path: root/net/compat.c
2017-10-08audit: log 32-bit socketcallsRichard Guy Briggs
[ Upstream commit 62bc306e2083436675e33b5bdeb6a77907d35971 ] 32-bit socketcalls were not being logged by audit on x86_64 systems. Log them. This is basically a duplicate of the call from net/socket.c:sys_socketcall(), but it addresses the impedance mismatch between 32-bit userspace process and 64-bit kernel audit. See: https://github.com/linux-audit/audit-kernel/issues/14 Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-09packet: compat support for sock_fprogWillem de Bruijn
Socket option PACKET_FANOUT_DATA takes a struct sock_fprog as argument if PACKET_FANOUT has mode PACKET_FANOUT_CBPF. This structure contains a pointer into user memory. If userland is 32-bit and kernel is 64-bit the two disagree about the layout of struct sock_fprog. Add compat setsockopt support to convert a 32-bit compat_sock_fprog to a 64-bit sock_fprog. This is analogous to compat_sock_fprog support for SO_REUSEPORT added in commit 1957598840f4 ("soreuseport: add compat case for setsockopt SO_ATTACH_REUSEPORT_CBPF"). Reported-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-06soreuseport: add compat case for setsockopt SO_ATTACH_REUSEPORT_CBPFHelge Deller
Commit 538950a1b752 ("soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPF") missed to add the compat case for the SO_ATTACH_REUSEPORT_CBPF option. Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-09net: switch importing msghdr from userland to {compat_,}import_iovec()Al Viro
2015-03-23net: socket: add support for async operationstadeusz.struk@intel.com
Add support for async operations. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c net/core/sysctl_net_core.c net/ipv4/inet_diag.c The be_main.c conflict resolution was really tricky. The conflict hunks generated by GIT were very unhelpful, to say the least. It split functions in half and moved them around, when the real actual conflict only existed solely inside of one function, that being be_map_pci_bars(). So instead, to resolve this, I checked out be_main.c from the top of net-next, then I applied the be_main.c changes from 'net' since the last time I merged. And this worked beautifully. The inet_diag.c and sysctl_net_core.c conflicts were simple overlapping changes, and were easily to resolve. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20net: compat: Update get_compat_msghdr() to match copy_msghdr_from_user() ↵Catalin Marinas
behaviour Commit db31c55a6fb2 (net: clamp ->msg_namelen instead of returning an error) introduced the clamping of msg_namelen when the unsigned value was larger than sizeof(struct sockaddr_storage). This caused a msg_namelen of -1 to be valid. The native code was subsequently fixed by commit dbb490b96584 (net: socket: error on a negative msg_namelen). In addition, the native code sets msg_namelen to 0 when msg_name is NULL. This was done in commit (6a2a2b3ae075 net:socket: set msg_namelen to 0 if msg_name is passed as NULL in msghdr struct from userland) and subsequently updated by 08adb7dabd48 (fold verify_iovec() into copy_msghdr_from_user()). This patch brings the get_compat_msghdr() in line with copy_msghdr_from_user(). Fixes: db31c55a6fb2 (net: clamp ->msg_namelen instead of returning an error) Cc: David S. Miller <davem@davemloft.net> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/rocker/rocker.c The rocker commit was two overlapping changes, one to rename the ->vport member to ->pport, and another making the bitmask expression use '1ULL' instead of plain '1'. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-23net: compat: Ignore MSG_CMSG_COMPAT in compat_sys_{send, recv}msgCatalin Marinas
With commit a7526eb5d06b (net: Unbreak compat_sys_{send,recv}msg), the MSG_CMSG_COMPAT flag is blocked at the compat syscall entry points, changing the kernel compat behaviour from the one before the commit it was trying to fix (1be374a0518a, net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg). On 32-bit kernels (!CONFIG_COMPAT), MSG_CMSG_COMPAT is 0 and the native 32-bit sys_sendmsg() allows flag 0x80000000 to be set (it is ignored by the kernel). However, on a 64-bit kernel, the compat ABI is different with commit a7526eb5d06b. This patch changes the compat_sys_{send,recv}msg behaviour to the one prior to commit 1be374a0518a. The problem was found running 32-bit LTP (sendmsg01) binary on an arm64 kernel. Arguably, LTP should not pass 0xffffffff as flags to sendmsg() but the general rule is not to break user ABI (even when the user behaviour is not entirely sane). Fixes: a7526eb5d06b (net: Unbreak compat_sys_{send,recv}msg) Cc: Andy Lutomirski <luto@amacapital.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-22net: __aligned(size) is preferred over __attribute__((aligned(size)))Ameen Ali
Signed-off-by: Ameen Ali <AmeenAli023@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09put iov_iter into msghdrAl Viro
Note that the code _using_ ->msg_iter at that point will be very unhappy with anything other than unshifted iovec-backed iov_iter. We still need to convert users to proper primitives. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19fold verify_iovec() into copy_msghdr_from_user()Al Viro
... and do the same on the compat side of things. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19{compat_,}verify_iovec(): switch to generic copying of iovecsAl Viro
use {compat_,}rw_copy_check_uvector(). As the result, we are guaranteed that all iovecs seen in ->msg_iov by ->sendmsg() and ->recvmsg() will pass access_ok(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19separate kernel- and userland-side msghdrAl Viro
Kernel-side struct msghdr is (currently) using the same layout as userland one, but it's not a one-to-one copy - even without considering 32bit compat issues, we have msg_iov, msg_name and msg_control copied to kernel[1]. It's fairly localized, so we get away with a few functions where that knowledge is needed (and we could shrink that set even more). Pretty much everything deals with the kernel-side variant and the few places that want userland one just use a bunch of force-casts to paper over the differences. The thing is, kernel-side definition of struct msghdr is *not* exposed in include/uapi - libc doesn't see it, etc. So we can add struct user_msghdr, with proper annotations and let the few places that ever deal with those beasts use it for userland pointers. Saner typechecking aside, that will allow to change the layout of kernel-side msghdr - e.g. replace msg_iov/msg_iovlen there with struct iov_iter, getting rid of the need to modify the iovec as we copy data to/from it, etc. We could introduce kernel_msghdr instead, but that would create much more noise - the absolute majority of the instances would need to have the type switched to kernel_msghdr and definition of struct msghdr in include/linux/socket.h is not going to be seen by userland anyway. This commit just introduces user_msghdr and switches the few places that are dealing with userland-side msghdr to it. [1] actually, it's even trickier than that - we copy msg_control for sendmsg, but keep the userland address on recvmsg. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-07-29net: sendmsg: fix NULL pointer dereferenceAndrey Ryabinin
