path: root/net/can
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-11-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-11-26can: bcm: initialize ifindex for timeouts without previous frame receptionOliver Hartkopp
Set in the rx_ifindex to pass the correct interface index in the case of a message timeout detection. Usually the rx_ifindex value is set at receive time. But when no CAN frame has been received the RX_TIMEOUT notification did not contain a valid value. Cc: linux-stable <stable@vger.kernel.org> Reported-by: Andre Naujoks <nautsch2@googlemail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-18net: Push capable(CAP_NET_ADMIN) into the rtnl methodsEric W. Biederman
- In rtnetlink_rcv_msg convert the capable(CAP_NET_ADMIN) check to ns_capable(net->user-ns, CAP_NET_ADMIN). Allowing unprivileged users to make netlink calls to modify their local network namespace. - In the rtnetlink doit methods add capable(CAP_NET_ADMIN) so that calls that are not safe for unprivileged users are still protected. Later patches will remove the extra capable calls from methods that are safe for unprivilged users. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-06sections: fix section conflicts in net/canAndi Kleen
Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Oliver Hartkopp <socketcan@hartkopp.net> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10can: gw: Remove pointless castsThomas Graf
No need to cast return value of nla_data() Signed-off-by: Thomas Graf <tgraf@suug.ch> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-07-10can: gw: Properly fill the netlink header when responding to RTM_GETROUTEThomas Graf
- set message type to RTM_NEWROUTE - relate to original request by inheriting the sequence and port number. - set NLM_F_MULTI because it's a dump and more messages will follow Signed-off-by: Thomas Graf <tgraf@suug.ch> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-07-10can: gw: Use nla_policy to validate netlink attributesThomas Graf
Also use nla_get_u32() instead of nla_memcpy() to access u32 attribtues. Signed-off-by: Thomas Graf <tgraf@suug.ch> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-07-10can: gw: Don't bump nlmsg_len manuallyThomas Graf
nlmsg_end() will take care of this when we finalize the message. Signed-off-by: Thomas Graf <tgraf@suug.ch> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-07-02can: fix sparse warning in af_can.cOliver Hartkopp
Put can_rx_alldev_list into the af_can header to fix the following sparse warning: net/can/af_can.c:80:22: warning: symbol 'can_rx_alldev_list' was not declared. Should it be static? Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-06-19canfd: add support for CAN FD in CAN_RAW socketsOliver Hartkopp
- introduce a new sockopt CAN_RAW_FD_FRAMES to allow CAN FD frames - handle CAN frames and CAN FD frames simultaneously when enabled Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-06-19canfd: add support for CAN FD in PF_CAN coreOliver Hartkopp
- handle ETH_P_CAN and ETH_P_CANFD skbuffs - update sanity checks for CAN and CAN FD - make sure the CAN frame can pass the selected CAN netdevice on send - bump core version and abi version to indicate the new CAN FD support Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-06-19canfd: add new data structures and constantsOliver Hartkopp
- add new struct canfd_frame - check identical element offsets in struct can_frame and struct canfd_frame - new ETH_P_CANFD definition to tag CAN FD skbs correctly - add CAN_MTU and CANFD_MTU definitions for easy frame and mode detection - add CAN[FD]_MAX_[DLC|DLEN] helper constants to remove hard coded values - update existing struct can_frame with helper constants and comments Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-06-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/ipv6/route.c This deals with a merge conflict between the net-next addition of the inetpeer network namespace ops, and Thomas Graf's bug fix in 2a0c451ade8e1783c5d453948289e4a978d417c9 which makes sure we don't register /proc/net/ipv6_route before it is actually safe to do so. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-15net: remove skb_orphan_try()Eric Dumazet
Orphaning skb in dev_hard_start_xmit() makes bonding behavior unfriendly for applications sending big UDP bursts : Once packets pass the bonding device and come to real device, they might hit a full qdisc and be dropped. Without orphaning, the sender is automatically throttled because sk->sk_wmemalloc reaches sk->sk_sndbuf (assuming sk_sndbuf is not too big) We could try to defer the orphaning adding another test in dev_hard_start_xmit(), but all this seems of little gain, now that BQL tends to make packets more likely to be parked in Qdisc queues instead of NIC TX ring, in cases where performance matters. Reverts commits : fc6055a5ba31 net: Introduce skb_orphan_try() 87fd308cfc6b net: skb_tx_hash() fix relative to skb_orphan_try() and removes SKBTX_DRV_NEEDS_SK_REF flag Reported-and-bisected-by: Jean-Michel Hautbois <jhautbois@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-23can: update documentation wording error frames -> error messagesOliver Hartkopp
