path: root/net/compat.c
2008-01-28[NETFILTER]: ip6_tables: add compat supportPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-20[NET]: Fix function put_cmsg() which may cause usr application memory overflowWei Yongjun
When used function put_cmsg() to copy kernel information to user application memory, if the memory length given by user application is not enough, by the bad length calculate of msg.msg_controllen, put_cmsg() function may cause the msg.msg_controllen to be a large value, such as 0xFFFFFFF0, so the following put_cmsg() can also write data to usr application memory even usr has no valid memory to store this. This may cause usr application memory overflow. int put_cmsg(struct msghdr * msg, int level, int type, int len, void *data) { struct cmsghdr __user *cm = (__force struct cmsghdr __user *)msg->msg_control; struct cmsghdr cmhdr; int cmlen = CMSG_LEN(len); ~~~~~~~~~~~~~~~~~~~~~ int err; if (MSG_CMSG_COMPAT & msg->msg_flags) return put_cmsg_compat(msg, level, type, len, data); if (cm==NULL || msg->msg_controllen < sizeof(*cm)) { msg->msg_flags |= MSG_CTRUNC; return 0; /* XXX: return error? check spec. */ } if (msg->msg_controllen < cmlen) { ~~~~~~~~~~~~~~~~~~~~~~~~ msg->msg_flags |= MSG_CTRUNC; cmlen = msg->msg_controllen; } cmhdr.cmsg_level = level; cmhdr.cmsg_type = type; cmhdr.cmsg_len = cmlen; err = -EFAULT; if (copy_to_user(cm, &cmhdr, sizeof cmhdr)) goto out; if (copy_to_user(CMSG_DATA(cm), data, cmlen - sizeof(struct cmsghdr))) goto out; cmlen = CMSG_SPACE(len); ~~~~~~~~~~~~~~~~~~~~~~~~~~~ If MSG_CTRUNC flags is set, msg->msg_controllen is less than CMSG_SPACE(len), "msg->msg_controllen -= cmlen" will cause unsinged int type msg->msg_controllen to be a large value. ~~~~~~~~~~~~~~~~~~~~~~~~~~~ msg->msg_control += cmlen; msg->msg_controllen -= cmlen; ~~~~~~~~~~~~~~~~~~~~~ err = 0; out: return err; } The same promble exists in put_cmsg_compat(). This patch can fix this problem. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16O_CLOEXEC for SCM_RIGHTSUlrich Drepper
Part two in the O_CLOEXEC saga: adding support for file descriptors received through Unix domain sockets. The patch is once again pretty minimal, it introduces a new flag for recvmsg and passes it just like the existing MSG_CMSG_COMPAT flag. I think this bit is not used otherwise but the networking people will know better. This new flag is not recognized by recvfrom and recv. These functions cannot be used for that purpose and the asymmetry this introduces is not worse than the already existing MSG_CMSG_COMPAT situations. The patch must be applied on the patch which introduced O_CLOEXEC. It has to remove static from the new get_unused_fd_flags function but since scm.c cannot live in a module the function still hasn't to be exported. Here's a test program to make sure the code works. It's so much longer than the actual patch... #include <errno.h> #include <error.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #include <unistd.h> #include <sys/socket.h> #include <sys/un.h> #ifndef O_CLOEXEC # define O_CLOEXEC 02000000 #endif #ifndef MSG_CMSG_CLOEXEC # define MSG_CMSG_CLOEXEC 0x40000000 #endif int main (int argc, char *argv[]) { if (argc > 1) { int fd = atol (argv[1]); printf ("child: fd = %d\n", fd); if (fcntl (fd, F_GETFD) == 0 || errno != EBADF) { puts ("file descriptor valid in child"); return 1; } return 0; } struct sockaddr_un sun; strcpy (sun.sun_path, "./testsocket"); sun.sun_family = AF_UNIX; char databuf[] = "hello"; struct iovec iov[1]; iov[0].iov_base = databuf; iov[0].iov_len = sizeof (databuf); union { struct cmsghdr hdr; char bytes[CMSG_SPACE (sizeof (int))]; } buf; struct msghdr msg = { .msg_iov = iov, .msg_iovlen = 1, .msg_control = buf.bytes, .msg_controllen = sizeof (buf) }; struct cmsghdr *cmsg = CMSG_FIRSTHDR (&msg); cmsg->cmsg_level = SOL_SOCKET; cmsg->cmsg_type = SCM_RIGHTS; cmsg->cmsg_len = CMSG_LEN (sizeof (int)); msg.msg_controllen = cmsg->cmsg_len; pid_t child = fork (); if (child == -1) error (1, errno, "fork"); if (child == 0) { int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (bind (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "bind"); if (listen (sock, SOMAXCONN) < 0) error (1, errno, "listen"); int conn = accept (sock, NULL, NULL); if (conn == -1) error (1, errno, "accept"); *(int *) CMSG_DATA (cmsg) = sock; if (sendmsg (conn, &msg, MSG_NOSIGNAL) < 0) error (1, errno, "sendmsg"); return 0; } /* For a test suite this should be more robust like a barrier in shared memory. */ sleep (1); int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (connect (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "connect"); unlink (sun.sun_path); *(int *) CMSG_DATA (cmsg) = -1; if (recvmsg (sock, &msg, MSG_CMSG_CLOEXEC) < 0) error (1, errno, "recvmsg"); int fd = *(int *) CMSG_DATA (cmsg); if (fd == -1) error (1, 0, "no descriptor received"); char fdname[20]; snprintf (fdname, sizeof (fdname), "%d", fd); execl ("/proc/self/exe", argv[0], fdname, NULL); puts ("execl failed"); return 1; } [akpm@linux-foundation.org: Fix fastcall inconsistency noted by Michael Buesch] [akpm@linux-foundation.org: build fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Buesch <mb@bu3sch.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[NET]: Adding SO_TIMESTAMPNS / SCM_TIMESTAMPNS supportEric Dumazet
