path: root/net/bluetooth
2010-04-27bluetooth: handle l2cap_create_connless_pdu() errorsDan Carpenter
l2cap_create_connless_pdu() can sometimes return ERR_PTR(-ENOMEM) or ERR_PTR(-EFAULT). Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits) smc91c92_cs: fix the problem of "Unable to find hardware address" r8169: clean up my printk uglyness net: Hook up cxgb4 to Kconfig and Makefile cxgb4: Add main driver file and driver Makefile cxgb4: Add remaining driver headers and L2T management cxgb4: Add packet queues and packet DMA code cxgb4: Add HW and FW support code cxgb4: Add register, message, and FW definitions netlabel: Fix several rcu_dereference() calls used without RCU read locks bonding: fix potential deadlock in bond_uninit() net: check the length of the socket address passed to connect(2) stmmac: add documentation for the driver. stmmac: fix kconfig for crc32 build error be2net: fix bug in vlan rx path for big endian architecture be2net: fix flashing on big endian architectures be2net: fix a bug in flashing the redboot section bonding: bond_xmit_roundrobin() fix drivers/net: Add missing unlock net: gianfar - align BD ring size console messages net: gianfar - initialize per-queue statistics ...
2010-04-01net: check the length of the socket address passed to connect(2)Changli Gao
check the length of the socket address passed to connect(2). Check the length of the socket address passed to connect(2). If the length is invalid, -EINVAL will be returned. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- net/bluetooth/l2cap.c | 3 ++- net/bluetooth/rfcomm/sock.c | 3 ++- net/bluetooth/sco.c | 3 ++- net/can/bcm.c | 3 +++ net/ieee802154/af_ieee802154.c | 3 +++ net/ipv4/af_inet.c | 5 +++++ net/netlink/af_netlink.c | 3 +++ 7 files changed, 20 insertions(+), 3 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-21Bluetooth: Fix kernel crash on L2CAP stress testsAndrei Emeltchenko
Added very simple check that req buffer has enough space to fit configuration parameters. Shall be enough to reject packets with configuration size more than req buffer. Crash trace below [ 6069.659393] Unable to handle kernel paging request at virtual address 02000205 [ 6069.673034] Internal error: Oops: 805 [#1] PREEMPT ... [ 6069.727172] PC is at l2cap_add_conf_opt+0x70/0xf0 [l2cap] [ 6069.732604] LR is at l2cap_recv_frame+0x1350/0x2e78 [l2cap] ... [ 6070.030303] Backtrace: [ 6070.032806] [<bf1c2880>] (l2cap_add_conf_opt+0x0/0xf0 [l2cap]) from [<bf1c6624>] (l2cap_recv_frame+0x1350/0x2e78 [l2cap]) [ 6070.043823] r8:dc5d3100 r7:df2a91d6 r6:00000001 r5:df2a8000 r4:00000200 [ 6070.050659] [<bf1c52d4>] (l2cap_recv_frame+0x0/0x2e78 [l2cap]) from [<bf1c8408>] (l2cap_recv_acldata+0x2bc/0x350 [l2cap]) [ 6070.061798] [<bf1c814c>] (l2cap_recv_acldata+0x0/0x350 [l2cap]) from [<bf0037a4>] (hci_rx_task+0x244/0x478 [bluetooth]) [ 6070.072631] r6:dc647700 r5:00000001 r4:df2ab740 [ 6070.077362] [<bf003560>] (hci_rx_task+0x0/0x478 [bluetooth]) from [<c006b9fc>] (tasklet_action+0x78/0xd8) [ 6070.087005] [<c006b984>] (tasklet_action+0x0/0xd8) from [<c006c160>] Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Acked-by: Gustavo F. Padovan <gustavo@padovan.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-03-21Bluetooth: Convert debug files to actually use debugfs instead of sysfsMarcel Holtmann
Some of the debug files ended up wrongly in sysfs, because at that point of time, debugfs didn't exist. Convert these files to use debugfs and also seq_file. This patch converts all of these files at once and then removes the exported symbol for the Bluetooth sysfs class. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-03-21Bluetooth: Fix potential bad memory access with sysfs filesMarcel Holtmann
