[ Upstream commit fc0d48b8fb449ca007b2057328abf736cb516168 ]
Currently, if the card supports CTAG acceleration we do not
account for the vlan header even if we are configuring an
8021AD vlan. This may not be best since we'll do software
tagging for 8021AD which will cause data copy on skb head expansion
Configure the length based on available hw offload capabilities and
vlan protocol.
CC: Patrick McHardy <kaber@trash.net>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit dd38743b4cc2f86be250eaf156cf113ba3dd531a ]
With TX VLAN offload enabled the source MAC address for frames sent using the
VLAN interface is currently set to the address of the real interface. This is
wrong since the VLAN interface may be configured with a different address.
The bug was introduced in commit 2205369a314e12fcec4781cc73ac9c08fc2b47de
("vlan: Fix header ops passthru when doing TX VLAN offload.").
This patch sets the source address before calling the create function of the
real interface.
Signed-off-by: Peter Boström <peter.bostrom@netrounds.com>
[ Upstream commit 2205369a314e12fcec4781cc73ac9c08fc2b47de ]
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
[ Upstream commit c33a39c575068c2ea9bffb22fd6de2df19c74b89 ]
This patch fixes the calculation of the nlmsg size, by adding the missing
nla_total_size().
Cc: Patrick McHardy <kaber@trash.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit 3e3aac497513c669e1c62c71e1d552ea85c1d974 ]
egress_priority_map[] hash table updates are protected by rtnl,
and we never remove elements until device is dismantled.
We have to make sure that before inserting an new element in hash table,
all its fields are committed to memory or else another cpu could
find corrupt values and crash.
[ Upstream commit d4b812dea4a236f729526facf97df1a9d18e191c ]
In commit 48cc32d38a52d0b68f91a171a8d00531edc6a46e
("vlan: don't deliver frames for unknown vlans to protocols")
Florian made sure we set pkt_type to PACKET_OTHERHOST
if the vlan id is set and we could find a vlan device for this
particular id.
But we also have a problem if prio bits are set.
Steinar reported an issue on a router receiving IPv6 frames with a
vlan tag of 4000 (id 0, prio 2), and tunneled into a sit device,
because skb->vlan_tci is set.
Forwarded frame is completely corrupted : We can see (8100:4000)
being inserted in the middle of IPv6 source address :
16:48:00.780413 IP6 2001:16d8:8100:4000:ee1c:0:9d9:bc87 >
9f94:4d95:2001:67c:29f4::: ICMP6, unknown icmp6 type (0), length 64
0x0000: 0000 0029 8000 c7c3 7103 0001 a0ae e651
0x0010: 0000 0000 ccce 0b00 0000 0000 1011 1213
0x0020: 1415 1617 1819 1a1b 1c1d 1e1f 2021 2223
0x0030: 2425 2627 2829 2a2b 2c2d 2e2f 3031 3233
It seems we are not really ready to properly cope with this right now.
We can probably do better in future kernels :
vlan_get_ingress_priority() should be a netdev property instead of
a per vlan_dev one.
For stable kernels, lets clear vlan_tci to fix the bugs.
Reported-by: Steinar H. Gunderson <sesse@google.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Supply a function (proc_remove()) to remove a proc entry (and any subtree
rooted there) by proc_dir_entry pointer rather than by name and (optionally)
root dir entry pointer. This allows us to eliminate all remaining pde->name
accesses outside of procfs.
