path: root/net/batman-adv
2014-10-14batman-adv: replace strnicmp with strncasecmpRasmus Villemoes
The kernel used to contain two functions for length-delimited, case-insensitive string comparison, strnicmp with correct semantics and a slightly buggy strncasecmp. The latter is the POSIX name, so strnicmp was renamed to strncasecmp, and strnicmp made into a wrapper for the new strncasecmp to avoid breaking existing users. To allow the compat wrapper strnicmp to be removed at some point in the future, and to avoid the extra indirection cost, do s/strnicmp/strncasecmp/g. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Marek Lindner <mareklindner@neomailbox.ch> Acked-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-16batman-adv: Fix parameter order of hlist_add_behindSven Eckelmann
1d023284c31a4e40a94d5bbcb7dbb7a35ee0bcbc ("list: fix order of arguments for hlist_add_after(_rcu)") was incorrectly rebased on top of d9124268d84a836f14a6ead54ff9d8eee4c43be5 ("batman-adv: Fix out-of-order fragmentation support"). The parameter order change of the rebased patch was not re-applied as expected. This causes a memory leak and can cause crashes when out-of-order packets are received. hlist_add_behind will try to access the uninitalized list pointers of frag_entry_new to find the previous/next entry and may modify/read random memory locations. Signed-off-by: Sven Eckelmann <sven@narfation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-07batman: fix duplicate #include of multicast.hJean Sacren
The header multicast.h was included twice, so delete one of them. Signed-off-by: Jean Sacren <sakiwit@gmail.com> Cc: Marek Lindner <mareklindner@neomailbox.ch> Cc: Simon Wunderlich <sw@simonwunderlich.de> Cc: Antonio Quartulli <antonio@meshcoding.com> Cc: b.a.t.m.a.n@lists.open-mesh.org Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-06list: fix order of arguments for hlist_add_after(_rcu)Ken Helias
All other add functions for lists have the new item as first argument and the position where it is added as second argument. This was changed for no good reason in this function and makes using it unnecessary confusing. The name was changed to hlist_add_behind() to cause unconverted code to generate a compile error instead of using the wrong parameter order. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Ken Helias <kenhelias@firemail.de> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> [intel driver bits] Cc: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/Makefile net/ipv6/sysctl_net_ipv6.c Two ipv6_table_template[] additions overlap, so the index of the ipv6_table[x] assignments needed to be adjusted. In the drivers/net/Makefile case, we've gotten rid of the garbage whereby we had to list every single USB networking driver in the top-level Makefile, there is just one "USB_NETWORKING" that guards everything. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-05batman-adv: Start new development cycleSimon Wunderlich
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-08-05batman-adv: increase default hop penaltySimon Wunderlich
The default hop penalty is currently set to 15, which is applied like that for multi interface devices (e.g. dual band APs). Single band devices will still use an effective penalty of 30 (hop penalty + wifi penalty). After receiving reports of too long paths in mesh networks with dual band APs which were fixed by increasing the hop penalty, we'd like to suggest to increase that default value in the default setting as well. We've evaluated that increase in a handful of medium sized mesh networks (5-20 nodes) with single and dual band devices, with changes for the better (shorter routes, higher throughput) or no change at all. This patch changes the hop penalty to 30, which will give an effective penalty of 60 on single band devices (hop penalty + wifi penalty). Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-08-05batman-adv: remove unnecessary logspamAndré Gaul
This patch removes unnecessary logspam which resulted from superfluous calls to net_ratelimit(). With the supplied patch, net_ratelimit() is called after the loglevel has been checked. Signed-off-by: André Gaul <gaul@web-yard.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-08-05batman-adv: Fix out-of-order fragmentation supportSven Eckelmann
