There is an imbalance in the rfcomm_session_hold / rfcomm_session_put
operations which causes the following crash:
[ 685.010159] BUG: unable to handle kernel paging request at 6b6b6b6b
[ 685.010169] IP: [<c149d76d>] rfcomm_process_dlcs+0x1b/0x15e
[ 685.010181] *pdpt = 000000002d665001 *pde = 0000000000000000
[ 685.010191] Oops: 0000 [#1] PREEMPT SMP
[ 685.010247]
[ 685.010255] Pid: 947, comm: krfcommd Tainted: G C 3.0.16-mid8-dirty #44
[ 685.010266] EIP: 0060:[<c149d76d>] EFLAGS: 00010246 CPU: 1
[ 685.010274] EIP is at rfcomm_process_dlcs+0x1b/0x15e
[ 685.010281] EAX: e79f551c EBX: 6b6b6b6b ECX: 00000007 EDX: e79f40b4
[ 685.010288] ESI: e79f4060 EDI: ed4e1f70 EBP: ed4e1f68 ESP: ed4e1f50
[ 685.010295] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 685.010303] Process krfcommd (pid: 947, ti=ed4e0000 task=ed43e5e0 task.ti=ed4e0000)
[ 685.010308] Stack:
[ 685.010312] ed4e1f68 c149eb53 e5925150 e79f4060 ed500000 ed4e1f70 ed4e1f80 c149ec10
[ 685.010331] 00000000 ed43e5e0 00000000 ed4e1f90 ed4e1f9c c149ec87 0000bf54 00000000
[ 685.010348] 00000000 ee03bf54 c149ec37 ed4e1fe4 c104fe01 00000000 00000000 00000000
[ 685.010367] Call Trace:
[ 685.010376] [<c149eb53>] ? rfcomm_process_rx+0x6e/0x74
[ 685.010387] [<c149ec10>] rfcomm_process_sessions+0xb7/0xde
[ 685.010398] [<c149ec87>] rfcomm_run+0x50/0x6d
[ 685.010409] [<c149ec37>] ? rfcomm_process_sessions+0xde/0xde
[ 685.010419] [<c104fe01>] kthread+0x63/0x68
[ 685.010431] [<c104fd9e>] ? __init_kthread_worker+0x42/0x42
[ 685.010442] [<c14dae82>] kernel_thread_helper+0x6/0xd
This issue has been brought up earlier here:
https://lkml.org/lkml/2011/5/21/127
The issue appears to be the rfcomm_session_put in rfcomm_recv_ua. This
operation doesn't seem be to required as for the non-initiator case we
have the rfcomm_process_rx doing an explicit put and in the initiator
case the last dlc_unlink will drive the reference counter to 0.
There have been several attempts to fix these issue:
6c2718d Bluetooth: Do not call rfcomm_session_put() for RFCOMM UA on closed socket
683d949 Bluetooth: Never deallocate a session when some DLC points to it
but AFAICS they do not fix the issue just make it harder to reproduce.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Signed-off-by: Gopala Krishna Murala <gopala.krishna.murala@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
drivers/net/wireless/b43/dma.c
drivers/net/wireless/brcm80211/brcmfmac/dhd_linux.c
sock and sk were leftover from another change.
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
net/bluetooth/l2cap_core.c
Just two overlapping changes, one added an initialization of
a local variable, and another change added a new local variable.
RFCOMM needs a proper priority mechanism inside itself and not try to use
l2cap priority to fix its own problem.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
(Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false).
Cc: netdev@vger.kernel.org
When the last RFCOMM data channel is closed, a timer is normally set
up to disconnect the control channel at a later time. If the control
channel disconnect command is sent with the timer pending, the timer
needs to be cancelled.
If the timer is not cancelled in this situation, the reference
counting logic for the RFCOMM session does not work correctly when the
remote device closes the L2CAP connection. The session is freed at
the wrong time, leading to a kernel panic.