Acked-by: Grant Likely <grant.likely@linaro.or>
cc: linux-acpi@vger.kernel.org
cc: openipmi-developer@lists.sourceforge.net
cc: devicetree-discuss@lists.ozlabs.org
cc: linux-pci@vger.kernel.org
cc: netdev@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
Add missing return statement for CONFIG_BUG=n.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
The following leak is reported by kmemleak:
[ 86.812073] kmemleak: Found object by alias at 0xffff88006ecc76f0
[ 86.816019] Pid: 739, comm: kworker/u:1 Not tainted 3.9.0-rc5+ #842
[ 86.816019] Call Trace:
[ 86.816019] <IRQ> [<ffffffff81151c58>] find_and_get_object+0x8c/0xdf
[ 86.816019] [<ffffffff8190e90d>] ? vlan_info_rcu_free+0x33/0x49
[ 86.816019] [<ffffffff81151cbe>] delete_object_full+0x13/0x2f
[ 86.816019] [<ffffffff8194bbb6>] kmemleak_free+0x26/0x45
[ 86.816019] [<ffffffff8113e8c7>] slab_free_hook+0x1e/0x7b
[ 86.816019] [<ffffffff81141c05>] kfree+0xce/0x14b
[ 86.816019] [<ffffffff8190e90d>] vlan_info_rcu_free+0x33/0x49
[ 86.816019] [<ffffffff810d0b0b>] rcu_do_batch+0x261/0x4e7
The reason is that in vlan_info_rcu_free() we don't take the VLAN protocol
into account when iterating over the vlan_devices_array.
Reported-by: Cong Wang <amwang@redhat.com>
Tested-by: Cong Wang <amwang@redhat.com>
Add support for 802.1ad VLAN devices. This mainly consists of checking for
ETH_P_8021AD in addition to ETH_P_8021Q in a couple of places and check
offloading capabilities based on the used protocol.
Configuration is done using "ip link":
# ip link add link eth0 eth0.1000 \
type vlan proto 802.1ad id 1000
# ip link add link eth0.1000 eth0.1000.1000 \
type vlan proto 802.1q id 1000
52:54:00:12:34:56 > 92:b1:54:28:e4:8c, ethertype 802.1Q (0x8100), length 106: vlan 1000, p 0, ethertype 802.1Q, vlan 1000, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto ICMP (1), length 84)
20.1.0.2 > 20.1.0.1: ICMP echo request, id 3003, seq 8, length 64
92:b1:54:28:e4:8c > 52:54:00:12:34:56, ethertype 802.1Q-QinQ (0x88a8), length 106: vlan 1000, p 0, ethertype 802.1Q, vlan 1000, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 47944, offset 0, flags [none], proto ICMP (1), length 84)
20.1.0.1 > 20.1.0.2: ICMP echo reply, id 3003, seq 8, length 64
Add a protocol argument to the VLAN packet tagging functions. In case of HW
tagging, we need that protocol available in the ndo_start_xmit functions,
so it is stored in a new field in the skb. The new field fits into a hole
(on 64 bit) and doesn't increase the sks's size.
Make the encapsulation protocol value a property of VLAN devices and change
the device lookup functions to take the protocol value into account.
Change the rx_{add,kill}_vid callbacks to take a protocol argument in
preparation of 802.1ad support. The protocol argument used so far is
always htons(ETH_P_8021Q).
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
vlan_vid_del() could possibly free ->vlan_info after a RCU grace
period, however, we may still refer to the freed memory area
by 'grp' pointer. Found by code inspection.
This patch moves vlan_vid_del() as behind as possible.
Signed-off-by: Cong Wang <amwang@redhat.com>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
At ingress, any untagged traffic is assigned to the PVID.
Any tagged traffic is filtered according to membership bitmap.
At egress, if the vlan matches the PVID, the frame is sent
untagged. Otherwise the frame is sent tagged.
__netpoll_rcu_free is used to free netpoll structures when the rtnl_lock is
already held. The mechanism is used to asynchronously call __netpoll_cleanup
outside of the holding of the rtnl_lock, so as to avoid deadlock.
Unfortunately, __netpoll_cleanup modifies pointers (dev->np), which means the
rtnl_lock must be held while calling it. Further, it cannot be held, because
rcu callbacks may be issued in softirq contexts, which cannot sleep.
Fix this by converting the rcu callback to a work queue that is guaranteed to
get scheduled in process context, so that we can hold the rtnl properly while
calling __netpoll_cleanup
Tested successfully by myself.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Cong Wang <amwang@redhat.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
Initial implementation of the Multiple VLAN Registration Protocol
(MVRP) from IEEE 802.1Q-2011, based on the existing implementation
of the GARP VLAN Registration Protocol (GVRP).
