path: root/net/8021q/vlan.c
2010-07-18vlan_dev: VLAN 0 should be treated as "no vlan tag" (802.1p packet)Pedro Garcia
- Without the 8021q module loaded in the kernel, all 802.1p packets (VLAN 0 but QoS tagging) are silently discarded (as expected, as the protocol is not loaded). - Without this patch in 8021q module, these packets are forwarded to the module, but they are discarded also if VLAN 0 is not configured, which should not be the default behaviour, as VLAN 0 is not really a VLANed packet but a 802.1p packet. Defining VLAN 0 makes it almost impossible to communicate with mixed 802.1p and non 802.1p devices on the same network due to arp table issues. - Changed logic to skip vlan specific code in vlan_skb_recv if VLAN is 0 and we have not defined a VLAN with ID 0, but we accept the packet with the encapsulated proto and pass it later to netif_rx. - In the vlan device event handler, added some logic to add VLAN 0 to HW filter in devices that support it (this prevented any traffic in VLAN 0 to reach the stack in e1000e with HW filter under 2.6.35, and probably also with other HW filtered cards, so we fix it here). - In the vlan unregister logic, prevent the elimination of VLAN 0 in devices with HW filter. - The default behaviour is to ignore the VLAN 0 tagging and accept the packet as if it was not tagged, but we can still define a VLAN 0 if desired (so it is backwards compatible). Signed-off-by: Pedro Garcia <pedro.netdev@dondevamos.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: move address list functions to a separate fileJiri Pirko
+little renaming of unicast functions to be smooth with multicast ones Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24vlan: updates vlan real_num_tx_queuesVasu Dev
Updates real_num_tx_queues in case underlying real device has changed real_num_tx_queues. -v2 As per Eric Dumazet<eric.dumazet@gmail.com> comment:- -- adds BUG_ON to catch case of real_num_tx_queues exceeding num_tx_queues. -- created this self contained patch to just update real_num_tx_queues. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18net: forbid underlaying devices to change its typeJiri Pirko
It's not desired for underlaying devices to change type. At the time, there is for example possible to have bond with changed type from Ethernet to Infiniband as a port of a bridge. This patch fixes this. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03netdevice: provide common routine for macvlan and vlan operstate managementPatrick Mullaney
Provide common routine for the transition of operational state for a leaf device during a root device transition. Signed-off-by: Patrick Mullaney <pmullaney@novell.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02net: Teach vlans to cleanup as a pernet subsystemEric W. Biederman
Take advantage of the fact that an explicit rtnl_kill_links is unnecessary (and skipping it improves batching), as network namespace exit calls dellink on all remaining virtual devices, and rtnl_link_unregister calls dellink on all outstanding devices in that network namespace. To do this we need to leave the vlan proc directories in place until after network device exit time, which is done by using register_pernet_subsys instead of register_pernet_device. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Simplify vlan pernet operations.Eric W. Biederman
Take advantage of the new pernet automatic storage management, and stop using compatibility network namespace functions. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26vlan: support "loose binding" to the underlying network devicePatrick McHardy
Currently the UP/DOWN state of VLANs is synchronized to the state of the underlying device, meaning all VLANs are set down once the underlying device is set down. This causes all routes to the VLAN devices to vanish. Add a flag to specify a "loose binding" mode, in which only the operstate is transfered, but the VLAN device state is independant. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18netns: net_identifiers should be read_mostlyEric Dumazet
2009-11-17vlan: Fix register_vlan_dev() error pathEric Dumazet
In case register_netdevice() returns an error, and a new vlan_group was allocated and inserted in vlan_group_hash[] we call vlan_group_free() without deleting group from hash table. Future lookups can give infinite loops or crashes. We must delete the vlan_group using RCU safe procedure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29vlan: cleanup multiple unregistrationsPatrick McHardy
The temporary copy of the VLAN group is not neccessary since the lower device is already in the process of being unregistered, if it was neccessary the memset of the global group would introduce a race condition. With this removed, the changes to the original code are only a few lines, so remove the new function and move the code back into vlan_device_event(). Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28vlan: Optimize multiple unregistrationEric Dumazet
Use unregister_netdevice_many() to speedup master device unregister. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28net: add a list_head parameter to dellink() methodEric Dumazet
