[ Upstream commit f8fb3419ead44f9a3136995acd24e35da4525177 ]
For multicast frames AP isolation is only supposed to be checked on
the receiving nodes and never on the originating one.
Furthermore, the isolation or wifi flag bits should only be intepreted
as such for unicast and never multicast TT entries.
By injecting flags to the multicast TT entry claimed by a single
target node it was verified in tests that this multicast address
becomes unreachable, leading to packet loss.
Omitting the "src" parameter to the batadv_transtable_search() call
successfully skipped the AP isolation check and made the target
reachable again.
Fixes: 1d8ab8d3c176 ("batman-adv: Modified forwarding behaviour for multicast packets")
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
Some functions already have documentation about locks they require inside
their kerneldoc header. These can be directly tested during runtime using
the lockdep asserts.
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
Functions which use (h)list_del* are requiring correct locking when they
operate on global lists. Most of the time the search in the list and the
delete are done in the same function. All other cases should have it
visible that they require a special lock to avoid race conditions.
Lockdep asserts can be used to check these problem during runtime when the
lockdep functionality is enabled.
(s|u)(8|16|32|64) are the preferred types in the kernel. The use of the
standard C99 types u?int(8|16|32|64)_t are objected by some people and even
checkpatch now warns about using them.
So far the mcast tvlv handler did not anticipate the processing of
multiple incoming OGMs from the same originator at the same time. This
can lead to various issues:
* Broken refcounting: For instance two mcast handlers might both assume
that an originator just got multicast capabilities and will together
wrongly decrease mcast.num_disabled by two, potentially leading to
an integer underflow.
* Potential kernel panic on hlist_del_rcu(): Two mcast handlers might
one after another try to do an
hlist_del_rcu(&orig->mcast_want_all_*_node). The second one will
cause memory corruption / crashes.
(Reported by: Sven Eckelmann <sven@narfation.org>)
Right in the beginning the code path makes assumptions about the current
multicast related state of an originator and bases all updates on that. The
easiest and least error prune way to fix the issues in this case is to
serialize multiple mcast handler invocations with a spinlock.
Fixes: 60432d756cf0 ("batman-adv: Announce new capability via multicast TVLV")
Bitwise OR/AND assignments in C aren't guaranteed to be atomic. One
OGM handler might undo the set/clear of a specific bit from another
handler run in between.
Fix this by using the atomic set_bit()/clear_bit()/test_bit() functions.
The header files could not be build indepdent from each other. This is
happened because headers didn't include the files for things they've used.
This was problematic because the success of a build depended on the
knowledge about the right order of local includes.
Also source files were not including everything they've used explicitly.
Instead they required that transitive includes are always stable. This is
problematic because some transitive includes are not obvious, depend on
config settings and may not be stable in the future.
The order for include blocks are:
* primary headers (main.h and the *.h file of a *.c file)
* global linux headers
* required local headers
* extra forward declarations for pointers in function/struct declarations
The only exceptions are linux/bitops.h and linux/if_ether.h in packet.h.
This header file is shared with userspace applications like batctl and must
therefore build together with userspace applications. The header
linux/bitops.h is not part of the uapi headers and linux/if_ether.h
conflicts with the musl implementation of netinet/if_ether.h. The
maintainers rejected the use of __KERNEL__ preprocessor checks and thus
these two headers are only in main.h. All files using packet.h first have
to include main.h to work correctly.
Reported-by: Markus Pargmann <mpa@pengutronix.de>
When purging an orig_node we should only decrease counter tracking the
number of nodes without multicast optimizations support if it was
increased through this orig_node before.
A not yet quite initialized orig_node (meaning it did not have its turn
in the mcast-tvlv handler so far) which gets purged would not adhere to
this and will lead to a counter imbalance.
Fixing this by adding a check whether the orig_node is mcast-initalized
before decreasing the counter in the mcast-orig_node-purging routine.
Introduced by 60432d756cf06e597ef9da511402dd059b112447
Reported-by: Tobias Hachmer <tobias@hachmer.de>
A miscounting of nodes having multicast optimizations enabled can lead
to multicast packet loss in the following scenario:
If the first OGM a node receives from another one has no multicast
optimizations support (no multicast tvlv) then we are missing to
increase the counter. This potentially leads to the wrong assumption
that we could safely use multicast optimizations.