Sasha's report: > While fuzzing with trinity inside a KVM tools guest running the latest -next > kernel with the KASAN patchset, I've stumbled on the following spew: > > [ 4448.949424] ================================================================== > [ 4448.951737] AddressSanitizer: user-memory-access on address 0 > [ 4448.952988] Read of size 2 by thread T19638: > [ 4448.954510] CPU: 28 PID: 19638 Comm: trinity-c76 Not tainted 3.16.0-rc4-next-20140711-sasha-00046-g07d3099-dirty #813 > [ 4448.956823] ffff88046d86ca40 0000000000000000 ffff880082f37e78 ffff880082f37a40 > [ 4448.958233] ffffffffb6e47068 ffff880082f37a68 ffff880082f37a58 ffffffffb242708d > [ 4448.959552] 0000000000000000 ffff880082f37a88 ffffffffb24255b1 0000000000000000 > [ 4448.961266] Call Trace: > [ 4448.963158] dump_stack (lib/dump_stack.c:52) > [ 4448.964244] kasan_report_user_access (mm/kasan/report.c:184) > [ 4448.965507] __asan_load2 (mm/kasan/kasan.c:352) > [ 4448.966482] ? netlink_sendmsg (net/netlink/af_netlink.c:2339) > [ 4448.967541] netlink_sendmsg (net/netlink/af_netlink.c:2339) > [ 4448.968537] ? get_parent_ip (kernel/sched/core.c:2555) > [ 4448.970103] sock_sendmsg (net/socket.c:654) > [ 4448.971584] ? might_fault (mm/memory.c:3741) > [ 4448.972526] ? might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3740) > [ 4448.973596] ? verify_iovec (net/core/iovec.c:64) > [ 4448.974522] ___sys_sendmsg (net/socket.c:2096) > [ 4448.975797] ? put_lock_stats.isra.13 (./arch/x86/include/asm/preempt.h:98 kernel/locking/lockdep.c:254) > [ 4448.977030] ? lock_release_holdtime (kernel/locking/lockdep.c:273) > [ 4448.978197] ? lock_release_non_nested (kernel/locking/lockdep.c:3434 (discriminator 1)) > [ 4448.979346] ? check_chain_key (kernel/locking/lockdep.c:2188) > [ 4448.980535] __sys_sendmmsg (net/socket.c:2181) > [ 4448.981592] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600) > [ 4448.982773] ? trace_hardirqs_on (kernel/locking/lockdep.c:2607) > [ 4448.984458] ? syscall_trace_enter (arch/x86/kernel/ptrace.c:1500 (discriminator 2)) > [ 4448.985621] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600) > [ 4448.986754] SyS_sendmmsg (net/socket.c:2201) > [ 4448.987708] tracesys (arch/x86/kernel/entry_64.S:542) > [ 4448.988929] ================================================================== This reports means that we've come to netlink_sendmsg() with msg->msg_name == NULL and msg->msg_namelen > 0. After this report there was no usual "Unable to handle kernel NULL pointer dereference" and this gave me a clue that address 0 is mapped and contains valid socket address structure in it. This bug was introduced in f3d3342602f8bcbf37d7c46641cb9bca7618eb1c (net: rework recvmsg handler msg_name and msg_namelen logic). Commit message states that: "Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address." But in fact this affects sendto when address 0 is mapped and contains socket address structure in it. In such case copy-in address will succeed, verify_iovec() function will successfully exit with msg->msg_namelen > 0 and msg->msg_name == NULL. This patch fixes it by setting msg_namelen to 0 if msg_name == NULL. Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Cc: Eric Dumazet <edumazet@google.com> Cc: <stable@vger.kernel.org> Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-06net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter typesHeiko Carstens
In order to allow the COMPAT_SYSCALL_DEFINE macro generate code that performs proper zero and sign extension convert all 64 bit parameters to their corresponding 32 bit compat counterparts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-03-06net/compat: convert to COMPAT_SYSCALL_DEFINEHeiko Carstens
Convert all compat system call functions where all parameter types have a size of four or less than four bytes, or are pointer types to COMPAT_SYSCALL_DEFINE. The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper zero and sign extension to 64 bit of all parameters if needed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-01-30x86, x32: Correct invalid use of user timespec in the kernelPaX Team
The x32 case for the recvmsg() timout handling is broken: asmlinkage long compat_sys_recvmmsg(int fd, struct compat_mmsghdr __user *mmsg, unsigned int vlen, unsigned int flags, struct compat_timespec __user *timeout) { int datagrams; struct timespec ktspec; if (flags & MSG_CMSG_COMPAT) return -EINVAL; if (COMPAT_USE_64BIT_TIME) return __sys_recvmmsg(fd, (struct mmsghdr __user *)mmsg, vlen, flags | MSG_CMSG_COMPAT, (struct timespec *) timeout); ... The timeout pointer parameter is provided by userland (hence the __user annotation) but for x32 syscalls it's simply cast to a kernel pointer and is passed to __sys_recvmmsg which will eventually directly dereference it for both reading and writing. Other callers to __sys_recvmmsg properly copy from userland to the kernel first. The bug was introduced by commit ee4fa23c4bfc ("compat: Use COMPAT_USE_64BIT_TIME in net/compat.c") and should affect all kernels since 3.4 (and perhaps vendor kernels if they backported x32 support along with this code). Note that CONFIG_X86_X32_ABI gets enabled at build time and only if CONFIG_X86_X32 is enabled and ld can build x32 executables. Other uses of COMPAT_USE_64BIT_TIME seem fine. This addresses CVE-2014-0038. Signed-off-by: PaX Team <pageexec@freemail.hu> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org> # v3.4+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-29net: clamp ->msg_namelen instead of returning an errorDan Carpenter
If kmsg->msg_namelen > sizeof(struct sockaddr_storage) then in the original code that would lead to memory corruption in the kernel if you had audit configured. If you didn't have audit configured it was harmless. There are some programs such as beta versions of Ruby which use too large of a buffer and returning an error code breaks them. We should clamp the ->msg_namelen value instead. Fixes: 1661bf364ae9 ("net: heap overflow in __audit_sockaddr()") Reported-by: Eric Wong <normalperson@yhbt.net> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Tested-by: Eric Wong <normalperson@yhbt.net> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-03net: heap overflow in __audit_sockaddr()Dan Carpenter
We need to cap ->msg_namelen or it leads to a buffer overflow when we to the memcpy() in __audit_sockaddr(). It requires CAP_AUDIT_CONTROL to exploit this bug. The call tree is: ___sys_recvmsg() move_addr_to_user() audit_sockaddr() __audit_sockaddr() Reported-by: Jüri Aedla <juri.aedla@gmail.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-06net: Unbreak compat_sys_{send,recv}msgAndy Lutomirski
I broke them in this commit: commit 1be374a0518a288147c6a7398792583200a67261 Author: Andy Lutomirski <luto@amacapital.net> Date: Wed May 22 14:07:44 2013 -0700 net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg This patch adds __sys_sendmsg and __sys_sendmsg as common helpers that accept MSG_CMSG_COMPAT and blocks MSG_CMSG_COMPAT at the syscall entrypoints. It also reverts some unnecessary checks in sys_socketcall. Apparently I was suffering from underscore blindness the first time around. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Tested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-26make get_file() return its argumentAl Viro
simplifies a bunch of callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22net: Fix references to out-of-scope variables in put_cmsg_compat()Jesper Juhl
In net/compat.c::put_cmsg_compat() we may assign 'data' the address of either the 'ctv' or 'cts' local variables inside the 'if (!COMPAT_USE_64BIT_TIME)' branch. Those variables go out of scope at the end of the 'if' statement, so when we use 'data' further down in 'copy_to_user(CMSG_COMPAT_DATA(cm), data, cmlen - sizeof(struct compat_cmsghdr))' there's no telling what it may be refering to - not good. Fix the problem by simply giving 'ctv' and 'cts' function scope. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "New notable features: - The seccomp work from Will Drewry - PR_{GET,SET}_NO_NEW_PRIVS from Andy Lutomirski - Longer security labels for Smack from Casey Schaufler - Additional ptrace restriction modes for Yama by Kees Cook" Fix up trivial context conflicts in arch/x86/Kconfig and include/linux/filter.h * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) apparmor: fix long path failure due to disconnected path apparmor: fix profile lookup for unconfined ima: fix filename hint to reflect script interpreter name KEYS: Don't check for NULL key pointer in key_validate() Smack: allow for significantly longer Smack labels v4 gfp flags for security_inode_alloc()? Smack: recursive tramsmute Yama: replace capable() with ns_capable() TOMOYO: Accept manager programs which do not start with / . KEYS: Add invalidation support KEYS: Do LRU discard in full keyrings KEYS: Permit in-place link replacement in keyring list KEYS: Perform RCU synchronisation on keys prior to key destruction KEYS: Announce key type (un)registration KEYS: Reorganise keys Makefile KEYS: Move the key config into security/keys/Kconfig KEYS: Use the compat keyctl() syscall wrapper on Sparc64 for Sparc32 compat Yama: remove an unused variable samples/seccomp: fix dependencies on arch macros Yama: add additional ptrace scopes ...
