path: root/mm
2013-01-17thp, memcg: split hugepage for memcg oom on cowDavid Rientjes
commit 1f1d06c34f7675026326cd9f39ff91e4555cf355 upstream. On COW, a new hugepage is allocated and charged to the memcg. If the system is oom or the charge to the memcg fails, however, the fault handler will return VM_FAULT_OOM which results in an oom kill. Instead, it's possible to fallback to splitting the hugepage so that the COW results only in an order-0 page being allocated and charged to the memcg which has a higher liklihood to succeed. This is expensive because the hugepage must be split in the page fault handler, but it is much better than unnecessarily oom killing a process. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17mm: use aligned zone start for pfn_to_bitidx calculationLaura Abbott
commit c060f943d0929f3e429c5d9522290584f6281d6e upstream. The current calculation in pfn_to_bitidx assumes that (pfn - zone->zone_start_pfn) >> pageblock_order will return the same bit for all pfn in a pageblock. If zone_start_pfn is not aligned to pageblock_nr_pages, this may not always be correct. Consider the following with pageblock order = 10, zone start 2MB: pfn | pfn - zone start | (pfn - zone start) >> page block order ---------------------------------------------------------------- 0x26000 | 0x25e00 | 0x97 0x26100 | 0x25f00 | 0x97 0x26200 | 0x26000 | 0x98 0x26300 | 0x26100 | 0x98 This means that calling {get,set}_pageblock_migratetype on a single page will not set the migratetype for the full block. Fix this by rounding down zone_start_pfn when doing the bitidx calculation. For our use case, the effects of this bug were mostly tied to the fact that CMA allocations would either take a long time or fail to happen. Depending on the driver using CMA, this could result in anything from visual glitches to application failures. Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17mm: compaction: fix echo 1 > compact_memory return error issueJason Liu
commit 7964c06d66c76507d8b6b662bffea770c29ef0ce upstream. when run the folloing command under shell, it will return error sh/$ echo 1 > /proc/sys/vm/compact_memory sh/$ sh: write error: Bad address After strace, I found the following log: ... write(1, "1\n", 2) = 3 write(1, "", 4294967295) = -1 EFAULT (Bad address) write(2, "echo: write error: Bad address\n", 31echo: write error: Bad address ) = 31 This tells system return 3(COMPACT_COMPLETE) after write data to compact_memory. The fix is to make the system just return 0 instead 3(COMPACT_COMPLETE) from sysctl_compaction_handler after compaction_nodes finished. Signed-off-by: Jason Liu <r64343@freescale.com> Suggested-by: David Rientjes <rientjes@google.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPTMichal Hocko
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream. Since commit e303297e6c3a ("mm: extended batches for generic mmu_gather") we are batching pages to be freed until either tlb_next_batch cannot allocate a new batch or we are done. This works just fine most of the time but we can get in troubles with non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY) on large machines where too aggressive batching might lead to soft lockups during process exit path (exit_mmap) because there are no scheduling points down the free_pages_and_swap_cache path and so the freeing can take long enough to trigger the soft lockup. The lockup is harmless except when the system is setup to panic on softlockup which is not that unusual. The simplest way to work around this issue is to limit the maximum number of batches in a single mmu_gather. 10k of collected pages should be safe to prevent from soft lockups (we would have 2ms for one) even if they are all freed without an explicit scheduling point. This patch doesn't add any new explicit scheduling points because it relies on zap_pmd_range during page tables zapping which calls cond_resched per PMD. The following lockup has been reported for 3.0 kernel with a huge process (in order of hundreds gigs but I do know any more details). BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053] Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod Supported: Yes CPU 56 Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7 RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10 RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206 RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80 RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206 RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400 R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100) Call Trace: release_pages+0xc5/0x260 free_pages_and_swap_cache+0x9d/0xc0 tlb_flush_mmu+0x5c/0x80 tlb_finish_mmu+0xe/0x50 exit_mmap+0xbd/0x120 mmput+0x49/0x120 exit_mm+0x122/0x160 do_exit+0x17a/0x430 do_group_exit+0x3d/0xb0 get_signal_to_deliver+0x247/0x480 do_signal+0x71/0x1b0 do_notify_resume+0x98/0xb0 int_signal+0x12/0x17 DWARF2 unwinder stuck at int_signal+0x12/0x17 Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tmpfs mempolicy: fix /proc/mounts corrupting memoryHugh Dickins
commit f2a07f40dbc603c15f8b06e6ec7f768af67b424f upstream. Recently I suggested using "mount -o remount,mpol=local /tmp" in NUMA mempolicy testing. Very nasty. Reading /proc/mounts, /proc/pid/mounts or /proc/pid/mountinfo may then corrupt one bit of kernel memory, often in a page table (causing "Bad swap" or "Bad page map" warning or "Bad pagetable" oops), sometimes in a vm_area_struct or rbnode or somewhere worse. "mpol=prefer" and "mpol=prefer:Node" are equally toxic. Recent NUMA enhancements are not to blame: this dates back to 2.6.35, when commit e17f74af351c "mempolicy: don't call mpol_set_nodemask() when no_context" skipped mpol_parse_str()'s call to mpol_set_nodemask(), which used to initialize v.preferred_node, or set MPOL_F_LOCAL in flags. With slab poisoning, you can then rely on mpol_to_str() to set the bit for node 0x6b6b, probably in the next page above the caller's stack. mpol_parse_str() is only called from shmem_parse_options(): no_context is always true, so call it unused for now, and remove !no_context code. Set v.nodes or v.preferred_node or MPOL_F_LOCAL as mpol_to_str() might expect. Then mpol_to_str() can ignore its no_context argument also, the mpol being appropriately initialized whether contextualized or not. Rename its no_context unused too, and let subsequent patch remove them (that's not needed for stable backporting, which would involve rejects). I don't understand why MPOL_LOCAL is described as a pseudo-policy: it's a reasonable policy which suffers from a confusing implementation in terms of MPOL_PREFERRED with MPOL_F_LOCAL. I believe this would be much more robust if MPOL_LOCAL were recognized in switch statements throughout, MPOL_F_LOCAL deleted, and MPOL_PREFERRED use the (possibly empty) nodes mask like everyone else, instead of its preferred_node variant (I presume an optimization from the days before MPOL_LOCAL). But that would take me too long to get right and fully tested. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17tmpfs: fix shared mempolicy leakMel Gorman
commit 18a2f371f5edf41810f6469cb9be39931ef9deb9 upstream. This fixes a regression in 3.7-rc, which has since gone into stable. Commit 00442ad04a5e ("mempolicy: fix a memory corruption by refcount imbalance in alloc_pages_vma()") changed get_vma_policy() to raise the refcount on a shmem shared mempolicy; whereas shmem_alloc_page() went on expecting alloc_page_vma() to drop the refcount it had acquired. This deserves a rework: but for now fix the leak in shmem_alloc_page(). Hugh: shmem_swapin() did not need a fix, but surely it's clearer to use the same refcounting there as in shmem_alloc_page(), delete its onstack mempolicy, and the strange mpol_cond_copy() and __mpol_cond_copy() - those were invented to let swapin_readahead() make an unknown number of calls to alloc_pages_vma() with one mempolicy; but since 00442ad04a5e, alloc_pages_vma() has kept refcount in balance, so now no problem. Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17mm: dmapool: use provided gfp flags for all dma_alloc_coherent() callsMarek Szyprowski
commit 387870f2d6d679746020fa8e25ef786ff338dc98 upstream. dmapool always calls dma_alloc_coherent() with GFP_ATOMIC flag, regardless the flags provided by the caller. This causes excessive pruning of emergency memory pools without any good reason. Additionaly, on ARM architecture any driver which is using dmapools will sooner or later trigger the following error: "ERROR: 256 KiB atomic DMA coherent pool is too small! Please increase it with coherent_pool= kernel parameter!". Increasing the coherent pool size usually doesn't help much and only delays such error, because all GFP_ATOMIC DMA allocations are always served from the special, very limited memory pool. This patch changes the dmapool code to correctly use gfp flags provided by the dmapool caller. Reported-by: Soeren Moch <smoch@web.de> Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Soeren Moch <smoch@web.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-10mm: soft offline: split thp at the beginning of soft_offline_page()Naoya Horiguchi
commit 783657a7dc20e5c0efbc9a09a9dd38e238a723da upstream. When we try to soft-offline a thp tail page, put_page() is called on the tail page unthinkingly and VM_BUG_ON is triggered in put_compound_page(). This patch splits thp before going into the main body of soft-offlining. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Andi Kleen <andi.kleen@intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-10mm/vmemmap: fix wrong use of virt_to_pageJianguo Wu
commit ae64ffcac35de0db628ba9631edf8ff34c5cd7ac upstream. I enable CONFIG_DEBUG_VIRTUAL and CONFIG_SPARSEMEM_VMEMMAP, when doing memory hotremove, there is a kernel BUG at arch/x86/mm/physaddr.c:20. It is caused by free_section_usemap()->virt_to_page(), virt_to_page() is only used for kernel direct mapping address, but sparse-vmemmap uses vmemmap address, so it is going wrong here. ------------[ cut here ]------------ kernel BUG at arch/x86/mm/physaddr.c:20! invalid opcode: 0000 [#1] SMP Modules linked in: acpihp_drv acpihp_slot edd cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf fuse vfat fat loop dm_mod coretemp kvm crc32c_intel ipv6 ixgbe igb iTCO_wdt i7core_edac edac_core pcspkr iTCO_vendor_support ioatdma microcode joydev sr_mod i2c_i801 dca lpc_ich mfd_core mdio tpm_tis i2c_core hid_generic tpm cdrom sg tpm_bios rtc_cmos button ext3 jbd mbcache usbhid hid uhci_hcd ehci_hcd usbcore usb_common sd_mod crc_t10dif processor thermal_sys hwmon scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh_emc scsi_dh ata_generic ata_piix libata megaraid_sas scsi_mod CPU 39 Pid: 6454, comm: sh Not tainted 3.7.0-rc1-acpihp-final+ #45 QCI QSSC-S4R/QSSC-S4R RIP: 0010:[<ffffffff8103c908>] [<ffffffff8103c908>] __phys_addr+0x88/0x90 RSP: 0018:ffff8804440d7c08 EFLAGS: 00010006 RAX: 0000000000000006 RBX: ffffea0012000000 RCX: 000000000000002c ... Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reviewd-by: Wen Congyang <wency@cn.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26mm: bugfix: set current->reclaim_state to NULL while returning from kswapd()Takamori Yamaguchi
