[ Upstream commit 3adadc08cc1e2cbcc15a640d639297ef5fcb17f5 ]
While reviewing the sysctl code in ax25 I spotted races in ax25_exit
where it is possible to receive notifications and packets after already
freeing up some of the data structures needed to process those
notifications and updates.
Call unregister_netdevice_notifier early so that the rest of the cleanup
code does not need to deal with network devices. This takes advantage
of my recent enhancement to unregister_netdevice_notifier to send
unregister notifications of all network devices that are current
registered.
Move the unregistration for packet types, socket types and protocol
types before we cleanup any of the ax25 data structures to remove the
possibilities of other races.
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
The variable 's' is set but unused in ax25_protocol_release().
Just kill it off.
Nobody alive seems to recall when they last were useful.
Commit fe10ae53384e48c51996941b7720ee16995cbcb7 adds a memset() to clear
the structure being sent back to userspace, but accidentally used the
wrong size.
Reported-by: Brad Spengler <spender@grsecurity.net>
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Cc: stable@kernel.org
Sometimes ax25_getname() doesn't initialize all members of fsa_digipeater
field of fsa struct, also the struct has padding bytes between
sax25_call and sax25_ndigis fields. This structure is then copied to
userland. It leads to leaking of contents of kernel stack memory.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
net/mac80211/main.c
This patch moves a missplaced sock_put(sk) after
bh_unlock_sock(sk)
like in other parts of AX25 driver.
Signed-off-by: Bernard Pidoux <f6bvp@free.fr>
Error codes are stored in err, but the return value is always 0. Return
err instead.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
local idexpression x;
constant C;
if (...) { ...
x = -C
... when != x
return <+...x...+>;
return NULL;
return;
* return ...;
// </smpl>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
err instead.
// <smpl>
@r@
constant C;
if (...) { ...
x = -C
... when != x
return <+...x...+>;
return NULL;
return;
* return ...;
// </smpl>
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Simplify seq_file code.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Wrong ax25_cb refcounting in ax25_send_frame() and by its callers can
cause timer oopses (first reported with 2.6.29.6 kernel).
Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14905
Reported-by: Bernard Pidoux <bpidoux@free.fr>
Tested-by: Bernard Pidoux <bpidoux@free.fr>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits)
mac80211: fix reorder buffer release
iwmc3200wifi: Enable wimax core through module parameter
iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter
iwmc3200wifi: Coex table command does not expect a response
iwmc3200wifi: Update wiwi priority table
iwlwifi: driver version track kernel version
iwlwifi: indicate uCode type when fail dump error/event log
iwl3945: remove duplicated event logging code
b43: fix two warnings
ipw2100: fix rebooting hang with driver loaded
cfg80211: indent regulatory messages with spaces
iwmc3200wifi: fix NULL pointer dereference in pmkid update
mac80211: Fix TX status reporting for injected data frames
ath9k: enable 2GHz band only if the device supports it
airo: Fix integer overflow warning
rt2x00: Fix padding bug on L2PAD devices.
WE: Fix set events not propagated
b43legacy: avoid PPC fault during resume
b43: avoid PPC fault during resume
tcp: fix a timewait refcnt race
Fix up conflicts due to sysctl cleanups (dead sysctl_check code and
CTL_UNNUMBERED removed) in
kernel/sysctl_check.c
net/ipv4/sysctl_net_ipv4.c
net/ipv6/addrconf.c
net/sctp/sysctl.c
Generated with the following semantic patch
struct net *n1;
struct net *n2;
- n1 == n2
+ net_eq(n1, n2)
struct net *n1;
struct net *n2;
- n1 != n2
+ !net_eq(n1, n2)
applied over {include,net,drivers/net}.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
The generic __sock_create function has a kern argument which allows the
security system to make decisions based on if a socket is being created by
the kernel or by userspace. This patch passes that flag to the
net_proto_family specific create function, so it can do the same thing.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
struct ax25_ctl_struct member `arg' is unsigned and cannot be less
than 0.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
All usages of structure net_proto_ops should be declared const.
