path: root/mm
2015-10-01dmapool: fix overflow condition in pool_find_page()Robin Murphy
If a DMA pool lies at the very top of the dma_addr_t range (as may happen with an IOMMU involved), the calculated end address of the pool wraps around to zero, and page lookup always fails. Tweak the relevant calculation to be overflow-proof. Signed-off-by: Robin Murphy <robin.murphy@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Sumit Semwal <sumit.semwal@linaro.org> Cc: Sakari Ailus <sakari.ailus@iki.fi> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01memcg: remove pcp_counter_lockGreg Thelen
Commit 733a572e66d2 ("memcg: make mem_cgroup_read_{stat|event}() iterate possible cpus instead of online") removed the last use of the per memcg pcp_counter_lock but forgot to remove the variable. Kill the vestigial variable. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01memcg: make mem_cgroup_read_stat() unsignedGreg Thelen
mem_cgroup_read_stat() returns a page count by summing per cpu page counters. The summing is racy wrt. updates, so a transient negative sum is possible. Callers don't want negative values: - mem_cgroup_wb_stats() doesn't want negative nr_dirty or nr_writeback. This could confuse dirty throttling. - oom reports and memory.stat shouldn't show confusing negative usage. - tree_usage() already avoids negatives. Avoid returning negative page counts from mem_cgroup_read_stat() and convert it to unsigned. [akpm@linux-foundation.org: fix old typo while we're in there] Signed-off-by: Greg Thelen <gthelen@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: <stable@vger.kernel.org> [4.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01memcg: fix dirty page migrationGreg Thelen
The problem starts with a file backed dirty page which is charged to a memcg. Then page migration is used to move oldpage to newpage. Migration: - copies the oldpage's data to newpage - clears oldpage.PG_dirty - sets newpage.PG_dirty - uncharges oldpage from memcg - charges newpage to memcg Clearing oldpage.PG_dirty decrements the charged memcg's dirty page count. However, because newpage is not yet charged, setting newpage.PG_dirty does not increment the memcg's dirty page count. After migration completes newpage.PG_dirty is eventually cleared, often in account_page_cleaned(). At this time newpage is charged to a memcg so the memcg's dirty page count is decremented which causes underflow because the count was not previously incremented by migration. This underflow causes balance_dirty_pages() to see a very large unsigned number of dirty memcg pages which leads to aggressive throttling of buffered writes by processes in non root memcg. This issue: - can harm performance of non root memcg buffered writes. - can report too small (even negative) values in memory.stat[(total_)dirty] counters of all memcg, including the root. To avoid polluting migrate.c with #ifdef CONFIG_MEMCG checks, introduce page_memcg() and set_page_memcg() helpers. Test: 0) setup and enter limited memcg mkdir /sys/fs/cgroup/test echo 1G > /sys/fs/cgroup/test/memory.limit_in_bytes echo $$ > /sys/fs/cgroup/test/cgroup.procs 1) buffered writes baseline dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k sync grep ^dirty /sys/fs/cgroup/test/memory.stat 2) buffered writes with compaction antagonist to induce migration yes 1 > /proc/sys/vm/compact_memory & rm -rf /data/tmp/foo dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k kill % sync grep ^dirty /sys/fs/cgroup/test/memory.stat 3) buffered writes without antagonist, should match baseline rm -rf /data/tmp/foo dd if=/dev/zero of=/data/tmp/foo bs=1M count=1k sync grep ^dirty /sys/fs/cgroup/test/memory.stat (speed, dirty residue) unpatched patched 1) 841 MB/s 0 dirty pages 886 MB/s 0 dirty pages 2) 611 MB/s -33427456 dirty pages 793 MB/s 0 dirty pages 3) 114 MB/s -33427456 dirty pages 891 MB/s 0 dirty pages Notice that unpatched baseline performance (1) fell after migration (3): 841 -> 114 MB/s. In the patched kernel, post migration performance matches baseline. Fixes: c4843a7593a9 ("memcg: add per cgroup dirty page accounting") Signed-off-by: Greg Thelen <gthelen@google.com> Reported-by: Dave Hansen <dave.hansen@intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: <stable@vger.kernel.org> [4.2+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01mm: hugetlbfs: skip shared VMAs when unmapping private pages to satisfy a faultMel Gorman
SunDong reported the following on https://bugzilla.kernel.org/show_bug.cgi?id=103841 I think I find a linux bug, I have the test cases is constructed. I can stable recurring problems in fedora22(4.0.4) kernel version, arch for x86_64. I construct transparent huge page, when the parent and child process with MAP_SHARE, MAP_PRIVATE way to access the same huge page area, it has the opportunity to lead to huge page copy on write failure, and then it will munmap the child corresponding mmap area, but then the child mmap area with VM_MAYSHARE attributes, child process munmap this area can trigger VM_BUG_ON in set_vma_resv_flags functions (vma - > vm_flags & VM_MAYSHARE). There were a number of problems with the report (e.g. it's hugetlbfs that triggers this, not transparent huge pages) but it was fundamentally correct in that a VM_BUG_ON in set_vma_resv_flags() can be triggered that looks like this vma ffff8804651fd0d0 start 00007fc474e00000 end 00007fc475e00000 next ffff8804651fd018 prev ffff8804651fd188 mm ffff88046b1b1800 prot 8000000000000027 anon_vma (null) vm_ops ffffffff8182a7a0 pgoff 0 file ffff88106bdb9800 private_data (null) flags: 0x84400fb(read|write|shared|mayread|maywrite|mayexec|mayshare|dontexpand|hugetlb) ------------ kernel BUG at mm/hugetlb.c:462! SMP Modules linked in: xt_pkttype xt_LOG xt_limit [..] CPU: 38 PID: 26839 Comm: map Not tainted 4.0.4-default #1 Hardware name: Dell Inc. PowerEdge R810/0TT6JF, BIOS 2.7.4 04/26/2012 set_vma_resv_flags+0x2d/0x30 The VM_BUG_ON is correct because private and shared mappings have different reservation accounting but the warning clearly shows that the VMA is shared. When a private COW fails to allocate a new page then only the process that created the VMA gets the page -- all the children unmap the page. If the children access that data in the future then they get killed. The problem is that the same file is mapped shared and private. During the COW, the allocation fails, the VMAs are traversed to unmap the other private pages but a shared VMA is found and the bug is triggered. This patch identifies such VMAs and skips them. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Reported-by: SunDong <sund_sky@126.com> Reviewed-by: Michal Hocko <mhocko@suse.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: David Rientjes <rientjes@google.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-01mm/slab: fix unexpected index mapping result of kmalloc_size(INDEX_NODE+1)Joonsoo Kim