Adding a list_head parameter to rtnl_link_ops->dellink() methods allow us to queue devices on a list, in order to dismantle them all at once. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02vlan: multiqueue vlan deviceEric Dumazet
vlan devices are currently not multi-queue capable. We can do that with a new rtnl_link_ops method, get_tx_queues(), called from rtnl_create_link() This new method gets num_tx_queues/real_num_tx_queues from real device. register_vlan_device() is also handled. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-14vlan: adds fcoe offload related net_device_ops and updates fcoe_ddp_xid fieldVasu Dev
Adds fcoe offload related net_device_ops functions vlan_dev_fcoe_ddp_setup and vlan_dev_fcoe_ddp_done, their implementation simply calls real eth device net_device_ops for FCoE DDP setup and done operations. Updates VLAN netdev field value for fcoe_ddp_xid from real eth device netdev. Above changes are required for fcoe DDP offload working on a VLAN interface. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30vlan: allow creating vlan when real device is not upStephen Hemminger
There is no reason for the arbitrary restriction that device must be up to create a vlan. This patch was added to Vyatta kernel to resolve startup ordering issues where vlan's are created but real device was disabled. Note: the vlan already correctly inherits the operstate from real device; so if vlan is created and real device is marked down, the vlan is marked down. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20vlan: Propagate physical MTU changesHerbert Xu
When the physical MTU changes we want to ensure that all existing VLAN device MTUs do not exceed the new underlying MTU. This patch adds that propagation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-108021q: Vlan driver should use rcu_barrier() on unload instead of ↵Jesper Dangaard Brouer
syncronize_net() The VLAN 8021q driver needs to call rcu_barrier() when unloading the module, instead of syncronize_net(). This is needed to make sure that outstanding call_rcu() callbacks have completed, before the callback function code is removed on module unload. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-25vlan: update vlan carrier state for admin up/downJay Vosburgh
Currently, the VLAN event handler does not adjust the VLAN device's carrier state when the real device or the VLAN device is set administratively up or down. The following patch adds a transfer of operating state from the real device to the VLAN device when the real device is administratively set up or down, and sets the carrier state up or down during init, open and close of the VLAN device. This permits observers above the VLAN device that care about the carrier state (bonding's link monitor, for example) to receive updates for administrative changes by more closely mimicing the behavior of real devices. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19vlan: convert to net_device_opsStephen Hemminger
Convert vlan devices and function pointers to net_device_ops. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28vlan: propogate ethtool speed valuesStephen Hemminger
This enables more ethtool information. The speed and settings of the underlying device are propagated up. This makes services like SNMP that use ethtool to get speed setting, work when managing a vlan, without adding silly heurtistics into SNMP daemon. For the driver info, just use existing driver strings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-11vlan: vlan device not reading gso max size of parent.Alexander Duyck
The vlan devices are not reading the gso max size of the parent device. As a result devices that do not support 64K max gso size are currently failing. This issue is seen on 2.6.26 kernels as well and the same patch should be able to be applied without any issues. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-14vlan: remove unnecessary include statementsPatrick McHardy
2008-07-08vlan: TCI related type and naming cleanupsPatrick McHardy
The VLAN code contains multiple spots that use tag, id and tci as identifiers for arguments and variables incorrectly and they actually contain or are expected to contain something different. Additionally types are used inconsistently (unsigned short vs u16) and identifiers are sometimes capitalized. - consistently use u16 for storing TCI, ID or QoS values - consistently use vlan_id and vlan_tci for storing the respective values - remove capitalization - add kdoc comment to netif_hwaccel_{rx,receive_skb} Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: move struct vlan_dev_info to private headerPatrick McHardy
Hide struct vlan_dev_info from drivers to prevent them from growing more creative ways to use it. Provide accessors for the two drivers that currently use it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: Use is_vlan_dev()Joonwoo Park
Use simplified is_vlan_dev function. Signed-off-by: Joonwoo Park <joonwpark81@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05vlan: Add GVRP supportPatrick McHardy
