path: root/net/bridge
2009-07-26net/bridge: use kobject_put to release kobject in br_add_if error pathXiaotian Feng
kobject_init_and_add will alloc memory for kobj->name, so in br_add_if error path, simply use kobject_del will not free memory for kobj->name. Fix by using kobject_put instead, kobject_put will internally calls kobject_del and frees memory for kobj->name. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-26bridge: Use rcu_barrier() instead of syncronize_net() on unload.Jesper Dangaard Brouer
When unloading modules that uses call_rcu() callbacks, then we must use rcu_barrier(). This module uses syncronize_net() which is not enough to be sure that all callback has been completed. Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11bridge: Simplify interface for ATM LANEMichał Mirosław
This patch changes FDB entry check for ATM LANE bridge integration. There's no point in holding a FDB entry around SKB building. br_fdb_get()/br_fdb_put() pair are changed into single br_fdb_test_addr() hook that checks if the addr has FDB entry pointing to other port to the one the request arrived on. FDB entry refcounting is removed as it's not used anywhere else. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11Merge branch 'master' of ↵Patrick McHardy
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6
2009-06-04netfilter: x_tables: added hook number into match extension parameter structure.Evgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->rtable accessorEric Dumazet
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb Delete skb->rtable field Setting rtable is not allowed, just set dst instead as rtable is an alias. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-02Merge branch 'master' of git://dev.medozas.de/linuxPatrick McHardy
2009-05-27bridge: avoid an extra space in br_fdb_update()Jiri Pirko
Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18net: Fix bridgeing sysfs handling of rtnl_lockEric W. Biederman
Holding rtnl_lock when we are unregistering the sysfs files can deadlock if we unconditionally take rtnl_lock in a sysfs file. So fix it with the now familiar patter of: rtnl_trylock and syscall_restart() Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-17bridge: fix initial packet flood if !STPStephen Hemminger
If bridge is configured with no STP and forwarding delay of 0 (which is typical for virtualization) then when link starts it will flood all packets for the first 20 seconds. This bug was introduced by a combination of earlier changes: * forwarding database uses hold time of zero to indicate user wants to always flood packets * optimzation of the case of forwarding delay of 0 avoids the initial timer tick The fix is to just skip all the topology change detection code if kernel STP is not being used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-17bridge: relay bridge multicast pkgs if !STPStephen Hemminger
Currently the bridge catches all STP packets; even if STP is turned off. This prevents other systems (which do have STP turned on) from being able to detect loops in the network. With this patch, if STP is off, then any packet sent to the STP multicast group address is forwarded to all ports. Based on earlier patch by Joakim Tjernlund with changes to go through forwarding (not local chain), and optimization that only last octet needs to be checked. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-08netfilter: xtables: consolidate open-coded logicJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2009-04-20netfilter: bridge: allow fragmentation of VLAN packets traversing a bridgehummerbliss@gmail.com
br_nf_dev_queue_xmit only checks for ETH_P_IP packets for fragmenting but not VLAN packets. This results in dropping of large VLAN packets. This can be observed when connection tracking is enabled. Connection tracking re-assembles fragmented packets, and these have to re-fragmented when transmitting out. Also, make sure only refragmented packets are defragmented as per suggestion from Patrick McHardy. Signed-off-by: Saikiran Madugula <hummerbliss@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-26Merge branch 'master' of ↵David S. Miller
2009-03-26netfilter: fix nf_logger name in ebt_ulog.Eric Leblond
This patch renames the ebt_ulog nf_logger from "ulog" to "ebt_ulog" to be in sync with other modules naming. As this name was currently only used for informational purpose, the renaming should be harmless. Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-26netfilter: fix warning in ebt_ulog init function.Eric Leblond
The ebt_ulog module does not follow the fixed convention about function return. Loading the module is triggering the following message: sys_init_module: 'ebt_ulog'->init suspiciously returned 1, it should follow 0/-E convention sys_init_module: loading module anyway... Pid: 2334, comm: modprobe Not tainted 2.6.29-rc5edenwall0-00883-g199e57b #146 Call Trace: [<c0441b81>] ? printk+0xf/0x16 [<c02311af>] sys_init_module+0x107/0x186 [<c0202cfa>] syscall_call+0x7/0xb The following patch fixes the return treatment in ebt_ulog_init() function. Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-26netfilter: fix warning about invalid const usageEric Leblond
This patch fixes the declaration of the logger structure in ebt_log and ebt_ulog: I forgot to remove the const option from their declaration in the commit ca735b3aaa945626ba65a3e51145bfe4ecd9e222 ("netfilter: use a linked list of loggers"). Pointed-out-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-25bridge: bad error handling when adding invalid ether addressStephen Hemminger
