This picks up all of the different fixes in Linus's tree that we also need here.
The RFCOMM code fails to initialize the two padding bytes of struct
rfcomm_dev_list_req inserted for alignment before copying it to
userland. Additionally there are two padding bytes in each instance of
struct rfcomm_dev_info. The ioctl() that for disclosures two bytes plus
dev_num times two bytes uninitialized kernel heap memory.
Allocate the memory using kzalloc() to fix this issue.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Currently we have no way to assign tty->port while performing tty
installation. There are two ways to provide the link tty_struct =>
tty_port. Either by calling tty_port_install from tty->ops->install or
tty_port_register_device called instead of tty_register_device when
the device is being set up after connected.
In this patch we modify most of the drivers to do the latter. When the
drivers use tty_register_device and we have tty_port already, we
switch to tty_port_register_device. So we have the tty_struct =>
tty_port link for free for those.
Acked-by: Alan Cox <alan@linux.intel.com>
The termios and other changes mean the other protections needed on the driver
tty arrays should be adequate. Turn it all back on.
This contains pieces folded in from the fixes made to the original patches
| From: Geert Uytterhoeven <geert@linux-m68k.org> (fix m68k)
| From: Paul Gortmaker <paul.gortmaker@windriver.com> (fix cris)
| From: Eric Dumazet <eric.dumazet@gmail.com> (lockdep)
Signed-off-by: Alan Cox <alan@linux.intel.com>
This handles the merge issue in:
arch/um/drivers/line.c
arch/um/drivers/line.h
And resolves the duplicate patches that were in both trees do to the
tty-next branch not getting merged into 3.6-rc1.
This will let us sort out a whole pile of tty related races. The
alternative would be to keep points and refcount the termios objects.
However
1. They are tiny anyway
2. Many devices don't use the stored copies
3. We can remove a pty special case
I sent GregKH this after the pre-requisites. He dropped the pre-requesites
for good reason and unfortunately then applied this patch. Without this
reverted you get random kernel memory corruption which will make bisecting
anything between it and the properly applied patches a complete sod.
Most of the include were unnecessary or already included by some other
header.
Replace module.h by export.h where possible.
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Only obvious cases were left as inline, mostly oneline functions.
This reverts the tty layer change to use per-tty locking, because it's
not correct yet, and fixing it will require some more deep surgery.
The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but
there are several smaller commits that built upon it, they also get
reverted here. The list of reverted commits is:
fde86d310886 - tty: add lockdep annotations
8f6576ad476b - tty: fix ldisc lock inversion trace
d3ca8b64b97e - pty: Fix lock inversion
b1d679afd766 - tty: drop the pty lock during hangup
abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock()
fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call
d29f3ef39be4 - tty_lock: Localise the lock
The revert had a trivial conflict in the 68360serial.c staging driver
that got removed in the meantime.
In each remaining case the tty_lock is associated with a specific tty. This
means we can now lock on a per tty basis. We do need tty_lock_pair() for
the pty case. Uglier but still a step in the right direction.
[fixed up calls in 3 missing drivers - gregkh]
This means converting an atomic counter to a counter protected by
lock. This is the first step needed to convert the rest of the code to
the tty_port helpers.
tty_wakeup is safe to be called from all contexts. No need to schedule
a work for that. Let us call it directly like in other drivers.
This allows us to kill another member of rfcomm_dev structure.
Switch the refcounting from manual atomic plays with refcounter to the
one offered by tty_port.
And use tty from there.
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
+ src/net/bluetooth/rfcomm/tty.c: warning: 'p' is used uninitialized in this
function: => 218
+ src/net/bluetooth/rfcomm/tty.c: warning: 'p' may be used uninitialized in
this function: => 218
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
We now run in process context, no need to disable interrupts.
Calls from the tty layer also run in process context.
rw_lock was converted to spinlock, we have more writers than readers in
this case.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
When all items in the list have the same type there is no much of a point
to use list_for_each except if you want to use the list pointer itself.
Remove old tasklets and replace by workqueue. To avoid reentrancy (which
tasklets always avoid) we use the system_nrt_wq.
