path: root/net/bridge
2014-02-10bridge: Prevent possible race condition in br_fdb_change_mac_addressToshiaki Makita
br_fdb_change_mac_address() calls fdb_insert()/fdb_delete() without br->hash_lock. These hash list updates are racy with br_fdb_update()/br_fdb_cleanup(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Properly check if local fdb entry can be deleted when deleting vlanToshiaki Makita
Vlan codes unconditionally delete local fdb entries. We should consider the possibility that other ports have the same address and vlan. Example of problematic case: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 brctl addif br0 eth1 # br0 will have mac address 12:34:56:78:90:ab bridge vlan add dev eth0 vid 10 bridge vlan add dev eth1 vid 10 bridge vlan add dev br0 vid 10 self We will have fdb entry such that f->dst == eth0, f->vlan_id == 10 and f->addr == 12:34:56:78:90:ab at this time. Next, delete eth0 vlan 10. bridge vlan del dev eth0 vid 10 In this case, we still need the entry for br0, but it will be deleted. Note that br0 needs the entry even though its mac address is not set manually. To delete the entry with proper condition checking, fdb_delete_local() is suitable to use. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Properly check if local fdb entry can be deleted in ↵Toshiaki Makita
br_fdb_delete_by_port br_fdb_delete_by_port() doesn't care about vlan and mac address of the bridge device. As the check is almost the same as mac address changing, slightly modify fdb_delete_local() and use it. Note that we can always set added_by_user to 0 in fdb_delete_local() because - br_fdb_delete_by_port() calls fdb_delete_local() for local entries regardless of its added_by_user. In this case, we have to check if another port has the same address and vlan, and if found, we have to create the entry (by changing dst). This is kernel-added entry, not user-added. - br_fdb_changeaddr() doesn't call fdb_delete_local() for user-added entry. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
br_fdb_change_mac_address br_fdb_change_mac_address() doesn't check if the local entry has the same address as any of bridge ports. Although I'm not sure when it is beneficial, current implementation allow the bridge device to receive any mac address of its ports. To preserve this behavior, we have to check if the mac address of the entry being deleted is identical to that of any port. As this check is almost the same as that in br_fdb_changeaddr(), create a common function fdb_delete_local() and call it from br_fdb_changeadddr() and br_fdb_change_mac_address(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to check if a local fdb entry can be deletedToshiaki Makita
We should take into account the followings when deleting a local fdb entry. - nbp_vlan_find() can be used only when vid != 0 to check if an entry is deletable, because a fdb entry with vid 0 can exist at any time while nbp_vlan_find() always return false with vid 0. Example of problematic case: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address 12:34:56:78:90:ab brctl addif br0 eth0 brctl addif br0 eth1 ip link set eth0 address aa:bb:cc:dd:ee:ff Then, the fdb entry 12:34:56:78:90:ab will be deleted even though the bridge port eth1 still has that address. - The port to which the bridge device is attached might needs a local entry if its mac address is set manually. Example of problematic case: ip link set eth0 address 12:34:56:78:90:ab brctl addif br0 eth0 ip link set br0 address 12:34:56:78:90:ab ip link set eth0 address aa:bb:cc:dd:ee:ff Then, the fdb still must have the entry 12:34:56:78:90:ab, but it will be deleted. We can use br->dev->addr_assign_type to check if the address is manually set or not, but I propose another approach. Since we delete and insert local entries whenever changing mac address of the bridge device, we can change dst of the entry to NULL regardless of addr_assign_type when deleting an entry associated with a certain port, and if it is found to be unnecessary later, then delete it. That is, if changing mac address of a port, the entry might be changed to its dst being NULL first, but is eventually deleted when recalculating and changing bridge id. This approach is especially useful when we want to share the code with deleting vlan in which the bridge device might want such an entry regardless of addr_assign_type, and makes things easy because we don't have to consider if mac