commit 4f32be677b124a49459e2603321c7a5605ceb9f8 upstream.
After trying to drain pages from pagevec/pageset, we try to get reference
count of the page again, however, the reference count of the page is not
reduced if the page is still not on LRU list.
Fix it by adding the put_page() to drop the page reference which is from
__get_any_page().
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit ecf5fc6e9654cd7a268c782a523f072b2f1959f9 upstream.
Nikolay has reported a hang when a memcg reclaim got stuck with the
following backtrace:
PID: 18308 TASK: ffff883d7c9b0a30 CPU: 1 COMMAND: "rsync"
#0 __schedule at ffffffff815ab152
#1 schedule at ffffffff815ab76e
#2 schedule_timeout at ffffffff815ae5e5
#3 io_schedule_timeout at ffffffff815aad6a
#4 bit_wait_io at ffffffff815abfc6
#5 __wait_on_bit at ffffffff815abda5
#6 wait_on_page_bit at ffffffff8111fd4f
#7 shrink_page_list at ffffffff81135445
#8 shrink_inactive_list at ffffffff81135845
#9 shrink_lruvec at ffffffff81135ead
#10 shrink_zone at ffffffff811360c3
#11 shrink_zones at ffffffff81136eff
#12 do_try_to_free_pages at ffffffff8113712f
#13 try_to_free_mem_cgroup_pages at ffffffff811372be
#14 try_charge at ffffffff81189423
#15 mem_cgroup_try_charge at ffffffff8118c6f5
#16 __add_to_page_cache_locked at ffffffff8112137d
#17 add_to_page_cache_lru at ffffffff81121618
#18 pagecache_get_page at ffffffff8112170b
#19 grow_dev_page at ffffffff811c8297
#20 __getblk_slow at ffffffff811c91d6
#21 __getblk_gfp at ffffffff811c92c1
#22 ext4_ext_grow_indepth at ffffffff8124565c
#23 ext4_ext_create_new_leaf at ffffffff81246ca8
#24 ext4_ext_insert_extent at ffffffff81246f09
#25 ext4_ext_map_blocks at ffffffff8124a848
#26 ext4_map_blocks at ffffffff8121a5b7
#27 mpage_map_one_extent at ffffffff8121b1fa
#28 mpage_map_and_submit_extent at ffffffff8121f07b
#29 ext4_writepages at ffffffff8121f6d5
#30 do_writepages at ffffffff8112c490
#31 __filemap_fdatawrite_range at ffffffff81120199
#32 filemap_flush at ffffffff8112041c
#33 ext4_alloc_da_blocks at ffffffff81219da1
#34 ext4_rename at ffffffff81229b91
#35 ext4_rename2 at ffffffff81229e32
#36 vfs_rename at ffffffff811a08a5
#37 SYSC_renameat2 at ffffffff811a3ffc
#38 sys_renameat2 at ffffffff811a408e
#39 sys_rename at ffffffff8119e51e
#40 system_call_fastpath at ffffffff815afa89
Dave Chinner has properly pointed out that this is a deadlock in the
reclaim code because ext4 doesn't submit pages which are marked by
PG_writeback right away.
The heuristic was introduced by commit e62e384e9da8 ("memcg: prevent OOM
with too many dirty pages") and it was applied only when may_enter_fs
was specified. The code has been changed by c3b94f44fcb0 ("memcg:
further prevent OOM with too many dirty pages") which has removed the
__GFP_FS restriction with a reasoning that we do not get into the fs
code. But this is not sufficient apparently because the fs doesn't
necessarily submit pages marked PG_writeback for IO right away.
ext4_bio_write_page calls io_submit_add_bh but that doesn't necessarily
submit the bio. Instead it tries to map more pages into the bio and
mpage_map_one_extent might trigger memcg charge which might end up
waiting on a page which is marked PG_writeback but hasn't been submitted
yet so we would end up waiting for something that never finishes.
Fix this issue by replacing __GFP_IO by may_enter_fs check (for case 2)
before we go to wait on the writeback. The page fault path, which is
the only path that triggers memcg oom killer since 3.12, shouldn't
require GFP_NOFS and so we shouldn't reintroduce the premature OOM
killer issue which was originally addressed by the heuristic.
As per David Chinner the xfs is doing similar thing since 2.6.15 already
so ext4 is not the only affected filesystem. Moreover he notes:
: For example: IO completion might require unwritten extent conversion
: which executes filesystem transactions and GFP_NOFS allocations. The
: writeback flag on the pages can not be cleared until unwritten
: extent conversion completes. Hence memory reclaim cannot wait on
: page writeback to complete in GFP_NOFS context because it is not
: safe to do so, memcg reclaim or otherwise.
[tytso@mit.edu: corrected the control flow]
Fixes: c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages")
Reported-by: Nikolay Borisov <kernel@kyup.com>
commit 6b7339f4c31ad69c8e9c0b2859276e22cf72176d upstream.
Reading page fault handler code I've noticed that under right
circumstances kernel would map anonymous pages into file mappings: if
the VMA doesn't have vm_ops->fault() and the VMA wasn't fully populated
on ->mmap(), kernel would handle page fault to not populated pte with
do_anonymous_page().
Let's change page fault handler to use do_anonymous_page() only on
anonymous VMA (->vm_ops == NULL) and make sure that the VMA is not
shared.
For file mappings without vm_ops->fault() or shred VMA without vm_ops,
page fault on pte_none() entry would lead to SIGBUS.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: stable@vger.kernel.org
commit 85bd839983778fcd0c1c043327b14a046e979b39 upstream.
Izumi found the following oops when hot re-adding a node:
BUG: unable to handle kernel paging request at ffffc90008963690
IP: __wake_up_bit+0x20/0x70
Oops: 0000 [#1] SMP
CPU: 68 PID: 1237 Comm: rs:main Q:Reg Not tainted 4.1.0-rc5 #80
Hardware name: FUJITSU PRIMEQUEST2800E/SB, BIOS PRIMEQUEST 2000 Series BIOS Version 1.87 04/28/2015
task: ffff880838df8000 ti: ffff880017b94000 task.ti: ffff880017b94000
RIP: 0010:[<ffffffff810dff80>] [<ffffffff810dff80>] __wake_up_bit+0x20/0x70
RSP: 0018:ffff880017b97be8 EFLAGS: 00010246
RAX: ffffc90008963690 RBX: 00000000003c0000 RCX: 000000000000a4c9
RDX: 0000000000000000 RSI: ffffea101bffd500 RDI: ffffc90008963648
RBP: ffff880017b97c08 R08: 0000000002000020 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8a0797c73800
R13: ffffea101bffd500 R14: 0000000000000001 R15: 00000000003c0000
FS: 00007fcc7ffff700(0000) GS:ffff880874800000(0000) knlGS:0000000000000000
CR2: ffffc90008963690 CR3: 0000000836761000 CR4: 00000000001407e0
Call Trace:
unlock_page+0x6d/0x70
generic_write_end+0x53/0xb0
xfs_vm_write_end+0x29/0x80 [xfs]
generic_perform_write+0x10a/0x1e0
xfs_file_buffered_aio_write+0x14d/0x3e0 [xfs]
xfs_file_write_iter+0x79/0x120 [xfs]
__vfs_write+0xd4/0x110
vfs_write+0xac/0x1c0
SyS_write+0x58/0xd0
system_call_fastpath+0x12/0x76
Code: 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 48 83 ec 20 65 48 8b 04 25 28 00 00 00 48 89 45 f8 31 c0 48 8d 47 48 <48> 39 47 48 48 c7 45 e8 00 00 00 00 48 c7 45 f0 00 00 00 00 48
RIP [<ffffffff810dff80>] __wake_up_bit+0x20/0x70
RSP <ffff880017b97be8>
Reproduce method (re-add a node)::
Hot-add nodeA --> remove nodeA --> hot-add nodeA (panic)
This seems an use-after-free problem, and the root cause is
zone->wait_table was not set to *NULL* after free it in
try_offline_node.
