path: root/net/9p
2012-10-22virtio: 9p: correctly pass physical address to userspace for high pagesWill Deacon
When using a virtio transport, the 9p net device may pass the physical address of a kernel buffer to userspace via a scatterlist inside a virtqueue. If the kernel buffer is mapped outside of the linear mapping (e.g. highmem), then virt_to_page will return a bogus value and we will populate the scatterlist with junk. This patch uses kmap_to_page when populating the page array for a kernel buffer. Cc: stable@kernel.org Cc: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-12Merge tag 'for-linus-merge-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull v9fs update from Eric Van Hensbergen. * tag 'for-linus-merge-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9P: Fix race between p9_write_work() and p9_fd_request() 9P: Fix race in p9_write_work() 9P: fix test at the end of p9_write_work() 9P: Fix race in p9_read_work() 9p: don't use __getname/__putname for uname/aname net/9p: Check errno validity fs/9p: avoid debug OOPS when reading a long symlink
2012-10-119P: Fix race between p9_write_work() and p9_fd_request()Simon Derr
Race scenario: thread A thread B p9_write_work() p9_fd_request() if (list_empty (&m->unsent_req_list)) ... spin_lock(&client->lock); req->status = REQ_STATUS_UNSENT; list_add_tail(..., &m->unsent_req_list); spin_unlock(&client->lock); .... if (n & POLLOUT && !test_and_set_bit(Wworksched, &m->wsched) schedule_work(&m->wq); --> not done because Wworksched is set clear_bit(Wworksched, &m->wsched); return; --> nobody will take care of sending the new request. This is not very likely to happen though, because p9_write_work() being called with an empty unsent_req_list is not frequent. But this also means that taking the lock earlier will not be costly. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-09-26unexport sock_map_fd(), switch to sock_alloc_file()Al Viro
Both modular callers of sock_map_fd() had been buggy; sctp one leaks descriptor and file if copy_to_user() fails, 9p one shouldn't be exposing file in the descriptor table at all. Switch both to sock_alloc_file(), export it, unexport sock_map_fd() and make it static. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-179P: Fix race in p9_write_work()Simon Derr
See previous commit about p9_read_work() for details. This fixes a similar race between p9_write_work() and p9_poll_mux() Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-09-179P: fix test at the end of p9_write_work()Simon Derr
At the end of p9_write_work() we want to test if there is still data to send. This means: - either the current request still has data to send (wsize != 0) - or there are requests in the unsent queue Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-09-179P: Fix race in p9_read_work()Simon Derr
Race scenario between p9_read_work() and p9_poll_mux() Data arrive, Rworksched is set, p9_read_work() is called. thread A thread B p9_read_work() . reads data . checks if new data ready. No. . gets preempted . More data arrive, p9_poll_mux() is called. . . . p9_poll_mux() . . if (!test_and_set_bit(Rworksched, . &m->wsched)) { . schedule_work(&m->rq); . } . . -> does not schedule work because . Rworksched is set . . clear_bit(Rworksched, &m->wsched); return; No work has been scheduled, and yet data are waiting. Currently p9_read_work() checks if there is data to read, and if not, it clears Rworksched. I think it should clear Rworksched first, and then check if there is data to read. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-09-06net/9p: Check errno validitySimon Derr
