commit ce6289661b14a8b391d90db918c91b6d6da6540a upstream.
When CONFIG_KASAN is set, we can use relatively large amounts of kernel
stack space:
net/caif/cfctrl.c:555:1: warning: the frame size of 1600 bytes is larger than 1280 bytes [-Wframe-larger-than=]
This adds convenience wrappers around cfpkt_extr_head(), which is responsible
for most of the stack growth. With those wrapper functions, gcc apparently
starts reusing the stack slots for each instance, thus avoiding the
problem.
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 64119e05f7b31e83e2555f6782e6cdc8f81c63f4 ]
Add a missing rcu_read_unlock in the error path
Fixes: c95567c80352 ("caif: added check for potential null return")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
Add support for extended error reporting.
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
Acked-by: David Ahern <dsahern@gmail.com>
The conflicts were two cases of overlapping changes in
batman-adv and the qed driver.
Verify that the caller-provided sockaddr structure is large enough to
contain the sa_family field, before accessing it in the connect()
handler of the AF_CAIF socket. Since the syscall doesn't enforce a minimum
size of the corresponding memory region, very short sockaddrs (zero or one
byte long) result in operating on uninitialized memory while referencing
sa_family.
Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com>
The kernel may sleep under a rcu read lock in cfpkt_create_pfx, and the
function call path is:
cfcnfg_linkup_rsp (acquire the lock by rcu_read_lock)
cfctrl_linkdown_req
cfpkt_create
cfpkt_create_pfx
alloc_skb(GFP_KERNEL) --> may sleep
cfserl_receive (acquire the lock by rcu_read_lock)
cfpkt_split
cfpkt_create_pfx
There is "in_interrupt" in cfpkt_create_pfx to decide use "GFP_KERNEL" or
"GFP_ATOMIC". In this situation, "GFP_KERNEL" is used because the function
is called under a rcu read lock, instead in interrupt.
To fix it, only "GFP_ATOMIC" is used in cfpkt_create_pfx.
Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com>
Network devices can allocate reasources and private memory using
netdev_ops->ndo_init(). However, the release of these resources
can occur in one of two different places.
Either netdev_ops->ndo_uninit() or netdev->destructor().
The decision of which operation frees the resources depends upon
whether it is necessary for all netdev refs to be released before it
is safe to perform the freeing.
netdev_ops->ndo_uninit() presumably can occur right after the
NETDEV_UNREGISTER notifier completes and the unicast and multicast
address lists are flushed.
netdev->destructor(), on the other hand, does not run until the
netdev references all go away.
Further complicating the situation is that netdev->destructor()
almost universally does also a free_netdev().
This creates a problem for the logic in register_netdevice().
Because all callers of register_netdevice() manage the freeing
of the netdev, and invoke free_netdev(dev) if register_netdevice()
fails.
If netdev_ops->ndo_init() succeeds, but something else fails inside
of register_netdevice(), it does call ndo_ops->ndo_uninit(). But
it is not able to invoke netdev->destructor().
This is because netdev->destructor() will do a free_netdev() and
then the caller of register_netdevice() will do the same.
However, this means that the resources that would normally be released
by netdev->destructor() will not be.
Over the years drivers have added local hacks to deal with this, by
invoking their destructor parts by hand when register_netdevice()
fails.
Many drivers do not try to deal with this, and instead we have leaks.
Let's close this hole by formalizing the distinction between what
private things need to be freed up by netdev->destructor() and whether
the driver needs unregister_netdevice() to perform the free_netdev().
netdev->priv_destructor() performs all actions to free up the private
resources that used to be freed by netdev->destructor(), except for
free_netdev().
netdev->needs_free_netdev is a boolean that indicates whether
free_netdev() should be done at the end of unregister_netdevice().
Now, register_netdevice() can sanely release all resources after
ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit()
and netdev->priv_destructor().
And at the end of unregister_netdevice(), we invoke
netdev->priv_destructor() and optionally call free_netdev().
Signed-off-by: linzhang <xiaolou4617@gmail.com>
<linux/sched/signal.h>
We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/signal.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
The stats member of struct chnl_net is used nowhere in the code, so it
might as well be removed.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
The check of the return value of sock_register() is ineffective.
"if(!err)" seems to be a typo. It is better to propagate the error code
to the callers of caif_sktinit_module(). This patch removes the check
statment and directly returns the result of sock_register().
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188751
Signed-off-by: Pan Bian <bianpan2016@163.com>
Make struct pernet_operations::id unsigned.
