path: root/net/8021q/vlan_dev.c
2013-07-28vlan: fix a race in egress prio managementEric Dumazet
[ Upstream commit 3e3aac497513c669e1c62c71e1d552ea85c1d974 ] egress_priority_map[] hash table updates are protected by rtnl, and we never remove elements until device is dismantled. We have to make sure that before inserting an new element in hash table, all its fields are committed to memory or else another cpu could find corrupt values and crash. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19net: vlan,ethtool: netdev_features_t is more than 32 bitBjørn Mork
[ Upstream commit b29d3145183da4e07d4b570fa8acdd3ac4a5c572 ] Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-10Revert "net: maintain namespace isolation between vlan and real device"David S. Miller
This reverts commit 8a83a00b0735190384a348156837918271034144. It causes regressions for S390 devices, because it does an unconditional DST drop on SKBs for vlans and the QETH device needs the neighbour entry hung off the DST for certain things on transmit. Arnd can't remember exactly why he even needed this change. Conflicts: drivers/net/macvlan.c net/8021q/vlan_dev.c net/core/dev.c Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-14vlan: static functionsEric Dumazet
commit 6d4cdf47d2 (vlan: add 802.1q netpoll support) forgot to declare as static some private functions. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08vlan: add 802.1q netpoll supportBenjamin LaHaise
Add netpoll support to 802.1q vlan devices. Based on the netpoll support in the bridging code. Tested on a forced_eth device with netconsole. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-08vlan: rename vlan_dev_info to vlan_dev_privJiri Pirko
As this structure is priv, name it approprietely. Also for pointer to it use name "vlan". Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: introduce and use netdev_features_t for device features setsMichał Mirosław
v2: add couple missing conversions in drivers split unexporting netdev_fix_features() implemented %pNF convert sock::sk_route_(no?)caps Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: remove legacy ethtool opsMichał Mirosław
As all drivers are converted, we may now remove discrete offload setting callback handling. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-01vlan: Don't propagate flag changes on down interfaces.Matthijs Kooijman
When (de)configuring a vlan interface, the IFF_ALLMULTI ans IFF_PROMISC flags are cleared or set on the underlying interface. So, if these flags are changed on a vlan interface that is not up, the flags underlying interface might be set or cleared twice. Only propagating flag changes when a device is up makes sure this does not happen. It also makes sure that an underlying device is not set to promiscuous or allmulti mode for a vlan device that is down. Signed-off-by: Matthijs Kooijman <matthijs@stdin.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15net: consolidate and fix ethtool_ops->get_settings callingJiri Pirko
This patch does several things: - introduces __ethtool_get_settings which is called from ethtool code and from drivers as well. Put ASSERT_RTNL there. - dev_ethtool_get_settings() is replaced by __ethtool_get_settings() - changes calling in drivers so rtnl locking is respected. In iboe_get_rate was previously ->get_settings() called unlocked. This fixes it. Also prb_calc_retire_blk_tmo() in af_packet.c had the same problem. Also fixed by calling __dev_get_by_index() instead of dev_get_by_index() and holding rtnl_lock for both calls. - introduces rtnl_lock in bnx2fc_vport_create() and fcoe_vport_create() so bnx2fc_if_create() and fcoe_if_create() are called locked as they are from other places. - use __ethtool_get_settings() in bonding code Signed-off-by: Jiri Pirko <jpirko@redhat.com> v2->v3: -removed dev_ethtool_get_settings() -added ASSERT_RTNL into __ethtool_get_settings() -prb_calc_retire_blk_tmo - use __dev_get_by_index() and lock around it and __ethtool_get_settings() call v1->v2: add missing export_symbol Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> [except FCoE bits] Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-27net: Audit drivers to identify those needing IFF_TX_SKB_SHARING clearedNeil Horman
