commit f131a56880d10932931e74773fb8702894a94a75 upstream.
The batadv_hash_remove is a function which searches the hashtable for an
entry using a needle, a hashtable bucket selection function and a compare
function. It will lock the bucket list and delete an entry when the compare
function matches it with the needle. It returns the pointer to the
hlist_node which matches or NULL when no entry matches the needle.
The batadv_tt_global_free is not itself protected in anyway to avoid that
any other function is modifying the hashtable between the search for the
entry and the call to batadv_hash_remove. It can therefore happen that the
entry either doesn't exist anymore or an entry was deleted which is not the
same object as the needle. In such an situation, the reference counter (for
the reference stored in the hashtable) must not be reduced for the needle.
Instead the reference counter of the actually removed entry has to be
reduced.
Otherwise the reference counter will underflow and the object might be
freed before all its references were dropped. The kref helpers reported
this problem as:
refcount_t: underflow; use-after-free.
Fixes: 7683fdc1e886 ("batman-adv: protect the local and the global trans-tables with rcu")
Reported-by: Martin Weinelt <martin@linuxlounge.net>
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Acked-by: Antonio Quartulli <a@unstable.cc>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
commit 3d65b9accab4a7ed5038f6df403fbd5e298398c7 upstream.
The batadv_tt_local_remove is not itself protected in anyway to avoid that
reduced.
this problem as:
Fixes: ef72706a0543 ("batman-adv: protect tt_local_entry from concurrent delete events")
commit e7136e48ffdfb9f37b0820f619380485eb407361 upstream.
The function batadv_tt_global_orig_entry_add is responsible for adding new
tt_orig_list_entry to the orig_list. It first checks whether the entry
already is in the list or not. If it is, then the creation of a new entry
is aborted.
But the lock for the list is only held when the list is really modified.
This could lead to duplicated entries because another context could create
an entry with the same key between the check and the list manipulation.
The check and the manipulation of the list must therefore be in the same
locked code section.
Fixes: d657e621a0f5 ("batman-adv: add reference counting for type batadv_tt_orig_list_entry")
commit 4a519b83da16927fb98fd32b0f598e639d1f1859 upstream.
Since commit 54e22f265e87 ("batman-adv: fix TT sync flag inconsistencies")
TT sync flags and TT non-sync'd flags are supposed to be stored
separately.
The previous patch missed to apply this separation on a TT entry with
only a single TT orig entry.
This is a minor fix because with only a single TT orig entry the DDoS
issue the former patch solves does not apply.
Fixes: 54e22f265e87 ("batman-adv: fix TT sync flag inconsistencies")
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
commit 16116dac23396e73c01eeee97b102e4833a4b205 upstream.
A translation table TVLV changset sent with an OGM consists
of a number of headers (one per VLAN) plus the changeset
itself (addition and/or deletion of entries).
The per-VLAN headers are used by OGM recipients for consistency
checks. Said consistency check might determine that a full
translation table request is needed to restore consistency. If
the TT sender adds per-VLAN headers of empty VLANs into the OGM,
recipients are led to believe to have reached an inconsistent
state and thus request a full table update. The full table does
not contain empty VLANs (due to missing entries) the cycle
restarts when the next OGM is issued.
Consequently, when the translation table TVLV headers are
composed, empty VLANs are to be excluded.
Fixes: 21a57f6e7a3b ("batman-adv: make the TT CRC logic VLAN specific")
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
commit 7072337e52b3e9d5460500d8dc9cbc1ba2db084c upstream.
The previous TT sync fix so far only fixed TT responses issued by the
target node directly. So far, TT responses issued by intermediate nodes
still lead to the wrong flags being added, leading to CRC mismatches.
This behaviour was observed at Freifunk Hannover in a 800 nodes setup
where a considerable amount of nodes were still infected with 'WI'
TT flags even with (most) nodes having the previous TT sync fix applied.
I was able to reproduce the issue with intermediate TT responses in a
four node test setup and this patch fixes this issue by ensuring to
use the per originator instead of the summarized, OR'd ones.
Fixes: e9c00136a475 ("batman-adv: fix tt_global_entries flags update")
Reported-by: Leonardo Mörlein <me@irrelefant.net>
commit 8ba0f9bd3bdea1058c2b2676bec7905724418e40 upstream.
