[ Upstream commit d323e92cc3f4edd943610557c9ea1bb4bb5056e8 ]
maxattr in genl_family should be used to save the max attribute
type, but not the max command type. Drop monitor doesn't support
any attributes, so we should leave it as zero.
drop_monitor calls several sleeping functions while in atomic context.
BUG: sleeping function called from invalid context at mm/slub.c:943
in_atomic(): 1, irqs_disabled(): 0, pid: 2103, name: kworker/0:2
Pid: 2103, comm: kworker/0:2 Not tainted 3.5.0-rc1+ #55
Call Trace:
[<ffffffff810697ca>] __might_sleep+0xca/0xf0
[<ffffffff811345a3>] kmem_cache_alloc_node+0x1b3/0x1c0
[<ffffffff8105578c>] ? queue_delayed_work_on+0x11c/0x130
[<ffffffff815343fb>] __alloc_skb+0x4b/0x230
[<ffffffffa00b0360>] ? reset_per_cpu_data+0x160/0x160 [drop_monitor]
[<ffffffffa00b022f>] reset_per_cpu_data+0x2f/0x160 [drop_monitor]
[<ffffffffa00b03ab>] send_dm_alert+0x4b/0xb0 [drop_monitor]
[<ffffffff810568e0>] process_one_work+0x130/0x4c0
[<ffffffff81058249>] worker_thread+0x159/0x360
[<ffffffff810580f0>] ? manage_workers.isra.27+0x240/0x240
[<ffffffff8105d403>] kthread+0x93/0xa0
[<ffffffff816be6d4>] kernel_thread_helper+0x4/0x10
[<ffffffff8105d370>] ? kthread_freezable_should_stop+0x80/0x80
[<ffffffff816be6d0>] ? gs_change+0xb/0xb
Rework the logic to call the sleeping functions in right context.
Use standard timer/workqueue api to let system chose any cpu to perform
the allocation and netlink send.
Also avoid a loop if reset_per_cpu_data() cannot allocate memory :
use mod_timer() to wait 1/10 second before next try.
Cc: Neil Horman <nhorman@tuxdriver.com>
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
Now that we have module alias macros for generic netlink families, lets use
those to mark modules with the appropriate family names for loading
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: David Miller <davem@davemloft.net>
When I first wrote drop monitor I wrote it to just build monolithically. There
is no reason it can't be built modularly as well, so lets give it that
flexibiity.
I've tested this by building it as both a module and monolithically, and it
seems to work quite well
Change notes:
v2)
* fixed for_each_present_cpu loops to be more correct as per Eric D.
* Converted exit path failures to BUG_ON as per Ben H.
v3)
* Converted del_timer to del_timer_sync to close race noted by Ben H.
CC: "David S. Miller" <davem@davemloft.net>
CC: Ben Hutchings <bhutchings@solarflare.com>
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
Use the current logging style.
This enables use of dynamic debugging as well.
Convert printk(KERN_<LEVEL> to pr_<level>.
Add pr_fmt. Remove embedded prefixes, use
%s, __func__ instead.
I just noticed after some recent updates, that the init path for the drop
monitor protocol has a minor error. drop monitor maintains a per cpu structure,
that gets initalized from a single cpu. Normally this is fine, as the protocol
isn't in use yet, but I recently made a change that causes a failed skb
allocation to reschedule itself . Given the current code, the implication is
that this workqueue reschedule will take place on the wrong cpu. If drop
monitor is used early during the boot process, its possible that two cpus will
access a single per-cpu structure in parallel, possibly leading to data
corruption.
This patch fixes the situation, by storing the cpu number that a given instance
of this per-cpu data should be accessed from. In the case of a need for a
reschedule, the cpu stored in the struct is assigned the rescheule, rather than
the currently executing cpu
Tested successfully by myself.