address of the bridge device will be changed or not at the time we delete a local entry of a port, which means fdb code will not be bothered even if the bridge id calculating logic is changed in the future. Also, this change reduces inconsistent state, where frames whose dst is the mac address of the bridge, can't reach the bridge because of premature fdb entry deletion. This change reduces the possibility that the bridge device replies unreachable mac address to arp requests, which could occur during the short window between calling del_nbp() and br_stp_recalculate_bridge_id() in br_del_if(). This will effective after br_fdb_delete_by_port() starts to use the same code by following patch. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Change local fdb entries whenever mac address of bridge device changesToshiaki Makita
Vlan code may need fdb change when changing mac address of bridge device even if it is caused by the mac address changing of a bridge port. Example configuration: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 brctl addif br0 eth1 # br0 will have mac address 12:34:56:78:90:ab bridge vlan add dev br0 vid 10 self bridge vlan add dev eth0 vid 10 We will have fdb entry such that f->dst == NULL, f->vlan_id == 10 and f->addr == 12:34:56:78:90:ab at this time. Next, change the mac address of eth0 to greater value. ip link set eth0 address ee:ff:12:34:56:78 Then, mac address of br0 will be recalculated and set to aa:bb:cc:dd:ee:ff. However, an entry aa:bb:cc:dd:ee:ff will not be created and we will be not able to communicate using br0 on vlan 10. Address this issue by deleting and adding local entries whenever changing the mac address of the bridge device. If there already exists an entry that has the same address, for example, in case that br_fdb_changeaddr() has already inserted it, br_fdb_change_mac_address() will simply fail to insert it and no duplicated entry will be made, as it was. This approach also needs br_add_if() to call br_fdb_insert() before br_stp_recalculate_bridge_id() so that we don't create an entry whose dst == NULL in this function to preserve previous behavior. Note that this is a slight change in behavior where the bridge device can receive the traffic to the new address before calling br_stp_recalculate_bridge_id() in br_add_if(). However, it is not a problem because we have already the address on the new port and such a way to insert new one before recalculating bridge id is taken in br_device_event() as well. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to find old local fdb entries in br_fdb_change_mac_addressToshiaki Makita
We have been always failed to delete the old entry at br_fdb_change_mac_address() because br_set_mac_address() updates dev->dev_addr before calling br_fdb_change_mac_address() and br_fdb_change_mac_address() uses dev->dev_addr to find the old entry. That update of dev_addr is completely unnecessary because the same work is done in br_stp_change_bridge_id() which is called right away after calling br_fdb_change_mac_address(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to insert new local fdb entries in br_fdb_changeaddrToshiaki Makita
Since commit bc9a25d21ef8 ("bridge: Add vlan support for local fdb entries"), br_fdb_changeaddr() has inserted a new local fdb entry only if it can find old one. But if we have two ports where they have the same address or user has deleted a local entry, there will be no entry for one of the ports. Example of problematic case: ip link set eth0 address aa:bb:cc:dd:ee:ff ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 brctl addif br0 eth1 # eth1 will not have a local entry due to dup. ip link set eth1 address 12:34:56:78:90:ab Then, the new entry for the address 12:34:56:78:90:ab will not be created, and the bridge device will not be able to communicate. Insert new entries regardless of whether we can find old entries or not. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-10bridge: Fix the way to find old local fdb entries in br_fdb_changeaddrToshiaki Makita