While working on a modified server I had the Linux clients crash a few times. This lead me to find this: Some error codes are directly extracted from the server replies. A malformed server reply could contain an invalid error code, with a very large value. If this value is then passed to ERR_PTR() it will not be properly detected as an error code by IS_ERR() and as a result the kernel will dereference an invalid pointer. This patch tries to avoid this. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-07-10net: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/caif/caif_hsi.c drivers/net/usb/qmi_wwan.c The qmi_wwan merge was trivial. The caif_hsi.c, on the other hand, was not. It's a conflict between 1c385f1fdf6f9c66d982802cd74349c040980b50 ("caif-hsi: Replace platform device with ops structure.") in the net-next tree and commit 39abbaef19cd0a30be93794aa4773c779c3eb1f3 ("caif-hsi: Postpone init of HIS until open()") in the net tree. I did my best with that one and will ask Sjur to check it out. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking update from David Miller: 1) Pairing and deadlock fixes in bluetooth from Johan Hedberg. 2) Add device IDs for AR3011 and AR3012 bluetooth chips. From Giancarlo Formicuccia and Marek Vasut. 3) Fix wireless regulatory deadlock, from Eliad Peller. 4) Fix full TX ring panic in bnx2x driver, from Eric Dumazet. 5) Revert the two commits that added skb_orphan_try(), it causes erratic bonding behavior with UDP clients and the gains it used to give are mostly no longer happening due to how BQL works. From Eric Dumazet. 6) It took two tries, but Thomas Graf fixed a problem wherein we registered ipv6 routing procfs files before their backend data were initialized properly. 7) Fix max GSO size setting in be2net, from Sarveshwar Bandi. 8) PHY device id mask is wrong for KSZ9021 and KS8001 chips, fix from Jason Wang. 9) Fix use of stale SKB data pointer after skb_linearize() call in batman-adv, from Antonio Quartulli. 10) Fix memory leak in IXGBE due to missing __GFP_COMP, from Alexander Duyck. 11) Fix probing of Gobi devices in qmi_wwan usbnet driver, from Bjørn Mork. 12) Fix suspend/resume and open failure handling in usbnet from Ming Lei. 13) Attempt to fix device r8169 hangs for certain chips, from Francois Romieu. 14) Fix advancement of RX dirty pointer in some situations in sh_eth driver, from Yoshihiro Shimoda. 15) Attempt to fix restart of IPV6 routing table dumps when there is an intervening table update. From Eric Dumazet. 16) Respect security_inet_conn_request() return value in ipv6 TCP. From Neal Cardwell. 17) Add another iPAD device ID to ipheth driver, from Davide Gerhard. 18) Fix access to freed SKB in l2tp_eth_dev_xmit(), and fix l2tp lockdep splats, from Eric Dumazet. 19) Make sure all bridge devices, regardless of whether they were created via netlink or ioctls, have their rtnetlink ops hooked up. From Thomas Graf and Stephen Hemminger. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (81 commits) 9p: fix min_t() casting in p9pdu_vwritef() can: flexcan: use be32_to_cpup to handle the value of dt entry xen/netfront: teardown the device before unregistering it. bridge: Assign rtnl_link_ops to bridge devices created via ioctl (v2) vhost: use USER_DS in vhost_worker thread ixgbe: Do not pad FCoE frames as this can cause issues with FCoE DDP net: l2tp_eth: use LLTX to avoid LOCKDEP splats mac802154: add missed braces net: l2tp_eth: fix l2tp_eth_dev_xmit race net/mlx4_en: Release QP range in free_resources net/mlx4: Use single completion vector after NOP failure net/mlx4_en: Set correct port parameters during device initialization ipheth: add support for iPad caif-hsi: Add missing return in error path caif-hsi: Bugfix - Piggyback'ed embedded CAIF frame lost caif: Clear shutdown mask to zero at reconnect. tcp: heed result of security_inet_conn_request() in tcp_v6_conn_request() ipv6: fib: fix fib dump restart batman-adv: fix race condition in TT full-table replacement batman-adv: only drop packets of known wifi clients ...
