In clip_mkip(), skb->dev is dereferenced after clip_push(),
which frees up skb.
Advisory: AD_LAB-06009 (<adlab@venustech.com.cn>).
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
If Classical IP over ATM module is loaded, its neighbor table gets
populated when permanent neighbor entries are created; but these entries
are not flushed when the device is removed. Since the entry never gets
flushed the unregister of the network device never completes.
This version of the patch also adds locking around the reference to
the atm arp daemon to avoid races with events and daemon state changes.
(Note: barrier() was never really safe)
Bug-reference: http://bugzilla.kernel.org/show_bug.cgi?id=6295
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
This seems to be trivial to trigger.
Signed-off-by: Dave Jones <davej@redhat.com>
net: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
This removes more unneeded casts on the return value for kmalloc(),
sock_kmalloc(), and vmalloc().
Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net>
Acked-by: James Morris <jmorris@namei.org>
This changes some memcmp(one,two,ETH_ALEN) to compare_ether_addr(one,two).
This uses is_multicast_ether_addr() because it has recently been
changed to do the same thing these seperate tests are doing.
I noticed that some of 'struct proto_ops' used in the kernel may share
a cache line used by locks or other heavily modified data. (default
linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at
least)
This patch makes sure a 'struct proto_ops' can be declared as const,
so that all cpus can share all parts of it without false sharing.
This is not mandatory : a driver can still use a read/write structure
if it needs to (and eventually a __read_mostly)
I made a global stubstitute to change all existing occurences to make
them const.
This should reduce the possibility of false sharing on SMP, and
speedup some socket system calls.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
atm_dev_deregister() removes device from atm_dev list immediately to
prevent operations on a phantom device. Decision to free device based
only on ->refcnt now. Remove shutdown_atm_dev() use atm_dev_deregister()
instead. atm_dev_deregister() also asynchronously releases all vccs
related to device.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Use semaphore to protect atm_devs list, as no one need access to it from
interrupt context. Avoid race conditions between atm_dev_register(),
atm_dev_lookup() and atm_dev_deregister(). Fix double spin_unlock() bug.
Signed-off-by: Mitchell Blank Jr <mitch@sfgoth.com>
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
Fix implicit nocast warnings in atm code:
net/atm/atm_misc.c:35:44: warning: implicit cast to nocast type
drivers/atm/fore200e.c:183:33: warning: implicit cast to nocast type
Also use kzalloc() instead of kmalloc().
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and
introduces __in_dev_get_rcu() to cover the second case.
1) RCU with refcnt should use in_dev_get().
2) RCU without refcnt should use __in_dev_get_rcu().
3) All others must hold RTNL and use __in_dev_get_rtnl().
There is one exception in net/ipv4/route.c which is in fact a pre-existing
race condition. I've marked it as such so that we remember to fix it.
This patch is based on suggestions and prior work by Suzanne Wood and
Paul McKenney.
Arnaldo and I agreed it could be applied now, because I have other
pending patches depending on this one (Thank you Arnaldo)
(The other important patch moves skc_refcnt in a separate cache line,
so that the SMP/NUMA performance doesnt suffer from cache line ping pongs)
1) First some performance data :
tcp_v4_rcv() wastes a *lot* of time in __inet_lookup_established()
The most time critical code is :
sk_for_each(sk, node, &head->chain) {
if (INET_MATCH(sk, acookie, saddr, daddr, ports, dif))
goto hit; /* You sunk my battleship! */
The sk_for_each() does use prefetch() hints but only the begining of
"struct sock" is prefetched.
As INET_MATCH first comparison uses inet_sk(__sk)->daddr, wich is far
away from the begining of "struct sock", it has to bring into CPU
cache cold cache line. Each iteration has to use at least 2 cache
lines.
This can be problematic if some chains are very long.
2) The goal
The idea I had is to change things so that INET_MATCH() may return
FALSE in 99% of cases only using the data already in the CPU cache,
using one cache line per iteration.
3) Description of the patch
Adds a new 'unsigned int skc_hash' field in 'struct sock_common',
filling a 32 bits hole on 64 bits platform.
struct sock_common {
unsigned short skc_family;
volatile unsigned char skc_state;
unsigned char skc_reuse;
int skc_bound_dev_if;
struct hlist_node skc_node;
struct hlist_node skc_bind_node;
atomic_t skc_refcnt;
+ unsigned int skc_hash;
struct proto *skc_prot;
Store in this 32 bits field the full hash, not masked by (ehash_size -
1) Using this full hash as the first comparison done in INET_MATCH
permits us immediatly skip the element without touching a second cache
line in case of a miss.
Suppress the sk_hashent/tw_hashent fields since skc_hash (aliased to
sk_hash and tw_hash) already contains the slot number if we mask with
(ehash_size - 1)
File include/net/inet_hashtables.h
64 bits platforms :
#define INET_MATCH(__sk, __hash, __cookie, __saddr, __daddr, __ports, __dif)\
(((__sk)->sk_hash == (__hash))
((*((__u64 *)&(inet_sk(__sk)->daddr)))== (__cookie)) && \
((*((__u32 *)&(inet_sk(__sk)->dport))) == (__ports)) && \
(!((__sk)->sk_bound_dev_if) || ((__sk)->sk_bound_dev_if == (__dif))))
32bits platforms:
#define TCP_IPV4_MATCH(__sk, __hash, __cookie, __saddr, __daddr, __ports, __dif)\
(((__sk)->sk_hash == (__hash)) && \
(inet_sk(__sk)->daddr == (__saddr)) && \
(inet_sk(__sk)->rcv_saddr == (__daddr)) && \
- Adds a prefetch(head->chain.first) in
__inet_lookup_established()/__tcp_v4_check_established() and
__inet6_lookup_established()/__tcp_v6_check_established() and
__dccp_v4_check_established() to bring into cache the first element of the
list, before the {read|write}_lock(&head->lock);
Acked-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Signed-off-by: Roman Kagan <rkagan@mail.ru>
Clean up timer initialization by introducing DEFINE_TIMER a'la
DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been
been in the -RT tree for some time.
Every file should #include the header files containing the prototypes
of it's global functions.
common.h contains the prototype for vcc_ioctl().
Remove the "list" member of struct sk_buff, as it is entirely
redundant. All SKB list removal callers know which list the
SKB is on, so storing this in sk_buff does nothing other than
taking up some space.
Two tricky bits were SCTP, which I took care of, and two ATM
drivers which Francois Romieu <romieu@fr.zoreil.com> fixed
up.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
<martin_whitaker@ntlworld.com>)
tr_type_trans(), hippi_type_trans() left as-is.
Move the protocol specific config options out to the specific protocols.
With this change net/Kconfig now starts to become readable and serve as a
good basis for further re-structuring.
The menu structure is left almost intact, except that indention is
fixed in most cases. Most visible are the INET changes where several
"depends on INET" are replaced with a single ifdef INET / endif pair.
Several new files were created to accomplish this change - they are
small but serve the purpose that config options are now distributed
out where they belongs.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
There were still a few comments left refering to verify_area, and two
functions, verify_area_skas & verify_area_tt that just wrap corresponding
access_ok_skas & access_ok_tt functions, just like verify_area does for
access_ok - deprecate those.
There was also a few places that still used verify_area in commented-out
code, fix those up to use access_ok.
After applying this one there should not be anything left but finally
removing verify_area completely, which will happen after a kernel release
or two.
infrastructure for it.
Let it rip!
