Restrict the reject expression to the prerouting and input bridge
hooks. If we allow this to be used from forward or any other later
bridge hook, if the frame is flooded to several ports, we'll end up
sending several reject packets, one per cloned packet.
If the packet is received via the bridge stack, this cannot reject
packets from the IP stack.
This adds functions to build the reject packet and send it from the
bridge stack. Comments and assumptions on this patch:
1) Validate the IPv4 and IPv6 headers before further processing,
given that the packet comes from the bridge stack, we cannot assume
they are clean. Truncated packets are dropped, we follow similar
approach in the existing iptables match/target extensions that need
to inspect layer 4 headers that is not available. This also includes
packets that are directed to multicast and broadcast ethernet
addresses.
2) br_deliver() is exported to inject the reject packet via
bridge localout -> postrouting. So the approach is similar to what
we already do in the iptables reject target. The reject packet is
sent to the bridge port from which we have received the original
packet.
3) The reject packet is forged based on the original packet. The TTL
is set based on sysctl_ip_default_ttl for IPv4 and per-net
ipv6.devconf_all hoplimit for IPv6.
Fixes: 36d2af5 ("netfilter: nf_tables: allow to filter from prerouting and postrouting")
This allows us to emulate the NAT table in ebtables, which is actually
a plain filter chain that hooks at prerouting, output and postrouting.
This patch introduces the NFT_REJECT_ICMPX_UNREACH type which provides
an abstraction to the ICMP and ICMPv6 codes that you can use from the
inet and bridge tables, they are:
* NFT_REJECT_ICMPX_NO_ROUTE: no route to host - network unreachable
* NFT_REJECT_ICMPX_PORT_UNREACH: port unreachable
* NFT_REJECT_ICMPX_HOST_UNREACH: host unreachable
* NFT_REJECT_ICMPX_ADMIN_PROHIBITED: administratevely prohibited
You can still use the specific codes when restricting the rule to match
the corresponding layer 3 protocol.
I decided to not overload the existing NFT_REJECT_ICMP_UNREACH to have
different semantics depending on the table family and to allow the user
to specify ICMP family specific codes if they restrict it to the
corresponding family.
This is already done for x_tables (family AF_INET and AF_INET6), let's
do it for AF_BRIDGE also.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Eric Dumazet reports that getsockopt() or setsockopt() sometimes
returns -EINTR instead of -ENOPROTOOPT, causing headaches to
application developers.
This patch replaces all the mutex_lock_interruptible() by mutex_lock()
in the netfilter tree, as there is no reason we should sleep for a
long time there.
Reported-by: Eric Dumazet <edumazet@google.com>
Suggested-by: Patrick McHardy <kaber@trash.net>
Acked-by: Julian Anastasov <ja@ssi.bg>
The ulog targets were recently killed. A few references to the Kconfig
macros CONFIG_IP_NF_TARGET_ULOG and CONFIG_BRIDGE_EBT_ULOG were left
untouched. Kill these too.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
So you can reject IPv4 and IPv6 packets from bridge tables. If the ether
proto is now known, default on dropping the packet instead.
This adds the generic plain text packet loggger for bridged packets.
It routes the logging message to the real protocol packet logger.
I decided not to refactor the ebt_log code for two reasons:
1) The ebt_log output is not consistent with the IPv4 and IPv6
Netfilter packet loggers. The output is different for no good
reason and it adds redundant code to handle packet logging.
2) To avoid breaking backward compatibility for applications
outthere that are parsing the specific ebt_log output, the ebt_log
output has been left as is. So only nftables will use the new
consistent logging format for logged bridged packets.
More decisions coming in this patch:
1) This also removes ebt_log as default logger for bridged packets.
Thus, nf_log_packet() routes packet to this new packet logger
instead. This doesn't break backward compatibility since
nf_log_packet() is not used to log packets in plain text format
from anywhere in the ebtables/netfilter bridge code.
2) The new bridge packet logger also performs a lazy request to
register the real IPv4, ARP and IPv6 netfilter packet loggers.
