path: root/net/8021q
2010-06-10net: deliver skbs on inactive slaves to exact matchesJohn Fastabend
Currently, the accelerated receive path for VLAN's will drop packets if the real device is an inactive slave and is not one of the special pkts tested for in skb_bond_should_drop(). This behavior is different then the non-accelerated path and for pkts over a bonded vlan. For example, vlanx -> bond0 -> ethx will be dropped in the vlan path and not delivered to any packet handlers at all. However, bond0 -> vlanx -> ethx and bond0 -> ethx will be delivered to handlers that match the exact dev, because the VLAN path checks the real_dev which is not a slave and netif_recv_skb() doesn't drop frames but only delivers them to exact matches. This patch adds a sk_buff flag which is used for tagging skbs that would previously been dropped and allows the skb to continue to skb_netif_recv(). Here we add logic to check for the deliver_no_wcard flag and if it is set only deliver to handlers that match exactly. This makes both paths above consistent and gives pkt handlers a way to identify skbs that come from inactive slaves. Without this patch in some configurations skbs will be delivered to handlers with exact matches and in others be dropped out right in the vlan path. I have tested the following 4 configurations in failover modes and load balancing modes. # bond0 -> ethx # vlanx -> bond0 -> ethx # bond0 -> vlanx -> ethx # bond0 -> ethx | vlanx -> -- Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02net: init_vlan should not copy slave or master flagsJohn Fastabend
The vlan device should not copy the slave or master flags from the real device. It is not in the bond until added nor is it a master. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary semicolons after switch statementsJoe Perches
Also added an explicit break; to avoid a fallthrough in net/ipv4/tcp_input.c Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-16net: congestion notifications are not dropped packetsEric Dumazet
vlan/macvlan start_xmit() can inform caller of congestion with NET_XMIT_CN return value. This doesnt mean packet was dropped. Increment normal stat counters instead of tx_dropped. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: move address list functions to a separate fileJiri Pirko
+little renaming of unicast functions to be smooth with multicast ones Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24vlan: updates vlan real_num_tx_queuesVasu Dev
Updates real_num_tx_queues in case underlying real device has changed real_num_tx_queues. -v2 As per Eric Dumazet<eric.dumazet@gmail.com> comment:- -- adds BUG_ON to catch case of real_num_tx_queues exceeding num_tx_queues. -- created this self contained patch to just update real_num_tx_queues. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-24vlan: adds vlan_dev_select_queueVasu Dev
This is required to correctly select vlan tx queue for a driver supporting multi tx queue with ndo_select_queue implemented since currently selected vlan tx queue is unaligned to selected queue by real net_devce ndo_select_queue. Unaligned vlan tx queue selection causes thrash with higher vlan tx lock contention for least fcoe traffic and wrong socket tx queue_mapping for ixgbe having ndo_select_queue implemented. -v2 As per Eric Dumazet<eric.dumazet@gmail.com> comments, mirrored vlan net_device_ops to have them with and without vlan_dev_select_queue and then select according to real dev ndo_select_queue present or not for a vlan net_device. This is to completely skip vlan_dev_select_queue calling for real net_device not supporting ndo_select_queue. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-20Merge branch 'master' of ↵David S. Miller
2010-03-18net: Potential null skb->dev dereferenceEric Dumazet
When doing "ifenslave -d bond0 eth0", there is chance to get NULL dereference in netif_receive_skb(), because dev->master suddenly becomes NULL after we tested it. We should use ACCESS_ONCE() to avoid this (or rcu_dereference()) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18net: forbid underlaying devices to change its typeJiri Pirko
It's not desired for underlaying devices to change type. At the time, there is for example possible to have bond with changed type from Ethernet to Infiniband as a port of a bridge. This patch fixes this. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03net: maintain namespace isolation between vlan and real deviceArnd Bergmann
In the vlan and macvlan drivers, the start_xmit function forwards data to the dev_queue_xmit function for another device, which may potentially belong to a different namespace. To make sure that classification stays within a single namespace, this resets the potentially critical fields. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28Merge branch 'master' of ↵David S. Miller
2010-01-24vlan: fix vlan_skb_recv()Eric Dumazet
Bruno Prémont found commit 9793241fe92f7d930 (vlan: Precise RX stats accounting) added a regression for non hw accelerated vlans. [ 26.390576] BUG: unable to handle kernel NULL pointer dereference at (null) [ 26.396369] IP: [<df856b89>] vlan_skb_recv+0x89/0x280 [8021q] vlan_dev_info() was used with original device, instead of skb->dev. Also spotted by Américo Wang. Reported-By: Bruno Prémont <bonbons@linux-vserver.org> Tested-By: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03bonding: allow arp_ip_targets on separate vlans to use arp validationAndy Gospodarek
