path: root/net/bluetooth/Kconfig
2017-09-28Revert "Bluetooth: Add option for disabling legacy ioctl interfaces"Linus Torvalds
This reverts commit dbbccdc4ced015cdd4051299bd87fbe0254ad351. It turns out that the "legacy" users aren't so legacy at all, and that turning off the legacy ioctl will break the current Qt bluetooth stack for bluetooth LE devices that were released just a couple of months ago. So it's simply not true that this was a legacy interface that hasn't been needed and is only limited to old legacy BT devices. Because I actually read Kconfig help messages, and actively try to turn off features that I don't need, I turned the option off. Then I spent _way_ too much time debugging BLE issues until I realized that it wasn't the Qt and subsurface development that had broken one of my dive computer BLE downloads, but simply my broken kernel config. Maybe in a decade it will be true that this is a legacy interface. And maybe with a better help-text and correct dependencies, this kind of legacy removal might be acceptable. But as things are right now both the commit message and the Kconfig help text were misleading, and the Kconfig option had the wrong dependenencies. There's no reason to keep that broken Kconfig option in the tree. Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-08-30Bluetooth: Add option for disabling legacy ioctl interfacesMarcel Holtmann
The legacy ioctl interfaces are only useful for BR/EDR operation and since Linux 3.4 no longer needed anyway. This options allows disabling them alltogether and use only management interfaces for setup and control. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2017-08-08Bluetooth: document config optionsPavel Machek
Kernel config options should include useful help text; I had to look up the terms on wikipedia. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2017-04-25Bluetooth: convert smp and selftest to crypto kpp APISalvatore Benedetto
* Convert both smp and selftest to crypto kpp API * Remove module ecc as no more required * Add ecdh_helper functions for wrapping kpp async calls This patch has been tested *only* with selftest, which is called on module loading. Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2016-02-23Bluetooth: add LED trigger for indicating HCI is powered upHeiner Kallweit
Add support for LED triggers to the Bluetooth subsystem and add kernel config symbol BT_LEDS for it. For now one trigger for indicating "HCI is powered up" is supported. Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2015-07-30Bluetooth: Add BT_HS config optionArron Wang
Move A2MP Module under BT_HS config option and allow the user have flexible option to choose the feature only they need a2mp_discover_amp() & a2mp_channel_create() are a2mp module entry point for master and slave, and this is dynamic invoked depends on the userspace or remote request, then we defined their implementation depends on BT_HS config Signed-off-by: Arron Wang <arron.wang@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2015-02-15Bluetooth: Provide option to enable/disable debugfs informationMarcel Holtmann
The Bluetooth controllers can export extensive information about internal states via debugfs. This patch provides an option to choose if these information are provided or not. For backwards compatibility with existing kernel configuration, this option defaults to yes. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-30Bluetooth: Add skeleton for SMP self-testsJohan Hedberg
This patch adds the initial skeleton and kernel config option for SMP self-tests. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-12-30Bluetooth: Add support for ECDH test casesJohan Hedberg
This patch adds the test cases for ECDH cryptographic functionality used by Bluetooth Low Energy Secure Connections feature. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-12-30Bluetooth: Add support for self testing frameworkMarcel Holtmann
This add support for the Bluetooth self testing framework that allows running certain test cases of sample data to ensure correctness of its basic functionality. With this patch only the basic framework will be added. It contains the build magic that allows running this at module loading time or at late_initcall stage when built into the kernel image. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-12-03Bluetooth: Add basic support for AES-CMACJohan Hedberg
Most of the LE Secure Connections SMP crypto functions build on top of the AES-CMAC function. This patch adds access to AES-CMAC in the kernel crypto subsystem by allocating a crypto_hash handle for it in a similar way that we have one for AES-CBC. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-11-02Bluetooth: Introduce BT_BREDR and BT_LE config optionsMarcel Holtmann