If the real protocol logger is no available (not compiled or the
module is not available in the system, not packet logging happens.
Now that legacy ulog targets are not available anymore in the tree, we
can have up to two possible loggers:
1) The plain text logging via kernel logging ring.
2) The nfnetlink_log infrastructure which delivers log messages
to userspace.
This patch replaces the list of loggers by an array of two pointers
per family for each possible logger and it also introduces a new field
to the nf_logger structure which indicates the position in the logger
array (based on the logger type).
This prepares a follow up patch that consolidates the nf_log_packet()
interface by allowing to specify the logger as parameter.
This has been marked as deprecated for quite some time and the NFLOG
target replacement has been also available since 2006.
Before f5efc69 ("netfilter: nf_tables: Add meta expression key for
bridge interface name"), the entire net/bridge/netfilter/ directory
depended on BRIDGE_NF_EBTABLES, ie. on ebtables. However, that
directory already contained the nf_tables bridge extension that
we should allow to compile separately. In f5efc69, we tried to
generalize this by using CONFIG_BRIDGE_NETFILTER which was not a good
idea since this option already existed and it is dedicated to enable
the Netfilter bridge IP/ARP filtering.
Let's try to fix this mess by:
1) making net/bridge/netfilter/ dependent on the toplevel
CONFIG_NETFILTER option, just like we do with the net/netfilter and
net/ipv{4,6}/netfilter/ directories.
2) Changing 'selects' to 'depends on' NETFILTER_XTABLES for
BRIDGE_NF_EBTABLES. I believe this problem was already before
f5efc69:
warning: (BRIDGE_NF_EBTABLES) selects NETFILTER_XTABLES which has
unmet direct dependencies (NET && INET && NETFILTER)
3) Fix ebtables/nf_tables bridge dependencies by making NF_TABLES_BRIDGE
and BRIDGE_NF_EBTABLES dependent on BRIDGE and NETFILTER:
warning: (NF_TABLES_BRIDGE && BRIDGE_NF_EBTABLES) selects
BRIDGE_NETFILTER which has unmet direct dependencies (NET && BRIDGE &&
NETFILTER && INET && NETFILTER_ADVANCED)
net/built-in.o: In function `br_parse_ip_options':
br_netfilter.c:(.text+0x4a5ba): undefined reference to `ip_options_compile'
br_netfilter.c:(.text+0x4a5ed): undefined reference to `ip_options_rcv_srr'
net/built-in.o: In function `br_nf_pre_routing_finish':
br_netfilter.c:(.text+0x4a8a4): undefined reference to `ip_route_input_noref'
br_netfilter.c:(.text+0x4a987): undefined reference to `ip_route_output_flow'
make: *** [vmlinux] Error 1
Reported-by: Jim Davis <jim.epost@gmail.com>
Pablo Neira Ayuso says:
Netfilter/nftables updates for net-next
The following patchset contains Netfilter/nftables updates for net-next,
most relevantly they are:
1) Add set element update notification via netlink, from Arturo Borrero.
2) Put all object updates in one single message batch that is sent to
kernel-space. Before this patch only rules where included in the batch.
This series also introduces the generic transaction infrastructure so
updates to all objects (tables, chains, rules and sets) are applied in
an all-or-nothing fashion, these series from me.
3) Defer release of objects via call_rcu to reduce the time required to
commit changes. The assumption is that all objects are destroyed in
reverse order to ensure that dependencies betweem them are fulfilled
(ie. rules and sets are destroyed first, then chains, and finally
tables).
4) Allow to match by bridge port name, from Tomasz Bursztyka. This series
include two patches to prepare this new feature.
5) Implement the proper set selection based on the characteristics of the
data. The new infrastructure also allows you to specify your preferences
in terms of memory and computational complexity so the underlying set
type is also selected according to your needs, from Patrick McHardy.
6) Several cleanup patches for nft expressions, including one minor possible
compilation breakage due to missing mark support, also from Patrick.