As Heinz-Juergen Oertel pointed out 'CAN error frames' are a already defined term for the CAN protocol violation indication on the wire. To avoid confusion with the error messages created by CAN drivers available via CAN RAW sockets update the documentation and change the naming from 'error frames' to 'error messages' or 'error message frames'. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2012-04-16can: fix sparse warning for cgw_listDaniel Baluta
Make cgw_list static to remove the following sparse warning: net/can/gw.c:69:1: warning: symbol 'cgw_list' was not declared. Should it be static? Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2011-10-17can: remove references to berlios mailinglistMarc Kleine-Budde
The BerliOS project, which currently hosts our mailinglist, will close with the end of the year. Now take the chance and remove all occurrences of the mailinglist address from the source files. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-07Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: net/batman-adv/soft-interface.c
2011-09-29can bcm: fix incomplete tx_setup fixOliver Hartkopp
The commit aabdcb0b553b9c9547b1a506b34d55a764745870 ("can bcm: fix tx_setup off-by-one errors") fixed only a part of the original problem reported by Andre Naujoks. It turned out that the original code needed to be re-ordered to reduce complexity and to finally fix the reported frame counting issues. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-29can bcm: fix tx_setup off-by-one errorsOliver Hartkopp
This patch fixes two off-by-one errors that canceled each other out. Checking for the same condition two times in bcm_tx_timeout_tsklet() reduced the count of frames to be sent by one. This did not show up the first time tx_setup is invoked as an additional frame is sent due to TX_ANNONCE. Invoking a second tx_setup on the same item led to a reduced (by 1) number of sent frames. Reported-by: Andre Naujoks <nautsch@gmail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-09-16can-gw: add netlink based CAN routingOliver Hartkopp
This patch adds a CAN Gateway/Router to route (and modify) CAN frames. It is based on the PF_CAN core infrastructure for msg filtering and msg sending and can optionally modify routed CAN frames on the fly. CAN frames can *only* be routed between CAN network interfaces (one hop). They can be modified with AND/OR/XOR/SET operations as configured by the netlink configuration interface known e.g. from iptables. From the netlink view this can-gw implements RTM_{NEW|DEL|GET}ROUTE for PF_CAN. The CAN specific userspace tool to manage CAN routing entries can be found in the CAN utils http://svn.berlios.de/wsvn/socketcan/trunk/can-utils/cangw.c at the SocketCAN SVN on BerliOS. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15net/can/af_can.c: Change del_timer to del_timer_syncrajan.aggarwal85@gmail.com
This is important for SMP platform to check if timer function is executing on other CPU with deleting the timer. Signed-off-by: Rajan Aggarwal <Rajan Aggarwal rajan.aggarwal85@gmail.com> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-17net/can: use printk_ratelimited() instead of printk_ratelimit()Manuel Zerpies
Since printk_ratelimit() shouldn't be used anymore (see comment in include/linux/printk.h), replace it with printk_ratelimited(). Signed-off-by: Manuel Zerpies <manuel.f.zerpies@ww.stud.uni-erlangen.de> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26can: convert to %pK for kptr_restrict supportOliver Hartkopp
As these pointers have been printed without using %p they were missed in the big network kptr_restrict conversion patch %p -> %pK from Dan Rosenberg. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24net: convert %p usage to %pKDan Rosenberg
The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". The supporting code for kptr_restrict and %pK are currently in the -mm tree. This patch converts users of %p in net/ to %pK. Cases of printing pointers to the syslog are not covered, since this would eliminate useful information for postmortem debugging and the reading of the syslog is already optionally protected by the dmesg_restrict sysctl. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-04can: rename can_try_module_get to can_get_protoKurt Van Dijck
can: rename can_try_module_get to can_get_proto can_try_module_get does return a struct can_proto. The name explains what is done in so much detail that a caller may not notice that a struct can_proto is locked/unlocked. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-04can: make struct can_proto constKurt Van Dijck
commit 53914b67993c724cec585863755c9ebc8446e83b had the same message. That commit did put everything in place but did not make can_proto const itself. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Resolved logic conflicts causing a build failure due to drivers/net/r8169.c changes using a patch from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20can: add missing socket check in can/raw releaseOliver Hartkopp