When hot re-add a node, we will reuse the pgdat of it, so does the zone
struct, and when add pages to the target zone, it will init the zone
first (including the wait_table) if the zone is not initialized. The
judgement of zone initialized is based on zone->wait_table:
static inline bool zone_is_initialized(struct zone *zone)
return !!zone->wait_table;
so if we do not set the zone->wait_table to *NULL* after free it, the
memory hotplug routine will skip the init of new zone when hot re-add
the node, and the wait_table still points to the freed memory, then we
will access the invalid address when trying to wake up the waiting
people after the i/o operation with the page is done, such as mentioned
above.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Reported-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
Reviewed by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
commit 09789e5de18e4e442870b2d700831f5cb802eb05 upstream.
Currently memory_failure() calls shake_page() to sweep pages out from
pcplists only when the victim page is 4kB LRU page or thp head page.
But we should do this for a thp tail page too.
Consider that a memory error hits a thp tail page whose head page is on
a pcplist when memory_failure() runs. Then, the current kernel skips
shake_pages() part, so hwpoison_user_mappings() returns without calling
split_huge_page() nor try_to_unmap() because PageLRU of the thp head is
still cleared due to the skip of shake_page().
As a result, me_huge_page() runs for the thp, which is broken behavior.
One effect is a leak of the thp. And another is to fail to isolate the
memory error, so later access to the error address causes another MCE,
which kills the processes which used the thp.
This patch fixes this problem by calling shake_page() for thp tail case.
Fixes: 385de35722c9 ("thp: allow a hwpoisoned head page to be put back to LRU")
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Dean Nelson <dnelson@redhat.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jin Dongming <jin.dongming@np.css.fujitsu.com>
commit 9c145c56d0c8a0b62e48c8d71e055ad0fb2012ba upstream.
The stack guard page error case has long incorrectly caused a SIGBUS
rather than a SIGSEGV, but nobody actually noticed until commit
fee7e49d4514 ("mm: propagate error from stack expansion even for guard
page") because that error case was never actually triggered in any
normal situations.
Now that we actually report the error, people noticed the wrong signal
that resulted. So far, only the test suite of libsigsegv seems to have
actually cared, but there are real applications that use libsigsegv, so
let's not wait for any of those to break.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
[shengyong: Backport to 3.10
- adjust context
- ignore modification for arch nios2, because 3.10 does not support it
- ignore modification for driver lustre, because 3.10 does not support it
- ignore VM_FAULT_FALLBACK in VM_FAULT_ERROR, becase 3.10 does not support
this flag
- add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.10 does not
separate it to copro_fault.c
- add SIGSEGV handling in mm/memory.c, because 3.10 does not separate it
to gup.c
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
commit c72efb658f7c8b27ca3d0efb5cfd5ded9fcac89e upstream.
From 1ebf33901ecc75d9496862dceb1ef0377980587c Mon Sep 17 00:00:00 2001
Date: Mon, 23 Mar 2015 00:08:19 -0400
2f800fbd777b ("writeback: fix dirtied pages accounting on redirty")
introduced account_page_redirty() which reverts stat updates for a
redirtied page, making BDI_DIRTIED no longer monotonically increasing.
bdi_update_write_bandwidth() uses the delta in BDI_DIRTIED as the
basis for bandwidth calculation. While unlikely, since the above
patch, the newer value may be lower than the recorded past value and
underflow the bandwidth calculation leading to a wild result.
Fix it by subtracing min of the old and new values when calculating
delta. AFAIK, there hasn't been any report of it happening but the
resulting erratic behavior would be non-critical and temporary, so
it's possible that the issue is happening without being reported. The
risk of the fix is very low, so tagged for -stable.
Cc: Jan Kara <jack@suse.cz>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Fixes: 2f800fbd777b ("writeback: fix dirtied pages accounting on redirty")
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 7d70e15480c0450d2bfafaad338a32e884fc215e upstream.
global_update_bandwidth() uses static variable update_time as the
timestamp for the last update but forgets to initialize it to
INITIALIZE_JIFFIES.
This means that global_dirty_limit will be 5 mins into the future on
32bit and some large amount jiffies into the past on 64bit. This
isn't critical as the only effect is that global_dirty_limit won't be
updated for the first 5 mins after booting on 32bit machines,
especially given the auxiliary nature of global_dirty_limit's role -
protecting against global dirty threshold's sudden dips; however, it
does lead to unintended suboptimal behavior. Fix it.
Fixes: c42843f2f0bb ("writeback: introduce smoothed global dirty limit")
Acked-by: Jan Kara <jack@suse.cz>
commit b0dc3a342af36f95a68fe229b8f0f73552c5ca08 upstream.
Qiu Xishi reported the following BUG when testing hot-add/hot-remove node under
stress condition:
BUG: unable to handle kernel paging request at 0000000000025f60
IP: next_online_pgdat+0x1/0x50
PGD 0
Oops: 0000 [#1] SMP
ACPI: Device does not support D3cold
Modules linked in: fuse nls_iso8859_1 nls_cp437 vfat fat loop dm_mod coretemp mperf crc32c_intel ghash_clmulni_intel aesni_intel ablk_helper cryptd lrw gf128mul glue_helper aes_x86_64 pcspkr microcode igb dca i2c_algo_bit ipv6 megaraid_sas iTCO_wdt i2c_i801 i2c_core iTCO_vendor_support tg3 sg hwmon ptp lpc_ich pps_core mfd_core acpi_pad rtc_cmos button ext3 jbd mbcache sd_mod crc_t10dif scsi_dh_alua scsi_dh_rdac scsi_dh_hp_sw scsi_dh_emc scsi_dh ahci libahci libata scsi_mod [last unloaded: rasf]
CPU: 23 PID: 238 Comm: kworker/23:1 Tainted: G O 3.10.15-5885-euler0302 #1
Hardware name: HUAWEI TECHNOLOGIES CO.,LTD. Huawei N1/Huawei N1, BIOS V100R001 03/02/2015
Workqueue: events vmstat_update
task: ffffa800d32c0000 ti: ffffa800d32ae000 task.ti: ffffa800d32ae000
RIP: 0010: next_online_pgdat+0x1/0x50
RSP: 0018:ffffa800d32afce8 EFLAGS: 00010286
RAX: 0000000000001440 RBX: ffffffff81da53b8 RCX: 0000000000000082
RDX: 0000000000000000 RSI: 0000000000000082 RDI: 0000000000000000
RBP: ffffa800d32afd28 R08: ffffffff81c93bfc R09: ffffffff81cbdc96
R10: 00000000000040ec R11: 00000000000000a0 R12: ffffa800fffb3440
R13: ffffa800d32afd38 R14: 0000000000000017 R15: ffffa800e6616800
FS: 0000000000000000(0000) GS:ffffa800e6600000(0000) knlGS:0000000000000000
CR2: 0000000000025f60 CR3: 0000000001a0b000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
refresh_cpu_vm_stats+0xd0/0x140
vmstat_update+0x11/0x50
process_one_work+0x194/0x3d0
worker_thread+0x12b/0x410
kthread+0xc6/0xd0
ret_from_fork+0x7c/0xb0
The cause is the "memset(pgdat, 0, sizeof(*pgdat))" at the end of
try_offline_node, which will reset all the content of pgdat to 0, as the
pgdat is accessed lock-free, so that the users still using the pgdat
will panic, such as the vmstat_update routine.
