path: root/net/atm/signaling.c
2007-10-10[NET]: sparse warning fixesStephen Hemminger
Fix a bunch of sparse warnings. Mostly about 0 used as NULL pointer, and shadowed variable declarations. One notable case was that hash size should have been unsigned. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ATM]: Replace DPRINTK() with pr_debug().Stephen Hemminger
Get rid of using DPRINTK macro in ATM and use pr_debug (in kernel.h). Using the standard macro is cleaner and forces code to check for bad arguments and formatting. Fixes from Thomas Graf. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: SPIN_LOCK_UNLOCKED cleanup in drivers/atm, netMilind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-04[ATM]: keep atmsvc failure messages quietChas Williams
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-13[ATM]: Ratelimit atmsvc failure messagesDave Jones
This seems to be trivial to trigger. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[ATM]: track and close listen sockets when sigd exitsChas Williams
2005-04-21[ATM]: sk_atm() conversion missed subtle change of vccChas Williams