Signed-off-by: Mat Martineau <mathewm@codeaurora.org>
This was triggered by turning off encryption on ACL link when rfcomm
was using high security. rfcomm_security_cfm (which is called from rx
task) was closing DLC and this involves sending disconnect message
(and locking socket).
Move closing DLC to rfcomm_process_dlcs and only flag DLC for closure
in rfcomm_security_cfm.
BUG: sleeping function called from invalid context at net/core/sock.c:2032
in_atomic(): 1, irqs_disabled(): 0, pid: 1788, name: kworker/0:3
[<c0068a08>] (unwind_backtrace+0x0/0x108) from [<c05e25dc>] (dump_stack+0x20/0x24)
[<c05e25dc>] (dump_stack+0x20/0x24) from [<c0087ba8>] (__might_sleep+0x110/0x12c)
[<c0087ba8>] (__might_sleep+0x110/0x12c) from [<c04801d8>] (lock_sock_nested+0x2c/0x64)
[<c04801d8>] (lock_sock_nested+0x2c/0x64) from [<c05670c8>] (l2cap_sock_sendmsg+0x58/0xcc)
[<c05670c8>] (l2cap_sock_sendmsg+0x58/0xcc) from [<c047cf6c>] (sock_sendmsg+0xb0/0xd0)
[<c047cf6c>] (sock_sendmsg+0xb0/0xd0) from [<c047cfc8>] (kernel_sendmsg+0x3c/0x44)
[<c047cfc8>] (kernel_sendmsg+0x3c/0x44) from [<c056b0e8>] (rfcomm_send_frame+0x50/0x58)
[<c056b0e8>] (rfcomm_send_frame+0x50/0x58) from [<c056b168>] (rfcomm_send_disc+0x78/0x80)
[<c056b168>] (rfcomm_send_disc+0x78/0x80) from [<c056b9f4>] (__rfcomm_dlc_close+0x2d0/0x2fc)
[<c056b9f4>] (__rfcomm_dlc_close+0x2d0/0x2fc) from [<c056bbac>] (rfcomm_security_cfm+0x140/0x1e0)
[<c056bbac>] (rfcomm_security_cfm+0x140/0x1e0) from [<c0555ec0>] (hci_event_packet+0x1ce8/0x4d84)
[<c0555ec0>] (hci_event_packet+0x1ce8/0x4d84) from [<c0550380>] (hci_rx_task+0x1d0/0x2d0)
[<c0550380>] (hci_rx_task+0x1d0/0x2d0) from [<c009ee04>] (tasklet_action+0x138/0x1e4)
[<c009ee04>] (tasklet_action+0x138/0x1e4) from [<c009f21c>] (__do_softirq+0xcc/0x274)
[<c009f21c>] (__do_softirq+0xcc/0x274) from [<c009f6c0>] (do_softirq+0x60/0x6c)
[<c009f6c0>] (do_softirq+0x60/0x6c) from [<c009f794>] (local_bh_enable_ip+0xc8/0xd4)
[<c009f794>] (local_bh_enable_ip+0xc8/0xd4) from [<c05e5804>] (_raw_spin_unlock_bh+0x48/0x4c)
[<c05e5804>] (_raw_spin_unlock_bh+0x48/0x4c) from [<c040d470>] (data_from_chip+0xf4/0xaec)
[<c040d470>] (data_from_chip+0xf4/0xaec) from [<c04136c0>] (send_skb_to_core+0x40/0x178)
[<c04136c0>] (send_skb_to_core+0x40/0x178) from [<c04139f4>] (cg2900_hu_receive+0x15c/0x2d0)
[<c04139f4>] (cg2900_hu_receive+0x15c/0x2d0) from [<c0414cb8>] (hci_uart_tty_receive+0x74/0xa0)
[<c0414cb8>] (hci_uart_tty_receive+0x74/0xa0) from [<c02cbd9c>] (flush_to_ldisc+0x188/0x198)
[<c02cbd9c>] (flush_to_ldisc+0x188/0x198) from [<c00b2774>] (process_one_work+0x144/0x4b8)
[<c00b2774>] (process_one_work+0x144/0x4b8) from [<c00b2e8c>] (worker_thread+0x198/0x468)
[<c00b2e8c>] (worker_thread+0x198/0x468) from [<c00b9bc8>] (kthread+0x98/0xa0)
[<c00b9bc8>] (kthread+0x98/0xa0) from [<c0061744>] (kernel_thread_exit+0x0/0x8)
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
When all items in the list have the same type there is no much of a point
to use list_for_each except if you want to use the list pointer itself.