process A: offline node XX:
vmstat_updat()
refresh_cpu_vm_stats()
for_each_populated_zone()
find online node XX
cond_resched()
offline cpu and memory, then try_offline_node()
node_set_offline(nid), and memset(pgdat, 0, sizeof(*pgdat))
zone = next_zone(zone)
pg_data_t *pgdat = zone->zone_pgdat; // here pgdat is NULL now
next_online_pgdat(pgdat)
next_online_node(pgdat->node_id); // NULL pointer access
So the solution here is postponing the reset of obsolete pgdat from
try_offline_node() to hotadd_new_pgdat(), and just resetting
pgdat->nr_zones and pgdat->classzone_idx to be 0 rather than the memset
0 to avoid breaking pointer information in pgdat.
Reported-by: Xishi Qiu <qiuxishi@huawei.com>
Suggested-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Xie XiuQi <xiexiuqi@huawei.com>
commit 9cb12d7b4ccaa976f97ce0c5fd0f1b6a83bc2a75 upstream.
For whatever reason, generic_access_phys() only remaps one page, but
actually allows to access arbitrary size. It's quite easy to trigger
large reads, like printing out large structure with gdb, which leads to a
crash. Fix it by remapping correct size.
Fixes: 28b2ee20c7cb ("access_process_vm device memory infrastructure")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
commit 372549c2a3778fd3df445819811c944ad54609ca upstream.
What we want to check here is whether there is highorder freepage in buddy
list of other migratetype in order to steal it without fragmentation.
But, current code just checks cc->order which means allocation request
order. So, this is wrong.
Without this fix, non-movable synchronous compaction below pageblock order
would not stopped until compaction is complete, because migratetype of
most pageblocks are movable and high order freepage made by compaction is
usually on movable type buddy list.
There is some report related to this bug. See below link.
http://www.spinics.net/lists/linux-mm/msg81666.html
Although the issued system still has load spike comes from compaction,
this makes that system completely stable and responsive according to his
report.
stress-highalloc test in mmtests with non movable order 7 allocation
doesn't show any notable difference in allocation success rate, but, it
shows more compaction success rate.
Compaction success rate (Compaction success * 100 / Compaction stalls, %)
18.47 : 28.94
Fixes: 1fb3f8ca0e92 ("mm: compaction: capture a suitable high-order page immediately when it is made available")
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
commit 8138a67a5557ffea3a21dfd6f037842d4e748513 upstream.
I noticed that "allowed" can easily overflow by falling below 0, because
(total_vm / 32) can be larger than "allowed". The problem occurs in
OVERCOMMIT_NONE mode.
In this case, a huge allocation can success and overcommit the system
(despite OVERCOMMIT_NONE mode). All subsequent allocations will fall
(system-wide), so system become unusable.
The problem was masked out by commit c9b1d0981fcc
("mm: limit growth of 3% hardcoded other user reserve"),
but it's easy to reproduce it on older kernels:
1) set overcommit_memory sysctl to 2
2) mmap() large file multiple times (with VM_SHARED flag)
3) try to malloc() large amount of memory
It also can be reproduced on newer kernels, but miss-configured
sysctl_user_reserve_kbytes is required.
Fix this issue by switching to signed arithmetic here.
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Cc: Andrew Shewmaker <agshew@gmail.com>
Cc: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
commit 5703b087dc8eaf47bfb399d6cf512d471beff405 upstream.
I noticed, that "allowed" can easily overflow by falling below 0,
because (total_vm / 32) can be larger than "allowed". The problem
occurs in OVERCOMMIT_NONE mode.
[akpm@linux-foundation.org: use min_t]
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit 9fbc1f635fd0bd28cb32550211bf095753ac637a upstream.
If __unmap_hugepage_range() tries to unmap the address range over which
hugepage migration is on the way, we get the wrong page because pte_page()
doesn't work for migration entries. This patch simply clears the pte for
migration entries as we do for hwpoison entries.
Fixes: 290408d4a2 ("hugetlb: hugepage migration core")
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Steve Capper <steve.capper@linaro.org>
commit 23aaed6659df9adfabe9c583e67a36b54e21df46 upstream.
walk_page_range() silently skips vma having VM_PFNMAP set, which leads
to undesirable behaviour at client end (who called walk_page_range).
Userspace applications get the wrong data, so the effect is like just
confusing users (if the applications just display the data) or sometimes
killing the processes (if the applications do something with
misunderstanding virtual addresses due to the wrong data.)
For example for pagemap_read, when no callbacks are called against
VM_PFNMAP vma, pagemap_read may prepare pagemap data for next virtual
address range at wrong index.
Eventually userspace may get wrong pagemap data for a task.
Corresponding to a VM_PFNMAP marked vma region, kernel may report
mappings from subsequent vma regions. User space in turn may account
more pages (than really are) to the task.
In my case I was using procmem, procrack (Android utility) which uses
pagemap interface to account RSS pages of a task. Due to this bug it
was giving a wrong picture for vmas (with VM_PFNMAP set).
Fixes: a9ff785e4437 ("mm/pagewalk.c: walk_page_range should avoid VM_PFNMAP areas")
Signed-off-by: Shiraz Hashim <shashim@codeaurora.org>
commit 690eac53daff34169a4d74fc7bfbd388c4896abb upstream.
Commit fee7e49d4514 ("mm: propagate error from stack expansion even for
guard page") made sure that we return the error properly for stack
growth conditions. It also theorized that counting the guard page
towards the stack limit might break something, but also said "Let's see
if anybody notices".
Somebody did notice. Apparently android-x86 sets the stack limit very
close to the limit indeed, and including the guard page in the rlimit
check causes the android 'zygote' process problems.
So this adds the (fairly trivial) code to make the stack rlimit check be
against the actual real stack size, rather than the size of the vma that
includes the guard page.
Reported-and-tested-by: Chih-Wei Huang <cwhuang@android-x86.org>
Cc: Jay Foad <jay.foad@gmail.com>
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
being killed
commit 9e5e3661727eaf960d3480213f8e87c8d67b6956 upstream.
Charles Shirron and Paul Cassella from Cray Inc have reported kswapd
stuck in a busy loop with nothing left to balance, but
kswapd_try_to_sleep() failing to sleep. Their analysis found the cause
to be a combination of several factors:
1. A process is waiting in throttle_direct_reclaim() on pgdat->pfmemalloc_wait
2. The process has been killed (by OOM in this case), but has not yet been
scheduled to remove itself from the waitqueue and die.