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-14net/compat.c,linux/filter.h: share compat_sock_fprogWill Drewry
Any other users of bpf_*_filter that take a struct sock_fprog from userspace will need to be able to also accept a compat_sock_fprog if the arch supports compat calls. This change allows the existing compat_sock_fprog be shared. Signed-off-by: Will Drewry <wad@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Eric Paris <eparis@redhat.com> v18: tasered by the apostrophe police v14: rebase/nochanges v13: rebase on to 88ebdda6159ffc15699f204c33feb3e431bf9bdc v12: rebase on to linux-next v11: introduction Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-11net: get rid of some pointless casts to sockaddrMaciej Żenczykowski
The following 4 functions: move_addr_to_kernel move_addr_to_user verify_iovec verify_compat_iovec are always effectively called with a sockaddr_storage. Make this explicit by changing their signature. This removes a large number of casts from sockaddr_storage to sockaddr. Signed-off-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-20compat: Use COMPAT_USE_64BIT_TIME in net/compat.cH. J. Lu
Handle 64-bit time structures in the networking core compat code. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-05net: Add sendmmsg socket system callAnton Blanchard
This patch adds a multiple message send syscall and is the send version of the existing recvmmsg syscall. This is heavily based on the patch by Arnaldo that added recvmmsg. I wrote a microbenchmark to test the performance gains of using this new syscall: http://ozlabs.org/~anton/junkcode/sendmmsg_test.c The test was run on a ppc64 box with a 10 Gbit network card. The benchmark can send both UDP and RAW ethernet packets. 64B UDP batch pkts/sec 1 804570 2 872800 (+ 8 %) 4 916556 (+14 %) 8 939712 (+17 %) 16 952688 (+18 %) 32 956448 (+19 %) 64 964800 (+20 %) 64B raw socket batch pkts/sec 1 1201449 2 1350028 (+12 %) 4 1461416 (+22 %) 8 1513080 (+26 %) 16 1541216 (+28 %) 32 1553440 (+29 %) 64 1557888 (+30 %) We see a 20% improvement in throughput on UDP send and 30% on raw socket send. [ Add sparc syscall entries. -DaveM ] Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-28net: Limit socket I/O iovec total length to INT_MAX.David S. Miller
This helps protect us from overflow issues down in the individual protocol sendmsg/recvmsg handlers. Once we hit INT_MAX we truncate out the rest of the iovec by setting the iov_len members to zero. This works because: 1) For SOCK_STREAM and SOCK_SEQPACKET sockets, partial writes are allowed and the application will just continue with another write to send the rest of the data. 2) For datagram oriented sockets, where there must be a one-to-one correspondance between write() calls and packets on the wire, INT_MAX is going to be far larger than the packet size limit the protocol is going to check for and signal with -EMSGSIZE. Based upon a patch by Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03From abbffa2aa9bd6f8df16d0d0a102af677510d8b9a Mon Sep 17 00:00:00 2001Eric Dumazet
From: Eric Dumazet <eric.dumazet@gmail.com> Date: Thu, 3 Jun 2010 04:29:41 +0000 Subject: [PATCH 2/3] net: net/socket.c and net/compat.c cleanups cleanup patch, to match modern coding style. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> --- net/compat.c | 47 ++++++++--------- net/socket.c | 165 ++++++++++++++++++++++++++++------------------------------ 2 files changed, 102 insertions(+), 110 deletions(-) diff --git a/net/compat.c b/net/compat.c index 1cf7590..63d260e 100644 --- a/net/compat.c +++ b/net/compat.c @@ -81,7 +81,7 @@ int verify_compat_iovec(struct msghdr *kern_msg, struct iovec *kern_iov, int tot_len; if (kern_msg->msg_namelen) { - if (mode==VERIFY_READ) { + if (mode == VERIFY_READ) { int err = move_addr_to_kernel(kern_msg->msg_name, kern_msg->msg_namelen, kern_address); @@ -354,7 +354,7 @@ static int do_set_attach_filter(struct socket *sock, int level, int optname, static int do_set_sock_timeout(struct socket *sock, int level, int optname, char __user *optval, unsigned int optlen) { - struct compat_timeval __user *up = (struct compat_timeval __user *) optval; + struct compat_timeval __user *up = (struct compat_timeval __user *)optval; struct timeval ktime; mm_segment_t old_fs; int err; @@ -367,7 +367,7 @@ static int do_set_sock_timeout(struct socket *sock, int level, return -EFAULT; old_fs = get_fs(); set_fs(KERNEL_DS); - err = sock_setsockopt(sock, level, optname, (char *) &ktime, sizeof(ktime)); + err = sock_setsockopt(sock, level, optname, (char *)&ktime, sizeof(ktime)); set_fs(old_fs); return err; @@ -389,11 +389,10 @@ asmlinkage long compat_sys_setsockopt(int fd, int level, int optname, char __user *optval, unsigned int optlen) { int err; - struct socket *sock; + struct socket *sock = sockfd_lookup(fd, &err); - if ((sock = sockfd_lookup(fd, &err))!=NULL) - { - err = security_socket_setsockopt(sock,level,optname); + if (sock) { + err = security_socket_setsockopt(sock, level, optname); if (err) { sockfd_put(sock); return err; @@ -453,7 +452,7 @@ static int compat_sock_getsockopt(struct socket *sock, int level, int optname, int compat_sock_get_timestamp(struct sock *sk, struct timeval __user *userstamp) { struct compat_timeval __user *ctv = - (struct compat_timeval __user*) userstamp; + (struct compat_timeval __user *) userstamp; int err = -ENOENT; struct timeval tv; @@ -477,7 +476,7 @@ EXPORT_SYMBOL(compat_sock_get_timestamp); int compat_sock_get_timestampns(struct sock *sk, struct timespec __user *userstamp) { struct compat_timespec __user *ctv = - (struct compat_timespec __user*) userstamp; + (struct compat_timespec __user *) userstamp; int err = -ENOENT; struct timespec ts; @@ -502,12 +501,10 @@ asmlinkage long compat_sys_getsockopt(int fd, int level, int optname, char __user *optval, int __user *optlen) { int err; - struct socket *sock; + struct socket *sock = sockfd_lookup(fd, &err); - if ((sock = sockfd_lookup(fd, &err))!