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth
Fragmented skbs are only encountered when receiving ERTM or streaming
mode L2CAP data. BNEP, CMTP, HIDP, and RFCOMM generally use basic
mode, but they need to handle fragments without crashing.
Removed superfluous event handling which was used to signal
that the rfcomm kthread had been woken. This appears to have been
used to prevent lost wakeups. Correctly ordering when the task
state is set to TASK_INTERRUPTIBLE is sufficient to prevent lost wakeups.
To prevent wakeups which occurred prior to initially setting
TASK_INTERRUPTIBLE from being lost, the main work of the thread loop -
rfcomm_process_sessions() - is performed prior to sleeping.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
In case of pre v2.1 devices authentication request will return
success immediately if the link key already exists without any
authentication process.
That means, it's not possible to re-authenticate the link if you
already have combination key and for instance want to re-authenticate
to get the high security (use 16 digit pin).
Therefore, it's necessary to check security requirements on auth
complete event to prevent not enough secure connection.
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
There is no need to the socket deal directly with the channel, most of the
time it cares about the channel only.
In this commit, omtu, imtu, flush_to, mode and sport. It also remove the
pi var from l2cap_sock_sendmsg().
In this commit all ERTM and Streaming Mode specific vars.
l2cap_load() was added to trigger l2cap.ko module loading from the RFCOMM
and BNEP modules. Now that L2CAP module is gone, we don't need it anymore.
Fix a bug introduced in commit 9cf5b0ea3a7f1432c61029f7aaf4b8b338628884:
function rfcomm_recv_ua calls rfcomm_session_put without checking that
the session is not referenced by some DLC. If the session is freed, that
DLC would refer to deallocated memory, causing an oops later, as shown
in this bug report: https://bugzilla.kernel.org/show_bug.cgi?id=15994
Signed-off-by: Lukas Turek <8an@praha12.net>
drivers/net/bnx2x/bnx2x.h
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/vhost/vhost.c
Due to commit 63ce0900 connections initiated through TTYs created with
"rfcomm bind ..." would have security level BT_SECURITY_SDP instead of
BT_SECURITY_LOW. This would cause instant connection failure between any
two SSP capable devices due to the L2CAP connect request to RFCOMM being
sent before authentication has been performed. This patch fixes the
regression by always initializing the DLC security level to
BT_SECURITY_LOW.
Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com>
Acked-by: Luiz Augusto von Dentz <luiz.dentz-von@nokia.com>
Remove extra spaces, assignments in if statement, zeroing static
variables, extra braces. Fix includes.
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
This cause 'No Bonding' to be used if userspace has not yet been paired
with remote device since the l2cap socket used to create the rfcomm
session does not have any security level set.
Signed-off-by: Luiz Augusto von Dentz <luiz.dentz-von@nokia.com>
Acked-by: Ville Tervo <ville.tervo@nokia.com>
Remove dead code and unused rfcomm thread events
According to the ETSI 3GPP TS 07.10 the default bit rate value for RFCOMM
is 9600 bit/s. Return this bit rate in case of RPN request and accept other
sane bit rates proposed by the sender in RPM command.