2012-06-279p: fix min_t() casting in p9pdu_vwritef()Dan Carpenter
I don't think we're actually likely to hit this limit but if we do then the comparison should be done as size_t. The original code is equivalent to: len = strlen(sptr) % USHRT_MAX; Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-119p: BUG before corrupting memorySasha Levin
The BUG_ON() in pack_sg_list() would get triggered only one time after we've corrupted some memory by sg_set_buf() into an invalid sg buffer. I'm still working on figuring out why I manage to trigger that bug... Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-06-04net/9p: Add __force to cast of __user pointerJoe Perches
A recent commit that removed unnecessary casts of pointers to the same type uncovered a missing __force cast. Add it. Reported by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-04net: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force and __user. @@ type T; T *p; @@ - (T *)p + p Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-21Merge tag 'virtio-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus Pull virtio updates from Rusty Russell. * tag 'virtio-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: virtio: fix typo in comment virtio-mmio: Devices parameter parsing virtio_blk: Drop unused request tracking list virtio-blk: Fix hot-unplug race in remove method virtio: Use ida to allocate virtio index virtio: balloon: separate out common code between remove and freeze functions virtio: balloon: drop restore_common() 9p: disconnect channel when PCI device is removed virtio: update documentation to v0.9.5 of spec
2012-05-229p: disconnect channel when PCI device is removedSasha Levin
When a virtio_9p pci device is being removed, we should close down any active channels and free up resources, we're not supposed to BUG() if there's still an open channel since it's a valid case when removing the PCI device. Otherwise, removing the PCI device with an open channel would cause the following BUG(): [ 1184.671416] ------------[ cut here ]------------ [ 1184.672057] kernel BUG at net/9p/trans_virtio.c:618! [ 1184.672057] invalid opcode: 0000 [#1] PREEMPT SMP [ 1184.672057] CPU 3 [ 1184.672057] Pid: 5, comm: kworker/u:0 Tainted: G W 3.4.0-rc2-next-20120413-sasha-dirty #76 [ 1184.672057] RIP: 0010:[<ffffffff825c9116>] [<ffffffff825c9116>] p9_virtio_remove+0x16/0x90 [ 1184.672057] RSP: 0018:ffff88000d653ac0 EFLAGS: 00010202 [ 1184.672057] RAX: ffffffff836bfb40 RBX: ffff88000c9b2148 RCX: ffff88000d658978 [ 1184.672057] RDX: 0000000000000006 RSI: 0000000000000000 RDI: ffff880028868000 [ 1184.672057] RBP: ffff88000d653ad0 R08: 0000000000000000 R09: 0000000000000000 [ 1184.672057] R10: 0000000000000000 R11: 0000000000000001 R12: ffff880028868000 [ 1184.672057] R13: ffffffff835aa7c0 R14: ffff880041630000 R15: ffff88000d653da0 [ 1184.672057] FS: 0000000000000000(0000) GS:ffff880035a00000(0000) knlGS:0000000000000000 [ 1184.672057] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 1184.672057] CR2: 0000000001181000 CR3: 000000000eba1000 CR4: 00000000000406e0 [ 1184.672057] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 x000000000117a190 *[ 1184.672057] DR3: 00000000000000** 00 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 1184.672057] Process kworker/u:0 (pid: 5, threadinfo ffff88000d652000, task ffff88000d658000) [ 1184.672057] Stack: [ 1184.672057] ffff880028868000 ffffffff836bfb40 ffff88000d653af0 ffffffff8193661b [ 1184.672057] ffff880028868008 ffffffff836bfb40 ffff88000d653b10 ffffffff81af1c81 [ 1184.672057] ffff880028868068 ffff880028868008 ffff88000d653b30 ffffffff81af257a [ 1184.795301] Call Trace: [ 1184.795301] [<ffffffff8193661b>] virtio_dev_remove+0x1b/0x60 [ 1184.795301] [<ffffffff81af1c81>] __device_release_driver+0x81/0xd0 [ 1184.795301] [<ffffffff81af257a>] device_release_driver+0x2a/0x40 [ 1184.795301] [<ffffffff81af0d48>] bus_remove_device+0x138/0x150 [ 1184.795301] [<ffffffff81aef08d>] device_del+0x14d/0x1b0 [ 1184.795301] [<ffffffff81aef138>] device_unregister+0x48/0x60 [ 1184.795301] [<ffffffff8193694d>] unregister_virtio_device+0xd/0x10 [ 1184.795301] [<ffffffff8265fc74>] virtio_pci_remove+0x2a/0x6c [ 