Eric Dumazet pointed out to me that the drop_monitor protocol has some holes in
its smp protections. Specifically, its possible to replace data->skb while its
being written. This patch corrects that by making data->skb an rcu protected
variable. That will prevent it from being overwritten while a tracepoint is
modifying it.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Eric Dumazet pointed out this warning in the drop_monitor protocol to me:
[ 38.352571] BUG: sleeping function called from invalid context at kernel/mutex.c:85
[ 38.352576] in_atomic(): 1, irqs_disabled(): 0, pid: 4415, name: dropwatch
[ 38.352580] Pid: 4415, comm: dropwatch Not tainted 3.4.0-rc2+ #71
[ 38.352582] Call Trace:
[ 38.352592] [<ffffffff8153aaf0>] ? trace_napi_poll_hit+0xd0/0xd0
[ 38.352599] [<ffffffff81063f2a>] __might_sleep+0xca/0xf0
[ 38.352606] [<ffffffff81655b16>] mutex_lock+0x26/0x50
[ 38.352610] [<ffffffff8153aaf0>] ? trace_napi_poll_hit+0xd0/0xd0
[ 38.352616] [<ffffffff810b72d9>] tracepoint_probe_register+0x29/0x90
[ 38.352621] [<ffffffff8153a585>] set_all_monitor_traces+0x105/0x170
[ 38.352625] [<ffffffff8153a8ca>] net_dm_cmd_trace+0x2a/0x40
[ 38.352630] [<ffffffff8154a81a>] genl_rcv_msg+0x21a/0x2b0
[ 38.352636] [<ffffffff810f8029>] ? zone_statistics+0x99/0xc0
[ 38.352640] [<ffffffff8154a600>] ? genl_rcv+0x30/0x30
[ 38.352645] [<ffffffff8154a059>] netlink_rcv_skb+0xa9/0xd0
[ 38.352649] [<ffffffff8154a5f0>] genl_rcv+0x20/0x30
[ 38.352653] [<ffffffff81549a7e>] netlink_unicast+0x1ae/0x1f0
[ 38.352658] [<ffffffff81549d76>] netlink_sendmsg+0x2b6/0x310
[ 38.352663] [<ffffffff8150824f>] sock_sendmsg+0x10f/0x130
[ 38.352668] [<ffffffff8150abe0>] ? move_addr_to_kernel+0x60/0xb0
[ 38.352673] [<ffffffff81515f04>] ? verify_iovec+0x64/0xe0
[ 38.352677] [<ffffffff81509c46>] __sys_sendmsg+0x386/0x390
[ 38.352682] [<ffffffff810ffaf9>] ? handle_mm_fault+0x139/0x210
[ 38.352687] [<ffffffff8165b5bc>] ? do_page_fault+0x1ec/0x4f0
[ 38.352693] [<ffffffff8106ba4d>] ? set_next_entity+0x9d/0xb0
[ 38.352699] [<ffffffff81310b49>] ? tty_ldisc_deref+0x9/0x10
[ 38.352703] [<ffffffff8106d363>] ? pick_next_task_fair+0x63/0x140
[ 38.352708] [<ffffffff8150b8d4>] sys_sendmsg+0x44/0x80
[ 38.352713] [<ffffffff8165f8e2>] system_call_fastpath+0x16/0x1b
It stems from holding a spinlock (trace_state_lock) while attempting to register
or unregister tracepoint hooks, making in_atomic() true in this context, leading
to the warning when the tracepoint calls might_sleep() while its taking a mutex.
Since we only use the trace_state_lock to prevent trace protocol state races, as
well as hardware stat list updates on an rcu write side, we can just convert the
spinlock to a mutex to avoid this problem.
It seems there is a logic error in trace_drop_common(), since we store
only 64 drops, even if they are from same location.
This fix is a one liner, but we probably need more work to avoid useless
atomic dec/inc
Now I can watch 1 Mpps drops through dropwatch...
The rcu callback free_dm_hw_stat() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(free_dm_hw_stat).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
It was pointed out to me recently that my spelling could be better :)
[ Fix unused local variable build warnings. -DaveM ]
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Patch to add -EAGAIN error to dropwatch netlink message handling code.
-EAGAIN will be returned anytime userspace attempts to transition the state of
the drop monitor service to a state that its already in. That allows user space
to detect this condition, so it doesn't wait for a success ACK that will never
arrive. Tested successfully by me
This patch adds data to be passed to tracepoint callbacks.
The created functions from DECLARE_TRACE() now need a mandatory data
parameter. For example:
DECLARE_TRACE(mytracepoint, int value, value)
Will create the register function:
int register_trace_mytracepoint((void(*)(void *data, int value))probe,
void *data);
As the first argument, all callbacks (probes) must take a (void *data)
parameter. So a callback for the above tracepoint will look like:
void myprobe(void *data, int value)
The callback may choose to ignore the data parameter.
This change allows callbacks to register a private data pointer along
with the function probe.
void mycallback(void *data, int value);
register_trace_mytracepoint(mycallback, mydata);
Then the mycallback() will receive the "mydata" as the first parameter
before the args.
