If we can't find a ACL link between the devices, we search
the connection list one second time looking for LE links.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Even for keys that shouldn't be stored some use cases require the
knowledge of a new key having been created so that the conclusion of a
successful pairing can be made. Therefore, always send the mgmt_new_key
event but add a store_hint parameter to it to indicate to user space
whether the key should be stored or not.
Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com>
User space shouldn't have any need for the old key type so remove it
from the corresponding Management interface event.
Link keys should only be stored if very specific criteria of the
authentication process are fulfilled. This patch essentially copies the
criteria that user space has so far been using to the kernel side so
that the management interface works properly.
When accepting a pairing request which fulfills the SSP auto-accept
criteria we need to push the request all the way to the user for
confirmation. This patch adds a new hint to the user_confirm_request
management event so user space can know when to show a numeric
comparison dialog and when to show a simple yes/no confirmation dialog.
Extend the mgmt_pin_code_request interface to require secure
pin code (16 digit) for authentication.
This is a kernel part of the secure pin code requirement notification
to user space agent.
Code styling fix by Johan Hedberg.
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
This patch adds a new event to the Management interface to track when
local adapters are discovering remote devices. For now this only tracks
BR/EDR discovery procedures.
Signed-off-by: Anderson Briglia <anderson.briglia@openbossa.org>
This patch adds start_discovery and stop_discovery commands to the
management interface. Right now their implementation is fairly
simplistic and the parameters are fixed to what user space has
defaulted to so far.
This is the very initial phase for discovery implementation into
the kernel. Next steps include name resolution, LE scanning and
bdaddr type handling.
The allocation in mgmt_control() code are in user context and not locked
by any spinlock, so it's not recommended the use of GFP_ATOMIC there.
spin_lock() and spin_unlock() are more apropiated for user context.
This patch adds a new remote_name event to the Management interface
which is sent every time the name of a remote device is resolved (over
BR/EDR).
This patch adds a device_found event to the Management interface. For
now the event only maps to BR/EDR inquiry result HCI events, but in the
future the plan is to also use it for the LE device discovery process.
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
The code was correctly calling _unlock at the end of the function but
there was no actual _lock call anywhere.
This patch adds automated creation of the local EIR data based on what
16-bit UUIDs are registered and what the device name is. This should
cover the majority use cases, however things like 32/128-bit UUIDs, TX
power and Device ID will need to be added later to be on par with what
bluetoothd is capable of doing (without the Management interface).
This patch adds commands to add and remove remote OOB data to the managment
interface. Remote data is stored in kernel and can be used by corresponding
HCI commands and events when needed.
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
This patch adds a command to read local OOB data to the managment interface.
The command maps directly to the Read Local OOB Data HCI command.
Since index is in mgmt_hdr it is possible to have mgmt command with
no parameters that still needs to add itself to pending list.
This field holds not whole command but only command specific
parameters.
This patch adds a new set_local_name management command as well as a
local_name_changed management event. With these user space can both
change the local name as well as monitor changes to it by others.
This patch adds the name of the adapter to the reply of the read_info
management command.
The management messages reserve 249 bytes for the name instead of 248
(like in the HCI spec) so that there is always a guarantee that it is
nul-terminated. That way it can safely be passed onto string
manipulation functions.
As written in the CodingStyle doc.
Command pointer was a leftover after moving controller index to
mgmt_hdr.
It is now possible to create command complete event without specific
reply data by passing NULL as reply with len 0. Check pointer before
calling memcpy to avoid undefined behaviour.
Use ERR_PTR mechanism to return error from hci_connect.
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
Crafted (too small) data buffer could result in reading data outside of buffer.
Validate buffer size and return EINVAL if size is wrong.
Acked-by: Johan Hedberg <johan.hedberg@nokia.com>
Most mgmt commands and event are related to hci adapter. Moving index to
common header allow to easily use it in command status while reporting errors.