1184.795301] [<ffffffff818a95ad>] pci_device_remove+0x4d/0x110 [ 1184.795301] [<ffffffff81af1c81>] __device_release_driver+0x81/0xd0 [ 1184.795301] [<ffffffff81af257a>] device_release_driver+0x2a/0x40 [ 1184.795301] [<ffffffff81af0d48>] bus_remove_device+0x138/0x150 [ 1184.795301] [<ffffffff81aef08d>] device_del+0x14d/0x1b0 [ 1184.795301] [<ffffffff81aef138>] device_unregister+0x48/0x60 [ 1184.795301] [<ffffffff818a36fa>] pci_stop_bus_device+0x6a/0x90 [ 1184.795301] [<ffffffff818a3791>] pci_stop_and_remove_bus_device+0x11/0x20 [ 1184.795301] [<ffffffff818c21d9>] remove_callback+0x9/0x10 [ 1184.795301] [<ffffffff81252d91>] sysfs_schedule_callback_work+0x21/0x60 [ 1184.795301] [<ffffffff810cb1a1>] process_one_work+0x281/0x430 [ 1184.795301] [<ffffffff810cb140>] ? process_one_work+0x220/0x430 [ 1184.795301] [<ffffffff81252d70>] ? sysfs_read_file+0x1c0/0x1c0 [ 1184.795301] [<ffffffff810cc613>] worker_thread+0x1f3/0x320 [ 1184.795301] [<ffffffff810cc420>] ? manage_workers.clone.13+0x130/0x130 [ 1184.795301] [<ffffffff810d30b2>] kthread+0xb2/0xc0 [ 1184.795301] [<ffffffff826783f4>] kernel_thread_helper+0x4/0x10 [ 1184.795301] [<ffffffff810deb18>] ? finish_task_switch+0x78/0xf0 [ 1184.795301] [<ffffffff82676574>] ? retint_restore_args+0x13/0x13 [ 1184.795301] [<ffffffff810d3000>] ? kthread_flush_work_fn+0x10/0x10 [ 1184.795301] [<ffffffff826783f0>] ? gs_change+0x13/0x13 [ 1184.795301] Code: c1 9e 0a 00 48 83 c4 08 5b c9 c3 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 e5 41 54 49 89 fc 53 48 8b 9f a8 04 00 00 80 3b 00 74 0a <0f> 0b 0f 1f 84 00 00 00 00 00 48 8b 87 88 04 00 00 ff 50 30 31 [ 1184.795301] RIP [<ffffffff825c9116>] p9_virtio_remove+0x16/0x90 [ 1184.795301] RSP <ffff88000d653ac0> [ 1184.952618] ---[ end trace a307b3ed40206b4c ]--- Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-26net/9p: handle flushed Tclunk/TremoveJim Garlick
When a Tclunk or Tremove request is flushed, the fid is not freed on the server. p9_client_clunk() should retry once on interrupt, then if interrupted again, leak the fid for the duration of the connection. p9_client_remove() should call p9_client_clunk() on interrupt instead of unconditionally destroying the fid. Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-02-26net/9p: don't allow Tflush to be interruptedJim Garlick
When a signal is received while sending a Tflush, the client, which has recursed into p9_client_rpc() while sending another request, should wait for Rflush as long as the transport is still up. Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2012-01-12virtio: rename virtqueue_add_buf_gfp to virtqueue_add_bufRusty Russell
Remove wrapper functions. This makes the allocation type explicit in all callers; I used GPF_KERNEL where it seemed obvious, left it at GFP_ATOMIC otherwise. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Christoph Hellwig <hch@lst.de>
2012-01-059p: Reduce object size with CONFIG_NET_9P_DEBUGJoe Perches
Reduce object size by deduplicating formats. Use vsprintf extension %pV. Rename P9_DPRINTK uses to p9_debug, align arguments. Add function for _p9_debug and macro to add __func__. Add missing "\n"s to p9_debug uses. Remove embedded function names as p9_debug adds it. Remove P9_EPRINTK macro and convert use to pr_<level>. Add and use pr_fmt and pr_<level>. $ size fs/9p/built-in.o* text data bss dec hex filename 62133 984 16000 79117 1350d fs/9p/built-in.o.new 67342 984 16928 85254 14d06 fs/9p/built-in.o.old $ size net/9p/built-in.o* text data bss dec hex filename 88792 4148 22024 114964 1c114 net/9p/built-in.o.new 94072 4148 23232 121452 1da6c net/9p/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-24net/9p: Convert net/9p protocol dumps to tracepointsAneesh Kumar K.V