Commit description is copied from the original post of this bug: http://comments.gmane.org/gmane.linux.kernel.mm/135349 Kernels after v3.9 use kmalloc_size(INDEX_NODE + 1) to get the next larger cache size than the size index INDEX_NODE mapping. In kernels 3.9 and earlier we used malloc_sizes[INDEX_L3 + 1].cs_size. However, sometimes we can't get the right output we expected via kmalloc_size(INDEX_NODE + 1), causing a BUG(). The mapping table in the latest kernel is like: index = {0, 1, 2 , 3, 4, 5, 6, n} size = {0, 96, 192, 8, 16, 32, 64, 2^n} The mapping table before 3.10 is like this: index = {0 , 1 , 2, 3, 4 , 5 , 6, n} size = {32, 64, 96, 128, 192, 256, 512, 2^(n+3)} The problem on my mips64 machine is as follows: (1) When configured DEBUG_SLAB && DEBUG_PAGEALLOC && DEBUG_LOCK_ALLOC && DEBUG_SPINLOCK, the sizeof(struct kmem_cache_node) will be "150", and the macro INDEX_NODE turns out to be "2": #define INDEX_NODE kmalloc_index(sizeof(struct kmem_cache_node)) (2) Then the result of kmalloc_size(INDEX_NODE + 1) is 8. (3) Then "if(size >= kmalloc_size(INDEX_NODE + 1)" will lead to "size = PAGE_SIZE". (4) Then "if ((size >= (PAGE_SIZE >> 3))" test will be satisfied and "flags |= CFLGS_OFF_SLAB" will be covered. (5) if (flags & CFLGS_OFF_SLAB)" test will be satisfied and will go to "cachep->slabp_cache = kmalloc_slab(slab_size, 0u)", and the result here may be NULL while kernel bootup. (6) Finally,"BUG_ON(ZERO_OR_NULL_PTR(cachep->slabp_cache));" causes the BUG info as the following shows (may be only mips64 has this problem): This patch fixes the problem of kmalloc_size(INDEX_NODE + 1) and removes the BUG by adding 'size >= 256' check to guarantee that all necessary small sized slabs are initialized regardless sequence of slab size in mapping table. Fixes: e33660165c90 ("slab: Use common kmalloc_index/kmalloc_size...") Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Liuhailong <liu.hailong6@zte.com.cn> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22vmscan: fix sane_reclaim helper for legacy memcgVladimir Davydov
The sane_reclaim() helper is supposed to return false for memcg reclaim if the legacy hierarchy is used, because the latter lacks dirty throttling mechanism, and so it did before it was accidentally broken by commit 33398cf2f360c ("memcg: export struct mem_cgroup"). Fix it. Fixes: 33398cf2f360c ("memcg: export struct mem_cgroup") Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22mm: migrate: hugetlb: putback destination hugepage to active listNaoya Horiguchi
Since commit bcc54222309c ("mm: hugetlb: introduce page_huge_active") each hugetlb page maintains its active flag to avoid a race condition betwe= en multiple calls of isolate_huge_page(), but current kernel doesn't set the f= lag on a hugepage allocated by migration because the proper putback routine isn= 't called. This means that users could still encounter the race referred to by bcc54222309c in this special case, so this patch fixes it. Fixes: bcc54222309c ("mm: hugetlb: introduce page_huge_active") Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Andi Kleen <andi@firstfloor.org> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> [4.1.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22mm, dax: VMA with vm_ops->pfn_mkwrite wants to be write-notifiedKirill A. Shutemov
For VM_PFNMAP and VM_MIXEDMAP we use vm_ops->pfn_mkwrite instead of vm_ops->page_mkwrite to notify abort write access. This means we want vma->vm_page_prot to be write-protected if the VMA provides this vm_ops. A theoretical scenario that will cause these missed events is: On writable mapping with vm_ops->pfn_mkwrite, but without vm_ops->page_mkwrite: read fault followed by write access to the pfn. Writable pte will be set up on read fault and write fault will not be generated. I found it examining Dave's complaint on generic/080: http://lkml.kernel.org/g/20150831233803.GO3902@dastard Although I don't think it's the reason. It shouldn't be a problem for ext2/ext4 as they provide both pfn_mkwrite and page_mkwrite. [akpm@linux-foundation.org: add local vm_ops to avoid 80-cols mess] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Yigal Korman <yigal@plexistor.com> Acked-by: Boaz Harrosh <boaz@plexistor.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Jan Kara <jack@suse.cz> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-17revert "mm: make sure all file VMAs have ->vm_ops set"Andrew Morton
Revert commit 6dc296e7df4c "mm: make sure all file VMAs have ->vm_ops set". Will Deacon reports that it "causes some mmap regressions in LTP, which appears to use a MAP_PRIVATE mmap of /dev/zero as a way to get anonymous pages in some of its tests (specifically mmap10 [1])". William Shuman reports Oracle crashes. So revert the patch while we work out what to do. Reported-by: William Shuman <wshuman3@gmail.com> Reported-by: Will Deacon <will.deacon@arm.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-17kasan: fix last shadow judgement in memory_is_poisoned_16()Xishi Qiu