Signed-off-by: David Herrmann <dh.herrmann@googlemail.com>
Forward error codes from tty core to the rfcomm_init caller instead of using
generic -1 errors.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits)
pch_uart: reference clock on CM-iTC
pch_phub: add new device ML7213
n_gsm: fix UIH control byte : P bit should be 0
n_gsm: add a documentation
serial: msm_serial_hs: Add MSM high speed UART driver
tty_audit: fix tty_audit_add_data live lock on audit disabled
tty: move cd1865.h to drivers/staging/tty/
Staging: tty: fix build with epca.c driver
pcmcia: synclink_cs: fix prototype for mgslpc_ioctl()
Staging: generic_serial: fix double locking bug
nozomi: don't use flush_scheduled_work()
tty/serial: Relax the device_type restriction from of_serial
MAINTAINERS: Update HVC file patterns
tty: phase out of ioctl file pointer for tty3270 as well
tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile
pch_uart: Fix DMA channel miss-setting issue.
pch_uart: fix exclusive access issue
pch_uart: fix auto flow control miss-setting issue
pch_uart: fix uart clock setting issue
pch_uart : Use dev_xxx not pr_xxx
Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied
twice, then changes to the same area in one branch)
Only oddities here are a couple of drivers that bogusly called the ldisc
helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes
away.
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
Signed-off-by: Vladislav P <vladisslav@inbox.ru>
Remove extra spaces, assignments in if statement, zeroing static
variables, extra braces. Fix includes.
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
Again basically cut and paste
Convert the main driver set to use the hooks for GICOUNT
The Bluetooth core uses the the BD_ADDR in the opposite order from the
human readable order. So we are changing batostr() to print in the
correct order and then removing some baswap(), as they are not needed
anymore.
rfcomm_cleanup_ttys() is also called from rfcomm_init(), so it can't
have __exit.
Reported-by: Mat Martineau <mathewm@codeaurora.org>
Those annotation save memory and space on the binary. __init code is
discarded just after execute and __exit code is discarded if the module
is built into the kernel image or unload of modules is not allowed.
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
struct tty_operations::proc_fops took it's place and there is one less
create_proc_read_entry() user now!
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
dpm_list currently relies on the fact that child devices will
be registered after their parents to get a correct suspend
order. Using device_move() however destroys this assumption, as
an already registered device may be moved under a newly registered
one.
This patch adds a new argument to device_move(), allowing callers
to specify how dpm_list should be adapted.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
It turns out that the following sequence of actions will reproduce the
oops:
1. Create a new RFCOMM device (using RFCOMMCREATEDEV ioctl)
2. (Try to) open the device
3. Release the RFCOMM device (using RFCOMMRELEASEDEV ioctl)
At this point, the "/dev/rfcomm*" device is still in use, but it is gone
from the internal list, so the device id can be reused.
4. Create a new RFCOMM device with the same device id as before
And now kobject will complain that the TTY already exists.
(See http://lkml.org/lkml/2008/7/13/89 for a reproducible test-case.)
This patch attempts to correct this by only removing the device from the
internal list of devices at the final unregister stage, so that the id
won't get reused until the device has been completely destructed.
This should be safe as the RFCOMM_TTY_RELEASED bit will be set for the
device and prevent the device from being reopened after it has been
released.
Based on a report from Vegard Nossum <vegard.nossum@gmail.com>
With the introduction of CONFIG_DYNAMIC_PRINTK_DEBUG it is possible to
allow debugging without having to recompile the kernel. This patch turns
all BT_DBG() calls into pr_debug() to support dynamic debug messages.
As a side effect all CONFIG_BT_*_DEBUG statements are now removed and
some broken debug entries have been fixed.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (1232 commits)
iucv: Fix bad merging.
net_sched: Add size table for qdiscs
net_sched: Add accessor function for packet length for qdiscs
net_sched: Add qdisc_enqueue wrapper
highmem: Export totalhigh_pages.
ipv6 mcast: Omit redundant address family checks in ip6_mc_source().
net: Use standard structures for generic socket address structures.
ipv6 netns: Make several "global" sysctl variables namespace aware.
netns: Use net_eq() to compare net-namespaces for optimization.
ipv6: remove unused macros from net/ipv6.h
ipv6: remove unused parameter from ip6_ra_control
tcp: fix kernel panic with listening_get_next
tcp: Remove redundant checks when setting eff_sacks
tcp: options clean up
tcp: Fix MD5 signatures for non-linear skbs
sctp: Update sctp global memory limit allocations.
sctp: remove unnecessary byteshifting, calculate directly in big-endian
sctp: Allow only 1 listening socket with SO_REUSEADDR
sctp: Do not leak memory on multiple listen() calls
sctp: Support ipv6only AF_INET6 sockets.