=NULL) - { - err = security_socket_getsockopt(sock, level, - optname); + if (sock) { + err = security_socket_getsockopt(sock, level, optname); if (err) { sockfd_put(sock); return err; @@ -557,7 +554,7 @@ struct compat_group_filter { int compat_mc_setsockopt(struct sock *sock, int level, int optname, char __user *optval, unsigned int optlen, - int (*setsockopt)(struct sock *,int,int,char __user *,unsigned int)) + int (*setsockopt)(struct sock *, int, int, char __user *, unsigned int)) { char __user *koptval = optval; int koptlen = optlen; @@ -640,12 +637,11 @@ int compat_mc_setsockopt(struct sock *sock, int level, int optname, } return setsockopt(sock, level, optname, koptval, koptlen); } - EXPORT_SYMBOL(compat_mc_setsockopt); int compat_mc_getsockopt(struct sock *sock, int level, int optname, char __user *optval, int __user *optlen, - int (*getsockopt)(struct sock *,int,int,char __user *,int __user *)) + int (*getsockopt)(struct sock *, int, int, char __user *, int __user *)) { struct compat_group_filter __user *gf32 = (void *)optval; struct group_filter __user *kgf; @@ -681,7 +677,7 @@ int compat_mc_getsockopt(struct sock *sock, int level, int optname, __put_user(interface, &kgf->gf_interface) || __put_user(fmode, &kgf->gf_fmode) || __put_user(numsrc, &kgf->gf_numsrc) || - copy_in_user(&kgf->gf_group,&gf32->gf_group,sizeof(kgf->gf_group))) + copy_in_user(&kgf->gf_group, &gf32->gf_group, sizeof(kgf->gf_group))) return -EFAULT; err = getsockopt(sock, level, optname, (char __user *)kgf, koptlen); @@ -714,21 +710,22 @@ int compat_mc_getsockopt(struct sock *sock, int level, int optname, copylen = numsrc * sizeof(gf32->gf_slist[0]); if (copylen > klen) copylen = klen; - if (copy_in_user(gf32->gf_slist, kgf->gf_slist, copylen)) + if (copy_in_user(gf32->gf_slist, kgf->gf_slist, copylen)) return -EFAULT; } return err; } - EXPORT_SYMBOL(compat_mc_getsockopt); /* Argument list sizes for compat_sys_socketcall */ #define AL(x) ((x) * sizeof(u32)) -static unsigned char nas[20]={AL(0),AL(3),AL(3),AL(3),AL(2),AL(3), - AL(3),AL(3),AL(4),AL(4),AL(4),AL(6), - AL(6),AL(2),AL(5),AL(5),AL(3),AL(3), - AL(4),AL(5)}; +static unsigned char nas[20] = { + AL(0), AL(3), AL(3), AL(3), AL(2), AL(3), + AL(3), AL(3), AL(4), AL(4), AL(4), AL(6), + AL(6), AL(2), AL(5), AL(5), AL(3), AL(3), + AL(4), AL(5) +}; #undef AL asmlinkage long compat_sys_sendmsg(int fd, struct compat_msghdr __user *msg, unsigned flags) @@ -827,7 +824,7 @@ asmlinkage long compat_sys_socketcall(int call, u32 __user *args) compat_ptr(a[4]), compat_ptr(a[5])); break; case SYS_SHUTDOWN: - ret = sys_shutdown(a0,a1); + ret = sys_shutdown(a0, a1); break; case SYS_SETSOCKOPT: ret = compat_sys_setsockopt(a0, a1, a[2], diff --git a/net/socket.c b/net/socket.c index 367d547..b63c051 100644 --- a/net/socket.c +++ b/net/socket.c @@ -124,7 +124,7 @@ static int sock_fasync(int fd, struct file *filp, int on); static ssize_t sock_sendpage(struct file *file, struct page *page, int offset, size_t size, loff_t *ppos, int more); static ssize_t sock_splice_read(struct file *file, loff_t *ppos, - struct pipe_inode_info *pipe, size_t len, + struct pipe_inode_info *pipe, size_t len, unsigned int flags); /* @@ -162,7 +162,7 @@ static const struct net_proto_family *net_families[NPROTO] __read_mostly; * Statistics counters of the socket lists */ -static DEFINE_PER_CPU(int, sockets_in_use) = 0; +static DEFINE_PER_CPU(int, sockets_in_use); /* * Support routines. @@ -309,9 +309,9 @@ static int init_inodecache(void) } static const struct super_operations sockfs_ops = { - .alloc_inode = sock_alloc_inode, - .destroy_inode =sock_destroy_inode, - .statfs = simple_statfs, + .alloc_inode = sock_alloc_inode, + .destroy_inode = sock_destroy_inode, + .statfs = simple_statfs, }; static int sockfs_get_sb(struct file_system_type *fs_type, @@ -411,6 +411,7 @@ int sock_map_fd(struct socket *sock, int flags) return fd; } +EXPORT_SYMBOL(sock_map_fd); static struct socket *sock_from_file(struct file *file, int *err) { @@ -422,7 +423,7 @@ static struct socket *sock_from_file(struct file *file, int *err) } /** - * sockfd_lookup - Go from a file number to its socket slot + * sockfd_lookup - Go from a file number to its socket slot * @fd: file handle * @err: pointer to an error code return * @@ -450,6 +451,7 @@ struct socket *sockfd_lookup(int fd, int *err) fput(file); return sock; } +EXPORT_SYMBOL(sockfd_lookup); static struct socket *sockfd_lookup_light(int fd, int *err, int *fput_needed) { @@ -540,6 +542,7 @@ void sock_release(struct socket *sock) } sock->file = NULL; } +EXPORT_SYMBOL(sock_release); int sock_tx_timestamp(struct msghdr *msg, struct sock *sk, union skb_shared_tx *shtx) @@ -586,6 +589,7 @@ int sock_sendmsg(struct socket *sock, struct msghdr *msg, size_t size) ret = wait_on_sync_kiocb(&iocb); return ret; } +EXPORT_SYMBOL(sock_sendmsg); int kernel_sendmsg(struct socket *sock, struct msghdr *msg, struct kvec *vec, size_t num, size_t size) @@ -604,6 +608,7 @@ int kernel_sendmsg(struct socket *sock, struct msghdr *msg, set_fs(oldfs); return result; } +EXPORT_SYMBOL(kernel_sendmsg); static int ktime2ts(ktime_t kt, struct timespec *ts) { @@ -664,7 +669,6 @@ void __sock_recv_timestamp(struct msghdr *msg, struct sock *sk, put_cmsg(msg, SOL_SOCKET, SCM_TIMESTAMPING, sizeof(ts), &ts); } - EXPORT_SYMBOL_GPL(__sock_recv_timestamp); inline void sock_recv_drops(struct msghdr *msg, struct sock *sk, struct sk_buff *skb) @@ -720,6 +724,7 @@ int sock_recvmsg(struct socket *sock, struct msghdr *msg, ret = wait_on_sync_kiocb(&iocb); return ret; } +EXPORT_SYMBOL(sock_recvmsg); static int sock_recvmsg_nosec(struct socket *sock, struct msghdr *msg, size_t size, int flags) @@ -752,6 +757,7 @@ int kernel_recvmsg(struct socket *sock, struct msghdr *msg, set_fs(oldfs); return result; } +EXPORT_SYMBOL(kernel_recvmsg); static void sock_aio_dtor(struct kiocb *iocb) { @@ -774,7 +780,7 @@ static ssize_t sock_sendpage(struct file *file, struct page *page, } static ssize_t sock_splice_read(struct file *file, loff_t *ppos, - struct pipe_inode_info *pipe, size_t len, + struct pipe_inode_info *pipe, size_t len, unsigned int flags) { struct socket *sock = file->private_data; @@ -887,7 +893,7 @@ static ssize_t sock_aio_write(struct kiocb *iocb, const struct iovec *iov, */ static DEFINE_MUTEX(br_ioctl_mutex); -static int (*br_ioctl_hook) (struct net *, unsigned int cmd, void __user *arg) = NULL; +static int (*br_ioctl_hook) (struct net *, unsigned int cmd, void __user *arg); void brioctl_set(int (*hook) (struct net *, unsigned int, void __user *)) { @@ -895,7 +901,6 @@ void brioctl_set(int (*hook) (struct net *, unsigned int, void __user *)) br_ioctl_hook = hook; mutex_unlock(&br_ioctl_mutex); } - EXPORT_SYMBOL(brioctl_set); static DEFINE_MUTEX(vlan_ioctl_mutex); @@ -907,7 +912,6 @@ void vlan_ioctl_set(int (*hook) (struct net *, void __user *)) vlan_ioctl_hook = hook; mutex_unlock(&vlan_ioctl_mutex); } - EXPORT_SYMBOL(vlan_ioctl_set); static DEFINE_MUTEX(dlci_ioctl_mutex); @@ -919,7 +923,6 @@ void dlci_ioctl_set(int (*hook) (unsigned int, void __user *)) dlci_ioctl_hook = hook; mutex_unlock(&dlci_ioctl_mutex); } - EXPORT_SYMBOL(dlci_ioctl_set); static long sock_do_ioctl(struct net *net, struct socket *sock, @@ -1047,6 +1050,7 @@ out_release: sock = NULL; goto out; } +EXPORT_SYMBOL(sock_create_lite); /* No kernel lock held - perfect */ static unsigned int sock_poll(struct file *file, poll_table *wait) @@ -1147,6 +1151,7 @@ call_kill: rcu_read_unlock(); return 0; } +EXPORT_SYMBOL(sock_wake_async); static int __sock_create(struct net *net, int family, int type, int protocol, struct socket **res, int kern) @@ -1265,11 +1270,13 @@ int sock_create(int family, int type, int protocol, struct socket **res) { return __sock_create(current->nsproxy->net_ns, family, type, protocol, res, 0); } +EXPORT_SYMBOL(sock_create); int sock_create_kern(int family, int type, int protocol, struct socket **res) { return __sock_create(&init_net, family, type, protocol, res, 1); } +EXPORT_SYMBOL(sock_create_kern); SYSCALL_DEFINE3(socket, int, family, int, type, int, protocol) { @@ -1474,7 +1481,8 @@ SYSCALL_DEFINE4(accept4, int, fd, struct sockaddr __user *, upeer_sockaddr, goto out; err = -ENFILE; - if (!