The shadow which correspond 16 bytes memory may span 2 or 3 bytes. If the memory is aligned on 8, then the shadow takes only 2 bytes. So we check "shadow_first_bytes" is enough, and need not to call "memory_is_poisoned_1(addr + 15);". But the code "if (likely(!last_byte))" is wrong judgement. e.g. addr=0, so last_byte = 15 & KASAN_SHADOW_MASK = 7, then the code will continue to call "memory_is_poisoned_1(addr + 15);" Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Michal Marek <mmarek@suse.cz> Cc: <zhongjiang@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-11Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fourth patch-bomb from Andrew Morton: - sys_membarier syscall - seq_file interface changes - a few misc fixups * emailed patches from Andrew Morton <akpm@linux-foundation.org>: revert "ocfs2/dlm: use list_for_each_entry instead of list_for_each" mm/early_ioremap: add explicit #include of asm/early_ioremap.h fs/seq_file: convert int seq_vprint/seq_printf/etc... returns to void selftests: enhance membarrier syscall test selftests: add membarrier syscall test sys_membarrier(): system-wide memory barrier (generic, x86) MODSIGN: fix a compilation warning in extract-cert
2015-09-11Merge tag 'media/v4.3-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "A series of patches that move part of the code used to allocate memory from the media subsystem to the mm subsystem" [ The mm parts have been acked by VM people, and the series was apparently in -mm for a while - Linus ] * tag 'media/v4.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] drm/exynos: Convert g2d_userptr_get_dma_addr() to use get_vaddr_frames() [media] media: vb2: Remove unused functions [media] media: vb2: Convert vb2_dc_get_userptr() to use frame vector [media] media: vb2: Convert vb2_vmalloc_get_userptr() to use frame vector [media] media: vb2: Convert vb2_dma_sg_get_userptr() to use frame vector [media] vb2: Provide helpers for mapping virtual addresses [media] media: omap_vout: Convert omap_vout_uservirt_to_phys() to use get_vaddr_pfns() [media] mm: Provide new get_vaddr_frames() helper [media] vb2: Push mmap_sem down to memops
2015-09-11mm/early_ioremap: add explicit #include of asm/early_ioremap.hArd Biesheuvel
Commit 6b0f68e32ea8 ("mm: add utility for early copy from unmapped ram") introduces a function copy_from_early_mem() into mm/early_ioremap.c which itself calls early_memremap()/early_memunmap(). However, since early_memunmap() has not been declared yet at this point in the .c file, nor by any explicitly included header files, we are depending on a transitive include of asm/early_ioremap.h to declare it, which is fragile. So instead, include this header explicitly. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Mark Salter <msalter@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10Merge branch 'for-4.3/blkcg' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull blk-cg updates from Jens Axboe: "A bit later in the cycle, but this has been in the block tree for a a while. This is basically four patchsets from Tejun, that improve our buffered cgroup writeback. It was dependent on the other cgroup changes, but they went in earlier in this cycle. Series 1 is set of 5 patches that has cgroup writeback updates: - bdi_writeback iteration fix which could lead to some wb's being skipped or repeated during e.g. sync under memory pressure. - Simplification of wb work wait mechanism. - Writeback tracepoints updated to report cgroup. Series 2 is is a set of updates for the CFQ cgroup writeback handling: cfq has always charged all async IOs to the root cgroup. It didn't have much choice as writeback didn't know about cgroups and there was no way to tell who to blame for a given writeback IO. writeback finally grew support for cgroups and now tags each writeback IO with the appropriate cgroup to charge it against. This patchset updates cfq so that it follows the blkcg each bio is tagged with. Async cfq_queues are now shared across cfq_group, which is per-cgroup, instead of per-request_queue cfq_data. This makes all IOs follow the weight based IO resource distribution implemented by cfq. - Switched from GFP_ATOMIC to GFP_NOWAIT as suggested by Jeff. - Other misc review points addressed, acks added and rebased. Series 3 is the blkcg policy cleanup patches: This patchset contains assorted cleanups for blkcg_policy methods and blk[c]g_policy_data handling. - alloc/free added for blkg_policy_data. exit dropped. - alloc/free added for blkcg_policy_data. - blk-throttle's async percpu allocation is replaced with direct allocation. - all methods now take blk[c]g_policy_data instead of blkcg_gq or blkcg. And finally, series 4 is a set of patches cleaning up the blkcg stats handling: blkcg's stats have always been somwhat of a mess. This patchset tries to improve the situation a bit. - The following patches added to consolidate blkcg entry point and blkg creation. This is in itself is an improvement and helps colllecting common stats on bio issue. - per-blkg stats now accounted on bio issue rather than request completion so that bio based and request based drivers can behave the same way. The issue was spotted by Vivek. - cfq-iosched implements custom recursive stats and blk-throttle implements custom per-cpu stats. This patchset make blkcg core support both by default. - cfq-iosched and blk-throttle keep track of the same stats multiple times. Unify them" * 'for-4.3/blkcg' of git://git.kernel.dk/linux-block: (45 commits) blkcg: use CGROUP_WEIGHT_* scale for io.weight on the unified hierarchy blkcg: s/CFQ_WEIGHT_*/CFQ_WEIGHT_LEGACY_*/ blkcg: implement interface for the unified hierarchy blkcg: misc preparations for unified hierarchy interface blkcg: separate out tg_conf_updated() from tg_set_conf() blkcg: move body parsing from blkg_conf_prep() to its callers blkcg: mark existing cftypes as legacy blkcg: rename subsystem name from blkio to io blkcg: refine error codes returned during blkcg configuration blkcg: remove unnecessary NULL checks from __cfqg_set_weight_device() blkcg: reduce stack usage of blkg_rwstat_recursive_sum() blkcg: remove cfqg_stats->sectors blkcg: move io_service_bytes and io_serviced stats into blkcg_gq blkcg: make blkg_[rw]stat_recursive_sum() to be able to index into blkcg_gq blkcg: make blkcg_[rw]stat per-cpu blkcg: add blkg_[rw]stat->aux_cnt and replace cfq_group->dead_stats with it blkcg: consolidate blkg creation in blkcg_bio_issue_check() blk-throttle: improve queue bypass handling blkcg: move root blkg lookup optimization from throtl_lookup_tg() to __blkg_lookup() blkcg: inline [__]blkg_lookup() ...