When creating a high number of Bluetooth sockets (L2CAP, SCO and RFCOMM) it is possible to scribble repeatedly on arbitrary pages of memory. Ensure that the content of these sysfs files is always less than one page. Even if this means truncating. The files in question are scheduled to be moved over to debugfs in the future anyway. Based on initial patches from Neil Brown and Linus Torvalds Reported-by: Neil Brown <neilb@suse.de> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits) bridge: ensure to unlock in error path in br_multicast_query(). drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages sky2: Avoid rtnl_unlock without rtnl_lock ipv6: Send netlink notification when DAD fails drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant ipconfig: Handle devices which take some time to come up. mac80211: Fix memory leak in ieee80211_if_write() mac80211: Fix (dynamic) power save entry ipw2200: use kmalloc for large local variables ath5k: read eeprom IQ calibration values correctly for G mode ath5k: fix I/Q calibration (for real) ath5k: fix TSF reset ath5k: use fixed antenna for tx descriptors libipw: split ieee->networks into small pieces mac80211: Fix sta_mtx unlocking on insert STA failure path rt2x00: remove KSEG1ADDR define from rt2x00soc.h net: add ColdFire support to the smc91x driver asix: fix setting mac address for AX88772 ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}. net: Fix dev_mc_add() ...
2010-03-07driver-core: Add attribute argument to class_attribute show/storeAndi Kleen
Passing the attribute to the low level IO functions allows all kinds of cleanups, by sharing low level IO code without requiring an own function for every piece of data. Also drivers can extend the attributes with own data fields and use that in the low level function. This makes the class attributes the same as sysdev_class attributes and plain attributes. This will allow further cleanups in drivers. Full tree sweep converting all users. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-03Bluetooth: Use single_open() for inquiry cache within debugfsMarcel Holtmann
The inquiry cache information in debugfs should be using seq_file support and not allocating memory on the stack for the string. Since the usage of these information is really seldom, using single_open() for it is good enough. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/firmware/iscsi_ibft.c
2010-02-28Bluetooth: Fix out of scope variable access in hci_sock_cmsg()Johann Felix Soden
The pointer data can point to the variable ctv. Access to data happens when ctv is already out of scope. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-27Bluetooth: Add SCO fallback for unsupported feature errorStephen Coe
The Bluetooth SIG PTS test case: TC_AG_ACS_BV_10_I, rejects eSCO with "Unsupported Feature or Parameter Value" (0x11). This patch adds case for SCO fallback. 2007-09-20 12:20:37.787747 > HCI Event: Number of Completed Packets (0x13) plen 5 handle 38 packets 1 2007-09-20 12:20:37.842154 < HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17 handle 38 voice setting 0x0060 2007-09-20 12:20:37.847037 > HCI Event: Command Status (0x0f) plen 4 Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1 2007-09-20 12:20:37.855233 > HCI Event: Max Slots Change (0x1b) plen 3 handle 38 slots 1 2007-09-20 12:20:39.913354 > HCI Event: Synchronous Connect Complete (0x2c) plen 17 status 0x11 handle 38 bdaddr 00:16:93:01:01:7A type eSCO Error: Unsupported Feature or Parameter Value 2007-09-20 12:20:39.922629 > HCI Event: Max Slots Change (0x1b) plen 3 handle 38 slots 5 2007-09-20 12:20:58.126886 < ACL data: handle 38 flags 0x02 dlen 8 L2CAP(d): cid 0x0041 len 4 [psm 0] 0000: 0b 53 01 b8 .S.. 2007-09-20 12:20:58.130138 > HCI Event: Number of Completed Packets (0x13) plen 5 handle 38 packets 1 Signed-off-by: Stephen Coe <smcoe1@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-27Bluetooth: Add controller types for BR/EDR and 802.11 AMPMarcel Holtmann
With the Bluetooth 3.0 specification and the introduction of alternate MAC/PHY (AMP) support, it is required to differentiate between primary BR/EDR controllers and 802.11 AMP controllers. So introduce a special type inside HCI device for differentiation. For now all AMP controllers will be treated as raw devices until an AMP manager has been implemented. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-27Bluetooth: Convert inquiry cache to use debugfs instead of sysfsMarcel Holtmann
