commit 94324962066231a938564bebad0f941cd2d06bb2 upstream.
Make sure hci_dev_open returns immediately if hci_dev_unregister has
been called.
This fixes a race between hci_dev_open and hci_dev_unregister which can
lead to a NULL-pointer dereference.
Bug is 100% reproducible using hciattach and a disconnected serial port:
0. # hciattach -n /dev/ttyO1 any noflow
1. hci_dev_open called from hci_power_on grabs req lock
2. hci_init_req executes but device fails to initialise (times out
eventually)
3. hci_dev_open is called from hci_sock_ioctl and sleeps on req lock
4. hci_uart_tty_close calls hci_dev_unregister and sleeps on req lock in
hci_dev_do_close
5. hci_dev_open (1) releases req lock
6. hci_dev_do_close grabs req lock and returns as device is not up
7. hci_dev_unregister sleeps in destroy_workqueue
8. hci_dev_open (3) grabs req lock, calls hci_init_req and eventually sleeps
9. hci_dev_unregister finishes, while hci_dev_open is still running...
[ 79.627136] INFO: trying to register non-static key.
[ 79.632354] the code is fine but needs lockdep annotation.
[ 79.638122] turning off the locking correctness validator.
[ 79.643920] [<c00188bc>] (unwind_backtrace+0x0/0xf8) from [<c00729c4>] (__lock_acquire+0x1590/0x1ab0)
[ 79.653594] [<c00729c4>] (__lock_acquire+0x1590/0x1ab0) from [<c00733f8>] (lock_acquire+0x9c/0x128)
[ 79.663085] [<c00733f8>] (lock_acquire+0x9c/0x128) from [<c0040a88>] (run_timer_softirq+0x150/0x3ac)
[ 79.672668] [<c0040a88>] (run_timer_softirq+0x150/0x3ac) from [<c003a3b8>] (__do_softirq+0xd4/0x22c)
[ 79.682281] [<c003a3b8>] (__do_softirq+0xd4/0x22c) from [<c003a924>] (irq_exit+0x8c/0x94)
[ 79.690856] [<c003a924>] (irq_exit+0x8c/0x94) from [<c0013a50>] (handle_IRQ+0x34/0x84)
[ 79.699157] [<c0013a50>] (handle_IRQ+0x34/0x84) from [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c)
[ 79.708648] [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) from [<c037499c>] (__irq_usr+0x3c/0x60)
[ 79.718048] Exception stack(0xcf281fb0 to 0xcf281ff8)
[ 79.723358] 1fa0: 0001e6a0 be8dab00 0001e698 00036698
[ 79.731933] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000
[ 79.740509] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff
[ 79.747497] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 79.756011] pgd = cf3b4000
[ 79.758850] [00000000] *pgd=8f0c7831, *pte=00000000, *ppte=00000000
[ 79.765502] Internal error: Oops: 80000007 [#1]
[ 79.770294] Modules linked in:
[ 79.773529] CPU: 0 Tainted: G W (3.3.0-rc6-00002-gb5d5c87 #421)
[ 79.781066] PC is at 0x0
[ 79.783721] LR is at run_timer_softirq+0x16c/0x3ac
[ 79.788787] pc : [<00000000>] lr : [<c0040aa4>] psr: 60000113
[ 79.788787] sp : cf281ee0 ip : 00000000 fp : cf280000
[ 79.800903] r10: 00000004 r9 : 00000100 r8 : b6f234d0
[ 79.806427] r7 : c0519c28 r6 : cf093488 r5 : c0561a00 r4 : 00000000
[ 79.813323] r3 : 00000000 r2 : c054eee0 r1 : 00000001 r0 : 00000000
[ 79.820190] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 79.827728] Control: 10c5387d Table: 8f3b4019 DAC: 00000015
[ 79.833801] Process gpsd (pid: 1265, stack limit = 0xcf2802e8)
[ 79.839965] Stack: (0xcf281ee0 to 0xcf282000)
[ 79.844573] 1ee0: 00000002 00000000 c0040a24 00000000 00000002 cf281f08 00200200 00000000
[ 79.853210] 1f00: 00000000 cf281f18 cf281f08 00000000 00000000 00000000 cf281f18 cf281f18
[ 79.861816] 1f20: 00000000 00000001 c056184c 00000000 00000001 b6f234d0 c0561848 00000004