Signed-off-by: David Ward <david.ward@ll.mit.edu>
Acked-by: Patrick McHardy <kaber@trash.net>
Instead of jumping aroung bugs that are easily fixed just don't let them in:
affected drivers should be either fixed or have NETIF_F_HW_VLAN_FILTER
removed from advertised features.
Quick grep in drivers/net shows two drivers that have NETIF_F_HW_VLAN_FILTER
but not ndo_vlan_rx_add/kill_vid(), but those are false-positives (features
are commented out).
OTOH two drivers have ndo_vlan_rx_add/kill_vid() implemented but don't
advertise NETIF_F_HW_VLAN_FILTER. Those are:
+ethernet/cisco/enic/enic_main.c
+ethernet/qlogic/qlcnic/qlcnic_main.c
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Use strlcpy where possible to ensure the string is \0 terminated.
Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN
and custom defines.
Use snprintf instead of sprint.
Remove unnecessary inits of ->fw_version
Remove unnecessary inits of drvinfo struct.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Also, since all users call __vlan_find_dev_deep() with rcu_read_lock,
make no possibility to call this with rtnl mutex held only.
This bug is observed on running FCoE over a VLAN device associated w/
a real device that has IFF_UNICAST_FLT set since FCoE would add unicast
address such as FLOGI MAC to the VLAN interface that FCoE is on. Since
currently, VLAN device is not inheriting the IFF_UNICAST_FLT flag from the
parent real device even though the real device is capable of doing unicast
filtering. This forces the VLAN device and its real device go to promiscuous
mode unnecessarily even the added address is actually being added to the
available unicast filter table in real device.
Signed-off-by: Yi Zou <yi.zou@intel.com>
Cc: devel@open-fcoe.org
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Allow the vlan ioctls:
SET_VLAN_INGRESS_PRIORITY_CMD
SET_VLAN_EGRESS_PRIORITY_CMD
SET_VLAN_FLAG_CMD
SET_VLAN_NAME_TYPE_CMD
ADD_VLAN_CMD
DEL_VLAN_CMD
Sets the sysfs device_type to 'vlan' for udev. This makes it easier for
applications that query network information via udev to identify vlans
instead of using strrchr().
Signed-off-by: Doug Goldstein <cardoe@cardoe.com>
#if defined(CONFIG_FOO) || defined(CONFIG_FOO_MODULE)
can be replaced by
#if IS_ENABLED(CONFIG_FOO)
vlan_info might be present but still no vlan devices might be there.
That is in case of vlan0 automatically added.
So in that case, allow to change netdev type.
Reported-by: Jon Stanley <jstanley@rmrf.net>
In vlan_uses_dev() check for number of vlan devs rather than existence
of vlan_info. The reason is that vlan id 0 is there without appropriate
vlan dev on it by default which prevented from enslaving vlan challenged
dev.
6a32e4f9dd9219261f8856f817e6655114cfec2f made the vlan code skip marking
vlan-tagged frames for not locally configured vlans as PACKET_OTHERHOST if
there was an rx_handler, as the rx_handler could cause the frame to be received
on a different (virtual) vlan-capable interface where that vlan might be
configured.
As rx_handlers do not necessarily return RX_HANDLER_ANOTHER, this could cause
frames for unknown vlans to be delivered to the protocol stack as if they had
been received untagged.
For example, if an ipv6 router advertisement that's tagged for a locally not
configured vlan is received on an interface with macvlan interfaces attached,
macvlan's rx_handler returns RX_HANDLER_PASS after delivering the frame to the
macvlan interfaces, which caused it to be passed to the protocol stack, leading
to ipv6 addresses for the announced prefix being configured even though those
are completely unusable on the underlying interface.