3. kswapd checks for throttled processes in prepare_kswapd_sleep():
if (waitqueue_active(&pgdat->pfmemalloc_wait)) {
wake_up(&pgdat->pfmemalloc_wait);
return false; // kswapd will not go to sleep
However, for a process that was already killed, wake_up() does not remove
the process from the waitqueue, since try_to_wake_up() checks its state
first and returns false when the process is no longer waiting.
4. kswapd is running on the same CPU as the only CPU that the process is
allowed to run on (through cpus_allowed, or possibly single-cpu system).
5. CONFIG_PREEMPT_NONE=y kernel is used. If there's nothing to balance, kswapd
encounters no voluntary preemption points and repeatedly fails
prepare_kswapd_sleep(), blocking the process from running and removing
itself from the waitqueue, which would let kswapd sleep.
So, the source of the problem is that we prevent kswapd from going to
sleep until there are processes waiting on the pfmemalloc_wait queue,
and a process waiting on a queue is guaranteed to be removed from the
queue only when it gets scheduled. This was done to make sure that no
process is left sleeping on pfmemalloc_wait when kswapd itself goes to
sleep.
However, it isn't necessary to postpone kswapd sleep until the
pfmemalloc_wait queue actually empties. To prevent processes from being
left sleeping, it's actually enough to guarantee that all processes
waiting on pfmemalloc_wait queue have been woken up by the time we put
kswapd to sleep.
This patch therefore fixes this issue by substituting 'wake_up' with
'wake_up_all' and removing 'return false' in the code snippet from
prepare_kswapd_sleep() above. Note that if any process puts itself in
the queue after this waitqueue_active() check, or after the wake up
itself, it means that the process will also wake up kswapd - and since
we are under prepare_to_wait(), the wake up won't be missed. Also we
update the comment prepare_kswapd_sleep() to hopefully more clearly
describe the races it is preventing.
Fixes: 5515061d22f0 ("mm: throttle direct reclaimers if PF_MEMALLOC reserves are low and swap is backed by network storage")
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
commit 2022b4d18a491a578218ce7a4eca8666db895a73 upstream.
I've been seeing swapoff hangs in recent testing: it's cycling around
trying unsuccessfully to find an mm for some remaining pages of swap.
I have been exercising swap and page migration more heavily recently,
and now notice a long-standing error in copy_one_pte(): it's trying to
add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing
so even when it's a migration entry or an hwpoison entry.
Which wouldn't matter much, except it adds dst_mm next to src_mm,
assuming src_mm is already on the mmlist: which may not be so. Then if
pages are later swapped out from dst_mm, swapoff won't be able to find
where to replace them.
There's already a !non_swap_entry() test for stats: move that up before
the swap_duplicate() and the addition to mmlist.
Cc: Kelley Nielsen <kelleynnn@gmail.com>
commit fb993fa1a2f669215fa03a09eed7848f2663e336 upstream.
If a frontswap dup-store failed, it should invalidate the expired page
in the backend, or it could trigger some data corruption issue.
Such as:
1. use zswap as the frontswap backend with writeback feature
2. store a swap page(version_1) to entry A, success
3. dup-store a newer page(version_2) to the same entry A, fail
4. use __swap_writepage() write version_2 page to swapfile, success
5. zswap do shrink, writeback version_1 page to swapfile
6. version_2 page is overwrited by version_1, data corrupt.
This patch fixes this issue by invalidating expired data immediately
when meet a dup-store failure.
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Seth Jennings <sjennings@variantweb.net>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
commit 4942642080ea82d99ab5b653abb9a12b7ba31f4a upstream.
Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full
callstack on OOM") assumed that only a few places that can trigger a
memcg OOM situation do not return VM_FAULT_OOM, like optional page cache
readahead. But there are many more and it's impractical to annotate
them all.
First of all, we don't want to invoke the OOM killer when the failed
allocation is gracefully handled, so defer the actual kill to the end of
the fault handling as well. This simplifies the code quite a bit for
added bonus.
Second, since a failed allocation might not be the abrupt end of the
fault, the memcg OOM handler needs to be re-entrant until the fault
finishes for subsequent allocation attempts. If an allocation is
attempted after the task already OOMed, allow it to bypass the limit so
that it can quickly finish the fault and invoke the OOM killer.
Reported-by: azurIt <azurit@pobox.sk>
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
commit 3812c8c8f3953921ef18544110dafc3505c1ac62 upstream.
The memcg OOM handling is incredibly fragile and can deadlock. When a
task fails to charge memory, it invokes the OOM killer and loops right
there in the charge code until it succeeds. Comparably, any other task
that enters the charge path at this point will go to a waitqueue right
then and there and sleep until the OOM situation is resolved. The problem
is that these tasks may hold filesystem locks and the mmap_sem; locks that
the selected OOM victim may need to exit.
For example, in one reported case, the task invoking the OOM killer was
about to charge a page cache page during a write(), which holds the
i_mutex. The OOM killer selected a task that was just entering truncate()
and trying to acquire the i_mutex:
OOM invoking task:
mem_cgroup_handle_oom+0x241/0x3b0
mem_cgroup_cache_charge+0xbe/0xe0
add_to_page_cache_locked+0x4c/0x140
add_to_page_cache_lru+0x22/0x50
grab_cache_page_write_begin+0x8b/0xe0
ext3_write_begin+0x88/0x270
generic_file_buffered_write+0x116/0x290
__generic_file_aio_write+0x27c/0x480
generic_file_aio_write+0x76/0xf0 # takes ->i_mutex
do_sync_write+0xea/0x130
vfs_write+0xf3/0x1f0
sys_write+0x51/0x90
system_call_fastpath+0x18/0x1d
OOM kill victim:
do_truncate+0x58/0xa0 # takes i_mutex
do_last+0x250/0xa30
path_openat+0xd7/0x440
do_filp_open+0x49/0xa0
do_sys_open+0x106/0x240
sys_open+0x20/0x30
The OOM handling task will retry the charge indefinitely while the OOM
killed task is not releasing any resources.
A similar scenario can happen when the kernel OOM killer for a memcg is
disabled and a userspace task is in charge of resolving OOM situations.
In this case, ALL tasks that enter the OOM path will be made to sleep on
the OOM waitqueue and wait for userspace to free resources or increase
the group's limit. But a userspace OOM handler is prone to deadlock
itself on the locks held by the waiting tasks. For example one of the
sleeping tasks may be stuck in a brk() call with the mmap_sem held for
writing but the userspace handler, in order to pick an optimal victim,
may need to read files from /proc/<pid>, which tries to acquire the same
mmap_sem for reading and deadlocks.
This patch changes the way tasks behave after detecting a memcg OOM and
makes sure nobody loops or sleeps with locks held:
1. When OOMing in a user fault, invoke the OOM killer and restart the
fault instead of looping on the charge attempt. This way, the OOM
victim can not get stuck on locks the looping task may hold.