[ 79.870452] 1f40: cf280000 c003a3b8 c051e79c 00000001 00000000 00000100 3fa9e7b8 0000000a
[ 79.879089] 1f60: 00000025 cf280000 00000025 00000000 00000000 b6f234d0 00000000 00000004
[ 79.887756] 1f80: 00000000 c003a924 c053ad38 c0013a50 fa200000 cf281fb0 ffffffff c0008530
[ 79.896362] 1fa0: 0001e6a0 0000aab8 80000010 c037499c 0001e6a0 be8dab00 0001e698 00036698
[ 79.904998] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000
[ 79.913665] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff 00fbf700 04ffff00
[ 79.922302] [<c0040aa4>] (run_timer_softirq+0x16c/0x3ac) from [<c003a3b8>] (__do_softirq+0xd4/0x22c)
[ 79.931945] [<c003a3b8>] (__do_softirq+0xd4/0x22c) from [<c003a924>] (irq_exit+0x8c/0x94)
[ 79.940582] [<c003a924>] (irq_exit+0x8c/0x94) from [<c0013a50>] (handle_IRQ+0x34/0x84)
[ 79.948913] [<c0013a50>] (handle_IRQ+0x34/0x84) from [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c)
[ 79.958404] [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) from [<c037499c>] (__irq_usr+0x3c/0x60)
[ 79.967773] Exception stack(0xcf281fb0 to 0xcf281ff8)
[ 79.973083] 1fa0: 0001e6a0 be8dab00 0001e698 00036698
[ 79.981658] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000
[ 79.990234] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff
[ 79.997161] Code: bad PC value
[ 80.000396] ---[ end trace 6f6739840475f9ee ]---
[ 80.005279] Kernel panic - not syncing: Fatal exception in interrupt
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
commit 18daf1644e634bae951a6e3d4d19d89170209762 upstream
Commit 330605423c fixed l2cap conn establishment for non-ssp remote
devices by not setting HCI_CONN_ENCRYPT_PEND every time conn security
is tested (which was always returning failure on any subsequent
security checks).
However, this broke l2cap conn establishment for ssp remote devices
when an ACL link was already established at SDP-level security. This
fix ensures that encryption must be pending whenever authentication
is also pending.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Tested-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
commit 2d20a26a92f72e3bb658fe8ce99c3663756e9e7a upstream.
The checks for HCI_INQUIRY and HCI_MGMT were in the wrong order,
so that second scans always failed.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
[ Upstream commit 550fd08c2cebad61c548def135f67aba284c6162 ]
After the last patch, We are left in a state in which only drivers calling
ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real
hardware call ether_setup for their net_devices and don't hold any state in
their skbs. There are a handful of drivers that violate this assumption of
course, and need to be fixed up. This patch identifies those drivers, and marks
them as not being able to support the safe transmission of skbs by clearning the
IFF_TX_SKB_SHARING flag in priv_flags
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Patrick McHardy <kaber@trash.net>
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johannes Berg <johannes@sipsolutions.net>
Another regression fix considering incomming l2cap connections with
defer_setup enabled. In situations when incomming connection is
extracted with l2cap_sock_accept, it's bt_sock info will have
'parent' member zerroed, but 'parent' may be used unconditionally
in l2cap_conn_start() and l2cap_security_cfm() when defer_setup
is enabled.
