path: root/net/atm/ioctl.c
2010-01-26net/atm/ioctl.c: checkpatch cleanupsJoe Perches
Spacing cleanups Moved EXPORT_SYMBOL Mostly 80 column wrapped. switch/case cleanups Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm: Convert printk to pr_<level>Joe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s: " fmt, __func__ Remove function names from output Use single line pr_debug instead of broken multiple uses without newline Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11net/atm: move all compat_ioctl handling to atm/ioctl.cArnd Bergmann
We have two implementations of the compat_ioctl handling for ATM, the one that we have had for ages in fs/compat_ioctl.c and the one added to net/atm/ioctl.c by David Woodhouse. Unfortunately, both versions are incomplete, and in practice we use a very confusing combination of the two. For ioctl numbers that have the same identifier on 32 and 64 bit systems, we go directly through the compat_ioctl socket operation, for those that differ, we do a conversion in fs/compat_ioctl.c. This patch moves both variants into the vcc_compat_ioctl() function, while preserving the current behaviour. It also kills off the COMPATIBLE_IOCTL definitions that we never use here. Doing it this way is clearly not a good solution, but I hope it is a step into the right direction, so that someone is able to clean up this mess for real. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18atm: sk_wmem_alloc initial value is oneEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. This broke net/atm since this protocol assumed a null initial value. This patch makes necessary changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03atm: 32-bit ioctl compatibilityDavid Woodhouse
We lack compat ioctl support through most of the ATM code. This patch deals with most of it, and I can now at least use BR2684 and PPPoATM with 32-bit userspace. I haven't added a .compat_ioctl method to struct atm_ioctl, because AFAICT none of the current users need any conversion -- so we can just call the ->ioctl() method in every case. I looked at br2684, clip, lec, mpc, pppoatm and atmtcp. In svc_compat_ioctl() the only mangling which is needed is to change COMPAT_ATM_ADDPARTY to ATM_ADDPARTY. Although it's defined as _IOW('a', ATMIOC_SPECIAL+4,struct atm_iobuf) it doesn't actually _take_ a struct atm_iobuf as an argument -- it takes a struct sockaddr_atmsvc, which _is_ the same between 32-bit and 64-bit code, so doesn't need conversion. Almost all of vcc_ioctl() would have been identical, so I converted that into a core do_vcc_ioctl() function with an 'int compat' argument. I've done the same with atm_dev_ioctl(), where there _are_ a few differences, but still it's relatively contained and there would otherwise have been a lot of duplication. I haven't done any of the actual device-specific ioctls, although I've added a compat_ioctl method to struct atmdev_ops. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] ATM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET] sem2mutex: net/Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[ATM]: net/atm/ioctl.c: autoload pppoatm and br2684Roman Kagan
Signed-off-by: Roman Kagan <rkagan@mail.ru> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
2005-09-05[ATM]: net/atm/ioctl.c should #include "common.h"Adrian Bunk
Every file should #include the header files containing the prototypes of it's global functions. common.h contains the prototype for vcc_ioctl(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