2015-09-10mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd()Kirill A. Shutemov
Let's use helper rather than direct check of vma->vm_ops to distinguish anonymous VMA. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Minchan Kim <minchan@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10mm: make sure all file VMAs have ->vm_ops setKirill A. Shutemov
We rely on vma->vm_ops == NULL to detect anonymous VMA: see vma_is_anonymous(), but some drivers doesn't set ->vm_ops. As a result we can end up with anonymous page in private file mapping. That should not lead to serious misbehaviour, but nevertheless is wrong. Let's fix by setting up dummy ->vm_ops for file mmapping if f_op->mmap() didn't set its own. The patch also adds sanity check into __vma_link_rb(). It will help catch broken VMAs which inserted directly into mm_struct via insert_vm_struct(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Minchan Kim <minchan@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff()Oleg Nesterov
Add the additional "vm_flags_t vm_flags" argument to do_mmap_pgoff(), rename it to do_mmap(), and re-introduce do_mmap_pgoff() as a simple wrapper on top of do_mmap(). Perhaps we should update the callers of do_mmap_pgoff() and kill it later. This way mpx_mmap() can simply call do_mmap(vm_flags => VM_MPX) and do not play with vm internals. After this change mmap_region() has a single user outside of mmap.c, arch/tile/mm/elf.c:arch_setup_additional_pages(). It would be nice to change arch/tile/ and unexport mmap_region(). [kirill@shutemov.name: fix build] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Dave Hansen <dave.hansen@linux.intel.com> Tested-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Minchan Kim <minchan@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10kmemleak: use seq_hex_dump() to dump buffersAndy Shevchenko
Instead of custom approach let's use recently introduced seq_hex_dump() helper. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Joe Perches <joe@perches.com> Cc: Tadeusz Struk <tadeusz.struk@intel.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10mm: introduce idle page trackingVladimir Davydov
Knowing the portion of memory that is not used by a certain application or memory cgroup (idle memory) can be useful for partitioning the system efficiently, e.g. by setting memory cgroup limits appropriately. Currently, the only means to estimate the amount of idle memory provided by the kernel is /proc/PID/{clear_refs,smaps}: the user can clear the access bit for all pages mapped to a particular process by writing 1 to clear_refs, wait for some time, and then count smaps:Referenced. However, this method has two serious shortcomings: - it does not count unmapped file pages - it affects the reclaimer logic To overcome these drawbacks, this patch introduces two new page flags, Idle and Young, and a new sysfs file, /sys/kernel/mm/page_idle/bitmap. A page's Idle flag can only be set from userspace by setting bit in /sys/kernel/mm/page_idle/bitmap at the offset corresponding to the page, and it is cleared whenever the page is accessed either through page tables (it is cleared in page_referenced() in this case) or using the read(2) system call (mark_page_accessed()). Thus by setting the Idle flag for pages of a particular workload, which can be found e.g. by reading /proc/PID/pagemap, waiting for some time to let the workload access its working set, and then reading the bitmap file, one can estimate the amount of pages that are not used by the workload. The Young page flag is used to avoid interference with the memory reclaimer. A page's Young flag is set whenever the Access bit of a page table entry pointing to the page is cleared by writing to the bitmap file. If page_referenced() is called on a Young page, it will add 1 to its return value, therefore concealing the fact that the Access bit was cleared. Note, since there is no room for extra page flags on 32 bit, this feature uses extended page flags when compiled on 32 bit. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: kpageidle requires an MMU] [akpm@linux-foundation.org: decouple from page-flags rework] Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10mmu-notifier: add clear_young callbackVladimir Davydov
In the scope of the idle memory tracking feature, which is introduced by the following patch, we need to clear the referenced/accessed bit not only in primary, but also in secondary ptes. The latter is required in order to estimate wss of KVM VMs. At the same time we want to avoid flushing tlb, because it is quite expensive and it won't really affect the final result. Currently, there is no function for clearing pte young bit that would meet our requirements, so this patch introduces one. To achieve that we have to add a new mmu-notifier callback, clear_young, since there is no method for testing-and-clearing a secondary pte w/o flushing tlb. The new method is not mandatory and currently only implemented by KVM. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Acked-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10memcg: zap try_get_mem_cgroup_from_pageVladimir Davydov
It is only used in mem_cgroup_try_charge, so fold it in and zap it. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10hwpoison: use page_cgroup_ino for filtering by memcgVladimir Davydov
Hwpoison allows to filter pages by memory cgroup ino. Currently, it calls try_get_mem_cgroup_from_page to obtain the cgroup from a page and then its ino using cgroup_ino, but now we have a helper method for that, page_cgroup_ino, so use it instead. This patch also loosens the hwpoison memcg filter dependency rules - it makes it depend on CONFIG_MEMCG instead of CONFIG_MEMCG_SWAP, because hwpoison memcg filter does not require anything (nor it used to) from CONFIG_MEMCG_SWAP side. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10memcg: add page_cgroup_ino helperVladimir Davydov