Backtrace:
[<bf02d5ac>] (l2cap_security_cfm+0x0/0x2ac [bluetooth]) from [<bf01f01c>] (hci_event_pac
ket+0xc2c/0x4aa4 [bluetooth])
[<bf01e3f0>] (hci_event_packet+0x0/0x4aa4 [bluetooth]) from [<bf01a844>] (hci_rx_task+0x
cc/0x27c [bluetooth])
[<bf01a778>] (hci_rx_task+0x0/0x27c [bluetooth]) from [<c008eee4>] (tasklet_action+0xa0/
0x15c)
[<c008ee44>] (tasklet_action+0x0/0x15c) from [<c008f38c>] (__do_softirq+0x98/0x130)
r7:00000101 r6:00000018 r5:00000001 r4:efc46000
[<c008f2f4>] (__do_softirq+0x0/0x130) from [<c008f524>] (do_softirq+0x4c/0x58)
[<c008f4d8>] (do_softirq+0x0/0x58) from [<c008f5e0>] (run_ksoftirqd+0xb0/0x1b4)
r4:efc46000 r3:00000001
[<c008f530>] (run_ksoftirqd+0x0/0x1b4) from [<c009f2a8>] (kthread+0x84/0x8c)
r7:00000000 r6:c008f530 r5:efc47fc4 r4:efc41f08
[<c009f224>] (kthread+0x0/0x8c) from [<c008cc84>] (do_exit+0x0/0x5f0)
Signed-off-by: Ilia Kolomisnky <iliak@ti.com>
Caused by the following commit, partially revert it.
commit 9fa7e4f76f3658ba1f44fbdb95c77e7df3f53f95
Author: Gustavo F. Padovan <padovan@profusion.mobi>
Date: Thu Jun 30 16:11:30 2011 -0300
Bluetooth: Fix regression with incoming L2CAP connections
PTS test A2DP/SRC/SRC_SET/TC_SRC_SET_BV_02_I revealed that
( probably after the df3c3931e commit ) the l2cap connection
could not be established in case when the "Auth Complete" HCI
event does not arive before the initiator send "Configuration
request", in which case l2cap replies with "Command rejected"
since the channel is still in BT_CONNECT2 state.
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
If the remote device is not present, the connections attemp fails and
the struct hci_conn was not freed
Signed-off-by: Tomas Targownik <ttargownik@geicp.com>
Based on patch from: Ilia Kolomisnky <iliak@ti.com>
Partial revert of commit aabf6f89. When the hidp session thread
was converted from kernel_thread to kthread, the atomic/wakeups
were replaced with kthread_stop. kthread_stop has blocking semantics
which are inappropriate for the hidp session kthread. In addition,
the kthread signals itself to terminate in hidp_process_hid_control()
- it cannot do this with kthread_stop().
Lastly, a wakeup can be lost if the wakeup happens between checking
for the loop exit condition and setting the current state to
TASK_INTERRUPTIBLE. (Without appropriate synchronization mechanisms,
the task state should not be changed between the condition test and
the yield - via schedule() - as this creates a race between the
wakeup and resetting the state back to interruptible.)
A remote user can provide a small value for the command size field in
the command header of an l2cap configuration request, resulting in an
integer underflow when subtracting the size of the configuration request
header. This results in copying a very large amount of data via
memcpy() and destroying the kernel heap. Check for underflow.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: stable <stable@kernel.org>
In hci_conn_security ( which is used during L2CAP connection
establishment ) test for HCI_CONN_ENCRYPT_PEND state also
sets this state, which is bogus and leads to connection time-out
on L2CAP sockets in certain situations (especially when
using non-ssp devices )
When authentication completes we shouldn't blindly accept any pending
L2CAP connect requests. If the socket has the defer_setup feature
enabled it should still wait for user space acceptance of the connect
request. The issue only happens for non-SSP connections since with SSP
the L2CAP Connect request may not be sent for non-SDP PSMs before
authentication has completed successfully.
With older userspace versions (using hciops) it might not have the
key type to check if the key has sufficient security for any security
level so it is necessary to check the return of hci_conn_auth to make
sure the connection is authenticated
Acked-by: Johan Hedberg <johan.hedberg@intel.com>
Some old hci controllers do not accept any mask so leave the
default mask on for these devices.