br_fdb_changeaddr() assumes that there is at most one local entry per port per vlan. It used to be true, but since commit 36fd2b63e3b4 ("bridge: allow creating/deleting fdb entries via netlink"), it has not been so. Therefore, the function might fail to search a correct previous address to be deleted and delete an arbitrary local entry if user has added local entries manually. Example of problematic case: ip link set eth0 address ee:ff:12:34:56:78 brctl addif br0 eth0 bridge fdb add 12:34:56:78:90:ab dev eth0 master ip link set eth0 address aa:bb:cc:dd:ee:ff Then, the address 12:34:56:78:90:ab might be deleted instead of ee:ff:12:34:56:78, the original mac address of eth0. Address this issue by introducing a new flag, added_by_user, to struct net_bridge_fdb_entry. Note that br_fdb_delete_by_port() has to set added_by_user to 0 in cases like: ip link set eth0 address 12:34:56:78:90:ab ip link set eth1 address aa:bb:cc:dd:ee:ff brctl addif br0 eth0 bridge fdb add aa:bb:cc:dd:ee:ff dev eth0 master brctl addif br0 eth1 brctl delif br0 eth0 In this case, kernel should delete the user-added entry aa:bb:cc:dd:ee:ff, but it also should have been added by "brctl addif br0 eth1" originally, so we don't delete it and treat it a new kernel-created entry. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06bridge: fix netconsole setup over bridgeCong Wang
Commit 93d8bf9fb8f3 ("bridge: cleanup netpoll code") introduced a check in br_netpoll_enable(), but this check is incorrect for br_netpoll_setup(). This patch moves the code after the check into __br_netpoll_enable() and calls it in br_netpoll_setup(). For br_add_if(), the check is still needed. Fixes: 93d8bf9fb8f3 ("bridge: cleanup netpoll code") Cc: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Tested-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-22bridge: Remove unnecessary vlan_put_tag in br_handle_vlanToshiaki Makita
br_handle_vlan() pushes HW accelerated vlan tag into skbuff when outgoing port is the bridge device. This is unnecessary because __netif_receive_skb_core() can handle skbs with HW accelerated vlan tag. In current implementation, __netif_receive_skb_core() needs to extract the vlan tag embedded in skb data. This could cause low network performance especially when receiving frames at a high frame rate on the bridge device. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13bridge: move br_net_exit() to br.cWANG Cong
And it can become static. Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-09netfilter: nf_tables: rename nft_do_chain_pktinfo() to nft_do_chain()Patrick McHardy
We don't encode argument types into function names and since besides nft_do_chain() there are only AF-specific versions, there is no risk of confusion. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-01-09netfilter: nf_tables: minor nf_chain_type cleanupsPatrick McHardy
Minor nf_chain_type cleanups: - reorder struct to plug a hoe - rename struct module member to "owner" for consistency - rename nf_hookfn array to "hooks" for consistency - reorder initializers for better readability Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-01-09netfilter: nf_tables: constify chain type definitions and pointersPatrick McHardy
2014-01-09netfilter: nf_tables: add missing module references to chain typesPatrick McHardy
In some cases we neither take a reference to the AF info nor to the chain type, allowing the module to be unloaded while in use. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-01-07netfilter: nf_tables: add support for multi family tablesPatrick McHardy
Add support to register chains to multiple hooks for different address families for mixed IPv4/IPv6 tables. Signed-off-by: Patrick McHardy <kaber@trash.net>
2014-01-07netfilter: nf_tables: make chain types override the default AF functionsPatrick McHardy
Currently the AF-specific hook functions override the chain-type specific hook functions. That doesn't make too much sense since the chain types are a special case of the AF-specific hooks. Make the AF-specific hook functions the default and make the optional chain type hooks override them. As a side effect, the necessary code restructuring reduces the code size, f.i. in case of nf_tables_ipv4.o: nf_tables_ipv4_init_net | -24 nft_do_chain_ipv4 | -113 2 functions changed, 137 bytes removed, diff: -137 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06bridge: use DEVICE_ATTR_xx macrossfeldma@cumulusnetworks.com
Use DEVICE_ATTR_RO/RW macros to simplify bridge sysfs attribute definitions. Signed-off-by: Scott Feldman <sfeldma@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06bridge: use spin_lock_bh() in br_multicast_set_hash_maxCurt Brune