batadv_frag_insert_packet was unable to handle out-of-order packets because it dropped them directly. This is caused by the way the fragmentation lists is checked for the correct place to insert a fragmentation entry. The fragmentation code keeps the fragments in lists. The fragmentation entries are kept in descending order of sequence number. The list is traversed and each entry is compared with the new fragment. If the current entry has a smaller sequence number than the new fragment then the new one has to be inserted before the current entry. This ensures that the list is still in descending order. An out-of-order packet with a smaller sequence number than all entries in the list still has to be added to the end of the list. The used hlist has no information about the last entry in the list inside hlist_head and thus the last entry has to be calculated differently. Currently the code assumes that the iterator variable of hlist_for_each_entry can be used for this purpose after the hlist_for_each_entry finished. This is obviously wrong because the iterator variable is always NULL when the list was completely traversed. Instead the information about the last entry has to be stored in a different variable. This problem was introduced in 610bfc6bc99bc83680d190ebc69359a05fc7f605 ("batman-adv: Receive fragmented packets and merge"). Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-08-04batman-adv: prefer kmalloc_array to kmalloc when possibleAntonio Quartulli
Reported by checkpatch with the following warning: WARNING: Prefer kmalloc_array over kmalloc with multiply Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/infiniband/hw/cxgb4/device.c The cxgb4 conflict was simply overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-21batman-adv: fix TT VLAN inconsistency on VLAN re-addAntonio Quartulli
When a VLAN interface (on top of batX) is removed and re-added within a short timeframe TT does not have enough time to properly cleanup. This creates an internal TT state mismatch as the newly created softif_vlan will be initialized from scratch with a TT client count of zero (even if TT entries for this VLAN still exist). The resulting TT messages are bogus due to the counter / tt client listing mismatch, thus creating inconsistencies on every node in the network To fix this issue destroy_vlan() has to not free the VLAN object immediately but it has to be kept alive until all the TT entries for this VLAN have been removed. destroy_vlan() still removes the sysfs folder so that the user has the feeling that everything went fine. If the same VLAN is re-added before the old object is free'd, then the latter is resurrected and re-used. Implement such behaviour by increasing the reference counter of a softif_vlan object every time a new local TT entry for such VLAN is created and remove the object from the list only when all the TT entries have been destroyed. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-07-21batman-adv: drop QinQ claim frames in bridge loop avoidanceSimon Wunderlich
Since bridge loop avoidance only supports untagged or simple 802.1q tagged VLAN claim frames, claim frames with stacked VLAN headers (QinQ) should be detected and dropped. Transporting the over the mesh may cause problems on the receivers, or create bogus entries in the local tt tables. Reported-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-07batman-adv: Use kasprintfHimangi Saraogi
kasprintf combines kmalloc and sprintf, and takes care of the size calculation itself. The semantic patch that makes this change is as follows: // <smpl> @@ expression a,flag; expression list args; statement S; @@ a = - \(kmalloc\|kzalloc\)(...,flag) + kasprintf(flag,args) <... when != a if (a == NULL || ...) S ...> - sprintf(a,args); // </smpl> Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-11net: add __pskb_copy_fclone and pskb_copy_for_cloneOctavian Purdila
There are several instances where a pskb_copy or __pskb_copy is immediately followed by an skb_clone. Add a couple of new functions to allow the copy skb to be allocated from the fclone cache and thus speed up subsequent skb_clone calls. Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Marek Lindner <mareklindner@neomailbox.ch> Cc: Simon Wunderlich <sw@simonwunderlich.de> Cc: Antonio Quartulli <antonio@meshcoding.com> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: Arvid Brodin <arvid.brodin@alten.se> Cc: Patrick McHardy <kaber@trash.net> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Jon Maloy <jon.maloy@ericsson.com> Cc: Allan Stephens <allan.stephens@windriver.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Cc: Eric Dumazet <edumazet@google.com> Reviewed-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: Octavian Purdila <octavian.purdila@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: include/net/inetpeer.h net/ipv6/output_core.c Changes in net were fixing bugs in code removed in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-31batman-adv: fix NULL pointer dereferencesMarek Lindner