The output of the inquiry cache is only useful for debugging purposes and so move it into debugfs. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-27Bluetooth: Convert controller hdev->type to hdev->busMarcel Holtmann
The hdev->type is misnamed and should be actually hdev->bus instead. So convert it now. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (41 commits) HID: usbhid: initialize interface pointers early enough HID: extend mask for BUTTON usage page HID: hid-ntrig: Single touch mode tap HID: hid-ntrig: multitouch cleanup and fix HID: n-trig: remove unnecessary tool switching HID: hid-ntrig add multi input quirk and clean up HID: usbhid: introduce timeout for stuck ctrl/out URBs HID: magicmouse: coding style and probe failure fixes HID: remove MODULE_VERSION from new drivers HID: fix up Kconfig entry for MagicMouse HID: add a device driver for the Apple Magic Mouse. HID: Export hid_register_report HID: Support for MosArt multitouch panel HID: add pressure support for the Stantum multitouch panel HID: fixed bug in single-touch emulation on the stantum panel HID: fix typo in error message HID: add mapping for "AL Network Chat" usage HID: use multi input quirk for TouchPack touchscreen HID: make full-fledged hid-bus drivers properly selectable HID: make Wacom modesetting failures non-fatal ...
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09Merge branch 'master' of ↵David S. Miller
2010-02-05Bluetooth: Keep a copy of each HID device's report descriptorMichael Poole
The report descriptor is read by user space (via the Service Discovery Protocol), so it is only available during the ioctl to connect. However, the HID probe function that needs the descriptor might not be called until a specific module is loaded. Keep a copy of the descriptor so it is available for later use. Signed-off-by: Michael Poole <mdpoole@troilus.org> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-03Merge branch 'master' of ↵David S. Miller
2010-02-03Bluetooth: Enter active mode before establishing a SCO link.Nick Pelly
When in sniff mode with a long interval time (1.28s) it can take 4+ seconds to establish a SCO link. Fix by requesting active mode before requesting SCO connection. This improves SCO setup time to ~500ms. Bluetooth headsets that use a long interval time, and exhibit the long SCO connection time include Motorola H790, HX1 and H17. They have a CSR 2.1 chipset. Verified this behavior and fix with host Bluetooth chipsets: BCM4329 and TI1271. 2009-10-13 14:17:46.183722 > HCI Event: Mode Change (0x14) plen 6 status 0x00 handle 1 mode 0x02 interval 2048 Mode: Sniff 2009-10-13 14:17:53.436285 < HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17 handle 1 voice setting 0x0060 2009-10-13 14:17:53.445593 > HCI Event: Command Status (0x0f) plen 4 Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1 2009-10-13 14:17:57.788855 > HCI Event: Synchronous Connect Complete 0x2c) plen 17 status 0x00 handle 257 bdaddr 00:1A:0E:F1:A4:7F type eSCO Air mode: CVSD Signed-off-by: Nick Pelly <npelly@google.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-03Bluetooth: Do not call rfcomm_session_put() for RFCOMM UA on closed socketNick Pelly
When processing a RFCOMM UA frame when the socket is closed and we were not the RFCOMM initiator would cause rfcomm_session_put() to be called twice during rfcomm_process_rx(). This would cause a kernel panic in rfcomm_session_close() then. This could be easily reproduced during disconnect with devices such as Motorola H270 that send RFCOMM UA followed quickly by L2CAP disconnect request. This trace for this looks like: 2009-09-21 17:22:37.788895 < ACL data: handle 1 flags 0x02 dlen 8 L2CAP(d): cid 0x0041 len 4 [psm 3] RFCOMM(s): DISC: cr 0 dlci 20 pf 1 ilen 0 fcs 0x7d 2009-09-21 17:22:37.906204 > HCI Event: Number of Completed Packets (0x13) plen 5 handle 1 packets 1 2009-09-21 17:22:37.933090 > ACL data: handle 1 flags 0x02 dlen 8 L2CAP(d): cid 0x0040 len 4 [psm 3] RFCOMM(s): UA: cr 0 dlci 20 pf 1 ilen 0 fcs 0x57 2009-09-21 17:22:38.636764 < ACL data: handle 1 flags 0x02 dlen 8 L2CAP(d): cid 0x0041 len 4 [psm 3] RFCOMM(s): DISC: cr 0 dlci 0 pf 1 ilen 0 fcs 0x9c 2009-09-21 17:22:38.744125 > HCI Event: Number of Completed Packets (0x13) plen 5 handle 1 packets 1 2009-09-21 17:22:38.763687 > ACL data: handle 1 flags 0x02 dlen 8 L2CAP(d): cid 0x0040 len 4 [psm 3] RFCOMM(s): UA: cr 0 dlci 0 pf 1 ilen 0 fcs 0xb6 2009-09-21 17:22:38.783554 > ACL data: handle 1 flags 0x02 dlen 12 L2CAP(s): Disconn req: dcid 0x0040 scid 0x0041 Avoid calling rfcomm_session_put() twice by skipping this call in rfcomm_recv_ua() if the socket is closed. Signed-off-by: Nick Pelly <npelly@google.