path: root/net/9p/util.c
2012-01-059p: Reduce object size with CONFIG_NET_9P_DEBUGJoe Perches
Reduce object size by deduplicating formats. Use vsprintf extension %pV. Rename P9_DPRINTK uses to p9_debug, align arguments. Add function for _p9_debug and macro to add __func__. Add missing "\n"s to p9_debug uses. Remove embedded function names as p9_debug adds it. Remove P9_EPRINTK macro and convert use to pr_<level>. Add and use pr_fmt and pr_<level>. $ size fs/9p/built-in.o* text data bss dec hex filename 62133 984 16000 79117 1350d fs/9p/built-in.o.new 67342 984 16928 85254 14d06 fs/9p/built-in.o.old $ size net/9p/built-in.o* text data bss dec hex filename 88792 4148 22024 114964 1c114 net/9p/built-in.o.new 94072 4148 23232 121452 1da6c net/9p/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-25net/9p: p9_idpool_get return -1 on errorAneesh Kumar K.V
We need to return -1 on error. Also handle error properly Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-22net/9p: Convert the in the 9p rpc call path to GFP_NOFSAneesh Kumar K.V
Without this we can cause reclaim allocation in writepage. [ 3433.448430] ================================= [ 3433.449117] [ INFO: inconsistent lock state ] [ 3433.449117] 2.6.38-rc5+ #84 [ 3433.449117] --------------------------------- [ 3433.449117] inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-R} usage. [ 3433.449117] kswapd0/505 [HC0[0]:SC0[0]:HE1:SE1] takes: [ 3433.449117] (iprune_sem){+++++-}, at: [<ffffffff810ebbab>] shrink_icache_memory+0x45/0x2b1 [ 3433.449117] {RECLAIM_FS-ON-W} state was registered at: [ 3433.449117] [<ffffffff8107fe5f>] mark_held_locks+0x52/0x70 [ 3433.449117] [<ffffffff8107ff02>] lockdep_trace_alloc+0x85/0x9f [ 3433.449117] [<ffffffff810d353d>] slab_pre_alloc_hook+0x18/0x3c [ 3433.449117] [<ffffffff810d3fd5>] kmem_cache_alloc+0x23/0xa2 [ 3433.449117] [<ffffffff8127be77>] idr_pre_get+0x2d/0x6f [ 3433.449117] [<ffffffff815434eb>] p9_idpool_get+0x30/0xae [ 3433.449117] [<ffffffff81540123>] p9_client_rpc+0xd7/0x9b0 [ 3433.449117] [<ffffffff815427b0>] p9_client_clunk+0x88/0xdb [ 3433.449117] [<ffffffff811d56e5>] v9fs_evict_inode+0x3c/0x48 [ 3433.449117] [<ffffffff810eb511>] evict+0x1f/0x87 [ 3433.449117] [<ffffffff810eb5c0>] dispose_list+0x47/0xe3 [ 3433.449117] [<ffffffff810eb8da>] evict_inodes+0x138/0x14f [ 3433.449117] [<ffffffff810d90e2>] generic_shutdown_super+0x57/0xe8 [ 3433.449117] [<ffffffff810d91e8>] kill_anon_super+0x11/0x50 [ 3433.449117] [<ffffffff811d4951>] v9fs_kill_super+0x49/0xab [ 3433.449117] [<ffffffff810d926e>] deactivate_locked_super+0x21/0x46 [ 3433.449117] [<ffffffff810d9e84>] deactivate_super+0x40/0x44 [ 3433.449117] [<ffffffff810ef848>] mntput_no_expire+0x100/0x109 [ 3433.449117] [<ffffffff810f0aeb>] sys_umount+0x2f1/0x31c [ 3433.449117] [<ffffffff8102c87b>] system_call_fastpath+0x16/0x1b [ 3433.449117] irq event stamp: 192941 [ 3433.449117] hardirqs last enabled at (192941): [<ffffffff81568dcf>] _raw_spin_unlock_irq+0x2b/0x30 [ 3433.449117] hardirqs last disabled at (192940): [<ffffffff810b5f97>] shrink_inactive_list+0x290/0x2f5 [ 3433.449117] softirqs last enabled at (188470): [<ffffffff8105fd65>] __do_softirq+0x133/0x152 [ 3433.449117] softirqs last disabled at (188455): [<ffffffff8102d7cc>] call_softirq+0x1c/0x28 [ 3433.449117] [ 3433.449117] other info that might help us debug this: [ 3433.449117] 1 lock held by kswapd0/505: [ 3433.449117] #0: (shrinker_rwsem){++++..