commit b0a8cc58e6b9aaae3045752059e5e6260c0b94bc upstream. In kswapd(), set current->reclaim_state to NULL before returning, as current->reclaim_state holds reference to variable on kswapd()'s stack. In rare cases, while returning from kswapd() during memory offlining, __free_slab() and freepages() can access the dangling pointer of current->reclaim_state. Signed-off-by: Takamori Yamaguchi <takamori.yamaguchi@jp.sony.com> Signed-off-by: Aaditya Kumar <aaditya.kumar@ap.sony.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-05mm: fix XFS oops due to dirty pages without buffers on s390Jan Kara
commit ef5d437f71afdf4afdbab99213add99f4b1318fd upstream. On s390 any write to a page (even from kernel itself) sets architecture specific page dirty bit. Thus when a page is written to via buffered write, HW dirty bit gets set and when we later map and unmap the page, page_remove_rmap() finds the dirty bit and calls set_page_dirty(). Dirtying of a page which shouldn't be dirty can cause all sorts of problems to filesystems. The bug we observed in practice is that buffers from the page get freed, so when the page gets later marked as dirty and writeback writes it, XFS crashes due to an assertion BUG_ON(!PagePrivate(page)) in page_buffers() called from xfs_count_page_state(). Similar problem can also happen when zero_user_segment() call from xfs_vm_writepage() (or block_write_full_page() for that matter) set the hardware dirty bit during writeback, later buffers get freed, and then page unmapped. Fix the issue by ignoring s390 HW dirty bit for page cache pages of mappings with mapping_cap_account_dirty(). This is safe because for such mappings when a page gets marked as writeable in PTE it is also marked dirty in do_wp_page() or do_page_fault(). When the dirty bit is cleared by clear_page_dirty_for_io(), the page gets writeprotected in page_mkclean(). So pagecache page is writeable if and only if it is dirty. Thanks to Hugh Dickins for pointing out mapping has to have mapping_cap_account_dirty() for things to work and proposing a cleaned up variant of the patch. The patch has survived about two hours of running fsx-linux on tmpfs while heavily swapping and several days of running on out build machines where the original problem was triggered. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21tmpfs,ceph,gfs2,isofs,reiserfs,xfs: fix fh_len checkingHugh Dickins
commit 35c2a7f4908d404c9124c2efc6ada4640ca4d5d5 upstream. Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(), u64 inum = fid->raw[2]; which is unhelpfully reported as at the end of shmem_alloc_inode(): BUG: unable to handle kernel paging request at ffff880061cd3000 IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Call Trace: [<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0 [<ffffffff812d77c3>] do_handle_open+0x163/0x2c0 [<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10 [<ffffffff83a5f3f8>] tracesys+0xe1/0xe6 Right, tmpfs is being stupid to access fid->raw[2] before validating that fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may fall at the end of a page, and the next page not be present. But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and could oops in the same way: add the missing fh_len checks to those. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Sage Weil <sage@inktank.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: fix a memory corruption by refcount imbalance in alloc_pages_vma()Mel Gorman
commit 00442ad04a5eac08a98255697c510e708f6082e2 upstream. Commit cc9a6c877661 ("cpuset: mm: reduce large amounts of memory barrier related damage v3") introduced a potential memory corruption. shmem_alloc_page() uses a pseudo vma and it has one significant unique combination, vma->vm_ops=NULL and vma->policy->flags & MPOL_F_SHARED. get_vma_policy() does NOT increase a policy ref when vma->vm_ops=NULL and mpol_cond_put() DOES decrease a policy ref when a policy has MPOL_F_SHARED. Therefore, when a cpuset update race occurs, alloc_pages_vma() falls in 'goto retry_cpuset' path, decrements the reference count and frees the policy prematurely. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: fix refcount leak in mpol_set_shared_policy()KOSAKI Motohiro
commit 63f74ca21f1fad36d075e063f06dcc6d39fe86b2 upstream. When shared_policy_replace() fails to allocate new->policy is not freed correctly by mpol_set_shared_policy(). The problem is that shared mempolicy code directly call kmem_cache_free() in multiple places where it is easy to make a mistake. This patch creates an sp_free wrapper function and uses it. The bug was introduced pre-git age (IOW, before 2.6.12-rc2). [mgorman@suse.de: Editted changelog] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: fix a race in shared_policy_replace()Mel Gorman
commit b22d127a39ddd10d93deee3d96e643657ad53a49 upstream. shared_policy_replace() use of sp_alloc() is unsafe. 1) sp_node cannot be dereferenced if sp->lock is not held and 2) another thread can modify sp_node between spin_unlock for allocating a new sp node and next spin_lock. The bug was introduced before 2.6.12-rc2. Kosaki's original patch for this problem was to allocate an sp node and policy within shared_policy_replace and initialise it when the lock is reacquired. I was not keen on this approach because it partially duplicates sp_alloc(). As the paths were sp->lock is taken are not that performance critical this patch converts sp->lock to sp->mutex so it can sleep when calling sp_alloc(). [kosaki.motohiro@jp.fujitsu.com: Original patch] Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mempolicy: remove mempolicy sharingKOSAKI Motohiro
commit 869833f2c5c6e4dd09a5378cfc665ffb4615e5d2 upstream. Dave Jones' system call fuzz testing tool "trinity" triggered the following bug error with slab debugging enabled ============================================================================= BUG numa_policy (Not tainted): Poison overwritten ----------------------------------------------------------------------------- INFO: 0xffff880146498250-0xffff880146498250. First byte 0x6a instead of 0x6b INFO: Allocated in mpol_new+0xa3/0x140 age=46310 cpu=6 pid=32154 __slab_alloc+0x3d3/0x445 kmem_cache_alloc+0x29d/0x2b0 mpol_new+0xa3/0x140 sys_mbind+0x142/0x620 system_call_fastpath+0x16/0x1b INFO: Freed in __mpol_put+0x27/0x30 age=46268 cpu=6 pid=32154 __slab_free+0x2e/0x1de kmem_cache_free+0x25a/0x260 __mpol_put+0x27/0x30 remove_vma+0x68/0x90 exit_mmap+0x118/0x140 mmput+0x73/0x110 exit_mm+0x108/0x130 do_exit+0x162/0xb90 do_group_exit+0x4f/0xc0 sys_exit_group+0x17/0x20 system_call_fastpath+0x16/0x1b INFO: Slab 0xffffea0005192600 objects=27 used=27 fp=0x (null) flags=0x20000000004080 INFO: Object 0xffff880146498250 @offset=592 fp=0xffff88014649b9d0 The problem is that the structure is being prematurely freed due to a reference count imbalance. In the following case mbind(addr, len) should replace the memory policies of both vma1 and vma2 and thus they will become to share the same mempolicy and the new mempolicy will have the MPOL_F_SHARED flag. +-------------------+-------------------+ | vma1 | vma2(shmem) | +-------------------+-------------------+ | | addr addr+len alloc_pages_vma() uses get_vma_policy() and mpol_cond_put() pair for maintaining the mempolicy reference count. The current rule is that get_vma_policy() only increments refcount for shmem VMA and mpol_conf_put() only decrements refcount if the policy has MPOL_F_SHARED. In above case, vma1 is not shmem vma and vma->policy has MPOL_F_SHARED! The reference count will be decreased even though was not increased whenever alloc_page_vma() is called. This has been broken since commit [52cd3b07: mempolicy: rework mempolicy Reference Counting] in 2008. There is another serious bug with the sharing of memory policies. Currently, mempolicy rebind logic (it is called from cpuset rebinding) ignores a refcount of mempolicy and override it forcibly. Thus, any mempolicy sharing may cause mempolicy corruption. The bug was introduced by commit [68860ec1: cpusets: automatic numa mempolicy rebinding]. Ideally, the shared policy handling would be rewritten to either properly handle COW of the policy structures or at least reference count MPOL_F_SHARED based exclusively on information within the policy. However, this patch takes the easier approach of disabling any policy sharing between VMAs. Each new range allocated with sp_alloc will allocate a new policy, set the reference count to 1 and drop the reference count of the old policy. This increases the memory footprint but is not expected to be a major problem as mbind() is unlikely to be used for fine-grained ranges. It is also inefficient because it means we allocate a new policy even in cases where mbind_range() could use the new_policy passed to it. However, it is more straight-forward and the change should be invisible to the user. [mgorman@suse.de: Edited changelog] Reported-by: Dave Jones <davej@redhat.com> Cc: Christoph Lameter <cl@linux.com> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13revert "mm: mempolicy: Let vma_merge and vma_split handle vma->vm_policy ↵KOSAKI Motohiro
linkages" commit 8d34694c1abf29df1f3c7317936b7e3e2e308d9b upstream. Commit 05f144a0d5c2 ("mm: mempolicy: Let vma_merge and vma_split handle vma->vm_policy linkages") removed vma->vm_policy updates code but it is the purpose of mbind_range(). Now, mbind_range() is virtually a no-op and while it does not allow memory corruption it is not the right fix. This patch is a revert. [mgorman@suse.de: Edited changelog] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Christoph Lameter <cl@linux.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mm: fix invalidate_complete_page2() lock orderingHugh Dickins