After the last patch, We are left in a state in which only drivers calling ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real hardware call ether_setup for their net_devices and don't hold any state in their skbs. There are a handful of drivers that violate this assumption of course, and need to be fixed up. This patch identifies those drivers, and marks them as not being able to support the safe transmission of skbs by clearning the IFF_TX_SKB_SHARING flag in priv_flags Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Karsten Keil <isdn@linux-pingi.de> CC: "David S. Miller" <davem@davemloft.net> CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: Patrick McHardy <kaber@trash.net> CC: Krzysztof Halasa <khc@pm.waw.pl> CC: "John W. Linville" <linville@tuxdriver.com> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Marcel Holtmann <marcel@holtmann.org> CC: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/bluetooth/l2cap_core.c
2011-07-14net: remove NETIF_F_ALL_TX_OFFLOADSMichał Mirosław
There is no software fallback implemented for SCTP or FCoE checksumming, and so it should not be passed on by software devices like bridge or bonding. For VLAN devices, this is different. First, the driver for underlying device should be prepared to get offloaded packets even when the feature is disabled (especially if it advertises it in vlan_features). Second, devices under VLANs do not get replaced without tearing down the VLAN first. This fixes a mess I accidentally introduced while converting bonding to ndo_fix_features. NETIF_F_SOFT_FEATURES are removed from BOND_VLAN_FEATURES because they are unused as of commit 712ae51afd. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-14net: vlan: remove reduntant check in ndo_fix_features callbackMichał Mirosław
Use the fact that ORing with zero is a no-op. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05Merge branch 'master' of ↵David S. Miller
2011-07-05net: vlan: enable soft features regardless of underlying deviceShan Wei
If gso/gro feature of underlying device is turned off, then new created vlan device never can turn gso/gro on. Although underlying device don't support TSO, we still should use software segments for vlan device. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-04Merge branch 'master' of ↵David S. Miller
2011-06-02net: 8021q: Add pr_fmtJoe Perches
Use the current logging style. Add #define pr_fmt and remove embedded prefix from formats. Not converting the current pr_<level> uses to netdev_<level> because all the output here is nicely prefaced with "8021q: ". Remove __func__ use from proc registration failure message. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01vlan: fix typo in vlan_dev_hard_start_xmit()Wei Yongjun
commit 4af429d29b341bb1735f04c2fb960178ed5d52e7 (vlan: lockless transmit path) have a typo in vlan_dev_hard_start_xmit(), using u64_stats_update_begin() to end the stat update, it should be u64_stats_update_end(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12net: Fix vlan_features propagationMichał Mirosław
Fix VLAN features propagation for devices which change vlan_features. For this to work, driver needs to make sure netdev_features_changed() gets called after the change (it is e.g. after ndo_set_features()). Side effect is that a user might request features that will never be enabled on a VLAN device. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6 Conflicts: drivers/net/benet/be_main.c
2011-05-10vlan: fix GVRP at dismantle timeEric Dumazet
ip link add link eth2 eth2.103 type vlan id 103 gvrp on loose_binding on ip link set eth2.103 up rmmod tg3 # driver providing eth2 BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffffa0030c9e>] garp_request_leave+0x3e/0xc0 [garp] PGD 11d251067 PUD 11b9e0067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/virtual/net/eth2.104/ifindex CPU 0 Modules linked in: tg3(-) 8021q garp nfsd lockd auth_rpcgss sunrpc libphy sg [last unloaded: x_tables] Pid: 11494, comm: rmmod Tainted: G W 2.6.39-rc6-00261-gfd71257-dirty #580 HP ProLiant BL460c G6 RIP: 0010:[<ffffffffa0030c9e>] [<ffffffffa0030c9e>] garp_request_leave+0x3e/0xc0 [garp] RSP: 0018:ffff88007a19bae8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88011b5e2000 RCX: 0000000000000002 RDX: 0000000000000000 RSI: 0000000000000175 RDI: ffffffffa0030d5b RBP: ffff88007a19bb18 R08: 0000000000000001 R09: ffff88011bd64a00 R10: ffff88011d34ec00 R11: 0000000000000000 R12: 0000000000000002 R13: ffff88007a19bc48 