path: root/net/bridge
2010-07-19bridge: Partially disable netpoll supportHerbert Xu
The new netpoll code in bridging contains use-after-free bugs that are non-trivial to fix. This patch fixes this by removing the code that uses skbs after they're freed. As a consequence, this means that we can no longer call bridge from the netpoll path, so this patch also removes the controller function in order to disable netpoll. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Thanks, Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07bridge: Clear IPCB before possible entry into IP stackHerbert Xu
The bridge protocol lives dangerously by having incestuous relations with the IP stack. In this instance an abomination has been created where a bogus IPCB area from a bridged packet leads to a crash in the IP stack because it's interpreted as IP options. This patch papers over the problem by clearing the IPCB area in that particular spot. To fix this properly we'd also need to parse any IP options if present but I'm way too lazy for that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cheers, Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05bridge br_multicast: BUG: unable to handle kernel NULL pointer dereferenceHerbert Xu
On Tue, Jul 06, 2010 at 08:48:35AM +0800, Herbert Xu wrote: > > bridge: Restore NULL check in br_mdb_ip_get Resend with proper attribution. bridge: Restore NULL check in br_mdb_ip_get Somewhere along the line the NULL check in br_mdb_ip_get went AWOL, causing crashes when we receive an IGMP packet with no multicast table allocated. This patch restores it and ensures all br_mdb_*_get functions use it. Reported-by: Frank Arnold <frank.arnold@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Thanks, Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-17bridge: fdb cleanup runs too oftenstephen hemminger
It is common in end-node, non STP bridges to set forwarding delay to zero; which causes the forwarding database cleanup to run every clock tick. Change to run only as soon as needed or at next ageing timer interval which ever is sooner. Use round_jiffies_up macro rather than attempting round up by changing value. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: Fix OOM crash in deliver_cloneHerbert Xu
The bridge multicast patches introduced an OOM crash in the forward path, when deliver_clone fails to clone the skb. Reported-by: Mark Wagner <mwagner@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-18bridge: fix build for CONFIG_SYSFS disabledRandy Dunlap
Fix build when CONFIG_SYSFS is not enabled: net/bridge/br_if.c:136: error: 'struct net_bridge_port' has no member named 'sysfs_name' Note: dev->name == sysfs_name except when change name is in progress, and we are protected from that by RTNL mutex. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: update sysfs link names if port device names have changedSimon Arlott
Links for each port are created in sysfs using the device name, but this could be changed after being added to the bridge. As well as being unable to remove interfaces after this occurs (because userspace tools don't recognise the new name, and the kernel won't recognise the old name), adding another interface with the old name to the bridge will cause an error trying to create the sysfs link. This fixes the problem by listening for NETDEV_CHANGENAME notifications and renaming the link. https://bugzilla.kernel.org/show_bug.cgi?id=12743 Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: change console message interfacestephen hemminger
Use one set of macro's for all bridge messages. Note: can't use netdev_XXX macro's because bridge is purely virtual and has no device parent. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: netpoll cleanupstephen hemminger
Move code around so that the ifdef for NETPOLL_CONTROLLER don't have to show up in main code path. The control functions should be in helpers that are only compiled if needed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-13netfilter: bridge-netfilter: fix crash in br_nf_forward_finish()Bart De Schuymer