commit ec4d9f626d5908b6052c2973f37992f1db52e967 upstream. In fuzzing with trinity, lockdep protested "possible irq lock inversion dependency detected" when isolate_lru_page() reenabled interrupts while still holding the supposedly irq-safe tree_lock: invalidate_inode_pages2 invalidate_complete_page2 spin_lock_irq(&mapping->tree_lock) clear_page_mlock isolate_lru_page spin_unlock_irq(&zone->lru_lock) isolate_lru_page() is correct to enable interrupts unconditionally: invalidate_complete_page2() is incorrect to call clear_page_mlock() while holding tree_lock, which is supposed to nest inside lru_lock. Both truncate_complete_page() and invalidate_complete_page() call clear_page_mlock() before taking tree_lock to remove page from radix_tree. I guess invalidate_complete_page2() preferred to test PageDirty (again) under tree_lock before committing to the munlock; but since the page has already been unmapped, its state is already somewhat inconsistent, and no worse if clear_page_mlock() moved up. Reported-by: Sasha Levin <levinsasha928@gmail.com> Deciphered-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michel Lespinasse <walken@google.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02memory hotplug: fix section info double registration bugqiuxishi
commit f14851af0ebb32745c6c5a2e400aa0549f9d20df upstream. There may be a bug when registering section info. For example, on my Itanium platform, the pfn range of node0 includes the other nodes, so other nodes' section info will be double registered, and memmap's page count will equal to 3. node0: start_pfn=0x100, spanned_pfn=0x20fb00, present_pfn=0x7f8a3, => 0x000100-0x20fc00 node1: start_pfn=0x80000, spanned_pfn=0x80000, present_pfn=0x80000, => 0x080000-0x100000 node2: start_pfn=0x100000, spanned_pfn=0x80000, present_pfn=0x80000, => 0x100000-0x180000 node3: start_pfn=0x180000, spanned_pfn=0x80000, present_pfn=0x80000, => 0x180000-0x200000 free_all_bootmem_node() register_page_bootmem_info_node() register_page_bootmem_info_section() When hot remove memory, we can't free the memmap's page because page_count() is 2 after put_page_bootmem(). sparse_remove_one_section() free_section_usemap() free_map_bootmem() put_page_bootmem() [akpm@linux-foundation.org: add code comment] Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02mm/page_alloc: fix the page address of higher page's buddy calculationLi Haifeng
commit 0ba8f2d59304dfe69b59c034de723ad80f7ab9ac upstream. The heuristic method for buddy has been introduced since commit 43506fad21ca ("mm/page_alloc.c: simplify calculation of combined index of adjacent buddy lists"). But the page address of higher page's buddy was wrongly calculated, which will lead page_is_buddy to fail for ever. IOW, the heuristic method would be disabled with the wrong page address of higher page's buddy. Calculating the page address of higher page's buddy should be based higher_page with the offset between index of higher page and index of higher page's buddy. Signed-off-by: Haifeng Li <omycle@gmail.com> Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KyongHo Cho <pullip.cho@samsung.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-14Remove user-triggerable BUG from mpol_to_strDave Jones
commit 80de7c3138ee9fd86a98696fd2cf7ad89b995d0a upstream. Trivially triggerable, found by trinity: kernel BUG at mm/mempolicy.c:2546! Process trinity-child2 (pid: 23988, threadinfo ffff88010197e000, task ffff88007821a670) Call Trace: show_numa_map+0xd5/0x450 show_pid_numa_map+0x13/0x20 traverse+0xf2/0x230 seq_read+0x34b/0x3e0 vfs_read+0xac/0x180 sys_pread64+0xa2/0xc0 system_call_fastpath+0x1a/0x1f RIP: mpol_to_str+0x156/0x360 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: hugetlbfs: close race during teardown of hugetlbfs shared page tablesMel Gorman
commit d833352a4338dc31295ed832a30c9ccff5c7a183 upstream. If a process creates a large hugetlbfs mapping that is eligible for page table sharing and forks heavily with children some of whom fault and others which destroy the mapping then it is possible for page tables to get corrupted. Some teardowns of the mapping encounter a "bad pmd" and output a message to the kernel log. The final teardown will trigger a BUG_ON in mm/filemap.c. This was reproduced in 3.4 but is known to have existed for a long time and goes back at least as far as 2.6.37. It was probably was introduced in 2.6.20 by [39dde65c: shared page table for hugetlb page]. The messages look like this; [ ..........] Lots of bad pmd messages followed by this [ 127.164256] mm/memory.c:391: bad pmd ffff880412e04fe8(80000003de4000e7). [ 127.164257] mm/memory.c:391: bad pmd ffff880412e04ff0(80000003de6000e7). [ 127.164258] mm/memory.c:391: bad pmd ffff880412e04ff8(80000003de0000e7). [ 127.186778] ------------[ cut here ]------------ [ 127.186781] kernel BUG at mm/filemap.c:134! [ 127.186782] invalid opcode: 0000 [#1] SMP [ 127.186783] CPU 7 [ 127.186784] Modules linked in: af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf ext3 jbd dm_mod coretemp crc32c_intel usb_storage ghash_clmulni_intel aesni_intel i2c_i801 r8169 mii uas sr_mod cdrom sg iTCO_wdt iTCO_vendor_support shpchp serio_raw cryptd aes_x86_64 e1000e pci_hotplug dcdbas aes_generic container microcode ext4 mbcache jbd2 crc16 sd_mod crc_t10dif i915 drm_kms_helper drm i2c_algo_bit ehci_hcd ahci libahci usbcore rtc_cmos usb_common button i2c_core intel_agp video intel_gtt fan processor thermal thermal_sys hwmon ata_generic pata_atiixp libata scsi_mod [ 127.186801] [ 127.186802] Pid: 9017, comm: hugetlbfs-test Not tainted 3.4.0-autobuild #53 Dell Inc. OptiPlex 990/06D7TR [ 127.186804] RIP: 0010:[<ffffffff810ed6ce>] [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160 [ 127.186809] RSP: 0000:ffff8804144b5c08 EFLAGS: 00010002 [ 127.186810] RAX: 0000000000000001 RBX: ffffea000a5c9000 RCX: 00000000ffffffc0 [ 127.186811] RDX: 0000000000000000 RSI: 0000000000000009 RDI: ffff88042dfdad00 [ 127.186812] RBP: ffff8804144b5c18 R08: 0000000000000009 R09: 0000000000000003 [ 127.186813] R10: 0000000000000000 R11: 000000000000002d R12: ffff880412ff83d8 [ 127.186814] R13: ffff880412ff83d8 R14: 0000000000000000 R15: ffff880412ff83d8 [ 127.186815] FS: 00007fe18ed2c700(0000) GS:ffff88042dce0000(0000) knlGS:0000000000000000 [ 127.186816] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 127.186817] CR2: 00007fe340000503 CR3: 0000000417a14000 CR4: 00000000000407e0 [ 127.186818] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 127.186819] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 127.186820] Process hugetlbfs-test (pid: 9017, threadinfo ffff8804144b4000, task ffff880417f803c0) [ 127.186821] Stack: [ 127.186822] ffffea000a5c9000 0000000000000000 ffff8804144b5c48 ffffffff810ed83b [ 127.186824] ffff8804144b5c48 000000000000138a 0000000000001387 ffff8804144b5c98 [ 127.186825] ffff8804144b5d48 ffffffff811bc925 ffff8804144b5cb8 0000000000000000 [ 127.186827] Call Trace: [ 127.186829] [<ffffffff810ed83b>] delete_from_page_cache+0x3b/0x80 [ 127.186832] [<ffffffff811bc925>] truncate_hugepages+0x115/0x220 [ 127.186834] [<ffffffff811bca43>] hugetlbfs_evict_inode+0x13/0x30 [ 127.186837] [<ffffffff811655c7>] evict+0xa7/0x1b0 [ 127.186839] [<ffffffff811657a3>] iput_final+0xd3/0x1f0 [ 127.186840] [<ffffffff811658f9>] iput+0x39/0x50 [ 127.186842] [<ffffffff81162708>] d_kill+0xf8/0x130 [ 127.186843] [<ffffffff81162812>] dput+0xd2/0x1a0 [ 127.186845] [<ffffffff8114e2d0>] __fput+0x170/0x230 [ 127.186848] [<ffffffff81236e0e>] ? rb_erase+0xce/0x150 [ 127.186849] [<ffffffff8114e3ad>] fput+0x1d/0x30 [ 127.186851] [<ffffffff81117db7>] remove_vma+0x37/0x80 [ 127.186853] [<ffffffff81119182>] do_munmap+0x2d2/0x360 [ 127.186855] [<ffffffff811cc639>] sys_shmdt+0xc9/0x170 [ 127.186857] [<ffffffff81410a39>] system_call_fastpath+0x16/0x1b [ 127.186858] Code: 0f 1f 44 00 00 48 8b 43 08 48 8b 00 48 8b 40 28 8b b0 40 03 00 00 85 f6 0f 88 df fe ff ff 48 89 df e8 e7 cb 05 00 e9 d2 fe ff ff <0f> 0b 55 83 e2 fd 48 89 e5 48 83 ec 30 48 89 5d d8 4c 89 65 e0 [ 127.186868] RIP [<ffffffff810ed6ce>] __delete_from_page_cache+0x15e/0x160 [ 127.186870] RSP <ffff8804144b5c08> [ 127.186871] ---[ end trace 7cbac5d1db69f426 ]--- The bug is a race and not always easy to reproduce. To reproduce it I was doing the following on a single socket I7-based machine with 16G of RAM. $ hugeadm --pool-pages-max DEFAULT:13G $ echo $((18*1048576*1024)) > /proc/sys/kernel/shmmax $ echo $((18*1048576*1024)) > /proc/sys/kernel/shmall $ for i in `seq 1 9000`; do ./hugetlbfs-test; done On my particular machine, it usually triggers within 10 minutes but enabling debug options can change the timing such that it never hits. Once the bug is triggered, the machine is in trouble and needs to be rebooted. The machine will respond but processes accessing proc like "ps aux" will hang due to the BUG_ON. shutdown will also hang and needs a hard reset or a sysrq-b. The basic problem is a race between page table sharing and teardown. For the most part page table sharing depends on i_mmap_mutex. In some cases, it is also taking the mm->page_table_lock for the PTE updates but with shared page tables, it is the i_mmap_mutex that is more important. Unfortunately it appears to be also insufficient. Consider the following situation Process A Process B --------- --------- hugetlb_fault shmdt LockWrite(mmap_sem) do_munmap unmap_region unmap_vmas unmap_single_vma unmap_hugepage_range Lock(i_mmap_mutex) Lock(mm->page_table_lock) huge_pmd_unshare/unmap tables <--- (1) Unlock(mm->page_table_lock) Unlock(i_mmap_mutex) huge_pte_alloc ... Lock(i_mmap_mutex) ... vma_prio_walk, find svma, spte ... Lock(mm->page_table_lock) ... share spte ... Unlock(mm->page_table_lock) ... Unlock(i_mmap_mutex) ... hugetlb_no_page <--- (2) free_pgtables unlink_file_vma hugetlb_free_pgd_range remove_vma_list In this scenario, it is possible for Process A to share page tables with Process B that is trying to tear them down. The i_mmap_mutex on its own does not prevent Process A walking Process B's page tables. At (1) above, the page tables are not shared yet so it unmaps the PMDs. Process A sets up page table sharing and at (2) faults a new entry. Process B then trips up on it in free_pgtables. This patch fixes the problem by adding a new function __unmap_hugepage_range_final that is only called when the VMA is about to be destroyed. This function clears VM_MAYSHARE during unmap_hugepage_range() under the i_mmap_mutex. This makes the VMA ineligible for sharing and avoids the race. Superficially this looks like it would then be vunerable to truncate and madvise issues but hugetlbfs has its own truncate handlers so does not use unmap_mapping_range() and does not support madvise(DONTNEED). This should be treated as a -stable candidate if it is merged. Test program is as follows. The test case was mostly written by Michal Hocko with a few minor changes to reproduce this bug. ==== CUT HERE ==== static size_t huge_page_size = (2UL << 20); static size_t nr_huge_page_A = 512; static size_t nr_huge_page_B = 5632; unsigned int get_random(unsigned int max) { struct timeval tv; gettimeofday(&tv, NULL); srandom(tv.tv_usec); return random() % max; } static void play(void *addr, size_t size) { unsigned char *start = addr, *end = start + size, *a; start += get_random(size/2); /* we could itterate on huge pages but let's give it more time. */ for (a = start; a < end; a += 4096) *a = 0; } int main(int argc, char **argv) { key_t key = IPC_PRIVATE; size_t sizeA = nr_huge_page_A * huge_page_size; size_t sizeB = nr_huge_page_B * huge_page_size; int shmidA, shmidB; void *addrA = NULL, *addrB = NULL; int nr_children = 300, n = 0; if ((shmidA = shmget(key, sizeA, IPC_CREAT|SHM_HUGETLB|0660)) == -1) { perror("shmget:"); return 1; } if ((addrA = shmat(shmidA, addrA, SHM_R|SHM_W)) == (void *)-1UL) { perror("shmat"); return 1; } if ((shmidB = shmget(key, sizeB, IPC_CREAT|SHM_HUGETLB|0660)) == -1) { perror("shmget:"); return 1; } if ((addrB = shmat(shmidB, addrB, SHM_R|SHM_W)) == (void *)-1UL) { perror("shmat"); return 1; } fork_child: switch(fork()) { case 0: switch (n%3) { case 0: play(addrA, sizeA); break; case 1: play(addrB, sizeB); break; case 2: break; } break; case -1: perror("fork:"); break; default: if (++n < nr_children) goto fork_child; play(addrA, sizeA); break; } shmdt(addrA); shmdt(addrB); do { wait(NULL); } while (--n > 0); shmctl(shmidA, IPC_RMID, NULL); shmctl(shmidB, IPC_RMID, NULL); return 0; } [akpm@linux-foundation.org: name the declaration's args, fix CONFIG_HUGETLBFS=n build] Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: mmu_notifier: fix freed page still mapped in secondary MMUXiao Guangrong