NFT_META_BRI_IIFNAME to get packet input bridge interface name
NFT_META_BRI_OIFNAME to get packet output bridge interface name
Such meta key are accessible only through NFPROTO_BRIDGE family, on a
dedicated nft meta module: nft_meta_bridge.
Suggested-by: Pablo Neira Ayuso <pablo@netfilter.org>
Signed-off-by: Tomasz Bursztyka <tomasz.bursztyka@linux.intel.com>
All xtables variants suffer from the defect that the copy_to_user()
to copy the counters to user memory may fail after the table has
already been exchanged and thus exposed. Return an error at this
point will result in freeing the already exposed table. Any
subsequent packet processing will result in a kernel panic.
We can't copy the counters before exposing the new tables as we
want provide the counter state after the old table has been
unhooked. Therefore convert this into a silent error.
Cc: Florian Westphal <fw@strlen.de>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Convert the uses of memcpy to ether_addr_copy because
for some architectures it is smaller and faster.
We don't encode argument types into function names and since besides
nft_do_chain() there are only AF-specific versions, there is no risk
of confusion.
Minor nf_chain_type cleanups:
- reorder struct to plug a hoe
- rename struct module member to "owner" for consistency
- rename nf_hookfn array to "hooks" for consistency
- reorder initializers for better readability
In some cases we neither take a reference to the AF info nor to the
chain type, allowing the module to be unloaded while in use.
Add support to register chains to multiple hooks for different address
families for mixed IPv4/IPv6 tables.
Currently the AF-specific hook functions override the chain-type specific
hook functions. That doesn't make too much sense since the chain types
are a special case of the AF-specific hooks.
Make the AF-specific hook functions the default and make the optional
chain type hooks override them.
As a side effect, the necessary code restructuring reduces the code size,
f.i. in case of nf_tables_ipv4.o:
nf_tables_ipv4_init_net | -24
nft_do_chain_ipv4 | -113
2 functions changed, 137 bytes removed, diff: -137
That open brace { should be on the previous line.
Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com>
Spaces required before the open parenthesis '(', before the open
brace '{', after that ',' and around that '?/:'.
Return is not a function, parentheses are not required.
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: netfilter@vger.kernel.org
CC: Pablo Neira Ayuso <pablo@netfilter.org>
CC: Patrick McHardy <kaber@trash.net>
CC: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
This bug was introduced on commit 0898f99a2. This just recovers two
checks that existed before as suggested by Bart De Schuymer.
Signed-off-by: Luís Fernando Cornachioni Estrozi <lestrozi@uolinc.com>
Signed-off-by: Bart De Schuymer <bdschuym@pandora.be>
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nftables
This batch contains fives nf_tables patches for your net-next tree,
they are:
* Fix possible use after free in the module removal path of the
x_tables compatibility layer, from Dan Carpenter.
* Add filter chain type for the bridge family, from myself.
* Fix Kconfig dependencies of the nf_tables bridge family with
the core, from myself.
* Fix sparse warnings in nft_nat, from Tomasz Bursztyka.
* Remove duplicated include in the IPv4 family support for nf_tables,
from Wei Yongjun.
drivers/net/ethernet/emulex/benet/be.h
drivers/net/netconsole.c
net/bridge/br_private.h
Three mostly trivial conflicts.
The net/bridge/br_private.h conflict was a function signature (argument
addition) change overlapping with the extern removals from Joe Perches.
In drivers/net/netconsole.c we had one change adjusting a printk message
whilst another changed "printk(KERN_INFO" into "pr_info(".
Lastly, the emulex change was a new inline function addition overlapping
with Joe Perches's extern removals.