The functions batadv_tt_prepare_tvlv_local_data and
batadv_tt_prepare_tvlv_global_data are responsible for preparing a buffer
which can be used to store the TVLV container for TT and add the VLAN
information to it.
This will be done in three phases:
1. count the number of VLANs and their entries
2. allocate the buffer using the counters from the previous step and limits
from the caller (parameter tt_len)
3. insert the VLAN information to the buffer
The step 1 and 3 operate on a list which contains the VLANs. The access to
these lists must be protected with an appropriate lock or otherwise they
might operate on on different entries. This could for example happen when
another context is adding VLAN entries to this list.
This could lead to a buffer overflow in these functions when enough entries
were added between step 1 and 3 to the VLAN lists that the buffer room for
the entries (*tt_change) is smaller then the now required extra buffer for
new VLAN entries.
Fixes: 7ea7b4a14275 ("batman-adv: make the TT CRC logic VLAN specific")
commit 54e22f265e872ae140755b3318521d400a094605 upstream.
This patch fixes an issue in the translation table code potentially
leading to a TT Request + Response storm. The issue may occur for nodes
involving BLA and an inconsistent configuration of the batman-adv AP
isolation feature. However, since the new multicast optimizations, a
single, malformed packet may lead to a mesh-wide, persistent
Denial-of-Service, too.
The issue occurs because nodes are currently OR-ing the TT sync flags of
all originators announcing a specific MAC address via the
translation table. When an intermediate node now receives a TT Request
and wants to answer this on behalf of the destination node, then this
intermediate node now responds with an altered flag field and broken
CRC. The next OGM of the real destination will lead to a CRC mismatch
and triggering a TT Request and Response again.
Furthermore, the OR-ing is currently never undone as long as at least
one originator announcing the according MAC address remains, leading to
the potential persistency of this issue.
This patch fixes this issue by storing the flags used in the CRC
calculation on a a per TT orig entry basis to be able to respond with
the correct, original flags in an intermediate TT Response for one
thing. And to be able to correctly unset sync flags once all nodes
announcing a sync flag vanish for another.
[sw: typo in commit message]
commit 9c4604a298e0a9807eaf2cd912d1ebf24d98fbeb upstream.
The tt_req_node is added and removed from a list inside a spinlock. But the
locking is sometimes removed even when the object is still referenced and
will be used later via this reference. For example batadv_send_tt_request
can create a new tt_req_node (including add to a list) and later
re-acquires the lock to remove it from the list and to free it. But at this
time another context could have already removed this tt_req_node from the
list and freed it.
CPU#0
batadv_batman_skb_recv from net_device 0
-> batadv_iv_ogm_receive
-> batadv_iv_ogm_process
-> batadv_iv_ogm_process_per_outif
-> batadv_tvlv_ogm_receive
-> batadv_tvlv_containers_process
-> batadv_tvlv_call_handler
-> batadv_tt_tvlv_ogm_handler_v1
-> batadv_tt_update_orig
-> batadv_send_tt_request
-> batadv_tt_req_node_new
spin_lock(...)
allocates new tt_req_node and adds it to list
spin_unlock(...)
return tt_req_node
CPU#1
batadv_batman_skb_recv from net_device 1
-> batadv_recv_unicast_tvlv
-> batadv_tt_tvlv_unicast_handler_v1
-> batadv_handle_tt_response
spin_lock(...)
tt_req_node gets removed from list and is freed
spin_unlock(...)
CPU#0
<- returned to batadv_send_tt_request
spin_lock(...)
MEMORY CORRUPTION/SEGFAULT/...
spin_unlock(...)
This can only be solved via reference counting to allow multiple contexts
to handle the list manipulation while making sure that only the last
context holding a reference will free the object.
Fixes: a73105b8d4c7 ("batman-adv: improved client announcement mechanism")
Tested-by: Martin Weinelt <martin@darmstadt.freifunk.net>
Tested-by: Amadeus Alfa <amadeus@chemnitz.freifunk.net>
commit a33d970d0b54b09746d5540af8271fad4eb10229 upstream.