There are 2 reasons to do so:
1)
This field is really an index into an zero based array and
thus is unsigned entity. Using negative value is out-of-bound
access by definition.
2)
On x86_64 unsigned 32-bit data which are mixed with pointers
via array indexing or offsets added or subtracted to pointers
are preffered to signed 32-bit data.
"int" being used as an array index needs to be sign-extended
to 64-bit before being used.
void f(long *p, int i)
g(p[i]);
roughly translates to
movsx rsi, esi
mov rdi, [rsi+...]
call g
MOVSX is 3 byte instruction which isn't necessary if the variable is
unsigned because x86_64 is zero extending by default.
Now, there is net_generic() function which, you guessed it right, uses
"int" as an array index:
static inline void *net_generic(const struct net *net, int id)
ptr = ng->ptr[id - 1];
And this function is used a lot, so those sign extensions add up.
Patch snipes ~1730 bytes on allyesconfig kernel (without all junk
messing with code generation):
add/remove: 0/0 grow/shrink: 70/598 up/down: 396/-2126 (-1730)
Unfortunately some functions actually grow bigger.
This is a semmingly random artefact of code generation with register
allocator being used differently. gcc decides that some variable
needs to live in new r8+ registers and every access now requires REX
prefix. Or it is shifted into r12, so [r12+0] addressing mode has to be
used which is longer than [r8]
However, overall balance is in negative direction:
function old new delta
nfsd4_lock 3886 3959 +73
tipc_link_build_proto_msg 1096 1140 +44
mac80211_hwsim_new_radio 2776 2808 +32
tipc_mon_rcv 1032 1058 +26
svcauth_gss_legacy_init 1413 1429 +16
tipc_bcbase_select_primary 379 392 +13
nfsd4_exchange_id 1247 1260 +13
nfsd4_setclientid_confirm 782 793 +11
put_client_renew_locked 494 480 -14
ip_set_sockfn_get 730 716 -14
geneve_sock_add 829 813 -16
nfsd4_sequence_done 721 703 -18
nlmclnt_lookup_host 708 686 -22
nfsd4_lockt 1085 1063 -22
nfs_get_client 1077 1050 -27
tcf_bpf_init 1106 1076 -30
nfsd4_encode_fattr 5997 5930 -67
Total: Before=154856051, After=154854321, chg -0.00%
Some of the pr_* messages are missing spaces, so insert these and also
unbreak multi-line literal strings in pr_* messages
Drop redundant include of moduleparam.h
The Coccinelle semantic patch used to make this change is as follows:
@ includesmodule @
#include <linux/module.h>
@ depends on includesmodule @
- #include <linux/moduleparam.h>
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
gcc points out code that is not indented the way it is
interpreted:
net/caif/cfpkt_skbuff.c: In function 'cfpkt_setlen':
net/caif/cfpkt_skbuff.c:289:4: error: statement is indented as if it were guarded by... [-Werror=misleading-indentation]
return cfpkt_getlen(pkt);
net/caif/cfpkt_skbuff.c:286:3: note: ...this 'else' clause, but it is not
else
It is clear from the context that not returning here would be
a bug, as we'd end up passing a negative length into a function
that takes a u16 length, so it is not missing curly braces
here, and I'm assuming that the indentation is the only part
that's wrong about it.
The cfrfml_receive() function might return positive value EPROTO
Signed-off-by: Anton Protopopov <a.s.protopopov@gmail.com>
This patch is a cleanup to make following patch easier to
review.
Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA
from (struct socket)->flags to a (struct socket_wq)->flags
to benefit from RCU protection in sock_wake_async()
To ease backports, we rename both constants.
Two new helpers, sk_set_bit(int nr, struct sock *sk)
and sk_clear_bit(int net, struct sock *sk) are added so that
following patch can change their implementation.
Signed-off-by: Phil Sutter <phil@nwl.cc>
Cc: Dmitry Tarnyagin <dmitry.tarnyagin@lockless.no>
1) If sk_filter() is applied, skb was leaked (not freed)
2) Testing SOCK_DEAD twice is racy :
packet could be freed while already queued.
3) Remove obsolete comment about caching skb->len
drivers/net/phy/amd-xgbe-phy.c
drivers/net/wireless/iwlwifi/Kconfig
include/net/mac80211.h
iwlwifi/Kconfig and mac80211.h were both trivial overlapping
changes.
