On systems with huge amount of physical memory, VFS cache and memory memmap
may eat all available system memory under 4G, then the system may fail to
allocate swiotlb bounce buffer.
There was a fix for this issue in arch/x86_64/mm/numa.c, but that fix dose
not cover sparsemem model.
This patch add fix to sparsemem model by first try to allocate memmap above
4G.
Signed-off-by: Zou Nan hai <nanhai.zou@intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Andi Kleen <ak@suse.de>
Cc: <stable@kernel.org>
[chrisw: trivial backport]
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
The internal hugetlb resv_huge_pages variable can permanently leak nonzero
value in the error path of hugetlb page fault handler when hugetlb page is
used in combination of cpuset. The leaked count can permanently trap N
number of hugetlb pages in unusable "reserved" state.
Steps to reproduce the bug:
(1) create two cpuset, user1 and user2
(2) reserve 50 htlb pages in cpuset user1
(3) attempt to shmget/shmat 50 htlb page inside cpuset user2
(4) kernel oom the user process in step 3
(5) ipcrm the shm segment
At this point resv_huge_pages will have a count of 49, even though
there are no active hugetlbfs file nor hugetlb shared memory segment
in the system. The leak is permanent and there is no recovery method
other than system reboot. The leaked count will hold up all future use
of that many htlb pages in all cpusets.
The culprit is that the error path of alloc_huge_page() did not
properly undo the change it made to resv_huge_page, causing
inconsistent state.
Signed-off-by: Ken Chen <kenchen@google.com>
Cc: David Gibson <david@gibson.dropbear.id.au>
Cc: Adam Litke <agl@us.ibm.com>
Cc: Martin Bligh <mbligh@google.com>
Acked-by: David Gibson <dwg@au1.ibm.com>
SLOB doesn't calculate correct page order when page size is not 4KB. This
patch fixes it with using get_order() instead of find_order() which is SLOB
version of get_order().
Acked-by: Matt Mackall <mpm@selenic.com>
Fixes a deadlock in the OOM killer for allocations that are not
__GFP_HARDWALL.
Before the OOM killer checks for the allocation constraint, it takes
callback_mutex.
constrained_alloc() iterates through each zone in the allocation zonelist
and calls cpuset_zone_allowed_softwall() to determine whether an allocation
for gfp_mask is possible. If a zone's node is not in the OOM-triggering
task's mems_allowed, it is not exiting, and we did not fail on a
__GFP_HARDWALL allocation, cpuset_zone_allowed_softwall() attempts to take
callback_mutex to check the nearest exclusive ancestor of current's cpuset.
This results in deadlock.
We now take callback_mutex after iterating through the zonelist since we
don't need it yet.
Cc: Nick Piggin <npiggin@suse.de>
Cc: Christoph Lameter <clameter@engr.sgi.com>
Cc: Martin J. Bligh <mbligh@mbligh.org>
Signed-off-by: David Rientjes <rientjes@google.com>
NR_FILE_PAGES must be accounted for depending on the zone that the page
belongs to. If we replace the page in the radix tree then we may have to
shift the count to another zone.
Suggested-by: Ethan Solomita <solo@google.com>
Eventually-typed-in-by: Christoph Lameter <clameter@sgi.com>
Cc: Martin Bligh <mbligh@mbligh.org>
Signed-off-by: Christoph Lameter <clameter@sgi.com>
I only have CONFIG_NUMA=y for build testing: surprised when trying a memhog
to see lots of other processes killed with "No available memory
(MPOL_BIND)". memhog is killed correctly once we initialize nodemask in
constrained_alloc().
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Acked-by: Christoph Lameter <clameter@sgi.com>
Acked-by: William Irwin <bill.irwin@oracle.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
oom_kill_task() calls __oom_kill_task() to OOM kill a selected task.
When finding other threads that share an mm with that task, we need to
kill those individual threads and not the same one.