2. When OOMing in a user fault but somebody else is handling it
(either the kernel OOM killer or a userspace handler), don't go to
sleep in the charge context. Instead, remember the OOMing memcg in
the task struct and then fully unwind the page fault stack with
-ENOMEM. pagefault_out_of_memory() will then call back into the
memcg code to check if the -ENOMEM came from the memcg, and then
either put the task to sleep on the memcg's OOM waitqueue or just
restart the fault. The OOM victim can no longer get stuck on any
lock a sleeping task may hold.
Debugged by Michal Hocko.
commit fb2a6fc56be66c169f8b80e07ed999ba453a2db2 upstream.
The memcg OOM handler open-codes a sleeping lock for OOM serialization
(trylock, wait, repeat) because the required locking is so specific to
memcg hierarchies. However, it would be nice if this construct would be
clearly recognizable and not be as obfuscated as it is right now. Clean
up as follows:
1. Remove the return value of mem_cgroup_oom_unlock()
2. Rename mem_cgroup_oom_lock() to mem_cgroup_oom_trylock().
3. Pull the prepare_to_wait() out of the memcg_oom_lock scope. This
makes it more obvious that the task has to be on the waitqueue
before attempting to OOM-trylock the hierarchy, to not miss any
wakeups before going to sleep. It just didn't matter until now
because it was all lumped together into the global memcg_oom_lock
spinlock section.
4. Pull the mem_cgroup_oom_notify() out of the memcg_oom_lock scope.
It is proctected by the hierarchical OOM-lock.
5. The memcg_oom_lock spinlock is only required to propagate the OOM
lock in any given hierarchy atomically. Restrict its scope to
mem_cgroup_oom_(trylock|unlock).
6. Do not wake up the waitqueue unconditionally at the end of the
function. Only the lockholder has to wake up the next in line
after releasing the lock.
Note that the lockholder kicks off the OOM-killer, which in turn
leads to wakeups from the uncharges of the exiting task. But a
contender is not guaranteed to see them if it enters the OOM path
after the OOM kills but before the lockholder releases the lock.
Thus there has to be an explicit wakeup after releasing the lock.
7. Put the OOM task on the waitqueue before marking the hierarchy as
under OOM as that is the point where we start to receive wakeups.
No point in listening before being on the waitqueue.
8. Likewise, unmark the hierarchy before finishing the sleep, for
symmetry.
Cc: azurIt <azurit@pobox.sk>
commit 519e52473ebe9db5cdef44670d5a97f1fd53d721 upstream.
System calls and kernel faults (uaccess, gup) can handle an out of memory
situation gracefully and just return -ENOMEM.
Enable the memcg OOM killer only for user faults, where it's really the
only option available.
commit f55fefd1a5a339b1bd08c120b93312d6eb64a9fb upstream.
The WARN_ON checking whether i_mutex is held in
pagecache_isize_extended() was wrong because some filesystems (e.g.
XFS) use different locks for serialization of truncates / writes. So
just remove the check.
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 401507d67d5c2854f5a88b3f93f64fc6f267bca5 upstream.
Commit ff7ee93f4715 ("cgroup/kmemleak: Annotate alloc_page() for cgroup
allocations") introduces kmemleak_alloc() for alloc_page_cgroup(), but
corresponding kmemleak_free() is missing, which makes kmemleak be
wrongly disabled after memory offlining. Log is pasted at the end of
this commit message.
This patch add kmemleak_free() into free_page_cgroup(). During page
offlining, this patch removes corresponding entries in kmemleak rbtree.
After that, the freed memory can be allocated again by other subsystems
without killing kmemleak.
bash # for x in 1 2 3 4; do echo offline > /sys/devices/system/memory/memory$x/state ; sleep 1; done ; dmesg | grep leak
Offlined Pages 32768
kmemleak: Cannot insert 0xffff880016969000 into the object search tree (overlaps existing)
CPU: 0 PID: 412 Comm: sleep Not tainted 3.17.0-rc5+ #86
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x46/0x58
create_object+0x266/0x2c0
kmemleak_alloc+0x26/0x50
kmem_cache_alloc+0xd3/0x160
__sigqueue_alloc+0x49/0xd0
__send_signal+0xcb/0x410
send_signal+0x45/0x90
__group_send_sig_info+0x13/0x20
do_notify_parent+0x1bb/0x260
do_exit+0x767/0xa40
do_group_exit+0x44/0xa0
SyS_exit_group+0x17/0x20
system_call_fastpath+0x16/0x1b
kmemleak: Kernel memory leak detector disabled
kmemleak: Object 0xffff880016900000 (size 524288):
kmemleak: comm "swapper/0", pid 0, jiffies 4294667296
kmemleak: min_count = 0
kmemleak: count = 0
kmemleak: flags = 0x1
kmemleak: checksum = 0
kmemleak: backtrace:
log_early+0x63/0x77
kmemleak_alloc+0x4b/0x50
init_section_page_cgroup+0x7f/0xf5
page_cgroup_init+0xc5/0xd0
start_kernel+0x333/0x408
x86_64_start_reservations+0x2a/0x2c
x86_64_start_kernel+0xf5/0xfc
Fixes: ff7ee93f4715 (cgroup/kmemleak: Annotate alloc_page() for cgroup allocations)
Signed-off-by: Wang Nan <wangnan0@huawei.com>
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream.
PM freezer relies on having all tasks frozen by the time devices are
getting frozen so that no task will touch them while they are getting
frozen. But OOM killer is allowed to kill an already frozen task in
order to handle OOM situtation. In order to protect from late wake ups
OOM killer is disabled after all tasks are frozen. This, however, still
keeps a window open when a killed task didn't manage to die by the time
freeze_processes finishes.
Reduce the race window by checking all tasks after OOM killer has been
disabled. This is still not race free completely unfortunately because
oom_killer_disable cannot stop an already ongoing OOM killer so a task
might still wake up from the fridge and get killed without
freeze_processes noticing. Full synchronization of OOM and freezer is,
however, too heavy weight for this highly unlikely case.
Introduce and check oom_kills counter which gets incremented early when
the allocator enters __alloc_pages_may_oom path and only check all the
tasks if the counter changes during the freezing attempt. The counter
is updated so early to reduce the race window since allocator checked
oom_killer_disabled which is set by PM-freezing code. A false positive
will push the PM-freezer into a slow path but that is not a big deal.
Changes since v1
- push the re-check loop out of freeze_processes into
check_frozen_processes and invert the condition to make the code more
readable as per Rafael
Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring)
commit 90a8020278c1598fafd071736a0846b38510309c upstream.
->page_mkwrite() is used by filesystems to allocate blocks under a page
which is becoming writeably mmapped in some process' address space. This
allows a filesystem to return a page fault if there is not enough space
available, user exceeds quota or similar problem happens, rather than
silently discarding data later when writepage is called.
However VFS fails to call ->page_mkwrite() in all the cases where
filesystems need it when blocksize < pagesize. For example when
blocksize = 1024, pagesize = 4096 the following is problematic:
ftruncate(fd, 0);
pwrite(fd, buf, 1024, 0);
map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0);
map[0] = 'a'; ----> page_mkwrite() for index 0 is called
ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */
mremap(map, 1024, 10000, 0);
map[4095] = 'a'; ----> no page_mkwrite() called
At the moment ->page_mkwrite() is called, filesystem can allocate only
one block for the page because i_size == 1024. Otherwise it would create
blocks beyond i_size which is generally undesirable. But later at
->writepage() time, we also need to store data at offset 4095 but we
don't have block allocated for it.