br_multicast_set_hash_max() is called from process context in net/bridge/br_sysfs_br.c by the sysfs store_hash_max() function. br_multicast_set_hash_max() calls spin_lock(&br->multicast_lock), which can deadlock the CPU if a softirq that also tries to take the same lock interrupts br_multicast_set_hash_max() while the lock is held . This can happen quite easily when any of the bridge multicast timers expire, which try to take the same lock. The fix here is to use spin_lock_bh(), preventing other softirqs from executing on this CPU. Steps to reproduce: 1. Create a bridge with several interfaces (I used 4). 2. Set the "multicast query interval" to a low number, like 2. 3. Enable the bridge as a multicast querier. 4. Repeatedly set the bridge hash_max parameter via sysfs. # brctl addbr br0 # brctl addif br0 eth1 eth2 eth3 eth4 # brctl setmcqi br0 2 # brctl setmcquerier br0 1 # while true ; do echo 4096 > /sys/class/net/br0/bridge/hash_max; done Signed-off-by: Curt Brune <curt@cumulusnetworks.com> Signed-off-by: Scott Feldman <sfeldma@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04net: unify the pcpu_tstats and br_cpu_netstats as oneLi RongQing
They are same, so unify them as one, pcpu_sw_netstats. Define pcpu_sw_netstat in netdevice.h, remove pcpu_tstats from if_tunnel and remove br_cpu_netstats from br_private.h Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-01netlink: cleanup rntl_af_registerstephen hemminger
The function __rtnl_af_register is never called outside this code, and the return value is always 0. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19bridge: change the position of '{' to the pre linetanxiaojun
That open brace { should be on the previous line. Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19bridge: change "foo* bar" to "foo *bar"tanxiaojun
"foo * bar" should be "foo *bar". Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19bridge: add space before '(/{', after ',', etc.tanxiaojun
Spaces required before the open parenthesis '(', before the open brace '{', after that ',' and around that '?/:'. Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19bridge: remove unnecessary parenthesestanxiaojun
Return is not a function, parentheses are not required. Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19bridge: remove unnecessary condition judgmenttanxiaojun
Because err is always negative, remove unnecessary condition judgment. Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18bridge: spelling fixestanxiaojun
Fix spelling errors in bridge driver. Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Acked-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-10net: more spelling fixesstephen hemminger
Various spelling fixes in networking stack Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Merge 'net' into 'net-next' to get the AF_PACKET bug fix that Daniel's direct transmit changes depend upon. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06br: fix use of ->rx_handler_data in code executed on non-rx_handler pathJiri Pirko
br_stp_rcv() is reached by non-rx_handler path. That means there is no guarantee that dev is bridge port and therefore simple NULL check of ->rx_handler_data is not enough. There is need to check if dev is really bridge port and since only rcu read lock is held here, do it by checking ->rx_handler pointer. Note that synchronize_net() in netdev_rx_handler_unregister() ensures this approach as valid. Introduced originally by: commit f350a0a87374418635689471606454abc7beaa3a "bridge: use rx_handler_data pointer to store net_bridge_port pointer" Fixed but not in the best way by: commit b5ed54e94d324f17c97852296d61a143f01b227a "bridge: fix RCU races with bridge port" Reintroduced by: commit 716ec052d2280d511e10e90ad54a86f5b5d4dcc2 "bridge: fix NULL pointer deref of br_port_get_rcu" Please apply to stable trees as well. Thanks. RH bugzilla reference: https://bugzilla.redhat.com/show_bug.cgi?id=1025770 Reported-by: Laine Stump <laine@redhat.com> Debugged-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06netfilter: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: netfilter@vger.kernel.org CC: Pablo Neira Ayuso <pablo@netfilter.org> CC: Patrick McHardy <kaber@trash.net> CC: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-21Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== netfilter fixes for net The following patchset contains fixes for your net tree, they are: * Remove extra quote from connlimit configuration in Kconfig, from Randy Dunlap. * Fix missing mss option in syn packets sent to the backend in our new synproxy target, from Martin Topholm. * Use window scale announced by client when sending the forged syn to the backend, from Martin Topholm. * Fix IPv6 address comparison in ebtables, from Luís Fernando Cornachioni Estrozi. * Fix wrong endianess in sequence adjustment which breaks helpers in NAT configurations, from Phil Oester. * Fix the error path handling of nft_compat, from me. * Make sure the global conntrack counter is decremented after the object has been released, also from me. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20bridge: flush br's address entry in fdb when remove theDing Tianhong
