path: root/net/8021q/vlan_dev.c
2008-07-22netdev: Handle ->addr_list_lock just like ->_xmit_lock for lockdep.David S. Miller
The new address list lock needs to handle the same device layering issues that the _xmit_lock one does. This integrates work done by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14vlan: remove unnecessary include statementsPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14vlan: clean up hard_start_xmit functionsPatrick McHardy
Remove excessive comments and debugging, use NETDEV_TX codes, remove some empty lines. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14vlan: clean up vlan_dev_hard_header()Patrick McHardy
Remove some debugging and excessive comments, merge the two dev_hard_header calls into one. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14vlan: ethtool ->get_flags supportPatrick McHardy
Allow to query LRO settings of underlying device when VLAN RX acceleration is used. Suggested by Ben Hutchings <bhutchings@solarflare.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-148021q: Check return of dev_set_promiscuity/allmultiWang Chen
dev_set_promiscuity/allmulti might overflow. Commit: "netdevice: Fix promiscuity and allmulti overflow" in net-next makes dev_set_promiscuity/allmulti return error number if overflow happened. Here, we check all positive increment for promiscuity and allmulti to get error return. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move _xmit_lock and xmit_lock_owner into netdev_queue.David S. Miller
Accesses are mostly structured such that when there are multiple TX queues the code transformations will be a little bit simpler. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: avoid header copying and linearisation where possiblePatrick McHardy
- vlan_dev_reorder_header() is only called on the receive path after calling skb_share_check(). This means we can use skb_cow() since all we need is a writable header. - vlan_dev_hard_header() includes a work-around for some apparently broken out of tree MPLS code. The hard_header functions can expect to always have a headroom of at least there own hard_header_len available, so the reallocation check is unnecessary. - __vlan_put_tag() can use skb_cow_head() to avoid the skb_unshare() copy when the header is writable. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: TCI related type and naming cleanupsPatrick McHardy
The VLAN code contains multiple spots that use tag, id and tci as identifiers for arguments and variables incorrectly and they actually contain or are expected to contain something different. Additionally types are used inconsistently (unsigned short vs u16) and identifiers are sometimes capitalized. - consistently use u16 for storing TCI, ID or QoS values - consistently use vlan_id and vlan_tci for storing the respective values - remove capitalization - add kdoc comment to netif_hwaccel_{rx,receive_skb} Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: move struct vlan_dev_info to private headerPatrick McHardy
Hide struct vlan_dev_info from drivers to prevent them from growing more creative ways to use it. Provide accessors for the two drivers that currently use it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: Add ethtool supportPatrick McHardy
Add ethtool support for querying the device for offload settings. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: Use is_vlan_dev()Joonwoo Park
Use simplified is_vlan_dev function. Signed-off-by: Joonwoo Park <joonwpark81@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08vlan: fix network_header/mac_header adjustmentsPatrick McHardy
Lennert Buytenhek points out that the VLAN code incorrectly adjusts skb->network_header to point in the middle of the VLAN header and additionally tries to adjust skb->mac_header without checking for validity. The network_header should not be touched at all since we're only adding headers in front of it, mac_header adjustments are not necessary at all. Based on patch by Lennert Buytenhek <buytenh@wantstofly.org>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05vlan: Add GVRP supportPatrick McHardy
Add GVRP support for dynamically registering VLANs with switches. By default GVRP is disabled because we only support the applicant-only participant model, which means it should not be enabled on vlans that are members of a bridge. Since there is currently no way to cleanly determine that, the user is responsible for enabling it. The code is pretty small and low impact, its wrapped in a config option though because it depends on the GARP implementation and the STP core. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05vlan: Change vlan_dev_set_vlan_flag() to handle multiple flags at oncePatrick McHardy
Change vlan_dev_set_vlan_flag() to handle multiple flags at once and rename to vlan_dev_change_flags(). This allows to to use it from the netlink interface, which in turn allows to handle necessary adjustments when changing flags centrally. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-23vlan: Use bitmask of feature flags instead of seperate feature bitsPatrick McHardy
Herbert Xu points out that the use of seperate feature bits for features to be propagated to VLAN devices is going to get messy real soon. Replace the VLAN feature bits by a bitmask of feature flags to be propagated and restore the old GSO_SHIFT/MASK values. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20[VLAN]: Propagate selected feature bits to VLAN devicesPatrick McHardy
Propagate feature bits from the NETDEV_FEAT_CHANGE notifier. For now only TSO is propagated for devices that announce their ability to support TSO in combination with VLAN accel by setting the NETIF_F_VLAN_TSO flag. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[VLAN]: Allow vlan devices registration in net namespaces.Pavel Emelyanov
This one is similar to what I've done for TUN - set the proper net after device allocation and clean VLANs on net exit (use the rtnl_kill_links helper finally). Plus, drop explicit init_net usage and net != &init_net checks. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-04[VLAN]: Fix egress priority mappings leak.Pavel Emelyanov
These entries are allocated in vlan_dev_set_egress_priority, but are never released and leaks on vlan device removal. Drop these in vlan's ->uninit callback - after the device is brought down and everyone is notified about it is going to be unregistered. Found during testing vlan netnsization patchset. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
2008-03-26[VLAN]: Don't copy ALLMULTI/PROMISC flags from underlying devicePatrick McHardy