This patch introduces a helper function filesystems can use to have
->page_mkwrite() called at all the necessary moments.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit bb2e226b3bef596dd56be97df655d857b4603923 upstream.
This reverts commit 3189eddbcafc ("percpu: free percpu allocation info for
uniprocessor system").
The commit causes a hang with a crisv32 image. This may be an architecture
problem, but at least for now the revert is necessary to be able to boot a
crisv32 image.
Cc: Tejun Heo <tj@kernel.org>
Cc: Honggang Li <enjoymindful@gmail.com>
Fixes: 3189eddbcafc ("percpu: free percpu allocation info for uniprocessor system")
commit abc40bd2eeb77eb7c2effcaf63154aad929a1d5f upstream.
This patch reverts 1ba6e0b50b ("mm: numa: split_huge_page: transfer the
NUMA type from the pmd to the pte"). If a huge page is being split due
a protection change and the tail will be in a PROT_NONE vma then NUMA
hinting PTEs are temporarily created in the protected VMA.
VM_RW|VM_PROTNONE
split here
In the specific case above, it should get fixed up by change_pte_range()
but there is a window of opportunity for weirdness to happen. Similarly,
if a huge page is shrunk and split during a protection update but before
pmd_numa is cleared then a pte_numa can be left behind.
Instead of adding complexity trying to deal with the case, this patch
will not mark PTEs NUMA when splitting a huge page. NUMA hinting faults
will not be triggered which is marginal in comparison to the complexity
in dealing with the corner cases during THP split.
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit f8303c2582b889351e261ff18c4d8eb197a77db2 upstream.
In __split_huge_page_map(), the check for page_mapcount(page) is
invariant within the for loop. Because of the fact that the macro is
implemented using atomic_read(), the redundant check cannot be optimized
away by the compiler leading to unnecessary read to the page structure.
This patch moves the invariant bug check out of the loop so that it will
be done only once. On a 3.16-rc1 based kernel, the execution time of a
microbenchmark that broke up 1000 transparent huge pages using munmap()
had an execution time of 38,245us and 38,548us with and without the
patch respectively. The performance gain is about 1%.
Signed-off-by: Waiman Long <Waiman.Long@hp.com>
Cc: Scott J Norton <scott.norton@hp.com>
commit 4449a51a7c281602d3a385044ab928322a122a02 upstream.
Aleksei hit the soft lockup during reading /proc/PID/smaps. David
investigated the problem and suggested the right fix.
while_each_thread() is racy and should die, this patch updates
vm_is_stack().
Reported-by: Aleksei Besogonov <alex.besogonov@gmail.com>
Tested-by: Aleksei Besogonov <alex.besogonov@gmail.com>
Suggested-by: David Rientjes <rientjes@google.com>
Cc: Li Zefan <lizefan@huawei.com>
commit 4d4048be8a93769350efa31d2482a038b7de73d0 upstream.
find_lock_task_mm() expects it is called under rcu or tasklist lock, but
it seems that at least oom_unkillable_task()->task_in_mem_cgroup() and
mem_cgroup_out_of_memory()->oom_badness() can call it lockless.
Perhaps we could fix the callers, but this patch simply adds rcu lock
into find_lock_task_mm(). This also allows to simplify a bit one of its
callers, oom_kill_process().
Cc: Sergey Dyasly <dserrg@gmail.com>
Cc: Sameer Nanda <snanda@chromium.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Mandeep Singh Baines <msb@chromium.org>
Cc: "Ma, Xindong" <xindong.ma@intel.com>
Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com>
Acked-by: David Rientjes <rientjes@google.com>
commit ad96244179fbd55b40c00f10f399bc04739b8e1f upstream.
At least out_of_memory() calls has_intersects_mems_allowed() without
even rcu_read_lock(), this is obviously buggy.
Add the necessary rcu_read_lock(). This means that we can not simply
return from the loop, we need "bool ret" and "break".
While at it, swap the names of task_struct's (the argument and the
local). This cleans up the code a little bit and avoids the unnecessary
initialization.
Reviewed-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Reviewed-by: Sameer Nanda <snanda@chromium.org>
commit 1da4db0cd5c8a31d4468ec906b413e75e604b465 upstream.
Change oom_kill.c to use for_each_thread() rather than the racy
while_each_thread() which can loop forever if we race with exit.
Note also that most users were buggy even if while_each_thread() was
fine, the task can exit even _before_ rcu_read_lock().
Fortunately the new for_each_thread() only requires the stable
task_struct, so this change fixes both problems.
commit 849f5169097e1ba35b90ac9df76b5bb6f9c0aabd upstream.
If pcpu_map_pages() fails midway, it unmaps the already mapped pages.
Currently, it doesn't flush tlb after the partial unmapping. This may
be okay in most cases as the established mapping hasn't been used at
that point but it can go wrong and when it goes wrong it'd be
extremely difficult to track down.
Flush tlb after the partial unmapping.
commit f0d279654dea22b7a6ad34b9334aee80cda62cde upstream.
When pcpu_alloc_pages() fails midway, pcpu_free_pages() is invoked to
free what has already been allocated. The invocation is across the
whole requested range and pcpu_free_pages() will try to free all
non-NULL pages; unfortunately, this is incorrect as
pcpu_get_pages_and_bitmap(), unlike what its comment suggests, doesn't
clear the pages array and thus the array may have entries from the
previous invocations making the partial failure path free incorrect
pages.
Fix it by open-coding the partial freeing of the already allocated
pages.
commit 3189eddbcafcc4d827f7f19facbeddec4424eba8 upstream.
Currently, only SMP system free the percpu allocation info.
Uniprocessor system should free it too. For example, one x86 UML
virtual machine with 256MB memory, UML kernel wastes one page memory.
Signed-off-by: Honggang Li <enjoymindful@gmail.com>
commit b928095b0a7cff7fb9fcf4c706348ceb8ab2c295 upstream.
If overwriting an empty directory with rename, then need to drop the extra
nlink.
Test prog:
#include <stdio.h>
#include <fcntl.h>
#include <err.h>
#include <sys/stat.h>
int main(void)
const char *test_dir1 = "test-dir1";
const char *test_dir2 = "test-dir2";
int res;
int fd;
struct stat statbuf;
res = mkdir(test_dir1, 0777);
if (res == -1)
err(1, "mkdir(\"%s\")", test_dir1);
res = mkdir(test_dir2, 0777);
if (res == -1)
err(1, "mkdir(\"%s\")", test_dir2);
fd = open(test_dir2, O_RDONLY);
if (fd == -1)
err(1, "open(\"%s\")", test_dir2);
res = rename(test_dir1, test_dir2);
if (res == -1)
err(1, "rename(\"%s\", \"%s\")", test_dir1, test_dir2);
res = fstat(fd, &statbuf);
if (res == -1)
err(1, "fstat(%i)", fd);
if (statbuf.st_nlink != 0) {
fprintf(stderr, "nlink is %lu, should be 0\n", statbuf.st_nlink);
return 1;
return 0;
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit b104a35d32025ca740539db2808aa3385d0f30eb upstream.