commit 3ad3d901bbcfb15a5e4690e55350db0899095a68 upstream. mmu_notifier_release() is called when the process is exiting. It will delete all the mmu notifiers. But at this time the page belonging to the process is still present in page tables and is present on the LRU list, so this race will happen: CPU 0 CPU 1 mmu_notifier_release: try_to_unmap: hlist_del_init_rcu(&mn->hlist); ptep_clear_flush_notify: mmu nofifler not found free page !!!!!! /* * At the point, the page has been * freed, but it is still mapped in * the secondary MMU. */ mn->ops->release(mn, mm); Then the box is not stable and sometimes we can get this bug: [ 738.075923] BUG: Bad page state in process migrate-perf pfn:03bec [ 738.075931] page:ffffea00000efb00 count:0 mapcount:0 mapping: (null) index:0x8076 [ 738.075936] page flags: 0x20000000000014(referenced|dirty) The same issue is present in mmu_notifier_unregister(). We can call ->release before deleting the notifier to ensure the page has been unmapped from the secondary MMU before it is freed. Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-15mm: fix wrong argument of migrate_huge_pages() in soft_offline_huge_page()Joonsoo Kim
commit dc32f63453f56d07a1073a697dcd843dd3098c09 upstream. Commit a6bc32b89922 ("mm: compaction: introduce sync-light migration for use by compaction") changed the declaration of migrate_pages() and migrate_huge_pages(). But it missed changing the argument of migrate_huge_pages() in soft_offline_huge_page(). In this case, we should call migrate_huge_pages() with MIGRATE_SYNC. Additionally, there is a mismatch between type the of argument and the function declaration for migrate_pages(). Signed-off-by: Joonsoo Kim <js1304@gmail.com> Cc: Christoph Lameter <cl@linux.com> Cc: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: fix initial shrinker size handlingKonstantin Khlebnikov
commit 635697c663f38106063d5659f0cf2e45afcd4bb5 upstream. Stable note: The commit [acf92b48: vmscan: shrinker->nr updates race and go wrong] aimed to reduce excessive reclaim of slab objects but had bug in how it treated shrinker functions that returned -1. A shrinker function can return -1, means that it cannot do anything without a risk of deadlock. For example prune_super() does this if it cannot grab a superblock refrence, even if nr_to_scan=0. Currently we interpret this -1 as a ULONG_MAX size shrinker and evaluate `total_scan' according to this. So the next time around this shrinker can cause really big pressure. Let's skip such shrinkers instead. Also make total_scan signed, otherwise the check (total_scan < 0) below never works. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm/hugetlb: fix warning in alloc_huge_page/dequeue_huge_page_vmaKonstantin Khlebnikov
commit b1c12cbcd0a02527c180a862e8971e249d3b347d upstream. Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely expensive and severely impacted page allocator performance. This is part of a series of patches that reduce page allocator overhead. Fix a gcc warning (and bug?) introduced in cc9a6c877 ("cpuset: mm: reduce large amounts of memory barrier related damage v3") Local variable "page" can be uninitialized if the nodemask from vma policy does not intersects with nodemask from cpuset. Even if it doesn't happens it is better to initialize this variable explicitly than to introduce a kernel oops in a weird corner case. mm/hugetlb.c: In function `alloc_huge_page': mm/hugetlb.c:1135:5: warning: `page' may be used uninitialized in this function Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01cpuset: mm: reduce large amounts of memory barrier related damage v3Mel Gorman
commit cc9a6c8776615f9c194ccf0b63a0aa5628235545 upstream. Stable note: Not tracked in Bugzilla. [get|put]_mems_allowed() is extremely expensive and severely impacted page allocator performance. This is part of a series of patches that reduce page allocator overhead. Commit c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing cpuset's mems") wins a super prize for the largest number of memory barriers entered into fast paths for one commit. [get|put]_mems_allowed is incredibly heavy with pairs of full memory barriers inserted into a number of hot paths. This was detected while investigating at large page allocator slowdown introduced some time after 2.6.32. The largest portion of this overhead was shown by oprofile to be at an mfence introduced by this commit into the page allocator hot path. For extra style points, the commit introduced the use of yield() in an implementation of what looks like a spinning mutex. This patch replaces the full memory barriers on both read and write sides with a sequence counter with just read barriers on the fast path side. This is much cheaper on some architectures, including x86. The main bulk of the patch is the retry logic if the nodemask changes in a manner that can cause a false failure. While updating the nodemask, a check is made to see if a false failure is a risk. If it is, the sequence number gets bumped and parallel allocators will briefly stall while the nodemask update takes place. In a page fault test microbenchmark, oprofile samples from __alloc_pages_nodemask went from 4.53% of all samples to 1.15%. The actual results were 3.3.0-rc3 3.3.0-rc3 rc3-vanilla nobarrier-v2r1 Clients 1 UserTime 0.07 ( 0.00%) 0.08 (-14.19%) Clients 2 UserTime 0.07 ( 0.00%) 0.07 ( 2.72%) Clients 4 UserTime 0.08 ( 0.00%) 0.07 ( 3.29%) Clients 1 SysTime 0.70 ( 0.00%) 0.65 ( 6.65%) Clients 2 SysTime 0.85 ( 0.00%) 0.82 ( 3.65%) Clients 4 SysTime 1.41 ( 0.00%) 1.41 ( 0.32%) Clients 1 WallTime 0.77 ( 0.00%) 0.74 ( 4.19%) Clients 2 WallTime 0.47 ( 0.00%) 0.45 ( 3.73%) Clients 4 WallTime 0.38 ( 0.00%) 0.37 ( 1.58%) Clients 1 Flt/sec/cpu 497620.28 ( 0.00%) 520294.53 ( 4.56%) Clients 2 Flt/sec/cpu 414639.05 ( 0.00%) 429882.01 ( 3.68%) Clients 4 Flt/sec/cpu 257959.16 ( 0.00%) 258761.48 ( 0.31%) Clients 1 Flt/sec 495161.39 ( 0.00%) 517292.87 ( 4.47%) Clients 2 Flt/sec 820325.95 ( 0.00%) 850289.77 ( 3.65%) Clients 4 Flt/sec 1020068.93 ( 0.00%) 1022674.06 ( 0.26%) MMTests Statistics: duration Sys Time Running Test (seconds) 135.68 132.17 User+Sys Time Running Test (seconds) 164.2 160.13 Total Elapsed Time (seconds) 123.46 120.87 The overall improvement is small but the System CPU time is much improved and roughly in correlation to what oprofile reported (these performance figures are without profiling so skew is expected). The actual number of page faults is noticeably improved. For benchmarks like kernel builds, the overall benefit is marginal but the system CPU time is slightly reduced. To test the actual bug the commit fixed I opened two terminals. The first ran within a cpuset and continually ran a small program that faulted 100M of anonymous data. In a second window, the nodemask of the cpuset was continually randomised in a loop. Without the commit, the program would fail every so often (usually within 10 seconds) and obviously with the commit everything worked fine. With this patch applied, it also worked fine so the fix should be functionally equivalent. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Miao Xie <miaox@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: vmscan: convert global reclaim to per-memcg LRU listsJohannes Weiner
commit b95a2f2d486d0d768a92879c023a03757b9c7e58 upstream - WARNING: this is a substitute patch. Stable note: Not tracked in Bugzilla. This is a partial backport of an upstream commit addressing a completely different issue that accidentally contained an important fix. The workload this patch helps was memcached when IO is started in the background. memcached should stay resident but without this patch it gets swapped. Sometimes this manifests as a drop in throughput but mostly it was observed through /proc/vmstat. Commit [246e87a9: memcg: fix get_scan_count() for small targets] was meant to fix a problem whereby small scan targets on memcg were ignored causing priority to raise too sharply. It forced scanning to take place if the target was small, memcg or kswapd. From the time it was introduced it caused excessive reclaim by kswapd with workloads being pushed to swap that previously would have stayed resident. This was accidentally fixed in commit [b95a2f2d: mm: vmscan: convert global reclaim to per-memcg LRU lists] by making it harder for kswapd to force scan small targets but that patchset is not suitable for backporting. This was later changed again by commit [90126375: mm/vmscan: push lruvec pointer into get_scan_count()] into a format that looks like it would be a straight-forward backport but there is a subtle difference due to the use of lruvecs. The impact of the accidental fix is to make it harder for kswapd to force scan small targets by taking zone->all_unreclaimable into account. This patch is the closest equivalent available based on what is backported. Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: test PageSwapBacked in lumpy reclaimHugh Dickins
commit 043bcbe5ec51e0478ef2b44acef17193e01d7f70 upstream. Stable note: Not tracked in Bugzilla. There were reports of shared mapped pages being unfairly reclaimed in comparison to older kernels. This is being addressed over time. Even though the subject refers to lumpy reclaim, it impacts compaction as well. Lumpy reclaim does well to stop at a PageAnon when there's no swap, but better is to stop at any PageSwapBacked, which includes shmem/tmpfs too. Signed-off-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-08-01mm/vmscan.c: consider swap space when deciding whether to continue reclaimMinchan Kim