The current kernel options do not make it clear which modules are for Bluetooth Classic (BR/EDR) and which are for Bluetooth Low Energy (LE). To make it really clear, introduce BT_BREDR and BT_LE options with proper dependencies into the different modules. Both new options default to y to not create a regression with previous kernel config files. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2014-07-126lowpan: introduce new net/6lowpan directoryAlexander Aring
This patch moves generic code which is used by bluetooth and ieee802154 6lowpan to a new net/6lowpan directory. This directory contains generic 6LoWPAN code which is shared between bluetooth and ieee802154 MAC-Layer. This is the IPHC - "IPv6 Header Compression" format at the moment. Which is described by RFC 6282 [0]. The BLTE 6LoWPAN draft describes that the IPHC is the same format like IEEE 802.15.4, see [1]. Futuremore we can put more code into this directory which is shared between BLTE and IEEE 802.15.4 6LoWPAN like RFC 6775 or the routing protocol RPL RFC 6550. To avoid naming conflicts I renamed 6lowpan-y to ieee802154_6lowpan-y in net/ieee802154/Makefile. [0] http://tools.ietf.org/html/rfc6282 [1] http://tools.ietf.org/html/draft-ietf-6lowpan-btle-12#section-3.2 [2] http://tools.ietf.org/html/rfc6775 [3] http://tools.ietf.org/html/rfc6550 Signed-off-by: Alexander Aring <alex.aring@gmail.com> Acked-by: Jukka Rissanen <jukka.rissanen@linux.intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-07-03Bluetooth: 6LoWPAN: Create a kernel moduleJukka Rissanen
Instead of adding the 6LoWPAN functionality to Bluetooth module, we create a separate kernel module for it. Usage: In the slave side do this: $ modprobe bluetooth_6lowpan $ echo 62 > /sys/kernel/debug/bluetooth/6lowpan_psm $ hciconfig hci0 leadv In the master side do this: $ modprobe bluetooth_6lowpan $ echo 62 > /sys/kernel/debug/bluetooth/6lowpan_psm $ echo 'connect E0:06:E6:B7:2A:73 1' > \ /sys/kernel/debug/bluetooth/6lowpan_control The 6LoWPAN functionality can be controlled by psm value. If it is left to 0, then the module is disabled and all the 6LoWPAN connections are dropped if there were any. In the above example, the psm value is just an example and not a real value for 6LoWPAN service. The real psm value is yet to be defined in Bluetooth specification. The 6lowpan controlling interface is a temporary solution until the specifications are ready. Signed-off-by: Jukka Rissanen <jukka.rissanen@linux.intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-03-13Bluetooth: make sure 6LOWPAN_IPHC is built-in if neededArnd Bergmann
Commit 975508879 "Bluetooth: make bluetooth 6lowpan as an option" ensures that 6LOWPAN_IPHC is turned on when we have BT_6LOWPAN enabled in Kconfig, but it allows building the IPHC code as a loadable module even if the entire Bluetooth stack is built-in, and that causes a link error. We can solve that by moving the 'select' statement into CONFIG_BT, which is a "tristate" option to enforce that 6LOWPAN_IPHC can only be a module if BT also is a module. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-03-11Bluetooth: make bluetooth 6lowpan as an optionAlexander Aring
Currently you can have bluetooth 6lowpan without ipv6 enabled. This doesn't make any sense. With this patch you can disable/enable bluetooth 6lowpan support at compile time. The current bluetooth 6lowpan implementation doesn't check the return value of 6lowpan function. Nevertheless I added -EOPNOTSUPP as return value if 6lowpan bluetooth is disabled. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2014-01-15net: move 6lowpan compression code to separate moduleDmitry Eremin-Solenikov
IEEE 802.15.4 and Bluetooth networking stacks share 6lowpan compression code. Instead of introducing Makefile/Kconfig hacks, build this code as a separate module referenced from both ieee802154 and bluetooth modules. This fixes the following build error observed in some kernel configurations: net/built-in.o: In function `header_create': 6lowpan.c:(.text+0x166149): undefined reference to `lowpan_header_compress' net/built-in.o: In function `bt_6lowpan_recv': (.text+0x166b3c): undefined reference to `lowpan_process_data' Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Dmitry Eremin-Solenikov <dmitry_eremin@mentor.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-24Bluetooth: trivial: Remove newline before EOFSyam Sidhardhan
Trivial fix. Signed-off-by: Syam Sidhardhan <s.syam@samsung.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2012-09-27Bluetooth: AMP: Add AMP key calculationAndrei Emeltchenko
Function calculates AMP keys using hmac_sha256 helper. Calculated keys are Generic AMP Link Key (gamp) and Dedicated AMP Link Key with keyID "802b" for 802.11 PAL. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
2012-02-29Bluetooth: Fix Kconfig help descriptionAndre Guedes