For those not related to adapter use MGMT_INDEX_NONE (0xFFFF) as index.
The structure used for command was wrong (probably copy-paste mistake).
All of the places that need to call mgmt_pending_remove already have a
pointer to the pending command, so searching for the command in the list
doesn't make sense. The added benefit is that many places that
previously had to call list_del + mgmt_pending_free can just call
mgmt_pending_remove now.
To properly track bonding completion an event to indicate authentication
failure is needed. This event will be sent whenever an authentication
complete HCI event with a non-zero status comes. It will also be sent
when we're acting in acceptor role for SSP authentication in which case
the controller will send a Simple Pairing Complete event.
The command complete event for mgmt_pin_code_reply &
mgmt_pin_code_neg_reply should have the adapter index, Bluetooth address
as well as the status.
The opcode for the ENODEV case was wrong (probably copy-paste mistake).
This patch adds support for the user confirmation (numeric comparison)
Secure Simple Pairing authentication method.
This patch adds a new mgmt_pair_device which can be used to initiate a
dedicated bonding procedure. Some extra callbacks are added to the
hci_conn struct so that the pairing code can get notified of the
completion of the procedure.
This makes it more convenient to do manipulations on the entry (needed
by later commits).
As warned by checkpatch.pl, use #include <linux/uaccess.h> instead of
<asm/uaccess.h>.
This patch adds a new set_io_capability management command which is used
to set the IO capability for Secure Simple Pairing (SSP) as well as the
Security Manager Protocol (SMP). The value is per hci_dev and each
hci_conn object inherits it upon creation.
This patch adds the necessary commands and events needed to communicate
PIN code related actions between the kernel and userspace. This includes
a pin_code_request event as well as pin_code_reply and
pin_code_negative_reply commands.
A lot of management code needs to generate command complete events so it
makes sense to have a helper function for this.
This patch adds a get_connections command to the management interface.
With this command userspace can get the current list of connected
devices. Typically this command would only be used once when enumerating
existing adapters. After that the connected and disconnected events are
used to track connections.
This patch add a new connect failed management event to track failures
in connecting to remote devices. It is particularly useful for security
mode 3 scenarios when we don't have a connected state while pairing but
still need to detect when the connect attempt failed.
This patch adds a disconnect command to the managment interface. Using
this command user space is able to force the disconnection of connected
devices. The command maps directly to the Disconnect HCI command.
This patch adds connected and disconnected managment events to track the
connection status to remote devices. The events map directly to
successful connection complete and disconnection complete HCI events for
ACL links.
This patch adds a management commands to feed the kernel with all stored
link keys as well as remove specific ones or all of them. Once the
load_keys command has been called the kernel takes over link key
replies. A new_key event is also added to inform userspace of newly
created link keys that should be stored permanently.
This patch adds the possibility for user space to fully control the
Class of Device value of local adapters. To control the service class
bits each UUID that's added comes with a service class "hint" which acts
as a mask of bits that the UUID needs to have enabled. The
set_service_cache management command is used to make sure we queue up
all UUID changes as user space initializes its drivers and then send a
single HCI_Write_Class_of_Device command when initialization is
complete.
This patch adds methods to the management interface for userspace to
notify the kernel of which services have been registered for specific
adapters. This information is needed for setting the appropriate Class
of Device value as well as the Extended Inquiry Response value. This
patch doesn't actually implement setting of these values but just
provides the storage of the UUIDs so the needed functionality can be
built on top of it.
This patch implements a new set_pairable management command to control
the pairable state of local adapters. The state is represented using a
new HCI_PAIRABLE flag in the hci_dev struct.
For backwards compatibility with older user space versions the
HCI_PAIRABLE flag gets automatically set when the existence of an
adapter is reported to user space through legacy methods and the
HCI_MGMT flag is not set.
Several management commands have similar responses but they are not
always sent asynchronously. To enable synchronous sending (from the
managment command handler function) a send_mode_rsp function is added.