(Bug introduced by f2a2a7108aa0039ba7a5fe7a0d2ecef2219a7584)
Acked-by: Christoph Lameter <clameter@engr.sgi.com>
Cc: Andrew Morton <akpm@osdl.org>
num_physpages is not exported out in mm/nommu.c, so the ip_conntrack module
link will fail.
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
Acked-By: David Howells <dhowells@redhat.com>
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6:
[S390] cio: Fix handling of interrupt for csch().
[S390] page_mkclean data corruption.
Mention the slab name when listing corrupt objects. Although the function
that released the memory is mentioned, that is frequently ambiguous as such
functions often release several pieces of memory.
The git commit c2fda5fed81eea077363b285b66eafce20dfd45a which
added the page_test_and_clear_dirty call to page_mkclean and the
git commit 7658cc289288b8ae7dd2c2224549a048431222b3 which fixes
the "nasty and subtle race in shared mmap'ed page writeback"
problem in clear_page_dirty_for_io cause data corruption on s390.
The effect of the two changes is that for every call to
clear_page_dirty_for_io a page_test_and_clear_dirty is done. If
the per page dirty bit is set set_page_dirty is called. Strangly
clear_page_dirty_for_io is called for not-uptodate pages, e.g.
over this call-chain:
[<000000000007c0f2>] clear_page_dirty_for_io+0x12a/0x130
[<000000000007c494>] generic_writepages+0x258/0x3e0
[<000000000007c692>] do_writepages+0x76/0x7c
[<00000000000c7a26>] __writeback_single_inode+0xba/0x3e4
[<00000000000c831a>] sync_sb_inodes+0x23e/0x398
[<00000000000c8802>] writeback_inodes+0x12e/0x140
[<000000000007b9ee>] wb_kupdate+0xd2/0x178
[<000000000007cca2>] pdflush+0x162/0x23c
The bad news now is that page_test_and_clear_dirty might claim
that a not-uptodate page is dirty since SetPageUptodate which
resets the per page dirty bit has not yet been called. The page
writeback that follows clobbers the data on disk.
The simplest solution to this problem is to move the call to
page_test_and_clear_dirty under the "if (page_mapped(page))".
If a file backed page is mapped it is uptodate.
Fix the bug, that reading into xip mapping from /dev/zero fills the user
page table with ZERO_PAGE() entries. Later on, xip cannot tell which pages
have been ZERO_PAGE() filled by access to a sparse mapping, and which ones
origin from /dev/zero. It will unmap ZERO_PAGE from all mappings when
filling the sparse hole with data. xip does now use its own zeroed page
for its sparse mappings. Please apply.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
sys_madvise has down_write of mmap_sem, then madvise_remove calls
vmtruncate_range which takes i_mutex and i_alloc_sem: no, we can easily devise
deadlocks from that ordering.
madvise_remove drop mmap_sem while calling vmtruncate_range: luckily, since
madvise_remove doesn't split or merge vmas, it's easy to handle this case with
a NULL prev, without restructuring sys_madvise. (Though sad to retake
mmap_sem when it's unlikely to be needed, and certainly down_read is
sufficient for MADV_REMOVE, unlike the other madvices.)
Cc: Miklos Szeredi <mszeredi@suse.cz>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
shmem_truncate_range has its own truncate_inode_pages_range, to free any pages
racily instantiated while it was in progress: a SHMEM_PAGEIN flag is set when
this might have happened. But holepunching gets no chance to clear that flag
at the start of vmtruncate_range, so it's always set (unless a truncate came
just before), so holepunch almost always does this second
truncate_inode_pages_range.
shmem holepunch has unlikely swap<->file races hereabouts whatever we do
(without a fuller rework than is fit for this release): I was going to skip
the second truncate in the punch_hole case, but Miklos points out that would
make holepunch correctness more vulnerable to swapoff. So keep the second
truncate, but follow it by an unmap_mapping_range to eliminate the
disconnected pages (freed from pagecache while still mapped in userspace) that
it might have left behind.