< HCI Command: Set Event Mask (0x03|0x0001) plen 8
Mask: 0xfffffbff00000000
> HCI Event: Command Complete (0x0e) plen 4
Set Event Mask (0x03|0x0001) ncmd 1
status 0x12
Error: Invalid HCI Command Parameters
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
Tested-by: Corey Boyle <corey@kansanian.com>
Tested-by: Ed Tomlinson <edt@aei.ca>
shutdown should wait for SCO link to be properly disconnected before
detroying the socket, otherwise an application using the socket may
assume link is properly disconnected before it really happens which
can be a problem when e.g synchronizing profile switch.
Signed-off-by: Luiz Augusto von Dentz <luiz.dentz-von@nokia.com>
Structures "l2cap_conninfo" and "rfcomm_conninfo" have one padding
byte each. This byte in "cinfo" is copied to userspace uninitialized.
Signed-off-by: Filip Palian <filip.palian@pjwstk.edu.pl>
read_lock() ... read_unlock_bh() is clearly bogus.
This was broken by
commit 23691d75cdc69c3b285211b4d77746aa20a17d18
Date: Wed Apr 27 18:26:32 2011 -0300
Bluetooth: Remove l2cap_sk_list
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (36 commits)
HID: hid-multitouch: cosmetic changes, sort classes and devices
HID: hid-multitouch: class MT_CLS_STANTUM is redundant with MT_CLS_CONFIDENCE
HID: hid-multitouch: add support for Unitec panels
HID: hid-multitouch: add support for Touch International panels
HID: hid-multitouch: add support for GoodTouch panels
HID: hid-multitouch: add support for CVTouch panels
HID: hid-multitouch: add support for ActionStar panels
HID: hiddev: fix race between hiddev_disconnect and hiddev_release
HID: magicmouse: ignore 'ivalid report id' while switching modes
HID: fix a crash in hid_report_raw_event() function.
HID: hid-multitouch: add support for Elo TouchSystems 2515 IntelliTouch Plus
HID: assorted usage updates from hut 1.12
HID: roccat: fix actual/startup profile sysfs attribute in koneplus
HID: hid-multitouch: Add support for Lumio panels
HID: 'name' and 'phys' in 'struct hid_device' can never be NULL
HID: hid-multitouch: add support for Ilitek dual-touch panel
HID: picolcd: Avoid compile warning/error triggered by copy_from_user()
HID: add support for Logitech G27 wheel
HID: hiddev: fix error path in hiddev_read when interrupted
HID: add support for Sony Navigation Controller
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
This is sync with Linus' tree to receive KEY_IMAGES definition
that went in through input tree.
net/bluetooth/l2cap_core.c: In function ‘l2cap_recv_frame’:
net/bluetooth/l2cap_core.c:3758:15: warning: ‘sk’ may be used uninitialized in this function
net/bluetooth/l2cap_core.c:3758:15: note: ‘sk’ was declared here
net/bluetooth/l2cap_core.c:3791:15: warning: ‘sk’ may be used uninitialized in this function
net/bluetooth/l2cap_core.c:3791:15: note: ‘sk’ was declared here
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-next-2.6
They were added by me while testing and I forgot to remove.
This reverts commit f21ca5fff6e548833fa5ee8867239a8378623150.
Quoth Gustavo F. Padovan:
"Commit f21ca5fff6e548833fa5ee8867239a8378623150 can cause a NULL
dereference if we call shutdown in a bluetooth SCO socket and doesn't
wait the shutdown completion to call close(). Please revert it. I
may have a fix for it soon, but we don't have time anymore, so revert
is the way to go. ;)"
Requested-by: Gustavo F. Padovan <padovan@profusion.mobi>
If we can't find a ACL link between the devices, we search
the connection list one second time looking for LE links.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
We need to be able for receive events notifying that the connection
was established, the connection attempt failed or that disconnection
happened.
In case of pre v2.1 devices authentication request will return
success immediately if the link key already exists without any
authentication process.
