PMD changes during a THP migration then migration aborts but the
failure path is doing more work than is necessary.
The anon_vma lock prevents parallel THP splits and any associated
complexity that arises when handling splits during THP migration. This
patch checks if the lock was successfully acquired and bails from THP
migration if it failed for any reason.
The TLB must be flushed if the PTE is updated but change_pte_range is
clearing the PTE while marking PTEs pte_numa without necessarily
flushing the TLB if it reinserts the same entry. Without the flush,
it's conceivable that two processors have different TLBs for the same
virtual address and at the very least it would generate spurious faults.
This patch only unmaps the pages in change_pte_range for a full
protection change.
[riel@redhat.com: write pte_numa pte back to the page tables]
Cc: Chegu Vinod <chegu_vinod@hp.com>
If the PMD is flushed then a parallel fault in handle_mm_fault() will
enter the pmd_none and do_huge_pmd_anonymous_page() path where it'll
attempt to insert a huge zero page. This is wasteful so the patch
avoids clearing the PMD when setting pmd_numa.
On x86, PMD entries are similar to _PAGE_PROTNONE protection and are
handled as NUMA hinting faults. The following two page table protection
bits are what defines them
_PAGE_NUMA:set _PAGE_PRESENT:clear
A PMD is considered present if any of the _PAGE_PRESENT, _PAGE_PROTNONE,
_PAGE_PSE or _PAGE_NUMA bits are set. If pmdp_invalidate encounters a
pmd_numa, it clears the present bit leaving _PAGE_NUMA which will be
considered not present by the CPU but present by pmd_present. The
existing caller of pmdp_invalidate should handle it but it's an
inconsistent state for a PMD. This patch keeps the state consistent
when calling pmdp_invalidate.
MMU notifiers must be called on THP page migration or secondary MMUs
will get very confused.
Base pages are unmapped and flushed from cache and TLB during normal
page migration and replaced with a migration entry that causes any
parallel NUMA hinting fault or gup to block until migration completes.
THP does not unmap pages due to a lack of support for migration entries
at a PMD level. This allows races with get_user_pages and
get_user_pages_fast which commit 3f926ab945b6 ("mm: Close races between
THP migration and PMD numa clearing") made worse by introducing a
pmd_clear_flush().
This patch forces get_user_page (fast and normal) on a pmd_numa page to
go through the slow get_user_page path where it will serialise against
THP migration and properly account for the NUMA hinting fault. On the
migration side the page table lock is taken for each PTE update.
Commit 4942642080ea ("mm: memcg: handle non-error OOM situations more
gracefully") allowed tasks that already entered a memcg OOM condition to
bypass the memcg limit on subsequent allocation attempts hoping this
would expedite finishing the page fault and executing the kill.
David Rientjes is worried that this breaks memcg isolation guarantees
and since there is no evidence that the bypass actually speeds up fault
processing just change it so that these subsequent charge attempts fail
outright. The notable exception being __GFP_NOFAIL charges which are
required to bypass the limit regardless.
Reported-by: David Rientjes <rientjes@google.com>
Acked-bt: David Rientjes <rientjes@google.com>
There is a race condition between a memcg being torn down and a swapin
triggered from a different memcg of a page that was recorded to belong
to the exiting memcg on swapout (with CONFIG_MEMCG_SWAP extension). The
result is unreclaimable pages pointing to dead memcgs, which can lead to
anything from endless loops in later memcg teardown (the page is charged
to all hierarchical parents but is not on any LRU list) or crashes from
following the dangling memcg pointer.
Memcgs with tasks in them can not be torn down and usually charges don't
show up in memcgs without tasks. Swapin with the CONFIG_MEMCG_SWAP
extension is the notable exception because it charges the cgroup that
was recorded as owner during swapout, which may be empty and in the
process of being torn down when a task in another memcg triggers the
swapin:
teardown: swapin:
lookup_swap_cgroup_id()
rcu_read_lock()
mem_cgroup_lookup()
css_tryget()
rcu_read_unlock()
disable css_tryget()
call_rcu()
offline_css()
reparent_charges()
res_counter_charge() (hierarchical!)
css_put()
css_free()
pc->mem_cgroup = dead memcg
add page to dead lru
Add a final reparenting step into css_free() to make sure any such raced
charges are moved out of the memcg before it's finally freed.
In the longer term it would be cleaner to have the css_tryget() and the
res_counter charge under the same RCU lock section so that the charge
reparenting is deferred until the last charge whose tryget succeeded is
visible. But this will require more invasive changes that will be
harder to evaluate and backport into stable, so better defer them to a
separate change set.