bridge dev When the following commands are executed: brctl addbr br0 ifconfig br0 hw ether <addr> rmmod bridge The calltrace will occur: [ 563.312114] device eth1 left promiscuous mode [ 563.312188] br0: port 1(eth1) entered disabled state [ 563.468190] kmem_cache_destroy bridge_fdb_cache: Slab cache still has objects [ 563.468197] CPU: 6 PID: 6982 Comm: rmmod Tainted: G O 3.12.0-0.7-default+ #9 [ 563.468199] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 563.468200] 0000000000000880 ffff88010f111e98 ffffffff814d1c92 ffff88010f111eb8 [ 563.468204] ffffffff81148efd ffff88010f111eb8 0000000000000000 ffff88010f111ec8 [ 563.468206] ffffffffa062a270 ffff88010f111ed8 ffffffffa063ac76 ffff88010f111f78 [ 563.468209] Call Trace: [ 563.468218] [<ffffffff814d1c92>] dump_stack+0x6a/0x78 [ 563.468234] [<ffffffff81148efd>] kmem_cache_destroy+0xfd/0x100 [ 563.468242] [<ffffffffa062a270>] br_fdb_fini+0x10/0x20 [bridge] [ 563.468247] [<ffffffffa063ac76>] br_deinit+0x4e/0x50 [bridge] [ 563.468254] [<ffffffff810c7dc9>] SyS_delete_module+0x199/0x2b0 [ 563.468259] [<ffffffff814e0922>] system_call_fastpath+0x16/0x1b [ 570.377958] Bridge firewalling registered --------------------------- cut here ------------------------------- The reason is that when the bridge dev's address is changed, the br_fdb_change_mac_address() will add new address in fdb, but when the bridge was removed, the address entry in the fdb did not free, the bridge_fdb_cache still has objects when destroy the cache, Fix this by flushing the bridge address entry when removing the bridge. v2: according to the Toshiaki Makita and Vlad's suggestion, I only delete the vlan0 entry, it still have a leak here if the vlan id is other number, so I need to call fdb_delete_by_port(br, NULL, 1) to flush all entries whose dst is NULL for the bridge. Suggested-by: Toshiaki Makita <toshiaki.makita1@gmail.com> Suggested-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Mostly these are fixes for fallout due to merge window changes, as well as cures for problems that have been with us for a much longer period of time" 1) Johannes Berg noticed two major deficiencies in our genetlink registration. Some genetlink protocols we passing in constant counts for their ops array rather than something like ARRAY_SIZE(ops) or similar. Also, some genetlink protocols were using fixed IDs for their multicast groups. We have to retain these fixed IDs to keep existing userland tools working, but reserve them so that other multicast groups used by other protocols can not possibly conflict. In dealing with these two problems, we actually now use less state management for genetlink operations and multicast groups. 2) When configuring interface hardware timestamping, fix several drivers that simply do not validate that the hwtstamp_config value is one the driver actually supports. From Ben Hutchings. 3) Invalid memory references in mwifiex driver, from Amitkumar Karwar. 4) In dev_forward_skb(), set the skb->protocol in the right order relative to skb_scrub_packet(). From Alexei Starovoitov. 5) Bridge erroneously fails to use the proper wrapper functions to make calls to netdev_ops->ndo_vlan_rx_{add,kill}_vid. Fix from Toshiaki Makita. 6) When detaching a bridge port, make sure to flush all VLAN IDs to prevent them from leaking, also from Toshiaki Makita. 7) Put in a compromise for TCP Small Queues so that deep queued devices that delay TX reclaim non-trivially don't have such a performance decrease. One particularly problematic area is 802.11 AMPDU in wireless. From Eric Dumazet. 8) Fix crashes in tcp_fastopen_cache_get(), we can see NULL socket dsts here. Fix from Eric Dumzaet, reported by Dave Jones. 9) Fix use after free in ipv6 SIT driver, from Willem de Bruijn. 10) When computing mergeable buffer sizes, virtio-net fails to take the virtio-net header into account. From Michael Dalton. 