commit 86cfd3a45042ab242d47f3935a02811a402beab6 upstream. Stable note: Not tracked in Bugzilla. This patch reduces kswapd CPU usage on swapless systems with high anonymous memory usage. It's pointless to continue reclaiming when we have no swap space and lots of anon pages in the inactive list. Without this patch, it is possible when swap is disabled to continue trying to reclaim when there are only anonymous pages in the system even though that will not make any progress. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: activate executable pages after first usageKonstantin Khlebnikov
commit c909e99364c8b6ca07864d752950b6b4ecf6bef4 upstream. Stable note: Not tracked in Bugzilla. There were reports of shared mapped pages being unfairly reclaimed in comparison to older kernels. This is being addressed over time. Logic added in commit 8cab4754d24a0 ("vmscan: make mapped executable pages the first class citizen") was noticeably weakened in commit 645747462435d84 ("vmscan: detect mapped file pages used only once"). Currently these pages can become "first class citizens" only after second usage. After this patch page_check_references() will activate they after first usage, and executable code gets yet better chance to stay in memory. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: promote shared file mapped pagesKonstantin Khlebnikov
commit 34dbc67a644f11ab3475d822d72e25409911e760 upstream. Stable note: Not tracked in Bugzilla. There were reports of shared mapped pages being unfairly reclaimed in comparison to older kernels. This is being addressed over time. The specific workload being addressed here in described in paragraph four and while paragraph five says it did not help performance as such, it made a difference to major page faults. I'm aware of at least one bug for a large vendor that was due to increased major faults. Commit 645747462435 ("vmscan: detect mapped file pages used only once") greatly decreases lifetime of single-used mapped file pages. Unfortunately it also decreases life time of all shared mapped file pages. Because after commit bf3f3bc5e7347 ("mm: don't mark_page_accessed in fault path") page-fault handler does not mark page active or even referenced. Thus page_check_references() activates file page only if it was used twice while it stays in inactive list, meanwhile it activates anon pages after first access. Inactive list can be small enough, this way reclaimer can accidentally throw away any widely used page if it wasn't used twice in short period. After this patch page_check_references() also activate file mapped page at first inactive list scan if this page is already used multiple times via several ptes. I found this while trying to fix degragation in rhel6 (~2.6.32) from rhel5 (~2.6.18). There a complete mess with >100 web/mail/spam/ftp containers, they share all their files but there a lot of anonymous pages: ~500mb shared file mapped memory and 15-20Gb non-shared anonymous memory. In this situation major-pagefaults are very costly, because all containers share the same page. In my load kernel created a disproportionate pressure on the file memory, compared with the anonymous, they equaled only if I raise swappiness up to 150 =) These patches actually wasn't helped a lot in my problem, but I saw noticable (10-20 times) reduce in count and average time of major-pagefault in file-mapped areas. Actually both patches are fixes for commit v2.6.33-5448-g6457474, because it was aimed at one scenario (singly used pages), but it breaks the logic in other scenarios (shared and/or executable pages) Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Shaohua Li <shaohua.li@intel.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-08-01mm: vmscan: check if reclaim should really abort even if compaction_ready() ↵Mel Gorman
is true for one zone commit 0cee34fd72c582b4f8ad8ce00645b75fb4168199 upstream. Stable note: Not tracked on Bugzilla. THP and compaction was found to aggressively reclaim pages and stall systems under different situations that was addressed piecemeal over time. If compaction can proceed for a given zone, shrink_zones() does not reclaim any more pages from it. After commit [e0c2327: vmscan: abort reclaim/compaction if compaction can proceed], do_try_to_free_pages() tries to finish as soon as possible once one zone can compact. This was intended to prevent slabs being shrunk unnecessarily but there are side-effects. One is that a small zone that is ready for compaction will abort reclaim even if the chances of successfully allocating a THP from that zone is small. It also means that reclaim can return too early even though sc->nr_to_reclaim pages were not reclaimed. This partially reverts the commit until it is proven that slabs are really being shrunk unnecessarily but preserves the check to return 1 to avoid OOM if reclaim was aborted prematurely. [aarcange@redhat.com: This patch replaces a revert from Andrea] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: vmscan: do not OOM if aborting reclaim to start compactionMel Gorman
commit 7335084d446b83cbcb15da80497d03f0c1dc9e21 upstream. Stable note: Not tracked in Bugzilla. This patch makes later patches easier to apply but otherwise has little to justify it. The problem it fixes was never observed but the source of the theoretical problem did not exist for very long. During direct reclaim it is possible that reclaim will be aborted so that compaction can be attempted to satisfy a high-order allocation. If this decision is made before any pages are reclaimed, it is possible that 0 is returned to the page allocator potentially triggering an OOM. This has not been observed but it is a possibility so this patch addresses it. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: vmscan: when reclaiming for compaction, ensure there are sufficient free ↵Mel Gorman
pages available commit fe4b1b244bdb96136855f2c694071cb09d140766 upstream. Stable note: Not tracked on Bugzilla. THP and compaction was found to aggressively reclaim pages and stall systems under different situations that was addressed piecemeal over time. This patch addresses a problem where the fix regressed THP allocation success rates. In commit e0887c19 ("vmscan: limit direct reclaim for higher order allocations"), Rik noted that reclaim was too aggressive when THP was enabled. In his initial patch he used the number of free pages to decide if reclaim should abort for compaction. My feedback was that reclaim and compaction should be using the same logic when deciding if reclaim should be aborted. Unfortunately, this had the effect of reducing THP success rates when the workload included something like streaming reads that continually allocated pages. The window during which compaction could run and return a THP was too small. This patch combines Rik's two patches together. compaction_suitable() is still used to decide if reclaim should be aborted to allow compaction is used. However, it will also ensure that there is a reasonable buffer of free pages available. This improves upon the THP allocation success rates but bounds the number of pages that are freed for compaction. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel<riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: compaction: introduce sync-light migration for use by compactionMel Gorman
commit a6bc32b899223a877f595ef9ddc1e89ead5072b8 upstream. Stable note: Not tracked in Buzilla. This was part of a series that reduced interactivity stalls experienced when THP was enabled. These stalls were particularly noticable when copying data to a USB stick but the experiences for users varied a lot. This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT mode that avoids writing back pages to backing storage. Async compaction maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT. For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is used. This avoids sync compaction stalling for an excessive length of time, particularly when copying files to a USB stick where there might be a large number of dirty pages backed by a filesystem that does not support ->writepages. [aarcange@redhat.com: This patch is heavily based on Andrea's work] [akpm@linux-foundation.org: fix fs/nfs/write.c build] [akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01kswapd: assign new_order and new_classzone_idx after wakeup in sleepingAlex Shi
commit f0dfcde099453aa4c0dc42473828d15a6d492936 upstream. Stable note: Fixes https://bugzilla.redhat.com/show_bug.cgi?id=712019. This patch reduces kswapd CPU usage. There 2 places to read pgdat in kswapd. One is return from a successful balance, another is waked up from kswapd sleeping. The new_order and new_classzone_idx represent the balance input order and classzone_idx. But current new_order and new_classzone_idx are not assigned after kswapd_try_to_sleep(), that will cause a bug in the following scenario. 1: after a successful balance, kswapd goes to sleep, and new_order = 0; new_classzone_idx = __MAX_NR_ZONES - 1; 2: kswapd waked up with order = 3 and classzone_idx = ZONE_NORMAL 3: in the balance_pgdat() running, a new balance wakeup happened with order = 5, and classzone_idx = ZONE_NORMAL 4: the first wakeup(order = 3) finished successufly, return order = 3 but, the new_order is still 0, so, this balancing will be treated as a failed balance. And then the second tighter balancing will be missed. So, to avoid the above problem, the new_order and new_classzone_idx need to be assigned for later successful comparison. Signed-off-by: Alex Shi <alex.shi@intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Tested-by: Pádraig Brady <P@draigBrady.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01kswapd: avoid unnecessary rebalance after an unsuccessful balancingAlex Shi
commit d2ebd0f6b89567eb93ead4e2ca0cbe03021f344b upstream. Stable note: Fixes https://bugzilla.redhat.com/show_bug.cgi?id=712019. This patch reduces kswapd CPU usage. In commit 215ddd66 ("mm: vmscan: only read new_classzone_idx from pgdat when reclaiming successfully") , Mel Gorman said kswapd is better to sleep after a unsuccessful balancing if there is tighter reclaim request pending in the balancing. But in the following scenario, kswapd do something that is not matched our expectation. The patch fixes this issue. 1, Read pgdat request A (classzone_idx, order = 3) 2, balance_pgdat() 3, During pgdat, a new pgdat request B (classzone_idx, order = 5) is placed 4, balance_pgdat() returns but failed since returned order = 0 5, pgdat of request A assigned to balance_pgdat(), and do balancing again. While the expectation behavior of kswapd should try to sleep. Signed-off-by: Alex Shi <alex.shi@intel.com> Reviewed-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Mel Gorman <mgorman@suse.de> Tested-by: Pádraig Brady <P@draigBrady.com> Cc: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: compaction: make isolate_lru_page() filter-aware againMel Gorman
