path: root/net/9p/trans_rdma.c
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cma: Save PID of ID's owner RDMA/cma: Add support for netlink statistics export RDMA/cma: Pass QP type into rdma_create_id() RDMA: Update exported headers list RDMA/cma: Export enum cma_state in <rdma/rdma_cm.h> RDMA/nes: Add a check for strict_strtoul() RDMA/cxgb3: Don't post zero-byte read if endpoint is going away RDMA/cxgb4: Use completion objects for event blocking IB/srp: Fix integer -> pointer cast warnings IB: Add devnode methods to cm_class and umad_class IB/mad: Return EPROTONOSUPPORT when an RDMA device lacks the QP required IB/uverbs: Add devnode method to set path/mode RDMA/ucma: Add .nodename/.mode to tell userspace where to create device node RDMA: Add netlink infrastructure RDMA: Add error handling to ib_core_init()
2011-05-25RDMA/cma: Pass QP type into rdma_create_id()Sean Hefty
The RDMA CM currently infers the QP type from the port space selected by the user. In the future (eg with RDMA_PS_IB or XRC), there may not be a 1-1 correspondence between port space and QP type. For netlink export of RDMA CM state, we want to export the QP type to userspace, so it is cleaner to explicitly associate a QP type to an ID. Modify rdma_create_id() to allow the user to specify the QP type, and use it to make our selections of datagram versus connected mode. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-05-199p: Kill unused variable 'ret' in trans_rdma.c:parse_opts()David S. Miller
Probably just cut and pasted from the other parse_opts() implementations in the 9p sources. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-22net/9p: Convert the in the 9p rpc call path to GFP_NOFSAneesh Kumar K.V
Without this we can cause reclaim allocation in writepage. [ 3433.448430] ================================= [ 3433.449117] [ INFO: inconsistent lock state ] [ 3433.449117] 2.6.38-rc5+ #84 [ 3433.449117] --------------------------------- [ 3433.449117] inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-R} usage. [ 3433.449117] kswapd0/505 [HC0[0]:SC0[0]:HE1:SE1] takes: [ 3433.449117] (iprune_sem){+++++-}, at: [<ffffffff810ebbab>] shrink_icache_memory+0x45/0x2b1 [ 3433.449117] {RECLAIM_FS-ON-W} state was registered at: [ 3433.449117] [<ffffffff8107fe5f>] mark_held_locks+0x52/0x70 [ 3433.449117] [<ffffffff8107ff02>] lockdep_trace_alloc+0x85/0x9f [ 3433.449117] [<ffffffff810d353d>] slab_pre_alloc_hook+0x18/0x3c [ 3433.449117] [<ffffffff810d3fd5>] kmem_cache_alloc+0x23/0xa2 [ 3433.449117] [<ffffffff8127be77>] idr_pre_get+0x2d/0x6f [ 3433.449117] [<ffffffff815434eb>] p9_idpool_get+0x30/0xae [ 3433.449117] [<ffffffff81540123>] p9_client_rpc+0xd7/0x9b0 [ 3433.449117] [<ffffffff815427b0>] p9_client_clunk+0x88/0xdb [ 3433.449117] [<ffffffff811d56e5>] v9fs_evict_inode+0x3c/0x48 [ 3433.449117] [<ffffffff810eb511>] evict+0x1f/0x87 [ 3433.449117] [<ffffffff810eb5c0>] dispose_list+0x47/0xe3 [ 3433.449117] [<ffffffff810eb8da>] evict_inodes+0x138/0x14f [ 3433.449117] [<ffffffff810d90e2>] generic_shutdown_super+0x57/0xe8 [ 3433.449117] [<ffffffff810d91e8>] kill_anon_super+0x11/0x50 [ 3433.449117] [<ffffffff811d4951>] v9fs_kill_super+0x49/0xab [ 3433.449117] [<ffffffff810d926e>] deactivate_locked_super+0x21/0x46 [ 3433.449117] [<ffffffff810d9e84>] deactivate_super+0x40/0x44 [ 3433.449117] [<ffffffff810ef848>] mntput_no_expire+0x100/0x109 [ 3433.449117] [<ffffffff810f0aeb>] sys_umount+0x2f1/0x31c [ 3433.449117] [<ffffffff8102c87b>] system_call_fastpath+0x16/0x1b [ 3433.449117] irq event stamp: 192941 [ 3433.449117] hardirqs last enabled at (192941): [<ffffffff81568dcf>] _raw_spin_unlock_irq+0x2b/0x30 [ 3433.449117] hardirqs last disabled at (192940): [<ffffffff810b5f97>] shrink_inactive_list+0x290/0x2f5 [ 3433.449117] softirqs last enabled at (188470): [<ffffffff8105fd65>] __do_softirq+0x133/0x152 [ 3433.449117] softirqs last disabled at (188455): [<ffffffff8102d7cc>] call_softirq+0x1c/0x28 [ 3433.449117] [ 3433.449117] other info that might help us debug this: [ 3433.449117] 1 lock held by kswapd0/505: [ 3433.449117] #0: (shrinker_rwsem){++++..