This patch adds the filter chain type which is required to
create filter chains in the bridge family from userspace.
when CONFIG_NF_TABLES[_MODULE] is not enabled,
but CONFIG_NF_TABLES_BRIDGE is enabled:
net/bridge/netfilter/nf_tables_bridge.c: In function 'nf_tables_bridge_init_net':
net/bridge/netfilter/nf_tables_bridge.c:24:5: error: 'struct net' has no member named 'nft'
net/bridge/netfilter/nf_tables_bridge.c:25:9: error: 'struct net' has no member named 'nft'
net/bridge/netfilter/nf_tables_bridge.c:28:2: error: 'struct net' has no member named 'nft'
net/bridge/netfilter/nf_tables_bridge.c:30:34: error: 'struct net' has no member named 'nft'
net/bridge/netfilter/nf_tables_bridge.c:35:11: error: 'struct net' has no member named 'nft'
net/bridge/netfilter/nf_tables_bridge.c: In function 'nf_tables_bridge_exit_net':
net/bridge/netfilter/nf_tables_bridge.c:41:27: error: 'struct net' has no member named 'nft'
net/bridge/netfilter/nf_tables_bridge.c:42:11: error: 'struct net' has no member named 'nft'
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Register family per netnamespace to ensure that sets are
only visible in its approapriate namespace.
This patch adds nftables which is the intended successor of iptables.
This packet filtering framework reuses the existing netfilter hooks,
the connection tracking system, the NAT subsystem, the transparent
proxying engine, the logging infrastructure and the userspace packet
queueing facilities.
In a nutshell, nftables provides a pseudo-state machine with 4 general
purpose registers of 128 bits and 1 specific purpose register to store
verdicts. This pseudo-machine comes with an extensible instruction set,
a.k.a. "expressions" in the nftables jargon. The expressions included
in this patch provide the basic functionality, they are:
* bitwise: to perform bitwise operations.
* byteorder: to change from host/network endianess.
* cmp: to compare data with the content of the registers.
* counter: to enable counters on rules.
* ct: to store conntrack keys into register.
* exthdr: to match IPv6 extension headers.
* immediate: to load data into registers.
* limit: to limit matching based on packet rate.
* log: to log packets.
* meta: to match metainformation that usually comes with the skbuff.
* nat: to perform Network Address Translation.
* payload: to fetch data from the packet payload and store it into
registers.
* reject (IPv4 only): to explicitly close connection, eg. TCP RST.
Using this instruction-set, the userspace utility 'nft' can transform
the rules expressed in human-readable text representation (using a
new syntax, inspired by tcpdump) to nftables bytecode.
nftables also inherits the table, chain and rule objects from
iptables, but in a more configurable way, and it also includes the
original datatype-agnostic set infrastructure with mapping support.
This set infrastructure is enhanced in the follow up patch (netfilter:
nf_tables: add netlink set API).
This patch includes the following components:
* the netlink API: net/netfilter/nf_tables_api.c and
include/uapi/netfilter/nf_tables.h
* the packet filter core: net/netfilter/nf_tables_core.c
* the expressions (described above): net/netfilter/nft_*.c
* the filter tables: arp, IPv4, IPv6 and bridge:
net/ipv4/netfilter/nf_tables_ipv4.c
net/ipv6/netfilter/nf_tables_ipv6.c
net/ipv4/netfilter/nf_tables_arp.c
* the NAT table (IPv4 only):
net/ipv4/netfilter/nf_table_nat_ipv4.c
* the route table (similar to mangle):
net/ipv4/netfilter/nf_table_route_ipv4.c
net/ipv6/netfilter/nf_table_route_ipv6.c
* internal definitions under:
include/net/netfilter/nf_tables.h
include/net/netfilter/nf_tables_core.h
* It also includes an skeleton expression:
net/netfilter/nft_expr_template.c
and the preliminary implementation of the meta target
net/netfilter/nft_meta_target.c
It also includes a change in struct nf_hook_ops to add a new
pointer to store private data to the hook, that is used to store
the rule list per chain.