commit c82449352854ff09e43062246af86bdeb628f0c3 upstream. Stable note: Not tracked in Bugzilla. A fix aimed at preserving page aging information by reducing LRU list churning had the side-effect of reducing THP allocation success rates. This was part of a series to restore the success rates while preserving the reclaim fix. Commit 39deaf85 ("mm: compaction: make isolate_lru_page() filter-aware") noted that compaction does not migrate dirty or writeback pages and that is was meaningless to pick the page and re-add it to the LRU list. This had to be partially reverted because some dirty pages can be migrated by compaction without blocking. This patch updates "mm: compaction: make isolate_lru_page" by skipping over pages that migration has no possibility of migrating to minimise LRU disruption. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel<riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: page allocator: do not call direct reclaim for THP allocations while ↵Mel Gorman
compaction is deferred commit 66199712e9eef5aede09dbcd9dfff87798a66917 upstream. Stable note: Not tracked in Buzilla. This was part of a series that reduced interactivity stalls experienced when THP was enabled. If compaction is deferred, direct reclaim is used to try to free enough pages for the allocation to succeed. For small high-orders, this has a reasonable chance of success. However, if the caller has specified __GFP_NO_KSWAPD to limit the disruption to the system, it makes more sense to fail the allocation rather than stall the caller in direct reclaim. This patch skips direct reclaim if compaction is deferred and the caller specifies __GFP_NO_KSWAPD. Async compaction only considers a subset of pages so it is possible for compaction to be deferred prematurely and not enter direct reclaim even in cases where it should. To compensate for this, this patch also defers compaction only if sync compaction failed. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Rik van Riel<riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: compaction: determine if dirty pages can be migrated without blocking ↵Mel Gorman
within ->migratepage commit b969c4ab9f182a6e1b2a0848be349f99714947b0 upstream. Stable note: Not tracked in Bugzilla. A fix aimed at preserving page aging information by reducing LRU list churning had the side-effect of reducing THP allocation success rates. This was part of a series to restore the success rates while preserving the reclaim fix. Asynchronous compaction is used when allocating transparent hugepages to avoid blocking for long periods of time. Due to reports of stalling, there was a debate on disabling synchronous compaction but this severely impacted allocation success rates. Part of the reason was that many dirty pages are skipped in asynchronous compaction by the following check; if (PageDirty(page) && !sync && mapping->a_ops->migratepage != migrate_page) rc = -EBUSY; This skips over all mapping aops using buffer_migrate_page() even though it is possible to migrate some of these pages without blocking. This patch updates the ->migratepage callback with a "sync" parameter. It is the responsibility of the callback to fail gracefully if migration would block. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: compaction: allow compaction to isolate dirty pagesMel Gorman
commit a77ebd333cd810d7b680d544be88c875131c2bd3 upstream. Stable note: Not tracked in Bugzilla. A fix aimed at preserving page aging information by reducing LRU list churning had the side-effect of reducing THP allocation success rates. This was part of a series to restore the success rates while preserving the reclaim fix. Short summary: There are severe stalls when a USB stick using VFAT is used with THP enabled that are reduced by this series. If you are experiencing this problem, please test and report back and considering I have seen complaints from openSUSE and Fedora users on this as well as a few private mails, I'm guessing it's a widespread issue. This is a new type of USB-related stall because it is due to synchronous compaction writing where as in the past the big problem was dirty pages reaching the end of the LRU and being written by reclaim. Am cc'ing Andrew this time and this series would replace mm-do-not-stall-in-synchronous-compaction-for-thp-allocations.patch. I'm also cc'ing Dave Jones as he might have merged that patch to Fedora for wider testing and ideally it would be reverted and replaced by this series. That said, the later patches could really do with some review. If this series is not the answer then a new direction needs to be discussed because as it is, the stalls are unacceptable as the results in this leader show. For testers that try backporting this to 3.1, it won't work because there is a non-obvious dependency on not writing back pages in direct reclaim so you need those patches too. Changelog since V5 o Rebase to 3.2-rc5 o Tidy up the changelogs a bit Changelog since V4 o Added reviewed-bys, credited Andrea properly for sync-light o Allow dirty pages without mappings to be considered for migration o Bound the number of pages freed for compaction o Isolate PageReclaim pages on their own LRU list This is against 3.2-rc5 and follows on from discussions on "mm: Do not stall in synchronous compaction for THP allocations" and "[RFC PATCH 0/5] Reduce compaction-related stalls". Initially, the proposed patch eliminated stalls due to compaction which sometimes resulted in user-visible interactivity problems on browsers by simply never using sync compaction. The downside was that THP success allocation rates were lower because dirty pages were not being migrated as reported by Andrea. His approach at fixing this was nacked on the grounds that it reverted fixes from Rik merged that reduced the amount of pages reclaimed as it severely impacted his workloads performance. This series attempts to reconcile the requirements of maximising THP usage, without stalling in a user-visible fashion due to compaction or cheating by reclaiming an excessive number of pages. Patch 1 partially reverts commit 39deaf85 to allow migration to isolate dirty pages. This is because migration can move some dirty pages without blocking. Patch 2 notes that the /proc/sys/vm/compact_memory handler is not using synchronous compaction when it should be. This is unrelated to the reported stalls but is worth fixing. Patch 3 checks if we isolated a compound page during lumpy scan and account for it properly. For the most part, this affects tracing so it's unrelated to the stalls but worth fixing. Patch 4 notes that it is possible to abort reclaim early for compaction and return 0 to the page allocator potentially entering the "may oom" path. This has not been observed in practice but the rest of the series potentially makes it easier to happen. Patch 5 adds a sync parameter to the migratepage callback and gives the callback responsibility for migrating the page without blocking if sync==false. For example, fallback_migrate_page will not call writepage if sync==false. This increases the number of pages that can be handled by asynchronous compaction thereby reducing stalls. Patch 6 restores filter-awareness to isolate_lru_page for migration. In practice, it means that pages under writeback and pages without a ->migratepage callback will not be isolated for migration. Patch 7 avoids calling direct reclaim if compaction is deferred but makes sure that compaction is only deferred if sync compaction was used. Patch 8 introduces a sync-light migration mechanism that sync compaction uses. The objective is to allow some stalls but to not call ->writepage which can lead to significant user-visible stalls. Patch 9 notes that while we want to abort reclaim ASAP to allow compation to go ahead that we leave a very small window of opportunity for compaction to run. This patch allows more pages to be freed by reclaim but bounds the number to a reasonable level based on the high watermark on each zone. Patch 10 allows slabs to be shrunk even after compaction_ready() is true for one zone. This is to avoid a problem whereby a single small zone can abort reclaim even though no pages have been reclaimed and no suitably large zone is in a usable state. Patch 11 fixes a problem with the rate of page scanning. As reclaim is rarely stalling on pages under writeback it means that scan rates are very high. This is particularly true for direct reclaim which is not calling writepage. The vmstat figures implied that much of this was busy work with PageReclaim pages marked for immediate reclaim. This patch is a prototype that moves these pages to their own LRU list. This has been tested and other than 2 USB keys getting trashed, nothing horrible fell out. That said, I am a bit unhappy with the rescue logic in patch 11 but did not find a better way around it. It does significantly reduce scan rates and System CPU time indicating it is the right direction to take. What is of critical importance is that stalls due to compaction are massively reduced even though sync compaction was still allowed. Testing from people complaining about stalls copying to USBs with THP enabled are particularly welcome. The following tests all involve THP usage and USB keys in some way. Each test follows this type of pattern 1. Read from some fast fast storage, be it raw device or file. Each time the copy finishes, start again until the test ends 2. Write a large file to a filesystem on a USB stick. Each time the copy finishes, start again until the test ends 3. When memory is low, start an alloc process that creates a mapping the size of physical memory to stress THP allocation. This is the "real" part of the test and the part that is meant to trigger stalls when THP is enabled. Copying continues in the background. 