This patchset introduces a new user API for tracking user memory pages that have not been used for a given period of time. The purpose of this is to provide the userspace with the means of tracking a workload's working set, i.e. the set of pages that are actively used by the workload. Knowing the working set size can be useful for partitioning the system more efficiently, e.g. by tuning memory cgroup limits appropriately, or for job placement within a compute cluster. ==== USE CASES ==== The unified cgroup hierarchy has memory.low and memory.high knobs, which are defined as the low and high boundaries for the workload working set size. However, the working set size of a workload may be unknown or change in time. With this patch set, one can periodically estimate the amount of memory unused by each cgroup and tune their memory.low and memory.high parameters accordingly, therefore optimizing the overall memory utilization. Another use case is balancing workloads within a compute cluster. Knowing how much memory is not really used by a workload unit may help take a more optimal decision when considering migrating the unit to another node within the cluster. Also, as noted by Minchan, this would be useful for per-process reclaim (https://lwn.net/Articles/545668/). With idle tracking, we could reclaim idle pages only by smart user memory manager. ==== USER API ==== The user API consists of two new files: * /sys/kernel/mm/page_idle/bitmap. This file implements a bitmap where each bit corresponds to a page, indexed by PFN. When the bit is set, the corresponding page is idle. A page is considered idle if it has not been accessed since it was marked idle. To mark a page idle one should set the bit corresponding to the page by writing to the file. A value written to the file is OR-ed with the current bitmap value. Only user memory pages can be marked idle, for other page types input is silently ignored. Writing to this file beyond max PFN results in the ENXIO error. Only available when CONFIG_IDLE_PAGE_TRACKING is set. This file can be used to estimate the amount of pages that are not used by a particular workload as follows: 1. mark all pages of interest idle by setting corresponding bits in the /sys/kernel/mm/page_idle/bitmap 2. wait until the workload accesses its working set 3. read /sys/kernel/mm/page_idle/bitmap and count the number of bits set * /proc/kpagecgroup. This file contains a 64-bit inode number of the memory cgroup each page is charged to, indexed by PFN. Only available when CONFIG_MEMCG is set. This file can be used to find all pages (including unmapped file pages) accounted to a particular cgroup. Using /sys/kernel/mm/page_idle/bitmap, one can then estimate the cgroup working set size. For an example of using these files for estimating the amount of unused memory pages per each memory cgroup, please see the script attached below. ==== REASONING ==== The reason to introduce the new user API instead of using /proc/PID/{clear_refs,smaps} is that the latter has two serious drawbacks: - it does not count unmapped file pages - it affects the reclaimer logic The new API attempts to overcome them both. For more details on how it is achieved, please see the comment to patch 6. ==== PATCHSET STRUCTURE ==== The patch set is organized as follows: - patch 1 adds page_cgroup_ino() helper for the sake of /proc/kpagecgroup and patches 2-3 do related cleanup - patch 4 adds /proc/kpagecgroup, which reports cgroup ino each page is charged to - patch 5 introduces a new mmu notifier callback, clear_young, which is a lightweight version of clear_flush_young; it is used in patch 6 - patch 6 implements the idle page tracking feature, including the userspace API, /sys/kernel/mm/page_idle/bitmap - patch 7 exports idle flag via /proc/kpageflags ==== SIMILAR WORKS ==== Originally, the patch for tracking idle memory was proposed back in 2011 by Michel Lespinasse (see http://lwn.net/Articles/459269/). The main difference between Michel's patch and this one is that Michel implemented a kernel space daemon for estimating idle memory size per cgroup while this patch only provides the userspace with the minimal API for doing the job, leaving the rest up to the userspace. However, they both share the same idea of Idle/Young page flags to avoid affecting the reclaimer logic. ==== PERFORMANCE EVALUATION ==== SPECjvm2008 (https://www.spec.org/jvm2008/) was used to evaluate the performance impact introduced by this patch set. Three runs were carried out: - base: kernel without the patch - patched: patched kernel, the feature is not used - patched-active: patched kernel, 1 minute-period daemon is used for tracking idle memory For tracking idle memory, idlememstat utility was used: https://github.com/locker/idlememstat testcase base patched patched-active compiler 537.40 ( 0.00)% 532.26 (-0.96)% 538.31 ( 0.17)% compress 305.47 ( 0.00)% 301.08 (-1.44)% 300.71 (-1.56)% crypto 284.32 ( 0.00)% 282.21 (-0.74)% 284.87 ( 0.19)% derby 411.05 ( 0.00)% 413.44 ( 0.58)% 412.07 ( 0.25)% mpegaudio 189.96 ( 0.00)% 190.87 ( 0.48)% 189.42 (-0.28)% scimark.large 46.85 ( 0.00)% 46.41 (-0.94)% 47.83 ( 2.09)% scimark.small 412.91 ( 0.00)% 415.41 ( 0.61)% 421.17 ( 2.00)% serial 204.23 ( 0.00)% 213.46 ( 4.52)% 203.17 (-0.52)% startup 36.76 ( 0.00)% 35.49 (-3.45)% 35.64 (-3.05)% sunflow 115.34 ( 0.00)% 115.08 (-0.23)% 117.37 ( 1.76)% xml 620.55 ( 0.00)% 619.95 (-0.10)% 