Fixings this by increasing the counter if the initial OGM has the
multicast TVLV unset, too.
The header multicast.h was included twice, so delete one of them.
Signed-off-by: Jean Sacren <sakiwit@gmail.com>
Cc: Marek Lindner <mareklindner@neomailbox.ch>
Cc: Simon Wunderlich <sw@simonwunderlich.de>
Cc: Antonio Quartulli <antonio@meshcoding.com>
Cc: b.a.t.m.a.n@lists.open-mesh.org
Was introduced with 4c8755d69cbde2ec464a39c932aed0a83f9ff89f
("batman-adv: Send multicast packets to nodes with a WANT_ALL flag")
Reported-by: Sven Eckelmann <sven@narfation.org>
Acked-by: Antonio Quartulli <antonio@meshcoding.com>
Signed-off-by: Linus Lüssing <linus.luessing@web.de>
With this patch a node sends IPv4 multicast packets to nodes which
have a BATADV_MCAST_WANT_ALL_IPV4 flag set and IPv6 multicast packets
to nodes which have a BATADV_MCAST_WANT_ALL_IPV6 flag set, too.
Why is this needed? There are scenarios involving bridges where
multicast report snooping and multicast TT announcements are not
sufficient, which would lead to packet loss for some nodes otherwise:
MLDv1 and IGMPv1/IGMPv2 have a suppression mechanism
for multicast listener reports. When we have an MLDv1/IGMPv1/IGMPv2
querier behind a bridge then our snooping bridge is potentially not
going to see any reports even though listeners exist because according
to RFC4541 such reports are only forwarded to multicast routers:
{Querier}---|Snoop. Switch|----{Listener}
| br0 | < ???
_-~---~_
_-~/ ~-_
~ batman-adv \-----{Sender}
\~_ cloud ~/
-~~__-__-~_/
I) MLDv1 Query: {Querier} -> flooded
II) MLDv1 Report: {Listener} -> {Querier}
-> br0 cannot detect the {Listener}
=> Packets from {Sender} need to be forwarded to all
detected listeners and MLDv1/IGMPv1/IGMPv2 queriers.
Note that we do not need to explicitly forward to MLDv2/IGMPv3 queriers,
because these protocols have no report suppression: A bridge has no
trouble detecting MLDv2/IGMPv3 listeners.
Even though we do not support bridges yet we need to provide the
according infrastructure already to not break compatibility later.
With this patch a node may additionally perform the dropping or
unicasting behaviour for a link-local IPv4 and link-local-all-nodes
IPv6 multicast packet, too.
The extra counter and BATADV_MCAST_WANT_ALL_UNSNOOPABLES flag is needed
because with a future bridge snooping support integration a node with a
bridge on top of its soft interface is not able to reliably detect its
multicast listeners for IPv4 link-local and the IPv6
link-local-all-nodes addresses anymore (see RFC4541, section 2.1.2.2
and section 3).
Even though this new flag does make "no difference" now, it'll ensure
a seamless integration of multicast bridge support without needing to
Also note, that even with multicast bridge support it won't be possible
to optimize 224.0.0.x and ff02::1 towards nodes with bridges, they will
always receive these ranges.
With this patch a multicast packet is not always simply flooded anymore,
the behaviour for the following cases is changed to reduce
unnecessary overhead:
If all nodes within the horizon of a certain node have signalized
multicast listener announcement capability then an IPv6 multicast packet
with a destination of IPv6 link-local scope (excluding ff02::1) coming
from the upstream of this node...
* ...is dropped if there is no according multicast listener in the
translation table,
* ...is forwarded via unicast if there is a single node with interested
multicast listeners
* ...and otherwise still gets flooded.
If the soft interface of a node is not part of a bridge then a node
announces a new multicast TVLV: The existence of this TVLV
signalizes that this node is announcing all of its multicast listeners
via the translation table infrastructure.
With this patch a node which has no bridge interface on top of its soft
interface announces its local multicast listeners via the translation
table.