The page allocator relies on __GFP_WAIT to determine if ALLOC_CPUSET
should be set in allocflags. ALLOC_CPUSET controls if a page allocation
should be restricted only to the set of allowed cpuset mems.
Transparent hugepages clears __GFP_WAIT when defrag is disabled to prevent
the fault path from using memory compaction or direct reclaim. Thus, it
is unfairly able to allocate outside of its cpuset mems restriction as a
side-effect.
This patch ensures that ALLOC_CPUSET is only cleared when the gfp mask is
truly GFP_ATOMIC by verifying it is also not a thp allocation.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Alex Thorlton <athorlton@sgi.com>
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: Bob Liu <lliubbo@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Hedi Berriche <hedi@sgi.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 0253d634e0803a8376a0d88efee0bf523d8673f9 upstream.
Commit 4a705fef9862 ("hugetlb: fix copy_hugetlb_page_range() to handle
migration/hwpoisoned entry") changed the order of
huge_ptep_set_wrprotect() and huge_ptep_get(), which leads to breakage
in some workloads like hugepage-backed heap allocation via libhugetlbfs.
This patch fixes it.
The test program for the problem is shown below:
$ cat heap.c
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
#define HPS 0x200000
int main() {
int i;
char *p = malloc(HPS);
memset(p, '1', HPS);
for (i = 0; i < 5; i++) {
if (!fork()) {
memset(p, '2', HPS);
p = malloc(HPS);
memset(p, '3', HPS);
free(p);
return 0;
sleep(1);
free(p);
return 0;
$ export HUGETLB_MORECORE=yes ; export HUGETLB_NO_PREFAULT= ; hugectl --heap ./heap
Fixes 4a705fef9862 ("hugetlb: fix copy_hugetlb_page_range() to handle
migration/hwpoisoned entry"), so is applicable to -stable kernels which
include it.
Reported-by: Guillaume Morin <guillaume@morinfr.org>
Suggested-by: Guillaume Morin <guillaume@morinfr.org>
commit 694617474e33b8603fc76e090ed7d09376514b1a upstream.
The patch 3e374919b314f20e2a04f641ebc1093d758f66a4 is supposed to fix the
problem where kmem_cache_create incorrectly reports duplicate cache name
and fails. The problem is described in the header of that patch.
However, the patch doesn't really fix the problem because of these
reasons:
* the logic to test for debugging is reversed. It was intended to perform
the check only if slub debugging is enabled (which implies that caches
with the same parameters are not merged). Therefore, there should be
#if !defined(CONFIG_SLUB) || defined(CONFIG_SLUB_DEBUG_ON)
The current code has the condition reversed and performs the test if
debugging is disabled.
* slub debugging may be enabled or disabled based on kernel command line,
CONFIG_SLUB_DEBUG_ON is just the default settings. Therefore the test
based on definition of CONFIG_SLUB_DEBUG_ON is unreliable.
This patch fixes the problem by removing the test
"!defined(CONFIG_SLUB_DEBUG_ON)". Therefore, duplicate names are never
checked if the SLUB allocator is used.
Note to stable kernel maintainers: when backporint this patch, please
backport also the patch 3e374919b314f20e2a04f641ebc1093d758f66a4.
Acked-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
commit 3e374919b314f20e2a04f641ebc1093d758f66a4 upstream.
SLUB can alias multiple slab kmem_create_requests to one slab cache to save
memory and increase the cache hotness. As a result the name of the slab can be
stale. Only check the name for duplicates if we are in debug mode where we do
not merge multiple caches.
This fixes the following problem reported by Jonathan Brassow:
The problem with kmem_cache* is this:
*) Assume CONFIG_SLUB is set
1) kmem_cache_create(name="foo-a")
- creates new kmem_cache structure
2) kmem_cache_create(name="foo-b")
- If identical cache characteristics, it will be merged with the previously
created cache associated with "foo-a". The cache's refcount will be
incremented and an alias will be created via sysfs_slab_alias().
3) kmem_cache_destroy(<ptr>)
- Attempting to destroy cache associated with "foo-a", but instead the
refcount is simply decremented. I don't even think the sysfs aliases are
ever removed...
4) kmem_cache_create(name="foo-a")
- This FAILS because kmem_cache_sanity_check colides with the existing
name ("foo-a") associated with the non-removed cache.
This is a problem for RAID (specifically dm-raid) because the name used
for the kmem_cache_create is ("raid%d-%p", level, mddev). If the cache
persists for long enough, the memory address of an old mddev will be
reused for a new mddev - causing an identical formulation of the cache
name. Even though kmem_cache_destory had long ago been used to delete
the old cache, the merging of caches has cause the name and cache of that
old instance to be preserved and causes a colision (and thus failure) in
kmem_cache_create(). I see this regularly in my testing.
Reported-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
commit b1a366500bd537b50c3aad26dc7df083ec03a448 upstream.
shmem_fault() is the actual culprit in trinity's hole-punch starvation,
and the most significant cause of such problems: since a page faulted is
one that then appears page_mapped(), needing unmap_mapping_range() and
i_mmap_mutex to be unmapped again.
But it is not the only way in which a page can be brought into a hole in
the radix_tree while that hole is being punched; and Vlastimil's testing
implies that if enough other processors are busy filling in the hole,
then shmem_undo_range() can be kept from completing indefinitely.
shmem_file_splice_read() is the main other user of SGP_CACHE, which can
instantiate shmem pagecache pages in the read-only case (without holding
i_mutex, so perhaps concurrently with a hole-punch). Probably it's
silly not to use SGP_READ already (using the ZERO_PAGE for holes): which
ought to be safe, but might bring surprises - not a change to be rushed.
shmem_read_mapping_page_gfp() is an internal interface used by
drivers/gpu/drm GEM (and next by uprobes): it should be okay. And
shmem_file_read_iter() uses the SGP_DIRTY variant of SGP_CACHE, when
called internally by the kernel (perhaps for a stacking filesystem,
which might rely on holes to be reserved): it's unclear whether it could
be provoked to keep hole-punch busy or not.
We could apply the same umbrella as now used in shmem_fault() to
shmem_file_splice_read() and the others; but it looks ugly, and use over
a range raises questions - should it actually be per page? can these get
starved themselves?
The origin of this part of the problem is my v3.1 commit d0823576bf4b
("mm: pincer in truncate_inode_pages_range"), once it was duplicated
into shmem.c. It seemed like a nice idea at the time, to ensure
(barring RCU lookup fuzziness) that there's an instant when the entire
hole is empty; but the indefinitely repeated scans to ensure that make
it vulnerable.
Revert that "enhancement" to hole-punch from shmem_undo_range(), but
retain the unproblematic rescanning when it's truncating; add a couple
of comments there.
Remove the "indices[0] >= end" test: that is now handled satisfactorily
by the inner loop, and mem_cgroup_uncharge_start()/end() are too light
to be worth avoiding here.
But if we do not always loop indefinitely, we do need to handle the case
of swap swizzled back to page before shmem_free_swap() gets it: add a
retry for that case, as suggested by Konstantin Khlebnikov; and for the
case of page swizzled back to swap, as suggested by Johannes Weiner.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Suggested-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Lukas Czerner <lczerner@redhat.com>
Cc: Dave Jones <davej@redhat.com>
commit 8e205f779d1443a94b5ae81aa359cb535dd3021e upstream.