Move the line disciplines towards a conventional ->ops arrangement. For
the moment the actual 'tty_ldisc' struct in the tty is kept as part of
the tty struct but this can then be changed if it turns out that when it
all settles down we want to refcount ldiscs separately to the tty.
Pull the ldisc code out of /proc and put it with our ldisc code.
Signed-off-by: Alan Cox <alan@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6
When an incoming RFCOMM socket connection gets converted into a TTY,
it can happen that packets are lost. This mainly happens with the
Handsfree profile where the remote side starts sending data right
away. The problem is that these packets are in the socket receive
queue. So when creating the TTY make sure to copy all pending packets
from the socket receive queue to a private queue inside the TTY.
To make this actually work, the flow control on the newly created TTY
will be disabled and only enabled again when the TTY is opened by an
application. And right before that, the pending packets will be put
into the TTY flip buffer.
Signed-off-by: Denis Kenzior <denis.kenzior@trolltech.com>
When switching a RFCOMM socket to a TTY, the remote modem status might
be needed later. Currently it is lost since the original configuration
is done via the socket interface. So store the modem status and reply
it when the socket has been converted to a TTY.
While the RFCOMM TTY emulation can act like a real serial port, in
reality it is not used like this. So to not mess up stupid applications,
use the non-canonical mode by default.
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
There's logic in __rfcomm_dlc_close:
rfcomm_dlc_lock(d);
d->state = BT_CLOSED;
d->state_changed(d, err);
rfcomm_dlc_unlock(d);
In rfcomm_dev_state_change, it's possible that rfcomm_dev_put try to
take the dlc lock, then we will deadlock.
Here fixed it by unlock dlc before rfcomm_dev_get in
rfcomm_dev_state_change.
why not unlock just before rfcomm_dev_put? it's because there's
another problem. rfcomm_dev_get/rfcomm_dev_del will take
rfcomm_dev_lock, but in rfcomm_dev_add the lock order is :
rfcomm_dev_lock --> dlc lock
so I unlock dlc before the taken of rfcomm_dev_lock.
Actually it's a regression caused by commit
1905f6c736cb618e07eca0c96e60e3c024023428 ("bluetooth :
__rfcomm_dlc_close lock fix"), the dlc state_change could be two
callbacks : rfcomm_sk_state_change and rfcomm_dev_state_change. I
missed the rfcomm_sk_state_change that time.
Thanks Arjan van de Ven <arjan@linux.intel.com> for the effort in
commit 4c8411f8c115def968820a4df6658ccfd55d7f1a ("bluetooth: fix
locking bug in the rfcomm socket cleanup handling") but he missed the
rfcomm_dev_state_change lock issue.
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Lockdep warning will be trigged while rfcomm connection closing.
The locks taken in rfcomm_dev_add:
rfcomm_dev_lock --> d->lock
In __rfcomm_dlc_close:
d->lock --> rfcomm_dev_lock (in rfcomm_dev_state_change)
There's two way to fix it, one is in rfcomm_dev_add we first locking
d->lock then the rfcomm_dev_lock
The other (in this patch), remove the locking of d->lock for
rfcomm_dev_state_change because just locking "d->state = BT_CLOSED;"
is enough.
[ 295.002046] =======================================================
[ 295.002046] [ INFO: possible circular locking dependency detected ]
[ 295.002046] 2.6.25-rc7 #1
[ 295.002046] -------------------------------------------------------
[ 295.002046] krfcommd/2705 is trying to acquire lock:
[ 295.002046] (rfcomm_dev_lock){-.--}, at: [<f89a090a>] rfcomm_dev_state_change+0x6a/0xd0 [rfcomm]
[ 295.002046]
[ 295.002046] but task is already holding lock:
[ 295.002046] (&d->lock){--..}, at: [<f899c533>] __rfcomm_dlc_close+0x43/0xd0 [rfcomm]
[ 295.002046]
[ 295.002046] which lock already depends on the new lock.