}, at: [<ffffffff810b52e2>] shrink_slab+0x38/0x15f [ 3433.449117] [ 3433.449117] stack backtrace: [ 3433.449117] Pid: 505, comm: kswapd0 Not tainted 2.6.38-rc5+ #84 [ 3433.449117] Call Trace: [ 3433.449117] [<ffffffff8107fbce>] ? valid_state+0x17e/0x191 [ 3433.449117] [<ffffffff81036896>] ? save_stack_trace+0x28/0x45 [ 3433.449117] [<ffffffff81080426>] ? check_usage_forwards+0x0/0x87 [ 3433.449117] [<ffffffff8107fcf4>] ? mark_lock+0x113/0x22c [ 3433.449117] [<ffffffff8108105f>] ? __lock_acquire+0x37a/0xcf7 [ 3433.449117] [<ffffffff8107fc0e>] ? mark_lock+0x2d/0x22c [ 3433.449117] [<ffffffff81081077>] ? __lock_acquire+0x392/0xcf7 [ 3433.449117] [<ffffffff810b14d2>] ? determine_dirtyable_memory+0x15/0x28 [ 3433.449117] [<ffffffff81081a33>] ? lock_acquire+0x57/0x6d [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff81567d85>] ? down_read+0x47/0x5c [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff810b5385>] ? shrink_slab+0xdb/0x15f [ 3433.449117] [<ffffffff810b69bc>] ? kswapd+0x574/0x96a [ 3433.449117] [<ffffffff810b6448>] ? kswapd+0x0/0x96a [ 3433.449117] [<ffffffff810714e2>] ? kthread+0x7d/0x85 [ 3433.449117] [<ffffffff8102d6d4>] ? kernel_thread_helper+0x4/0x10 [ 3433.449117] [<ffffffff81569200>] ? restore_args+0x0/0x30 [ 3433.449117] [<ffffffff81071465>] ? kthread+0x0/0x85 [ 3433.449117] [<ffffffff8102d6d0>] ? kernel_thread_helper+0x0/0x10 Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-01-19net: cleanup unused macros in net directoryShan Wei
Clean up some unused macros in net/*. 1. be left for code change. e.g. PGV_FROM_VMALLOC, PGV_FROM_VMALLOC, KMEM_SAFETYZONE. 2. never be used since introduced to kernel. e.g. P9_RDMA_MAX_SGE, UTIL_CTRL_PKT_SIZE. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27net/9p: fix memory handling/allocation in rdma_request()Davidlohr Bueso
Return -ENOMEM when erroring on kmalloc and fix memory leaks when returning on error. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-089p: fix option parsingEric Van Hensbergen
Options pointer is being moved before calling kfree() which seems to cause problems. This uses a separate pointer to track and free original allocation. Signed-off-by: Venkateswararao Jujjuri <jvrao@us.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>w
2009-08-179p: minor comment fixesAbhishek Kulkarni
Fix the comments -- mostly the improper and/or missing descriptions of function parameters. Signed-off-by: Abhishek Kulkarni <adkulkar@umail.iu.edu> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2009-04-05net/9p: handle correctly interrupted 9P requestsLatchesar Ionkov
Currently the 9p code crashes when a operation is interrupted, i.e. for example when the user presses ^C while reading from a file. This patch fixes the code that is responsible for interruption and flushing of 9P operations. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
2008-11-21net: remove redundant argument commentsQinghuang Feng
Remove redundant argument comments in files of net/* Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-059p: rdma: remove duplicated #includeHuang Weiyi
Removed duplicated #include <rdma/ib_verbs.h> in net/9p/trans_rdma.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-059p: rdma: Set trans prior to requesting async connection opsTom Tucker
The RDMA connection manager is fundamentally asynchronous. Since the async callback context is the client pointer, the transport in the client struct needs to be set prior to calling the first async op. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-10-229p: rdma: RDMA Transport Support for 9PTom Tucker
This patch implements the RDMA transport provider for 9P. It allows mounts to be performed over iWARP and IB capable network interfaces. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Latchesar Ionkov <lionkov@lanl.gov>