The batadv_tt_local_entry was specific to a batadv_softif_vlan and held an
implicit reference to it. But this reference was never stored in form of a
pointer in the tt_local_entry itself. Instead batadv_tt_local_remove,
batadv_tt_local_table_free and batadv_tt_local_purge_pending_clients depend
on a consistent state of bat_priv->softif_vlan_list and that
batadv_softif_vlan_get always returns the batadv_softif_vlan object which
it has a reference for. But batadv_softif_vlan_get cannot guarantee that
because it is working only with rcu_read_lock on this list. It can
therefore happen that an vid is in this list twice or that
batadv_softif_vlan_get cannot find the batadv_softif_vlan for an vid due to
some other list operations taking place at the same time.
Instead add a batadv_softif_vlan pointer directly in batadv_tt_local_entry
which will be used for the reference counter decremented on release of
batadv_tt_local_entry.
Fixes: 35df3b298fc8 ("batman-adv: fix TT VLAN inconsistency on VLAN re-add")
Signed-off-by: Antonio Quartulli <a@unstable.cc>
commit 3db152093efb750bc47fd4d69355b90b18113105 upstream.
The batadv_orig_node_vlan reference counter in batadv_tt_global_size_mod
can only be reduced when the list entry was actually removed. Otherwise the
reference counter may reach zero when batadv_tt_global_size_mod is called
from two different contexts for the same orig_node_vlan but only one
context is actually removing the entry from the list.
The release function for this orig_node_vlan is not called inside the
vlan_list_lock spinlock protected region because the function
batadv_tt_global_size_mod still holds a orig_node_vlan reference for the
object pointer on the stack. Thus the actual release function (when
required) will be called only at the end of the function.
[ Upstream commit 17f78dd1bd624a4dd78ed5db3284a63ee807fcc3 ]
A handler for BATADV_TVLV_ROAM was being registered when the
translation-table was initialized, but not unregistered when the
translation-table was freed. Unregister it.
Fixes: 122edaa05940 ("batman-adv: tvlv - convert roaming adv packet to use tvlv unicast packets")
Reported-by: syzbot+d454a826e670502484b8@syzkaller.appspotmail.com
Signed-off-by: Jeremy Sowden <jeremy@azazel.net>
commit c2d0f48a13e53b4747704c9e692f5e765e52041a upstream.
batadv_tt_prepare_tvlv_local_data can fail to allocate the memory for the
new TVLV block. The caller is informed about this problem with the returned
length of 0. Not checking this value results in an invalid memory access
when either tt_data or tt_change is accessed.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 42eff6a617e23b691f8e4467f4687ed7245a92db ]
It is not allowed to free the memory of an object which is part of a list
which is protected by rcu-read-side-critical sections without making sure
that no other context is accessing the object anymore. This usually happens
by removing the references to this object and then waiting until the rcu
grace period is over and no one (allowedly) accesses it anymore.
But the _now functions ignore this completely. They free the object
directly even when a different context still tries to access it. This has
to be avoided and thus these functions must be removed and all functions
have to use batadv_orig_node_free_ref.
Fixes: 72822225bd41 ("batman-adv: Fix rcu_barrier() miss due to double call_rcu() in TT code")
The translation table implementation, namely batadv_compare_tt(),
is used to compare two client entries and deciding if they are the
holding the same information. Each client entry is identified by
its mac address and its VLAN id (VID).
Consequently, batadv_compare_tt() has to not only compare the mac
addresses but also the VIDs.
Without this fix adding a new client entry that possesses the same
mac address as another client but operates on a different VID will
fail because both client entries will considered identical.
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
In the case when a temporary entry is added first and a proper tt entry
is added after that, the temporary tt entry is kept in the orig list.
However the temporary flag is removed at this point, and therefore the
purge function can not find this temporary entry anymore.
Therefore, remove the previous temp entry before adding the new proper
one.
This case can happen if a client behind a given originator moves before
the TT announcement is sent out. Other than that, this case can also be
created by bogus or malicious payload frames for VLANs which are not
existent on the sending originator.