This allows a bond device to specify an arp_ip_target as a host that is not on the same vlan as the base bond device and still use arp validation. A configuration like this, now works: BONDING_OPTS="mode=active-backup arp_interval=1000 arp_ip_target=10.0.100.1 arp_validate=3" 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000 link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff 3: eth0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000 link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff 8: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff inet6 fe80::213:21ff:febe:33e9/64 scope link valid_lft forever preferred_lft forever 9: bond0.100@bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff inet 10.0.100.2/24 brd 10.0.100.255 scope global bond0.100 inet6 fe80::213:21ff:febe:33e9/64 scope link valid_lft forever preferred_lft forever Ethernet Channel Bonding Driver: v3.6.0 (September 26, 2009) Bonding Mode: fault-tolerance (active-backup) Primary Slave: None Currently Active Slave: eth1 MII Status: up MII Polling Interval (ms): 0 Up Delay (ms): 0 Down Delay (ms): 0 ARP Polling Interval (ms): 1000 ARP IP target/s (n.n.n.n form): 10.0.100.1 Slave Interface: eth1 MII Status: up Link Failure Count: 1 Permanent HW addr: 00:40:05:30:ff:30 Slave Interface: eth0 MII Status: up Link Failure Count: 0 Permanent HW addr: 00:13:21:be:33:e9 Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-26llc: use dev_hard_headerOctavian Purdila
Using dev_hard_header allows us to use LLC with VLANs and potentially other Ethernet/TokernRing specific encapsulations. It also removes code duplication between LLC and Ethernet/TokenRing core code. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03netdevice: provide common routine for macvlan and vlan operstate managementPatrick Mullaney
Provide common routine for the transition of operational state for a leaf device during a root device transition. Signed-off-by: Patrick Mullaney <pmullaney@novell.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02net: Teach vlans to cleanup as a pernet subsystemEric W. Biederman
Take advantage of the fact that an explicit rtnl_kill_links is unnecessary (and skipping it improves batching), as network namespace exit calls dellink on all remaining virtual devices, and rtnl_link_unregister calls dellink on all outstanding devices in that network namespace. To do this we need to leave the vlan proc directories in place until after network device exit time, which is done by using register_pernet_subsys instead of register_pernet_device. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Simplify vlan pernet operations.Eric W. Biederman
Take advantage of the new pernet automatic storage management, and stop using compatibility network namespace functions. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26vlan: support "loose binding" to the underlying network devicePatrick McHardy
Currently the UP/DOWN state of VLANs is synchronized to the state of the underlying device, meaning all VLANs are set down once the underlying device is set down. This causes all routes to the VLAN devices to vanish. Add a flag to specify a "loose binding" mode, in which only the operstate is transfered, but the VLAN device state is independant. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18netns: net_identifiers should be read_mostlyEric Dumazet
2009-11-17vlan: Precise RX stats accountingEric Dumazet
With multi queue devices, its possible that several cpus call vlan RX routines simultaneously for the same vlan device. We update RX stats counter without any locking, so we can get slightly wrong counters. One possible fix is to use percpu counters, to get precise accounting and also get guarantee of no cache line ping pongs between cpus. Note: this adds 16 bytes (32 bytes on 64bit arches) of percpu data per vlan device. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17vlan: Fix register_vlan_dev() error pathEric Dumazet
In case register_netdevice() returns an error, and a new vlan_group was allocated and inserted in vlan_group_hash[] we call vlan_group_free() without deleting group from hash table. Future lookups can give infinite loops or crashes. We must delete the vlan_group using RCU safe procedure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15vlan: Use __vlan_hwaccel_put_tag() in rxEric Dumazet
Commit 05423b241311c9380 (vlan: allow null VLAN ID to be used) forgot to update __vlan_hwaccel_rx() & vlan_gro_common() We need to set VLAN_TAG_PRESENT flag in skb->vlan_tci Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13vlan/macvlan: propagate transmission state to upper layersPatrick McHardy
Both vlan and macvlan devices usually don't use a qdisc and immediately queue packets to the underlying device. Propagate transmission state of the underlying device to the upper layers so they can react on congestion and/or inform the sending process. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10vlan: eliminate use of dev_base_lockstephen hemminger
Do not need to use read_lock(&dev_base_lock), use RCU instead. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08net: Support specifying the network namespace upon device creation.Eric W. Biederman
There is no good reason to not support userspace specifying the network namespace during device creation, and it makes it easier to create a network device and pass it to a child network namespace with a well known name. We have to be careful to ensure that the target network namespace for the new device exists through the life of the call. To keep that logic clear I have factored out the network namespace grabbing logic into rtnl_link_get_net. In addtion we need to continue to pass the source network namespace to the rtnl_link_ops.newlink method so that we can find the base device source network namespace. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2009-10-29vlan: cleanup multiple unregistrationsPatrick McHardy
The temporary copy of the VLAN group is not neccessary since the lower device is already in the process of being unregistered, if it was neccessary the memset of the global group would introduce a race condition. With this removed, the changes to the original code are only a few lines, so remove the new function and move the code back into vlan_device_event(). Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gro: Change all receive functions to return GRO result codesBen Hutchings