}, at: [<ffffffff810b52e2>] shrink_slab+0x38/0x15f [ 3433.449117] [ 3433.449117] stack backtrace: [ 3433.449117] Pid: 505, comm: kswapd0 Not tainted 2.6.38-rc5+ #84 [ 3433.449117] Call Trace: [ 3433.449117] [<ffffffff8107fbce>] ? valid_state+0x17e/0x191 [ 3433.449117] [<ffffffff81036896>] ? save_stack_trace+0x28/0x45 [ 3433.449117] [<ffffffff81080426>] ? check_usage_forwards+0x0/0x87 [ 3433.449117] [<ffffffff8107fcf4>] ? mark_lock+0x113/0x22c [ 3433.449117] [<ffffffff8108105f>] ? __lock_acquire+0x37a/0xcf7 [ 3433.449117] [<ffffffff8107fc0e>] ? mark_lock+0x2d/0x22c [ 3433.449117] [<ffffffff81081077>] ? __lock_acquire+0x392/0xcf7 [ 3433.449117] [<ffffffff810b14d2>] ? determine_dirtyable_memory+0x15/0x28 [ 3433.449117] [<ffffffff81081a33>] ? lock_acquire+0x57/0x6d [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff81567d85>] ? down_read+0x47/0x5c [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff810ebbab>] ? shrink_icache_memory+0x45/0x2b1 [ 3433.449117] [<ffffffff810b5385>] ? shrink_slab+0xdb/0x15f [ 3433.449117] [<ffffffff810b69bc>] ? kswapd+0x574/0x96a [ 3433.449117] [<ffffffff810b6448>] ? kswapd+0x0/0x96a [ 3433.449117] [<ffffffff810714e2>] ? kthread+0x7d/0x85 [ 3433.449117] [<ffffffff8102d6d4>] ? kernel_thread_helper+0x4/0x10 [ 3433.449117] [<ffffffff81569200>] ? restore_args+0x0/0x30 [ 3433.449117] [<ffffffff81071465>] ? kthread+0x0/0x85 [ 3433.449117] [<ffffffff8102d6d0>] ? kernel_thread_helper+0x0/0x10 Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-10-179p: rework client code to use new protocol support functionsEric Van Hensbergen
Now that the new protocol functions are in place, this patch switches the client code to using the new support code. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-05-149p: fix flags length in netSteven Rostedt
Some files in the net/9p directory uses "int" for flags. This can cause hard to find bugs on some architectures. This patch converts the flags to use "long" instead. This bug was discovered by doing an allyesconfig make on the -rt kernel where checks are done to ensure all flags are of size sizeof(long). Signed-off-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-05-149p: Documentation updatesEric Van Hensbergen
The kernel-doc comments of much of the 9p system have been in disarray since reorganization. This patch fixes those problems, adds additional documentation and a template book which collects the 9p information. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-02-069p: Convert semaphore to spinlock for p9_idpoolAnthony Liguori
When booting from v9fs, down_interruptible in p9_idpool_get() triggered a BUG as it was being called with IRQs disabled. A spinlock seems like the right thing to be using since the idr functions go out of their way not to sleep. This patch eliminates the BUG by converting the semaphore to a spinlock. Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-07-149p: Reorganization of 9p file system codeLatchesar Ionkov
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p. It moves the transport, packet marshalling and connection layers to net/9p leaving only the VFS related files in fs/9p. This work is being done in preparation for in-kernel 9p servers as well as alternate 9p clients (other than VFS). Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