SMP is not a kernel module, it is part of Bluetooth Core (as already described in lines above). Signed-off-by: Andre Guedes <andre.guedes@openbossa.org> Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2011-12-21Bluetooth: Always compile SCO and L2CAP in Bluetooth CoreUlisses Furquim
The handling of SCO audio links and the L2CAP protocol are essential to any system with Bluetooth thus are always compiled in from now on. Signed-off-by: Ulisses Furquim <ulisses@profusion.mobi> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-06-27bluetooth: uses crypto interfaces, select CRYPTORandy Dunlap
Recent changes to hci_core.c use crypto interfaces, so select CRYPTO to make sure that those interfaces are present. Fixes these build errors when CRYPTO is not enabled: net/built-in.o: In function `hci_register_dev': (.text+0x4cf86): undefined reference to `crypto_alloc_base' net/built-in.o: In function `hci_unregister_dev': (.text+0x4f912): undefined reference to `crypto_destroy_tfm' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-13Bluetooth: Add support for using the crypto subsystemVinicius Costa Gomes
This will allow using the crypto subsystem for encrypting data. As SMP (Security Manager Protocol) is implemented almost entirely on the host side and the crypto module already implements the needed methods (AES-128), it makes sense to use it. There's now a new module option to enable/disable SMP support. Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org> Signed-off-by: Anderson Briglia <anderson.briglia@openbossa.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-02-28Bluetooth: Fix BT_L2CAP and BT_SCO in KconfigGustavo F. Padovan
If we want something "bool" built-in in something "tristate" it can't "depend on" the tristate config option. Report by DaveM: I give it 'y' just to make it happen, for both, and afterways no matter how many times I rerun "make oldconfig" I keep seeing things like this in my build: scripts/kconfig/conf --silentoldconfig Kconfig include/config/auto.conf:986:warning: symbol value 'm' invalid for BT_SCO include/config/auto.conf:3156:warning: symbol value 'm' invalid for BT_L2CAP Reported-by: David S. Miller <davem@davemloft.net> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-14Bluetooth: Merge L2CAP and SCO modules into bluetooth.koGustavo F. Padovan
Actually doesn't make sense have these modules built separately. The L2CAP layer is needed by almost all Bluetooth protocols and profiles. There isn't any real use case without having L2CAP loaded. SCO is only essential for Audio transfers, but it is so small that we can have it loaded always in bluetooth.ko without problems. If you really doesn't want it you can disable SCO in the kernel config. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-02-08Bluetooth: update Bluetooth daemon name in Kconfig helpGustavo F. Padovan
Change hcid to bluetoothd. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2010-07-21Bluetooth: Remove L2CAP Extended Features from KconfigGustavo F. Padovan
This reverts commit 84fb0a6334af0ccad3544f6972c055d90fbb9fbe which adds the L2CAP Extended Features to the Kconfig, that is actually not needed. One can use other mechanisms to enable L2CAP Extended Features. Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-05-10Bluetooth: Add Kconfig option for L2CAP Extended FeaturesGustavo F. Padovan
The L2CAP Extended Features are still unstable and under development, so we are adding them under the EXPERIMENTAL flag to get more feedback on them. L2CAP Extended Features includes the Enhanced Retransmission and Streaming Modes, Frame Check Sequence (FCS), and Segmentation and Reassemby (SAR). Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Reviewed-by: João Paulo Rechi Vita <jprvita@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-08-24Bluetooth: Add missing selection of CONFIG_CRC16 for L2CAP layerRandy Dunlap
Fix net/bluetooth/l2cap.c build errors: l2cap.c:(.text+0x126035): undefined reference to `crc16' l2cap.c:(.text+0x126323): undefined reference to `crc16' l2cap.c:(.text+0x12668e): undefined reference to `crc16' l2cap.c:(.text+0x12683b): undefined reference to `crc16' l2cap.c:(.text+0x126956): undefined reference to `crc16' net/built-in.o:l2cap.c:(.text+0x129041): more undefined references to `crc16' follow Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-14Bluetooth: Fix Kconfig issue with RFKILL integrationMarcel Holtmann
Since the re-write of the RFKILL subsystem it is no longer good to just select RFKILL, but it is important to add a proper depends on rule. Based on a report by Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-10[S390] Kconfig: unwanted menus for s390.Martin Schwidefsky
Disable some more menus in the configuration files that are of no interest to a s390 machine. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