620.39 (-0.03)% composite 211.50 ( 0.00)% 211.15 (-0.17)% 211.67 ( 0.08)% time idlememstat: 17.20user 65.16system 2:15:23elapsed 1%CPU (0avgtext+0avgdata 8476maxresident)k 448inputs+40outputs (1major+36052minor)pagefaults 0swaps ==== SCRIPT FOR COUNTING IDLE PAGES PER CGROUP ==== #! /usr/bin/python # import os import stat import errno import struct CGROUP_MOUNT = "/sys/fs/cgroup/memory" BUFSIZE = 8 * 1024 # must be multiple of 8 def get_hugepage_size(): with open("/proc/meminfo", "r") as f: for s in f: k, v = s.split(":") if k == "Hugepagesize": return int(v.split()[0]) * 1024 PAGE_SIZE = os.sysconf("SC_PAGE_SIZE") HUGEPAGE_SIZE = get_hugepage_size() def set_idle(): f = open("/sys/kernel/mm/page_idle/bitmap", "wb", BUFSIZE) while True: try: f.write(struct.pack("Q", pow(2, 64) - 1)) except IOError as err: if err.errno == errno.ENXIO: break raise f.close() def count_idle(): f_flags = open("/proc/kpageflags", "rb", BUFSIZE) f_cgroup = open("/proc/kpagecgroup", "rb", BUFSIZE) with open("/sys/kernel/mm/page_idle/bitmap", "rb", BUFSIZE) as f: while f.read(BUFSIZE): pass # update idle flag idlememsz = {} while True: s1, s2 = f_flags.read(8), f_cgroup.read(8) if not s1 or not s2: break flags, = struct.unpack('Q', s1) cgino, = struct.unpack('Q', s2) unevictable = (flags >> 18) & 1 huge = (flags >> 22) & 1 idle = (flags >> 25) & 1 if idle and not unevictable: idlememsz[cgino] = idlememsz.get(cgino, 0) + \ (HUGEPAGE_SIZE if huge else PAGE_SIZE) f_flags.close() f_cgroup.close() return idlememsz if __name__ == "__main__": print "Setting the idle flag for each page..." set_idle() raw_input("Wait until the workload accesses its working set, " "then press Enter") print "Counting idle pages..." idlememsz = count_idle() for dir, subdirs, files in os.walk(CGROUP_MOUNT): ino = os.stat(dir)[stat.ST_INO] print dir + ": " + str(idlememsz.get(ino, 0) / 1024) + " kB" ==== END SCRIPT ==== This patch (of 8): Add page_cgroup_ino() helper to memcg. This function returns the inode number of the closest online ancestor of the memory cgroup a page is charged to. It is required for exporting information about which page is charged to which cgroup to userspace, which will be introduced by a following patch. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10zswap: change zpool/compressor at runtimeDan Streetman
Update the zpool and compressor parameters to be changeable at runtime. When changed, a new pool is created with the requested zpool/compressor, and added as the current pool at the front of the pool list. Previous pools remain in the list only to remove existing compressed pages from. The old pool(s) are removed once they become empty. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Acked-by: Seth Jennings <sjennings@variantweb.net> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10zswap: dynamic pool creationDan Streetman
Add dynamic creation of pools. Move the static crypto compression per-cpu transforms into each pool. Add a pointer to zswap_entry to the pool it's in. This is required by the following patch which enables changing the zswap zpool and compressor params at runtime. [akpm@linux-foundation.org: fix merge snafus] Signed-off-by: Dan Streetman <ddstreet@ieee.org> Acked-by: Seth Jennings <sjennings@variantweb.net> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10zpool: add zpool_has_pool()Dan Streetman
This series makes creation of the zpool and compressor dynamic, so that they can be changed at runtime. This makes using/configuring zswap easier, as before this zswap had to be configured at boot time, using boot params. This uses a single list to track both the zpool and compressor together, although Seth had mentioned an alternative which is to track the zpools and compressors using separate lists. In the most common case, only a single zpool and single compressor, using one list is slightly simpler than using two lists, and for the uncommon case of multiple zpools and/or compressors, using one list is slightly less simple (and uses slightly more memory, probably) than using two lists. This patch (of 4): Add zpool_has_pool() function, indicating if the specified type of zpool is available (i.e. zsmalloc or zbud). This allows checking if a pool is available, without actually trying to allocate it, similar to crypto_has_alg(). This is used by a following patch to zswap that enables the dynamic runtime creation of zswap zpools. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Acked-by: Seth Jennings <sjennings@variantweb.net> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: "Almost all of the rest of MM. There was an unusually large amount of MM material this time" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (141 commits) zpool: remove no-op module init/exit mm: zbud: constify the zbud_ops mm: zpool: constify the zpool_ops mm: swap: zswap: maybe_preload & refactoring zram: unify error reporting zsmalloc: remove null check from destroy_handle_cache() zsmalloc: do not take class lock in zs_shrinker_count() zsmalloc: use class->pages_per_zspage zsmalloc: consider ZS_ALMOST_FULL as migrate source zsmalloc: partial page ordering within a fullness_list zsmalloc: use shrinker to trigger auto-compaction zsmalloc: account the number of compacted pages zsmalloc/zram: introduce zs_pool_stats api zsmalloc: cosmetic compaction code adjustments zsmalloc: introduce zs_can_compact() function zsmalloc: always keep per-class stats zsmalloc: drop unused variable `nr_to_migrate' mm/memblock.c: fix comment in __next_mem_range() mm/page_alloc.c: fix type information of memoryless node memory-hotplug: fix comments in zone_spanned_pages_in_node() and zone_spanned_pages_in_node() ...
