The commit aabdcb0b553b9c9547b1a506b34d55a764745870 ("can bcm: fix tx_setup
off-by-one errors") fixed only a part of the original problem reported by
Andre Naujoks. It turned out that the original code needed to be re-ordered
to reduce complexity and to finally fix the reported frame counting issues.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
This patch fixes two off-by-one errors that canceled each other out.
Checking for the same condition two times in bcm_tx_timeout_tsklet() reduced
the count of frames to be sent by one. This did not show up the first time
tx_setup is invoked as an additional frame is sent due to TX_ANNONCE.
Invoking a second tx_setup on the same item led to a reduced (by 1) number of
sent frames.
Reported-by: Andre Naujoks <nautsch@gmail.com>
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
commit 53914b67993c724cec585863755c9ebc8446e83b had the
same message. That commit did put everything in place but
did not make can_proto const itself.
Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
We can get here with a NULL socket argument passed from userspace,
so we need to handle it accordingly.
Signed-off-by: Dave Jones <davej@redhat.com>
can_ioctl is the only reason for struct proto to be non-const.
script/check-patch.pl suggests struct proto be const.
Setting the reference to the common can_ioctl() in all CAN protocols directly
removes the need to make the struct proto writable in af_can.c
This patch makes the CAN socket code conform to the manpage of sendmsg.
Since the socket address is just being used as a unique identifier, its
inode number is an alternative that does not leak potentially sensitive
information.
CC-ing stable because MITRE has assigned CVE-2010-4565 to the issue.
On 64-bit platforms the ASCII representation of a pointer may be up to 17
bytes long. This patch increases the length of the buffer accordingly.
http://marc.info/?l=linux-netdev&m=128872251418192&w=2
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
CC: Linus Torvalds <torvalds@linux-foundation.org>
This patch adds a limit for nframes as the number of frames in TX_SETUP and
RX_SETUP are derived from a single byte multiplex value by default.
Use-cases that would require to send/filter more than 256 CAN frames should
be implemented in userspace for complexity reasons anyway.
Additionally the assignments of unsigned values from userspace to signed
values in kernelspace and vice versa are fixed by using unsigned values in
kernelspace consistently.
Reported-by: Ben Hawkes <hawkes@google.com>
Acked-by: Urs Thuermann <urs.thuermann@volkswagen.de>
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits)
smc91c92_cs: fix the problem of "Unable to find hardware address"
r8169: clean up my printk uglyness
net: Hook up cxgb4 to Kconfig and Makefile
cxgb4: Add main driver file and driver Makefile
cxgb4: Add remaining driver headers and L2T management
cxgb4: Add packet queues and packet DMA code
cxgb4: Add HW and FW support code
cxgb4: Add register, message, and FW definitions
netlabel: Fix several rcu_dereference() calls used without RCU read locks
bonding: fix potential deadlock in bond_uninit()
net: check the length of the socket address passed to connect(2)
stmmac: add documentation for the driver.
stmmac: fix kconfig for crc32 build error
be2net: fix bug in vlan rx path for big endian architecture
be2net: fix flashing on big endian architectures
be2net: fix a bug in flashing the redboot section
bonding: bond_xmit_roundrobin() fix
drivers/net: Add missing unlock
net: gianfar - align BD ring size console messages
net: gianfar - initialize per-queue statistics
check the length of the socket address passed to connect(2).
Check the length of the socket address passed to connect(2). If the
length is invalid, -EINVAL will be returned.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
net/bluetooth/l2cap.c | 3 ++-
net/bluetooth/rfcomm/sock.c | 3 ++-
net/bluetooth/sco.c | 3 ++-
net/can/bcm.c | 3 +++
net/ieee802154/af_ieee802154.c | 3 +++
net/ipv4/af_inet.c | 5 +++++
net/netlink/af_netlink.c | 3 +++
7 files changed, 20 insertions(+), 3 deletions(-)
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Use new function to avoid doing read_lock().
Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net>
drivers/net/can/usb/ems_usb.c
bcm_proc_getifname() is called with RTNL and dev_base_lock
not held. It calls __dev_get_by_index() without locks, and
this is illegal (might crash)
Close the race by holding dev_base_lock and copying dev->name
in the protected section.
struct can_proto had a capability field which wasn't ever used. It is
dropped entirely.
struct inet_protosw had a capability field which can be more clearly
expressed in the code by just checking if sock->type = SOCK_RAW.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Create a new socket level option to report number of queue overflows
Recently I augmented the AF_PACKET protocol to report the number of frames lost
on the socket receive queue between any two enqueued frames. This value was
exported via a SOL_PACKET level cmsg. AFter I completed that work it was
requested that this feature be generalized so that any datagram oriented socket
could make use of this option. As such I've created this patch, It creates a
new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a
SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue
overflowed between any two given frames. It also augments the AF_PACKET
protocol to take advantage of this new feature (as it previously did not touch
sk->sk_drops, which this patch uses to record the overflow count). Tested
successfully by me.
Notes:
1) Unlike my previous patch, this patch simply records the sk_drops value, which
is not a number of drops between packets, but rather a total number of drops.
Deltas must be computed in user space.
2) While this patch currently works with datagram oriented protocols, it will
also be accepted by non-datagram oriented protocols. I'm not sure if thats
agreeable to everyone, but my argument in favor of doing so is that, for those
protocols which aren't applicable to this option, sk_drops will always be zero,
and reporting no drops on a receive queue that isn't used for those
non-participating protocols seems reasonable to me. This also saves us having
to code in a per-protocol opt in mechanism.