Was introduced with 4c8755d69cbde2ec464a39c932aed0a83f9ff89f ("batman-adv: Send multicast packets to nodes with a WANT_ALL flag") Reported-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Acked-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/bonding/bond_alb.c drivers/net/ethernet/altera/altera_msgdma.c drivers/net/ethernet/altera/altera_sgdma.c net/ipv6/xfrm6_output.c Several cases of overlapping changes. The xfrm6_output.c has a bug fix which overlaps the renaming of skb->local_df to skb->ignore_df. In the Altera TSE driver cases, the register access cleanups in net-next overlapped with bug fixes done in net. Similarly a bug fix to send ALB packets in the bonding driver using the right source address overlaps with cleanups in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-22batman: fix a bogus warning from batadv_is_on_batman_iface()Cong Wang
batman tries to search dev->iflink to check if it's a batman interface, but ->iflink could be 0, which is not a valid ifindex. It should just avoid iflink == 0 case. Reported-by: Jet Chen <jet.chen@intel.com> Tested-by: Jet Chen <jet.chen@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Antonio Quartulli <antonio@open-mesh.com> Cc: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-18batman-adv: Start new development cycleSimon Wunderlich
2014-05-18batman-adv: remove semi-colon after macro definitionAntonio Quartulli
Reported by checkpatch with the following warning: "WARNING: macros should not use a trailing semicolon" Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-05-18batman-adv: add blank line between declarations and the rest of the codeAntonio Quartulli
Reported by checkpatch with the following message: "WARNING: Missing a blank line after declarations" Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-05-15batman-adv: fix local TT check for outgoing arp requests in DATAntonio Quartulli
Change introduced by 88e48d7b3340ef07b108eb8a8b3813dd093cc7f7 ("batman-adv: make DAT drop ARP requests targeting local clients") implements a check that prevents DAT from using the caching mechanism when the client that is supposed to provide a reply to an arp request is local. However change brought by be1db4f6615b5e6156c807ea8985171c215c2d57 ("batman-adv: make the Distributed ARP Table vlan aware") has not converted the above check into its vlan aware version thus making it useless when the local client is behind a vlan. Fix the behaviour by properly specifying the vlan when checking for a client being local or not. Reported-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-05-15batman-adv: increase orig refcount when storing ref in gw_nodeAntonio Quartulli
A pointer to the orig_node representing a bat-gateway is stored in the gw_node->orig_node member, but the refcount for such orig_node is never increased. This leads to memory faults when gw_node->orig_node is accessed and the originator has already been freed. Fix this by increasing the refcount on gw_node creation and decreasing it on gw_node free. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-05-15batman-adv: fix reference counting imbalance while sending fragmentAntonio Quartulli
In the new fragmentation code the batadv_frag_send_packet() function obtains a reference to the primary_if, but it does not release it upon return. This reference imbalance prevents the primary_if (and then the related netdevice) to be properly released on shut down. Fix this by releasing the primary_if in batadv_frag_send_packet(). Introduced by ee75ed88879af88558818a5c6609d85f60ff0df4 ("batman-adv: Fragment and send skbs larger than mtu") Cc: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Acked-by: Martin Hundebøll <martin@hundeboll.net>
2014-05-15batman-adv: fix indirect hard_iface NULL dereferenceMarek Lindner
If hard_iface is NULL and goto out is made batadv_hardif_free_ref() doesn't check for NULL before dereferencing it to get to refcount. Introduced in cb1c92ec37fb70543d133a1fa7d9b54d6f8a1ecd ("batman-adv: add debugfs support to view multiif tables"). Reported-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Acked-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-05-13net: get rid of SET_ETHTOOL_OPSWilfried Klaebe
net: get rid of SET_ETHTOOL_OPS Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone. This does that. Mostly done via coccinelle script: @@ struct ethtool_ops *ops; struct net_device *dev; @@ - SET_ETHTOOL_OPS(dev, ops); + dev->ethtool_ops = ops; Compile tested only, but I'd seriously wonder if this broke anything. Suggested-by: Dave Miller <davem@davemloft.net> Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-11batman-adv: fix removing neigh_ifinfoSimon Wunderlich