Signed-off-by: Yuri Kululin <ext-yuri.kululin@nokia.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Some of the debug files ended up wrongly in sysfs, because at that point
of time, debugfs didn't exist. Convert these files to use debugfs and
also seq_file. This patch converts all of these files at once and then
removes the exported symbol for the Bluetooth sysfs class.
When creating a high number of Bluetooth sockets (L2CAP, SCO
and RFCOMM) it is possible to scribble repeatedly on arbitrary
pages of memory. Ensure that the content of these sysfs files is
always less than one page. Even if this means truncating. The
files in question are scheduled to be moved over to debugfs in
the future anyway.
Based on initial patches from Neil Brown and Linus Torvalds
Reported-by: Neil Brown <neilb@suse.de>
Passing the attribute to the low level IO functions allows all kinds
of cleanups, by sharing low level IO code without requiring
an own function for every piece of data.
Also drivers can extend the attributes with own data fields
and use that in the low level function.
This makes the class attributes the same as sysdev_class attributes
and plain attributes.
This will allow further cleanups in drivers.
Full tree sweep converting all users.
When processing a RFCOMM UA frame when the socket is closed and we were
not the RFCOMM initiator would cause rfcomm_session_put() to be called
twice during rfcomm_process_rx(). This would cause a kernel panic in
rfcomm_session_close() then.
This could be easily reproduced during disconnect with devices such as
Motorola H270 that send RFCOMM UA followed quickly by L2CAP disconnect
request. This trace for this looks like:
2009-09-21 17:22:37.788895 < ACL data: handle 1 flags 0x02 dlen 8
L2CAP(d): cid 0x0041 len 4 [psm 3]
RFCOMM(s): DISC: cr 0 dlci 20 pf 1 ilen 0 fcs 0x7d
2009-09-21 17:22:37.906204 > HCI Event: Number of Completed Packets (0x13) plen 5
handle 1 packets 1
2009-09-21 17:22:37.933090 > ACL data: handle 1 flags 0x02 dlen 8
L2CAP(d): cid 0x0040 len 4 [psm 3]
RFCOMM(s): UA: cr 0 dlci 20 pf 1 ilen 0 fcs 0x57
2009-09-21 17:22:38.636764 < ACL data: handle 1 flags 0x02 dlen 8
RFCOMM(s): DISC: cr 0 dlci 0 pf 1 ilen 0 fcs 0x9c
2009-09-21 17:22:38.744125 > HCI Event: Number of Completed Packets (0x13) plen 5
handle 1 packets 1
2009-09-21 17:22:38.763687 > ACL data: handle 1 flags 0x02 dlen 8
RFCOMM(s): UA: cr 0 dlci 0 pf 1 ilen 0 fcs 0xb6
2009-09-21 17:22:38.783554 > ACL data: handle 1 flags 0x02 dlen 12
L2CAP(s): Disconn req: dcid 0x0040 scid 0x0041
Avoid calling rfcomm_session_put() twice by skipping this call
in rfcomm_recv_ua() if the socket is closed.