This helps in more control over debugging. root@qemu-img-64:~# ls /pass/123 ls: cannot access /pass/123: No such file or directory root@qemu-img-64:~# cat /sys/kernel/debug/tracing/trace # tracer: nop # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | ls-1536 [001] 70.928584: 9p_protocol_dump: clnt 18446612132784021504 P9_TWALK(tag = 1) 000: 16 00 00 00 6e 01 00 01 00 00 00 02 00 00 00 01 010: 00 03 00 31 32 33 00 00 00 ff ff ff ff 00 00 00 ls-1536 [001] 70.928587: <stack trace> => trace_9p_protocol_dump => p9pdu_finalize => p9_client_rpc => p9_client_walk => v9fs_vfs_lookup => d_alloc_and_lookup => walk_component => path_lookupat ls-1536 [000] 70.929696: 9p_protocol_dump: clnt 18446612132784021504 P9_RLERROR(tag = 1) 000: 0b 00 00 00 07 01 00 02 00 00 00 4e 03 00 02 00 010: 00 00 00 00 03 00 02 00 00 00 00 00 ff 43 00 00 ls-1536 [000] 70.929697: <stack trace> => trace_9p_protocol_dump => p9_client_rpc => p9_client_walk => v9fs_vfs_lookup => d_alloc_and_lookup => walk_component => path_lookupat => do_path_lookup Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-24fs/9p: change an int to unsigned intDan Carpenter
Without this msize=4294967295 will result in a crash Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-24fs/9p: Cleanup option parsing in 9pAneesh Kumar K.V
Instead of saying all integer argument option should be listed in the beginning move integer parsing to each option type. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-249p: move dereference after NULL checkDan Carpenter
We dereferenced "req->tc" and "req->rc" before checking for NULL. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-24fs/9p: Update zero-copy implementation in 9pAneesh Kumar K.V
* remove lot of update to different data structure * add a seperate callback for zero copy request. * above makes non zero copy code path simpler * remove conditionalizing TREAD/TREADDIR/TWRITE in the zero copy path * Fix the dotu p9_check_errors with zero copy. Add sufficient doc around * Add support for both in and output buffers in zero copy callback * pin and unpin pages in the same context * use helpers instead of defining page offset and rest of page ourself * Fix mem leak in p9_check_errors * Remove 'E' and 'F' in p9pdu_vwritef Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-09-06net/9p: Fix kernel crash with msize 512KAneesh Kumar K.V
With msize equal to 512K (PAGE_SIZE * VIRTQUEUE_NUM), we hit multiple crashes. This patch fix those. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23net/9p: Fix the msize calculation.Venkateswararao Jujjuri (JV)
msize represents the maximum PDU size that includes P9_IOHDRSZ. Signed-off-by: Venkateswararao Jujjuri "<jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: add 9P2000.L unlinkat operationAneesh Kumar K.V
unlinkat - Remove a directory entry size[4] Tunlinkat tag[2] dirfid[4] name[s] flag[4] size[4] Runlinkat tag[2] older Tremove have the below request format size[4] Tremove tag[2] fid[4] The remove message is used to remove a directory entry either file or directory The remove opreation is actually a directory opertation and should ideally have dirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the directory name from fid in the Tremove request. NOTE: The operation doesn't clunk the unlink fid. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: add 9P2000.L renameat operationAneesh Kumar K.V
renameat - change name of file or directory size[4] Trenameat tag[2] olddirfid[4] oldname[s] newdirfid[4] newname[s] size[4] Rrenameat tag[2] older Trename have the below request format size[4] Trename tag[2] fid[4] newdirfid[4] name[s] The rename message is used to change the name of a file, possibly moving it to a new directory. The rename opreation is actually a directory opertation and should ideally have olddirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the old directory name from fid in the Trename request. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: Clean-up get_protocol_version() to use strcmpPrem Karat
Signed-off-by: Prem Karat <prem.karat@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: Fid is not valid after a failed clunk.Aneesh Kumar K.V
free the fid even in case of failed clunk. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23VirtIO can transfer VIRTQUEUE_NUM of pages.jvrao
Signed-off-by: Venkateswararao Jujjuri "<jvrao@linux.vnet.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23Fix the size of receive buffer packing onto VirtIO ring.jvrao
2011-07-239p: clean up packet dump codeEric Van Hensbergen