[ 4593.956206] BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 [ 4593.956219] IP: [<ffffffffa03357a4>] br_nf_forward_finish+0x154/0x170 [bridge] [ 4593.956232] PGD 195ece067 PUD 1ba005067 PMD 0 [ 4593.956241] Oops: 0000 [#1] SMP [ 4593.956248] last sysfs file: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/ATK0110:00/hwmon/hwmon0/temp2_label [ 4593.956253] CPU 3 ... [ 4593.956380] Pid: 29512, comm: kvm Not tainted 2.6.34-rc7-net #195 P6T DELUXE/System Product Name [ 4593.956384] RIP: 0010:[<ffffffffa03357a4>] [<ffffffffa03357a4>] br_nf_forward_finish+0x154/0x170 [bridge] [ 4593.956395] RSP: 0018:ffff880001e63b78 EFLAGS: 00010246 [ 4593.956399] RAX: 0000000000000608 RBX: ffff880057181700 RCX: ffff8801b813d000 [ 4593.956402] RDX: 0000000000000000 RSI: 0000000000000002 RDI: ffff880057181700 [ 4593.956406] RBP: ffff880001e63ba8 R08: ffff8801b9d97000 R09: ffffffffa0335650 [ 4593.956410] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801b813d000 [ 4593.956413] R13: ffffffff81ab3940 R14: ffff880057181700 R15: 0000000000000002 [ 4593.956418] FS: 00007fc40d380710(0000) GS:ffff880001e60000(0000) knlGS:0000000000000000 [ 4593.956422] CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b [ 4593.956426] CR2: 0000000000000018 CR3: 00000001ba1d7000 CR4: 00000000000026e0 [ 4593.956429] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 4593.956433] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 4593.956437] Process kvm (pid: 29512, threadinfo ffff8801ba566000, task ffff8801b8003870) [ 4593.956441] Stack: [ 4593.956443] 0000000100000020 ffff880001e63ba0 ffff880001e63ba0 ffff880057181700 [ 4593.956451] <0> ffffffffa0335650 ffffffff81ab3940 ffff880001e63bd8 ffffffffa03350e6 [ 4593.956462] <0> ffff880001e63c40 000000000000024d ffff880057181700 0000000080000000 [ 4593.956474] Call Trace: [ 4593.956478] <IRQ> [ 4593.956488] [<ffffffffa0335650>] ? br_nf_forward_finish+0x0/0x170 [bridge] [ 4593.956496] [<ffffffffa03350e6>] NF_HOOK_THRESH+0x56/0x60 [bridge] [ 4593.956504] [<ffffffffa0335282>] br_nf_forward_arp+0x112/0x120 [bridge] [ 4593.956511] [<ffffffff813f7184>] nf_iterate+0x64/0xa0 [ 4593.956519] [<ffffffffa032f920>] ? br_forward_finish+0x0/0x60 [bridge] [ 4593.956524] [<ffffffff813f722c>] nf_hook_slow+0x6c/0x100 [ 4593.956531] [<ffffffffa032f920>] ? br_forward_finish+0x0/0x60 [bridge] [ 4593.956538] [<ffffffffa032f800>] ? __br_forward+0x0/0xc0 [bridge] [ 4593.956545] [<ffffffffa032f86d>] __br_forward+0x6d/0xc0 [bridge] [ 4593.956550] [<ffffffff813c5d8e>] ? skb_clone+0x3e/0x70 [ 4593.956557] [<ffffffffa032f462>] deliver_clone+0x32/0x60 [bridge] [ 4593.956564] [<ffffffffa032f6b6>] br_flood+0xa6/0xe0 [bridge] [ 4593.956571] [<ffffffffa032f800>] ? __br_forward+0x0/0xc0 [bridge] Don't call nf_bridge_update_protocol() for ARP traffic as skb->nf_bridge isn't used in the ARP case. Reported-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-11Merge branch 'master' of git://dev.medozas.de/linuxPatrick McHardy
2010-05-11netfilter: xtables: change hotdrop pointer to direct modificationJan Engelhardt
Since xt_action_param is writable, let's use it. The pointer to 'bool hotdrop' always worried (8 bytes (64-bit) to write 1 byte!). Surprisingly results in a reduction in size: text data bss filename 5457066 692730 357892 vmlinux.o-prev 5456554 692730 357892 vmlinux.o Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-11netfilter: xtables: deconstify struct xt_action_param for matchesJan Engelhardt
In future, layer-3 matches will be an xt module of their own, and need to set the fragoff and thoff fields. Adding more pointers would needlessy increase memory requirements (esp. so for 64-bit, where pointers are wider). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-11netfilter: xtables: substitute temporary defines by final nameJan Engelhardt
2010-05-11netfilter: xtables: combine struct xt_match_param and xt_target_paramJan Engelhardt
The structures carried - besides match/target - almost the same data. It is possible to combine them, as extensions are evaluated serially, and so, the callers end up a little smaller. text data bss filename -15318 740 104 net/ipv4/netfilter/ip_tables.o +15286 740 104 net/ipv4/netfilter/ip_tables.o -15333 540 152 net/ipv6/netfilter/ip6_tables.o +15269 540 152 net/ipv6/netfilter/ip6_tables.o Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-10Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: net/bridge/br_device.c net/bridge/br_forward.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-06bridge: make bridge support netpollWANG Cong
Based on the previous patch, make bridge support netpoll by: 1) implement the 2 methods to support netpoll for bridge; 2) modify netpoll during forwarding packets via bridge; 3) disable netpoll support of bridge when a netpoll-unabled device is added to bridge; 4) enable netpoll support when all underlying devices support netpoll. Cc: David Miller <davem@davemloft.net> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast_flood cleanupstephen hemminger