Changing these flags requires to use dev_set_allmulti/dev_set_promiscuity or dev_change_flags. Setting it directly causes two unwanted effects: - the next dev_change_flags call will notice a difference between dev->gflags and the actual flags, enable promisc/allmulti mode and incorrectly update dev->gflags - this keeps the underlying device in promisc/allmulti mode until the VLAN device is deleted Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-17[8021Q]: vlan_dev misannotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-23[NET]: Restore sanity wrt. print_mac().David S. Miller
MAC_FMT had only one user and we tried to get rid of that, but this created more problems than it solved. As a result, this reverts three commits: 235365f3aaaa10b7056293877c0ead50425f25c7 ("net/8021q/vlan_dev.c: Use print_mac."), fea5fa875eb235dc186b1f5184eb36abc63e26cc ("[NET]: Remove MAC_FMT"), and 8f789c48448aed74fe1c07af76de8f04adacec7d ("[NET]: Elminate spurious print_mac() calls.") Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-17net/8021q/vlan_dev.c: Use print_mac.Joe Perches
Remove direct use of MAC_FMT Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[VLAN]: set_rx_mode support for unicast address listChris Leech
Reuse the existing logic for multicast list synchronization for the unicast address list. The core of dev_mc_sync/unsync are split out as __dev_addr_sync/unsync and moved from dev_mcast.c to dev.c. These are then used to implement dev_unicast_sync/unsync as well. I'm working on cleaning up Intel's FCoE stack, which generates new MAC addresses from the fibre channel device id assigned by the fabric as per the current draft specification in T11. When using such a protocol in a VLAN environment it would be nice to not always be forced into promiscuous mode, assuming the underlying Ethernet driver supports multiple unicast addresses as well. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-01-28[VLAN]: Move protocol determination to seperate functionPavel Emelyanov
I think, that we can make this code flow easier to understand by introducing the vlan_set_encap_proto() function (I hope the name is good) to setup the skb proto and merge the paths calling netif_rx() together. [Patrick: Modified to apply on top of my previous patches] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Clean up vlan_skb_recv()Patrick McHardy
- remove three instances of identical code - remove unnecessary NULL initialization - remove obvious and unnecessary comments Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Update list addressPatrick McHardy
VLAN related mail should go to netdev. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: checkpatch cleanupsPatrick McHardy
Checkpatch cleanups, consisting mainly of overly long lines and missing spaces. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Turn VLAN_DEV_INFO into inline functionPatrick McHardy
2008-01-28[VLAN]: Clean up debugging and printksPatrick McHardy
- use pr_* functions and common prefix for non-device related messages - remove VLAN_ printk levels - kill lots of useless debugging statements - remove a few unnecessary printks like for double VID registration (already returns -EEXIST) and kill of a number of unnecessary checks in vlan_proc_{add,rem}_dev() that are already performed by the caller Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Kill useless checkPatrick McHardy
vlan->real_dev is always equal to the device since thats what we used for the lookup. It doesn't even seem worth a WARN_ON or BUG_ON. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Move device setup to vlan_dev.cPatrick McHardy
Move device setup to vlan_dev.c and make all the VLAN device methods static. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[VLAN]: Use dev->statsPatrick McHardy
2007-11-29[VLAN]: Fix nested VLAN transmit bugJoonwoo Park
Fix misbehavior of vlan_dev_hard_start_xmit() for recursive encapsulations. Signed-off-by: Joonwoo Park <joonwpark81@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-10[VLAN]: Allow setting mac address while device is upPatrick McHardy
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-26[VLAN/BRIDGE]: Fix "skb_pull_rcsum - Fatal exception in interrupt"Evgeniy Polyakov
I tried to preserve bridging code as it was before, but logic is quite strange - I think we should free skb on error, since it is already unshared and thus will just leak. Herbert Xu states: > + if ((skb = skb_share_check(skb, GFP_ATOMIC)) == NULL) > + goto out; If this happens it'll be a double-free on skb since we'll return NF_DROP which makes the caller free it too. We could return NF_STOLEN to prevent that but I'm not sure whether that's correct netfilter semantics. Patrick, could you please make a call on this? Patrick McHardy states: NF_STOLEN should work fine here. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: ethtool ops are the only wayMatthew Wilcox
During the transition to the ethtool_ops way of doing things, we supported calling the device's ->do_ioctl method to allow unconverted drivers to continue working. Those days are long behind us, all in-tree drivers use the ethtool_ops way, and so we no longer need to support this. The bonding driver is the biggest beneficiary of this; it no longer needs to call ioctl() as a fallback if ethtool_ops aren't supported. Also put a proper copyright statement on ethtool.c. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[VLAN]: Use multicast list synchronization helpersPatrick McHardy
2007-07-14[VLAN]: Fix promiscous/allmulti synchronization racesPatrick McHardy
The set_multicast_list function may be called without holding the rtnl mutex, resulting in races when changing the underlying device's promiscous and allmulti state. Use the change_rx_mode hook, which is always invoked under the rtnl. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11[VLAN]: Fix MAC address handlingPatrick McHardy
The VLAN MAC address handling is broken in multiple ways. When the address differs when setting it, the real device is put in promiscous mode twice, but never taken out again. Additionally it doesn't resync when the real device's address is changed and needlessly puts it in promiscous mode when the vlan device is still down. Fix by moving address handling to vlan_dev_open/vlan_dev_stop and properly deal with address changes in the device notifier. Also switch to dev_unicast_add (which needs the exact same handling). Since the set_mac_address handler is identical to the generic ethernet one with these changes, kill it and use ether_setup(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[VLAN]: Introduce symbolic constants for flag valuesPatrick McHardy
