path: root/net/ax25
2011-04-17ax25: Fix set-but-unused variable.David S. Miller
The variable 's' is set but unused in ax25_protocol_release(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14NET: AX.25, NETROM, ROSE: Remove SOCK_DEBUG callsRalf Baechle
Nobody alive seems to recall when they last were useful. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-12net: ax25: fix information leak to userland harderKees Cook
Commit fe10ae53384e48c51996941b7720ee16995cbcb7 adds a memset() to clear the structure being sent back to userspace, but accidentally used the wrong size. Reported-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-10net: ax25: fix information leak to userlandVasiliy Kulikov
Sometimes ax25_getname() doesn't initialize all members of fsa_digipeater field of fsa struct, also the struct has padding bytes between sax25_call and sax25_ndigis fields. This structure is then copied to userland. It leads to leaking of contents of kernel stack memory. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-08-26ax25: missplaced sock_put(sk)Bernard Pidoux F6BVP
This patch moves a missplaced sock_put(sk) after bh_unlock_sock(sk) like in other parts of AX25 driver. Signed-off-by: Bernard Pidoux <f6bvp@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-18net/ax25: Use available error codesJulia Lawall
Error codes are stored in err, but the return value is always 0. Return err instead. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ local idexpression x; constant C; @@ if (...) { ... x = -C ... when != x ( return <+...x...+>; | return NULL; | return; | * return ...; ) } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10net: ax25: use seq_hlist_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16ax25: netrom: rose: Fix timer oopsesJarek Poplawski
Wrong ax25_cb refcounting in ax25_send_frame() and by its callers can cause timer oopses (first reported with 2.6.29.6 kernel). Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14905 Reported-by: Bernard Pidoux <bpidoux@free.fr> Tested-by: Bernard Pidoux <bpidoux@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29ax25: unsigned cannot be less than 0 in ax25_ctl_ioctl()roel kluin
struct ax25_ctl_struct member `arg' is unsigned and cannot be less than 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30ax25: Fix possible oops in ax25_make_newJarek Poplawski
In ax25_make_new, if kmemdup of digipeat returns an error, there would be an oops in sk_free while calling sk_destruct, because sk_protinfo is NULL at the moment; move sk->sk_destruct initialization after this. BTW of reported-by: Bernard Pidoux F6BVP <f6bvp@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-28ax25: Add missing dev_put in ax25_setsockoptRalf Baechle
ax25_setsockopt SO_BINDTODEVICE is missing a dev_put call in case of success. Re-order code to fix this bug. While at it also reformat two lines of code to comply with the Linux coding style. Initial patch by Jarek Poplawski <jarkao2@gmail.com>. Reported-by: Bernard Pidoux F6BVP <f6bvp@free.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-25ax25: Fix ax25_cb refcounting in ax25_ctl_ioctlJarek Poplawski
Use ax25_cb_put after ax25_find_cb in ax25_ctl_ioctl. Reported-by: Bernard Pidoux F6BVP <f6bvp@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Reviewed-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22ax25: Fix SIOCAX25GETINFO ioctlEric Dumazet
rcv_q & snd_q initializations were reversed in commit 31e6d363abcd0d05766c82f1a9c905a4c974a199 (net: correct off-by-one write allocations reports) Signed-off-by: Jan Rafaj <jr+netfilter-devel@cedric.unob.cz> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23net: Move rx skb_orphan call to where neededHerbert Xu
In order to get the tun driver to account packets, we need to be able to receive packets with destructors set. To be on the safe side, I added an skb_orphan call for all protocols by default since some of them (IP in particular) cannot handle receiving packets destructors properly. Now it seems that at least one protocol (CAN) expects to be able to pass skb->sk through the rx path without getting clobbered. So this patch attempts to fix this properly by moving the skb_orphan call to where it's actually needed. In particular, I've added it to skb_set_owner_[rw] which is what most users of skb->destructor call. This is actually an improvement for tun too since it means that we only give back the amount charged to the socket when the skb is passed to another socket that will also be charged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Oliver Hartkopp <olver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17net: sk_wmem_alloc has initial value of one, not zeroEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. Some protocols check sk_wmem_alloc value to determine if a timer must delay socket deallocation. We must take care of the sk_wmem_alloc value being one instead of zero when no write allocations are pending. Reported by Ingo Molnar, and full diagnostic from David Miller. This patch introduces three helpers to get read/write allocations and a followup patch will use these helpers to report correct write allocations to user. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-20ax25: proc uid file misses headerAlan Cox
This has been broken for a while. I happened to catch it testing because one app "knew" that the top line of the calls data was the policy line and got confused. Put the header back. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27Revert "ax25: zero length frame filtering in AX25"David S. Miller