When an interface is removed separately, all neighbors need to be checked if they have a neigh_ifinfo structure for that particular interface. If that is the case, remove that ifinfo so any references to a hard interface can be freed. This is a regression introduced by 89652331c00f43574515059ecbf262d26d885717 ("batman-adv: split tq information in neigh_node struct") Reported-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-05-10batman-adv: always run purge_orig_neighborsSimon Wunderlich
The current code will not execute batadv_purge_orig_neighbors() when an orig_ifinfo has already been purged. However we need to run it in any case. Fix that. This is a regression introduced by 7351a4822d42827ba0110677c0cbad88a3d52585 ("batman-adv: split out router from orig_node") Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-05-10batman-adv: fix neigh reference imbalanceSimon Wunderlich
When an interface is removed from batman-adv, the orig_ifinfo of a orig_node may be removed without releasing the router first. This will prevent the reference for the neighbor pointed at by the orig_ifinfo->router to be released, and this leak may result in reference leaks for the interface used by this neighbor. Fix that. This is a regression introduced by 7351a4822d42827ba0110677c0cbad88a3d52585 ("batman-adv: split out router from orig_node"). Reported-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-05-10batman-adv: fix neigh_ifinfo imbalanceSimon Wunderlich
The neigh_ifinfo object must be freed if it has been used in batadv_iv_ogm_process_per_outif(). This is a regression introduced by 89652331c00f43574515059ecbf262d26d885717 ("batman-adv: split tq information in neigh_node struct") Reported-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Simon Wunderlich <simon@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: Start new development cycleSimon Wunderlich
2014-03-22batman-adv: improve DAT documentationAntonio Quartulli
Add missing documentation for BATADV_DAT_ADDR_MAX and convert an existing documentation to kerneldoc Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-03-22batman-adv: improve the TT flags documentationAntonio Quartulli
Convert the current documentation for the TT flags in proper kerneldoc and improve it by adding an explanation for each of the flags. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-03-22batman-adv: Send multicast packets to nodes with a WANT_ALL flagLinus Lüssing
With this patch a node sends IPv4 multicast packets to nodes which have a BATADV_MCAST_WANT_ALL_IPV4 flag set and IPv6 multicast packets to nodes which have a BATADV_MCAST_WANT_ALL_IPV6 flag set, too. Why is this needed? There are scenarios involving bridges where multicast report snooping and multicast TT announcements are not sufficient, which would lead to packet loss for some nodes otherwise: MLDv1 and IGMPv1/IGMPv2 have a suppression mechanism for multicast listener reports. When we have an MLDv1/IGMPv1/IGMPv2 querier behind a bridge then our snooping bridge is potentially not going to see any reports even though listeners exist because according to RFC4541 such reports are only forwarded to multicast routers: ----------------------------------------------------------- --------------- {Querier}---|Snoop. Switch|----{Listener} --------------- \ ^ ------- | br0 | < ??? ------- \ _-~---~_ _-~/ ~-_ ~ batman-adv \-----{Sender} \~_ cloud ~/ -~~__-__-~_/ I) MLDv1 Query: {Querier} -> flooded II) MLDv1 Report: {Listener} -> {Querier} -> br0 cannot detect the {Listener} => Packets from {Sender} need to be forwarded to all detected listeners and MLDv1/IGMPv1/IGMPv2 queriers. ----------------------------------------------------------- Note that we do not need to explicitly forward to MLDv2/IGMPv3 queriers, because these protocols have no report suppression: A bridge has no trouble detecting MLDv2/IGMPv3 listeners. Even though we do not support bridges yet we need to provide the according infrastructure already to not break compatibility later. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: Add IPv4 link-local/IPv6-ll-all-nodes multicast supportLinus Lüssing
With this patch a node may additionally perform the dropping or unicasting behaviour for a link-local IPv4 and link-local-all-nodes IPv6 multicast packet, too. The extra counter and BATADV_MCAST_WANT_ALL_UNSNOOPABLES flag is needed because with a future bridge snooping support integration a node with a bridge on top of its soft interface is not able to reliably detect its multicast listeners for IPv4 link-local and the IPv6 link-local-all-nodes addresses anymore (see RFC4541, section 2.1.2.2 and section 3). Even though this new flag does make "no difference" now, it'll ensure a seamless integration of multicast bridge support without needing to break compatibility later. Also note, that even with multicast bridge support it won't be possible to optimize 224.0.0.x and ff02::1 towards nodes with bridges, they will always receive these ranges. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: Modified forwarding behaviour for multicast packetsLinus Lüssing
