path: root/net/bridge/br.c
2014-09-26netfilter: bridge: move br_netfilter out of the corePablo Neira Ayuso
Jesper reported that br_netfilter always registers the hooks since this is part of the bridge core. This harms performance for people that don't need this. This patch modularizes br_netfilter so it can be rmmod'ed, thus, the hooks can be unregistered. I think the bridge netfilter should have been a separated module since the beginning, Patrick agreed on that. Note that this is breaking compatibility for users that expect that bridge netfilter is going to be available after explicitly 'modprobe bridge' or via automatic load through brctl. However, the damage can be easily undone by modprobing br_netfilter. The bridge core also spots a message to provide a clue to people that didn't notice that this has been deprecated. On top of that, the plan is that nftables will not rely on this software layer, but integrate the connection tracking into the bridge layer to enable stateful filtering and NAT, which is was bridge netfilter users seem to require. This patch still keeps the fake_dst_ops in the bridge core, since this is required by when the bridge port is initialized. So we can safely modprobe/rmmod br_netfilter anytime. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Florian Westphal <fw@strlen.de>
2014-05-22bridge: make br_device_notifier staticCong Wang
Merge net/bridge/br_notify.c into net/bridge/br.c, since it has only br_device_event() and br.c is small. Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13bridge: move br_net_exit() to br.cWANG Cong
And it can become static. Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16net:bridge: use IS_ENABLEDIgor Maravić
Use IS_ENABLED(CONFIG_FOO) instead of defined(CONFIG_FOO) || defined (CONFIG_FOO_MODULE) Signed-off-by: Igor Maravić <igorm@etf.rs> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-04bridge: allow creating bridge devices with netlinkstephen hemminger
Add netlink device ops to allow creating bridge device via netlink. This works in a manner similar to vlan, macvlan and bonding. Example: # ip link add link dev br0 type bridge # ip link del dev br0 The change required rearranging initializtion code to deal with being called by create link. Most of the initialization happens in br_dev_setup, but allocation of stats is done in ndo_init callback to deal with allocation failure. Sysfs setup has to wait until after the network device kobject is registered. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15bridge: add proper RCU annotation to should_route_hookEric Dumazet
Add br_should_route_hook_t typedef, this is the only way we can get a clean RCU implementation for function pointer. Move route_hook to location where it is used. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02net: replace hooks in __netif_receive_skb V5Jiri Pirko
What this patch does is it removes two receive frame hooks (for bridge and for macvlan) from __netif_receive_skb. These are replaced them with a single hook for both. It only supports one hook per device because it makes no sense to do bridging and macvlan on the same device. Then a network driver (of virtual netdev like macvlan or bridge) can register an rx_handler for needed net device. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: change console message interfacestephen hemminger
Use one set of macro's for all bridge messages. Note: can't use netdev_XXX macro's because bridge is purely virtual and has no device parent. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26bridge: Use rcu_barrier() instead of syncronize_net() on unload.Jesper Dangaard Brouer
When unloading modules that uses call_rcu() callbacks, then we must use rcu_barrier(). This module uses syncronize_net() which is not enough to be sure that all callback has been completed. Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11bridge: Simplify interface for ATM LANEMichał Mirosław
This patch changes FDB entry check for ATM LANE bridge integration. There's no point in holding a FDB entry around SKB building. br_fdb_get()/br_fdb_put() pair are changed into single br_fdb_test_addr() hook that checks if the addr has FDB entry pointing to other port to the one the request arrived on. FDB entry refcounting is removed as it's not used anywhere else. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08netns bridge: cleanup bridges during netns stopAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Stephen Hemminger <shemming@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05bridge: Use STP demuxPatrick McHardy
Use the STP demux layer for receiving STP PDUs instead of directly registering with LLC. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29bridge: kernel panic when unloading bridge moduleBodo Stroesser
There is a race condition when unloading bridge and netfilter. The problem happens if __fake_rtable is in use by a skb coming in, while someone starts to unload bridge.ko. br_netfilter_fini() is called at the beginning of unload in br_deinit() while skbs still are being forwarded and transferred to local ip stack. Thus there is a possibility of the __fake_rtable pointer not being removed in a skb that goes up to ip stack. This results in a kernel panic, as ip_rcv() calls the input-function of __fake_rtable, which is NULL. Moving the call of br_netfilter_fini() to the end of br_deinit() solves the problem. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Stephen Hemminger <stephen.hemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-29[BRIDGE]: Lost call to br_fdb_fini() in br_init() error pathPavel Emelyanov
In case the br_netfilter_init() (or any subsequent call) fails, the br_fdb_fini() must be called to free the allocated in br_fdb_init() br_fdb_cache kmem cache. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25bridge: check kmem_cache_create() errorAkinobu Mita
This patch checks kmem_cache_create() error and aborts loading module on failure. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
2007-04-25[BRIDGE]: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BRIDGE]: netlink interface for link managementStephen Hemminger
Add basic netlink support to the Ethernet bridge. Including: * dump interfaces in bridges * monitor link status changes * change state of bridge port For some demo programs see: http://developer.osdl.org/shemminger/prototypes/brnl.tar.gz These are to allow building a daemon that does alternative implementations of Spanning Tree Protocol. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[BRIDGE]: fix module startup error handlingStephen Hemminger
Return address in use, if some other kernel code has the SAP. Propogate out error codes from netfilter registration and unwind. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-23[BRIDGE]: need to ref count the LLC sapStephen Hemminger
Bridge will OOPS on removal if other application has the SAP open. The bridge SAP might be shared with other usages, so need to do reference counting on module removal rather than explicit close/delete. Since packet might arrive after or during removal, need to clear the receive function handle, so LLC only hands it to user (if any). Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: use llc for receiving STP packetsStephen Hemminger
Use LLC for the receive path of Spanning Tree Protocol packets. This allows link local multicast packets to be received by other protocols (if they care), and uses the existing LLC code to get STP packets back into bridge code. The bridge multicast address is also checked, so bridges using other link local multicast addresses are ignored. This allows for use of different multicast addresses to define separate STP domains. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: add version numberStephen Hemminger
Add version info to bridge module. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