This will allow drivers to adjust their receive path dynamically based on whether GRO is being applied successfully. Currently all in-tree callers ignore the return values of these functions and do not need to be changed. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gro: Name the GRO result enumeration typeBen Hutchings
This clarifies which return and parameter types are GRO result codes and not RX result codes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29vlan: Add support to netdev_ops.ndo_fcoe_get_wwn for VLAN deviceYi Zou
Implements the netdev_ops.ndo_fcoe_get_wwn for VLAN device. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28vlan: Optimize multiple unregistrationEric Dumazet
Use unregister_netdevice_many() to speedup master device unregister. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28net: add a list_head parameter to dellink() methodEric Dumazet
Adding a list_head parameter to rtnl_link_ops->dellink() methods allow us to queue devices on a list, in order to dismantle them all at once. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27vlan: allow null VLAN ID to be usedEric Dumazet
We currently use a 16 bit field (vlan_tci) to store VLAN ID/PRIO on a skb. Null value is used as a special value, meaning vlan tagging not enabled. This forbids use of null vlan ID. As pointed by David, some drivers use the 3 high order bits (PRIO) As VLAN ID is 12 bits, we can use the remaining bit (CFI) as a flag, and allow null VLAN ID. In case future code really wants to use VLAN_CFI_MASK, we'll have to use a bit outside of vlan_tci. #define VLAN_PRIO_MASK 0xe000 /* Priority Code Point */ #define VLAN_PRIO_SHIFT 13 #define VLAN_CFI_MASK 0x1000 /* Canonical Format Indicator */ #define VLAN_TAG_PRESENT VLAN_CFI_MASK #define VLAN_VID_MASK 0x0fff /* VLAN Identifier */ Reported-by: Gertjan Hofman <gertjan_hofman@yahoo.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26net: fix vlan_get_size to include vlan_flags sizeJohn Fastabend
Fix vlan_get_size to include vlan->flags. Currently, the size of the vlan flags is not included in the nlmsg size. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03vlan: adds drops accountingEric Dumazet
Its hard to tell if vlans are dropping frames, since every frame given to vlan_???_start_xmit() functions is accounted as fully transmitted by lower device. We can test dev_queue_xmit() return values to properly account for dropped frames. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03vlan: enable multiqueue xmitsEric Dumazet
vlan_dev_hard_start_xmit() & vlan_dev_hwaccel_hard_start_xmit() select txqueue number 0, instead of using index provided by skb_get_queue_mapping(). This is not correct after commit 2e59af3dcbdf11635c03f [vlan: multiqueue vlan device] because txq->tx_packets & txq->tx_bytes changes are performed on a single location, and not the right locking. Fix is to take the appropriate struct netdev_queue pointer Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02vlan: multiqueue vlan deviceEric Dumazet
vlan devices are currently not multi-queue capable. We can do that with a new rtnl_link_ops method, get_tx_queues(), called from rtnl_create_link() This new method gets num_tx_queues/real_num_tx_queues from real device. register_vlan_device() is also handled. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01vlan: Add support for net_devices_ops.ndo_fcoe_enable/_disable to VLANYi Zou
This adds implementation of the net_devices_ops.ndo_fcoe_enable/_disable to the VLAN driver. It checks if the real_dev has support for ndo_fcoe_enable/ ndo_fcoe_disable and if so, passes on to call the associated real_dev. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert pseudo-devices to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-14vlan: adds fcoe offload related net_device_ops and updates fcoe_ddp_xid fieldVasu Dev
Adds fcoe offload related net_device_ops functions vlan_dev_fcoe_ddp_setup and vlan_dev_fcoe_ddp_done, their implementation simply calls real eth device net_device_ops for FCoE DDP setup and done operations. Updates VLAN netdev field value for fcoe_ddp_xid from real eth device netdev. Above changes are required for fcoe DDP offload working on a VLAN interface. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: mark read-only arrays as constJan Engelhardt
String literals are constant, and usually, we can also tag the array of pointers const too, moving it to the .rodata section. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30vlan: allow creating vlan when real device is not upStephen Hemminger
There is no reason for the arbitrary restriction that device must be up to create a vlan. This patch was added to Vyatta kernel to resolve startup ordering issues where vlan's are created but real device was disabled. Note: the vlan already correctly inherits the operstate from real device; so if vlan is created and real device is marked down, the vlan is marked down. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20vlan: Propagate physical MTU changesHerbert Xu
When the physical MTU changes we want to ensure that all existing VLAN device MTUs do not exceed the new underlying MTU. This patch adds that propagation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-108021q: Vlan driver should use rcu_barrier() on unload instead of ↵Jesper Dangaard Brouer
syncronize_net() The VLAN 8021q driver needs to call rcu_barrier() when unloading the module, instead of syncronize_net(). This is needed to make sure that outstanding call_rcu() callbacks have completed, before the callback function code is removed on module unload. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