Signed-off-by: Nick Pelly <npelly@google.com>
With the commit 9e726b17422bade75fba94e625cd35fd1353e682 the
rfcomm_session_put() gets accidentially called from a timeout
callback and results in this:
BUG: sleeping function called from invalid context at net/core/sock.c:1897
in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper
Pid: 0, comm: swapper Tainted: P 2.6.32 #31
Call Trace:
<IRQ> [<ffffffff81036455>] __might_sleep+0xf8/0xfa
[<ffffffff8138ef1d>] lock_sock_nested+0x29/0xc4
[<ffffffffa03921b3>] lock_sock+0xb/0xd [l2cap]
[<ffffffffa03948e6>] l2cap_sock_shutdown+0x1c/0x76 [l2cap]
[<ffffffff8106adea>] ? clockevents_program_event+0x75/0x7e
[<ffffffff8106bea2>] ? tick_dev_program_event+0x37/0xa5
[<ffffffffa0394967>] l2cap_sock_release+0x27/0x67 [l2cap]
[<ffffffff8138c971>] sock_release+0x1a/0x67
[<ffffffffa03d2492>] rfcomm_session_del+0x34/0x53 [rfcomm]
[<ffffffffa03d24c5>] rfcomm_session_put+0x14/0x16 [rfcomm]
[<ffffffffa03d28b4>] rfcomm_session_timeout+0xe/0x1a [rfcomm]
[<ffffffff810554a8>] run_timer_softirq+0x1e2/0x29a
[<ffffffffa03d28a6>] ? rfcomm_session_timeout+0x0/0x1a [rfcomm]
[<ffffffff8104e0f6>] __do_softirq+0xfe/0x1c5
[<ffffffff8100e8ce>] ? timer_interrupt+0x1a/0x21
[<ffffffff8100cc4c>] call_softirq+0x1c/0x28
[<ffffffff8100e05b>] do_softirq+0x33/0x6b
[<ffffffff8104daf6>] irq_exit+0x36/0x85
[<ffffffff8100d7a9>] do_IRQ+0xa6/0xbd
[<ffffffff8100c493>] ret_from_intr+0x0/0xa
<EOI> [<ffffffff812585b3>] ? acpi_idle_enter_bm+0x269/0x294
[<ffffffff812585a9>] ? acpi_idle_enter_bm+0x25f/0x294
[<ffffffff81373ddc>] ? cpuidle_idle_call+0x97/0x107
[<ffffffff8100aca0>] ? cpu_idle+0x53/0xaa
[<ffffffff81429006>] ? rest_init+0x7a/0x7c
[<ffffffff8177bc8c>] ? start_kernel+0x389/0x394
[<ffffffff8177b29c>] ? x86_64_start_reservations+0xac/0xb0
[<ffffffff8177b384>] ? x86_64_start_kernel+0xe4/0xeb
To fix this, the rfcomm_session_put() needs to be moved out of
rfcomm_session_timeout() into rfcomm_process_sessions(). In that
context it is perfectly fine to sleep and disconnect the socket.
Tested-by: David John <davidjon@xenontk.org>
By default the RFCOMM layer would still use L2CAP basic mode. For testing
purposes this option enables RFCOMM to select enhanced retransmission
mode.
When using DEFER_SETUP on a RFCOMM socket, a SABM frame triggers
authorization which when rejected send a DM response. This is fine
according to the RFCOMM spec:
the responding implementation may replace the "proper" response
on the Multiplexer Control channel with a DM frame, sent on the
referenced DLCI to indicate that the DLCI is not open, and that
the responder would not grant a request to open it later either.
But some stacks doesn't seems to cope with this leaving DLCI 0 open after
receiving DM frame.
To fix it properly a timer was introduced to rfcomm_session which is used
to set a timeout when the last active DLC of a session is unlinked, this
will give the remote stack some time to reply with a proper DISC frame on
DLCI 0 avoiding both sides sending DISC to each other on stacks that
follow the specification and taking care of those who don't by taking
down DLCI 0.
Signed-off-by: Luiz Augusto von Dentz <luiz.dentz@openbossa.org>
The rfcomm_init bug fix went into the kernel premature before it got fully
reviewed and acknowledged by the Bluetooth maintainer. So fix up the coding
style now.
rfcomm tty may be used before rfcomm_tty_driver initilized,
The problem is that now socket layer init before tty layer, if userspace
program do socket callback right here then oops will happen.
reporting in:
http://marc.info/?l=linux-bluetooth&m=124404919324542&w=2
make 3 changes:
1. remove #ifdef in rfcomm/core.c,
make it blank function when rfcomm tty not selected in rfcomm.h
2. tune the rfcomm_init error patch to ensure
tty driver initilized before rfcomm socket usage.
3. remove __exit for rfcomm_cleanup_sockets
because above change need call it in a __init function.