Miklos Szeredi observes that during truncation of shmem page directories,
info->lock is released to improve latency (after lowering i_size and
next_index to exclude races); but this is quite wrong for holepunching, which
receives no such protection from i_size or next_index, and is left vulnerable
to races with shmem_unuse, shmem_getpage and shmem_writepage.
Hold info->lock throughout when holepunching? No, any user could prevent
rescheduling for far too long. Instead take info->lock just when needed: in
shmem_free_swp when removing the swap entries, and whenever removing a
directory page from the level above. But so long as we remove before
scanning, we can safely skip taking the lock at the lower levels, except at
misaligned start and end of the hole.
Miklos Szeredi observes BUG_ON(!entry) in shmem_writepage() triggered in rare
circumstances, because shmem_truncate_range() erroneously removes partially
truncated directory pages at the end of the range: later reclaim on pages
pointing to these removed directories triggers the BUG. Indeed, and it can
also cause data loss beyond the hole.
Fix this as in the patch proposed by Miklos, but distinguish between "limit"
(how far we need to search: ignore truncation's next_index optimization in the
holepunch case - if there are races it's more consistent to act on the whole
range specified) and "upper_limit" (how far we can free directory pages:
generally we must be careful to keep partially punched pages, but can relax at
end of file - i_size being held stable by i_mutex).
Cc: Miklos Szeredi <mszeredi@suse.cs>
There is a small problem in handling page bounce.
At the moment blk_max_pfn equals max_pfn, which is in fact not maximum
possible _number_ of a page frame, but the _amount_ of page frames. For
example for the 32bit x86 node with 4Gb RAM, max_pfn = 0x100000, but not
0xFFFF.
request_queue structure has a member q->bounce_pfn and queue needs bounce
pages for the pages _above_ this limit. This routine is handled by
blk_queue_bounce(), where the following check is produced:
if (q->bounce_pfn >= blk_max_pfn)
return;
Assume, that a driver has set q->bounce_pfn to 0xFFFF, but blk_max_pfn
equals 0x10000. In such situation the check above fails and for each bio
we always fall down for iterating over pages tied to the bio.
I want to notice, that for quite a big range of device drivers (ide, md,
...) such problem doesn't happen because they use BLK_BOUNCE_ANY for
bounce_pfn. BLK_BOUNCE_ANY is defined as blk_max_pfn << PAGE_SHIFT, and
then the check above doesn't fail. But for other drivers, which obtain
reuired value from drivers, it fails. For example sata_nv uses
ATA_DMA_MASK or dev->dma_mask.
I propose to use (max_pfn - 1) for blk_max_pfn. And the same for
blk_max_low_pfn. The patch also cleanses some checks related with
bounce_pfn.
Signed-off-by: Vasily Tarasov <vtaras@openvz.org>
Make the SYSV SHM nattch counter work correctly by forcing multiple VMAs to
be produced to represent MAP_SHARED segments, even if they overlap exactly.
Using this test program:
http://people.redhat.com/~dhowells/doshm.c
Run as:
doshm sysv
I can see nattch going from one before the patch:
# /doshm sysv
Command: sysv
shmid: 65536
memory: 0xc3700000
c0b00000-c0b04000 rw-p 00000000 00:00 0
c0bb0000-c0bba788 r-xs 00000000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so
c3180000-c31dede4 r-xs 00000000 00:0b 14582179 /lib/libuClibc-0.9.28.so
c3520000-c352278c rw-p 00000000 00:0b 13763417 /doshm
c3584000-c35865e8 r-xs 00000000 00:0b 13763417 /doshm
c3588000-c358aa00 rw-p 00008000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so
c3590000-c359b6c0 rw-p 00000000 00:00 0
c3620000-c3640000 rwxp 00000000 00:00 0
c3700000-c37fa000 rw-S 00000000 00:06 1411 /SYSV00000000 (deleted)
nattch 1
To two after the patch:
# /doshm sysv
Command: sysv
shmid: 0
memory: 0xc3700000
c3320000-c3340000 rwxp 00000000 00:00 0
c3530000-c35325e8 r-xs 00000000 00:0b 13763417 /doshm
c3534000-c353678c rw-p 00000000 00:0b 13763417 /doshm
c3538000-c353aa00 rw-p 00008000 00:0b 14582157 /lib/ld-uClibc-0.9.28.so
c35a4000-c35a8000 rw-p 00000000 00:00 0
c3700000-c37fa000 rw-S 00000000 00:06 1369 /SYSV00000000 (deleted)
nattch 2
That's +1 to nattch for each shmat() made.