R14: ffff88007a19bb88 R15: 0000000000000001 FS: 0000000000000000(0000) GS:ffff88011fc00000(0063) knlGS:00000000f77d76c0 CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b CR2: 0000000000000000 CR3: 000000011a675000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 11494, threadinfo ffff88007a19a000, task ffff8800798595c0) Stack: ffff88007a19bb36 ffff88011c84b800 ffff88011b5e2000 ffff88007a19bc48 ffff88007a19bb88 0000000000000006 ffff88007a19bb38 ffffffffa003a5f6 ffff88007a19bb38 670088007a19bba8 ffff88007a19bb58 ffffffffa00397e7 Call Trace: [<ffffffffa003a5f6>] vlan_gvrp_request_leave+0x46/0x50 [8021q] [<ffffffffa00397e7>] vlan_dev_stop+0xb7/0xc0 [8021q] [<ffffffff8137e427>] __dev_close_many+0x87/0xe0 [<ffffffff8137e507>] dev_close_many+0x87/0x110 [<ffffffff8137e630>] rollback_registered_many+0xa0/0x240 [<ffffffff8137e7e9>] unregister_netdevice_many+0x19/0x60 [<ffffffffa00389eb>] vlan_device_event+0x53b/0x550 [8021q] [<ffffffff8143f448>] ? ip6mr_device_event+0xa8/0xd0 [<ffffffff81479d03>] notifier_call_chain+0x53/0x80 [<ffffffff81062539>] __raw_notifier_call_chain+0x9/0x10 [<ffffffff81062551>] raw_notifier_call_chain+0x11/0x20 [<ffffffff8137df82>] call_netdevice_notifiers+0x32/0x60 [<ffffffff8137e69f>] rollback_registered_many+0x10f/0x240 [<ffffffff8137e85f>] rollback_registered+0x2f/0x40 [<ffffffff8137e8c8>] unregister_netdevice_queue+0x58/0x90 [<ffffffff8137e9eb>] unregister_netdev+0x1b/0x30 [<ffffffffa005d73f>] tg3_remove_one+0x6f/0x10b [tg3] We should call vlan_gvrp_request_leave() from unregister_vlan_dev(), not from vlan_dev_stop(), because vlan_gvrp_uninit_applicant() is called right after unregister_netdevice_queue(). In batch mode, unregister_netdevice_queue() doesn’t immediately call vlan_dev_stop(). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12net: vlan: make non-hw-accel rx path similar to hw-accelJiri Pirko
Now there are 2 paths for rx vlan frames. When rx-vlan-hw-accel is enabled, skb is untagged by NIC, vlan_tci is set and the skb gets into vlan code in __netif_receive_skb - vlan_hwaccel_do_receive. For non-rx-vlan-hw-accel however, tagged skb goes thru whole __netif_receive_skb, it's untagged in ptype_base hander and reinjected This incosistency is fixed by this patch. Vlan untagging happens early in __netif_receive_skb so the rest of code (ptype_all handlers, rx_handlers) see the skb like it was untagged by hw. Signed-off-by: Jiri Pirko <jpirko@redhat.com> v1->v2: remove "inline" from vlan_core.c functions Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-02vlan: convert VLAN devices to use ndo_fix_features()Michał Mirosław
Note: get_flags was actually broken, because it should return the flags capped with vlan_features. This is now done implicitly by limiting netdev->hw_features. RX checksumming offload control is (and was) broken, as there was no way before to say whether it's done for tagged packets. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18vlan: should take into account needed_headroomEric Dumazet
Commit c95b819ad7 (gre: Use needed_headroom) made gre use needed_headroom instead of hard_header_len This uncover a bug in vlan code. We should make sure vlan devices take into account their real_dev->needed_headroom or we risk a crash in ipgre_header(), because we dont have enough room to push IP header in skb. Reported-by: Diddi Oscarsson <diddi@diddi.se> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07vlan: add support to ndo_fcoe_ddp_target()Yi Zou
Add the new target ddp offload support ndo_fcoe_ddp_target(). Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Kiran Patil <kiran.patil@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-11-16vlan: remove ndo_select_queue() logicEric Dumazet
Now vlan are lockless, we dont need special ndo_select_queue() logic. dev_pick_tx() will do the multiqueue stuff on the real device transmit. Suggested-by: Jesse Gross <jesse@nicira.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16vlan: lockless transmit pathEric Dumazet
vlan is a stacked device, like tunnels. We should use the lockless mechanism we are using in tunnels and loopback. This patch completely removes locking in TX path. tx stat counters are added into existing percpu stat structure, renamed from vlan_rx_stats to vlan_pcpu_stats. Note : this partially reverts commit 2e59af3dcbdf (vlan: multiqueue vlan device) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15net: consolidate 8021q taggingJohn Fastabend
