path: root/net/atm/svc.c
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm/svc.c: checkpatch cleanupsJoe Perches
Convert #include <asm... to #include <linux... Spacing cleanups Mostly 80 column wrapped Move trailing statements to new lines switch/case cleanups Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26net/atm: Convert printk to pr_<level>Joe Perches
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s: " fmt, __func__ Remove function names from output Use single line pr_debug instead of broken multiple uses without newline Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/iwlwifi/iwl-sta.c
2008-12-04ATM: CVE-2008-5079: duplicate listen() on socket corrupts the vcc tableChas Williams
As reported by Hugo Dias that it is possible to cause a local denial of service attack by calling the svc_listen function twice on the same socket and reading /proc/net/atm/*vc Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03atm: 32-bit ioctl compatibilityDavid Woodhouse
We lack compat ioctl support through most of the ATM code. This patch deals with most of it, and I can now at least use BR2684 and PPPoATM with 32-bit userspace. I haven't added a .compat_ioctl method to struct atm_ioctl, because AFAICT none of the current users need any conversion -- so we can just call the ->ioctl() method in every case. I looked at br2684, clip, lec, mpc, pppoatm and atmtcp. In svc_compat_ioctl() the only mangling which is needed is to change COMPAT_ATM_ADDPARTY to ATM_ADDPARTY. Although it's defined as _IOW('a', ATMIOC_SPECIAL+4,struct atm_iobuf) it doesn't actually _take_ a struct atm_iobuf as an argument -- it takes a struct sockaddr_atmsvc, which _is_ the same between 32-bit and 64-bit code, so doesn't need conversion. Almost all of vcc_ioctl() would have been identical, so I converted that into a core do_vcc_ioctl() function with an 'int compat' argument. I've done the same with atm_dev_ioctl(), where there _are_ a few differences, but still it's relatively contained and there would otherwise have been a lot of duplication. I haven't done any of the actual device-specific ioctls, although I've added a compat_ioctl method to struct atmdev_ops. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[ATM]: Replace DPRINTK() with pr_debug().Stephen Hemminger
Get rid of using DPRINTK macro in ATM and use pr_debug (in kernel.h). Using the standard macro is cleaner and forces code to check for bad arguments and formatting. Fixes from Thomas Graf. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] ATM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[ATM]: track and close listen sockets when sigd exitsChas Williams
2005-07-19[ATM]: allow bind() on point-to-multpoint svcs (from Martin Whitaker ↵Chas Williams
<martin_whitaker@ntlworld.com>) Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