This patch is based on the patch from Patrick McHardy, plus merged
accumulated cleanups, fixes and small enhancements to the nftables
code that has been done since 2009, which are:
From Patrick McHardy:
* nf_tables: adjust netlink handler function signatures
* nf_tables: only retry table lookup after successful table module load
* nf_tables: fix event notification echo and avoid unnecessary messages
* nft_ct: add l3proto support
* nf_tables: pass expression context to nft_validate_data_load()
* nf_tables: remove redundant definition
* nft_ct: fix maxattr initialization
* nf_tables: fix invalid event type in nf_tables_getrule()
* nf_tables: simplify nft_data_init() usage
* nf_tables: build in more core modules
* nf_tables: fix double lookup expression unregistation
* nf_tables: move expression initialization to nf_tables_core.c
* nf_tables: build in payload module
* nf_tables: use NFPROTO constants
* nf_tables: rename pid variables to portid
* nf_tables: save 48 bits per rule
* nf_tables: introduce chain rename
* nf_tables: check for duplicate names on chain rename
* nf_tables: remove ability to specify handles for new rules
* nf_tables: return error for rule change request
* nf_tables: return error for NLM_F_REPLACE without rule handle
* nf_tables: include NLM_F_APPEND/NLM_F_REPLACE flags in rule notification
* nf_tables: fix NLM_F_MULTI usage in netlink notifications
* nf_tables: include NLM_F_APPEND in rule dumps
From Pablo Neira Ayuso:
* nf_tables: fix stack overflow in nf_tables_newrule
* nf_tables: nft_ct: fix compilation warning
* nf_tables: nft_ct: fix crash with invalid packets
* nft_log: group and qthreshold are 2^16
* nf_tables: nft_meta: fix socket uid,gid handling
* nft_counter: allow to restore counters
* nf_tables: fix module autoload
* nf_tables: allow to remove all rules placed in one chain
* nf_tables: use 64-bits rule handle instead of 16-bits
* nf_tables: fix chain after rule deletion
* nf_tables: improve deletion performance
* nf_tables: add missing code in route chain type
* nf_tables: rise maximum number of expressions from 12 to 128
* nf_tables: don't delete table if in use
* nf_tables: fix basechain release
From Tomasz Bursztyka:
* nf_tables: Add support for changing users chain's name
* nf_tables: Change chain's name to be fixed sized
* nf_tables: Add support for replacing a rule by another one
* nf_tables: Update uapi nftables netlink header documentation
From Florian Westphal:
* nft_log: group is u16, snaplen u32
From Phil Oester:
* nf_tables: operational limit match
Pass the hook ops to the hookfn to allow for generic hook
functions. This change is required by nf_tables.
Convert the memset/memcpy uses of 6 to ETH_ALEN
where appropriate.
Also convert some struct definitions and u8 array
declarations of [6] to ETH_ALEN.
Acked-by: Arend van Spriel <arend@broadcom.com>
The ulog messages leak heap bytes by the means of padding bytes and
incompletely filled string arrays. Fix those by memset(0)'ing the
whole struct before filling it.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Sweep of the simple cases.
Cc: netdev@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Julia Lawall <julia.lawall@lip6.fr>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next
net/netfilter/nf_log.c
The conflict in nf_log.c is that in 'net' we added CONFIG_PROC_FS
protection around foo_proc_entry() calls to fix a build failure,
whereas in Pablo's tree a guard if() test around a call is
remove_proc_entry() was removed. Trivially resolved.
The following patchset contains the first batch of
Netfilter/IPVS updates for your net-next tree, they are:
* Three patches with improvements and code refactorization
for nfnetlink_queue, from Florian Westphal.
* FTP helper now parses replies without brackets, as RFC1123
recommends, from Jeff Mahoney.
* Rise a warning to tell everyone about ULOG deprecation,
NFLOG has been already in the kernel tree for long time
and supersedes the old logging over netlink stub, from
myself.
* Don't panic if we fail to load netfilter core framework,
just bail out instead, from myself.
* Add cond_resched_rcu, used by IPVS to allow rescheduling
while walking over big hashtables, from Simon Horman.
* Change type of IPVS sysctl_sync_qlen_max sysctl to avoid
possible overflow, from Zhang Yanfei.
* Use strlcpy instead of strncpy to skip zeroing of already
initialized area to write the extension names in ebtables,
from Chen Gang.
* Use already existing per-cpu notrack object from xt_CT,
from Eric Dumazet.