Add GVRP support for dynamically registering VLANs with switches. By default GVRP is disabled because we only support the applicant-only participant model, which means it should not be enabled on vlans that are members of a bridge. Since there is currently no way to cleanly determine that, the user is responsible for enabling it. The code is pretty small and low impact, its wrapped in a config option though because it depends on the GARP implementation and the STP core. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05vlan: Move device unregistration before lower dev cleanupPatrick McHardy
Move the unregister_netdevice() call for the VLAN device before cleanup for the lower device. This is needed by GVRP so it can send a leave message before the applicant on the lower device is cleaned up. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05vlan: Change vlan_dev_set_vlan_flag() to handle multiple flags at oncePatrick McHardy
Change vlan_dev_set_vlan_flag() to handle multiple flags at once and rename to vlan_dev_change_flags(). This allows to to use it from the netlink interface, which in turn allows to handle necessary adjustments when changing flags centrally. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16Merge branch 'linus' into core/rcutip-core-rcu-2008-06-16_09.23_MonIngo Molnar
2008-05-23vlan: Use bitmask of feature flags instead of seperate feature bitsPatrick McHardy
Herbert Xu points out that the use of seperate feature bits for features to be propagated to VLAN devices is going to get messy real soon. Replace the VLAN feature bits by a bitmask of feature flags to be propagated and restore the old GSO_SHIFT/MASK values. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20[VLAN]: Propagate selected feature bits to VLAN devicesPatrick McHardy
Propagate feature bits from the NETDEV_FEAT_CHANGE notifier. For now only TSO is propagated for devices that announce their ability to support TSO in combination with VLAN accel by setting the NETIF_F_VLAN_TSO flag. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20vlan: Correctly handle device notifications for layered VLAN devicesPatrick McHardy
Commit 30688a9 ([VLAN]: Handle vlan devices net namespace changing) changed the device notifier to special-case notifications for VLAN devices, effectively disabling state propagation to underlying VLAN devices. This is needed for layered VLANs though, so restore the original behaviour. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-19rcu: split list.h and move rcu-protected lists into rculist.hFranck Bui-Huu
Move rcu-protected lists from list.h into a new header file rculist.h. This is done because list are a very used primitive structure all over the kernel and it's currently impossible to include other header files in this list.h without creating some circular dependencies. For example, list.h implements rcu-protected list and uses rcu_dereference() without including rcupdate.h. It actually compiles because users of rcu_dereference() are macros. Others RCU functions could be used too but aren't probably because of this. Therefore this patch creates rculist.h which includes rcupdates without to many changes/troubles. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-16[VLAN]: Handle vlan devices net namespace changing.Pavel Emelyanov
When van device is moved to another namespace proc files, related to this device, should also change one. Use the netdev REGISTER and UNREGISTER event handlers for this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Allow vlan devices registration in net namespaces.Pavel Emelyanov
This one is similar to what I've done for TUN - set the proper net after device allocation and clean VLANs on net exit (use the rtnl_kill_links helper finally). Plus, drop explicit init_net usage and net != &init_net checks. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Make the vlan_name_type per-net.Pavel Emelyanov
This includes moving one on the struct vlan_net and s/vlan_name_type/vn->name_type/ over the code. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Add a net argument to proc init and cleanup calls.Pavel Emelyanov
All proc files will be created in each net, so prepare them for this change now, not to mess it with real creation patch. The net != &init_net checks in them are for git-bisect sanity, but I will drop them soon. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Introduce the vlan_net structure and init/exit net ops.Pavel Emelyanov
Unlike TUN, it is empty from the very beginning, and will be eventually populated later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Tag vlan_group_device with net device, not ifindex.Pavel Emelyanov
Currently vlan group is searched using one key - the ifindex. We'll have to lookup the vlan_group by two keys - ifindex and net. Turning the vlan_group lookup key to struct net_device pointer will make this process easier. Besides, this will eliminate one more place in the networking, that assumes that indexes are unique in the kernel. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/s2io.c