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-03Bluetooth: Fix sleeping function in RFCOMM within invalid contextMarcel Holtmann
With the commit 9e726b17422bade75fba94e625cd35fd1353e682 the rfcomm_session_put() gets accidentially called from a timeout callback and results in this: BUG: sleeping function called from invalid context at net/core/sock.c:1897 in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper Pid: 0, comm: swapper Tainted: P 2.6.32 #31 Call Trace: <IRQ> [<ffffffff81036455>] __might_sleep+0xf8/0xfa [<ffffffff8138ef1d>] lock_sock_nested+0x29/0xc4 [<ffffffffa03921b3>] lock_sock+0xb/0xd [l2cap] [<ffffffffa03948e6>] l2cap_sock_shutdown+0x1c/0x76 [l2cap] [<ffffffff8106adea>] ? clockevents_program_event+0x75/0x7e [<ffffffff8106bea2>] ? tick_dev_program_event+0x37/0xa5 [<ffffffffa0394967>] l2cap_sock_release+0x27/0x67 [l2cap] [<ffffffff8138c971>] sock_release+0x1a/0x67 [<ffffffffa03d2492>] rfcomm_session_del+0x34/0x53 [rfcomm] [<ffffffffa03d24c5>] rfcomm_session_put+0x14/0x16 [rfcomm] [<ffffffffa03d28b4>] rfcomm_session_timeout+0xe/0x1a [rfcomm] [<ffffffff810554a8>] run_timer_softirq+0x1e2/0x29a [<ffffffffa03d28a6>] ? rfcomm_session_timeout+0x0/0x1a [rfcomm] [<ffffffff8104e0f6>] __do_softirq+0xfe/0x1c5 [<ffffffff8100e8ce>] ? timer_interrupt+0x1a/0x21 [<ffffffff8100cc4c>] call_softirq+0x1c/0x28 [<ffffffff8100e05b>] do_softirq+0x33/0x6b [<ffffffff8104daf6>] irq_exit+0x36/0x85 [<ffffffff8100d7a9>] do_IRQ+0xa6/0xbd [<ffffffff8100c493>] ret_from_intr+0x0/0xa <EOI> [<ffffffff812585b3>] ? acpi_idle_enter_bm+0x269/0x294 [<ffffffff812585a9>] ? acpi_idle_enter_bm+0x25f/0x294 [<ffffffff81373ddc>] ? cpuidle_idle_call+0x97/0x107 [<ffffffff8100aca0>] ? cpu_idle+0x53/0xaa [<ffffffff81429006>] ? rest_init+0x7a/0x7c [<ffffffff8177bc8c>] ? start_kernel+0x389/0x394 [<ffffffff8177b29c>] ? x86_64_start_reservations+0xac/0xb0 [<ffffffff8177b384>] ? x86_64_start_kernel+0xe4/0xeb To fix this, the rfcomm_session_put() needs to be moved out of rfcomm_session_timeout() into rfcomm_process_sessions(). In that context it is perfectly fine to sleep and disconnect the socket. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Tested-by: David John <davidjon@xenontk.org>
2010-02-03Bluetooth: Fallback eSCO to SCO on error 0x1a (Unsupported Remote Feature)Nick Pelly
General Motors carkits that use LGE BT chipsets return this error code when an eSCO is attempted, despite advertising eSCO support. 2009-08-13 14:41:39.755518 < HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17 handle 1 voice setting 0x0060 2009-08-13 14:41:39.757563 > HCI Event: Command Status (0x0f) plen 4 Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1 2009-08-13 14:41:39.789484 > HCI Event: Synchronous Connect Complete (0x2c) plen 17 status 0x1a handle 257 bdaddr 00:1E:B2:23:5E:B3 type eSCO Error: Unsupported Remote Feature / Unsupported LMP Feature Signed-off-by: Jaikumar Ganesh <jaikumar@google.com> Signed-off-by: Nick Pelly <npelly@google.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-02-03HID: make raw reports possible for both feature and output reportsJiri Kosina