The drivers/net/phy/amd-xgbe-phy.c file got removed in 'net-next' and
the bug fix that happened on the 'net' side is already integrated
into the rest of the amd-xgbe driver.
got a rare NULL pointer dereference in clear_bit
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
v2: switch to sock_flag(sk, SOCK_DEAD) and added net/caif/caif_socket.c
v3: return -ECONNRESET in upstream caller of wait function for SOCK_DEAD
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
drivers/net/ethernet/emulex/benet/be_main.c
net/core/sysctl_net_core.c
net/ipv4/inet_diag.c
The be_main.c conflict resolution was really tricky. The conflict
hunks generated by GIT were very unhelpful, to say the least. It
split functions in half and moved them around, when the real actual
conflict only existed solely inside of one function, that being
be_map_pci_bars().
So instead, to resolve this, I checked out be_main.c from the top
of net-next, then I applied the be_main.c changes from 'net' since
the last time I merged. And this worked beautifully.
The inet_diag.c and sysctl_net_core.c conflicts were simple
overlapping changes, and were easily to resolve.
It should be checking flags, not msg->msg_flags. It's ->sendmsg()
instances that need to look for that in ->msg_flags, ->recvmsg() ones
(including the other ->recvmsg() instance in that file, as well as
unix_dgram_recvmsg() this one claims to be imitating) check in flags.
Braino had been introduced in commit dcda13 ("caif: Bugfix - use MSG_TRUNC
in receive") back in 2010, so it goes quite a while back.
drivers/net/ethernet/rocker/rocker.c
The rocker commit was two overlapping changes, one to rename
the ->vport member to ->pport, and another making the bitmask
expression use '1ULL' instead of plain '1'.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
The cfpkt_iterate() function can return -EPROTO on error, but the
function is a u16 so the negative value gets truncated to a positive
unsigned short. This causes a static checker warning.
The only caller which might care is cffrml_receive(), when it's checking
the frame checksum. I modified cffrml_receive() so that it never says
-EPROTO is a valid checksum.
Also this isn't ever going to be inlined so I removed the "inline".
src_net points to the netns where the netlink message has been received. This
netns may be different from the netns where the interface is created (because
the user may add IFLA_NET_NS_[PID|FD]). In this case, src_net is the link netns.
It seems wrong to override the netns in the newlink() handler because if it
was not already src_net, it means that the user explicitly asks to create the
netdevice in another netns.
CC: Sjur Brændeland <sjur.brandeland@stericsson.com>
CC: Dmitry Tarnyagin <dmitry.tarnyagin@lockless.no>
Fixes: 8391c4aab1aa ("caif: Bugfixes in CAIF netdevice for close and flow control")
Fixes: c41254006377 ("caif-hsi: Add rtnl support")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
parent cfusbl was used instead of first structure member 'layer'
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Let MM subsystem display out of memory messages.
Also add blank line after declaration
debugfs_remove_recursive
based on checkpatch:
"debugfs_remove_recursive(NULL) is safe this check is probably not required"
Cc: netdev@vger.kernel.org
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
Include appropriate header file net/caif/caif_dev.h in caif/cfsrvl.c
because it has prototype declaration of functions defined in
caif/cfsrvl.c.
This eliminates the following warning in caif/cfsrvl.c:
net/caif/cfsrvl.c:198:6: warning: no previous prototype for ‘caif_free_client’ [-Wmissing-prototypes]
net/caif/cfsrvl.c:208:6: warning: no previous prototype for ‘caif_client_register_refcnt’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Include appropriate header file net/caif/caif_dev.h in caif/caif_dev.c
because it has prototype declarations of function defined in
caif/caif_dev.c.
This eliminates the following file in caif/caif_dev.c:
net/caif/caif_dev.c:303:6: warning: no previous prototype for ‘caif_enroll_dev’ [-Wmissing-prototypes]
Use ether_addr_copy instead of memcpy(a, b, ETH_ALEN) to
save some cycles on arm and powerpc.
The following call chains indicate that chnl_net_open() is under
rtnl_lock protection as __dev_open() is protected by rtnl_lock.
So if __dev_get_by_index() instead of dev_get_by_index() is used
to find interface handler in it, this would help us avoid to change
interface reference counter.
__dev_open()
chnl_net_open()
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Also remove the warning for fragmented packets -- skb_cow_data() will
linearize the buffer, removing all fragments.
Signed-off-by: Mathias Krause <mathias.krause@secunet.com>
The indentation here implies this was meant to be a multi-line if.
Introduced several years back in commit c85c2951d4da1236e32f1858db418221e624aba5
("caif: Handle dev_queue_xmit errors.")
Signed-off-by: Dave Jones <davej@fedoraproject.org>