2015-09-08zpool: remove no-op module init/exitDan Streetman
Remove zpool_init() and zpool_exit(); they do nothing other than print "loaded" and "unloaded". Signed-off-by: Dan Streetman <ddstreet@ieee.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm: zbud: constify the zbud_opsKrzysztof Kozlowski
The structure zbud_ops is not modified so make the pointer to it a pointer to const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Dan Streetman <ddstreet@ieee.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm: zpool: constify the zpool_opsKrzysztof Kozlowski
The structure zpool_ops is not modified so make the pointer to it a pointer to const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Dan Streetman <ddstreet@ieee.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm: swap: zswap: maybe_preload & refactoringDmitry Safonov
zswap_get_swap_cache_page and read_swap_cache_async have pretty much the same code with only significant difference in return value and usage of swap_readpage. I a helper __read_swap_cache_async() with the common code. Behavior change: now zswap_get_swap_cache_page will use radix_tree_maybe_preload instead radix_tree_preload. Looks like, this wasn't changed only by the reason of code duplication. Signed-off-by: Dmitry Safonov <0x7f454c46@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@fb.com> Cc: Christoph Hellwig <hch@lst.de> Cc: David Herrmann <dh.herrmann@gmail.com> Cc: Seth Jennings <sjennings@variantweb.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: remove null check from destroy_handle_cache()Sergey Senozhatsky
We can pass a NULL cache pointer to kmem_cache_destroy(), because it NULL-checks its argument now. Remove redundant test from destroy_handle_cache(). Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: do not take class lock in zs_shrinker_count()Sergey Senozhatsky
We can avoid taking class ->lock around zs_can_compact() in zs_shrinker_count(), because the number that we return back is outdated in general case, by design. We have different sources that are able to change class's state right after we return from zs_can_compact() -- ongoing I/O operations, manually triggered compaction, or two of them happening simultaneously. We re-do this calculations during compaction on a per class basis anyway. zs_unregister_shrinker() will not return until we have an active shrinker, so classes won't unexpectedly disappear while zs_shrinker_count() iterates them. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: use class->pages_per_zspageMinchan Kim
There is no need to recalcurate pages_per_zspage in runtime. Just use class->pages_per_zspage to avoid unnecessary runtime overhead. Signed-off-by: Minchan Kim <minchan@kernel.org> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: consider ZS_ALMOST_FULL as migrate sourceMinchan Kim
There is no reason to prevent select ZS_ALMOST_FULL as migration source if we cannot find source from ZS_ALMOST_EMPTY. With this patch, zs_can_compact will return more exact result. Signed-off-by: Minchan Kim <minchan.kim@lge.com> Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: partial page ordering within a fullness_listSergey Senozhatsky
We want to see more ZS_FULL pages and less ZS_ALMOST_{FULL, EMPTY} pages. Put a page with higher ->inuse count first within its ->fullness_list, which will give us better chances to fill up this page with new objects (find_get_zspage() return ->fullness_list head for new object allocation), so some zspages will become ZS_ALMOST_FULL/ZS_FULL quicker. It performs a trivial and cheap ->inuse compare which does not slow down zsmalloc and in the worst case keeps the list pages in no particular order. A more expensive solution could sort fullness_list by ->inuse count. [minchan@kernel.org: code adjustments] Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: use shrinker to trigger auto-compactionSergey Senozhatsky
Perform automatic pool compaction by a shrinker when system is getting tight on memory. User-space has a very little knowledge regarding zsmalloc fragmentation and basically has no mechanism to tell whether compaction will result in any memory gain. Another issue is that user space is not always aware of the fact that system is getting tight on memory. Which leads to very uncomfortable scenarios when user space may start issuing compaction 'randomly' or from crontab (for example). Fragmentation is not always necessarily bad, allocated and unused objects, after all, may be filled with the data later, w/o the need of allocating a new zspage. On the other hand, we obviously don't want to waste memory when the system needs it. Compaction now has a relatively quick pool scan so we are able to estimate the number of pages that will be freed easily, which makes it possible to call this function from a shrinker->count_objects() callback. We also abort compaction as soon as we detect that we can't free any pages any more, preventing wasteful objects migrations. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Suggested-by: Minchan Kim <minchan@kernel.org> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: account the number of compacted pagesSergey Senozhatsky
Compaction returns back to zram the number of migrated objects, which is quite uninformative -- we have objects of different sizes so user space cannot obtain any valuable data from that number. Change compaction to operate in terms of pages and return back to compaction issuer the number of pages that were freed during compaction. So from now on we will export more meaningful value in zram<id>/mm_stat -- the number of freed (compacted) pages. This requires: (a) a rename of `num_migrated' to 'pages_compacted' (b) a internal API change -- return first_page's fullness_group from putback_zspage(), so we know when putback_zspage() did free_zspage(). It helps us to account compaction stats correctly. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc/zram: introduce zs_pool_stats apiSergey Senozhatsky
`zs_compact_control' accounts the number of migrated objects but it has a limited lifespan -- we lose it as soon as zs_compaction() returns back to zram. It worked fine, because (a) zram had it's own counter of migrated objects and (b) only zram could trigger compaction. However, this does not work for automatic pool compaction (not issued by zram). To account objects migrated during auto-compaction (issued by the shrinker) we need to store this number in zs_pool. Define a new `struct zs_pool_stats' structure to keep zs_pool's stats there. It provides only `num_migrated', as of this writing, but it surely can be extended. A new zsmalloc zs_pool_stats() symbol exports zs_pool's stats back to caller. Use zs_pool_stats() in zram and remove `num_migrated' from zram_stats. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Suggested-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: cosmetic compaction code adjustmentsSergey Senozhatsky