In commit 2da31939a42 ("Bluetooth: Implement raw output support for HIDP layer"), support for Bluetooth hid_output_raw_report was added, but it pushes the data to the intr socket instead of the ctrl one. This has been fixed by 6bf8268f9a91f1 ("Bluetooth: Use the control channel for raw HID reports") Still, it is necessary to distinguish whether the report in question should be either FEATURE or OUTPUT. For this, we have to extend the generic HID API, so that hid_output_raw_report() callback provides means to specify this value so that it can be passed down to lower level hardware drivers (currently Bluetooth and USB). Based on original patch by Bastien Nocera <hadess@hadess.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-30Bluetooth: Use the control channel for raw HID reportsBastien Nocera
In commit 2da31939a42f7a676a0bc5155d6a0a39ed8451f2, support for Bluetooth hid_output_raw_report was added, but it pushes the data to the interrupt channel instead of the contol one. This patch makes hid_output_raw_report use the control channel instead. Using the interrupt channel was a mistake. Signed-off-by: Bastien Nocera <hadess@hadess.net> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-01-30Bluetooth: Fix memory leak in L2CAPAndrei Emeltchenko
Move skb_clone after error confition check so it is not going potentially out of the scope. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-01-30Bluetooth: Remove double free of SKB pointer in L2CAPAndrei Emeltchenko
Trivial fix for double free of SKB pointer with kfree_skb to make code simplier and cleaner. Remove unused variable err. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2010-01-14proc_fops: convert drivers/isdn/ to seq_fileAlexey Dobriyan
Convert code away from ->read_proc/->write_proc interfaces. Switch to proc_create()/proc_create_data() which make addition of proc entries reliable wrt NULL ->proc_fops, NULL ->data and so on. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" [akpm@linux-foundation.org: CONFIG_PROC_FS=n build fix] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-17Bluetooth: Fix L2CAP locking scheme regressionAndrei Emeltchenko
When locking was introduced the error path branch was not taken into account. Error was found in sparse code checking. Kudos to Jani Nikula. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Acked-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Ack L2CAP I-frames before retransmit missing packetGustavo F. Padovan
Moving the Ack to before l2cap_retransmit_frame() we can avoid the case where txWindow is full and the packet can't be retransmited. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Fix unset of RemoteBusy flag for L2CAPGustavo F. Padovan
RemoteBusy flag need to be unset before l2cap_ertm_send(), otherwise l2cap_ertm_send() will return without sending packets because it checks that flag before start sending. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Fix PTR_ERR return of wrong pointer in hidp_setup_hid()Roel Kluin
Return the PTR_ERR of the correct pointer. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix some typos and punctuation in commentsThadeu Lima de Souza Cascardo
fix some typos and punctuation in comments Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03Bluetooth: Add RFCOMM option to use L2CAP ERTM modeMarcel Holtmann
By default the RFCOMM layer would still use L2CAP basic mode. For testing purposes this option enables RFCOMM to select enhanced retransmission mode. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Add L2CAP option for max transmit valueMarcel Holtmann
For testing purposes it is important to modify the max transmit value. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Fix 'SendRRorRNR' to send the ReqSeq valueGustavo F. Padovan
SendRRorRNR needs to acknowledge received I-frames (actually every packet needs to acknowledge received I-frames by sending the proper packet sequence number), so ReqSeq is set to the next I-frame number sequence to be pulled by the reassembly function. SendRRorRNR tells the remote side about local busy conditions, it sends a Receiver Ready frame if local busy is false or a Receiver Not Ready if local busy is true. ReqSeq is the packet's field to send the number of the acknowledged packets. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Implement RejActioned flagGustavo F. Padovan