Now that VLAN packets are tagged in dev_hard_start_xmit() at the bottom of the stack we no longer need to tag them in the 8021Q module (Except in the !VLAN_FLAG_REORDER_HDR case). This allows the accel path and non accel paths to be consolidated. Here the vlan_tci in the skb is always set and we allow the stack to add the actual tag in dev_hard_start_xmit(). Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15net: remove check for headroom in vlan_dev_createJohn Fastabend
It is possible for the headroom to be smaller then the hard_header_len for a short period of time after toggling the vlan offload setting. This is not a hard error and skb_cow_head is called in __vlan_put_tag() to resolve this. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Avoid hash table lookup to find group.Jesse Gross
A struct net_device always maps to zero or one vlan groups and we always know the device when we are looking up a group. We currently do a hash table lookup on the device to find the group but it is much simpler to just store a pointer. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: add a core netdev->rx_dropped counterEric Dumazet
In various situations, a device provides a packet to our stack and we drop it before it enters protocol stack : - softnet backlog full (accounted in /proc/net/softnet_stat) - bad vlan tag (not accounted) - unknown/unregistered protocol (not accounted) We can handle a per-device counter of such dropped frames at core level, and automatically adds it to the device provided stats (rx_dropped), so that standard tools can be used (ifconfig, ip link, cat /proc/net/dev) This is a generalization of commit 8990f468a (net: rx_dropped accounting), thus reverting it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27vlan: use this_cpu_ptr() in vlan_skb_recv()Eric Dumazet
2010-09-20net: rx_dropped accountingEric Dumazet
Under load, netif_rx() can drop incoming packets but administrators dont have a chance to spot which device needs some tuning (RPS activation for example) This patch adds rx_dropped accounting in vlans and tunnels. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19vlan: Match underlying dev carrier on vlan addPhil Oester
When adding a new vlan, if the underlying interface has no carrier, then the newly added vlan interface should also have no carrier. At present, this is not true - the newly added vlan is added with carrier up. Fix by checking state of real device. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-18vlan_dev: VLAN 0 should be treated as "no vlan tag" (802.1p packet)Pedro Garcia
- Without the 8021q module loaded in the kernel, all 802.1p packets (VLAN 0 but QoS tagging) are silently discarded (as expected, as the protocol is not loaded). - Without this patch in 8021q module, these packets are forwarded to the module, but they are discarded also if VLAN 0 is not configured, which should not be the default behaviour, as VLAN 0 is not really a VLANed packet but a 802.1p packet. Defining VLAN 0 makes it almost impossible to communicate with mixed 802.1p and non 802.1p devices on the same network due to arp table issues. - Changed logic to skip vlan specific code in vlan_skb_recv if VLAN is 0 and we have not defined a VLAN with ID 0, but we accept the packet with the encapsulated proto and pass it later to netif_rx. - In the vlan device event handler, added some logic to add VLAN 0 to HW filter in devices that support it (this prevented any traffic in VLAN 0 to reach the stack in e1000e with HW filter under 2.6.35, and probably also with other HW filtered cards, so we fix it here). - In the vlan unregister logic, prevent the elimination of VLAN 0 in devices with HW filter. - The default behaviour is to ignore the VLAN 0 tagging and accept the packet as if it was not tagged, but we can still define a VLAN 0 if desired (so it is backwards compatible). Signed-off-by: Pedro Garcia <pedro.netdev@dondevamos.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-09net: Get rid of rtnl_link_stats64 / net_device_stats unionBen Hutchings