Now that network timestamps use ktime_t infrastructure, we can add a new SOL_SOCKET sockopt SO_TIMESTAMPNS. This command is similar to SO_TIMESTAMP, but permits transmission of a 'timespec struct' instead of a 'timeval struct' control message. (nanosecond resolution instead of microsecond) Control message is labelled SCM_TIMESTAMPNS instead of SCM_TIMESTAMP A socket cannot mix SO_TIMESTAMP and SO_TIMESTAMPNS : the two modes are mutually exclusive. sock_recv_timestamp() became too big to be fully inlined so I added a __sock_recv_timestamp() helper function. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: linux-arch@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] core: whitespace cleanupStephen Hemminger
Fix whitespace around keywords. Fix indentation especially of switch statements. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: convert network timestamps to ktime_tEric Dumazet
We currently use a special structure (struct skb_timeval) and plain 'struct timeval' to store packet timestamps in sk_buffs and struct sock. This has some drawbacks : - Fixed resolution of micro second. - Waste of space on 64bit platforms where sizeof(struct timeval)=16 I suggest using ktime_t that is a nice abstraction of high resolution time services, currently capable of nanosecond resolution. As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits a 8 byte shrink of this structure on 64bit architectures. Some other structures also benefit from this size reduction (struct ipq in ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...) Once this ktime infrastructure adopted, we can more easily provide nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or SO_TIMESTAMPNS/SCM_TIMESTAMPNS) Note : this patch includes a bug correction in compat_sock_get_timestamp() where a "err = 0;" was missing (so this syscall returned -ENOENT instead of 0) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> CC: John find <linux.kernel@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET]: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[NET]: File descriptor loss while receiving SCM_RIGHTSMiklos Szeredi
If more than one file descriptor was sent with an SCM_RIGHTS message, and on the receiving end, after installing a nonzero (but not all) file descritpors the process runs out of fds, then the already installed fds will be lost (userspace will have no way of knowing about them). The following patch makes sure, that at least the already installed fds are sent to userspace. It doesn't solve the issue of losing file descriptors in case of an EFAULT on the userspace buffer. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-01[NETFILTER]: iptables 32bit compat layerDmitry Mishin
This patch extends current iptables compatibility layer in order to get 32bit iptables to work on 64bit kernel. Current layer is insufficient due to alignment checks both in kernel and user space tools. Patch is for current net-2.6.17 with addition of move of ipt_entry_{match| target} definitions to xt_entry_{match|target}. Signed-off-by: Dmitry Mishin <dim@openvz.org> Acked-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-21[NET]: socket timestamp 32 bit handler for 64 bit kernelShaun Pereira
Get socket timestamp handler function that does not use the ioctl32_hash_table. Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: {get|set}sockopt compatibility layerDmitry Mishin
This patch extends {get|set}sockopt compatibility layer in order to move protocol specific parts to their place and avoid huge universal net/compat.c file in the future. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-08[PATCH] Fix 32bit sendmsg() flawAl Viro
When we copy 32bit ->msg_control contents to kernel, we walk the same userland data twice without sanity checks on the second pass. Second version of this patch: the original broke with 64-bit arches running 32-bit-compat-mode executables doing sendmsg() syscalls with unaligned CMSG data areas Another thing is that we use kmalloc() to allocate and sock_kfree_s() to free afterwards; less serious, but also needs fixing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Chris Wright <chrisw@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[NET]: Fix memory leak in sys_{send,recv}msg() w/compatAndrew Morton
From: Dave Johnson <djohnson+linux-kernel@sw.starentnetworks.com> sendmsg()/recvmsg() syscalls from o32/n32 apps to a 64bit kernel will cause a kernel memory leak if iov_len > UIO_FASTIOV for each syscall! This is because both sys_sendmsg() and verify_compat_iovec() kmalloc a new iovec structure. Only the one from sys_sendmsg() is free'ed. I wrote a simple test program to confirm this after identifying the problem: http://davej.org/programs/testsendmsg.c Note that the below fix will break solaris_sendmsg()/solaris_recvmsg() as it also calls verify_compat_iovec() but expects it to malloc internally. [ I fixed that. -DaveM ] Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