11) Fix seqlock deadlock in ip4_datagram_connect() wrt. statistic bumping, this one has been with us for a while. From Eric Dumazet. 12) Fix NULL deref in the new TIPC fragmentation handling, from Erik Hugne. 13) 6lowpan bit used for traffic classification was wrong, from Jukka Rissanen. 14) macvlan has the same issue as normal vlans did wrt. propagating LRO disabling down to the real device, fix it the same way. From Michal Kubecek. 15) CPSW driver needs to soft reset all slaves during suspend, from Daniel Mack. 16) Fix small frame pacing in FQ packet scheduler, from Eric Dumazet. 17) The xen-netfront RX buffer refill timer isn't properly scheduled on partial RX allocation success, from Ma JieYue. 18) When ipv6 ping protocol support was added, the AF_INET6 protocol initialization cleanup path on failure was borked a little. Fix from Vlad Yasevich. 19) If a socket disconnects during a read/recvmsg/recvfrom/etc that blocks we can do the wrong thing with the msg_name we write back to userspace. From Hannes Frederic Sowa. There is another fix in the works from Hannes which will prevent future problems of this nature. 20) Fix route leak in VTI tunnel transmit, from Fan Du. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits) genetlink: make multicast groups const, prevent abuse genetlink: pass family to functions using groups genetlink: add and use genl_set_err() genetlink: remove family pointer from genl_multicast_group genetlink: remove genl_unregister_mc_group() hsr: don't call genl_unregister_mc_group() quota/genetlink: use proper genetlink multicast APIs drop_monitor/genetlink: use proper genetlink multicast APIs genetlink: only pass array to genl_register_family_with_ops() tcp: don't update snd_nxt, when a socket is switched from repair mode atm: idt77252: fix dev refcnt leak xfrm: Release dst if this dst is improper for vti tunnel netlink: fix documentation typo in netlink_set_err() be2net: Delete secondary unicast MAC addresses during be_close be2net: Fix unconditional enabling of Rx interface options net, virtio_net: replace the magic value ping: prevent NULL pointer dereference on write to msg_name bnx2x: Prevent "timeout waiting for state X" bnx2x: prevent CFC attention bnx2x: Prevent panic during DMAE timeout ...
2013-11-19netfilter: ebt_ip6: fix source and destination matchingLuís Fernando Cornachioni Estrozi
This bug was introduced on commit 0898f99a2. This just recovers two checks that existed before as suggested by Bart De Schuymer. Signed-off-by: Luís Fernando Cornachioni Estrozi <lestrozi@uolinc.com> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-11-14bridge: Fix memory leak when deleting bridge with vlan filtering enabledToshiaki Makita
We currently don't call br_vlan_flush() when deleting a bridge, which leads to memory leak if br->vlan_info is allocated. Steps to reproduce: while : do brctl addbr br0 bridge vlan add dev br0 vid 10 self brctl delbr br0 done We can observe the cache size of corresponding slab entry (as kmalloc-2048 in SLUB) is increased. kmemleak output: unreferenced object 0xffff8800b68a7000 (size 2048): comm "bridge", pid 2086, jiffies 4295774704 (age 47.656s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 48 9b 36 00 88 ff ff .........H.6.... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff815eb6ae>] kmemleak_alloc+0x4e/0xb0 [<ffffffff8116a1ca>] kmem_cache_alloc_trace+0xca/0x220 [<ffffffffa03eddd6>] br_vlan_add+0x66/0xe0 [bridge] [<ffffffffa03e543c>] br_setlink+0x2dc/0x340 [bridge] [<ffffffff8150e481>] rtnl_bridge_setlink+0x101/0x200 [<ffffffff8150d9d9>] rtnetlink_rcv_msg+0x99/0x260 [<ffffffff81528679>] netlink_rcv_skb+0xa9/0xc0 [<ffffffff8150d938>] rtnetlink_rcv+0x28/0x30 [<ffffffff81527ccd>] netlink_unicast+0xdd/0x190 [<ffffffff8152807f>] netlink_sendmsg+0x2ff/0x740 [<ffffffff814e8368>] sock_sendmsg+0x88/0xc0 [<ffffffff814e8ac8>] ___sys_sendmsg.part.14+0x298/0x2b0 [<ffffffff814e91de>] __sys_sendmsg+0x4e/0x90 [<ffffffff814e922e>] SyS_sendmsg+0xe/0x10 [<ffffffff81601669>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14bridge: Call vlan_vid_del for all vids at nbp_vlan_flushToshiaki Makita
We should call vlan_vid_del for all vids at nbp_vlan_flush to prevent vid_info->refcount from being leaked when detaching a bridge port. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14bridge: Use vlan_vid_[add/del] instead of direct ndo_vlan_rx_[add/kill]_vid ↵Toshiaki Makita