3) This applies cleanly to net-next assuming that commit
977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
create_proc_read_entry() is going to be removed soon.
Add appropriate MODULE_ALIAS() to facilitate autoloading of can protocol drivers
Signed-off-by: Lothar Wassmann <LW@KARO-electronics.de>
Acked-by: Oliver Hartkopp <oliver@hartkopp.net>
Fix a use after free bug in can protocol drivers
The release functions of the can protocol drivers lack a call to
sock_orphan() which leads to referencing freed memory under certain
circumstances.
This patch fixes a bug reported here:
https://lists.berlios.de/pipermail/socketcan-users/2009-July/000985.html
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy
as correctly noted at bug #12454. Someone can lookup entry with NULL
->owner, thus not pinning enything, and release it later resulting
in module refcount underflow.
We can keep ->owner and supply it at registration time like ->proc_fops
and ->data.
But this leaves ->owner as easy-manipulative field (just one C assignment)
and somebody will forget to unpin previous/pin current module when
switching ->owner. ->proc_fops is declared as "const" which should give
some thoughts.
->read_proc/->write_proc were just fixed to not require ->owner for
protection.
rmmod'ed directories will be empty and return "." and ".." -- no harm.
And directories with tricky enough readdir and lookup shouldn't be modular.
We definitely don't want such modular code.
Removing ->owner will also make PDE smaller.
So, let's nuke it.
Kudos to Jeff Layton for reminding about this, let's say, oversight.
http://bugzilla.kernel.org/show_bug.cgi?id=12454
Due to the loopback functionality in can_send() we can not invoke it
from hardirq context which was done inside the
bcm_tx_timeout_handler() hrtimer callback:
[ 700.361154] [<c012228c>] warn_slowpath+0x80/0xb6
[ 700.361163] [<c013d559>] valid_state+0x125/0x136
[ 700.361171] [<c013d858>] mark_lock+0x18e/0x332
[ 700.361180] [<c013e300>] __lock_acquire+0x12e/0xb1e
[ 700.361189] [<f8ab5915>] bcm_tx_timeout_handler+0x0/0xbc [can_bcm]
[ 700.361198] [<c031e20a>] dev_queue_xmit+0x191/0x479
[ 700.361206] [<c01262a7>] __local_bh_disable+0x2b/0x64
[ 700.361213] [<c031e20a>] dev_queue_xmit+0x191/0x479
[ 700.361225] [<f8aa69a1>] can_send+0xd7/0x11a [can]
[ 700.361235] [<f8ab522b>] bcm_can_tx+0x9d/0xd9 [can_bcm]
[ 700.361245] [<f8ab597f>] bcm_tx_timeout_handler+0x6a/0xbc [can_bcm]
[ 700.361255] [<f8ab5915>] bcm_tx_timeout_handler+0x0/0xbc [can_bcm]
[ 700.361263] [<c0134143>] __run_hrtimer+0x5a/0x86
[ 700.361273] [<f8ab5915>] bcm_tx_timeout_handler+0x0/0xbc [can_bcm]
[ 700.361282] [<c0134a50>] hrtimer_interrupt+0xb9/0x110
This patch moves the rest of the functionality from the hrtimer
callback to the already existing tasklet to fix this slowpath problem.
The AF_CAN core delivered always cloned sk_buffs to the AF_CAN
protocols, although this was _only_ needed by the can-raw protocol.
With this (additionally documented) change, the AF_CAN core calls the
callback functions of the registered AF_CAN protocols with the original
(uncloned) sk_buff pointer and let's the can-raw protocol do the
skb_clone() itself which omits all unneeded skb_clone() calls for other
AF_CAN protocols.
Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de>
Since commit ca109491f612aab5c8152207631c0444f63da97f ("hrtimer:
removing all ur callback modes") the hrtimer callbacks are processed
only in hardirq context.
This patch moves some functionality into tasklets to run in softirq
context.
Additionally some duplicated code was removed in bcm_rx_thr_flush()
and an avoidable memcpy was removed from bcm_rx_handler().
Due to a wrong safety check in af_can.c it was not possible to filter
for SFF frames with a specific CAN identifier without getting the
same selected CAN identifier from a received EFF frame also.
This fix has a minimum (but user visible) impact on the CAN filter
API and therefore the CAN version is set to a new date.
Indeed the 'old' API is still working as-is. But when now setting
CAN_(EFF|RTR)_FLAG in can_filter.can_mask you might get less traffic
than before - but still the stuff that you expected to get for your
defined filter ...
Thanks to Kurt Van Dijck for pointing at this issue and for the review.
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Even though the CAN netlayer only deals with CAN netdevices, the
netlayer interface to the userspace and to the device layer should
perform some sanity checks.
This patch adds several sanity checks that mainly prevent userspace apps
to send broken content into the system that may be misinterpreted by
some other userspace application.
Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de>
Acked-by: Andre Naujoks <nautsch@gmail.com>
The helper function hrtimer_callback_running() is used in
kernel/hrtimer.c as well as in the updated net/can/bcm.c which now
supports hrtimers. Moving the helper function to hrtimer.h removes the
duplicate definition in the C-files.
Make use of hrtimers to support high resolution capabilities, when
provided by the system clocksource.
The conversion to hrtimers additionally discovered and solved an
unlikely race condition that has been reproduced under (unrealistic)
massive receive load, which can only be produced on vcan software devices.
[ Fix printf format warnings on 64-bit -DaveM ]
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
This patch adds the CAN broadcast manager (bcm) protocol.