Andrey Wagin reported crash on VM_BUG_ON() in pgtable_pmd_page_dtor() with
fallowing backtrace:
free_pgd_range+0x2bf/0x410
free_pgtables+0xce/0x120
unmap_region+0xe0/0x120
do_munmap+0x249/0x360
move_vma+0x144/0x270
SyS_mremap+0x3b9/0x510
system_call_fastpath+0x16/0x1b
The crash can be reproduce with this test case:
#define _GNU_SOURCE
#include <sys/mman.h>
#include <stdio.h>
#include <unistd.h>
#define MB (1024 * 1024UL)
#define GB (1024 * MB)
int main(int argc, char **argv)
char *p;
int i;
p = mmap((void *) GB, 10 * MB, PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
for (i = 0; i < 10 * MB; i += 4096)
p[i] = 1;
mremap(p, 10 * MB, 10 * MB, MREMAP_FIXED | MREMAP_MAYMOVE, 2 * GB);
return 0;
Due to split PMD lock, we now store preallocated PTE tables for THP
pages per-PMD table. It means we need to move them to other PMD table
if huge PMD moved there.
Reported-by: Andrey Vagin <avagin@openvz.org>
Tested-by: Andrey Vagin <avagin@openvz.org>
Commit 84235de394d9 ("fs: buffer: move allocation failure loop into the
allocator") started recognizing __GFP_NOFAIL in memory cgroups but
forgot to disable the OOM killer.
Any task that does not fail allocation will also not enter the OOM
completion path. So don't declare an OOM state in this case or it'll be
leaked and the task be able to bypass the limit until the next
userspace-triggered page fault cleans up the OOM state.
Reported-by: William Dauchy <wdauchy@gmail.com>
We have a problem where the big_key key storage implementation uses a
shmem backed inode to hold the key contents. Because of this detail of
implementation LSM checks are being done between processes trying to
read the keys and the tmpfs backed inode. The LSM checks are already
being handled on the key interface level and should not be enforced at
the inode level (since the inode is an implementation detail, not a
part of the security model)
This patch implements a new function shmem_kernel_file_setup() which
returns the equivalent to shmem_file_setup() only the underlying inode
has S_PRIVATE set. This means that all LSM checks for the inode in
question are skipped. It should only be used for kernel internal
operations where the inode is not exposed to userspace without proper
LSM checking. It is possible that some other users of
shmem_file_setup() should use the new interface, but this has not been
explored.
Reproducing this bug is a little bit difficult. The steps I used on
Fedora are:
(1) Turn off selinux enforcing:
setenforce 0
(2) Create a huge key
k=`dd if=/dev/zero bs=8192 count=1 | keyctl padd big_key test-key @s`
(3) Access the key in another context:
runcon system_u:system_r:httpd_t:s0-s0:c0.c1023 keyctl print $k >/dev/null
(4) Examine the audit logs:
ausearch -m AVC -i --subject httpd_t | audit2allow
If the last command's output includes a line that looks like:
allow httpd_t user_tmpfs_t:file { open read };
There was an inode check between httpd and the tmpfs filesystem. With
this patch no such denial will be seen. (NOTE! you should clear your
audit log if you have tested for this previously)
(Please return you box to enforcing)
Signed-off-by: Eric Paris <eparis@redhat.com>
cc: Hugh Dickins <hughd@google.com>
cc: linux-mm@kvack.org
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux
Pull SLAB changes from Pekka Enberg:
"The patches from Joonsoo Kim switch mm/slab.c to use 'struct page' for
slab internals similar to mm/slub.c. This reduces memory usage and
improves performance:
https://lkml.org/lkml/2013/10/16/155
Rest of the changes are bug fixes from various people"
* 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: (21 commits)
mm, slub: fix the typo in mm/slub.c
mm, slub: fix the typo in include/linux/slub_def.h
slub: Handle NULL parameter in kmem_cache_flags
slab: replace non-existing 'struct freelist *' with 'void *'
slab: fix to calm down kmemleak warning
slub: proper kmemleak tracking if CONFIG_SLUB_DEBUG disabled
slab: rename slab_bufctl to slab_freelist
slab: remove useless statement for checking pfmemalloc
slab: replace free and inuse in struct slab with newly introduced active
slab: remove SLAB_LIMIT
slab: remove kmem_bufctl_t
slab: change the management method of free objects of the slab
slab: use __GFP_COMP flag for allocating slab pages
slab: use well-defined macro, virt_to_slab()
slab: overloading the RCU head over the LRU for RCU free
slab: remove cachep in struct slab_rcu
slab: remove nodeid in struct slab
slab: remove colouroff in struct slab
slab: change return type of kmem_getpages() to struct page