A more detailed example:
DECLARE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status));
/* In the C file */
DEFINE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status));
trace_mytracepoint(status);
/* In a file registering this tracepoint */
int my_callback(void *data, int status)
struct my_struct my_data = data;
my_data = kmalloc(sizeof(*my_data), GFP_KERNEL);
init_my_data(my_data);
register_trace_mytracepoint(my_callback, my_data);
The same callback can also be registered to the same tracepoint as long
as the data registered is different. Note, the data must also be used
to unregister the callback:
unregister_trace_mytracepoint(my_callback, my_data);
Because of the data parameter, tracepoints declared this way can not have
no args. That is:
DECLARE_TRACE(mytracepoint, TP_PROTO(void), TP_ARGS());
will cause an error.
If no arguments are needed, a new macro can be used instead:
DECLARE_TRACE_NOARGS(mytracepoint);
Since there are no arguments, the proto and args fields are left out.
This is part of a series to make the tracepoint footprint smaller:
4913961 1088356 861512 6863829 68bbd5 vmlinux.orig
4914025 1088868 861512 6864405 68be15 vmlinux.class
4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint
Again, this patch also increases the size of the kernel, but
lays the ground work for decreasing it.
v5: Fixed net/core/drop_monitor.c to handle these updates.
v4: Moved the DECLARE_TRACE() DECLARE_TRACE_NOARGS out of the
#ifdef CONFIG_TRACE_POINTS, since the two are the same in both
cases. The __DECLARE_TRACE() is what changes.
Thanks to Frederic Weisbecker for pointing this out.
v3: Made all register_* functions require data to be passed and
all callbacks to take a void * parameter as its first argument.
This makes the calling functions comply with C standards.
Also added more comments to the modifications of DECLARE_TRACE().
v2: Made the DECLARE_TRACE() have the ability to pass arguments
and added a new DECLARE_TRACE_NOARGS() for tracepoints that
do not need any arguments.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
call_rcu() will unconditionally reinitialize RCU head anyway.
SPIN_LOCK_UNLOCKED is deprecated. Use DEFINE_SPINLOCK instead.
It was recently pointed out to me that the last_rx field of the
net_device structure wasn't updated regularly. In fact only the
bonding driver really uses it currently. Since the drop_monitor code
relies on the last_rx field to detect drops on recevie in hardware, We
need to find a more reliable way to rate limit our drop checks (so
that we don't check for drops on every frame recevied, which would be
inefficient. This patch makes a last_rx timestamp that is private to
the drop monitor code and is updated for every device that we track.
The net_dev of backlog napi is NULL, like below:
__get_cpu_var(softnet_data).backlog.dev == NULL
So, we should check it in napi tracepoint's probe function
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/net-traces.c
Patch to add the ability to detect drops in hardware interfaces via dropwatch.
Adds a tracepoint to net_rx_action to signal everytime a napi instance is
polled. The dropmon code then periodically checks to see if the rx_frames
counter has changed, and if so, adds a drop notification to the netlink
protocol, using the reserved all-0's vector to indicate the drop location was in
hardware, rather than somewhere in the code.
include/linux/net_dropmon.h | 8 ++
include/trace/napi.h | 11 +++
net/core/dev.c | 5 +
net/core/drop_monitor.c | 124 ++++++++++++++++++++++++++++++++++++++++++--
net/core/net-traces.c | 4 +
net/core/netpoll.c | 2
6 files changed, 149 insertions(+), 5 deletions(-)
alert message
When I initially implemented this protocol, I disregarded the use of netlink
attribute headers, thinking for my purposes they weren't needed. I've come to
find out that, as I'm starting to work with sending down messages with
associated data (like config messages), the kernel code spits out warnings about
trailing data in a netlink skb that doesn't have an associated header on it. As
such, I'm going to start including attribute headers in my netlink transaction,
and so for completeness, I should likely include them on messages bound from the
kernel to user space. This patch adds that header to the kernel, and bumps the
protocol version accordingly
Impact: clean up
Create a sub directory in include/trace called events to keep the
trace point headers in their own separate directory. Only headers that
declare trace points should be defined in this directory.
Cc: Zhao Lei <zhaolei@cn.fujitsu.com>
Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
include/linux/net_dropmon.h | 56 +++++++++
net/core/drop_monitor.c | 263 ++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 319 insertions(+)