Supply a get_unmapped_area() to fix NOMMU SYSV SHM support.
Acked-by: Adam Litke <agl@us.ibm.com>
unkillable
Looking at oom_kill.c, found that the intention to not kill the selected
process if any of its children/siblings has OOM_DISABLE set, is not being
met.
Signed-off-by: Ankita Garg <ankita@in.ibm.com>
Acked-by: Nick Piggin <npiggin@suse.de>
Acked-by: William Irwin <wli@holomorphy.com>
The current NFS client congestion logic is severly broken, it marks the
backing device congested during each nfs_writepages() call but doesn't
mirror this in nfs_writepage() which makes for deadlocks. Also it
implements its own waitqueue.
Replace this by a more regular congestion implementation that puts a cap on
the number of active writeback pages and uses the bdi congestion waitqueue.
Also always use an interruptible wait since it makes sense to be able to
SIGKILL the process even for mounts without 'intr'.
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
This patch fixes a user-triggerable oops that was reported by Leonid
Ananiev as archived at http://lkml.org/lkml/2007/2/8/337.
dio writes invalidate clean pages that intersect the written region so that
subsequent buffered reads go to disk to read the new data. If this fails
the interface tries to tell the caller that the cache is inconsistent by
returning EIO.
Before this patch we had the problem where this invalidation failure would
clobber -EIOCBQUEUED as it made its way from fs/direct-io.c to fs/aio.c.
Both fs/aio.c and bio completion call aio_complete() and we reference freed
memory, usually oopsing.
This patch addresses this problem by invalidating before the write so that
we can cleanly return -EIO before ->direct_IO() has had a chance to return
-EIOCBQUEUED.
There is a compromise here. During the dio write we can fault in mmap()ed
pages which intersect the written range with get_user_pages() if the user
provided them for the source buffer. This is a crazy thing to do, but we
can make it mostly work in most cases by trying the invalidation again.
The compromise is that we won't return an error if this second invalidation
fails if it's an AIO write and we have -EIOCBQUEUED.
This was tested by having two processes race performing large O_DIRECT and
buffered ordered writes. Within minutes ext3 would see a race between
ext3_releasepage() and jbd holding a reference on ordered data buffers and
would cause invalidation to fail, panicing the box. The test can be found
in the 'aio_dio_bugs' test group in test.kernel.org/autotest. After this
patch the test passes.
Signed-off-by: Zach Brown <zach.brown@oracle.com>
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
Cc: Leonid Ananiev <leonid.i.ananiev@linux.intel.com>
madvise(MADV_REMOVE) can go into an infinite loop or cause an oops if the
call covers a region from the start of a vma, and extending past that vma.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Hugh Dickins <hugh@veritas.com>
Currently we do not check for vma flags if sys_move_pages is called to move
individual pages. If sys_migrate_pages is called to move pages then we
check for vm_flags that indicate a non migratable vma but that still
includes VM_LOCKED and we can migrate mlocked pages.
Extract the vma_migratable check from mm/mempolicy.c, fix it and put it
into migrate.h so that is can be used from both locations.
