path: root/net/bridge/Kconfig
2011-03-10net: bridge builtin vs. ipv6 modularRandy Dunlap
When configs BRIDGE=y and IPV6=m, this build error occurs: br_multicast.c:(.text+0xa3341): undefined reference to `ipv6_dev_get_saddr' BRIDGE_IGMP_SNOOPING is boolean; if it were tristate, then adding depends on IPV6 || IPV6=n to BRIDGE_IGMP_SNOOPING would be a good fix. As it is currently, making BRIDGE depend on the IPV6 config works. Reported-by: Patrick Schaaf <netdev@bof.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23bridge br_multicast: IPv6 MLD support.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2010-03-03bridge: depends on INETRandy Dunlap
br_multicast calls ip_send_check(), so it should depend on INET. built-in: br_multicast.c:(.text+0x88cf4): undefined reference to `ip_send_check' or modular: ERROR: "ip_send_check" [net/bridge/bridge.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28bridge: Make IGMP snooping depend upon BRIDGE.David S. Miller
2010-02-28bridge: Add core IGMP snooping supportHerbert Xu
This patch adds the core functionality of IGMP snooping support without actually hooking it up. So this patch should be a no-op as far as the bridge's external behaviour is concerned. All the new code and data is controlled by the Kconfig option BRIDGE_IGMP_SNOOPING. A run-time toggle is also available. The multicast switching is done using an hash table that is lockless on the read-side through RCU. On the write-side the new multicast_lock is used for all operations. The hash table supports dynamic growth/rehashing. The hash table will be rehashed if any chain length exceeds a preset limit. If rehashing does not reduce the maximum chain length then snooping will be disabled. These features may be added in future (in no particular order): * IGMPv3 source support * Non-querier router detection * IPv6 Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05bridge: Use STP demuxPatrick McHardy
Use the STP demux layer for receiving STP PDUs instead of directly registering with LLC. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: use llc for receiving STP packetsStephen Hemminger
Use LLC for the receive path of Spanning Tree Protocol packets. This allows link local multicast packets to be received by other protocols (if they care), and uses the existing LLC code to get STP packets back into bridge code. The bridge multicast address is also checked, so bridges using other link local multicast addresses are ignored. This allows for use of different multicast addresses to define separate STP domains. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-11[NET]: move config options out to individual protocolsSam Ravnborg
Move the protocol specific config options out to the specific protocols. With this change net/Kconfig now starts to become readable and serve as a good basis for further re-structuring. The menu structure is left almost intact, except that indention is fixed in most cases. Most visible are the INET changes where several "depends on INET" are replaced with a single ifdef INET / endif pair. Several new files were created to accomplish this change - they are small but serve the purpose that config options are now distributed out where they belongs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