The fix moves marking as PACKET_OTHERHOST after the rx_handler so the
rx_handler, if there is one, sees the frame unchanged, but afterwards,
before the frame is delivered to the protocol stack, it gets marked whether
there is an rx_handler or not.
Signed-off-by: Florian Zumbiehl <florz@florz.de>
skb_reset_mac_len() relies on the value of the skb->network_header pointer,
therefore we must wait for such pointer to be recalculated before computing
the new mac_len value.
Signed-off-by: Antonio Quartulli <ordex@autistici.org>
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
Pull the trivial tree from Jiri Kosina:
"Tiny usual fixes all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
doc: fix old config name of kprobetrace
fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc
btrfs: fix the commment for the action flags in delayed-ref.h
btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID
vfs: fix kerneldoc for generic_fh_to_parent()
treewide: fix comment/printk/variable typos
ipr: fix small coding style issues
doc: fix broken utf8 encoding
nfs: comment fix
platform/x86: fix asus_laptop.wled_type module parameter
mfd: printk/comment fixes
doc: getdelays.c: remember to close() socket on error in create_nl_socket()
doc: aliasing-test: close fd on write error
mmc: fix comment typos
dma: fix comments
spi: fix comment/printk typos in spi
Coccinelle: fix typo in memdup_user.cocci
tmiofb: missing NULL pointer checks
tools: perf: Fix typo in tools/perf
tools/testing: fix comment / output typos
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
also, remove unused vlan_info definition from header
Clean up vlan_dev_hard_start_xmit() function.
Cc: Benjamin LaHaise <bcrl@kvack.org>
To be consistent, s/info/vlan/.
Like the previous patch, slave_disable_netpoll() and __netpoll_cleanup()
may be called with read_lock() held too, so we should make them
non-block, by moving the cleanup and kfree() to call_rcu_bh() callbacks.
slave_enable_netpoll() and __netpoll_setup() may be called
with read_lock() held, so should use GFP_ATOMIC to allocate
memory. Eric suggested to pass gfp flags to __netpoll_setup().
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
In driver reload test there is a memory leak.
The structure vlan_info was not freed when the driver was removed.
It was not released since the nr_vids var is one after last vlan was removed.
The nr_vids is one, since vlan zero is added to the interface when the interface
is being set, but the vlan zero is not deleted at unregister.
Fix - delete vlan zero when we unregister the device.
Signed-off-by: Amir Hanania <amir.hanania@intel.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
This reverts commit 8a83a00b0735190384a348156837918271034144.
It causes regressions for S390 devices, because it does an
unconditional DST drop on SKBs for vlans and the QETH device
needs the neighbour entry hung off the DST for certain things
on transmit.
Arnd can't remember exactly why he even needed this change.
drivers/net/macvlan.c
net/8021q/vlan_dev.c
net/core/dev.c
Use the new bool function ether_addr_equal to add
some clarity and reduce the likelihood for misuse
of compare_ether_addr for sorting.
Done via cocci script:
$ cat compare_ether_addr.cocci
expression a,b;
- !compare_ether_addr(a, b)
+ ether_addr_equal(a, b)
expression a,b;
- compare_ether_addr(a, b)
+ !ether_addr_equal(a, b)
expression a,b;
- !ether_addr_equal(a, b) == 0
expression a,b;
- !ether_addr_equal(a, b) != 0
expression a,b;
- ether_addr_equal(a, b) == 0
expression a,b;
- ether_addr_equal(a, b) != 0
expression a,b;
- !!ether_addr_equal(a, b)
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
commit 6d4cdf47d2 (vlan: add 802.1q netpoll support) forgot to declare
as static some private functions.
CC: Benjamin LaHaise <bcrl@kvack.org>
The original code generates a Sparse warning:
net/8021q/vlan_core.c:336:9:
error: incompatible types in comparison expression (different address spaces)
It's ok to dereference __rcu pointers here because we are holding the
RTNL lock. I've added some calls to rtnl_dereference() to silence the
warning.
Acked-by: Jiri Pirko <jpirko@redhat.com>