Reported-by: Alessandro Bolletta <alessandro@mediaspot.net>
Acked-by: Antonio Quartulli <antonio@meshcoding.com>
Some functions already have documentation about locks they require inside
their kerneldoc header. These can be directly tested during runtime using
the lockdep asserts.
Functions which use (h)list_del* are requiring correct locking when they
operate on global lists. Most of the time the search in the list and the
delete are done in the same function. All other cases should have it
visible that they require a special lock to avoid race conditions.
Lockdep asserts can be used to check these problem during runtime when the
lockdep functionality is enabled.
Since the list's tail is never accessed using a double linked list head
wastes memory.
The hlist_del_rcu() call in batadv_tt_global_size_mod() does not check
if the element still is part of the list prior to deletion. The atomic
list counter should prevent the worst but converting to
hlist_del_init_rcu() ensures the element can't be deleted more than
once.
wastes memory.
The updated kernel doc & additional comment shall prevent accidental
copy & paste errors or calling the function without the required
precautions.
The Linux CodingStyle disallows multiple assignments in a single line.
(see chapter 1)
Reported-by: Markus Pargmann <mpa@pengutronix.de>
(s|u)(8|16|32|64) are the preferred types in the kernel. The use of the
standard C99 types u?int(8|16|32|64)_t are objected by some people and even
checkpatch now warns about using them.
drivers/net/usb/qmi_wwan.c
Overlapping additions of new device IDs to qmi_wwan.c
The object tt_local is allocated with kmalloc and not initialized when the
function batadv_tt_local_add checks for the vlan. But this function can
only cleanup the object when the (not yet initialized) reference counter of
the object is 1. This is unlikely and thus the object would leak when the
vlan could not be found.
Instead the uninitialized object tt_local has to be freed manually and the
pointer has to set to NULL to avoid calling the function which would try to
decrement the reference counter of the not existing object.
CID: 1316518
Fixes: 354136bcc3c4 ("batman-adv: fix kernel crash due to missing NULL checks")
Antonio Quartulli says:
Included changes:
- avoid integer overflow in GW selection routine
- prevent race condition by making capability bit changes atomic (use
clear/set/test_bit)
- fix synchronization issue in mcast tvlv handler
- fix crash on double list removal of TT Request objects
- fix leak by puring packets enqueued for sending upon iface removal
- ensure network header pointer is set in skb
The list_del() calls were changed to list_del_init() to prevent
an accidental double deletion in batadv_tt_req_node_new().
Bitwise OR/AND assignments in C aren't guaranteed to be atomic. One
OGM handler might undo the set/clear of a specific bit from another
handler run in between.
Fix this by using the atomic set_bit()/clear_bit()/test_bit() functions.
Fixes: e17931d1a61d ("batman-adv: introduce capability initialization bitfield")
The tt_local_entry deletion performed in batadv_tt_local_remove() was neither
protecting against simultaneous deletes nor checking whether the element was
still part of the list before calling hlist_del_rcu().
Replacing the hlist_del_rcu() call with batadv_hash_remove() provides adequate
protection via hash spinlocks as well as an is-element-still-in-hash check to
avoid 'blind' hash removal.
Fixes: 068ee6e204e1 ("batman-adv: roaming handling mechanism redesign")
Reported-by: alfonsname@web.de
batadv_softif_vlan_get() may return NULL which has to be verified
by the caller.
Reported-by: Ryan Thompson <ryan@eero.com>
The header files could not be build indepdent from each other. This is
happened because headers didn't include the files for things they've used.
This was problematic because the success of a build depended on the
knowledge about the right order of local includes.
Also source files were not including everything they've used explicitly.
Instead they required that transitive includes are always stable. This is
problematic because some transitive includes are not obvious, depend on
config settings and may not be stable in the future.
The order for include blocks are:
* primary headers (main.h and the *.h file of a *.c file)
* global linux headers
* required local headers
* extra forward declarations for pointers in function/struct declarations
The only exceptions are linux/bitops.h and linux/if_ether.h in packet.h.
This header file is shared with userspace applications like batctl and must
therefore build together with userspace applications. The header
linux/bitops.h is not part of the uapi headers and linux/if_ether.h
conflicts with the musl implementation of netinet/if_ether.h. The
maintainers rejected the use of __KERNEL__ preprocessor checks and thus
these two headers are only in main.h. All files using packet.h first have
to include main.h to work correctly.