In ax25_make_new, if kmemdup of digipeat returns an error, there would
be an oops in sk_free while calling sk_destruct, because sk_protinfo
is NULL at the moment; move sk->sk_destruct initialization after this.
BTW of reported-by: Bernard Pidoux F6BVP <f6bvp@free.fr>
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
ax25_setsockopt SO_BINDTODEVICE is missing a dev_put call in case of
success. Re-order code to fix this bug. While at it also reformat two
lines of code to comply with the Linux coding style.
Initial patch by Jarek Poplawski <jarkao2@gmail.com>.
Reported-by: Bernard Pidoux F6BVP <f6bvp@free.fr>
Use ax25_cb_put after ax25_find_cb in ax25_ctl_ioctl.
Reviewed-by: Ralf Baechle <ralf@linux-mips.org>
rcv_q & snd_q initializations were reversed in commit
31e6d363abcd0d05766c82f1a9c905a4c974a199
(net: correct off-by-one write allocations reports)
Signed-off-by: Jan Rafaj <jr+netfilter-devel@cedric.unob.cz>
In order to get the tun driver to account packets, we need to be
able to receive packets with destructors set. To be on the safe
side, I added an skb_orphan call for all protocols by default since
some of them (IP in particular) cannot handle receiving packets
destructors properly.
Now it seems that at least one protocol (CAN) expects to be able
to pass skb->sk through the rx path without getting clobbered.
So this patch attempts to fix this properly by moving the skb_orphan
call to where it's actually needed. In particular, I've added it
to skb_set_owner_[rw] which is what most users of skb->destructor
call.
This is actually an improvement for tun too since it means that
we only give back the amount charged to the socket when the skb
is passed to another socket that will also be charged accordingly.
Tested-by: Oliver Hartkopp <olver@hartkopp.net>
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
changed initial sk_wmem_alloc value.
We need to take into account this offset when reporting
sk_wmem_alloc to user, in PROC_FS files or various
ioctls (SIOCOUTQ/TIOCOUTQ)
Some protocols check sk_wmem_alloc value to determine if a timer
must delay socket deallocation. We must take care of the sk_wmem_alloc
value being one instead of zero when no write allocations are pending.
Reported by Ingo Molnar, and full diagnostic from David Miller.
This patch introduces three helpers to get read/write allocations
and a followup patch will use these helpers to report correct
write allocations to user.
Reported-by: Ingo Molnar <mingo@elte.hu>
This has been broken for a while. I happened to catch it testing because one
app "knew" that the top line of the calls data was the policy line and got
confused.
Put the header back.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
This reverts commit f99bcff7a290768e035f3d4726e103c6ebe858bf.
Like netrom, Alan Cox says that zero lengths have real meaning
and are useful in this protocol.
In previous commit 244f46ae6e9e18f6fc0be7d1f49febde4762c34b
was introduced a zero length frame filter for ROSE protocole.
This patch has the same purpose at AX25 frame level for the same
reason. Empty frames have no meaning in AX25 protocole.
Signed-off-by: Bernard Pidoux <f6bvp@amsat.org>
This patch condenses two debug messages in one.
Protocols that use packet_type can be __read_mostly section for better
locality. Elminate any unnecessary initializations of NULL.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits)
net: Allow dependancies of FDDI & Tokenring to be modular.
igb: Fix build warning when DCA is disabled.
net: Fix warning fallout from recent NAPI interface changes.
gro: Fix potential use after free
sfc: If AN is enabled, always read speed/duplex from the AN advertising bits
sfc: When disabling the NIC, close the device rather than unregistering it
sfc: SFT9001: Add cable diagnostics
sfc: Add support for multiple PHY self-tests
sfc: Merge top-level functions for self-tests
sfc: Clean up PHY mode management in loopback self-test
sfc: Fix unreliable link detection in some loopback modes
sfc: Generate unique names for per-NIC workqueues
802.3ad: use standard ethhdr instead of ad_header
802.3ad: generalize out mac address initializer
802.3ad: initialize ports LACPDU from const initializer
802.3ad: remove typedef around ad_system
802.3ad: turn ports is_individual into a bool
802.3ad: turn ports is_enabled into a bool
802.3ad: make ntt bool
ixgbe: Fix set_ringparam in ixgbe to use the same memory pools.
Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due
to the conversion to %pI (in this networking merge) and the addition of
doing IPv6 addresses (from the earlier merge of CIFS).
fix this warning:
net/ax25/sysctl_net_ax25.c:27: warning: ‘min_ds_timeout’ defined but not used
net/ax25/sysctl_net_ax25.c:27: warning: ‘max_ds_timeout’ defined but not used
These are only used in the CONFIG_AX25_DAMA_SLAVE case.
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: linux-hams@vger.kernel.org
Signed-off-by: James Morris <jmorris@namei.org>
I want to compile out proc_* and sysctl_* handlers totally and
stub them to NULL depending on config options, however usage of &
will prevent this, since taking adress of NULL pointer will break
compilation.
So, drop & in front of every ->proc_handler and every ->strategy
handler, it was never needed in fact.
Since we reverted 30902dc3cb0ea1cfc7ac2b17bcf478ff98420d74 ("ax25: Fix
std timer socket destroy handling.") we have to put some kind of fix
in to cure the issue whereby unaccepted connections do not get destroyed.
The approach used here is from Tihomir Heidelberg - 9a4gl
This reverts commit 30902dc3cb0ea1cfc7ac2b17bcf478ff98420d74.
It causes all kinds of problems, based upon a report by
Bernard (f6bvp) and analysis by Jarek Poplawski.
Since 49ffcf8f99e8d33ec8afb450956804af518fd788 ("sysctl: update
sysctl_check_table") setting struct ctl_table.procname = NULL does no
longer work as it used to the way the AX.25 code is expecting it to
resulting in the AX.25 sysctl registration code to break if
CONFIG_AX25_DAMA_SLAVE was not set as in some distribution kernels.
Kernel releases from 2.6.24 are affected.
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Tihomir Heidelberg - 9a4gl, reports:
I would like to direct you attention to one problem existing in ax.25
kernel since 2.4. If listening socket is closed and its SKB queue is
released but those sockets get weird. Those "unAccepted()" sockets
should be destroyed in ax25_std_heartbeat_expiry, but it will not
happen. And there is also a note about that in ax25_std_timer.c:
/* Magic here: If we listen() and a new link dies before it
is accepted() it isn't 'dead' so doesn't get removed. */
This issue cause ax25d to stop accepting new connections and I had to
restarted ax25d approximately each day and my services were unavailable.
Also netstat -n -l shows invalid source and device for those listening
sockets. It is strange why ax25d's listening socket get weird because of
this issue, but definitely when I solved this bug I do not have problems
with ax25d anymore and my ax25d can run for months without problems.
Actually as far as I can see, this problem is even in releases
as far back as 2.2.x as well.
It seems senseless to special case this test on TCP_LISTEN state.
Anything still stuck in state 0 has no external references and
we can just simply kill it off directly.
The way that listening sockets work in ax25 is that the packet input
code path creates new socks via ax25_make_new() and attaches them
to the incoming SKB. This SKB gets queued up into the listening
socket's receive queue.
When accept()'d the sock gets hooked up to the real parent socket.
Alternatively, if the listening socket is closed and released, any
unborn socks stuff up in the receive queue get released.
So during this time period these sockets are unreachable in any
other way, so no wakeup events nor references to their ->sk_socket
and ->sk_sleep members can occur. And even if they do, all such
paths have to make NULL checks.
So do not deceptively initialize them in ax25_make_new() to the
values in the listening socket. Leave them at NULL.
Finally, use sock_graft() in ax25_accept().
There is only one function in AX25 calling skb_append(), and it really
looks suspicious: appends skb after previously enqueued one, but in
the meantime this previous skb could be removed from the queue.
This patch Fixes it the simple way, so this is not fully compatible with
the current method, but testing hasn't shown any problems.
drivers/net/ehea/ehea_main.c
drivers/net/wireless/iwlwifi/Kconfig
drivers/net/wireless/rt2x00/rt61pci.c
net/ipv4/inet_timewait_sock.c
net/ipv6/raw.c
net/mac80211/ieee80211_sta.c