(newsock = sock_alloc())) + newsock = sock_alloc(); + if (!newsock) goto out_put; newsock->type = sock->type; @@ -1861,8 +1869,7 @@ SYSCALL_DEFINE3(sendmsg, int, fd, struct msghdr __user *, msg, unsigned, flags) if (MSG_CMSG_COMPAT & flags) { if (get_compat_msghdr(&msg_sys, msg_compat)) return -EFAULT; - } - else if (copy_from_user(&msg_sys, msg, sizeof(struct msghdr))) + } else if (copy_from_user(&msg_sys, msg, sizeof(struct msghdr))) return -EFAULT; sock = sockfd_lookup_light(fd, &err, &fput_needed); @@ -1964,8 +1971,7 @@ static int __sys_recvmsg(struct socket *sock, struct msghdr __user *msg, if (MSG_CMSG_COMPAT & flags) { if (get_compat_msghdr(msg_sys, msg_compat)) return -EFAULT; - } - else if (copy_from_user(msg_sys, msg, sizeof(struct msghdr))) + } else if (copy_from_user(msg_sys, msg, sizeof(struct msghdr))) return -EFAULT; err = -EMSGSIZE; @@ -2191,10 +2197,10 @@ SYSCALL_DEFINE5(recvmmsg, int, fd, struct mmsghdr __user *, mmsg, /* Argument list sizes for sys_socketcall */ #define AL(x) ((x) * sizeof(unsigned long)) static const unsigned char nargs[20] = { - AL(0),AL(3),AL(3),AL(3),AL(2),AL(3), - AL(3),AL(3),AL(4),AL(4),AL(4),AL(6), - AL(6),AL(2),AL(5),AL(5),AL(3),AL(3), - AL(4),AL(5) + AL(0), AL(3), AL(3), AL(3), AL(2), AL(3), + AL(3), AL(3), AL(4), AL(4), AL(4), AL(6), + AL(6), AL(2), AL(5), AL(5), AL(3), AL(3), + AL(4), AL(5) }; #undef AL @@ -2340,6 +2346,7 @@ int sock_register(const struct net_proto_family *ops) printk(KERN_INFO "NET: Registered protocol family %d\n", ops->family); return err; } +EXPORT_SYMBOL(sock_register); /** * sock_unregister - remove a protocol handler @@ -2366,6 +2373,7 @@ void sock_unregister(int family) printk(KERN_INFO "NET: Unregistered protocol family %d\n", family); } +EXPORT_SYMBOL(sock_unregister); static int __init sock_init(void) { @@ -2490,13 +2498,13 @@ static int dev_ifconf(struct net *net, struct compat_ifconf __user *uifc32) ifc.ifc_req = NULL; uifc = compat_alloc_user_space(sizeof(struct ifconf)); } else { - size_t len =((ifc32.ifc_len / sizeof (struct compat_ifreq)) + 1) * - sizeof (struct ifreq); + size_t len = ((ifc32.ifc_len / sizeof(struct compat_ifreq)) + 1) * + sizeof(struct ifreq); uifc = compat_alloc_user_space(sizeof(struct ifconf) + len); ifc.ifc_len = len; ifr = ifc.ifc_req = (void __user *)(uifc + 1); ifr32 = compat_ptr(ifc32.ifcbuf); - for (i = 0; i < ifc32.ifc_len; i += sizeof (struct compat_ifreq)) { + for (i = 0; i < ifc32.ifc_len; i += sizeof(struct compat_ifreq)) { if (copy_in_user(ifr, ifr32, sizeof(struct compat_ifreq))) return -EFAULT; ifr++; @@ -2516,9 +2524,9 @@ static int dev_ifconf(struct net *net, struct compat_ifconf __user *uifc32) ifr = ifc.ifc_req; ifr32 = compat_ptr(ifc32.ifcbuf); for (i = 0, j = 0; - i + sizeof (struct compat_ifreq) <= ifc32.ifc_len && j < ifc.ifc_len; - i += sizeof (struct compat_ifreq), j += sizeof (struct ifreq)) { - if (copy_in_user(ifr32, ifr, sizeof (struct compat_ifreq))) + i + sizeof(struct compat_ifreq) <= ifc32.ifc_len && j < ifc.ifc_len; + i += sizeof(struct compat_ifreq), j += sizeof(struct ifreq)) { + if (copy_in_user(ifr32, ifr, sizeof(struct compat_ifreq))) return -EFAULT; ifr32++; ifr++; @@ -2567,7 +2575,7 @@ static int compat_siocwandev(struct net *net, struct compat_ifreq __user *uifr32 compat_uptr_t uptr32; struct ifreq __user *uifr; - uifr = compat_alloc_user_space(sizeof (*uifr)); + uifr = compat_alloc_user_space(sizeof(*uifr)); if (copy_in_user(uifr, uifr32, sizeof(struct compat_ifreq))) return -EFAULT; @@ -2601,9 +2609,9 @@ static int bond_ioctl(struct net *net, unsigned int cmd, return -EFAULT; old_fs = get_fs(); - set_fs (KERNEL_DS); + set_fs(KERNEL_DS); err = dev_ioctl(net, cmd, &kifr); - set_fs (old_fs); + set_fs(old_fs); return err; case SIOCBONDSLAVEINFOQUERY: @@ -2710,9 +2718,9 @@ static int compat_sioc_ifmap(struct net *net, unsigned int cmd, return -EFAULT; old_fs = get_fs(); - set_fs (KERNEL_DS); + set_fs(KERNEL_DS); err = dev_ioctl(net, cmd, (void __user *)&ifr); - set_fs (old_fs); + set_fs(old_fs); if (cmd == SIOCGIFMAP && !err) { err = copy_to_user(uifr32, &ifr, sizeof(ifr.ifr_name)); @@ -2734,7 +2742,7 @@ static int compat_siocshwtstamp(struct net *net, struct compat_ifreq __user *uif compat_uptr_t uptr32; struct ifreq __user *uifr; - uifr = compat_alloc_user_space(sizeof (*uifr)); + uifr = compat_alloc_user_space(sizeof(*uifr)); if (copy_in_user(uifr, uifr32, sizeof(struct compat_ifreq))) return -EFAULT; @@ -2750,20 +2758,20 @@ static int compat_siocshwtstamp(struct net *net, struct compat_ifreq __user *uif } struct rtentry32 { - u32 rt_pad1; + u32 rt_pad1; struct sockaddr rt_dst; /* target address */ struct sockaddr rt_gateway; /* gateway addr (RTF_GATEWAY) */ struct sockaddr rt_genmask; /* target network mask (IP) */ - unsigned short rt_flags; - short rt_pad2; - u32 rt_pad3; - unsigned char rt_tos; - unsigned char rt_class; - short rt_pad4; - short rt_metric; /* +1 for binary compatibility! */ + unsigned short rt_flags; + short rt_pad2; + u32 rt_pad3; + unsigned char rt_tos; + unsigned char rt_class; + short rt_pad4; + short rt_metric; /* +1 for binary compatibility! */ /* char * */ u32 rt_dev; /* forcing the device at add */ - u32 rt_mtu; /* per route MTU/Window */ - u32 rt_window; /* Window clamping */ + u32 rt_mtu; /* per route MTU/Window */ + u32 rt_window; /* Window clamping */ unsigned short rt_irtt; /* Initial RTT */ }; @@ -2793,29 +2801,29 @@ static int routing_ioctl(struct net *net, struct socket *sock, if (sock && sock->sk && sock->sk->sk_family == AF_INET6) { /* ipv6 */ struct in6_rtmsg32 __user *ur6 = argp; - ret = copy_from_user (&r6.rtmsg_dst, &(ur6->rtmsg_dst), + ret = copy_from_user(&r6.rtmsg_dst, &(ur6->rtmsg_dst), 3 * sizeof(struct in6_addr)); - ret |= __get_user (r6.rtmsg_type, &(ur6->rtmsg_type)); - ret |= __get_user (r6.rtmsg_dst_len, &(ur6->rtmsg_dst_len)); - ret |= __get_user (r6.rtmsg_src_len, &(ur6->rtmsg_src_len)); - ret |= __get_user (r6.rtmsg_metric, &(ur6->rtmsg_metric)); - ret |= __get_user (r6.rtmsg_info, &(ur6->rtmsg_info)); - ret |= __get_user (r6.rtmsg_flags, &(ur6->rtmsg_flags)); - ret |= __get_user (r6.rtmsg_ifindex, &(ur6->rtmsg_ifindex)); + ret |= __get_user(r6.rtmsg_type, &(ur6->rtmsg_type)); + ret |= __get_user(r6.rtmsg_dst_len, &(ur6->rtmsg_dst_len)); + ret |= __get_user(r6.rtmsg_src_len, &(ur6->rtmsg_src_len)); + ret |= __get_user(r6.rtmsg_metric, &(ur6->rtmsg_metric)); + ret |= __get_user(r6.rtmsg_info, &(ur6->rtmsg_info)); + ret |= __get_user(r6.rtmsg_flags, &(ur6->rtmsg_flags)); + ret |= __get_user(r6.rtmsg_ifindex, &(ur6->rtmsg_ifindex)); r = (void *) &r6; } else { /* ipv4 */ struct rtentry32 __user *ur4 = argp; - ret = copy_from_user (&r4.rt_dst, &(ur4->rt_dst), + ret = copy_from_user(&r4.rt_dst, &(ur4->rt_dst), 3 * sizeof(struct sockaddr)); - ret |= __get_user (r4.rt_flags, &(ur4->rt_flags)); - ret |= __get_user (r4.rt_metric, &(ur4->rt_metric)); - ret |= __get_user (r4.rt_mtu, &(ur4->rt_mtu)); - ret |= __get_user (r4.rt_window, &(ur4->rt_window)); - ret |= __get_user (r4.rt_irtt, &(ur4->rt_irtt)); - ret |= __get_user (rtdev, &(ur4->rt_dev)); + ret |= __get_user(r4.rt_flags, &(ur4->rt_flags)); + ret |= __get_user(r4.rt_metric, &(ur4->rt_metric)); + ret |= __get_user(r4.rt_mtu, &(ur4->rt_mtu)); + ret |= __get_user(r4.rt_window, &(ur4->rt_window)); + ret |= __get_user(r4.rt_irtt, &(ur4->rt_irtt)); + ret |= __get_user(rtdev, &(ur4->rt_dev)); if (rtdev) { - ret |= copy_from_user (devname, compat_ptr(rtdev), 15); + ret |= copy_from_user(devname, compat_ptr(rtdev), 15); r4.rt_dev = devname; devname[15] = 0; } else r4.rt_dev = NULL; @@ -2828,9 +2836,9 @@ static int routing_ioctl(struct net *net, struct socket *sock, goto out; } - set_fs (KERNEL_DS); + set_fs(KERNEL_DS); ret = sock_do_ioctl(net, sock, cmd, (unsigned long) r); - set_fs (old_fs); + set_fs(old_fs); out: return ret; @@ -2993,11 +3001,13 @@ int kernel_bind(struct socket *sock, struct sockaddr *addr, int addrlen) { return sock->ops->bind(sock, addr, addrlen); } +EXPORT_SYMBOL(kernel_bind); int kernel_listen(struct socket *sock, int backlog) { return sock->ops->listen(sock, backlog); } +EXPORT_SYMBOL(kernel_listen); int kernel_accept(struct socket *sock, struct socket **newsock, int flags) { @@ -3022,24 +3032,28 @@ int kernel_accept(struct socket *sock, struct socket **newsock, int flags) done: return err; } +EXPORT_SYMBOL(kernel_accept); int kernel_connect(struct socket *sock, struct sockaddr *addr, int addrlen, int flags) { return sock->ops->connect(sock, addr, addrlen, flags); } +EXPORT_SYMBOL(kernel_connect); int kernel_getsockname(struct socket *sock, struct sockaddr *addr, int *addrlen) { return sock->ops->getname(sock, addr, addrlen, 0); } +EXPORT_SYMBOL(kernel_getsockname); int kernel_getpeername(struct socket *sock, struct sockaddr *addr, int *addrlen) { return sock->ops->getname(sock, addr, addrlen, 1); } +EXPORT_SYMBOL(kernel_getpeername); int kernel_getsockopt(struct socket *sock, int level, int optname, char *optval, int *optlen) @@ -3056,6 +3070,7 @@ int kernel_getsockopt(struct socket *sock, int level, int optname, set_fs(oldfs); return err; } +EXPORT_SYMBOL(kernel_getsockopt); int kernel_setsockopt(struct socket *sock, int level, int optname, char *optval, unsigned int optlen) @@ -3072,6 +3087,7 @@ int kernel_setsockopt(struct socket *sock, int level, int optname, set_fs(oldfs); return err; } +EXPORT_SYMBOL(kernel_setsockopt); int kernel_sendpage(struct socket *sock, struct page *page, int offset, size_t size, int flags) @@ -3083,6 +3099,7 @@ int kernel_sendpage(struct socket *sock, struct page *page, int offset, return sock_no_sendpage(sock, page, offset, size, flags); } +EXPORT_SYMBOL(kernel_sendpage); int kernel_sock_ioctl(struct socket *sock, int cmd, unsigned long arg) { @@ -3095,33 +3112,11 @@ int kernel_sock_ioctl(struct socket *sock, int cmd, unsigned long arg) return err; } +EXPORT_SYMBOL(kernel_sock_ioctl); int kernel_sock_shutdown(struct socket *sock, enum sock_shutdown_cmd how) { return sock->ops->shutdown(sock, how); } - -EXPORT_SYMBOL(sock_create); -EXPORT_SYMBOL(sock_create_kern); -EXPORT_SYMBOL(sock_create_lite); -EXPORT_SYMBOL(sock_map_fd); -EXPORT_SYMBOL(sock_recvmsg); -EXPORT_SYMBOL(sock_register); -EXPORT_SYMBOL(sock_release); -EXPORT_SYMBOL(sock_sendmsg); -EXPORT_SYMBOL(sock_unregister); -EXPORT_SYMBOL(sock_wake_async); -EXPORT_SYMBOL(sockfd_lookup); -EXPORT_SYMBOL(kernel_sendmsg); -EXPORT_SYMBOL(kernel_recvmsg); -EXPORT_SYMBOL(kernel_bind); -EXPORT_SYMBOL(kernel_listen); -EXPORT_SYMBOL(kernel_accept); -EXPORT_SYMBOL(kernel_connect); -EXPORT_SYMBOL(kernel_getsockname); -EXPORT_SYMBOL(kernel_getpeername); -EXPORT_SYMBOL(kernel_getsockopt); -EXPORT_SYMBOL(kernel_setsockopt); -EXPORT_SYMBOL(kernel_sendpage); -EXPORT_SYMBOL(kernel_sock_ioctl); EXPORT_SYMBOL(kernel_sock_shutdown); + -- 1.7.0.4
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-11net: use compat helper functions in compat_sys_recvmmsgHeiko Carstens
Use (get|put)_compat_timespec helper functions to simplify the code. Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11net: fix compat_sys_recvmmsg parameter typeHeiko Carstens
compat_sys_recvmmsg has a compat_timespec parameter and not a timespec parameter. This way we also get rid of an odd cast. Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02net: compat_sys_recvmmsg user timespec arg can be NULLJean-Mickael Guerin
We must test if user timespec is non-NULL before copying from userpace, same as sys_recvmmsg(). Commiter note: changed it so that we have just one branch. Signed-off-by: Jean-Mickael Guerin <jean-mickael.guerin@6wind.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29net: Cleanup redundant tests on unsignedroel kluin
optlen is unsigned so the `< 0' test is never true. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Introduce recvmmsg socket syscallArnaldo Carvalho de Melo
Meaning receive multiple messages, reducing the number of syscalls and net stack entry/exit operations. Next patches will introduce mechanisms where protocols that want to optimize this operation will provide an unlocked_recvmsg operation. This takes into account comments made by: . Paul Moore: sock_recvmsg is called only for the first datagram, sock_recvmsg_nosec is used for the rest. . Caitlin Bestler: recvmmsg now has a struct timespec timeout, that works in the same fashion as the ppoll one. If the underlying protocol returns a datagram with MSG_OOB set, this will make recvmmsg return right away with as many datagrams (+ the OOB one) it has received so far. . Rémi Denis-Courmont & Steven Whitehouse: If we receive N < vlen datagrams and then recvmsg returns an error, recvmmsg will return the successfully received datagrams, store the error and return it in the next call. This paves the way for a subsequent optimization, sk_prot->unlocked_recvmsg, where we will be able to acquire the lock only at batch start and end, not at every underlying recvmsg call. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-15net/compat/wext: send different messages to compat tasksJohannes Berg