4. Record the CPU usage and time to execute of the alloc process 5. Record the number of THP allocs and fallbacks as well as the number of THP pages in use a the end of the test just before alloc exited 6. Run the test 5 times to get an idea of variability 7. Between each run, sync is run and caches dropped and the test waits until nr_dirty is a small number to avoid interference or caching between iterations that would skew the figures. The individual tests were then writebackCPDeviceBasevfat Disable THP, read from a raw device (sda), vfat on USB stick writebackCPDeviceBaseext4 Disable THP, read from a raw device (sda), ext4 on USB stick writebackCPDevicevfat THP enabled, read from a raw device (sda), vfat on USB stick writebackCPDeviceext4 THP enabled, read from a raw device (sda), ext4 on USB stick writebackCPFilevfat THP enabled, read from a file on fast storage and USB, both vfat writebackCPFileext4 THP enabled, read from a file on fast storage and USB, both ext4 The kernels tested were 3.1 3.1 vanilla 3.2-rc5 freemore Patches 1-10 immediate Patches 1-11 andrea The 8 patches Andrea posted as a basis of comparison The results are very long unfortunately. I'll start with the case where we are not using THP at all writebackCPDeviceBasevfat 3.1.0-vanilla rc5-vanilla freemore-v6r1 isolate-v6r1 andrea-v2r1 System Time 1.28 ( 0.00%) 54.49 (-4143.46%) 48.63 (-3687.69%) 4.69 ( -265.11%) 51.88 (-3940.81%) +/- 0.06 ( 0.00%) 2.45 (-4305.55%) 4.75 (-8430.57%) 7.46 (-13282.76%) 4.76 (-8440.70%) User Time 0.09 ( 0.00%) 0.05 ( 40.91%) 0.06 ( 29.55%) 0.07 ( 15.91%) 0.06 ( 27.27%) +/- 0.02 ( 0.00%) 0.01 ( 45.39%) 0.02 ( 25.07%) 0.00 ( 77.06%) 0.01 ( 52.24%) Elapsed Time 110.27 ( 0.00%) 56.38 ( 48.87%) 49.95 ( 54.70%) 11.77 ( 89.33%) 53.43 ( 51.54%) +/- 7.33 ( 0.00%) 3.77 ( 48.61%) 4.94 ( 32.63%) 6.71 ( 8.50%) 4.76 ( 35.03%) THP Active 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) +/- 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) Fault Alloc 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) +/- 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) Fault Fallback 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) +/- 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) 0.00 ( 0.00%) The THP figures are obviously all 0 because THP was enabled. The main thing to watch is the elapsed times and how they compare to times when THP is enabled later. It's also important to note that elapsed time is improved by this series as System CPu time is much reduced. writebackCPDevicevfat 3.1.0-vanilla rc5-vanilla freemore-v6r1 isolate-v6r1 andrea-v2r1 System Time 1.22 ( 0.00%) 13.89 (-1040.72%) 46.40 (-3709.20%) 4.44 ( -264.37%) 47.37 (-3789.33%) +/- 0.06 ( 0.00%) 22.82 (-37635.56%) 3.84 (-6249.44%) 6.48 (-10618.92%) 6.60 (-10818.53%) User Time 0.06 ( 0.00%) 0.06 ( -6.90%) 0.05 ( 17.24%) 0.05 ( 13.79%) 0.04 ( 31.03%) +/- 0.01 ( 0.00%) 0.01 ( 33.33%) 0.01 ( 33.33%) 0.01 ( 39.14%) 0.01 ( 25.46%) Elapsed Time 10445.54 ( 0.00%) 2249.92 ( 78.46%) 70.06 ( 99.33%) 16.59 ( 99.84%) 472.43 ( 95.48%) +/- 643.98 ( 0.00%) 811.62 ( -26.03%) 10.02 ( 98.44%) 7.03 ( 98.91%) 59.99 ( 90.68%) THP Active 15.60 ( 0.00%) 35.20 ( 225.64%) 65.00 ( 416.67%) 70.80 ( 453.85%) 62.20 ( 398.72%) +/- 18.48 ( 0.00%) 51.29 ( 277.59%) 15.99 ( 86.52%) 37.91 ( 205.18%) 22.02 ( 119.18%) Fault Alloc 121.80 ( 0.00%) 76.60 ( 62.89%) 155.40 ( 127.59%) 181.20 ( 148.77%) 286.60 ( 235.30%) +/- 73.51 ( 0.00%) 61.11 ( 83.12%) 34.89 ( 47.46%) 31.88 ( 43.36%) 68.13 ( 92.68%) Fault Fallback 881.20 ( 0.00%) 926.60 ( -5.15%) 847.60 ( 3.81%) 822.00 ( 6.72%) 716.60 ( 18.68%) +/- 73.51 ( 0.00%) 61.26 ( 16.67%) 34.89 ( 52.54%) 31.65 ( 56.94%) 67.75 ( 7.84%) MMTests Statistics: duration User/Sys Time Running Test (seconds) 3540.88 1945.37 716.04 64.97 1937.03 Total Elapsed Time (seconds) 52417.33 11425.90 501.02 230.95 2520.28 The first thing to note is the "Elapsed Time" for the vanilla kernels of 2249 seconds versus 56 with THP disabled which might explain the reports of USB stalls with THP enabled. Applying the patches brings performance in line with THP-disabled performance while isolating pages for immediate reclaim from the LRU cuts down System CPU time. The "Fault Alloc" success rate figures are also improved. The vanilla kernel only managed to allocate 76.6 pages on average over the course of 5 iterations where as applying the series allocated 181.20 on average albeit it is well within variance. It's worth noting that applies the series at least descreases the amount of variance which implies an improvement. Andrea's series had a higher success rate for THP allocations but at a severe cost to elapsed time which is still better than vanilla but still much worse than disabling THP altogether. One can bring my series close to Andrea's by removing this check /* * If compaction is deferred for high-order allocations, it is because * sync compaction recently failed. In this is the case and the caller * has requested the system not be heavily disrupted, fail the * allocation now instead of entering direct reclaim */ if (deferred_compaction && (gfp_mask & __GFP_NO_KSWAPD)) goto nopage; I didn't include a patch that removed the above check because hurting overall performance to improve the THP figure is not what the average user wants. It's something to consider though if someone really wants to maximise THP usage no matter what it does to the workload initially. This is summary of vmstat figures from the same test. 3.1.0-vanilla rc5-vanilla freemore-v6r1 isolate-v6r1 andrea-v2r1 Page Ins 3257266139 1111844061 17263623 10901575 161423219 Page Outs 81054922 30364312 3626530 3657687 8753730 Swap Ins 3294 2851 6560 4964 4592 Swap Outs 390073 528094 620197 790912 698285 Direct pages scanned 1077581700 3024951463 1764930052 115140570 5901188831 Kswapd pages scanned 34826043 7112868 2131265 1686942 1893966 Kswapd pages reclaimed 28950067 4911036 1246044 966475 1497726 Direct pages reclaimed 805148398 280167837 3623473 2215044 40809360 Kswapd efficiency 83% 69% 58% 57% 79% Kswapd velocity 664.399 622.521 4253.852 7304.360 751.490 Direct efficiency 74% 9% 0% 1% 0% Direct velocity 20557.737 264745.137 3522673.849 498551.938 2341481.435 Percentage direct scans 96% 99% 99% 98% 99% Page writes by reclaim 722646 529174 620319 791018 699198 Page writes file 332573 1080 122 106 913 Page writes anon 390073 528094 620197 790912 698285 Page reclaim immediate 0 2552514720 1635858848 111281140 5478375032 Page rescued immediate 0 0 0 87848 0 Slabs scanned 23552 23552 9216 8192 9216 Direct inode steals 231 0 0 0 0 Kswapd inode steals 0 0 0 0 0 Kswapd skipped wait 28076 786 0 61 6 THP fault alloc 609 383 753 906 1433 THP collapse alloc 12 6 0 0 6 THP splits 536 211 456 593 1136 THP fault fallback 4406 4633 4263 4110 3583 THP collapse fail 120 127 0 0 4 Compaction stalls 1810 728 623 779 3200 Compaction success 196 53 60 80 123 Compaction failures 1614 675 563 699 3077 Compaction pages moved 193158 53545 243185 333457 226688 Compaction move failure 9952 9396 16424 23676 45070 The main things to look at are 1. Page In/out figures are much reduced by the series. 2. Direct page scanning is incredibly high (264745.137 pages scanned per second on the vanilla kernel) but isolating PageReclaim pages on their own list reduces the number of pages scanned significantly. 3. The fact that "Page rescued immediate" is a positive number implies that we sometimes race removing pages from the LRU_IMMEDIATE list that need to be put back on a normal LRU but it happens only for 0.07% of the pages marked for immediate reclaim. writebackCPDeviceext4 3.1.0-vanilla rc5-vanilla freemore-v6r1 isolate-v6r1 andrea-v2r1 System Time 1.51 ( 0.00%) 1.77 ( -17.66%) 1.46 ( 2.92%) 1.15 ( 23.77%) 1.89 ( -25.63%) +/- 0.27 ( 0.00%) 0.67 ( -148.52%) 0.33 ( -22.76%) 0.30 ( -11.15%) 0.19 ( 30.16%) User Time 0.03 ( 0.00%) 0.04 ( -37.50%) 0.05 ( -62.50%) 0.07 ( -112.50%) 0.04 ( -18.75%) +/- 0.01 ( 0.00%) 0.02 ( -146.64%) 0.02 ( -97.91%) 0.02 ( -75.59%) 0.02 ( -63.30%) Elapsed Time 124.93 ( 0.00%) 114.49 ( 8.36%) 96.77 ( 22.55%) 27.48 ( 78.00%) 205.70 ( -64.65%) +/- 20.20 ( 0.00%) 74.39 ( -268.34%) 59.88 ( -196.48%) 7.72 ( 61.79%) 25.03 ( -23.95%) THP Active 161.80 ( 0.00%) 83.60 ( 51.67%) 141.20 ( 87.27%) 84.60 ( 52.29%) 82.60 ( 51.05%) +/- 71.95 ( 0.00%) 43.80 ( 60.88%) 26.91 ( 37.40%) 59.02 ( 82.03%) 52.13 ( 72.45%) Fault Alloc 471.40 ( 0.00%) 228.60 ( 48.49%) 282.20 ( 59.86%) 225.20 ( 47.77%) 388.40 ( 82.39%) +/- 88.07 ( 0.00%) 87.42 ( 99.26%) 73.79 ( 83.78%) 109.62 ( 124.47%) 82.62 ( 93.81%) Fault Fallback 531.60 ( 0.00%) 774.60 ( -45.71%) 720.80 ( -35.59%) 777.80 ( -46.31%) 614.80 ( -15.65%) +/- 88.07 ( 0.00%) 87.26 ( 0.92%) 73.79 ( 16.22%) 109.62 ( -24.47%) 82.29 ( 6.56%) MMTests Statistics: duration User/Sys Time Running Test (seconds) 50.22 33.76 30.65 24.14 128.45 Total Elapsed Time (seconds) 1113.73 1132.19 1029.45 759.49 1707.26 Similar test but the USB stick is using ext4 instead of vfat. As ext4 does not use writepage for migration, the large stalls due to compaction when THP is enabled are not observed. Still, isolating PageReclaim pages on their own list helped completion time largely by reducing the number of pages scanned by direct reclaim although time spend in congestion_wait could also be a factor. Again, Andrea's series had far higher success rates for THP allocation at the cost of elapsed time. I didn't look too closely but a quick look at the vmstat figures tells me kswapd reclaimed 8 times more pages than the patch series and direct reclaim reclaimed roughly three times as many pages. It follows that if memory is aggressively reclaimed, there will be more available for THP. writebackCPFilevfat 3.1.0-vanilla rc5-vanilla freemore-v6r1 isolate-v6r1 andrea-v2r1 System Time 1.76 ( 0.00%) 29.10 (-1555.52%) 46.01 (-2517.18%) 4.79 ( -172.35%) 54.89 (-3022.53%) +/- 0.14 ( 0.00%) 25.61 (-18185.17%) 2.15 (-1434.83%) 6.60 (-4610.03%) 9.75 (-6863.76%) User Time 0.05 ( 0.00%) 0.07 ( -45.83%) 0.05 ( -4.17%) 0.06 ( -29.17%) 0.06 ( -16.67%) +/- 0.02 ( 0.00%) 0.02 ( 20.11%) 0.02 ( -3.14%) 0.01 ( 31.58%) 0.01 ( 47.41%) Elapsed Time 22520.79 ( 0.00%) 1082.85 ( 95.19%) 73.30 ( 99.67%) 32.43 ( 99.86%) 291.84 ( 98.70%) +/- 7277.23 ( 0.00%) 706.29 ( 90.29%) 19.05 ( 99.74%) 17.05 ( 99.77%) 125.55 ( 98.27%) THP Active 83.80 ( 0.00%) 12.80 ( 15.27%) 15.60 ( 18.62%) 13.00 ( 15.51%) 0.80 ( 0.95%) +/- 66.81 ( 0.00%) 20.19 ( 30.22%) 5.92 ( 8.86%) 15.06 ( 22.54%) 1.17 ( 1.75%) Fault Alloc 171.00 ( 0.00%) 67.80 ( 39.65%) 97.40 ( 56.96%) 125.60 ( 73.45%) 133.00 ( 77.78%) +/- 82.91 ( 0.00%) 30.69 ( 37.02%) 53.91 ( 65.02%) 55.05 ( 66.40%) 21.19 ( 25.56%) Fault Fallback 832.00 ( 0.00%) 935.20 ( -12.40%) 906.00 ( -8.89%) 877.40 ( -5.46%) 870.20 ( -4.59%) +/- 82.91 ( 0.00%) 30.69 ( 62.98%) 54.01 ( 34.86%) 55.05 ( 33.60%) 20.91 ( 74.78%) MMTests Statistics: duration User/Sys Time Running Test (seconds) 7229.81 928.42 704.52 80.68 1330.76 Total Elapsed Time (seconds) 112849.04 5618.69 571.11 360.54 1664.28 In this case, the test is reading/writing only from filesystems but as it's vfat, it's slow due to calling writepage during compaction. Little to observe really - the time to complete the test goes way down with the series applied and THP