An unoptimized version of the Jenkins one-at-a-time hash function is used
and partially copied all over the code wherever an hashtable is used.
Instead the optimized version shared between the whole kernel should be
used to reduce code duplication and use better optimized code.
Only the DAT code must use the old implementation because it is used as
distributed hash function which has to be common for all nodes.
Reported-by: checkpatch
When a VLAN interface (on top of batX) is removed and
re-added within a short timeframe TT does not have enough
time to properly cleanup. This creates an internal TT state
mismatch as the newly created softif_vlan will be
initialized from scratch with a TT client count of zero
(even if TT entries for this VLAN still exist). The
resulting TT messages are bogus due to the counter / tt
client listing mismatch, thus creating inconsistencies on
every node in the network
To fix this issue destroy_vlan() has to not free the VLAN
object immediately but it has to be kept alive until all the
TT entries for this VLAN have been removed. destroy_vlan()
still removes the sysfs folder so that the user has the
feeling that everything went fine.
If the same VLAN is re-added before the old object is free'd,
then the latter is resurrected and re-used.
Implement such behaviour by increasing the reference counter
of a softif_vlan object every time a new local TT entry for
such VLAN is created and remove the object from the list
only when all the TT entries have been destroyed.
Signed-off-by: Antonio Quartulli <antonio@open-mesh.com>
With this patch a multicast packet is not always simply flooded anymore,
the behaviour for the following cases is changed to reduce
unnecessary overhead:
If all nodes within the horizon of a certain node have signalized
multicast listener announcement capability then an IPv6 multicast packet
with a destination of IPv6 link-local scope (excluding ff02::1) coming
from the upstream of this node...
* ...is dropped if there is no according multicast listener in the
translation table,
* ...is forwarded via unicast if there is a single node with interested
multicast listeners
* ...and otherwise still gets flooded.
Signed-off-by: Linus Lüssing <linus.luessing@web.de>
The new bitfield allows us to keep track whether capability subsets of
an originator have gone through their initialization phase yet.
The translation table is the only user right now, but a new one will be
added soon.
With this patch a node which has no bridge interface on top of its soft
interface announces its local multicast listeners via the translation
table.
On some architectures ether_addr_copy() is slightly faster
than memcpy() therefore use the former when possible.
When computing the CRC on a 2byte variable the order of
the bytes obviously alters the final result. This means
that computing the CRC over the same value on two archs
having different endianess leads to different numbers.
The global and local translation table CRC computation
routine makes this mistake while processing the clients
VIDs. The result is a continuous CRC mismatching between
nodes having different endianess.
Fix this by converting the VID to Network Order before
processing it. This guarantees that every node uses the same
byte order.
Introduced by 7ea7b4a142758deaf46c1af0ca9ceca6dd55138b
Reported-by: Russel Senior <russell@personaltelco.net>
Tested-by: Russell Senior <russell@personaltelco.net>
There is a refcounter unbalance in the CRC checking routine
invoked on OGM reception. A vlan object is retrieved (thus
its refcounter is increased by one) but it is never properly
released. This leads to a memleak because the vlan object
will never be free'd.
Fix this by releasing the vlan object after having read the
CRC.
Reported-by: Russell Senior <russell@personaltelco.net>
Reported-by: Daniel <daniel@makrotopia.org>
Reported-by: cmsv <cmsv@wirelesspt.net>
When accessing a TT-TVLV container in the OGM RX path
the variable pointing to the list of changes to apply is
altered by mistake.
This makes the TT component read data at the wrong position
in the OGM packet buffer.
Fix it by removing the bogus pointer alteration.
Reported-by: Antonio Quartulli <antonio@meshcoding.com>
For the network wide multi interface optimization there are different
routers for each outgoing interface (outgoing from the OGM perspective,
incoming for payload traffic). To reflect this, change the router and
associated data to a list of routers.
While at it, rename batadv_orig_node_get_router() to
batadv_orig_router_get() to follow the new naming scheme.
Signed-off-by: Simon Wunderlich <simon@open-mesh.com>