[ 295.002046]
[ 295.002046]
[ 295.002046] the existing dependency chain (in reverse order) is:
[ 295.002046]
[ 295.002046] -> #1 (&d->lock){--..}:
[ 295.002046] [<c0149b23>] check_prev_add+0xd3/0x200
[ 295.002046] [<c0149ce5>] check_prevs_add+0x95/0xe0
[ 295.002046] [<c0149f6f>] validate_chain+0x23f/0x320
[ 295.002046] [<c014b7b1>] __lock_acquire+0x1c1/0x760
[ 295.002046] [<c014c349>] lock_acquire+0x79/0xb0
[ 295.002046] [<c03d6b99>] _spin_lock+0x39/0x80
[ 295.002046] [<f89a01c0>] rfcomm_dev_add+0x240/0x360 [rfcomm]
[ 295.002046] [<f89a047e>] rfcomm_create_dev+0x6e/0xe0 [rfcomm]
[ 295.002046] [<f89a0823>] rfcomm_dev_ioctl+0x33/0x60 [rfcomm]
[ 295.002046] [<f899facc>] rfcomm_sock_ioctl+0x2c/0x50 [rfcomm]
[ 295.002046] [<c0363d38>] sock_ioctl+0x118/0x240
[ 295.002046] [<c0194196>] vfs_ioctl+0x76/0x90
[ 295.002046] [<c0194446>] do_vfs_ioctl+0x56/0x140
[ 295.002046] [<c0194569>] sys_ioctl+0x39/0x60
[ 295.002046] [<c0104faa>] syscall_call+0x7/0xb
[ 295.002046] [<ffffffff>] 0xffffffff
[ 295.002046]
[ 295.002046] -> #0 (rfcomm_dev_lock){-.--}:
[ 295.002046] [<c0149a84>] check_prev_add+0x34/0x200
[ 295.002046] [<c03d6639>] _read_lock+0x39/0x80
[ 295.002046] [<f89a090a>] rfcomm_dev_state_change+0x6a/0xd0 [rfcomm]
[ 295.002046] [<f899c548>] __rfcomm_dlc_close+0x58/0xd0 [rfcomm]
[ 295.002046] [<f899d44f>] rfcomm_recv_ua+0x6f/0x120 [rfcomm]
[ 295.002046] [<f899e061>] rfcomm_recv_frame+0x171/0x1e0 [rfcomm]
[ 295.002046] [<f899e357>] rfcomm_run+0xe7/0x550 [rfcomm]
[ 295.002046] [<c013c18c>] kthread+0x5c/0xa0
[ 295.002046] [<c0105c07>] kernel_thread_helper+0x7/0x10
[ 295.002046]
[ 295.002046] other info that might help us debug this:
[ 295.002046]
[ 295.002046] 2 locks held by krfcommd/2705:
[ 295.002046] #0: (rfcomm_mutex){--..}, at: [<f899e2eb>] rfcomm_run+0x7b/0x550 [rfcomm]
[ 295.002046] #1: (&d->lock){--..}, at: [<f899c533>] __rfcomm_dlc_close+0x43/0xd0 [rfcomm]
[ 295.002046]
[ 295.002046] stack backtrace:
[ 295.002046] Pid: 2705, comm: krfcommd Not tainted 2.6.25-rc7 #1
[ 295.002046] [<c0128a38>] ? printk+0x18/0x20
[ 295.002046] [<c014927f>] print_circular_bug_tail+0x6f/0x80
[ 295.002046] [<f89a090a>] ? rfcomm_dev_state_change+0x6a/0xd0 [rfcomm]
[ 295.002046] [<c014abd9>] ? trace_hardirqs_on+0xb9/0x130
[ 295.002046] [<c03d6e89>] ? _spin_unlock_irqrestore+0x39/0x70
[ 295.002046] [<c03d4559>] ? __sched_text_start+0x229/0x4c0
[ 295.002046] [<c0120000>] ? cpu_avg_load_per_task+0x20/0x30
[ 295.002046] [<f899e270>] ? rfcomm_run+0x0/0x550 [rfcomm]
[ 295.002046] [<c013c130>] ? kthread+0x0/0xa0
rfcomm dev could be deleted in tty_hangup, so we must not call
rfcomm_dev_del again to prevent from destroying rfcomm dev before tty
close.