Reported-by: Oliver Hartkopp <oliver@hartkopp.net>
Tested-by: Oliver Hartkopp <oliver@hartkopp.net>
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
The Bluetooth source uses some endian conversion helpers, that in the end
translate to kernel standard routines. So remove this obfuscation since it
is fully pointless.
There is a missing call to rfcomm_dlc_clear_timer in the case that
DEFER_SETUP is used and so the connection gets disconnected after the
timeout even if it was successfully accepted previously.
This patch adds a call to rfcomm_dlc_clear_timer to rfcomm_dlc_accept
which will get called when the user accepts the connection by calling
read() on the socket.
The CID value of L2CAP sockets need to be set to zero. All userspace
applications do this via memset() on the sockaddr_l2 structure. The
RFCOMM implementation uses in-kernel L2CAP sockets and so it has to
make sure that l2_cid is set to zero.
When BT_DEFER_SETUP is enabled on a RFCOMM socket, then switch its
current state from BT_OPEN to BT_CONNECT2. This gives the Bluetooth
core a unified way to handle L2CAP and RFCOMM sockets. The BT_CONNECT2
state is designated for incoming connections.
When receiving incoming connection to specific services, always use
general bonding. This ensures that the link key gets stored and can be
used for further authentications.
During a role change with pre-Bluetooth 2.1 devices, the remote side drops
the encryption of the RFCOMM connection. We allow a grace period for the
encryption to be re-established, before dropping the connection. During
this grace period, the RFCOMM_SEC_PENDING flag is set. Check this flag
before sending RFCOMM packets.
Signed-off-by: Jaikumar Ganesh <jaikumar@google.com>
With the support for the enhanced security model and the support for
deferring connection setup, it is a good idea to increase various
version numbers.
This is purely cosmetic and has no effect on the behavior, but can
be really helpful when debugging problems in different kernel versions.
A role switch with devices following the Bluetooth pre-2.1 standards
or without Encryption Pause and Resume support is not possible if
encryption is enabled. Most newer headsets require the role switch,
but also require that the connection is encrypted.
For connections with a high security mode setting, the link will be
immediately dropped. When the connection uses medium security mode
setting, then a grace period is introduced where the TX is halted and
the remote device gets a change to re-enable encryption after the
role switch. If not re-enabled the link will be dropped.
Based on initial work by Ville Tervo <ville.tervo@nokia.com>
Change the RFCOMM internals to use the new security levels and remove
the link mode details.
The current security model is based around the flags AUTH, ENCRYPT and
SECURE. Starting with support for the Bluetooth 2.1 specification this is
no longer sufficient. The different security levels are now defined as
SDP, LOW, MEDIUM and SECURE.
Previously it was possible to set each security independently, but this
actually doesn't make a lot of sense. For Bluetooth the encryption depends
on a previous successful authentication. Also you can only update your
existing link key if you successfully created at least one before. And of
course the update of link keys without having proper encryption in place
is a security issue.
The new security levels from the Bluetooth 2.1 specification are now
used internally. All old settings are mapped to the new values and this
way it ensures that old applications still work. The only limitation
is that it is no longer possible to set authentication without also
enabling encryption. No application should have done this anyway since
this is actually a security issue. Without encryption the integrity of
the authentication can't be guaranteed.
As default for a new L2CAP or RFCOMM connection, the LOW security level
is used. The only exception here are the service discovery sessions on
PSM 1 where SDP level is used. To have similar security strength as with
a Bluetooth 2.0 and before combination key, the MEDIUM level should be
used. This is according to the Bluetooth specification. The MEDIUM level
will not require any kind of man-in-the-middle (MITM) protection. Only
the HIGH security level will require this.
In order to decide if listening RFCOMM sockets should be accept()ed
the BD_ADDR of the remote device needs to be known. This patch adds
a socket option which defines a timeout for deferring the actual
connection setup.
The connection setup is done after reading from the socket for the
first time. Until then writing to the socket returns ENOTCONN.
