path: root/net/atm/resources.c
2010-12-10atm: correct sysfs 'device' link creation and parent relationshipsDan Williams
The ATM subsystem was incorrectly creating the 'device' link for ATM nodes in sysfs. This led to incorrect device/parent relationships exposed by sysfs and udev. Instead of rolling the 'device' link by hand in the generic ATM code, pass each ATM driver's bus device down to the sysfs code and let sysfs do this stuff correctly. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10net: atm: use seq_list_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm/resources.c: checkpatch cleanupsJoe Perches
Spacing cleanups Mostly 80 column wrapped. Move embedded assigns out of tests Move trailing statements to new lines switch/case cleanups Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm: Convert printk to pr_<level>Joe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s: " fmt, __func__ Remove function names from output Use single line pr_debug instead of broken multiple uses without newline Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03atm: 32-bit ioctl compatibilityDavid Woodhouse
We lack compat ioctl support through most of the ATM code. This patch deals with most of it, and I can now at least use BR2684 and PPPoATM with 32-bit userspace. I haven't added a .compat_ioctl method to struct atm_ioctl, because AFAICT none of the current users need any conversion -- so we can just call the ->ioctl() method in every case. I looked at br2684, clip, lec, mpc, pppoatm and atmtcp. In svc_compat_ioctl() the only mangling which is needed is to change COMPAT_ATM_ADDPARTY to ATM_ADDPARTY. Although it's defined as _IOW('a', ATMIOC_SPECIAL+4,struct atm_iobuf) it doesn't actually _take_ a struct atm_iobuf as an argument -- it takes a struct sockaddr_atmsvc, which _is_ the same between 32-bit and 64-bit code, so doesn't need conversion. Almost all of vcc_ioctl() would have been identical, so I converted that into a core do_vcc_ioctl() function with an 'int compat' argument. I've done the same with atm_dev_ioctl(), where there _are_ a few differences, but still it's relatively contained and there would otherwise have been a lot of duplication. I haven't done any of the actual device-specific ioctls, although I've added a compat_ioctl method to struct atmdev_ops. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-10[ATM]: Use SEQ_START_TOKENJoe Perches
2007-02-10[NET] ATM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[ATM]: basic sysfs support for ATM devicesRoman Kagan
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: sem2mutex part 2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29[ATM]: deregistration removes device from atm_devs list immediatelyStanislaw Gruszka
atm_dev_deregister() removes device from atm_dev list immediately to prevent operations on a phantom device. Decision to free device based only on ->refcnt now. Remove shutdown_atm_dev() use atm_dev_deregister() instead. atm_dev_deregister() also asynchronously releases all vccs related to device. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[ATM]: avoid race conditions related to atm_devs listStanislaw Gruszka
Use semaphore to protect atm_devs list, as no one need access to it from interrupt context. Avoid race conditions between atm_dev_register(), atm_dev_lookup() and atm_dev_deregister(). Fix double spin_unlock() bug. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-29[ATM]: attempt to autoload atm driversMitchell Blank Jr
From: Mitchell Blank Jr <mitch@sfgoth.com> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-06[ATM]: add support for LECS addresses learned from networkEric Kinzie
From: Eric Kinzie <ekinzie@cmf.nrl.navy.mil> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-21[ATM]: net/atm/resources.c: remove __free_atm_devAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