That means, it's not possible to re-authenticate the link if you
already have combination key and for instance want to re-authenticate
to get the high security (use 16 digit pin).
Therefore, it's necessary to check security requirements on auth
complete event to prevent not enough secure connection.
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
drivers/net/wireless/libertas/if_cs.c
drivers/net/wireless/rtlwifi/pci.c
net/bluetooth/l2cap_sock.c
A new list was added to replace the socket based one. This new list
doesn't depent on sock and then fits better inside l2cap_core.c code.
It also rename l2cap_chan_alloc() to l2cap_chan_create() and
l2cap_chan_free() to l2cap_chan_destroy)
When the user doesn't specify a psm we have the choose one for the
channel. Now we do this inside l2cap_add_psm().
The intention is to get rid of the l2cap_sk_list usage inside
l2cap_core.c. l2cap_sk_list will soon be replaced by a list that does not
depend on socket usage.
In some circumstances hci_get_auth_req will return a value different
from the current conn->auth_type. In these cases update conn->auth_type
so that when a user confirm request comes it doesn't falsely trigger
auto-accept.
Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com>
Even for keys that shouldn't be stored some use cases require the
knowledge of a new key having been created so that the conclusion of a
successful pairing can be made. Therefore, always send the mgmt_new_key
event but add a store_hint parameter to it to indicate to user space
whether the key should be stored or not.
User space shouldn't have any need for the old key type so remove it
from the corresponding Management interface event.
If a controller generates a changed combination key as its first key the
connection key type will not be correctly set. In these situations make
sure the update the connection key type when such a buggy controller is
detected.
Even if there's no previous key stored the connection might still be
secured with a non-persistent key and in that case the key type in the
hci_conn struct should be checked.
Link keys should only be stored if very specific criteria of the
authentication process are fulfilled. This patch essentially copies the
criteria that user space has so far been using to the kernel side so
that the management interface works properly.
The mgmt_ev_pin_code_request event should not be sent to user space if
the request gets rejected by the kernel due to the pairable flag not
being set.
"Pairing not allowed" is 0x18 and not 0x16.
When accepting a pairing request which fulfills the SSP auto-accept
criteria we need to push the request all the way to the user for
confirmation. This patch adds a new hint to the user_confirm_request
management event so user space can know when to show a numeric
comparison dialog and when to show a simple yes/no confirmation dialog.
The HCI_CONN_AUTH_PEND flag should be set whenever requesting
authentication so that multiple pending requests can't occur.
Some test systems require an arbitrary delay to the auto-accept test
cases for Secure Simple Pairing in order for the tests to pass.
Previously when this was handled in user space it was worked around by
code modifications and recompilation, but now that it's on the kernel
side it's more convenient if there's a debugfs interface for it.
This patch adds automated negative and positive (auto-accept) responses
for Secure Simple Pairing user confirmation requests. The responses are
only sent if the HCI_MGMT flag is set in order not to confuse older user
space versions (without management interface support).
Extend the mgmt_pin_code_request interface to require secure
pin code (16 digit) for authentication.
This is a kernel part of the secure pin code requirement notification
to user space agent.
Code styling fix by Johan Hedberg.
If host requires MITM protection notify that to controller in
io capabilities reply even if the remote device requires no bonding.
If it is not respected, host can get an unauthenticated link key while
it expects authenticated one.
High security level for pre v2.1 devices requires combination link key
authenticated by at least 16 digit PIN code.
It's also necessary to update key_type and pin_length when the key
exists and is sufficently secured for the connection as there will be
no link key notify event in that case.
Keep the link key type together with connection and use it to
map security level to link key requirements. Authenticate and/or
encrypt connection if the link is insufficiently secure.
If authentication fails the security level should stay as it was set
before the process has started. Setting BT_SECURITY_LOW can hide real
security level on a link eg. having BT_SECURITY_MEDIUM on the link,
re-authenticate with failure to get BT_SECURITY_HIGH, as a result we
get BT_SECURITY_LOW on the link while the real security is still medium.
