[ Upstream commit 6377f787aeb945cae7abbb6474798de129e1f3ac ]
KASAN report this:
BUG: KASAN: use-after-free in pde_subdir_find+0x12d/0x150 fs/proc/generic.c:71
Read of size 8 at addr ffff8881f41fe5b0 by task syz-executor.0/2806
CPU: 0 PID: 2806 Comm: syz-executor.0 Not tainted 5.0.0-rc7+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xfa/0x1ce lib/dump_stack.c:113
print_address_description+0x65/0x270 mm/kasan/report.c:187
kasan_report+0x149/0x18d mm/kasan/report.c:317
remove_proc_entry+0xe8/0x420 fs/proc/generic.c:667
atalk_proc_exit+0x18/0x820 [appletalk]
atalk_exit+0xf/0x5a [appletalk]
__do_sys_delete_module kernel/module.c:1018 [inline]
__se_sys_delete_module kernel/module.c:961 [inline]
__x64_sys_delete_module+0x3dc/0x5e0 kernel/module.c:961
do_syscall_64+0x147/0x600 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x462e99
Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007fb2de6b9c58 EFLAGS: 00000246 ORIG_RAX: 00000000000000b0
RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 00000000200001c0
RBP: 0000000000000002 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007fb2de6ba6bc
R13: 00000000004bccaa R14: 00000000006f6bc8 R15: 00000000ffffffff
Allocated by task 2806:
set_track mm/kasan/common.c:85 [inline]
__kasan_kmalloc.constprop.3+0xa0/0xd0 mm/kasan/common.c:496
slab_post_alloc_hook mm/slab.h:444 [inline]
slab_alloc_node mm/slub.c:2739 [inline]
slab_alloc mm/slub.c:2747 [inline]
kmem_cache_alloc+0xcf/0x250 mm/slub.c:2752
kmem_cache_zalloc include/linux/slab.h:730 [inline]
__proc_create+0x30f/0xa20 fs/proc/generic.c:408
proc_mkdir_data+0x47/0x190 fs/proc/generic.c:469
0xffffffffc10c01bb
0xffffffffc10c0166
do_one_initcall+0xfa/0x5ca init/main.c:887
do_init_module+0x204/0x5f6 kernel/module.c:3460
load_module+0x66b2/0x8570 kernel/module.c:3808
__do_sys_finit_module+0x238/0x2a0 kernel/module.c:3902
Freed by task 2806:
__kasan_slab_free+0x130/0x180 mm/kasan/common.c:458
slab_free_hook mm/slub.c:1409 [inline]
slab_free_freelist_hook mm/slub.c:1436 [inline]
slab_free mm/slub.c:2986 [inline]
kmem_cache_free+0xa6/0x2a0 mm/slub.c:3002
pde_put+0x6e/0x80 fs/proc/generic.c:647
remove_proc_entry+0x1d3/0x420 fs/proc/generic.c:684
0xffffffffc10c031c
0xffffffffc10c0166
The buggy address belongs to the object at ffff8881f41fe500
which belongs to the cache proc_dir_entry of size 256
The buggy address is located 176 bytes inside of
256-byte region [ffff8881f41fe500, ffff8881f41fe600)
The buggy address belongs to the page:
page:ffffea0007d07f80 count:1 mapcount:0 mapping:ffff8881f6e69a00 index:0x0
flags: 0x2fffc0000000200(slab)
raw: 02fffc0000000200 dead000000000100 dead000000000200 ffff8881f6e69a00
raw: 0000000000000000 00000000800c000c 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881f41fe480: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff8881f41fe500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8881f41fe580: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881f41fe600: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8881f41fe680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
It should check the return value of atalk_proc_init fails,
otherwise atalk_exit will trgger use-after-free in pde_subdir_find
while unload the module.This patch fix error cleanup path of atalk_init
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This results in code with less boiler plate that is a bit easier
to read.
Additionally stops us from using compatibility code in the sysctl
core, hastening the day when the compatibility code can be removed.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
This makes it clearer which sysctls are relative to your current network
namespace.
This makes it a little less error prone by not exposing sysctls for the
initial network namespace in other namespaces.
This is the same way we handle all of our other network interfaces to
userspace and I can't honestly remember why we didn't do this for
sysctls right from the start.
Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
I want to compile out proc_* and sysctl_* handlers totally and
stub them to NULL depending on config options, however usage of &
will prevent this, since taking adress of NULL pointer will break
compilation.
So, drop & in front of every ->proc_handler and every ->strategy
handler, it was never needed in fact.
This patch includes many places, that only required
replacing the ctl_table-s with appropriate ctl_paths
and call register_sysctl_paths().
Nothing special was done with them.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
The semantic effect of insert_at_head is that it would allow new registered
sysctl entries to override existing sysctl entries of the same name. Which is
pain for caching and the proc interface never implemented.
I have done an audit and discovered that none of the current users of
register_sysctl care as (excpet for directories) they do not register
duplicate sysctl entries.
So this patch simply removes the support for overriding existing entries in
the sys_sysctl interface since no one uses it or cares and it makes future
enhancments harder.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Corey Minyard <minyard@acm.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: David Chinner <dgc@sgi.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
infrastructure for it.
Let it rip!