Commit f00cdc6df7d7 ("shmem: fix faulting into a hole while it's
punched") was buggy: Sasha sent a lockdep report to remind us that
grabbing i_mutex in the fault path is a no-no (write syscall may already
hold i_mutex while faulting user buffer).
We tried a completely different approach (see following patch) but that
proved inadequate: good enough for a rational workload, but not good
enough against trinity - which forks off so many mappings of the object
that contention on i_mmap_mutex while hole-puncher holds i_mutex builds
into serious starvation when concurrent faults force the puncher to fall
back to single-page unmap_mapping_range() searches of the i_mmap tree.
So return to the original umbrella approach, but keep away from i_mutex
this time. We really don't want to bloat every shmem inode with a new
mutex or completion, just to protect this unlikely case from trinity.
So extend the original with wait_queue_head on stack at the hole-punch
end, and wait_queue item on the stack at the fault end.
This involves further use of i_lock to guard against the races: lockdep
has been happy so far, and I see fs/inode.c:unlock_new_inode() holds
i_lock around wake_up_bit(), which is comparable to what we do here.
i_lock is more convenient, but we could switch to shmem's info->lock.
This issue has been tagged with CVE-2014-4171, which will require commit
f00cdc6df7d7 and this and the following patch to be backported: we
suggest to 3.1+, though in fact the trinity forkbomb effect might go
back as far as 2.6.16, when madvise(,,MADV_REMOVE) came in - or might
not, since much has changed, with i_mmap_mutex a spinlock before 3.0.
Anyone running trinity on 3.0 and earlier? I don't think we need care.
Tested-by: Sasha Levin <sasha.levin@oracle.com>
commit f00cdc6df7d7cfcabb5b740911e6788cb0802bdb upstream.
Trinity finds that mmap access to a hole while it's punched from shmem
can prevent the madvise(MADV_REMOVE) or fallocate(FALLOC_FL_PUNCH_HOLE)
from completing, until the reader chooses to stop; with the puncher's
hold on i_mutex locking out all other writers until it can complete.
It appears that the tmpfs fault path is too light in comparison with its
hole-punching path, lacking an i_data_sem to obstruct it; but we don't
want to slow down the common case.
Extend shmem_fallocate()'s existing range notification mechanism, so
shmem_fault() can refrain from faulting pages into the hole while it's
punched, waiting instead on i_mutex (when safe to sleep; or repeatedly
faulting when not).
commit 391acf970d21219a2a5446282d3b20eace0c0d7a upstream.
When runing with the kernel(3.15-rc7+), the follow bug occurs:
[ 9969.258987] BUG: sleeping function called from invalid context at kernel/locking/mutex.c:586
[ 9969.359906] in_atomic(): 1, irqs_disabled(): 0, pid: 160655, name: python
[ 9969.441175] INFO: lockdep is turned off.
[ 9969.488184] CPU: 26 PID: 160655 Comm: python Tainted: G A 3.15.0-rc7+ #85
[ 9969.581032] Hardware name: FUJITSU-SV PRIMEQUEST 1800E/SB, BIOS PRIMEQUEST 1000 Series BIOS Version 1.39 11/16/2012
[ 9969.706052] ffffffff81a20e60 ffff8803e941fbd0 ffffffff8162f523 ffff8803e941fd18
[ 9969.795323] ffff8803e941fbe0 ffffffff8109995a ffff8803e941fc58 ffffffff81633e6c
[ 9969.884710] ffffffff811ba5dc ffff880405c6b480 ffff88041fdd90a0 0000000000002000
[ 9969.974071] Call Trace:
[ 9970.003403] [<ffffffff8162f523>] dump_stack+0x4d/0x66
[ 9970.065074] [<ffffffff8109995a>] __might_sleep+0xfa/0x130
[ 9970.130743] [<ffffffff81633e6c>] mutex_lock_nested+0x3c/0x4f0
[ 9970.200638] [<ffffffff811ba5dc>] ? kmem_cache_alloc+0x1bc/0x210
[ 9970.272610] [<ffffffff81105807>] cpuset_mems_allowed+0x27/0x140
[ 9970.344584] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.409282] [<ffffffff811b1385>] __mpol_dup+0xe5/0x150
[ 9970.471897] [<ffffffff811b1303>] ? __mpol_dup+0x63/0x150
[ 9970.536585] [<ffffffff81068c86>] ? copy_process.part.23+0x606/0x1d40
[ 9970.613763] [<ffffffff810bf28d>] ? trace_hardirqs_on+0xd/0x10
[ 9970.683660] [<ffffffff810ddddf>] ? monotonic_to_bootbased+0x2f/0x50
[ 9970.759795] [<ffffffff81068cf0>] copy_process.part.23+0x670/0x1d40
[ 9970.834885] [<ffffffff8106a598>] do_fork+0xd8/0x380
[ 9970.894375] [<ffffffff81110e4c>] ? __audit_syscall_entry+0x9c/0xf0
[ 9970.969470] [<ffffffff8106a8c6>] SyS_clone+0x16/0x20
[ 9971.030011] [<ffffffff81642009>] stub_clone+0x69/0x90
[ 9971.091573] [<ffffffff81641c29>] ? system_call_fastpath+0x16/0x1b
The cause is that cpuset_mems_allowed() try to take
mutex_lock(&callback_mutex) under the rcu_read_lock(which was hold in
__mpol_dup()). And in cpuset_mems_allowed(), the access to cpuset is
under rcu_read_lock, so in __mpol_dup, we can reduce the rcu_read_lock
protection region to protect the access to cpuset only in
current_cpuset_is_being_rebound(). So that we can avoid this bug.
This patch is a temporary solution that just addresses the bug
mentioned above, can not fix the long-standing issue about cpuset.mems
rebinding on fork():
"When the forker's task_struct is duplicated (which includes
->mems_allowed) and it races with an update to cpuset_being_rebound
in update_tasks_nodemask() then the task's mems_allowed doesn't get
updated. And the child task's mems_allowed can be wrong if the
cpuset's nodemask changes before the child has been added to the
cgroup's tasklist."
Acked-by: Li Zefan <lizefan@huawei.com>
commit d05f0cdcbe6388723f1900c549b4850360545201 upstream.
In v2.6.34 commit 9d8cebd4bcd7 ("mm: fix mbind vma merge problem")
introduced vma merging to mbind(), but it should have also changed the
convention of passing start vma from queue_pages_range() (formerly
check_range()) to new_vma_page(): vma merging may have already freed
that structure, resulting in BUG at mm/mempolicy.c:1738 and probably
worse crashes.
Fixes: 9d8cebd4bcd7 ("mm: fix mbind vma merge problem")
Reported-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Tested-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
commit 4a705fef986231a3e7a6b1a6d3c37025f021f49f upstream.
There's a race between fork() and hugepage migration, as a result we try
to "dereference" a swap entry as a normal pte, causing kernel panic.
The cause of the problem is that copy_hugetlb_page_range() can't handle
"swap entry" family (migration entry and hwpoisoned entry) so let's fix
it.
Cc: Christoph Lameter <cl@linux.com>