This reverts commit f99bcff7a290768e035f3d4726e103c6ebe858bf. Like netrom, Alan Cox says that zero lengths have real meaning and are useful in this protocol. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21ax25: zero length frame filtering in AX25Bernard Pidoux
In previous commit 244f46ae6e9e18f6fc0be7d1f49febde4762c34b was introduced a zero length frame filter for ROSE protocole. This patch has the same purpose at AX25 frame level for the same reason. Empty frames have no meaning in AX25 protocole. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21ax25: SOCK_DEBUG message simplificationBernard Pidoux
This patch condenses two debug messages in one. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-06ax25: more common return path joiningIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-14ax25: join the return paths that free skbIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25ax25: fix warning in net/ax25/sysctl_net_ax25.cIngo Molnar
fix this warning: net/ax25/sysctl_net_ax25.c:27: warning: ‘min_ds_timeout’ defined but not used net/ax25/sysctl_net_ax25.c:27: warning: ‘max_ds_timeout’ defined but not used These are only used in the CONFIG_AX25_DAMA_SLAVE case. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14CRED: Wrap task credential accesses in the AX25 protocolDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-06ax25: Quick fix for making sure unaccepted sockets get destroyed.David S. Miller
Since we reverted 30902dc3cb0ea1cfc7ac2b17bcf478ff98420d74 ("ax25: Fix std timer socket destroy handling.") we have to put some kind of fix in to cure the issue whereby unaccepted connections do not get destroyed. The approach used here is from Tihomir Heidelberg - 9a4gl Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-06Revert "ax25: Fix std timer socket destroy handling."David S. Miller
This reverts commit 30902dc3cb0ea1cfc7ac2b17bcf478ff98420d74. It causes all kinds of problems, based upon a report by Bernard (f6bvp) and analysis by Jarek Poplawski. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-05AX.25: Fix sysctl registration if !CONFIG_AX25_DAMA_SLAVERalf Baechle
Since 49ffcf8f99e8d33ec8afb450956804af518fd788 ("sysctl: update sysctl_check_table") setting struct ctl_table.procname = NULL does no longer work as it used to the way the AX.25 code is expecting it to resulting in the AX.25 sysctl registration code to break if CONFIG_AX25_DAMA_SLAVE was not set as in some distribution kernels. Kernel releases from 2.6.24 are affected. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17ax25: Fix std timer socket destroy handling.David S. Miller
Tihomir Heidelberg - 9a4gl, reports: -------------------- I would like to direct you attention to one problem existing in ax.25 kernel since 2.4. If listening socket is closed and its SKB queue is released but those sockets get weird. Those "unAccepted()" sockets should be destroyed in ax25_std_heartbeat_expiry, but it will not happen. And there is also a note about that in ax25_std_timer.c: /* Magic here: If we listen() and a new link dies before it is accepted() it isn't 'dead' so doesn't get removed. */ This issue cause ax25d to stop accepting new connections and I had to restarted ax25d approximately each day and my services were unavailable. Also netstat -n -l shows invalid source and device for those listening sockets. It is strange why ax25d's listening socket get weird because of this issue, but definitely when I solved this bug I do not have problems with ax25d anymore and my ax25d can run for months without problems. -------------------- Actually as far as I can see, this problem is even in releases as far back as 2.2.x as well. It seems senseless to special case this test on TCP_LISTEN state. Anything still stuck in state 0 has no external references and we can just simply kill it off directly. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17ax25: Use sock_graft() and remove bogus sk_socket and sk_sleep init.David S. Miller
The way that listening sockets work in ax25 is that the packet input code path creates new socks via ax25_make_new() and attaches them to the incoming SKB. This SKB gets queued up into the listening socket's receive queue. When accept()'d the sock gets hooked up to the real parent socket. Alternatively, if the listening socket is closed and released, any unborn socks stuff up in the receive queue get released. So during this time period these sockets are unreachable in any other way, so no wakeup events nor references to their ->sk_socket and ->sk_sleep members can occur. And even if they do, all such paths have to make NULL checks. So do not deceptively initialize them in ax25_make_new() to the values in the listening socket. Leave them at NULL. Finally, use sock_graft() in ax25_accept(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03ax25: Fix NULL pointer dereference and lockup.Jarek Poplawski
From: Jarek Poplawski <jarkao2@gmail.com> There is only one function in AX25 calling skb_append(), and it really looks suspicious: appends skb after previously enqueued one, but in the meantime this previous skb could be removed from the queue. This patch Fixes it the simple way, so this is not fully compatible with the current method, but testing hasn't shown any problems. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-12[AX25]: Potential ax25_uid_assoc-s leaks on module unload.Pavel Emelyanov
The ax25_uid_free call walks the ax25_uid_list and releases entries from it. The problem is that after the fisrt call to hlist_del_init the hlist_for_each_entry (which hides behind the ax25_uid_for_each) will consider the current position to be the last and will return. Thus, the whole list will be left not freed. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