This fixes an crash when empty bond device is added to a bridge. If an interface with invalid ethernet address (all zero) is added to a bridge, then bridge code detects it when setting up the forward databas entry. But the error unwind is broken, the bridge port object can get freed twice: once when ref count went to zeo, and once by kfree. Since object is never really accessible, just free it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-24Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-02-24netlink: change nlmsg_notify() return value logicPablo Neira Ayuso
This patch changes the return value of nlmsg_notify() as follows: If NETLINK_BROADCAST_ERROR is set by any of the listeners and an error in the delivery happened, return the broadcast error; else if there are no listeners apart from the socket that requested a change with the echo flag, return the result of the unicast notification. Thus, with this patch, the unicast notification is handled in the same way of a broadcast listener that has set the NETLINK_BROADCAST_ERROR socket flag. This patch is useful in case that the caller of nlmsg_notify() wants to know the result of the delivery of a netlink notification (including the broadcast delivery) and take any action in case that the delivery failed. For example, ctnetlink can drop packets if the event delivery failed to provide reliable logging and state-synchronization at the cost of dropping packets. This patch also modifies the rtnetlink code to ignore the return value of rtnl_notify() in all callers. The function rtnl_notify() (before this patch) returned the error of the unicast notification which makes rtnl_set_sk_err() reports errors to all listeners. This is not of any help since the origin of the change (the socket that requested the echoing) notices the ENOBUFS error if the notification fails and should resync itself. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18netfilter: ebtables: remove unneeded initializationsStephen Hemminger
The initialization of the lock element is not needed since the lock is always initialized in ebt_register_table. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-02-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/gianfar.c
2009-02-09bridge: Fix LRO crash with tunHerbert Xu
> Kernel BUG at drivers/net/tun.c:444 > invalid opcode: 0000 [1] SMP > last sysfs file: /class/net/lo/ifindex > CPU 0 > Modules linked in: tun ipt_MASQUERADE iptable_nat ip_nat xt_state ip_conntrack > nfnetlink ipt_REJECT xt_tcpudp iptable_filter d > Pid: 6912, comm: qemu-kvm Tainted: G 2.6.18-128.el5 #1 > RIP: 0010:[<ffffffff886f57b0>] [<ffffffff886f57b0>] > :tun:tun_chr_readv+0x2b1/0x3a6 > RSP: 0018:ffff8102202c5e48 EFLAGS: 00010246 > RAX: 0000000000000000 RBX: ffff8102202c5e98 RCX: 0000000004010000 > RDX: ffff810227063680 RSI: ffff8102202c5e9e RDI: ffff8102202c5e92 > RBP: 0000000000010ff6 R08: 0000000000000000 R09: 0000000000000001 > R10: ffff8102202c5e94 R11: 0000000000000202 R12: ffff8102275357c0 > R13: ffff81022755e500 R14: 0000000000000000 R15: ffff8102202c5ef8 > FS: 00002ae4398db980(0000) GS:ffffffff803ac000(0000) knlGS:0000000000000000 > CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b > CR2: 00002ae4ab514000 CR3: 0000000221344000 CR4: 00000000000026e0 > Process qemu-kvm (pid: 6912, threadinfo ffff8102202c4000, task > ffff81022e58d820) > Stack: 00000000498735cb ffff810229d1a3c0 0000000000000000 ffff81022e58d820 > ffffffff8008a461 ffff81022755e528 ffff81022755e528 ffffffff8009f925 > 000005ea05ea0000 ffff8102209d0000 00001051143e1600 ffffffff8003c00e > Call Trace: > [<ffffffff8008a461>] default_wake_function+0x0/0xe > [<ffffffff8009f925>] enqueue_hrtimer+0x55/0x70 > [<ffffffff8003c00e>] hrtimer_start+0xbc/0xce > [<ffffffff886f58bf>] :tun:tun_chr_read+0x1a/0x1f > [<ffffffff8000b3f3>] vfs_read+0xcb/0x171 > [<ffffffff800117d4>] sys_read+0x45/0x6e > [<ffffffff8005d116>] system_call+0x7e/0x83 > > > Code: 0f 0b 68 40 62 6f 88 c2 bc 01 f6 42 0a 08 74 0c 80 4c 24 41 > RIP [<ffffffff886f57b0>] :tun:tun_chr_readv+0x2b1/0x3a6 > RSP <ffff8102202c5e48> > <0>Kernel panic - not syncing: Fatal exception This crashed when an LRO packet generated by bnx2x reached a tun device through the bridge. We're supposed to drop it at the bridge. However, because the check was placed in br_forward instead of __br_forward, it's only effective if we are sending the packet through a single port. This patch fixes it by moving the check into __br_forward. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 05/09: ebtables: fix inversion in match codeJan Engelhardt
Commit 8cc784ee (netfilter: change return types of match functions for ebtables extensions) broke ebtables matches by inverting the sense of match/nomatch. Reported-by: Matt Cross <matthltc@us.ibm.com> Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 03/09: bridge: Disable PPPOE/VLAN processing by defaultHerbert Xu
The PPPOE/VLAN processing code in the bridge netfilter is broken by design. The VLAN tag and the PPPOE session ID are an integral part of the packet flow information, yet they're completely ignored by the bridge netfilter. This is potentially a security hole as it treats all VLANs and PPPOE sessions as the same. What's more, it's actually broken for PPPOE as the bridge netfilter tries to trim the packets to the IP length without adjusting the PPPOE header (and adjusting the PPPOE header isn't much better since the PPPOE peer may require the padding to be present). Therefore we should disable this by default. It does mean that people relying on this feature may lose networking depending on how their bridge netfilter rules are configured. However, IMHO the problems this code causes are serious enough to warrant this. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12netfilter 02/09: bridge: Fix handling of non-IP packets in FORWARD/POST_ROUTINGHerbert Xu