v2: added space after 'if' according code style. We can get here with a NULL socket argument passed from userspace, so we need to handle it accordingly. Thanks to Dave Jones pointing at this issue in net/can/bcm.c Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19can: Add missing socket check in can/bcm release.Dave Jones
We can get here with a NULL socket argument passed from userspace, so we need to handle it accordingly. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-06can: convert protocol handling to RCUOliver Hartkopp
This patch removes spin_locks at CAN socket creation time by using RCU. Inspired by the discussion with Kurt van Dijck and Eric Dumazet the RCU code was partly derived from af_phonet.c Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27can: make struct proto constOliver Hartkopp
can_ioctl is the only reason for struct proto to be non-const. script/check-patch.pl suggests struct proto be const. Setting the reference to the common can_ioctl() in all CAN protocols directly removes the need to make the struct proto writable in af_can.c Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-15can: test size of struct sockaddr in sendmsgKurt Van Dijck
This patch makes the CAN socket code conform to the manpage of sendmsg. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-04Merge branch 'master' of ↵David S. Miller
2010-12-31CAN: Use inode instead of kernel address for /proc fileDan Rosenberg
Since the socket address is just being used as a unique identifier, its inode number is an alternative that does not leak potentially sensitive information. CC-ing stable because MITRE has assigned CVE-2010-4565 to the issue. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22Net: can: Makefile: Remove deprecated kbuild goal definitionsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-12can-bcm: fix minor heap overflowOliver Hartkopp
On 64-bit platforms the ASCII representation of a pointer may be up to 17 bytes long. This patch increases the length of the buffer accordingly. http://marc.info/?l=linux-netdev&m=128872251418192&w=2 Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> CC: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21can-raw: add msg_flags to distinguish local trafficOliver Hartkopp
CAN has no addressing scheme. It is currently impossible for userspace to tell is a received CAN frame comes from another process on the local host, or from a remote CAN device. This patch add support for userspace applications to distinguish between 'own', 'local' and 'remote' CAN traffic. The distinction is made by returning flags in msg->msg_flags in the call to recvmsg(). The added documentation explains the introduced flags. Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19net: simplify flags for tx timestampingOliver Hartkopp
This patch removes the abstraction introduced by the union skb_shared_tx in the shared skb data. The access of the different union elements at several places led to some confusion about accessing the shared tx_flags e.g. in skb_orphan_try(). http://marc.info/?l=linux-netdev&m=128084897415886&w=2 Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-11can: add limit for nframes and clean up signed/unsigned variablesOliver Hartkopp
This patch adds a limit for nframes as the number of frames in TX_SETUP and RX_SETUP are derived from a single byte multiplex value by default. Use-cases that would require to send/filter more than 256 CAN frames should be implemented in userspace for complexity reasons anyway. Additionally the assignments of unsigned values from userspace to signed values in kernelspace and vice versa are fixed by using unsigned values in kernelspace consistently. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Reported-by: Ben Hawkes <hawkes@google.com> Acked-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03can-raw: Fix skb_orphan_try handlingOliver Hartkopp
Commit fc6055a5ba31e2c14e36e8939f9bf2b6d586a7f5 (net: Introduce skb_orphan_try()) allows an early orphan of the skb and takes care on tx timestamping, which needs the sk-reference in the skb on driver level. So does the can-raw socket, which has not been taken into account here. The patch below adds a 'prevent_sk_orphan' bit in the skb tx shared info, which fixes the problem discovered by Matthias Fuchs here: http://marc.info/?t=128030411900003&r=1&w=2 Even if it's not a primary tx timestamp topic it fits well into some skb shared tx context. Or should be find a different place for the information to protect the sk reference until it reaches the driver level? Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31net/can: Use memdup_userJulia Lawall
Use memdup_user when user data is immediately copied into the allocated region. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; position p; identifier l1,l2; @@ - to = \(kmalloc@p\|kzalloc@p\)(size,flag); + to = memdup_user(from,size); if ( - to==NULL + IS_ERR(to) || ...) { <+... when != goto l1; - -ENOMEM + PTR_ERR(to) ...+> } - if (copy_from_user(to, from, size) != 0) { - <+... when != goto l2; - -EFAULT - ...+> - } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