allocation success rates go up in comparison to 3.2-rc5. The success rates are lower than 3.1.0 but the elapsed time for that kernel is abysmal so it is not really a sensible comparison. As before, Andrea's series allocates more THPs at the cost of overall performance. writebackCPFileext4 3.1.0-vanilla rc5-vanilla freemore-v6r1 isolate-v6r1 andrea-v2r1 System Time 1.51 ( 0.00%) 1.77 ( -17.66%) 1.46 ( 2.92%) 1.15 ( 23.77%) 1.89 ( -25.63%) +/- 0.27 ( 0.00%) 0.67 ( -148.52%) 0.33 ( -22.76%) 0.30 ( -11.15%) 0.19 ( 30.16%) User Time 0.03 ( 0.00%) 0.04 ( -37.50%) 0.05 ( -62.50%) 0.07 ( -112.50%) 0.04 ( -18.75%) +/- 0.01 ( 0.00%) 0.02 ( -146.64%) 0.02 ( -97.91%) 0.02 ( -75.59%) 0.02 ( -63.30%) Elapsed Time 124.93 ( 0.00%) 114.49 ( 8.36%) 96.77 ( 22.55%) 27.48 ( 78.00%) 205.70 ( -64.65%) +/- 20.20 ( 0.00%) 74.39 ( -268.34%) 59.88 ( -196.48%) 7.72 ( 61.79%) 25.03 ( -23.95%) THP Active 161.80 ( 0.00%) 83.60 ( 51.67%) 141.20 ( 87.27%) 84.60 ( 52.29%) 82.60 ( 51.05%) +/- 71.95 ( 0.00%) 43.80 ( 60.88%) 26.91 ( 37.40%) 59.02 ( 82.03%) 52.13 ( 72.45%) Fault Alloc 471.40 ( 0.00%) 228.60 ( 48.49%) 282.20 ( 59.86%) 225.20 ( 47.77%) 388.40 ( 82.39%) +/- 88.07 ( 0.00%) 87.42 ( 99.26%) 73.79 ( 83.78%) 109.62 ( 124.47%) 82.62 ( 93.81%) Fault Fallback 531.60 ( 0.00%) 774.60 ( -45.71%) 720.80 ( -35.59%) 777.80 ( -46.31%) 614.80 ( -15.65%) +/- 88.07 ( 0.00%) 87.26 ( 0.92%) 73.79 ( 16.22%) 109.62 ( -24.47%) 82.29 ( 6.56%) MMTests Statistics: duration User/Sys Time Running Test (seconds) 50.22 33.76 30.65 24.14 128.45 Total Elapsed Time (seconds) 1113.73 1132.19 1029.45 759.49 1707.26 Same type of story - elapsed times go down. In this case, allocation success rates are roughtly the same. As before, Andrea's has higher success rates but takes a lot longer. Overall the series does reduce latencies and while the tests are inherency racy as alloc competes with the cp processes, the variability was included. The THP allocation rates are not as high as they could be but that is because we would have to be more aggressive about reclaim and compaction impacting overall performance. This patch: Commit 39deaf85 ("mm: compaction: make isolate_lru_page() filter-aware") noted that compaction does not migrate dirty or writeback pages and that is was meaningless to pick the page and re-add it to the LRU list. What was missed during review is that asynchronous migration moves dirty pages if their ->migratepage callback is migrate_page() because these can be moved without blocking. This potentially impacted hugepage allocation success rates by a factor depending on how many dirty pages are in the system. This patch partially reverts 39deaf85 to allow migration to isolate dirty pages again. This increases how much compaction disrupts the LRU but that is addressed later in the series. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: migration: clean up unmap_and_move()Minchan Kim
commit 0dabec93de633a87adfbbe1d800a4c56cd19d73b upstream. Stable note: Not tracked in Bugzilla. This patch makes later patches easier to apply but has no other impact. unmap_and_move() is one a big messy function. Clean it up. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: zone_reclaim: make isolate_lru_page() filter-awareMinchan Kim
commit f80c0673610e36ae29d63e3297175e22f70dde5f upstream. Stable note: Not tracked in Bugzilla. THP and compaction disrupt the LRU list leading to poor reclaim decisions which has a variable performance impact. In __zone_reclaim case, we don't want to shrink mapped page. Nonetheless, we have isolated mapped page and re-add it into LRU's head. It's unnecessary CPU overhead and makes LRU churning. Of course, when we isolate the page, the page might be mapped but when we try to migrate the page, the page would be not mapped. So it could be migrated. But race is rare and although it happens, it's no big deal. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: compaction: make isolate_lru_page() filter-awareMinchan Kim
commit 39deaf8585152f1a35c1676d3d7dc6ae0fb65967 upstream. Stable note: Not tracked in Bugzilla. THP and compaction disrupt the LRU list leading to poor reclaim decisions which has a variable performance impact. In async mode, compaction doesn't migrate dirty or writeback pages. So, it's meaningless to pick the page and re-add it to lru list. Of course, when we isolate the page in compaction, the page might be dirty or writeback but when we try to migrate the page, the page would be not dirty, writeback. So it could be migrated. But it's very unlikely as isolate and migration cycle is much faster than writeout. So, this patch helps cpu overhead and prevent unnecessary LRU churning. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: change isolate mode from #define to bitwise typeMinchan Kim
commit 4356f21d09283dc6d39a6f7287a65ddab61e2808 upstream. Stable note: Not tracked in Bugzilla. This patch makes later patches easier to apply but has no other impact. Change ISOLATE_XXX macro with bitwise isolate_mode_t type. Normally, macro isn't recommended as it's type-unsafe and making debugging harder as symbol cannot be passed throught to the debugger. Quote from Johannes " Hmm, it would probably be cleaner to fully convert the isolation mode into independent flags. INACTIVE, ACTIVE, BOTH is currently a tri-state among flags, which is a bit ugly." This patch moves isolate mode from swap.h to mmzone.h by memcontrol.h Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01mm: compaction: trivial clean up in acct_isolated()Minchan Kim
commit b9e84ac1536d35aee03b2601f19694949f0bd506 upstream. Stable note: Not tracked in Bugzilla. This patch makes later patches easier to apply but has no other impact. acct_isolated of compaction uses page_lru_base_type which returns only base type of LRU list so it never returns LRU_ACTIVE_ANON or LRU_ACTIVE_FILE. In addtion, cc->nr_[anon|file] is used in only acct_isolated so it doesn't have fields in conpact_control. This patch removes fields from compact_control and makes clear function of acct_issolated which counts the number of anon|file pages isolated. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: abort reclaim/compaction if compaction can proceedMel Gorman
commit e0c23279c9f800c403f37511484d9014ac83adec upstream. Stable note: Not tracked on Bugzilla. THP and compaction was found to aggressively reclaim pages and stall systems under different situations that was addressed piecemeal over time. If compaction can proceed, shrink_zones() stops doing any work but its callers still call shrink_slab() which raises the priority and potentially sleeps. This is unnecessary and wasteful so this patch aborts direct reclaim/compaction entirely if compaction can proceed. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: limit direct reclaim for higher order allocationsRik van Riel
commit e0887c19b2daa140f20ca8104bdc5740f39dbb86 upstream. Stable note: Not tracked on Bugzilla. THP and compaction was found to aggressively reclaim pages and stall systems under different situations that was addressed piecemeal over time. Paragraph 3 of this changelog is the motivation for this patch. When suffering from memory fragmentation due to unfreeable pages, THP page faults will repeatedly try to compact memory. Due to the unfreeable pages, compaction fails. Needless to say, at that point page reclaim also fails to create free contiguous 2MB areas. However, that doesn't stop the current code from trying, over and over again, and freeing a minimum of 4MB (2UL << sc->order pages) at every single invocation. This resulted in my 12GB system having 2-3GB free memory, a corresponding amount of used swap and very sluggish response times. This can be avoided by having the direct reclaim code not reclaim from zones that already have plenty of free memory available for compaction. If compaction still fails due to unmovable memory, doing additional reclaim will only hurt the system, not help. [jweiner@redhat.com: change comment to explain the order check] Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-01vmscan: reduce wind up shrinker->nr when shrinker can't do workDave Chinner
commit 3567b59aa80ac4417002bf58e35dce5c777d4164 upstream. Stable note: Not tracked in Bugzilla. This patch reduces excessive reclaim of slab objects reducing the amount of information that has to be brought back in from disk. The third and fourth paragram in the series describes the impact. When a shrinker returns -1 to shrink_slab() to indicate it cannot do any work given the current memory reclaim requirements, it adds the entire total_scan count to shrinker->nr. The idea ehind this is that whenteh shrinker is next called and can do work, it will do the work of the previously aborted shrinker call as well. However, if a filesystem is doing lots of allocation with GFP_NOFS set, then we get many, many more aborts from the shrinkers than we do successful calls. The result is that shrinker->nr winds up to it's maximum permissible value (twice the current cache size) and then when the next shrinker call that can do work is issued, it has enough scan count built up to free the entire cache twice over. This manifests itself in the cache going from full to empty in a matter of seconds, even when only a small part of the cache is needed to be emptied to free sufficient memory. Under metadata intensive workloads on ext4 and XFS, I'm seeing the VFS caches increase memory consumption up to 75% of memory (no page cache pressure) over a period of 30-60s, and then the shrinker empties them down to zero in the space of 2-3s. This cycle repeats over and over again, with the shrinker completely trashing the inode and dentry caches every minute or so the workload continues. This behaviour was made obvious by the shrink_slab tracepoints added earlier in the series, and made worse by the patch that corrected the concurrent accounting of shrinker->nr. To avoid this problem, stop repeated small increments of the total scan value from winding shrinker->nr up to a value that can cause the entire cache to be freed. We still need to allow it to wind up, so use the delta as the "large scan" threshold check - if the delta is more than a quarter of the entire cache size, then it is a large scan and allowed to cause lots of windup because we are clearly needing to free lots of memory. If it isn't a large scan then limit the total scan to half the size of the cache so that windup never increases to consume the whole cache. Reducing the total scan limit further does not allow enough wind-up to maintain the current levels of performance, whilst a higher threshold does not prevent the windup from freeing the entire cache under sustained workloads. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