Problem was spotted by Lee Schermerhorn
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
shmem's super_operations were missed from the recent const-ification;
and simple_fill_super()'s, which can share with get_sb_pseudo()'s.
Acked-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu>
Fix invalidate_inode_pages2_range() so that it does not immediately exit
just because a single page in the specified range could not be removed.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
page_lock_anon_vma() uses spin_lock() to block RCU. This doesn't work with
PREEMPT_RCU, we have to do rcu_read_lock() explicitely. Otherwise, it is
theoretically possible that slab returns anon_vma's memory to the system
before we do spin_unlock(&anon_vma->lock).
[ Hugh points out that this only matters for PREEMPT_RCU, which isn't merged
yet, and may never be. Regardless, this patch is conceptually the
right thing to do, even if it doesn't matter at this point. - Linus ]
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
throttle_vm_writeout() is designed to wait for the dirty levels to subside.
But if the caller holds IO or FS locks, we might be holding up that writeout.
So change it to take a single nap to give other devices a chance to clean some
memory, then return.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Pete Zaitcev <zaitcev@redhat.com>
The code is seemingly trying to make sure that rb_next() brings us to
successive increasing vma entries.
But the two variables, prev and pend, used to perform these checks, are
never advanced.
Cc: Andrea Arcangeli <andrea@novell.com>
Rename PG_checked to PG_owner_priv_1 to reflect its availablilty as a
private flag for use by the owner/allocator of the page. In the case of
pagecache pages (which might be considered to be owned by the mm),
filesystems may use the flag.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au>
Fix kernel-doc warnings in 2.6.20-git15 (lib/, mm/, kernel/, include/).
shmem_{nopage,mmap} are no longer used in ipc/shm.c
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Hugh Dickins <hugh@veritas.com>
The alien cache is a per cpu per node array allocated for every slab on the
system. Currently we size this array for all nodes that the kernel does
support. For IA64 this is 1024 nodes. So we allocate an array with 1024
objects even if we only boot a system with 4 nodes.
This patch uses "nr_node_ids" to determine the number of possible nodes
supported by a hardware configuration and only allocates an alien cache
sized for possible nodes.
The initialization of nr_node_ids occurred too late relative to the bootstrap
of the slab allocator and so I moved the setup_nr_node_ids() into
free_area_init_nodes().
highest_possible_node_id() is currently used to calculate the last possible
node idso that the network subsystem can figure out how to size per node
arrays.
I think having the ability to determine the maximum amount of nodes in a
system at runtime is useful but then we should name this entry
correspondingly, it should return the number of node_ids, and the the value
needs to be setup only once on bootup. The node_possible_map does not
change after bootup.
This patch introduces nr_node_ids and replaces the use of
highest_possible_node_id(). nr_node_ids is calculated on bootup when the
page allocators pagesets are initialized.
[deweerdt@free.fr: fix oops]
Cc: Neil Brown <neilb@suse.de>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com>
bind_zonelist() can create zero-length zonelist if there is a
memory-less-node. This patch checks the length of zonelist. If length is
0, returns -EINVAL.
tested on ia64/NUMA with memory-less-node.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Andi Kleen <ak@suse.de>
Cc: Christoph Lameter <clameter@sgi.com>
to filesystem
When NFSD receives a write request, the data is typically in a number of
1448 byte segments and writev is used to collect them together.
Unfortunately, generic_file_buffered_write passes these to the filesystem
one at a time, so an e.g. 32K over-write becomes a series of partial-page
writes to each page, causing the filesystem to have to pre-read those pages
- wasted effort.
generic_file_buffered_write handles one segment of the vector at a time as
it has to pre-fault in each segment to avoid deadlocks. When writing from
kernel-space (and nfsd does) this is not an issue, so
generic_file_buffered_write does not need to break and iovec from nfsd into
little pieces.
This patch avoids the splitting when get_fs is KERNEL_DS as it is
from NFSd.