Switch to generic kernel hexdump library and cleanup macros to be more consistent with the way we do normal debug prints. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23net/9p: fix client code to fail more gracefully on protocol errorEric Van Hensbergen
There was a BUG_ON to protect against a bad id which could be dealt with more gracefully. Reported-by: Natalie Orlin <norlin@us.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cma: Save PID of ID's owner RDMA/cma: Add support for netlink statistics export RDMA/cma: Pass QP type into rdma_create_id() RDMA: Update exported headers list RDMA/cma: Export enum cma_state in <rdma/rdma_cm.h> RDMA/nes: Add a check for strict_strtoul() RDMA/cxgb3: Don't post zero-byte read if endpoint is going away RDMA/cxgb4: Use completion objects for event blocking IB/srp: Fix integer -> pointer cast warnings IB: Add devnode methods to cm_class and umad_class IB/mad: Return EPROTONOSUPPORT when an RDMA device lacks the QP required IB/uverbs: Add devnode method to set path/mode RDMA/ucma: Add .nodename/.mode to tell userspace where to create device node RDMA: Add netlink infrastructure RDMA: Add error handling to ib_core_init()
2011-05-25RDMA/cma: Pass QP type into rdma_create_id()Sean Hefty
The RDMA CM currently infers the QP type from the port space selected by the user. In the future (eg with RDMA_PS_IB or XRC), there may not be a 1-1 correspondence between port space and QP type. For netlink export of RDMA CM state, we want to export the QP type to userspace, so it is cleaner to explicitly associate a QP type to an ID. Modify rdma_create_id() to allow the user to specify the QP type, and use it to make our selections of datagram versus connected mode. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-05-25net/9p: enable 9p to work in non-default network namespaceRob Landley
Teach 9p filesystem to work in container with non-default network namespace. (Note: I also patched the unix domain socket code but don't have a test case for that. It's the same fix, I just don't have a server for it...) To test, run diod server (http://code.google.com/p/diod): diod -n -f -L stderr -l 172.23.255.1:9999 -c /dev/null -e /root and then mount like so: mount -t 9p -o port=9999,aname=/root,version=9p2000.L 172.23.255.1 /mnt A container test environment is described at http://landley.net/lxc Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-25net/9p: p9_idpool_get return -1 on errorAneesh Kumar K.V
We need to return -1 on error. Also handle error properly Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-259p: remove experimental tag from tested configurationsEric Van Hensbergen
The 9p client is currently undergoing regular regresssion and stress testing as a by-product of the virtfs work. I think its finally time to take off the experimental tags from the well-tested code paths. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-259p: typo fixes and minor cleanupsRob Landley
Typo fixes and minor cleanups for v9fs Signed-off-by: Rob Landley <rob@landley.net> Reviewed-by: Venkateswararao Jujjuri (JV) <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-25net/9p: Change linuxdoc names to match functions.Rob Landley
As on Jeopardy, my question is in the form of a patch: Does this have some special meaning, or is it an accident? (I looked at other filesystems but they didn't bother having doc entries for their init/exit function that I could find.) Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-199p: Kill unused variable 'ret' in trans_rdma.c:parse_opts()David S. Miller
Probably just cut and pasted from the other parse_opts() implementations in the 9p sources. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-199p: Kill set but not used variable 'ret' in parse_opts()David S. Miller
2011-05-12net/9p/protocol.c: Fix a memory leakPedro Scarapicchia Junior
When p9pdu_readf() is called with "s" attribute, it allocates a pointer that will store a string. In p9dirent_read(), this pointer is not being released, leading to out of memory errors. This patch releases this pointer after string is copyed to dirent->d_name. Signed-off-by: Pedro Scarapicchia Junior <pedro.scarapiccha@br.flextronics.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
