commit 140ed8e87ca8f4875c2b146cdb2cdbf0c9ac6080 upstream.
The references to the network device should be dropped inside the release
function for batadv_hard_iface similar to what is done with the batman-adv
internal datastructures.
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <a@unstable.cc>
[ Upstream commit b4d922cfc9c08318eeb77d53b7633740e6b0efb0 ]
It is not allowed to free the memory of an object which is part of a list
which is protected by rcu-read-side-critical sections without making sure
that no other context is accessing the object anymore. This usually happens
by removing the references to this object and then waiting until the rcu
grace period is over and no one (allowedly) accesses it anymore.
But the _now functions ignore this completely. They free the object
directly even when a different context still tries to access it. This has
to be avoided and thus these functions must be removed and all functions
have to use batadv_hardif_free_ref.
Fixes: 89652331c00f ("batman-adv: split tq information in neigh_node struct")
The header files could not be build indepdent from each other. This is
happened because headers didn't include the files for things they've used.
This was problematic because the success of a build depended on the
knowledge about the right order of local includes.
Also source files were not including everything they've used explicitly.
Instead they required that transitive includes are always stable. This is
problematic because some transitive includes are not obvious, depend on
config settings and may not be stable in the future.
The order for include blocks are:
* primary headers (main.h and the *.h file of a *.c file)
* global linux headers
* required local headers
* extra forward declarations for pointers in function/struct declarations
The only exceptions are linux/bitops.h and linux/if_ether.h in packet.h.
This header file is shared with userspace applications like batctl and must
therefore build together with userspace applications. The header
linux/bitops.h is not part of the uapi headers and linux/if_ether.h
conflicts with the musl implementation of netinet/if_ether.h. The
maintainers rejected the use of __KERNEL__ preprocessor checks and thus
these two headers are only in main.h. All files using packet.h first have
to include main.h to work correctly.
Reported-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
If the same interface is used for sending and receiving, there might be
throughput degradation on half-duplex interfaces such as WiFi. Add a
penalty if the same interface is used to reflect this problem in the
metric. At the same time, change the hop penalty from 30 to 15 so there
will be no change for single wifi mesh network. the effective hop
penalty will stay at 30 due to the new wifi penalty for these networks.
Signed-off-by: Simon Wunderlich <simon@open-mesh.com>
For the network wide multi interface optimization it is required to save
metrics per outgoing interface in one neighbor. Therefore a new type is
introduced to keep interface-specific information. This also requires
some changes in access and list management.
The compare and equiv_or_better API calls are changed to take the
outgoing interface into consideration.
As suggested by checkpatch, remove all the references to the
FSF address since the kernel already has one reference in
its documentation.
In this way it is easier to update it in case of future
changes.
Upcoming changes need to perform other checks on the
incoming net_device struct.
To avoid performing dev_get_by_index() for each and every
check, it is better to move it outside of is_wifi_iface()
and search the netdev object once only.
Signed-off-by: Antonio Quartulli <antonio@open-mesh.com>
batman-adv has an unusual way to manage softinterfaces. These will be created
automatically when a user writes to the batman-adv/mesh_iface file in sysfs and
removed when no slave device exists anymore.
This behaviour cannot be changed without breaking compatibility with existing
code. Instead other interfaces should be able to slightly reduce this behaviour
and provide a more common reaction to a removal of a slave interface.
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
Acked-by: Antonio Quartulli <ordex@autistici.org>
Signed-off-by: Antonio Quartulli <ordex@autistici.org>
Reported-by: Martin Hundebøll <martin@hundeboll.net>
All non-static symbols of batman-adv were prefixed with batadv_ to avoid
collisions with other symbols of the kernel. Other symbols of batman-adv
should use the same prefix to keep the naming scheme consistent.
batman-adv doesn't follow the style for multiline comments that David S. Miller
prefers. All comments should be reformatted to follow this consistent style to
make the code slightly more readable.
batman-adv can be compiled as part of the kernel instead of an module. In that
case the linker will see all non-static symbols of batman-adv and all other
non-static symbols of the kernel. This could lead to symbol collisions. A
prefix for the batman-adv symbols that defines their private namespace avoids
such a problem.
Reported-by: David Miller <davem@davemloft.net>
Clients connected through a 802.11 device are now marked with the
TT_CLIENT_WIFI flag. This flag is also advertised with the tt
announcement.
CodingStyle "Chapter 12: Macros, Enums and RTL" recommends to use enums
for several related constants. Internal states can be used without
defining the actual value, but all values which are visible to the
outside must be defined as before. Normal values are assigned as usual
and flags are defined by shifts of a bit.
batman-adv uses pointers which are marked as const and should not
violate that type qualifier by passing it to functions which force a
cast to the non-const version.
The rcu protected macros rcu_dereference() and rcu_assign_pointer()
for the bat_priv->primary_if need to be used, as well as spin/rcu locking.
Otherwise we might end up using a primary_if pointer pointing to already
freed memory.
It might be possible that 2 threads access the same data in the same
rcu grace period. The first thread calls call_rcu() to decrement the
refcount and free the data while the second thread increases the
refcount to use the data. To avoid this race condition all refcount
operations have to be atomic.
Reported-by: Sven Eckelmann <sven@narfation.org>
batman_skb_recv can be defined in hard-interface.c as static because it is
never used outside of that file.
B.A.T.M.A.N. (better approach to mobile ad-hoc networking) is a routing
protocol for multi-hop ad-hoc mesh networks. The networks may be wired or
wireless. See http://www.open-mesh.org/ for more information and user space
tools.