With this patch a multicast packet is not always simply flooded anymore, the behaviour for the following cases is changed to reduce unnecessary overhead: If all nodes within the horizon of a certain node have signalized multicast listener announcement capability then an IPv6 multicast packet with a destination of IPv6 link-local scope (excluding ff02::1) coming from the upstream of this node... * ...is dropped if there is no according multicast listener in the translation table, * ...is forwarded via unicast if there is a single node with interested multicast listeners * ...and otherwise still gets flooded. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: Announce new capability via multicast TVLVLinus Lüssing
If the soft interface of a node is not part of a bridge then a node announces a new multicast TVLV: The existence of this TVLV signalizes that this node is announcing all of its multicast listeners via the translation table infrastructure. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: introduce capability initialization bitfieldLinus Lüssing
The new bitfield allows us to keep track whether capability subsets of an originator have gone through their initialization phase yet. The translation table is the only user right now, but a new one will be added soon. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: Multicast Listener Announcements via Translation TableLinus Lüssing
With this patch a node which has no bridge interface on top of its soft interface announces its local multicast listeners via the translation table. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: add kerneldoc for dst_hint argumentAntonio Quartulli
Some helper functions used along the TX path have now a new "dst_hint" argument but the kerneldoc was missing. Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-03-22batman-adv: call unregister_netdev() to have it handle the locking for usMarek Lindner
Reported-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: fix a few kerneldoc inconsistenciesSimon Wunderlich
Reported-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: prefer ether_addr_copy to memcpyAntonio Quartulli
On some architectures ether_addr_copy() is slightly faster than memcpy() therefore use the former when possible. Signed-off-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
2014-03-22batman-adv: remove obsolete skb_reset_mac_header() in batadv_bla_tx()Linus Lüssing
Our .ndo_start_xmit handler (batadv_interface_tx()) can rely on having the skb mac header pointer set correctly since the following commit present in kernels >= 3.9: "net: reset mac header in dev_start_xmit()" (6d1ccff627) Therefore this commit removes the according, now redundant, skb_reset_mac_header() call in batadv_bla_tx(). Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: use vlan_/eth_hdr() instead of skb->data in interface_tx pathLinus Lüssing
Our .ndo_start_xmit handler (batadv_interface_tx()) can rely on having the skb mac header pointer set correctly since the following commit present in kernels >= 3.9: "net: reset mac header in dev_start_xmit()" (6d1ccff627) Therefore we can safely use eth_hdr() and vlan_eth_hdr() instead of skb->data now, which spares us some ugly type casts. At the same time set the mac_header in batadv_dat_snoop_incoming_arp_request() before sending the skb along the TX path. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-03-22batman-adv: fix coccinelle warningsFengguang Wu
net/batman-adv/network-coding.c:1535:1-7: Replace memcpy with struct assignment Generated by: coccinelle/misc/memcpy-assign.cocci Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
2014-02-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/bonding/bond_3ad.h drivers/net/bonding/bond_main.c Two minor conflicts in bonding, both of which were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17batman-adv: fix potential kernel paging error for unicast transmissionsAntonio Quartulli
batadv_send_skb_prepare_unicast(_4addr) might reallocate the skb's data. If it does then our ethhdr pointer is not valid anymore in batadv_send_skb_unicast(), resulting in a kernel paging error. Fixing this by refetching the ethhdr pointer after the potential reallocation. Signed-off-by: Linus Lüssing <linus.luessing@web.de> Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