Move some declarations around to make it clearer which variables are being used inside loop. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast port group RCU fixstephen hemminger
The recently introduced bridge mulitcast port group list was only partially using RCU correctly. It was missing rcu_dereference() and missing the necessary barrier on deletion. The code should have used one of the standard list methods (list or hlist) instead of open coding a RCU based link list. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast floodstephen hemminger
Fix unsafe usage of RCU. Would never work on Alpha SMP because of lack of rcu_dereference() Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: simplify multicast_add_routerstephen hemminger
By coding slightly differently, there are only two cases to deal with: add at head and add after previous entry. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Revert "bridge: Use hlist_for_each_entry_rcu() in br_multicast_add_router()"David S. Miller
This reverts commit ff65e8275f6c96a5eda57493bd84c4555decf7b3. As explained by Stephen Hemminger, the traversal doesn't require RCU handling as we hold a lock. The list addition et al. calls, on the other hand, do. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: Use hlist_for_each_entry_rcu() in br_multicast_add_router()David S. Miller
Noticed by Michał Mirosław. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: multicast router list manipulationstephen hemminger
I prefer that the hlist be only accessed through the hlist macro objects. Explicit twiddling of links (especially with RCU) exposes the code to future bugs. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: use is_multicast_ether_addrstephen hemminger
Use existing inline function. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: Fix build of ipv6 multicast code.David S. Miller
Based upon a report from Stephen Rothwell: -------------------- net/bridge/br_multicast.c: In function 'br_ip6_multicast_alloc_query': net/bridge/br_multicast.c:469: error: implicit declaration of function 'csum_ipv6_magic' Introduced by commit 08b202b6726459626c73ecfa08fcdc8c3efc76c2 ("bridge br_multicast: IPv6 MLD support") from the net tree. csum_ipv6_magic is declared in net/ip6_checksum.h ... -------------------- Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26bridge br_multicast: Ensure to initialize BR_INPUT_SKB_CB(skb)->mrouters_only.YOSHIFUJI Hideaki / 吉藤英明
Even with commit 32dec5dd0233ebffa9cae25ce7ba6daeb7df4467 ("bridge br_multicast: Don't refer to BR_INPUT_SKB_CB(skb)->mrouters_only without IGMP snooping."), BR_INPUT_SKB_CB(skb)->mrouters_only is not appropriately initialized if IGMP/MLD snooping support is compiled and disabled, so we can see garbage. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23bridge br_multicast: IPv6 MLD support.YOSHIFUJI Hideaki
2010-04-23bridge br_multicast: Make functions less ipv4 dependent.YOSHIFUJI Hideaki
Introduce struct br_ip{} to store ip address and protocol and make functions more generic so that we can support both IPv4 and IPv6 with less pain. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2010-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-6000.c net/core/dev.c
2010-04-20net: Fix various endianness glitchesEric Dumazet
Sparse can help us find endianness bugs, but we need to make some cleanups to be able to more easily spot real bugs. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20bridge: add a missing ntohs()Eric Dumazet
grec_nsrcs is in network order, we should convert to host horder in br_multicast_igmp3_report() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20netfilter: bridge-netfilter: fix refragmenting IP traffic encapsulated in ↵Bart De Schuymer
PPPoE traffic The MTU for IP traffic encapsulated inside PPPoE traffic is smaller than the MTU of the Ethernet device (1500). Connection tracking gathers all IP packets and sometimes will refragment them in ip_fragment(). We then need to subtract the length of the encapsulating header from the mtu used in ip_fragment(). The check in br_nf_dev_queue_xmit() which determines if ip_fragment() has to be called is also updated for the PPPoE-encapsulated packets. nf_bridge_copy_header() is also updated to make sure the PPPoE data length field has the correct value. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15netfilter: bridge-netfilter: Fix MAC header handling with IP DNATBart De Schuymer