In commit be1f3c2c027cc5ad735df6a45a542ed1db7ec48b "net: Enable 64-bit net device statistics on 32-bit architectures" I redefined struct net_device_stats so that it could be used in a union with struct rtnl_link_stats64, avoiding the need for explicit copying or conversion between the two. However, this is unsafe because there is no locking required and no lock consistently held around calls to dev_get_stats() and use of the statistics structure it returns. In commit 28172739f0a276eb8d6ca917b3974c2edb036da3 "net: fix 64 bit counters on 32 bit arches" Eric Dumazet dealt with that problem by requiring callers of dev_get_stats() to provide storage for the result. This means that the net_device::stats64 field and the padding in struct net_device_stats are now redundant, so remove them. Update the comment on net_device_ops::ndo_get_stats64 to reflect its new usage. Change dev_txq_stats_fold() to use struct rtnl_link_stats64, since that is what all its callers are really using and it is no longer going to be compatible with struct net_device_stats. Eric Dumazet suggested the separate function for the structure conversion. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-08vlan: allow TSO setting on vlan interfacesEric Dumazet
When we need to shape traffic using low speeds, we need to disable tso on network interface : ethtool -K eth0.2240 tso off It seems vlan interfaces miss the set_tso() ethtool method. Before enabling TSO, we must check real device supports TSO for VLAN-tagged packets and enables TSO. Note that a TSO change on real device propagates TSO setting on all vlans, even if admin selected a different TSO setting. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07net: fix 64 bit counters on 32 bit archesEric Dumazet
There is a small possibility that a reader gets incorrect values on 32 bit arches. SNMP applications could catch incorrect counters when a 32bit high part is changed by another stats consumer/provider. One way to solve this is to add a rtnl_link_stats64 param to all ndo_get_stats64() methods, and also add such a parameter to dev_get_stats(). Rule is that we are not allowed to use dev->stats64 as a temporary storage for 64bit stats, but a caller provided area (usually on stack) Old drivers (only providing get_stats() method) need no changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-28vlan: 64 bit rx countersEric Dumazet
Use u64_stats_sync infrastructure to implement 64bit rx stats. (tx stats are addressed later) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02net: init_vlan should not copy slave or master flagsJohn Fastabend
The vlan device should not copy the slave or master flags from the real device. It is not in the bond until added nor is it a master. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-16net: congestion notifications are not dropped packetsEric Dumazet
vlan/macvlan start_xmit() can inform caller of congestion with NET_XMIT_CN return value. This doesnt mean packet was dropped. Increment normal stat counters instead of tx_dropped. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: move address list functions to a separate fileJiri Pirko
+little renaming of unicast functions to be smooth with multicast ones Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24vlan: adds vlan_dev_select_queueVasu Dev
This is required to correctly select vlan tx queue for a driver supporting multi tx queue with ndo_select_queue implemented since currently selected vlan tx queue is unaligned to selected queue by real net_devce ndo_select_queue. Unaligned vlan tx queue selection causes thrash with higher vlan tx lock contention for least fcoe traffic and wrong socket tx queue_mapping for ixgbe having ndo_select_queue implemented. -v2 As per Eric Dumazet<eric.dumazet@gmail.com> comments, mirrored vlan net_device_ops to have them with and without vlan_dev_select_queue and then select according to real dev ndo_select_queue present or not for a vlan net_device. This is to completely skip vlan_dev_select_queue calling for real net_device not supporting ndo_select_queue. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03net: maintain namespace isolation between vlan and real deviceArnd Bergmann
In the vlan and macvlan drivers, the start_xmit function forwards data to the dev_queue_xmit function for another device, which may potentially belong to a different namespace. To make sure that classification stays within a single namespace, this resets the potentially critical fields. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28Merge branch 'master' of ↵David S. Miller