calls We should use wrapper functions vlan_vid_[add/del] instead of ndo_vlan_rx_[add/kill]_vid. Otherwise, we might be not able to communicate using vlan interface in a certain situation. Example of problematic case: vconfig add eth0 10 brctl addif br0 eth0 bridge vlan add dev eth0 vid 10 bridge vlan del dev eth0 vid 10 brctl delif br0 eth0 In this case, we cannot communicate via eth0.10 because vlan 10 is filtered by NIC that has the vlan filtering feature. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking changes from Ingo Molnar: "The biggest changes: - add lockdep support for seqcount/seqlocks structures, this unearthed both bugs and required extra annotation. - move the various kernel locking primitives to the new kernel/locking/ directory" * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits) block: Use u64_stats_init() to initialize seqcounts locking/lockdep: Mark __lockdep_count_forward_deps() as static lockdep/proc: Fix lock-time avg computation locking/doc: Update references to kernel/mutex.c ipv6: Fix possible ipv6 seqlock deadlock cpuset: Fix potential deadlock w/ set_mems_allowed seqcount: Add lockdep functionality to seqcount/seqlock structures net: Explicitly initialize u64_stats_sync structures for lockdep locking: Move the percpu-rwsem code to kernel/locking/ locking: Move the lglocks code to kernel/locking/ locking: Move the rwsem code to kernel/locking/ locking: Move the rtmutex code to kernel/locking/ locking: Move the semaphore core to kernel/locking/ locking: Move the spinlock code to kernel/locking/ locking: Move the lockdep code to kernel/locking/ locking: Move the mutex code to kernel/locking/ hung_task debugging: Add tracepoint to report the hang x86/locking/kconfig: Update paravirt spinlock Kconfig description lockstat: Report avg wait and hold times lockdep, x86/alternatives: Drop ancient lockdep fixup message ...
2013-11-06net: Explicitly initialize u64_stats_sync structures for lockdepJohn Stultz
In order to enable lockdep on seqcount/seqlock structures, we must explicitly initialize any locks. The u64_stats_sync structure, uses a seqcount, and thus we need to introduce a u64_stats_init() function and use it to initialize the structure. This unfortunately adds a lot of fairly trivial initialization code to a number of drivers. But the benefit of ensuring correctness makes this worth while. Because these changes are required for lockdep to be enabled, and the changes are quite trivial, I've not yet split this patch out into 30-some separate patches, as I figured it would be better to get the various maintainers thoughts on how to best merge this change along with the seqcount lockdep enablement. Feedback would be appreciated! Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: James Morris <jmorris@namei.org> Cc: Jesse Gross <jesse@nicira.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Mirko Lindner <mlindner@marvell.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Roger Luethi <rl@hellgate.ch> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Simon Horman <horms@verge.net.au> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Wensong Zhang <wensong@linux-vs.org> Cc: netdev@vger.kernel.org Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-04Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nftables Pablo Neira Ayuso says: ==================== This batch contains fives nf_tables patches for your net-next tree, they are: * Fix possible use after free in the module removal path of the x_tables compatibility layer, from Dan Carpenter. * Add filter chain type for the bridge family, from myself. * Fix Kconfig dependencies of the nf_tables bridge family with the core, from myself. * Fix sparse warnings in nft_nat, from Tomasz Bursztyka. * Remove duplicated include in the IPv4 family support for nf_tables, from Wei Yongjun. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next Pablo Neira Ayuso says: ==================== This is another batch containing Netfilter/IPVS updates for your net-next tree, they are: * Six patches to make the ipt_CLUSTERIP target support netnamespace, from Gao feng. * Two cleanups for the nf_conntrack_acct infrastructure, introducing a new structure to encapsulate conntrack counters, from Holger Eitzenberger. * Fix missing verdict in SCTP support for IPVS, from Daniel Borkmann. * Skip checksum recalculation in SCTP support for IPVS, also from Daniel Borkmann. * Fix behavioural change in xt_socket after IP early demux, from Florian Westphal. * Fix bogus large memory allocation in the bitmap port set type in ipset, from Jozsef Kadlecsik. * Fix possible compilation issues in the hash netnet set type in ipset, also from Jozsef Kadlecsik. * Define constants to identify netlink callback data in ipset dumps, again from Jozsef Kadlecsik. * Use sock_gen_put() in xt_socket to replace xt_socket_put_sk, from Eric Dumazet. * Improvements for the SH scheduler in IPVS, from Alexander Frolkin. * Remove extra delay due to unneeded rcu barrier in IPVS net namespace cleanup path, from Julian Anastasov. * Save some cycles in ip6t_REJECT by skipping checksum validation in packets leaving from our stack, from Stanislav Fomichev. * Fix IPVS_CMD_ATTR_MAX definition in IPVS, larger that required, from Julian Anastasov. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be.h drivers/net/netconsole.c net/bridge/br_private.h Three mostly trivial conflicts. The net/bridge/br_private.h conflict was a function signature (argument addition) change overlapping with the extern removals from Joe Perches. In drivers/net/netconsole.c we had one change adjusting a printk message whilst another changed "printk(KERN_INFO" into "pr_info(". Lastly, the emulex change was a new inline function addition overlapping with Joe Perches's extern removals. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-29bridge: pass correct vlan id to multicast codeVlad Yasevich
Currently multicast code attempts to extrace the vlan id from the skb even when vlan filtering is disabled. This can lead to mdb entries being created with the wrong vlan id. Pass the already extracted vlan id to the multicast filtering code to make the correct id is used in creation as well as lookup. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Acked-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-28netfilter: bridge: nf_tables: add filter chain typePablo Neira Ayuso
This patch adds the filter chain type which is required to create filter chains in the bridge family from userspace. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-10-28netfilter: bridge: fix nf_tables bridge dependencies with main corePablo Neira Ayuso
when CONFIG_NF_TABLES[_MODULE] is not enabled, but CONFIG_NF_TABLES_BRIDGE is enabled: net/bridge/netfilter/nf_tables_bridge.c: In function 'nf_tables_bridge_init_net': net/bridge/netfilter/nf_tables_bridge.c:24:5: error: 'struct net' has no member named 'nft' net/bridge/netfilter/nf_tables_bridge.c:25:9: error: 'struct net' has no member named 'nft' net/bridge/netfilter/nf_tables_bridge.c:28:2: error: 'struct net' has no member named 'nft' net/bridge/netfilter/nf_tables_bridge.c:30:34: error: 'struct net' has no member named 'nft' net/bridge/netfilter/nf_tables_bridge.c:35:11: error: 'struct net' has no member named 'nft' net/bridge/netfilter/nf_tables_bridge.c: In function 'nf_tables_bridge_exit_net': net/bridge/netfilter/nf_tables_bridge.c:41:27: error: 'struct net' has no member named 'nft' net/bridge/netfilter/nf_tables_bridge.c:42:11: error: 'struct net' has no member named 'nft' Reported-by: Randy Dunlap <rdunlap@infradead.org> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-10-27bridge: netfilter: orphan skb before invoking ip netfilter hooksFlorian Westphal
Pekka Pietikäinen reports xt_socket behavioural change after commit 00028aa37098o (netfilter: xt_socket: use IP early demux). Reason is xt_socket now no longer does an unconditional sk lookup - it re-uses existing skb->sk if possible, assuming ->sk was set by ip early demux. However, when netfilter is invoked via bridge, this can cause 'bogus' sockets to be examined by the match, e.g. a 'tun' device socket. bridge netfilter should orphan the skb just like the routing path before invoking ipv4/ipv6 netfilter hooks to avoid this. Reported-and-tested-by: Pekka Pietikäinen <pp@ee.oulu.fi> Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-10-23Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains three netfilter fixes for your net tree, they are: * A couple of fixes to resolve info leak to userspace due to uninitialized memory area in ulogd, from Mathias Krause. * Fix instruction ordering issues that may lead to the access of uninitialized data in x_tables. The problem involves the table update (producer) and the main packet matching (consumer) routines. Detected in SMP ARMv7, from Will Deacon. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