Wireless extensions have the unfortunate problem that events are multicast netlink messages, and are not independent of pointer size. Thus, currently 32-bit tasks on 64-bit platforms cannot properly receive events and fail with all kinds of strange problems, for instance wpa_supplicant never notices disassociations, due to the way the 64-bit event looks (to a 32-bit process), the fact that the address is all zeroes is lost, it thinks instead it is 00:00:00:00:01:00. The same problem existed with the ioctls, until David Miller fixed those some time ago in an heroic effort. A different problem caused by this is that we cannot send the ASSOCREQIE/ASSOCRESPIE events because sending them causes a 32-bit wpa_supplicant on a 64-bit system to overwrite its internal information, which is worse than it not getting the information at all -- so we currently resort to sending a custom string event that it then parses. This, however, has a severe size limitation we are frequently hitting with modern access points; this limitation would can be lifted after this patch by sending the correct binary, not custom, event. A similar problem apparently happens for some other netlink users on x86_64 with 32-bit tasks due to the alignment for 64-bit quantities. In order to fix these problems, I have implemented a way to send compat messages to tasks. When sending an event, we send the non-compat event data together with a compat event data in skb_shinfo(main_skb)->frag_list. Then, when the event is read from the socket, the netlink code makes sure to pass out only the skb that is compatible with the task. This approach was suggested by David Miller, my original approach required always sending two skbs but that had various small problems. To determine whether compat is needed or not, I have used the MSG_CMSG_COMPAT flag, and adjusted the call path for recv and recvfrom to include it, even if those calls do not have a cmsg parameter. I have not solved one small part of the problem, and I don't think it is necessary to: if a 32-bit application uses read() rather than any form of recvmsg() it will still get the wrong (64-bit) event. However, neither do applications actually do this, nor would it be a regression. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15net: socket infrastructure for SO_TIMESTAMPINGPatrick Ohly
The overlap with the old SO_TIMESTAMP[NS] options is handled so that time stamping in software (net_enable_timestamp()) is enabled when SO_TIMESTAMP[NS] and/or SO_TIMESTAMPING_RX_SOFTWARE is set. It's disabled if all of these are off. Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19reintroduce accept4Ulrich Drepper
Introduce a new accept4() system call. The addition of this system call matches analogous changes in 2.6.27 (dup3(), evenfd2(), signalfd4(), inotify_init1(), epoll_create1(), pipe2()) which added new system calls that differed from analogous traditional system calls in adding a flags argument that can be used to access additional functionality. The accept4() system call is exactly the same as accept(), except that it adds a flags bit-mask argument. Two flags are initially implemented. (Most of the new system calls in 2.6.27 also had both of these flags.) SOCK_CLOEXEC causes the close-on-exec (FD_CLOEXEC) flag to be enabled for the new file descriptor returned by accept4(). This is a useful security feature to avoid leaking information in a multithreaded program where one thread is doing an accept() at the same time as another thread is doing a fork() plus exec(). More details here: http://udrepper.livejournal.com/20407.html "Secure File Descriptor Handling", Ulrich Drepper). The other flag is SOCK_NONBLOCK, which causes the O_NONBLOCK flag to be enabled on the new open file description created by accept4(). (This flag is merely a convenience, saving the use of additional calls fcntl(F_GETFL) and fcntl (F_SETFL) to achieve the same result. Here's a test program. Works on x86-32. Should work on x86-64, but I (mtk) don't have a system to hand to test with. It tests accept4() with each of the four possible combinations of SOCK_CLOEXEC and SOCK_NONBLOCK set/clear in 'flags', and verifies that the appropriate flags are set on the file descriptor/open file description returned by accept4(). I tested Ulrich's patch in this thread by applying against 2.6.28-rc2, and it passes according to my test program. /* test_accept4.c Copyright (C) 2008, Linux Foundation, written by Michael Kerrisk <mtk.manpages@gmail.com> Licensed under the GNU GPLv2 or later. */ #define _GNU_SOURCE #include <unistd.h> #include <sys/syscall.h> #include <sys/socket.h> #include <netinet/in.h> #include <stdlib.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #define PORT_NUM 33333 #define die(msg) do { perror(msg); exit(EXIT_FAILURE); } while (0) /**********************************************************************/ /* The following is what we need until glibc gets a wrapper for accept4() */ /* Flags for socket(), socketpair(), accept4() */ #ifndef SOCK_CLOEXEC #define SOCK_CLOEXEC O_CLOEXEC #endif #ifndef SOCK_NONBLOCK #define SOCK_NONBLOCK O_NONBLOCK #endif #ifdef __x86_64__ #define SYS_accept4 288 #elif __i386__ #define USE_SOCKETCALL 1 #define SYS_ACCEPT4 18 #else #error "Sorry -- don't know the syscall # on this architecture" #endif static int accept4(int fd, struct sockaddr *sockaddr, socklen_t *addrlen, int flags) { printf("Calling accept4(): flags = %x", flags); if (flags != 0) { printf(" ("); if (flags & SOCK_CLOEXEC) printf("SOCK_CLOEXEC"); if ((flags & SOCK_CLOEXEC) && (flags & SOCK_NONBLOCK)) printf(" "); if (flags & SOCK_NONBLOCK) printf("SOCK_NONBLOCK"); printf(")"); } printf("\n"); #if USE_SOCKETCALL long args[6]; args[0] = fd; args[1] = (long) sockaddr; args[2] = (long) addrlen; args[3] = flags; return syscall(SYS_socketcall, SYS_ACCEPT4, args); #else return syscall(SYS_accept4, fd, sockaddr, addrlen, flags); #endif } /**********************************************************************/ static int do_test(int lfd, struct sockaddr_in *conn_addr, int closeonexec_flag, int nonblock_flag) { int connfd, acceptfd; int fdf, flf, fdf_pass, flf_pass; struct sockaddr_in claddr; socklen_t addrlen; printf("=======================================\n"); connfd = socket(AF_INET, SOCK_STREAM, 0); if (connfd == -1) die("socket"); if (connect(connfd, (struct sockaddr *) conn_addr, sizeof(struct sockaddr_in)) == -1) die("connect"); addrlen = sizeof(struct sockaddr_in); acceptfd = accept4(lfd, (struct sockaddr *) &claddr, &addrlen, closeonexec_flag | nonblock_flag); if (acceptfd == -1) { perror("accept4()"); close(connfd); return 0; } fdf = fcntl(acceptfd, F_GETFD); if (fdf == -1) die("fcntl:F_GETFD"); fdf_pass = ((fdf & FD_CLOEXEC) != 0) == ((closeonexec_flag & SOCK_CLOEXEC) != 0); printf("Close-on-exec flag is %sset (%s); ", (fdf & FD_CLOEXEC) ? "" : "not ", fdf_pass ? "OK" : "failed"); flf = fcntl(acceptfd, F_GETFL); if (flf == -1) die("fcntl:F_GETFD"); flf_pass = ((flf & O_NONBLOCK) != 0) == ((nonblock_flag & SOCK_NONBLOCK) !