Currently the bridge FORWARD/POST_ROUTING chains treats all non-IPv4 packets as IPv6. This packet fixes that by returning NF_ACCEPT on non-IP packets instead, just as is done in PRE_ROUTING. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11net/bridge/netfilter: move a dereference below a NULL testJulia Lawall
In each case, if the NULL test is necessary, then the dereference should be moved below the NULL test. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; expression E; identifier i,fld; statement S; @@ - T i = E->fld; + T i; ... when != E when != i if (E == NULL) S + i = E->fld; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-28Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6 Conflicts: net/netfilter/nf_conntrack_netlink.c
2008-11-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/hp-plus.c drivers/net/wireless/ath5k/base.c drivers/net/wireless/ath9k/recv.c net/wireless/reg.c
2008-11-24bridge: netfilter: fix update_pmtu crash with GREHerbert Xu
As GRE tries to call the update_pmtu function on skb->dst and bridge supplies an skb->dst that has a NULL ops field, all is not well. This patch fixes this by giving the bridge device an ops field with an update_pmtu function. For the moment I've left all other fields blank but we can fill them in later should the need arise. Based on report and patch by Philip Craig. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19bridge: convert to net_device_opsStephen Hemminger
Convert to net_device_ops function table. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-4Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-04netfilter: netns ebtables: br_nf_pre_routing_finish() fixupAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-04netfilter: netns ebtables: ebtable_nat in netnsAlexey Dobriyan
2008-11-04netfilter: netns ebtables: ebtable_filter in netnsAlexey Dobriyan
2008-11-04netfilter: netns ebtables: ebtable_broute in netnsAlexey Dobriyan
2008-11-04netfilter: netns ebtables: more cleanup during ebt_unregister_table()Alexey Dobriyan
Now that ebt_unregister_table() can be called during netns stop, and module pinning scheme can't prevent netns stop, do table cleanup by hand. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-04netfilter: netns ebtables: part 2Alexey Dobriyan
* return ebt_table from ebt_register_table(), module code will save it into per-netns data for unregistration * duplicate ebt_table at the very beginning of registration -- it's added into list, so one ebt_table wouldn't end up in many lists (and each netns has different one) * introduce underscored tables in individial modules, this is temporary to not break bisection. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-04netfilter: netns ebtables: part 1Alexey Dobriyan
* propagate netns from userspace, register table in passed netns * remporarily register every ebt_table in init_net P. S.: one needs to add ".netns_ok = 1" to igmp_protocol to test with ebtables(8) in netns. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
2008-10-28net: remove NIP6(), NIP6_FMT, NIP6_SEQFMT and final usersHarvey Harrison
Open code NIP6_FMT in the one call inside sscanf and one user of NIP6() that could use %p6 in the netfilter code. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-23net: Fix disjunct computation of netdev featuresHerbert Xu
My change commit e2a6b85247aacc52d6ba0d9b37a99b8d1a3e0d83 net: Enable TSO if supported by at least one device didn't do what was intended because the netdev_compute_features function was designed for conjunctions. So what happened was that it would simply take the TSO status of the last constituent device. This patch extends it to support both conjunctions and disjunctions under the new name of netdev_increment_features. It also adds a new function netdev_fix_features which does the sanity checking that usually occurs upon registration. This ensures that the computation doesn't result in an illegal combination since this checking is absent when the change is initiated via ethtool. The two users of netdev_compute_features have been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-20netfilter: replace old NF_ARP calls with NFPROTO_ARPJan Engelhardt
(Supplements: ee999d8b9573df1b547aacdc6d79f86eb79c25cd) NFPROTO_ARP actually has a different value from NF_ARP, so ensure all callers use the new value so that packets _do_ get delivered to the registered hooks. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)Johannes Berg
Some code here depends on CONFIG_KMOD to not try to load protocol modules or similar, replace by CONFIG_MODULES where more than just request_module depends on CONFIG_KMOD and and also use try_then_request_module in ebtables. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-14netfilter: fix ebtables dependenciesPatrick McHardy
Ingo Molnar reported a build error with ebtables: ERROR: "ebt_register_table" [net/bridge/netfilter/ebtable_filter.ko] undefined! ERROR: "ebt_do_table" [net/bridge/netfilter/ebtable_filter.ko] undefined! ERROR: "ebt_unregister_table" [net/bridge/netfilter/ebtable_filter.ko] undefined! ERROR: "ebt_register_table" [net/bridge/netfilter/ebtable_broute.ko] undefined! ERROR: "ebt_do_table" [net/bridge/netfilter/ebtable_broute.ko] undefined! ERROR: "ebt_unregister_table" [net/bridge/netfilter/ebtable_broute.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 This reason is a missing dependencies that got lost during Kconfig cleanups. Restore it. Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
