path: root/net/bridge/br_stp_bpdu.c
2011-07-22bridge: minor cleanupsstephen hemminger
Some minor cleanups that won't impact code: 1. Remove inline from non-critical functions; compiler will most likely inline them anyway. 2. Make function args const where possible. 3. Whitespace cleanup Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-22bridge: ignore bogus STP config packetsstephen hemminger
If the message_age is already greater than the max_age, then the BPDU is bogus. Linux won't generate BPDU, but conformance tester or buggy implementation might. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-04Merge branch 'master' of ↵David S. Miller
2011-01-03bridge: stp: ensure mac header is setFlorian Westphal
commit bf9ae5386bca8836c16e69ab8fdbe46767d7452a (llc: use dev_hard_header) removed the skb_reset_mac_header call from llc_mac_hdr_init. This seems fine itself, but br_send_bpdu() invokes ebtables LOCAL_OUT. We oops in ebt_basic_match() because it assumes eth_hdr(skb) returns a meaningful result. Cc: acme@ghostprotocols.net References: https://bugzilla.kernel.org/show_bug.cgi?id=24532 Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15bridge: fix RCU races with bridge portstephen hemminger
The macro br_port_exists() is not enough protection when only RCU is being used. There is a tiny race where other CPU has cleared port handler hook, but is bridge port flag might still be set. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/hw.h net/bridge/br_device.c net/bridge/br_input.c
2010-07-28bridge: add rcu_read_lock on transmitstephen hemminger
Long ago, when bridge was converted to RCU, rcu lock was equivalent to having preempt disabled. RCU has changed a lot since then and bridge code was still assuming the since transmit was called with bottom half disabled, it was RCU safe. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: use rx_handler_data pointer to store net_bridge_port pointerJiri Pirko
Register net_bridge_port pointer as rx_handler data pointer. As br_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a bridge port. Also rcuized pointers are now correctly dereferenced in br_fdb.c and in netfilter parts. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: bridge: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The first argument to NF_HOOK* is an nfproto since quite some time. Commit v2.6.27-2457-gfdc9314 was the first to practically start using the new names. Do that now for the remaining NF_HOOK calls. The semantic patch used was: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_THRESH )( -PF_BRIDGE, +NFPROTO_BRIDGE, ...) @@ @@ NF_HOOK( -PF_INET6, +NFPROTO_IPV6, ...) @@ @@ NF_HOOK( -PF_INET, +NFPROTO_IPV4, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2008-09-08netns bridge: allow bridges in netns!Alexey Dobriyan
Bridge as netdevice doesn't cross netns boundaries. Bridge ports and bridge itself live in same netns. Notifiers are fixed. netns propagated from userspace socket for setup and teardown. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Stephen Hemminger <shemming@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05bridge: Use STP demuxPatrick McHardy
Use the STP demux layer for receiving STP PDUs instead of directly registering with LLC. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02net: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: DIV_ROUND_UP cleanup (part two)Ilpo Järvinen
Hopefully captured all single statement cases under net/. I'm not too sure if there is some policy about #includes that are "guaranteed" (ie., in the current tree) to be available through some other #included header, so I just added linux/kernel.h to each changed file that didn't #include it previously. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25bridge: add support for user mode STPStephen Hemminger
This patchset based on work by Aji_Srinivas@emc.com provides allows spanning tree to be controled from userspace. Like hotplug, it uses call_usermodehelper when spanning tree is enabled so there is no visible API change. If call to start usermode STP fails it falls back to existing kernel STP. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
2007-02-10[NET] BRIDGE: Fix whitespace errors.YOSHIFUJI Hideaki
2006-09-17[BRIDGE]: random extra bytes on STP TCN packetStephen Hemminger
We seem to send 3 extra bytes in a TCN, which will be whatever happens to be on the stack. Thanks to Aji_Srinivas@emc.com for seeing. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-24[BRIDGE]: Unaligned accesses in the ethernet bridgePeter Chubb
I see lots of kernel unaligned access to 0xa0000001009dbb6f, ip=0xa000000100811591 kernel unaligned access to 0xa0000001009dbb6b, ip=0xa0000001008115c1 kernel unaligned access to 0xa0000001009dbb6d, ip=0xa0000001008115f1 messages in my logs on IA64 when using the ethernet bridge with 2.6.16. Appended is a patch to fix them. Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: use LLC to send STPStephen Hemminger
The bridge code can use existing LLC output code when building spanning tree protocol packets. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: allow show/store of group multicast addressStephen Hemminger
Bridge's communicate with each other using Spanning Tree Protocol over a standard multicast address. There are times when testing or layering bridges over existing topologies or tunnels, when it is useful to use alternative multicast addresses for STP packets. The 802.1d standard has some unused addresses, that can be used for this. This patch is restrictive in that it only allows one of the possible addresses in the standard. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: use llc for receiving STP packetsStephen Hemminger
Use LLC for the receive path of Spanning Tree Protocol packets. This allows link local multicast packets to be received by other protocols (if they care), and uses the existing LLC code to get STP packets back into bridge code. The bridge multicast address is also checked, so bridges using other link local multicast addresses are ignored. This allows for use of different multicast addresses to define separate STP domains. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: stp timer to jiffies cleanupStephen Hemminger
Cleanup the get/set of bridge timer value in the packets. It is clearer not to bury the conversion in macro. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-09[BRIDGE]: fix for RCU and deadlock on device removalStephen Hemminger
Change Bridge receive path to correctly handle RCU removal of device from bridge. Also fixes deadlock between carrier_check and del_nbp. This replaces the previous deleted flag fix. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[BRIDGE]: prevent bad forwarding table updatesStephen Hemminger
Avoid poisoning of the bridge forwarding table by frames that have been dropped by filtering. This prevents spoofed source addresses on hostile side of bridge from causing packet leakage, a small but possible security risk. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
