path: root/net/atm/atm_misc.c
2010-01-26net/atm/atm_misc.c: checkpatch cleanupsJoe Perches
Moved EXPORT_SYMBOL to follow definition Add space after commas Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[ATM]: atm_pcr_goal() doesn't modify its argument's contents -- mark it as constMitchell Blank Jr
Signed-off-by: Mitchell Blank Jr <mitch@sfgoth.com> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[ATM]: fix sparse gfp nocast warningsRandy Dunlap
Fix implicit nocast warnings in atm code: net/atm/atm_misc.c:35:44: warning: implicit cast to nocast type drivers/atm/fore200e.c:183:33: warning: implicit cast to nocast type Also use kzalloc() instead of kmalloc(). Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