RejActioned is used to prevent retransmission when a entity is on the WAIT_F state, i.e., waiting for a frame with F-bit set due local busy condition or a expired retransmission timer. (When these two events raise they send a frame with the Poll bit set and enters in the WAIT_F state to wait for a frame with the Final bit set.) The local entity doesn't send I-frames(the data frames) until the receipt of a frame with F-bit set. When that happens it also set RejActioned to false. RejActioned is a mandatory feature of ERTM spec. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Fix sending ReqSeq on I-framesGustavo F. Padovan
As specified by ERTM spec an ERTM channel can acknowledge received I-frames(the data frames) by sending an I-frame with the proper ReqSeq value (i.e. ReqSeq is set to BufferSeq). Until now we aren't setting the ReqSeq value on I-frame control bits. That way we can save sending S-frames(Supervise frames) only to acknowledge receipt of I-frames. It is very helpful to the full-duplex channel. ReqSeq is the packet sequence number sent in an acknowledgement frame to acknowledge receipt of frames up to (ReqSeq - 1). BufferSeq controls the receiver buffer, it is used to delay acknowledgement of new frames to not cause buffer overflow. BufferSeq value is not increased until frames are pulled by reassembly function. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Fix unset of SrejActioned flagGustavo F. Padovan
SrejActioned is a flag that when set prevents local side to retransmit a I-frame(the data frame) already retransmitted. The local entity can retransmit again only when it receives a SREJ frame with the F-bit set. SREJ frame - Selective Reject frame - is sent when an entity wants the retransmission of a specific I-frame that was lost or corrupted. This bug can put ERTM in an unknown state once the entity can't retransmit. A frame with the Final bit set is expected when the local side sends a frame with the Poll bit set due to a local busy condition or a retransmission timer expired. (Receipt of P-bit shall always be replied by a frame with the F-bit set). pi->conn_state keeps informations about many ERTM flags including SrejActioned. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Initialize variables and timers for both channel's sidesGustavo F. Padovan
Fix ERTM's full-duplex channel to work as specified by ERTM spec. ERTM needs to handle state vars, timers and counters to send and receive I-frames(the data frames), i.e., for both sides of data communication. We initialize all of them to the default values here. Full-duplex channel is a mandatory feature of ERTM spec. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Fix handling of BNEP setup connection requestsVikram Kandukuri
According to BNEP test specification the proper response should be sent for a setup connection request message after the BNEP connection setup has been completed. Signed-off-by: Vikram Kandukuri <vikram.kandukuri@atheros.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Unobfuscate tasklet_schedule usageMarcel Holtmann
The tasklet schedule function helpers are just an obfuscation. So remove them and call the schedule functions directly. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Turn hci_recv_frame into an exported functionMarcel Holtmann
For future simplification it is important that the hci_recv_frame function is no longer an inline function. So move it into the module itself and export it. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Return ENETDOWN when interface is downMarcel Holtmann
Sending commands to a down interface results in a timeout while clearly it should just return ENETDOWN. When using the ioctls this works fine, but not when using the HCI sockets sendmsg interface. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-03Bluetooth: Implement raw output support for HIDP layerJiri Kosina
Implement raw output callback which is used by hidraw to send raw data to the underlying device. Without this patch, the userspace hidraw-based applications can't send output reports to HID Bluetooth devices. Reported-and-tested-by: Brian Gunn <bgunn@solekai.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