This issue was introduced by commit 6527c2bdf1f833cc18e8f42bd97973d583e4aa83
Acked-by: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Norman Weathers <norman.r.weathers@conocophillips.com>
Cc: Vladimir V. Saveliev <vs@namesys.com>
Signed-off-by: Neil Brown <neilb@suse.de>
My mincore also forgot about crossing vmas.
Paper bag time. Thanks to Randy for noticing that I didn't actually assign
'present' to anything.
Unfortunately my original patch passed the few simple test cases I gave it,
purely by coincidence.
Fix mincore-anon patch to compile with CONFIG_SWAP=n
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Make mincore work for anon mappings, nonlinear, and migration entries.
Based on patch from Linus Torvalds <torvalds@linux-foundation.org>.
Add a NOPFN_REFAULT return code for vm_ops->nopfn() equivalent to
NOPAGE_REFAULT for vmops->nopage() indicating that the handler requests a
re-execution of the faulting instruction
Cc: Arnd Bergmann <arnd.bergmann@de.ibm.com>
Add a vm_insert_pfn helper, so that ->fault handlers can have nopfn
functionality by installing their own pte and returning NULL.
Change a hard-coded constant 0 to the symbolic equivalent NOTIFY_DONE in
the ratelimit_handler() CPU notifier handler function.
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in
source files, including:
* make multi-line initial descriptions single line
* denote some function names, constants and structs as such
* change erroneous opening '/*' to '/**' in a few places
* reword some text for clarity
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Convert all calls to invalidate_inode_pages() into open-coded calls to
invalidate_mapping_pages().
Leave the invalidate_inode_pages() wrapper in place for now, marked as
deprecated.
It makes no sense to me to export invalidate_inode_pages() and not
invalidate_mapping_pages() and I actually need invalidate_mapping_pages()
because of its range specification ability...
akpm: also remove the export of invalidate_inode_pages() by making it an
inlined wrapper.
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
kmem_cache_free() was missing the check for freeing held locks.
When kernel unmaps an address range, it needs to transfer PTE state into
page struct. Currently, kernel transfer access bit via
mark_page_accessed(). The call to mark_page_accessed in the unmap path
doesn't look logically correct.
At unmap time, calling mark_page_accessed will causes page LRU state to be
bumped up one step closer to more recently used state. It is causing quite
a bit headache in a scenario when a process creates a shmem segment, touch
a whole bunch of pages, then unmaps it. The unmapping takes a long time
because mark_page_accessed() will start moving pages from inactive to
active list.
I'm not too much concerned with moving the page from one list to another in
LRU. Sooner or later it might be moved because of multiple mappings from
various processes. But it just doesn't look logical that when user asks a
range to be unmapped, it's his intention that the process is no longer
interested in these pages. Moving those pages to active list (or bumping
up a state towards more active) seems to be an over reaction. It also
prolongs unmapping latency which is the core issue I'm trying to solve.
As suggested by Peter, we should still preserve the info on pte young
pages, but not more.
Acked-by: Ken Chen <kenchen@google.com>
shmem backed file does not have page writeback, nor it participates in
backing device's dirty or writeback accounting. So using generic
__set_page_dirty_nobuffers() for its .set_page_dirty aops method is a bit
overkill. It unnecessarily prolongs shm unmap latency.
For example, on a densely populated large shm segment (sevearl GBs), the
unmapping operation becomes painfully long. Because at unmap, kernel
transfers dirty bit in PTE into page struct and to the radix tree tag. The
operation of tagging the radix tree is particularly expensive because it
has to traverse the tree from the root to the leaf node on every dirty
page. What's bothering is that radix tree tag is used for page write back.
However, shmem is memory backed and there is no page write back for such
file system. And in the end, we spend all that time tagging radix tree and
none of that fancy tagging will be used. So let's simplify it by introduce
a new aops __set_page_dirty_no_writeback and this will speed up shm unmap.
