path: root/net/bluetooth/hci_sock.c
2008-05-02bluetooth: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-28bluetooth: replace deprecated RW_LOCK_UNLOCKED macrosRobert P. J. Day
The older RW_LOCK_UNLOCKED macros defeat lockdep state tracing so replace them with the newer __RW_LOCK_UNLOCKED macros. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05bluetooth: Make hci_sock_cleanup() return voidTobias Klauser
hci_sock_cleanup() always returns 0 and its return value isn't used anywhere in the code. Compile-tested with 'make allyesconfig && make net/bluetooth/bluetooth.ko' Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Marcel Holtmann <marcel@holtmann.org>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-22[Bluetooth] Switch from OGF+OCF to using only opcodesMarcel Holtmann
The Bluetooth HCI commands are divided into logical OGF groups for easier identification of their purposes. While this still makes sense for the written specification, its makes the code only more complex and harder to read. So instead of using separate OGF and OCF values to identify the commands, use a common 16-bit opcode that combines both values. As a side effect this also reduces the complexity of OGF and OCF calculations during command header parsing. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-12[BLUETOOTH]: Fix non-COMPAT build of hci_sock.cDavid S. Miller
2007-09-09[Bluetooth] Update security filter for Bluetooth 2.1Marcel Holtmann
This patch updates the HCI security filter with support for the Bluetooth 2.1 commands and events. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-09-09[Bluetooth] Add compat handling for timestamp structureMarcel Holtmann
The timestamp structure needs special handling in case of compat programs. Use the same wrapping method the network core uses. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-05-17[BLUETOOTH]: Fix locking in hci_sock_dev_event().Satyam Sharma
We presently use lock_sock() to acquire a lock on a socket in hci_sock_dev_event(), but this goes BUG because lock_sock() can sleep and we're already holding a read-write spinlock at that point. So, we must use the non-sleeping BH version, bh_lock_sock(). However, hci_sock_dev_event() is called from user context and hence using simply bh_lock_sock() will deadlock against a concurrent softirq that tries to acquire a lock on the same socket. Hence, disabling BH's before acquiring the socket lock and enable them afterwards, is the proper solution to fix socket locking in hci_sock_dev_event(). Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-05[Bluetooth] Fix L2CAP and HCI setsockopt() information leaksMarcel Holtmann
The L2CAP and HCI setsockopt() implementations have a small information leak that makes it possible to leak kernel stack memory to userspace. If the optlen parameter is 0, no data will be copied by copy_from_user(), but the uninitialized stack buffer will be read and stored later. A call to getsockopt() can now retrieve the leaked information. To fix this problem the stack buffer given to copy_from_user() must be initialized with the current settings. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-08[PATCH] bluetooth: fix socket locking in hci_sock_dev_event()Jiri Kosina
[Bluetooth] Fix socket locking in hci_sock_dev_event() hci_sock_dev_event() uses bh_lock_sock() to lock the socket lock. This is not deadlock-safe against locking of the same socket lock in l2cap_connect_cfm() from softirq context. In addition to that, hci_sock_dev_event() doesn't seem to be called from softirq context, so it is safe to use lock_sock()/release_sock() instead. The lockdep warning can be triggered on my T42p simply by switching the Bluetooth off by the keyboard button. ================================= [ INFO: inconsistent lock state ] 2.6.21-rc2 #4 --------------------------------- inconsistent {in-softirq-W} -> {softirq-on-W} usage. khubd/156 [HC0[0]:SC0[0]:HE1:SE1] takes: (slock-AF_BLUETOOTH){-+..}, at: [<e0ca5520>] hci_sock_dev_event+0xa8/0xc5 [bluetooth] {in-softirq-W} state was registered at: [<c012d1db>] mark_lock+0x59/0x414 [<e0cef688>] l2cap_connect_cfm+0x4e/0x11f [l2cap] [<c012dfd7>] __lock_acquire+0x3e5/0xb99 [<e0cef688>] l2cap_connect_cfm+0x4e/0x11f [l2cap] [<c012e7f2>] lock_acquire+0x67/0x81 [<e0cef688>] l2cap_connect_cfm+0x4e/0x11f [l2cap] [<c036ee72>] _spin_lock+0x29/0x34 [<e0cef688>] l2cap_connect_cfm+0x4e/0x11f [l2cap] [<e0cef688>] l2cap_connect_cfm+0x4e/0x11f [l2cap] [<e0ca17c3>] hci_send_cmd+0x126/0x14f [bluetooth] [<e0ca4ce4>] hci_event_packet+0x729/0xebd [bluetooth] [<e0ca205b>] hci_rx_task+0x2a/0x20f [bluetooth] [<e0ca209d>] hci_rx_task+0x6c/0x20f [bluetooth] [<c012d7be>] trace_hardirqs_on+0x10d/0x14e [<c011ac85>] tasklet_action+0x3d/0x68 [<c011abba>] __do_softirq+0x41/0x92 [<c011ac32>] do_softirq+0x27/0x3d [<c0105134>] do_IRQ+0x7b/0x8f [<c0103dec>] common_interrupt+0x24/0x34 [<c0103df6>] common_interrupt+0x2e/0x34 [<c0248e65>] acpi_processor_idle+0x1b3/0x34a [<c0248e68>] acpi_processor_idle+0x1b6/0x34a [<c010232b>] cpu_idle+0x39/0x4e [<c04bab0c>] start_kernel+0x372/0x37a [<c04ba42b>] unknown_bootoption+0x0/0x202 [<ffffffff>] 0xffffffff Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] BLUETOOTH: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[PATCH] hci endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-21[BLUETOOTH]: Fix unaligned access in hci_send_to_sock.David S. Miller
The "u16 *" derefs of skb->data need to be wrapped inside of a get_unaligned(). Thanks to Gustavo Zacarias for the bug report. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-15[Bluetooth] Add locking for bt_proto array manipulationMarcel Holtmann
The bt_proto array needs to be protected by some kind of locking to prevent a race condition between bt_sock_create and bt_sock_register. And in addition all calls to sk_alloc need to be made GFP_ATOMIC now. Signed-off-by: Masatake YAMATO <jet@gyve.org> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-02-13[Bluetooth] Fix NULL pointer dereferences of the HCI socketMarcel Holtmann
This patch fixes the two NULL pointer dereferences found by the sfuzz tool from Ilja van Sprundel. The first one was a call of getsockname() for an unbound socket and the second was calling accept() while this operation isn't implemented for the HCI socket interface. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[Bluetooth]: Add endian annotations to the coreMarcel Holtmann
This patch adds the endian annotations to the Bluetooth core. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28[Bluetooth] Update security filter for Extended Inquiry ResponseMarcel Holtmann
This patch updates the HCI security filter with support for the Extended Inquiry Response (EIR) feature. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-08-29[NET]: Store skb->timestamp as offset to a base timestampPatrick McHardy
Reduces skb size by 8 bytes on 64-bit. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[Bluetooth]: Move packet type into the SKB control bufferMarcel Holtmann
This patch moves the usage of packet type into the SKB control buffer. After this patch it is now possible to shrink the sk_buff structure and redefine its pkt_type. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-25[PATCH] kill gratitious includes of major.h under net/*Al Viro
A lot of places in there are including major.h for no reason whatsoever. Removed. And yes, it still builds. The history of that stuff is often amusing. E.g. for net/core/sock.c the story looks so, as far as I've been able to reconstruct it: we used to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket", &net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of net/* had moved a lot of stuff from net/socket.c to net/core/sock.c, this crap had followed... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