=0); printf("nonblock flag is %sset (%s)\n", (flf & O_NONBLOCK) ? "" : "not ", flf_pass ? "OK" : "failed"); close(acceptfd); close(connfd); printf("Test result: %s\n", (fdf_pass && flf_pass) ? "PASS" : "FAIL"); return fdf_pass && flf_pass; } static int create_listening_socket(int port_num) { struct sockaddr_in svaddr; int lfd; int optval; memset(&svaddr, 0, sizeof(struct sockaddr_in)); svaddr.sin_family = AF_INET; svaddr.sin_addr.s_addr = htonl(INADDR_ANY); svaddr.sin_port = htons(port_num); lfd = socket(AF_INET, SOCK_STREAM, 0); if (lfd == -1) die("socket"); optval = 1; if (setsockopt(lfd, SOL_SOCKET, SO_REUSEADDR, &optval, sizeof(optval)) == -1) die("setsockopt"); if (bind(lfd, (struct sockaddr *) &svaddr, sizeof(struct sockaddr_in)) == -1) die("bind"); if (listen(lfd, 5) == -1) die("listen"); return lfd; } int main(int argc, char *argv[]) { struct sockaddr_in conn_addr; int lfd; int port_num; int passed; passed = 1; port_num = (argc > 1) ? atoi(argv[1]) : PORT_NUM; memset(&conn_addr, 0, sizeof(struct sockaddr_in)); conn_addr.sin_family = AF_INET; conn_addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK); conn_addr.sin_port = htons(port_num); lfd = create_listening_socket(port_num); if (!do_test(lfd, &conn_addr, 0, 0)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, 0)) passed = 0; if (!do_test(lfd, &conn_addr, 0, SOCK_NONBLOCK)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, SOCK_NONBLOCK)) passed = 0; close(lfd); exit(passed ? EXIT_SUCCESS : EXIT_FAILURE); } [mtk.manpages@gmail.com: rewrote changelog, updated test program] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-12net: put_cmsg_compat + SO_TIMESTAMP[NS]: use same name for value as callerPatrick Ohly
In __sock_recv_timestamp() the additional SCM_TIMESTAMP[NS] is used. This has the same value as SO_TIMESTAMP[NS], so this is a purely cosmetic change. Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-24flag parameters: pacceptUlrich Drepper
This patch is by far the most complex in the series. It adds a new syscall paccept. This syscall differs from accept in that it adds (at the userlevel) two additional parameters: - a signal mask - a flags value The flags parameter can be used to set flag like SOCK_CLOEXEC. This is imlpemented here as well. Some people argued that this is a property which should be inherited from the file desriptor for the server but this is against POSIX. Additionally, we really want the signal mask parameter as well (similar to pselect, ppoll, etc). So an interface change in inevitable. The flag value is the same as for socket and socketpair. I think diverging here will only create confusion. Similar to the filesystem interfaces where the use of the O_* constants differs, it is acceptable here. The signal mask is handled as for pselect etc. The mask is temporarily installed for the thread and removed before the call returns. I modeled the code after pselect. If there is a problem it's likely also in pselect. For architectures which use socketcall I maintained this interface instead of adding a system call. The symmetry shouldn't be broken. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <errno.h> #include <fcntl.h> #include <pthread.h> #include <signal.h> #include <stdio.h> #include <unistd.h> #include <netinet/in.h> #include <sys/socket.h> #include <sys/syscall.h> #ifndef __NR_paccept # ifdef __x86_64__ # define __NR_paccept 288 # elif defined __i386__ # define SYS_PACCEPT 18 # define USE_SOCKETCALL 1 # else # error "need __NR_paccept" # endif #endif #ifdef USE_SOCKETCALL # define paccept(fd, addr, addrlen, mask, flags) \ ({ long args[6] = { \ (long) fd, (long) addr, (long) addrlen, (long) mask, 8, (long) flags }; \ syscall (__NR_socketcall, SYS_PACCEPT, args); }) #else # define paccept(fd, addr, addrlen, mask, flags) \ syscall (__NR_paccept, fd, addr, addrlen, mask, 8, flags) #endif #define PORT 57392 #define SOCK_CLOEXEC O_CLOEXEC static pthread_barrier_t b; static void * tf (void *arg) { pthread_barrier_wait (&b); int s = socket (AF_INET, SOCK_STREAM, 0); struct sockaddr_in sin; sin.sin_family = AF_INET; sin.sin_addr.s_addr = htonl (INADDR_LOOPBACK); sin.sin_port = htons (PORT); connect (s, (const struct sockaddr *) &sin, sizeof (sin)); close (s); pthread_barrier_wait (&b); s = socket (AF_INET, SOCK_STREAM, 0); sin.sin_port = htons (PORT); connect (s, (const struct sockaddr *) &sin, sizeof (sin)); close (s); pthread_barrier_wait (&b); pthread_barrier_wait (&b); sleep (2); pthread_kill ((pthread_t) arg, SIGUSR1); return NULL; } static void handler (int s) { } int main (void) { pthread_barrier_init (&b, NULL, 2); struct sockaddr_in sin; pthread_t th; if (pthread_create (&th, NULL, tf, (void *) pthread_self ()) != 0) { puts ("pthread_create failed"); return 1; } int s = socket (AF_INET, SOCK_STREAM, 0); int reuse = 1; setsockopt (s, SOL_SOCKET, SO_REUSEADDR, &reuse, sizeof (reuse)); sin.sin_family = AF_INET; sin.sin_addr.s_addr = htonl (INADDR_LOOPBACK); sin.sin_port = htons (PORT); bind (s, (struct sockaddr *) &sin, sizeof (sin)); listen (s, SOMAXCONN); pthread_barrier_wait (&b); int s2 = paccept (s, NULL, 0, NULL, 0); if (s2 < 0) { puts ("paccept(0) failed"); return 1; } int coe = fcntl (s2, F_GETFD); if (coe & FD_CLOEXEC) { puts ("paccept(0) set close-on-exec-flag"); return 1; } close (s2); pthread_barrier_wait (&b); s2 = paccept (s, NULL, 0, NULL, SOCK_CLOEXEC); if (s2 < 0) { puts ("paccept(SOCK_CLOEXEC) failed"); return 1; } coe = fcntl (s2, F_GETFD); if ((coe & FD_CLOEXEC) == 0) { puts ("paccept(SOCK_CLOEXEC) does not set close-on-exec flag"); return 1; } close (s2); pthread_barrier_wait (&b); struct sigaction sa; sa.sa_handler = handler; sa.sa_flags = 0; sigemptyset (&sa.sa_mask); sigaction (SIGUSR1, &sa, NULL); sigset_t ss; pthread_sigmask (SIG_SETMASK, NULL, &ss); sigaddset (&ss, SIGUSR1); pthread_sigmask (SIG_SETMASK, &ss, NULL); sigdelset (&ss, SIGUSR1); alarm (4); pthread_barrier_wait (&b); errno = 0 ; s2 = paccept (s, NULL, 0, &ss, 0); if (s2 != -1 || errno != EINTR) { puts ("paccept did not fail with EINTR"); return 1; } close (s); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: make it compile] [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roland McGrath <roland@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19net: Use standard structures for generic socket address structures.YOSHIFUJI Hideaki
Use sockaddr_storage{} for generic socket address storage and ensures proper alignment. Use sockaddr{} for pointers to omit several casts. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29net: Add compat support for getsockopt (MCAST_MSFILTER)David L Stevens
This patch adds support for getsockopt for MCAST_MSFILTER for both IPv4 and IPv6. It depends on the previous setsockopt patch, and uses the same method. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29net: Several cleanups for the setsockopt compat support.David L Stevens
1) added missing "__user" for kgsr and kgf pointers 2) verify read for only GROUP_FILTER_SIZE(0). The group_filter structure definition (via RFC) includes space for one source in the source list array, but that source need not be present. So, sizeof(group_filter) > GROUP_FILTER_SIZE(0). Fixed the user read-check for minimum length to use the smaller size. 3) remove unneeded "&" for gf_slist addresses Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