Change zs_object_copy() argument order to be (DST, SRC) rather than (SRC, DST). copy/move functions usually have (to, from) arguments order. Rename alloc_target_page() to isolate_target_page(). This function doesn't allocate anything, it isolates target page, pretty much like isolate_source_page(). Tweak __zs_compact() comment. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: introduce zs_can_compact() functionSergey Senozhatsky
This function checks if class compaction will free any pages. Rephrasing -- do we have enough unused objects to form at least one ZS_EMPTY page and free it. It aborts compaction if class compaction will not result in any (further) savings. EXAMPLE (this debug output is not part of this patch set): - class size - number of allocated objects - number of used objects - max objects per zspage - pages per zspage - estimated number of pages that will be freed [..] class-512 objs:544 inuse:540 maxobj-per-zspage:8 pages-per-zspage:1 zspages-to-free:0 ... class-512 compaction is useless. break class-496 objs:660 inuse:570 maxobj-per-zspage:33 pages-per-zspage:4 zspages-to-free:2 class-496 objs:627 inuse:570 maxobj-per-zspage:33 pages-per-zspage:4 zspages-to-free:1 class-496 objs:594 inuse:570 maxobj-per-zspage:33 pages-per-zspage:4 zspages-to-free:0 ... class-496 compaction is useless. break class-448 objs:657 inuse:617 maxobj-per-zspage:9 pages-per-zspage:1 zspages-to-free:4 class-448 objs:648 inuse:617 maxobj-per-zspage:9 pages-per-zspage:1 zspages-to-free:3 class-448 objs:639 inuse:617 maxobj-per-zspage:9 pages-per-zspage:1 zspages-to-free:2 class-448 objs:630 inuse:617 maxobj-per-zspage:9 pages-per-zspage:1 zspages-to-free:1 class-448 objs:621 inuse:617 maxobj-per-zspage:9 pages-per-zspage:1 zspages-to-free:0 ... class-448 compaction is useless. break class-432 objs:728 inuse:685 maxobj-per-zspage:28 pages-per-zspage:3 zspages-to-free:1 class-432 objs:700 inuse:685 maxobj-per-zspage:28 pages-per-zspage:3 zspages-to-free:0 ... class-432 compaction is useless. break class-416 objs:819 inuse:705 maxobj-per-zspage:39 pages-per-zspage:4 zspages-to-free:2 class-416 objs:780 inuse:705 maxobj-per-zspage:39 pages-per-zspage:4 zspages-to-free:1 class-416 objs:741 inuse:705 maxobj-per-zspage:39 pages-per-zspage:4 zspages-to-free:0 ... class-416 compaction is useless. break class-400 objs:690 inuse:674 maxobj-per-zspage:10 pages-per-zspage:1 zspages-to-free:1 class-400 objs:680 inuse:674 maxobj-per-zspage:10 pages-per-zspage:1 zspages-to-free:0 ... class-400 compaction is useless. break class-384 objs:736 inuse:709 maxobj-per-zspage:32 pages-per-zspage:3 zspages-to-free:0 ... class-384 compaction is useless. break [..] Every "compaction is useless" indicates that we saved CPU cycles. class-512 has 544 object allocated 540 objects used 8 objects per-page Even if we have a ALMOST_EMPTY zspage, we still don't have enough room to migrate all of its objects and free this zspage; so compaction will not make a lot of sense, it's better to just leave it as is. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: always keep per-class statsSergey Senozhatsky
Always account per-class `zs_size_stat' stats. This data will help us make better decisions during compaction. We are especially interested in OBJ_ALLOCATED and OBJ_USED, which can tell us if class compaction will result in any memory gain. For instance, we know the number of allocated objects in the class, the number of objects being used (so we also know how many objects are not used) and the number of objects per-page. So we can ensure if we have enough unused objects to form at least one ZS_EMPTY zspage during compaction. We calculate this value on per-class basis so we can calculate a total number of zspages that can be released. Which is exactly what a shrinker wants to know. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08zsmalloc: drop unused variable `nr_to_migrate'Sergey Senozhatsky
This patchset tweaks compaction and makes it possible to trigger pool compaction automatically when system is getting low on memory. zsmalloc in some cases can suffer from a notable fragmentation and compaction can release some considerable amount of memory. The problem here is that currently we fully rely on user space to perform compaction when needed. However, performing zsmalloc compaction is not always an obvious thing to do. For example, suppose we have a `idle' fragmented (compaction was never performed) zram device and system is getting low on memory due to some 3rd party user processes (gcc LTO, or firefox, etc.). It's quite unlikely that user space will issue zpool compaction in this case. Besides, user space cannot tell for sure how badly pool is fragmented; however, this info is known to zsmalloc and, hence, to a shrinker. This patch (of 7): __zs_compact() does not use `nr_to_migrate', drop it. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/memblock.c: fix comment in __next_mem_range()Alexander Kuleshov
Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/page_alloc.c: fix type information of memoryless nodeZhen Lei
For a memoryless node, the output of get_pfn_range_for_nid are all zero. It will display mem from 0 to -1. Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08memory-hotplug: fix comments in zone_spanned_pages_in_node() and ↵Xishi Qiu
zone_spanned_pages_in_node() When hot adding a node from add_memory(), we will add memblock first, so the node is not empty. But when called from cpu_up(), the node should be empty. Signed-off-by: Xishi Qiu <qiuxishi@huawei.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>\ Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/page_alloc.c: change sysctl_lower_zone_reserve_ratio to ↵Yaowei Bai
sysctl_lowmem_reserve_ratio in comments We use sysctl_lowmem_reserve_ratio rather than sysctl_lower_zone_reserve_ratio to determine how aggressive the kernel is in defending lowmem from the possibility of being captured into pinned user memory. To avoid misleading, correct it in some comments. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/page_alloc.c: fix a misleading commentYaowei Bai
The comment says that the per-cpu batchsize and zone watermarks are determined by present_pages which is definitely wrong, they are both calculated from managed_pages. Fix it. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/mmap.c:insert_vm_struct(): check for failure before setting valuesChen Gang
There's no point in initializing vma->vm_pgoff if the insertion attempt will be failing anyway. Run the checks before performing the initialization. Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Cc: Michal Hocko <mhocko@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