- fix IP DNAT on vlan- or pppoe-encapsulated traffic: The functions neigh_hh_output() or dst->neighbour->output() overwrite the complete Ethernet header, although we only need the destination MAC address. For encapsulated packets, they ended up overwriting the encapsulating header. The new code copies the Ethernet source MAC address and protocol number before calling dst->neighbour->output(). The Ethernet source MAC and protocol number are copied back in place in br_nf_pre_routing_finish_bridge_slow(). This also makes the IP DNAT more transparent because in the old scheme the source MAC of the bridge was copied into the source address in the Ethernet header. We also let skb->protocol equal ETH_P_IP resp. ETH_P_IPV6 during the execution of the PF_INET resp. PF_INET6 hooks. - Speed up IP DNAT by calling neigh_hh_bridge() instead of neigh_hh_output(): if dst->hh is available, we already know the MAC address so we can just copy it. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15netfilter: bridge-netfilter: simplify IP DNATBart De Schuymer
Remove br_netfilter.c::br_nf_local_out(). The function br_nf_local_out() was needed because the PF_BRIDGE::LOCAL_OUT hook could be called when IP DNAT happens on to-be-bridged traffic. The new scheme eliminates this mess. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-13netfilter: bridge-netfilter: update a comment in br_forward.c about ↵Bart De Schuymer
ip_fragment() ip_refrag isn't used anymore in the bridge-netfilter code Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-13netfilter: bridge-netfilter: cleanup br_netfilter.cBart De Schuymer
bridge-netfilter: cleanup br_netfilter.c - remove some of the graffiti at the head of br_netfilter.c - remove __br_dnat_complain() - remove KERN_INFO messages when CONFIG_NETFILTER_DEBUG is defined Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-07bridge: Fix IGMP3 report parsingHerbert Xu
The IGMP3 report parsing is looking at the wrong address for group records. This patch fixes it. Reported-by: Banyeer <banyeer@yahoo.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: xtables: change targets to return error codeJan Engelhardt
Part of the transition of done by this semantic patch: // <smpl> @ rule1 @ struct xt_target ops; identifier check; @@ ops.checkentry = check; @@ identifier rule1.check; @@ check(...) { <... -return true; +return 0; ...> } @@ identifier rule1.check; @@ check(...) { <... -return false; +return -EINVAL; ...> } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change matches to return error codeJan Engelhardt
The following semantic patch does part of the transformation: // <smpl> @ rule1 @ struct xt_match ops; identifier check; @@ ops.checkentry = check; @@ identifier rule1.check; @@ check(...) { <... -return true; +return 0; ...> } @@ identifier rule1.check; @@ check(...) { <... -return false; +return -EINVAL; ...> } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change xt_target.checkentry return typeJan Engelhardt
Restore function signatures from bool to int so that we can report memory allocation failures or similar using -ENOMEM rather than always having to pass -EINVAL back. // <smpl> @@ type bool; identifier check, par; @@ -bool check +int check (struct xt_tgchk_param *par) { ... } // </smpl> Minus the change it does to xt_ct_find_proto. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change xt_match.checkentry return typeJan Engelhardt
Restore function signatures from bool to int so that we can report memory allocation failures or similar using -ENOMEM rather than always having to pass -EINVAL back. This semantic patch may not be too precise (checking for functions that use xt_mtchk_param rather than functions referenced by xt_match.checkentry), but reviewed, it produced the intended result. // <smpl> @@ type bool; identifier check, par; @@ -bool check +int check (struct xt_mtchk_param *par) { ... } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: bridge: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The first argument to NF_HOOK* is an nfproto since quite some time. Commit v2.6.27-2457-gfdc9314 was the first to practically start using the new names. Do that now for the remaining NF_HOOK calls. The semantic patch used was: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_THRESH )( -PF_BRIDGE, +NFPROTO_BRIDGE, ...) @@ @@ NF_HOOK( -PF_INET6, +NFPROTO_IPV6, ...) @@ @@ NF_HOOK( -PF_INET, +NFPROTO_IPV4, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: consolidate code into xt_request_find_matchJan Engelhardt
2010-03-25netfilter: xtables: make use of xt_request_find_targetJan Engelhardt