* Save explicit socket lookup in xt_socket now that we have
early demux, also from Eric Dumazet.
This target has been superseded by NFLOG. Spot a warning
so we prepare removal in a couple of years.
Acked-by: Gao feng <gaofeng@cn.fujitsu.com>
'name' has already set all zero when it is defined, so not need let
strncpy() to pad it again.
'name' is a string, better always let is NUL terminated, so use
strlcpy() instead of strncpy().
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Acked-by: Bart De Schuymer <bdschuym@pandora.be>
Since (69b34fb netfilter: xt_LOG: add net namespace support
for xt_LOG), we hit this:
[ 4224.708977] BUG: unable to handle kernel NULL pointer dereference at 0000000000000388
[ 4224.709074] IP: [<ffffffff8147f699>] ipt_log_packet+0x29/0x270
when callling log functions from conntrack both in and out
are NULL i.e. the net pointer is invalid.
Adding struct net *net in call to nf_logfn() will secure that
there always is a vaild net ptr.
Reported as netfilter's bugzilla bug 818:
https://bugzilla.netfilter.org/show_bug.cgi?id=818
Reported-by: Ronald <ronald645@gmail.com>
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
The following patchset contains Netfilter and IPVS updates for
your net-next tree, most relevantly they are:
* Add net namespace support to NFLOG, ULOG and ebt_ulog and NFQUEUE.
The LOG and ebt_log target has been also adapted, but they still
depend on the syslog netnamespace that seems to be missing, from
Gao Feng.
* Don't lose indications of congestion in IPv6 fragmentation handling,
from Hannes Frederic Sowa.i
* IPVS conversion to use RCU, including some code consolidation patches
and optimizations, also some from Julian Anastasov.
* cpu fanout support for NFQUEUE, from Holger Eitzenberger.
* Better error reporting to userspace when dropping packets from
all our _*_[xfrm|route]_me_harder functions, from Patrick McHardy.
Add pernet support to ebt_ulog by means of the new nf_log_set
function added in (30e0c6a netfilter: nf_log: prepare net
namespace support for loggers).
This patch also make ulog_buffers and netlink socket
ebtulognl per netns.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Add pernet support to ebt_log by means of the new nf_log_set
Since syslog ns has yet not been implemented, we don't want
the containers to DDOS host's syslogd. So only enable ebt_log
only from init_net and wait for syslog ns support.
This patch adds netns support to nf_log and it prepares netns
support for existing loggers. It is composed of four major
changes.
1) nf_log_register has been split to two functions: nf_log_register
and nf_log_set. The new nf_log_register is used to globally
register the nf_logger and nf_log_set is used for enabling
pernet support from nf_loggers.
Per netns is not yet complete after this patch, it comes in
separate follow up patches.
2) Add net as a parameter of nf_log_bind_pf. Per netns is not
yet complete after this patch, it only allows to bind the
nf_logger to the protocol family from init_net and it skips
other cases.
3) Adapt all nf_log_packet callers to pass netns as parameter.
After this patch, this function only works for init_net.
4) Make the sysctl net/netfilter/nf_log pernet.
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for
an 802.3 frame. Frames with a lower value in the ethernet type field
are Ethernet II.
Also update all the users of this value that David Miller and
I could find to use the new constant.
Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN
should be >= not >.
As suggested by Jesse Gross.
Compile tested only.
Cc: Jesse Gross <jesse@nicira.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Bart De Schuymer <bart.de.schuymer@pandora.be>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netfilter-devel@vger.kernel.org
Cc: bridge@lists.linux-foundation.org
Cc: linux-wireless@vger.kernel.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-media@vger.kernel.org
Cc: dev@openvswitch.org
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Signed-off-by: Simon Horman <horms@verge.net.au>
No need for spinlock to protect the netlink skb in the
ebt_ulog_fini path. We are sure there is noone using it
at that stage.
This uses PTR_RET instead of IS_ERR and PTR_ERR in order to increase
readability.
Signed-off-by: Silviu-Mihai Popescu <silviupopescu1990@gmail.com>
